[Darshan-users] darshan-job-summary.pl question
Jeffrey Layton laytonjb at gmail.com
Wed May 20 09:16:38 CDT 2020
On Wed, May 20, 2020 at 10:12 AM Jeffrey Layton <laytonjb at gmail.com> wrote:
> On Tue, May 19, 2020 at 2:48 PM Snyder, Shane <ssnyder at mcs.anl.gov> wrote:
>> Not a problem at all, that's what we're here for. I'm sorry it hasn't
>> been as straightforward of a process getting this up and running as we'd
>> hope. FWIW, we really appreciate all of the feedback, this is all really
>> helpful!
> No worries. Anything I can do to help (BTW - I'm probably a strange bird,
> but I like doing documentation so if you have any needs or desired, let me
> know and I'll see what I can do).
> Also, I'm betting I'm one of the few to use Ubuntu 18.04 :)  I'm using
> Darshan for some work related things and I'm boxed into using Ubuntu 18.04
> exclusively. I actually like it so I'm not complaining, but it is a
> constraint.
>> It looks like the system you're using doesn't have the required Perl
>> Latex module we're using as part of darshan-job-summary. Can you try
>> installing the following package with your package manager to see if it
>> helps work around that:
>> texlive-latex-extra
>> We should update our documentation to clearly indicate that as another
>> explicit dependency, if so. That was probably just an oversight on our part.
> Installing this package got me further, but I'm getting an error about
> another missing package:
> $ darshan-job-summary.pl --output jeff.pdf
> /usr/local/darshan-logs/2020/5/19/laytonjb_ex1_id4630_5-19-28572-4707187774811817098_1589889373.darshan
> Can't locate Pod/LaTeX.pm in @INC (you may need to install the Pod::LaTeX
> module) (@INC contains: /usr/local/lib /etc/perl
> /usr/local/lib/x86_64-linux-gnu/perl/5.26.1 /usr/local/share/perl/5.26.1
> /usr/lib/x86_64-linux-gnu/perl5/5.26 /usr/share/perl5
> /usr/lib/x86_64-linux-gnu/perl/5.26 /usr/share/perl/5.26
> /usr/local/lib/site_perl /usr/lib/x86_64-linux-gnu/perl-base) at
> /usr/local/lib/TeX/Encode.pm line 10.
> BEGIN failed--compilation aborted at /usr/local/lib/TeX/Encode.pm line 10.
> Compilation failed in require at /usr/local/bin/darshan-job-summary.pl
> line 12.
> BEGIN failed--compilation aborted at /usr/local/bin/darshan-job-summary.pl
> line 12.
> I'm looking around for LaTeX.pm without much luck yet. The only thing I've
> found that is close is libpod-latex-perl but I'm struggling to find the
> corresponding package :)  I'm still looking but if you find the package I
> would appreciate it.
Aha! I found it: libpod-latex-perl.
Thanks!
Jeff
> Thanks!
> Jeff
>> --Shane
>> *From:* Darshan-users <darshan-users-bounces at lists.mcs.anl.gov> on
>> behalf of Jeffrey Layton <laytonjb at gmail.com>
>> *Sent:* Tuesday, May 19, 2020 9:46 AM
>> *To:* darshan-users at lists.mcs.anl.gov <darshan-users at lists.mcs.anl.gov>
>> *Subject:* [Darshan-users] darshan-job-summary.pl question
>> Good morning,
>> I really apologize for being a pest :)  I've been able to profile an
>> extremely simple C code and I'm ready to post-process. I wanted to
>> experiment with darshan-job-summary.pl. When I run it, I get the
>> following message:
>> line 12.
>> darshan-job-summary.pl line 12.
>> I installed the dependencies for the pdf output: gnuplot, pdflatex,
>> epstopdf (no errors during darshan-utils build and I can run these
>> commands). Am I missing a Perl module?
>> Thank you very much!
>> Jeff
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20200520/72669eaf/attachment-0001.html>
More information about the Darshan-users mailing list
