[Darshan-users] darshan-job-summary.pl question
Jeffrey Layton laytonjb at gmail.com
Tue May 19 09:46:53 CDT 2020
Good morning,
I really apologize for being a pest :)  I've been able to profile an
extremely simple C code and I'm ready to post-process. I wanted to
experiment with darshan-job-summary.pl. When I run it, I get the following
message:
$ darshan-job-summary.pl
/usr/local/darshan-logs/2020/5/19/laytonjb_ex1_id4630_5-19-28572-4707187774811817098_1589889373.darshan
Can't locate Pod/LaTeX.pm in @INC (you may need to install the Pod::LaTeX
module) (@INC contains: /usr/local/lib /etc/perl
/usr/local/lib/x86_64-linux-gnu/perl/5.26.1 /usr/local/share/perl/5.26.1
/usr/lib/x86_64-linux-gnu/perl5/5.26 /usr/share/perl5
/usr/lib/x86_64-linux-gnu/perl/5.26 /usr/share/perl/5.26
/usr/local/lib/site_perl /usr/lib/x86_64-linux-gnu/perl-base) at
/usr/local/lib/TeX/Encode.pm line 10.
BEGIN failed--compilation aborted at /usr/local/lib/TeX/Encode.pm line 10.
Compilation failed in require at /usr/local/bin/darshan-job-summary.pl line
12.
BEGIN failed--compilation aborted at /usr/local/bin/darshan-job-summary.pl
line 12.
I installed the dependencies for the pdf output: gnuplot, pdflatex,
epstopdf (no errors during darshan-utils build and I can run these
commands). Am I missing a Perl module?
Thank you very much!
Jeff
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20200519/0d0e07ad/attachment.html>
More information about the Darshan-users mailing list
