[Darshan-users] darshan-job-summary.pl question
Snyder, Shane ssnyder at mcs.anl.gov
Tue May 19 13:48:57 CDT 2020
Not a problem at all, that's what we're here for. I'm sorry it hasn't been as straightforward of a process getting this up and running as we'd hope. FWIW, we really appreciate all of the feedback, this is all really helpful!
It looks like the system you're using doesn't have the required Perl Latex module we're using as part of darshan-job-summary. Can you try installing the following package with your package manager to see if it helps work around that:
texlive-latex-extra
We should update our documentation to clearly indicate that as another explicit dependency, if so. That was probably just an oversight on our part.
--Shane
From: Darshan-users <darshan-users-bounces at lists.mcs.anl.gov> on behalf of Jeffrey Layton <laytonjb at gmail.com>
Sent: Tuesday, May 19, 2020 9:46 AM
To: darshan-users at lists.mcs.anl.gov <darshan-users at lists.mcs.anl.gov>
Subject: [Darshan-users] darshan-job-summary.pl question
Good morning,
I really apologize for being a pest :)  I've been able to profile an extremely simple C code and I'm ready to post-process. I wanted to experiment with darshan-job-summary.pl<http://darshan-job-summary.pl>. When I run it, I get the following message:
$ darshan-job-summary.pl<http://darshan-job-summary.pl> /usr/local/darshan-logs/2020/5/19/laytonjb_ex1_id4630_5-19-28572-4707187774811817098_1589889373.darshan
Can't locate Pod/LaTeX.pm in @INC (you may need to install the Pod::LaTeX module) (@INC contains: /usr/local/lib /etc/perl /usr/local/lib/x86_64-linux-gnu/perl/5.26.1 /usr/local/share/perl/5.26.1 /usr/lib/x86_64-linux-gnu/perl5/5.26 /usr/share/perl5 /usr/lib/x86_64-linux-gnu/perl/5.26 /usr/share/perl/5.26 /usr/local/lib/site_perl /usr/lib/x86_64-linux-gnu/perl-base) at /usr/local/lib/TeX/Encode.pm line 10.
BEGIN failed--compilation aborted at /usr/local/lib/TeX/Encode.pm line 10.
Compilation failed in require at /usr/local/bin/darshan-job-summary.pl<http://darshan-job-summary.pl> line 12.
BEGIN failed--compilation aborted at /usr/local/bin/darshan-job-summary.pl<http://darshan-job-summary.pl> line 12.
I installed the dependencies for the pdf output: gnuplot, pdflatex, epstopdf (no errors during darshan-utils build and I can run these commands). Am I missing a Perl module?
Thank you very much!
Jeff
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20200519/82cca2a0/attachment-0001.html>
More information about the Darshan-users mailing list
