[Darshan-users] Darshan & EPCC benchio different behaviour
    Carns, Philip H.
    carns at mcs.anl.gov
    Wed Feb 12 14:37:03 CST 2020
Thank you Piero, that does help quite a bit.  I don't know the cause, but I do see why Darshan reports a rate much higher than the benchmark.
The clue is in the write() timing if you zero in on a specific file, in this case serial.dat.1:
[carns at carns-x1-7g Downloads]$ darshan-parser benchio_1202.dn.darshan |grep serial.dat.1 |grep F_WRITE
POSIX 0 2553187295521652424 POSIX_F_WRITE_START_TIMESTAMP 0.350832 /gpfs/scratch/userinternal/planucar/benchio-master/shared-file/source/benchio_files/serial.dat.1 /gpfs/scratch gpfs
POSIX 0 2553187295521652424 POSIX_F_WRITE_END_TIMESTAMP 4.519859 /gpfs/scratch/userinternal/planucar/benchio-master/shared-file/source/benchio_files/serial.dat.1 /gpfs/scratch gpfs
POSIX 0 2553187295521652424 POSIX_F_WRITE_TIME 1.336200 /gpfs/scratch/userinternal/planucar/benchio-master/shared-file/source/benchio_files/serial.dat.1 /gpfs/scratch gpfs
The POSIX_F_WRITE_TIME shows the cumulative time in seconds was spent waiting on glibc write() calls: 1.3 seconds.
The POSIX_F_WRITE_{START/END}_TIMESTAMP show the elapsed time between when the first write started and the last write ended: 4.2 seconds.
Somehow almost 70% of the elapsed time measured by the benchmark is spent doing something between individual write() calls that make it to glibc.  The writes seem to be relatively sparse in time.
This doesn't make any sense if you look at the benchmark code, though.  The write loop is very simple, in fact it is just a tight loop calling write():
https://github.com/EPCCed/benchio/blob/master/shared-file/source/mpiio.F90#L154
Maybe someone on the list with more Fortran expertise than me can comment on why this might happen?  Is it possible that the Fortran runtime is doing something (buffering?) that consumes time in the Fortran-level write call before the data is actually relayed to the system?
As a side note we could use other heuristics for performance, but they all have their tradeoffs.  The one that would obviously work here (measuring time from first to last I/O) would break for other common patterns.
thanks,
-Phil
Sent: Wednesday, February 12, 2020 1:47 PM
To: Carns, Philip H. <carns at mcs.anl.gov>; Snyder, Shane <ssnyder at mcs.anl.gov>; Harms, Kevin <harms at alcf.anl.gov>
Cc: darshan-users at lists.mcs.anl.gov <darshan-users at lists.mcs.anl.gov>
Subject: Re: [Darshan-users] Darshan & EPCC benchio different behaviour
p.s
sorry, I forgotted to say that we built the environment (both Darshan and benchmark) using IntelMPI release mpiifort script:
 mpiifort -v
mpiifort for the Intel(R) MPI Library 2018 Update 4 for Linux*
Copyright(C) 2003-2018, Intel Corporation.  All rights reserved.
regards
Piero
Il 12/02/2020 16:54, Piero LANUCARA ha scritto:
Hi Phil
in attach
dn stands for different names....
cheers
Piero
Il 12/02/2020 16:13, Carns, Philip H. ha scritto:
Ah, great, thank you for the confirmation.
In that case it looks like Darshan is instrumenting properly at run time, but I think Kevin is on the right track that Darshan's heuristics for calculating performance in post processing are getting confused for some reason.
Probably GPFS is client-side caching aggressively in the single client case, but that wouldn't explain why the benchmark output reports a much different number than Darshan, though.  They should both perceive roughly the same performance; neither the benchmark itself nor Darshan know if caching is happening or not.
It's hard to see where the performance heuristic went wrong from looking at the log, in large part because the app repeatedly opens a file with the same name (there is a clue to this in the OPEN counters; the same file name is opened 20 times):
# WARNING: POSIX_OPENS counter includes both POSIX_FILENOS and POSIX_DUPS counts
POSIX 0 6563482044800691889 POSIX_OPENS 20 /gpfs/scratch/userinternal/planucar/benchio-master/shared-file/source/benchio_files/serial.dat /gpfs/scratch gpfs
Every time the file is opened (regardless of whether it was unlinked in between or not), Darshan keeps adding counters to the same record, which are associated with that serial.dat file name.  So things like close() timestamps become nonsensical because Darshan records when the first close() starts and when the last one finishes:
[carns at carns-x1-7g Downloads]$ darshan-parser benchio_1202.darshan |grep CLOSE
POSIX 0 6563482044800691889 POSIX_F_CLOSE_START_TIMESTAMP 4.536853/gpfs/scratch/userinternal/planucar/benchio-master/shared-file/source/benchio_files/serial.dat /gpfs/scratch gpfs
POSIX 0 6563482044800691889 POSIX_F_CLOSE_END_TIMESTAMP 43.041987 /gpfs/scratch/userinternal/planucar/benchio-master/shared-file/source/benchio_files/serial.dat /gpfs/scratch gpfs
(This doesn't mean there was one close() that took ~40 seconds; in this case there were many close() calls and ~40 seconds elapsed between the start of the first one and completion of the last one).
If it is possible for you to modify the benchmark (as an experiment) so that it chooses a new file name on each iteration, then I think it would probably disentangle the counters enough for us to tell what went wrong.
thanks,
-Phil
From: Piero LANUCARA <p.lanucara at cineca.it><mailto:p.lanucara at cineca.it>
Sent: Wednesday, February 12, 2020 9:47 AM
To: Carns, Philip H. <carns at mcs.anl.gov><mailto:carns at mcs.anl.gov>; Snyder, Shane <ssnyder at mcs.anl.gov><mailto:ssnyder at mcs.anl.gov>; Harms, Kevin <harms at alcf.anl.gov><mailto:harms at alcf.anl.gov>
Cc: darshan-users at lists.mcs.anl.gov<mailto:darshan-users at lists.mcs.anl.gov> <darshan-users at lists.mcs.anl.gov><mailto:darshan-users at lists.mcs.anl.gov>
Hi Phil.....POSIX
this is a well known benchmark ....you can easily verify it!
by the way it's something like that
! Serial write is unconditionally compiled
subroutine serialwrite(filename, iodata, n1, n2, n3, cartcomm)
  character*(*) :: filename
  integer :: n1, n2, n3
  double precision, dimension(0:n1+1,0:n2+1,0:n3+1) :: iodata
  integer :: cartcomm, ierr, rank, size
  integer, parameter :: iounit = 10
  integer :: i
  call MPI_Comm_size(cartcomm, size, ierr)
  call MPI_Comm_rank(cartcomm, rank, ierr)
!  Write same amount of data as the parallel write but do it all from rank 0
!  This is just to get a baseline figure for serial IO performance - note
!  that the contents of the file will be differnent from the parallel calls
  if (rank == 0) then
     open(file=filename, unit=iounit, access='stream')
     do i = 1, size
        write(unit=iounit) iodata(1:n1, 1:n2, 1:n3)
     end do
     close(iounit)
  end if
end subroutine serialwrite
Piero
Il 12/02/2020 14:13, Carns, Philip H. ha scritto:
Hi Piero,
In the serial case, is the rank that's doing I/O still using MPI-IO, or is it making calls directly to POSIX in that case?
The Darshan log for the serial case doesn't show any MPI-IO activity, but I'm not sure if that's accurate, or if it's an indication that we missed some instrumentation.
thanks,
-Phil
From: Darshan-users <darshan-users-bounces at lists.mcs.anl.gov><mailto:darshan-users-bounces at lists.mcs.anl.gov> on behalf of Piero LANUCARA <p.lanucara at cineca.it><mailto:p.lanucara at cineca.it>
Sent: Wednesday, February 12, 2020 5:29 AM
To: Snyder, Shane <ssnyder at mcs.anl.gov><mailto:ssnyder at mcs.anl.gov>; Harms, Kevin <harms at alcf.anl.gov><mailto:harms at alcf.anl.gov>
Hi Shane, Kevin
thanks for the update.
I attached a new upated files (log and pdf) to this email.
Also, the log from BENCHIO is attached.
thanks again
regards
Piero
Il 11/02/2020 20:15, Shane Snyder ha scritto:
> Definitely looks like something strange is happening when Darshan is
> estimating the time spent in I/O operations (as seen in the very first
> figure, observed write time barely even registers) in the serial case,
> which it is ultimately used to provide the performance estimate.
> If you could provide them, the raw Darshan logs would be really
> helpful. That should make it clear whether it's an instrumentation
> issue (i.e., under accounting for time spent in I/O operations at
> runtime) or if its an issue with the heuristics in the PDF summary
> tool you are using, as Kevin points out. If it's the latter, having an
> example log to test modifications to our heuristics would be very
> helpful to us.
> Thanks,
> --Shane
> On 2/11/20 8:36 AM, Harms, Kevin wrote:
>> Piero,
>>    the performance estimate is based on heuristics, it's possible the
>> 'serial' model is breaking some assumptions about how the I/O is
>> done. Is every rank opening the file, but only rank 0 is doing actual
>> I/O?
>>    If possible, you could provide the log and we could check to see
>> what the counters look like.
>> kevin
>> ________________________________________
>> Sent: Tuesday, February 11, 2020 2:28 AM
>> To: Harms, Kevin
>> Hi Kevin
>> first of all thanks for the investigation..I did some futher test and it
>> seems like the issue may appear using Fortran (MPI, mainly IntelMPI)
>> codes.
>> Is this information useful?
>> regards
>> Piero
>> Il 07/02/2020 16:07, Harms, Kevin ha scritto:
>>> Piero,
>>>     just to confirm, the serial case is still running in parallel,
>>> 36 processes, but the I/O is only from rank 0?
>>> kevin
>>> Sent: Wednesday, February 5, 2020 4:56 AM
>>> To: darshan-users at lists.mcs.anl.gov<mailto:darshan-users at lists.mcs.anl.gov>
>>> p.s
>>> to be more "verbose" I add to the discussion:
>>> Darshan output for the "serial" run (serial.pdf)
>>> Darshan output for the MPI-IO run (mpiio.pdf)
>>> benchio output for "serial" run (serial.out)
>>> benchio output for "MPI-IO" run (mpi-io.out)
>>> thanks
>>> Piero
>>> Il 04/02/2020 19:44, Piero LANUCARA ha scritto:
>>>> Dear all
>>>> I'm using Darshan to measure EPCC benchio benchmark
>>>> (https://github.com/EPCCed/benchio) behaviour on a given x86 Tier1
>>>> machine.
>>>> running two benchio tests (MPI-IO and serial) a different behaviour
>>>> appear
>>>> while Darhsan pdf log file is able to recover the estimated time and
>>>> bandwidth in the MPI-IO case, the "serial" run is completely
>>>> underestimated by Darshan (the time and bandwidth are less/greater
>>>> than benchio output).
>>>> Suggestions are welcomed
>>>> thanks
>>>> Piero
>>>> _______________________________________________
>>>> Darshan-users mailing list
>>>> Darshan-users at lists.mcs.anl.gov<mailto:Darshan-users at lists.mcs.anl.gov>
>>>> https://lists.mcs.anl.gov/mailman/listinfo/darshan-users
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20200212/f2e03f02/attachment-0001.html>
More information about the Darshan-users
