[Darshan-users] Darshan & EPCC benchio different behaviour
Piero LANUCARA p.lanucara at cineca.it
Thu Feb 13 04:24:19 CST 2020
Hi Phil,
first of all thanks for your quite detailed analysis.
I did some further test and the behaviour, for example, slightly change
passing from MPIIFORT to MPIF90 (which is a sort of wrapper to GNU)
[planucar at r033c01s05 source]$ mpif90 -v
mpif90 for the Intel(R) MPI Library 2018 Update 4 for Linux*
Copyright(C) 2003-2018, Intel Corporation.  All rights reserved.
Using built-in specs.
COLLECT_GCC=gfortran
COLLECT_LTO_WRAPPER=/usr/libexec/gcc/x86_64-redhat-linux/4.8.5/lto-wrapper
Target: x86_64-redhat-linux
Configured with: ../configure --prefix=/usr --mandir=/usr/share/man
--infodir=/usr/share/info
--with-bugurl=http://bugzilla.redhat.com/bugzilla --enable-bootstrap
--enable-shared --enable-threads=posix --enable-checking=release
--with-system-zlib --enable-__cxa_atexit --disable-libunwind-exceptions
--enable-gnu-unique-object --enable-linker-build-id
--with-linker-hash-style=gnu
--enable-languages=c,c++,objc,obj-c++,java,fortran,ada,go,lto
--enable-plugin --enable-initfini-array --disable-libgcj
--with-isl=/builddir/build/BUILD/gcc-4.8.5-20150702/obj-x86_64-redhat-linux/isl-install
--with-cloog=/builddir/build/BUILD/gcc-4.8.5-20150702/obj-x86_64-redhat-linux/cloog-install
--enable-gnu-indirect-function --with-tune=generic --with-arch_32=x86-64
--build=x86_64-redhat-linux
Thread model: posix
gcc version 4.8.5 20150623 (Red Hat 4.8.5-16) (GCC)
In this case the estimate is more correct (altough there is still some
"time" missing also in that estimate). Of course, this is a simple
benchmark....so, in the end, results are not so useful.
But, my question, is how to recover the "missing" I/O time?
Infact, we should have an uncorrect information that the I/O behaviour
is more efficient than we can observe and in a real situation this can
be a limit of the tool.
Are you agree?
thanks again
Piero
in this case the estimate is more correct (altough there is still some
of course, this is a simple benchmark....so, in the end, results are not
so useful.
But, my question, how to recover the "missing" time I/O time?
infact, we should have the incorrect information that the I/O time is
more efficient than we can observe and in a real situation this can be a
limit of the tool.
Agree?
thanks again
Piero
Il 12/02/2020 21:37, Carns, Philip H. ha scritto:
> Thank you Piero, that does help quite a bit.  I don't know the cause,
> but I do see why Darshan reports a rate much higher than the benchmark.
> The clue is in the write() timing if you zero in on a specific file,
> in this case serial.dat.1:
> [carns at carns-x1-7g Downloads]$ darshan-parser benchio_1202.dn.darshan
> |grep serial.dat.1 |grep F_WRITE
> POSIX 0 2553187295521652424 POSIX_F_WRITE_START_TIMESTAMP 0.350832
> /gpfs/scratch/userinternal/planucar/benchio-master/shared-file/source/benchio_files/serial.dat.1
> /gpfs/scratch gpfs
> POSIX 0 2553187295521652424 POSIX_F_WRITE_END_TIMESTAMP 4.519859
> /gpfs/scratch gpfs
> POSIX 0 2553187295521652424 POSIX_F_WRITE_TIME 1.336200
> /gpfs/scratch gpfs
> The POSIX_F_WRITE_TIME shows the cumulative time in seconds was spent
> waiting on glibc write() calls: 1.3 seconds.
> The POSIX_F_WRITE_{START/END}_TIMESTAMP show the elapsed time between
> when the first write started and the last write ended: 4.2 seconds.
> Somehow almost 70% of the elapsed time measured by the benchmark is
> spent doing something between individual write() calls that make it to
> glibc.  The writes seem to be relatively sparse in time.
> This doesn't make any sense if you look at the benchmark code,
> though.  The write loop is very simple, in fact it is just a tight
> loop calling write():
> https://github.com/EPCCed/benchio/blob/master/shared-file/source/mpiio.F90#L154
> Maybe someone on the list with more Fortran expertise than me can
> comment on why this might happen?  Is it possible that the Fortran
> runtime is doing something (buffering?) that consumes time in the
> Fortran-level write call before the data is actually relayed to the
> system?
> As a side note we could use other heuristics for performance, but they
> all have their tradeoffs.  The one that would obviously work here
> (measuring time from first to last I/O) would break for other common
> patterns.
> thanks,
> -Phil
> *From:* Piero LANUCARA <p.lanucara at cineca.it>
> *Sent:* Wednesday, February 12, 2020 1:47 PM
> *To:* Carns, Philip H. <carns at mcs.anl.gov>; Snyder, Shane
> <ssnyder at mcs.anl.gov>; Harms, Kevin <harms at alcf.anl.gov>
> *Cc:* darshan-users at lists.mcs.anl.gov <darshan-users at lists.mcs.anl.gov>
> *Subject:* Re: [Darshan-users] Darshan & EPCC benchio different behaviour
> p.s
> sorry, I forgotted to say that we built the environment (both Darshan
> and benchmark) using IntelMPI release mpiifort script:
>  mpiifort -v
> mpiifort for the Intel(R) MPI Library 2018 Update 4 for Linux*
> regards
> Piero
> Il 12/02/2020 16:54, Piero LANUCARA ha scritto:
>> Hi Phil
>> in attach
>> dn stands for different names....
>> cheers
>> Piero
>> Il 12/02/2020 16:13, Carns, Philip H. ha scritto:
>>> Ah, great, thank you for the confirmation.
>>> In that case it looks like Darshan is instrumenting properly at run
>>> time, but I think Kevin is on the right track that Darshan's
>>> heuristics for calculating performance in post processing are
>>> getting confused for some reason.
>>> Probably GPFS is client-side caching aggressively in the single
>>> client case, but that wouldn't explain why the benchmark output
>>> reports a much different number than Darshan, though.  They should
>>> both perceive roughly the same performance; neither the benchmark
>>> itself nor Darshan know if caching is happening or not.
>>> It's hard to see where the performance heuristic went wrong from
>>> looking at the log, in large part because the app repeatedly opens a
>>> file with the same name (there is a clue to this in the OPEN
>>> counters; the same file name is opened 20 times):
>>> # WARNING: POSIX_OPENS counter includes both POSIX_FILENOS and
>>> POSIX_DUPS counts
>>> POSIX 0 6563482044800691889 POSIX_OPENS 20
>>> /gpfs/scratch gpfs
>>> Every time the file is opened (regardless of whether it was unlinked
>>> in between or not), Darshan keeps adding counters to the same
>>> record, which are associated with that serial.dat file name.  So
>>> things like close() timestamps become nonsensical because Darshan
>>> records when the first close() starts and when the last one finishes:
>>> [carns at carns-x1-7g Downloads]$ darshan-parser benchio_1202.darshan
>>> |grep CLOSE
>>> POSIX 0 6563482044800691889 POSIX_F_CLOSE_START_TIMESTAMP
>>> 4.536853/gpfs/scratch/userinternal/planucar/benchio-master/shared-file/source/benchio_files/serial.dat
>>> /gpfs/scratch gpfs
>>> POSIX 0 6563482044800691889 POSIX_F_CLOSE_END_TIMESTAMP 43.041987
>>> /gpfs/scratch gpfs
>>> (This doesn't mean there was one close() that took ~40 seconds; in
>>> this case there were many close() calls and ~40 seconds elapsed
>>> between the start of the first one and completion of the last one).
>>> If it is possible for you to modify the benchmark (as an experiment)
>>> so that it chooses a new file name on each iteration, then I think
>>> it would probably disentangle the counters enough for us to tell
>>> what went wrong.
>>> thanks,
>>> -Phil
>>> <mailto:p.lanucara at cineca.it>
>>> *Sent:* Wednesday, February 12, 2020 9:47 AM
>>> <mailto:carns at mcs.anl.gov>; Snyder, Shane <ssnyder at mcs.anl.gov>
>>> <mailto:ssnyder at mcs.anl.gov>; Harms, Kevin <harms at alcf.anl.gov>
>>> <mailto:harms at alcf.anl.gov>
>>> <mailto:darshan-users at lists.mcs.anl.gov>
>>> behaviour
>>> Hi Phil.....POSIX
>>> this is a well known benchmark ....you can easily verify it!
>>> by the way it's something like that
>>> ! Serial write is unconditionally compiled
>>> subroutine serialwrite(filename, iodata, n1, n2, n3, cartcomm)
>>>   character*(*) :: filename
>>>   integer :: n1, n2, n3
>>>   double precision, dimension(0:n1+1,0:n2+1,0:n3+1) :: iodata
>>>   integer :: cartcomm, ierr, rank, size
>>>   integer, parameter :: iounit = 10
>>>   integer :: i
>>>   call MPI_Comm_size(cartcomm, size, ierr)
>>>   call MPI_Comm_rank(cartcomm, rank, ierr)
>>> !  Write same amount of data as the parallel write but do it all
>>> from rank 0
>>> !  This is just to get a baseline figure for serial IO performance -
>>> note
>>> !  that the contents of the file will be differnent from the
>>> parallel calls
>>>   if (rank == 0) then
>>>      open(file=filename, unit=iounit, access='stream')
>>>      do i = 1, size
>>>         write(unit=iounit) iodata(1:n1, 1:n2, 1:n3)
>>>      end do
>>>      close(iounit)
>>>   end if
>>> end subroutine serialwrite
>>> Piero
>>> Il 12/02/2020 14:13, Carns, Philip H. ha scritto:
>>>> Hi Piero,
>>>> In the serial case, is the rank that's doing I/O still using
>>>> MPI-IO, or is it making calls directly to POSIX in that case?
>>>> The Darshan log for the serial case doesn't show any MPI-IO
>>>> activity, but I'm not sure if that's accurate, or if it's an
>>>> indication that we missed some instrumentation.
>>>> thanks,
>>>> -Phil
>>>> *From:* Darshan-users <darshan-users-bounces at lists.mcs.anl.gov>
>>>> <mailto:darshan-users-bounces at lists.mcs.anl.gov> on behalf of Piero
>>>> LANUCARA <p.lanucara at cineca.it> <mailto:p.lanucara at cineca.it>
>>>> *Sent:* Wednesday, February 12, 2020 5:29 AM
>>>> *To:* Snyder, Shane <ssnyder at mcs.anl.gov>
>>>> behaviour
>>>> Hi Shane, Kevin
>>>> thanks for the update.
>>>> I attached a new upated files (log and pdf) to this email.
>>>> Also, the log from BENCHIO is attached.
>>>> thanks again
>>>> regards
>>>> Piero
>>>> Il 11/02/2020 20:15, Shane Snyder ha scritto:
>>>> > Definitely looks like something strange is happening when Darshan is
>>>> > estimating the time spent in I/O operations (as seen in the very
>>>> first
>>>> > figure, observed write time barely even registers) in the serial
>>>> case,
>>>> > which it is ultimately used to provide the performance estimate.
>>>> > If you could provide them, the raw Darshan logs would be really
>>>> > helpful. That should make it clear whether it's an instrumentation
>>>> > issue (i.e., under accounting for time spent in I/O operations at
>>>> > runtime) or if its an issue with the heuristics in the PDF summary
>>>> > tool you are using, as Kevin points out. If it's the latter,
>>>> having an
>>>> > example log to test modifications to our heuristics would be very
>>>> > helpful to us.
>>>> > Thanks,
>>>> > --Shane
>>>> > On 2/11/20 8:36 AM, Harms, Kevin wrote:
>>>> >> Piero,
>>>> >>    the performance estimate is based on heuristics, it's
>>>> possible the
>>>> >> 'serial' model is breaking some assumptions about how the I/O is
>>>> >> done. Is every rank opening the file, but only rank 0 is doing
>>>> actual
>>>> >> I/O?
>>>> >>    If possible, you could provide the log and we could check to see
>>>> >> what the counters look like.
>>>> >> kevin
>>>> >> ________________________________________
>>>> >> From: Piero LANUCARA <p.lanucara at cineca.it>
>>>> >> Sent: Tuesday, February 11, 2020 2:28 AM
>>>> >> To: Harms, Kevin
>>>> >> Cc: darshan-users at lists.mcs.anl.gov
>>>> >> Subject: Re: [Darshan-users] Darshan & EPCC benchio different
>>>> behaviour
>>>> >> Hi Kevin
>>>> >> first of all thanks for the investigation..I did some futher
>>>> test and it
>>>> >> seems like the issue may appear using Fortran (MPI, mainly
>>>> IntelMPI)
>>>> >> codes.
>>>> >> Is this information useful?
>>>> >> regards
>>>> >> Piero
>>>> >> Il 07/02/2020 16:07, Harms, Kevin ha scritto:
>>>> >>> Piero,
>>>> >>>     just to confirm, the serial case is still running in parallel,
>>>> >>> 36 processes, but the I/O is only from rank 0?
>>>> >>> kevin
>>>> >>> From: Darshan-users <darshan-users-bounces at lists.mcs.anl.gov>
>>>> >>> behalf of Piero LANUCARA <p.lanucara at cineca.it>
>>>> >>> Sent: Wednesday, February 5, 2020 4:56 AM
>>>> >>> To: darshan-users at lists.mcs.anl.gov
>>>> behaviour
>>>> >>> p.s
>>>> >>> to be more "verbose" I add to the discussion:
>>>> >>> Darshan output for the "serial" run (serial.pdf)
>>>> >>> Darshan output for the MPI-IO run (mpiio.pdf)
>>>> >>> benchio output for "serial" run (serial.out)
>>>> >>> benchio output for "MPI-IO" run (mpi-io.out)
>>>> >>> thanks
>>>> >>> Piero
>>>> >>> Il 04/02/2020 19:44, Piero LANUCARA ha scritto:
>>>> >>>> Dear all
>>>> >>>> I'm using Darshan to measure EPCC benchio benchmark
>>>> >>>> (https://github.com/EPCCed/benchio) behaviour on a given x86 Tier1
>>>> >>>> machine.
>>>> >>>> running two benchio tests (MPI-IO and serial) a different
>>>> behaviour
>>>> >>>> appear
>>>> >>>> while Darhsan pdf log file is able to recover the estimated
>>>> time and
>>>> >>>> bandwidth in the MPI-IO case, the "serial" run is completely
>>>> >>>> underestimated by Darshan (the time and bandwidth are less/greater
>>>> >>>> than benchio output).
>>>> >>>> Suggestions are welcomed
>>>> >>>> thanks
>>>> >>>> Piero
>>>> >>>> _______________________________________________
>>>> >>>> Darshan-users mailing list
>>>> >>>> Darshan-users at lists.mcs.anl.gov
>>>> <mailto:Darshan-users at lists.mcs.anl.gov>
>>>> >>>> https://lists.mcs.anl.gov/mailman/listinfo/darshan-users
>> Darshan-users at lists.mcs.anl.gov  <mailto:Darshan-users at lists.mcs.anl.gov>
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20200213/6d5d3c6e/attachment-0001.html>
More information about the Darshan-users mailing list
