[Darshan-users] Darshan & EPCC benchio different behaviour
Piero LANUCARA
p.lanucara at cineca.it
Wed Feb 12 12:47:19 CST 2020
p.s
sorry, I forgotted to say that we built the environment (both Darshan
and benchmark) using IntelMPI release mpiifort script:
mpiifort -v
mpiifort for the Intel(R) MPI Library 2018 Update 4 for Linux*
Copyright(C) 2003-2018, Intel Corporation. All rights reserved.
regards
Piero
Il 12/02/2020 16:54, Piero LANUCARA ha scritto:
> Hi Phil
> in attach
> dn stands for different names....
> cheers
> Piero
> Il 12/02/2020 16:13, Carns, Philip H. ha scritto:
>> Ah, great, thank you for the confirmation.
>> In that case it looks like Darshan is instrumenting properly at run
>> time, but I think Kevin is on the right track that Darshan's
>> heuristics for calculating performance in post processing are getting
>> confused for some reason.
>> Probably GPFS is client-side caching aggressively in the single
>> client case, but that wouldn't explain why the benchmark output
>> reports a much different number than Darshan, though. They should
>> both perceive roughly the same performance; neither the benchmark
>> itself nor Darshan know if caching is happening or not.
>> It's hard to see where the performance heuristic went wrong from
>> looking at the log, in large part because the app repeatedly opens a
>> file with the same name (there is a clue to this in the OPEN
>> counters; the same file name is opened 20 times):
>> # WARNING: POSIX_OPENS counter includes both POSIX_FILENOS and
>> POSIX_DUPS counts
>> POSIX 0 6563482044800691889 POSIX_OPENS 20
>> /gpfs/scratch/userinternal/planucar/benchio-master/shared-file/source/benchio_files/serial.dat
>> /gpfs/scratch gpfs
>> Every time the file is opened (regardless of whether it was unlinked
>> in between or not), Darshan keeps adding counters to the same record,
>> which are associated with that serial.dat file name. So things like
>> close() timestamps become nonsensical because Darshan records when
>> the first close() starts and when the last one finishes:
>> [carns at carns-x1-7g Downloads]$ darshan-parser benchio_1202.darshan
>> |grep CLOSE
>> POSIX 0 6563482044800691889 POSIX_F_CLOSE_START_TIMESTAMP
>> 4.536853/gpfs/scratch/userinternal/planucar/benchio-master/shared-file/source/benchio_files/serial.dat
>> /gpfs/scratch gpfs
>> POSIX 0 6563482044800691889 POSIX_F_CLOSE_END_TIMESTAMP 43.041987
>> /gpfs/scratch gpfs
>> (This doesn't mean there was one close() that took ~40 seconds; in
>> this case there were many close() calls and ~40 seconds elapsed
>> between the start of the first one and completion of the last one).
>> If it is possible for you to modify the benchmark (as an experiment)
>> so that it chooses a new file name on each iteration, then I think it
>> would probably disentangle the counters enough for us to tell what
>> went wrong.
>> thanks,
>> -Phil
>> *From:* Piero LANUCARA <p.lanucara at cineca.it>
>> *Sent:* Wednesday, February 12, 2020 9:47 AM
>> *To:* Carns, Philip H. <carns at mcs.anl.gov>; Snyder, Shane
>> <ssnyder at mcs.anl.gov>; Harms, Kevin <harms at alcf.anl.gov>
>> *Cc:* darshan-users at lists.mcs.anl.gov <darshan-users at lists.mcs.anl.gov>
>> *Subject:* Re: [Darshan-users] Darshan & EPCC benchio different
>> behaviour
>> Hi Phil.....POSIX
>> this is a well known benchmark ....you can easily verify it!
>> by the way it's something like that
>> ! Serial write is unconditionally compiled
>> subroutine serialwrite(filename, iodata, n1, n2, n3, cartcomm)
>> character*(*) :: filename
>> integer :: n1, n2, n3
>> double precision, dimension(0:n1+1,0:n2+1,0:n3+1) :: iodata
>> integer :: cartcomm, ierr, rank, size
>> integer, parameter :: iounit = 10
>> integer :: i
>> call MPI_Comm_size(cartcomm, size, ierr)
>> call MPI_Comm_rank(cartcomm, rank, ierr)
>> ! Write same amount of data as the parallel write but do it all from
>> rank 0
>> ! This is just to get a baseline figure for serial IO performance - note
>> ! that the contents of the file will be differnent from the parallel
>> calls
>> if (rank == 0) then
>> open(file=filename, unit=iounit, access='stream')
>> do i = 1, size
>> write(unit=iounit) iodata(1:n1, 1:n2, 1:n3)
>> end do
>> close(iounit)
>> end if
>> end subroutine serialwrite
>> Piero
>> Il 12/02/2020 14:13, Carns, Philip H. ha scritto:
>>> Hi Piero,
>>> In the serial case, is the rank that's doing I/O still using MPI-IO,
>>> or is it making calls directly to POSIX in that case?
>>> The Darshan log for the serial case doesn't show any MPI-IO
>>> activity, but I'm not sure if that's accurate, or if it's an
>>> indication that we missed some instrumentation.
>>> thanks,
>>> -Phil
>>> *From:* Darshan-users <darshan-users-bounces at lists.mcs.anl.gov>
>>> <mailto:darshan-users-bounces at lists.mcs.anl.gov> on behalf of Piero
>>> LANUCARA <p.lanucara at cineca.it> <mailto:p.lanucara at cineca.it>
>>> *Sent:* Wednesday, February 12, 2020 5:29 AM
>>> *To:* Snyder, Shane <ssnyder at mcs.anl.gov>
>>> <mailto:ssnyder at mcs.anl.gov>; Harms, Kevin <harms at alcf.anl.gov>
>>> <mailto:harms at alcf.anl.gov>
>>> <mailto:darshan-users at lists.mcs.anl.gov>
>>> behaviour
>>> Hi Shane, Kevin
>>> thanks for the update.
>>> I attached a new upated files (log and pdf) to this email.
>>> Also, the log from BENCHIO is attached.
>>> thanks again
>>> regards
>>> Piero
>>> Il 11/02/2020 20:15, Shane Snyder ha scritto:
>>> > Definitely looks like something strange is happening when Darshan is
>>> > estimating the time spent in I/O operations (as seen in the very
>>> first
>>> > figure, observed write time barely even registers) in the serial
>>> case,
>>> > which it is ultimately used to provide the performance estimate.
>>> > If you could provide them, the raw Darshan logs would be really
>>> > helpful. That should make it clear whether it's an instrumentation
>>> > issue (i.e., under accounting for time spent in I/O operations at
>>> > runtime) or if its an issue with the heuristics in the PDF summary
>>> > tool you are using, as Kevin points out. If it's the latter,
>>> having an
>>> > example log to test modifications to our heuristics would be very
>>> > helpful to us.
>>> > Thanks,
>>> > --Shane
>>> > On 2/11/20 8:36 AM, Harms, Kevin wrote:
>>> >> Piero,
>>> >> the performance estimate is based on heuristics, it's possible
>>> the
>>> >> 'serial' model is breaking some assumptions about how the I/O is
>>> >> done. Is every rank opening the file, but only rank 0 is doing
>>> actual
>>> >> I/O?
>>> >> If possible, you could provide the log and we could check to see
>>> >> what the counters look like.
>>> >> kevin
>>> >> ________________________________________
>>> >> From: Piero LANUCARA <p.lanucara at cineca.it>
>>> >> Sent: Tuesday, February 11, 2020 2:28 AM
>>> >> To: Harms, Kevin
>>> >> Cc: darshan-users at lists.mcs.anl.gov
>>> >> Subject: Re: [Darshan-users] Darshan & EPCC benchio different
>>> behaviour
>>> >> Hi Kevin
>>> >> first of all thanks for the investigation..I did some futher test
>>> and it
>>> >> seems like the issue may appear using Fortran (MPI, mainly IntelMPI)
>>> >> codes.
>>> >> Is this information useful?
>>> >> regards
>>> >> Piero
>>> >> Il 07/02/2020 16:07, Harms, Kevin ha scritto:
>>> >>> Piero,
>>> >>> just to confirm, the serial case is still running in parallel,
>>> >>> 36 processes, but the I/O is only from rank 0?
>>> >>> kevin
>>> >>> From: Darshan-users <darshan-users-bounces at lists.mcs.anl.gov>
>>> >>> behalf of Piero LANUCARA <p.lanucara at cineca.it>
>>> >>> Sent: Wednesday, February 5, 2020 4:56 AM
>>> >>> To: darshan-users at lists.mcs.anl.gov
>>> behaviour
>>> >>> p.s
>>> >>> to be more "verbose" I add to the discussion:
>>> >>> Darshan output for the "serial" run (serial.pdf)
>>> >>> Darshan output for the MPI-IO run (mpiio.pdf)
>>> >>> benchio output for "serial" run (serial.out)
>>> >>> benchio output for "MPI-IO" run (mpi-io.out)
>>> >>> thanks
>>> >>> Piero
>>> >>> Il 04/02/2020 19:44, Piero LANUCARA ha scritto:
>>> >>>> Dear all
>>> >>>> I'm using Darshan to measure EPCC benchio benchmark
>>> >>>> (https://github.com/EPCCed/benchio) behaviour on a given x86 Tier1
>>> >>>> machine.
>>> >>>> running two benchio tests (MPI-IO and serial) a different behaviour
>>> >>>> appear
>>> >>>> while Darhsan pdf log file is able to recover the estimated
>>> time and
>>> >>>> bandwidth in the MPI-IO case, the "serial" run is completely
>>> >>>> underestimated by Darshan (the time and bandwidth are less/greater
>>> >>>> than benchio output).
>>> >>>> Suggestions are welcomed
>>> >>>> thanks
>>> >>>> Piero
>>> >>>> _______________________________________________
>>> >>>> Darshan-users mailing list
>>> >>>> Darshan-users at lists.mcs.anl.gov
>>> <mailto:Darshan-users at lists.mcs.anl.gov>
>>> >>>> https://lists.mcs.anl.gov/mailman/listinfo/darshan-users
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20200212/303c0f6b/attachment-0001.html>
More information about the Darshan-users
