[Darshan-users] Darshan-users Digest, Vol 64, Issue 3
Jean Bez
jean.bez at ufrgs.br
Tue Feb 14 14:18:24 CST 2017
> Are you actually performing any read or write operations to a file in
the application you are linking with Darshan? DXT only traces reads and
> writes, so if you are just opening a file (for instance), it shouldn't
> produce any DXT data.
Yes, but after looking at the application I was testing it used some
functions (fwrite for instance) that were not traced by Darshan DxT,
although they appeared on the default Darshan report. So I looked at the
souce-code and those calls is not handled yet.
If your application is doing reads/writes, there should be DXT data if
> you enabled it properly. Did you run 'export DXT_ENABLE_IO_TRACE='? Note
> that you need to include the trailing equal sign, even if you aren't
> setting a value for the amount of memory to use. For example:
> 'export DXT_ENABLE_IO_TRACE=' will give you the default 4MiB buffer per
> process for tracing
> 'export DXT_ENABLE_IO_TRACE=8' will instead allocate 8MiB buffers per
> process
Yes, I set the variable via the MPICH -env option and now it worked ok for
the MPI-IO requests.
Thanks!
Jean
> Thanks,
> --Shane
> On 02/13/2017 11:03 AM, Jean Bez wrote:
> > Hi!
> > I was just trying to use the new DXT module and although I have set
> > the environment variable (DXT_ENABLE_IO_TRACE) to activate it, when I
> > attempt to parse the .darshan file with the darshan-dxt-parser I
> > always get the message:
> > "no DXT module data available for this Darshan log."
> > Is there something else we need to do to enable DXT?
> > Thanks!
> > Best regards,
> > Jean
> > _______________________________________________
> > Darshan-users mailing list
> > Darshan-users at lists.mcs.anl.gov
> > https://lists.mcs.anl.gov/mailman/listinfo/darshan-users
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/
> attachments/20170213/7b14bb18/attachment-0001.html>
> End of Darshan-users Digest, Vol 64, Issue 3
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20170214/fd77f5f5/attachment.html>
More information about the Darshan-users
