[Darshan-users] No PDF file generation with darshan-summary-per-file.sh
Suman, Preeti
preeti.suman at intel.com
Mon May 23 14:44:51 CDT 2016
Hello,
I have installed Darshan-3.0.1. I have couple of questions on darshan-summary-per-file.sh.
When I run darshan-summary-per-file.sh it gives the following error:
#### BEGIN : output of darshan-summary-per-file.sh (using mpi-io-test-x86_64-3.0.1.darshan from darshan-test)
$ darshan-summary-per-file.sh mpi-io-test-x86_64-3.0.1.darshan output
Status: Generating summary for file 1 of 1: mpi-io-test.tmp.dat
Slowest unique file time: 0
Slowest shared file time: 0.033856
Total bytes read and written by app (may be incorrect): 134217728
Total absolute I/O time: 0.033856
**NOTE: above shared and unique file times calculated using MPI-IO timers if MPI-IO interface used on a given file, POSIX timers otherwise.
LaTeX generation (phase1) failed [256], aborting summary creation.
error log:
or enter new name. (Default extension: sty)
Enter file name:
! Emergency stop.
<read *>
l.9 \usepackage
{color}^^M
! ==> Fatal error occurred, no output PDF file produced!
Transcript written on summary.log.
darshan-summary-per-file.sh done. Results can be found in output/*.pdf.
#### END : output of darshan-summary-per-file.sh
System specification:
Kernel Version: Linux 4.0.5-1.el7.elrepo.x86_64
Operating System: CentOS Linux release 7.1.1503
CPU: Intel(R) Xeon(R) CPU E5-2630 v3 @ 2.40GHz (Haswell-EP)
Architecture:x86_64
Compiler: GCC 5.1.0
MPI: Intel MPI-5.1.2
I have the following questions:
a) The color.sty file is located at "/usr/share/texlive/texmf-dist/tex/latex/graphics/color.sty". What could be the reason for error?
b) I have installed all the prerequisites mentioned in the Darshan-util installation page (zlib, libbz2 development headers and library (libbz2-dev or similar), Perl, pdflatex, gnuplot 4.2 or later, epstopdf), is there any other prerequisite required?
c) At the end of the darshan-summary-per-file.sh run, it mentions "Transcript written on summary.log". Where can I locate the log file?
I will greatly appreciate your response.
Preeti
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20160523/7f173ec5/attachment.html>
More information about the Darshan-users
