[Darshan-users] Darshan 3.0.1 now available
Shane Snyder
ssnyder at mcs.anl.gov
Fri May 20 13:29:02 CDT 2016
Darshan users,
Darshan version 3.0.1 is now available for download. This version
contains a number of bug fixes and enhancements to Darshan 3.0.0. For
reference, the complete list of changes for this release is:
* bug fix in darshan logutil mount parsing code that was causing file
paths to be matched to the first mount point with a common prefix rather
than the one with the longest common prefix
* bug fix in the darshan-util bzip2 configure check that was
accidentally overwriting Darshan’s LDFLAGS
* minor bug fixes to IO start time counters in all modules to set IO
start time to the actual first start time rather than the first IO op to
complete
* update darshan-util perl scripts to get perl bin from user’s path,
rather than from /usr/lib (reported by Kay Thust)
* update Darshan’s fortran and cxx compiler wrapper generators to
automatically detect MPICH library names on BG/Q
* bug fix for calculating Darshan’s agg_perf_by_slowest performance
metric correctly
* add performance estimate info to darshan-job-summary graph
We have tested this release on multiple platforms, but please let us
know if you have any issues or questions. You can report issues directly
using Darshan’s GitLab page
<https://xgitlab.cels.anl.gov/darshan/darshan> or by using this mailing
list.
The release tarball can be downloaded HERE
<http://press3.mcs.anl.gov/darshan/download/>.
Documentation for this version of Darshan can be found HERE
<http://press3.mcs.anl.gov/darshan/documentation/>.
Thanks!
--Darshan team
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20160520/ef647eef/attachment.html>
More information about the Darshan-users
