[Darshan-users] getting plots
    Shane Snyder
    ssnyder at mcs.anl.gov
    Mon Mar 14 17:56:47 CDT 2016
Hi Burlen,
Would you mind sharing your Darshan log with us? If you prefer, you can
send it to me off-list, or if it contains sensitive information we can
give you details on how to anonymize parts of it (e.g., file names, etc.).
I don't know for sure what the historical reason the "(may be
incorrect)" caveat is given with the total bytes read and written.
Someone correct me if I'm wrong, but I suspect that is to warn against
the possibility that the code actually wrote/read more data than
expected from the application's point of view? For instance, an I/O
optimization called data sieving is possible at the MPI-IO layer which
results in more data being read than expected from the application's
point of view to improve performance. That shouldn't account for the
drastic discrepancy you are seeing, though, so perhaps something else is up.
--Shane
On 03/14/2016 05:29 PM, Burlen Loring wrote:
> Hi, I'd like to analyze our runs with darshan. I'm able to get the log
> files, but so far no luck plotting them.
> In the terminal after a while I see the following output, but then the
> program appears to hang. After ~20 min of no output and no evidence of
> it running in top, I killed it, and I didn't see any newly created files.
> I'm also wondering about the total bytes report and warning that it
> may be wrong. it does indeed seem way off, du reports 1.6T, but
> darshan only reports ~200G.
> Please, let me know what I did wrong! and if I should I be concerned
> about the numbers being so far off.
> Thanks
> Burlen
> $/work/apps/darshan/3.0.0-pre/bin/darshan-job-summary.pl
> loring_oscillator_id1336621_3-14-37256-5315836542621785504_1.darshan
> Slowest unique file time: 25.579892
> Slowest shared file time: 0
> Total bytes read and written by app (may be incorrect): 214218545937
> Total absolute I/O time: 25.579892
> **NOTE: above shared and unique file times calculated using MPI-IO
> timers if MPI-IO interface used on a given file, POSIX timers otherwise.
> Darshan-users mailing list
> Darshan-users at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/darshan-users
More information about the Darshan-users
