[Darshan-users] getting plots
Burlen Loring bloring at lbl.gov
Mon Mar 14 18:44:35 CDT 2016
sure, here is the link
https://drive.google.com/open?id=0B3y5yyus32lveHljWkExal9TVmM
On 03/14/2016 03:56 PM, Shane Snyder wrote:
> Hi Burlen,
> Would you mind sharing your Darshan log with us? If you prefer, you
> can send it to me off-list, or if it contains sensitive information we
> can give you details on how to anonymize parts of it (e.g., file
> names, etc.).
> I don't know for sure what the historical reason the "(may be
> incorrect)" caveat is given with the total bytes read and written.
> Someone correct me if I'm wrong, but I suspect that is to warn against
> the possibility that the code actually wrote/read more data than
> expected from the application's point of view? For instance, an I/O
> optimization called data sieving is possible at the MPI-IO layer which
> results in more data being read than expected from the application's
> point of view to improve performance. That shouldn't account for the
> drastic discrepancy you are seeing, though, so perhaps something else
> is up.
> Thanks,
> --Shane
> On 03/14/2016 05:29 PM, Burlen Loring wrote:
>> Hi, I'd like to analyze our runs with darshan. I'm able to get the
>> log files, but so far no luck plotting them.
>> In the terminal after a while I see the following output, but then
>> the program appears to hang. After ~20 min of no output and no
>> evidence of it running in top, I killed it, and I didn't see any
>> newly created files.
>> I'm also wondering about the total bytes report and warning that it
>> may be wrong. it does indeed seem way off, du reports 1.6T, but
>> darshan only reports ~200G.
>> Please, let me know what I did wrong! and if I should I be concerned
>> about the numbers being so far off.
>> Thanks
>> Burlen
>> $/work/apps/darshan/3.0.0-pre/bin/darshan-job-summary.pl
>> loring_oscillator_id1336621_3-14-37256-5315836542621785504_1.darshan
>> Slowest unique file time: 25.579892
>> Slowest shared file time: 0
>> Total bytes read and written by app (may be incorrect): 214218545937
>> Total absolute I/O time: 25.579892
>> **NOTE: above shared and unique file times calculated using MPI-IO
>> timers if MPI-IO interface used on a given file, POSIX timers otherwise.
>> Darshan-users mailing list
>> Darshan-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/darshan-users
More information about the Darshan-users mailing list
