[Darshan-users] Trouble building shared parallel hdf5 library on BGQ, trying to use w Darshan
Rob Latham robl at mcs.anl.gov
Tue Jan 12 14:54:56 CST 2016
On 01/12/2016 11:25 AM, Hedges, Richard M. wrote:
> I am trying to apply Darshan to a dynamically linked executable on a BGQ
> system with shared parallel hdf5 library.  I have tried several Darshan
> versions, several hdf5 versions, and am using the gcc C and fortran
> compilers (with mlicc and mpif90 wrappers)
> Without Darshan, the code will execute, but when set LD_PRELOAD, the
> code aborts.  My suspicion is that there is a problem with my hdf5
> library build.
> Has anyone encountered this?
> Does anyone have a good (and current)recipe for building parallel hdf5
> on BGQ?
My BGQ recipe (attached) is not so different from the one you shared
with me all those years ago.  I merely updated it for 1.8
==rob
> Thanks,
> - Richard
> Richard Hedges
> Customer Support and Test - File Systems Project
> Development Environment Group - Livermore Computing
> Lawrence Livermore National Laboratory
> 7000 East Avenue, MS L-557
> Livermore, CA    94551
> v:    (925) 423-2699
> f:    (925) 423-6961
> E:    richard-hedges at llnl.gov
> Darshan-users mailing list
> Darshan-users at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/darshan-users
Type: application/x-shellscript
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20160112/c9915471/attachment.bin>
More information about the Darshan-users mailing list
