[Darshan-users] Trouble building shared parallel hdf5 library on BGQ, trying to use w Darshan
Harms, Kevin
harms at alcf.anl.gov
Tue Jan 12 11:40:51 CST 2016
I haven't tried HDF5 with dynamic linking. We build HDF5 like this:
$ ./configure --without-pthread --disable-shared --enable-fortran --disable-cxx --enable-parallel --with-zlib=/soft/libraries/alcf/current/xl/ZLIB --prefix=/soft/libraries/hdf5/1.8.14/cnk-xl/V1R2M2-20150213
using XL compiler.
Do you get a core file from the abort? If you take a look at the call stack maybe that will give a hint where we should look.
kevin
>I am trying to apply Darshan to a dynamically linked executable on a BGQ system with shared parallel hdf5 library. I have tried several Darshan versions, several hdf5 versions, and am using the gcc C and fortran compilers (with mlicc and mpif90 wrappers)
>Without Darshan, the code will execute, but when set LD_PRELOAD, the code aborts. My suspicion is that there is a problem with my hdf5 library build.
>Has anyone encountered this?
>Does anyone have a good (and current)recipe for building parallel hdf5 on BGQ?
>Thanks,
>- Richard
>Richard Hedges
>Customer Support and Test - File Systems Project
>Development Environment Group - Livermore Computing
>Lawrence Livermore National Laboratory
>7000 East Avenue, MS L-557
>Livermore, CA 94551
>v: (925) 423-2699
>f: (925) 423-6961
>E: richard-hedges at llnl.gov
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20160112/a22b3fa4/attachment.bin>
More information about the Darshan-users
