[Darshan-users] Profiling arbitrary parts of an application with Darshan
Phil Carns carns at mcs.anl.gov
Mon Feb 1 06:04:25 CST 2016
Hi Judit,
Is there any chance that we could have a look at your log to help debug
it?  You can send it off-list if you prefer, and we can also tell you
how to anonymize the information (file names, command line, etc.) in it
first if needed.
As a side note, Florin Isaila implemented some Darshan extensions (which
can be found in the darshan-florin-extensions branch in git) that
include explicit hooks you can call to enable and disable Darshan at
runtime.  It will create a separate log file for each period that you
have enabled Darshan.  That is another option if we can't get the
summary-per-file tool working quickly, but you should consider that
branch to be experimental for now.
thanks,
-Phil
On 02/01/2016 03:58 AM, Judit Planas wrote:
> Hi Rob,
> Thanks for your reply.
> Unfortunately, I already tried darshan-summary-per-file.sh, but it
> didn't work for me: some of the charts and tables in the generated PDF
> are blank or filled with 0's.
> For example, 'I/O sizes' and 'I/O pattern' charts are completely blank.
> And the 'Average I/O per process' and 'Data Transfer Per Filesystem'
> tables are filled with either 0's or 'N/A'. However, I know the file was
> created by my application and around 16 MB of data were written (that is
> the size of the file at the end of the execution).
> When running the darshan-summary-per-file.sh script, I get the following
> messages for the file I'm interested in (I guess the PDF charts are
> blank because of the warnings...):
> Slowest unique file time: 0
> Slowest shared file time: 65.503991
> Total bytes read and written by app (may be incorrect): 0
> Total absolute I/O time: 65.503991
> Warning: empty y range [0:0], adjusting to [-1:1]
> Status: Generating summary for file 81 of 177: allcurrents.bbp
> Any idea?
> Thanks in advance,
> Judit
> > On 01/28/2016 05:05 AM, Judit Planas wrote:
> >>/Hello, />>//>>/I am using Darshan to profile my application and I wonder if it is />>/possible to enable/disable Darshan profiling for arbitrary parts of the/
> >>/application. />>//>>/The thing is that my application does a lot of I/O work, but I only want />>/to profile a small part. If I profile the whole application, the reports />>/have a lot of noise from the I/O part that I do not want to profile. />>//>>/Darshan version is 2.3.1 (but I can update it to the latest one if />>/needed) and I am running on a BG/Q system. />
> > There are two things that might help you:
> > - darshan-summary-per-file.sh might do the trick?  you can generate
> > profiles on a per-file basis when you want to, for example, exclude
> > reading in the input deck and focus only on output.  This approach works
> > well if there are particular files you want to study, but not so well if
> > there's a particular phase of I/O you are most concerned about:
> > - I don't know if anyone has tried using MPI_PCONTROL with darshan.  I
> > don't think Darshan knows what to do with that routine, anyway.
> > ==rob
> >>//>/> Thanks in advance, />/> Judit />/> _______________________________________________ />/> Darshan-users mailing list />/> Darshan-users at lists.mcs.anl.gov
> <https://lists.mcs.anl.gov/mailman/listinfo/darshan-users> />/> https://lists.mcs.anl.gov/mailman/listinfo/darshan-users /
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20160201/b1cb9320/attachment.html>
More information about the Darshan-users mailing list
