[Darshan-users] Darshan Fortran wrapper on Blue Gene Q
Harms, Kevin N.
harms at alcf.anl.gov
Thu Mar 12 09:33:25 CDT 2015
Kay,
there are two issues here:
(1) The wrapper generators don't work for BG/Q. I'm attaching some
modified ones for you. I believe that should allow all C, C++ and F77
codes to work.
(2) There is an ongoing issue with IBM and the F90 MPI library. This
library is bypassing MPI_Init and calling PMPI_Init directly. One work
around is to link with the mpixlf77 wrapper. I have a PMR open on the
issue but haven't received any updates yet.
kevin
>Hello,
>We installed Darshan in Juelich for our users to help them analyzing
>their I/O patterns and identifying potential bottlenecks. Our Blue Gene
>Q system (JUQUEEN) runs driver version V1R2M2. Everything works fine
>with the C compiler wrapper but the ones for Fortran and C++ don't seem
>to work. I tested both version 2.3.0 and 2.3.1-pre2.
>For the Fortran wrapper we have no libmpifort, libfmpich.cnk or
>libfmpich on our system but only libmpichf90-xl (and versions for f77,
>or gcc but non of the ). So I needed to change FMPICH in the wrapper. I
>tried different variations (empty, -lmpichf90-xl, "-lmpichf90-xl
>-lmpich-xl") but non of those made a simple Fortran test program use the
>instrumented calls of Darshan. An "nm" on the binary shows the same
>symbols with "darshan" in their names in both the C and the Fortran
>version, so it seems to be used during linking.
>Darshan is a great tool we would also like to offer to users using
>Fortran or C++ codes, too.
>Did anybody already successfully install Darshan on a platform with a
>similar setup? Since linking succeeds and the applications run I have no
>idea how to find the cause of this problem although the FMPICH variable
>seems most promising. Any ideas on how to fix this issue would be
>appreciated.
>Thanks,
>Kay
>Dr. Kay Thust
>Juelich Supercomputing Centre
>Institute for Advanced Simulation
>Forschungszentrum Juelich GmbH
>52425 Juelich
>Sitz der Gesellschaft: Juelich
>Eingetragen im Handelsregister des Amtsgerichts Dueren Nr. HR B 3498
>Vorsitzender des Aufsichtsrats: MinDir Dr. Karl Eugen Huthmacher
>Geschaeftsfuehrung: Prof. Dr.-Ing. Wolfgang Marquardt (Vorsitzender),
>Karsten Beneke (stellv. Vorsitzender), Prof. Dr.-Ing. Harald Bolt,
>Prof. Dr. Sebastian M. Schmidt
>_______________________________________________
>Darshan-users mailing list
>Darshan-users at lists.mcs.anl.gov
>https://lists.mcs.anl.gov/mailman/listinfo/darshan-users
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20150312/133e1519/attachment-0001.obj>
Type: text/x-perl-script
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20150312/133e1519/attachment-0004.bin>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20150312/133e1519/attachment-0005.bin>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20150312/133e1519/attachment-0006.bin>
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20150312/133e1519/attachment-0007.bin>
More information about the Darshan-users
