[Darshan-users] Darshan pre-release: 2.2.9-pre2
Phil Carns
carns at mcs.anl.gov
Mon May 5 20:19:00 CDT 2014
Darshan 2.2.9-pre2 is now available for download. The changes since
pre1 are:
- bug fixes to the Cray PE 2.x environment support (thanks to testing
from Yushu Yao)
- --enable-shared option for darshan-util (suggested by Matthieu Dorier)
We'll be doing some cross-platform testing with 2.2.9-pre2 this week to
try to wrap up a final release.
thanks,
-Phil
On 04/14/2014 04:36 PM, Carns, Philip H. wrote:
> I also forgot to mention that there are some documentation updates in
> this release. The updated documentation is not available on the web
> site, but you can find it in the darshan-util/doc/ and
> darshan-runtime/doc/ subdirectories in the source code.
> thanks,
> -Phil
> On 04/14/2014 04:34 PM, Carns, Philip H. wrote:
>> There is a new experimental version of Darshan available for download
>> today. It includes fixes for several bugs as well as support for
>> versions 2.0 and newer of the Cray Programming Environment. The full
>> change log is listed below.
>> Feedback is always welcome! We will do more thorough cross-platform
>> testing before the official 2.2.9 release; please just use this version
>> for testing and evaluation.
>> thanks!
>> -Darshan team
>> darshan-2.2.9-pre1
>> * Bug fixes:
>> - Fix mnt table overflow if a large number of file systems are mounted,
>> reported by David Shrader.
>> - Fix argument parsing for darshan-convert, reported by Mouhamed Gueye.
>> - Fix metadata annotation overflow in darshan-convert, reported by
>> Mouhamed Gueye.
>> - Fix const-correctness in dynamic library when built against MPI 3.x
>> libraries.
>> - Fix "undefined symbol: dlsym" error when using preloaded dynamic
>> library
>> on some platforms, reported by Florin Isaila.
>> - Normalize timestamps to always be relative to MPI_Init().
>> - Better library name matching in compiler wrappers to handle more MPICH
>> variations on Blue Gene systems.
>> - Fixed header dependency problems when using darshan-logutils.h in
>> external
>> programs (Shane Snyder).
>> * Enhancements:
>> - Add support (both in documentation and in provided module files) for
>> Cray PE 2.x.
>> - Honor CC variable to allow darshan-util to be built with other
>> compilers
>> besides gcc.
>> - Update documentation to clarify the interaction between rpath and
>> LD_PRELOAD when instrumenting dynamic libraries, issue reported and
>> investigated by Davide Del Vento.
>> - Ability to disable shared-file reduction by setting the
>> DARSHAN_DISABLE_SHARED_REDUCTION environment variable.
>> - More thorough output from darshan-parser --perf, suggested by Huong
>> Luu.
>> - Increased metadata annotation room from 64 bytes to 1KiB in header.
>> - CP_F_{FASTEST/SLOWEST}_RANK_TIME counters now take MPI-IO time into
>> account, not just POSIX time, issue reported by Huong Luu.
>> - Better handling of systems with many mounted file systems (after which
>> point Darshan will assume file resides on / file system), issue
>> reported
>> and investigated by David Shrader:
>> - Track up to 64 rather than 32 mounted file systems at runtime.
>> - Increase header space available for storing mount point
>> information in
>> log file from approximately 1 KiB to approximately 3 KiB.
>> - Prioritize storing information about non-NFS volumes over NFS volumes
>> if too many file systems are mounted to record them all.
>> - Added darshan-util pkgconfig file (Shane Snyder).
>> Darshan-users mailing list
>> Darshan-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/darshan-users
More information about the Darshan-users
