[Darshan-users] Compiling Darshan with -fPIC
Phil Carns carns at mcs.anl.gov
Mon May 5 20:12:56 CDT 2014
On 05/05/2014 03:09 PM, Carns, Philip H. wrote:
> On 05/05/2014 09:00 AM, Matthieu Dorier wrote:
>> Hi,
>> While installing Darshan-Ruby on a new plateforme (Debian with Linux
>> kernel 3.2.0 amd64 and gcc 4.7), I encountered a compilation error,
>> basically asking me to recompile Darshan with -fPIC.
>> I tried to use CFLAGS=-fPIC but, I don't know why, it didn't work. I
>> ended up changing the Makefile.in of Darshan, line 59 and 60, to the
>> following:
>> darshan-logutils.o: darshan-logutils.c
>>       $(CC) $(CFLAGS) -fPIC -c $< -o $@
>> Maybe it could be useful to add the options of compiling Darshan with
>> or without PIC (with PIC enabled by default), or even some kind of
>> --enable-shared option to produce a libdarshan-util.so?
>> Best,
>> Matthieu Dorier
>> PhD student at ENS Rennes
>> http://people.irisa.fr/Matthieu.Dorier
> Thanks for the bug report Matthieu.   Which version of Darshan was this?
> Is the PIC option required for Darshan-Ruby to use the libdarshan-util
> library correctly, or did you need to add it for libdarshan-util to
> build cleanly at all on this platform?
> I'll definitely look into this further.  At a minimum we should fix
> the CFLAGS issue so that you can pass in custom flags.
I wasn't able to reproduce the CFLAGS problem, but that may be something
that has changed in trunk (I didn't look back at previous releases).
The --enable-shared option is pretty straightforward, though, so I went
ahead and added that.  It will be available in 2.2.9-pre2 and later.
thanks,
-Phil
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20140505/03ba1a73/attachment.html>
More information about the Darshan-users mailing list
