[Darshan-users] Darshan 2.2.9 release
Phil Carns
carns at mcs.anl.gov
Tue May 6 14:37:07 CDT 2014
The official Darshan 2.2.9 release is now available on the web site.
This is primarily a maintenance and bug fix release. It also includes
support for versions 2.0 and newer of the Cray Programming Environment.
The full change log since 2.2.8 is listed below:
* Bug fixes:
- Fix mnt table overflow if a large number of file systems are
mounted,reported by David Shrader.
- Fix argument parsing for darshan-convert, reported by Mouhamed Gueye.
- Fix metadata annotation overflow in darshan-convert, reported
byMouhamed Gueye.
- Fix const-correctness in dynamic library when built against MPI
3.xlibraries.
- Fix "undefined symbol: dlsym" error when using preloaded dynamic
libraryon some platforms, reported by Florin Isaila.
- Normalize timestamps to always be relative to MPI_Init().
- Better library name matching in compiler wrappers to handle more
MPICH variations on Blue Gene systems.
- Fixed header dependency problems when using darshan-logutils.h in
externalprograms (Shane Snyder).
* Enhancements:
- Add support (both in documentation and in provided module files)
forCray PE 2.x.
- Honor CC variable to allow darshan-util to be built with other
compilersbesides gcc.
- Update documentation to clarify the interaction between rpath and
LD_PRELOAD when instrumenting dynamic libraries, issue reported
andinvestigated by Davide Del Vento.
- Ability to disable shared-file reduction by setting the
DARSHAN_DISABLE_SHARED_REDUCTION environment variable.
- More thorough output from darshan-parser --perf, suggested by Huong
Luu.
- Increased metadata annotation room from 64 bytes to 1KiB in header.
- CP_F_{FASTEST/SLOWEST}_RANK_TIME counters now take MPI-IO time
intoaccount, not just POSIX time, issue reported by Huong Luu.
- Better handling of systems with many mounted file systems (after
whichpoint Darshan will assume file resides on / file system), issue
reportedand investigated by David Shrader:
- Track up to 64 rather than 32 mounted file systems at runtime.
- Increase header space available for storing mount point
information in log file from approximately 1 KiB to approximately 3 KiB.
- Prioritize storing information about non-NFS volumes over NFS
volumes if too many file systems are mounted to record them all.
- Added darshan-util pkgconfig file (Shane Snyder).
- Added --enable-shared configure option to darshan-util to build
anda shared library version of libdarshan-util
thanks,
-Darshan development team
More information about the Darshan-users
