[Darshan-users] darshan doesn't generate the login
    Phil Carns
    carns at mcs.anl.gov
    Thu Apr  3 12:55:04 CDT 2014
Hi Nicola,
I can think of a couple of things to try:
a) maybe confirm that the executable has dynamically linked the mpi
libraries (run "ldd lmp_fornax" to see a list of dynamic libraries) just
as a safety check.
b) I don't regularly use mpirun from OpenMPI, but does it automatically
propagate environment variables to the executable or do you need to
specify something on the command line to get that behavior?  If your
executable can run correctly with a single rank then you can take mpirun
out of the loop temporarily for testing purposes and just try running
"/scratch/director100/nicola/lammps_pistolare/src/lmp_fornax <
in.friction" directly.  If the instrumentation works in that case but
not when using mpirun then that would indicate that something isn't
being translated into the mpirun environment.
thanks,
-Phil
On 04/02/2014 11:49 PM, nicola varini wrote:
> Hi, I am new to darshan. Sorry if my question is trivial but I've tried
> to search a bit through the mailing list archive and I did not find much
> help.
> I am try to understand how to use darshan and I've build the runtime with
> ./configure --with-mem-align=8
> --with-log-path=/scratch/director100/nicola/darshan-2.2.8 CC=mpicc
> --with-jobid-env=PBS_JOBID
> --prefix=/scratch/director100/nicola/darshan-2.2.8
> and the util with
> ./configure --prefix=/scratch/director100/nicola/darshan-2.2.8
> then I'd like to profile LAMMPS IO with darshan. Here I use openmpi
> 1.6.5, so I did
> export
> LD_PRELOAD=/scratch/director100/nicola/darshan-2.2.8/lib/libdarshan.so
> then I make lammps
> and I tried to execute a simple example with
> mpirun -np 12
> /scratch/director100/nicola/lammps_pistolare/src/lmp_fornax < in.friction
> However no darshan.gz is generated.
> Any idea why?
> Thanks,
> Nicola
> Darshan-users mailing list
> Darshan-users at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/darshan-users
More information about the Darshan-users
