[Darshan-users] fputs and internal glibc i/o calls
Chuck Cranor chuck at ece.cmu.edu
Thu Apr 3 12:17:51 CDT 2014
hi-
    I downloaded and tried 2.2.8 to better understand how it works
and what it can do.  The test app I used uses MPI to simulate
checkpoints and then proc 0 writes the performance results to a log
file.  I used the LD_PRELOAD mechanism to load darshan.
    Looking at the darshan log file from this app, I noticed that
darshan captured proc 0 creating the log file, but didn't show
any writes to it (even though new data was added).   This is because
the app does all its writes with fputs and darshan doesn't intercept
calls to fputs (or calls to fprintf either, for that matter).
    I'm not sure if omitting fputs/fprintf is intentional or not, but
I didn't see anything in the documentation about it.
    Also, it is worth noting in the documentation somewhere that
internal glibc I/O system calls may not be captured in the darshan
log.   For example, fputs() is a libc function that uses write()
internally, but the internal write() will not appear in the darshan
log.  I believe this is because glibc does not allow internally
generated system calls to be overridden.   See the discussion of
hidden prototypes here:
     https://sourceware.org/glibc/wiki/Testing/Check-localplt
An easy way to demo this is with the ctime(3) function.  Internally,
ctime(3) uses the POSIX open(2) I/O call to load local timezone
information from /etc/localtime.  So you might think a simple program like:
    #include <stdio.h>
    #include <time.h>
    main(int argc, char **argv ) {
        time_t now;
        MPI_Init(&argc, &argv);
        now = time(0);
        printf("time=%s", ctime(&now));
        MPI_Finalize();
would show the I/O to /etc/localtime in the darshan log, but it
doesn't:
h0:/tmp/ctime# ./a.out
time=Thu Apr  3 11:05:56 2014
h0:/tmp/ctime#
h0:/tmp/ctime# strace ./a.out |& fgrep localtime
open("/etc/localtime", O_RDONLY|O_CLOEXEC) = 4
h0:/tmp/ctime#
h0:/tmp/ctime# env LD_PRELOAD=/usr/local/lib/libdarshan.so mpirun.mpich2 ./a.out
time=Thu Apr  3 11:06:31 2014
h0:/tmp/ctime# darshan-parser /m/pvfs/tmp/2014/4/3/root_a.out_id22281_4-3-39991-1756671920181884080_1.darshan.gz
# darshan log version: 2.02
# size of file statistics: 1328 bytes
# size of job statistics: 120 bytes
# exe: ./a.out
# uid: 0
# jobid: 22281
# start_time: 1396544791
# start_time_asci: Thu Apr  3 11:06:31 2014
# end_time: 1396544791
# end_time_asci: Thu Apr  3 11:06:31 2014
# nprocs: 1
# run time: 1
# metadata: lib_ver = 2.2.8
# metadata: h = romio_no_indep_rw=true;cb_nodes=4
# mounted file systems (device, mount point, and fs type)
# mount entry: 8879946760550363901      /m/pvfs fuse
# mount entry: -6525176383006974612     /l0     ext2
# mount entry: 1378004016996341907      /users/garth    nfs
# mount entry: -6395289464566466203     /users/qingzhen nfs
# mount entry: 3967925232003708285      /proj/TableFS   nfs
# mount entry: -5933552100018119666     /users/chuck    nfs
# mount entry: -9071479661283960111     /share  nfs
# mount entry: 361011049498856045       /users/kair     nfs
# mount entry: 3179183617035706161      /dev    devtmpfs
# mount entry: -648807988769344735      /       ext3
# no files opened.
h0:/tmp/ctime#
The only internal functions that glibc seems to let you override
are malloc-related:
h0:/l0/glibc-2.14# cat scripts/data/localplt-generic.data
libc.so: calloc
libc.so: free
libc.so: malloc
libc.so: memalign
libc.so: realloc
libm.so: matherr
h0:/l0/glibc-2.14#
that's prob for malloc debuggers, otherwise they would have
trouble with functions like strdup(3) that call malloc internally
for an application [and expect the app to free(3) the memory later].
I suspect the behavior might be different using a static-linked
program, but haven't tried it...
chuck
More information about the Darshan-users mailing list
