[Darshan-users] Using darshan for non-MPI programs
Michael Kluge michael.kluge at tu-dresden.de
Thu Jun 6 14:21:52 CDT 2013
Hi Kevin,
I tried this today with OpenMPI and it looks like that mpirun does some
magic as well which is need to initilize MPI within PMPI_Init()
correctly. This needs some more work, probably one needs to read
/proc/self/cmdline to recreate argc and argv for MPI_Init or at least to
put the correct binary into argv[0]. I'll try a bit more but at least
this stuff started and did'nt generate loader errors or segfault.
Regads, Michael
Am 05.06.2013 21:05, schrieb Kevin Harms:
>    I'd like to start with, I'm not saying this is a good idea, just an idea. You could build a shim which wraps main and is listed in the LD_PRELOAD variable along with darshan. The main wrapper would call the PMPI_Init and then call  the real main. You could either call PMPI_Finalize after the real main returns or try using atexit() to register a helper function that calls PMPI_Finalize() to catch cases where applications exit at places other than main. (Or maybe register PMPI_Finalize directly?) I'm also making the assumption you can intercept main which I don't know if that is true. Then in the LD_PRELOAD you list your library, darshan and maybe MPI? although i think the dynamic loader should load MPI when darshan.so is loaded without naming it explicitly.
>    something to try anyway.
> kevin
> On Jun 5, 2013, at 1:22 AM, Michael Kluge <michael.kluge at tu-dresden.de> wrote:
>> Hi Julian,
>> the problem is that I'm looking for a tool that works with all dynamic binaries, even those, where I don't have the source and that are not using MPI. There is no hope with darshan for this type of binaries?
>> Regards, Michael
>> On 05.06.2013 00:24, Julian Kunkel wrote:
>>> Hi
>>> With ld's wrap option I think you can provide a main() replacement which
>>> calls (p)mpi_init() then the real main and (p)mpi_finalize() afterwards.
>>> This way you only have to recompile POSIX apps wrapping against you
>>> "darshaning" main method.
>>> Regards
>>> Julian
>>> -- send with android. Sorry for typos.
>>> Am 04.06.2013 19:03 schrieb "Michael Kluge" <michael.kluge at tu-dresden.de
>>> <mailto:michael.kluge at tu-dresden.de>>:
>>>     Hi Kevin,
>>>     if I really want to use darshan for POSIX programs on single hosts,
>>>     then it should be fairly easy to emulate the semantics of the MPI
>>>     calls through a couple of pthread calls. It might even be possible
>>>     to replace the few MPI funktions used in darshan with a generic
>>>     abstraction layer and create an MPI and POSIX-only implementation of
>>>     that layer. Just thinking ...
>>>     Regards, Michael
>>>     Am 04.06.2013 18 <tel:04.06.2013%2018>:49, schrieb Kevin Harms:
>>>         Michael,
>>>             Darshan itself needs MPI. It uses some collective calls and
>>>         file routines when generating the log. The log is written when
>>>         MPI_Finalize is called. If you're going to modify your POSIX
>>>         program, then it seems easier to just instrument your main()
>>>         with MPI_Init() and MPI_Finalize().
>>>             Using:
>>>         void __attribute__ ((constructor)) PMPI_Init()
>>>             i think would work to initialize darshan, but you still need
>>>         to call PMPI_Finalize at some point to get the log.
>>>         kevin
>>>         On Jun 4, 2013, at 8:37 AM, Michael Kluge
>>>         <mailto:michael.kluge at tu-dresden.de>> wrote:
>>>             Dear list,
>>>             if I understand all the documentation well, darshan collects
>>>             profiles of MPI programs only because it will initialize
>>>             itself from a wrapper to MPI_Init(). Is this the only case,
>>>             why pure POSIX programs (maybe multithreaded) would not work
>>>             together with darshan?
>>>             Is there any chance that an approach that uses
>>>             void __attribute__ ((constructor)) my_lib_init()
>>>             (see:
>>>             http://gcc.gnu.org/onlinedocs/__gcc/Function-Attributes.html
>>>             <http://gcc.gnu.org/onlinedocs/gcc/Function-Attributes.html>)
>>>             from gcc would work as well for pure POSIX programs?
>>>             Regards, Michael
>>>             Dr.-Ing. Michael Kluge
>>>             Technische Universität Dresden
>>>             Center for Information Services and
>>>             High Performance Computing (ZIH)
>>>             D-01062 Dresden
>>>             Germany
>>>             Contact:
>>>             Willersbau, Room WIL A 208
>>>             Phone: (+49) 351 463-34217 <tel:%28%2B49%29%20351%20463-34217>
>>>             Fax: (+49) 351 463-37773 <tel:%28%2B49%29%20351%20463-37773>
>>>             e-mail: michael.kluge at tu-dresden.de
>>>             WWW: http://www.tu-dresden.de/zih
>>>             _________________________________________________
>>>             Darshan-users mailing list
>>>             Darshan-users at lists.mcs.anl.__gov
>>>             <mailto:Darshan-users at lists.mcs.anl.gov>
>>>             https://lists.mcs.anl.gov/__mailman/listinfo/darshan-users
>>>             <https://lists.mcs.anl.gov/mailman/listinfo/darshan-users>
>> D-01062 Dresden
>> Germany
>> Contact:
>> Willersbau, Room A 208
More information about the Darshan-users mailing list
