[Darshan-users] Using darshan for non-MPI programs
Phil Carns
carns at mcs.anl.gov
Thu Jun 6 08:42:01 CDT 2013
There are some different options that require different levels of
development effort. A really clean solution would require modification
to Darshan to implement an optional mode that doesn't make any MPI
calls. You might not have to use a constructor. Each wrapper could
just do an initialization check and call the init function if needed.
atexit() could probably be used to register the finalize function.
For a shorter term solution that avoids modifying internal Darshan code,
you would need to pull in a full MPI library and initialize and finalize
it so that the existing Darshan code doesn't complain about lack of MPI
functionality. Even if you used a dummy/stub MPI implementation in
place of a real MPI library, it would still at a minimum will need to
correctly handle MPI_File_write_at_* and a subset of derived MPI
datatypes to write log files correctly the way that Darshan is doing it
now. You couldn't just return 0 for all MPI functions.
I don't think there is any show stopper technical limitation preventing
Darshan from being used like this (and I think it would definitely be
valuable functionality), but there is some work required either way.
-Phil
On 06/05/2013 03:05 PM, Kevin Harms wrote:
> I'd like to start with, I'm not saying this is a good idea, just an idea. You could build a shim which wraps main and is listed in the LD_PRELOAD variable along with darshan. The main wrapper would call the PMPI_Init and then call the real main. You could either call PMPI_Finalize after the real main returns or try using atexit() to register a helper function that calls PMPI_Finalize() to catch cases where applications exit at places other than main. (Or maybe register PMPI_Finalize directly?) I'm also making the assumption you can intercept main which I don't know if that is true. Then in the LD_PRELOAD you list your library, darshan and maybe MPI? although i think the dynamic loader should load MPI when darshan.so is loaded without naming it explicitly.
> something to try anyway.
> kevin
> On Jun 5, 2013, at 1:22 AM, Michael Kluge <michael.kluge at tu-dresden.de> wrote:
>> Hi Julian,
>> the problem is that I'm looking for a tool that works with all dynamic binaries, even those, where I don't have the source and that are not using MPI. There is no hope with darshan for this type of binaries?
>> Regards, Michael
>> On 05.06.2013 00:24, Julian Kunkel wrote:
>>> Hi
>>> With ld's wrap option I think you can provide a main() replacement which
>>> calls (p)mpi_init() then the real main and (p)mpi_finalize() afterwards.
>>> This way you only have to recompile POSIX apps wrapping against you
>>> "darshaning" main method.
>>> Regards
>>> Julian
>>> -- send with android. Sorry for typos.
>>> Am 04.06.2013 19:03 schrieb "Michael Kluge" <michael.kluge at tu-dresden.de
>>> <mailto:michael.kluge at tu-dresden.de>>:
>>> Hi Kevin,
>>> if I really want to use darshan for POSIX programs on single hosts,
>>> then it should be fairly easy to emulate the semantics of the MPI
>>> calls through a couple of pthread calls. It might even be possible
>>> to replace the few MPI funktions used in darshan with a generic
>>> abstraction layer and create an MPI and POSIX-only implementation of
>>> that layer. Just thinking ...
>>> Regards, Michael
>>> Am 04.06.2013 18 <tel:04.06.2013%2018>:49, schrieb Kevin Harms:
>>> Michael,
>>> Darshan itself needs MPI. It uses some collective calls and
>>> file routines when generating the log. The log is written when
>>> MPI_Finalize is called. If you're going to modify your POSIX
>>> program, then it seems easier to just instrument your main()
>>> with MPI_Init() and MPI_Finalize().
>>> Using:
>>> void __attribute__ ((constructor)) PMPI_Init()
>>> i think would work to initialize darshan, but you still need
>>> to call PMPI_Finalize at some point to get the log.
>>> kevin
>>> On Jun 4, 2013, at 8:37 AM, Michael Kluge
>>> <mailto:michael.kluge at tu-dresden.de>> wrote:
>>> Dear list,
>>> if I understand all the documentation well, darshan collects
>>> profiles of MPI programs only because it will initialize
>>> itself from a wrapper to MPI_Init(). Is this the only case,
>>> why pure POSIX programs (maybe multithreaded) would not work
>>> together with darshan?
>>> Is there any chance that an approach that uses
>>> void __attribute__ ((constructor)) my_lib_init()
>>> (see:
>>> http://gcc.gnu.org/onlinedocs/__gcc/Function-Attributes.html
>>> <http://gcc.gnu.org/onlinedocs/gcc/Function-Attributes.html>)
>>> from gcc would work as well for pure POSIX programs?
>>> Regards, Michael
>>> Dr.-Ing. Michael Kluge
>>> Technische Universität Dresden
>>> Center for Information Services and
>>> High Performance Computing (ZIH)
>>> D-01062 Dresden
>>> Germany
>>> Contact:
>>> Willersbau, Room WIL A 208
>>> Phone: (+49) 351 463-34217 <tel:%28%2B49%29%20351%20463-34217>
>>> Fax: (+49) 351 463-37773 <tel:%28%2B49%29%20351%20463-37773>
>>> e-mail: michael.kluge at tu-dresden.de
>>> WWW: http://www.tu-dresden.de/zih
>>> _________________________________________________
>>> Darshan-users mailing list
>>> Darshan-users at lists.mcs.anl.__gov
>>> <mailto:Darshan-users at lists.mcs.anl.gov>
>>> https://lists.mcs.anl.gov/__mailman/listinfo/darshan-users
>>> <https://lists.mcs.anl.gov/mailman/listinfo/darshan-users>
>> D-01062 Dresden
>> Germany
>> Contact:
>> Willersbau, Room A 208
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20130606/b51f3bc7/attachment-0001.html>
More information about the Darshan-users
