[Darshan-users] Error Make - Darshan 2.2.6 - Error: symbol
Sandra Mendez sandra.mendez at caos.uab.es
Sun Jun 9 09:56:46 CDT 2013
 Hello,
I have configured Darshan with the following command:
./configure --prefix=$HOME/darshan-2.2.6/build --with-mem-align=8
--with-log-path=$HOME/darshan-2.2.6/darshan-logs --with-jobid-env=PBS_JOBID
CC=$HOME/mpich2-1.5/build-pvfs2/bin/mpicc
+>01_script-configure-darshan.sh.log
But, when I make Darshan I have the following errors:
/home/sandra/mpich2-1.5/build-pvfs2/bin/mpicc
-DDARSHAN_CONFIG_H=\"darshan-runtime-config.h\" -I . -I ../ -I . -I./../ -g
-O2 -D_LARGEFILE64_SOURCE -c lib/darshan-posix.c -o lib/darshan-posix.o
-O2 -D_LARGEFILE64_SOURCE -c lib/lookup3.c -o lib/lookup3.o
-O2 -D_LARGEFILE64_SOURCE -c lib/lookup8.c -o lib/lookup8.o
ar rcs lib/libdarshan-posix.a lib/darshan-posix.o lib/lookup3.o
lib/lookup8.o
-O2 -D_LARGEFILE64_SOURCE -c lib/darshan-mpi-io.c -o lib/darshan-mpi-io.o
-O2 -D_LARGEFILE64_SOURCE -c lib/darshan-mpi-init-finalize.c -o
lib/darshan-mpi-init-finalize.o
-O2 -D_LARGEFILE64_SOURCE -c lib/darshan-pnetcdf.c -o lib/darshan-pnetcdf.o
-O2 -D_LARGEFILE64_SOURCE -c lib/darshan-hdf5.c -o lib/darshan-hdf5.o
ar rcs lib/libdarshan-mpi-io.a lib/darshan-mpi-io.o
lib/darshan-mpi-init-finalize.o lib/darshan-pnetcdf.o lib/darshan-hdf5.o
-DDARSHAN_CONFIG_H=\"darshan-runtime-config.h\" -I . -I. -I./../ -g -O2
-D_LARGEFILE64_SOURCE -shared -fpic -DPIC -DDARSHAN_PRELOAD -c
lib/darshan-mpi-io.c -o lib/darshan-mpi-io.po
lib/darshan-mpi-init-finalize.c -o lib/darshan-mpi-init-finalize.po
lib/darshan-pnetcdf.c -o lib/darshan-pnetcdf.po
lib/darshan-hdf5.c -o lib/darshan-hdf5.po
lib/darshan-posix.c -o lib/darshan-posix.po
/tmp/ccwsfNVH.s: Assembler messages:
/tmp/ccwsfNVH.s:1758: Error: symbol `lseek64' is already defined
/tmp/ccwsfNVH.s:2067: Error: symbol `__fxstat64' is already defined
/tmp/ccwsfNVH.s:2344: Error: symbol `mmap64' is already defined
/tmp/ccwsfNVH.s:5846: Error: symbol `pwrite64' is already defined
/tmp/ccwsfNVH.s:6496: Error: symbol `pread64' is already defined
/tmp/ccwsfNVH.s:7233: Error: symbol `__lxstat64' is already defined
/tmp/ccwsfNVH.s:7438: Error: symbol `__xstat64' is already defined
/tmp/ccwsfNVH.s:7891: Error: symbol `fopen64' is already defined
/tmp/ccwsfNVH.s:8373: Error: symbol `creat64' is already defined
/tmp/ccwsfNVH.s:8891: Error: symbol `open64' is already defined
make: *** [lib/darshan-posix.po] Error 1
Somebody, Can help me?
Thanks in advance.
Sandra.-
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20130609/f7584fe6/attachment.html>
More information about the Darshan-users mailing list
