[Darshan-users] Using darshan for non-MPI programs
Kevin Harms
harms at alcf.anl.gov
Wed Jun 5 14:05:56 CDT 2013
I'd like to start with, I'm not saying this is a good idea, just an idea. You could build a shim which wraps main and is listed in the LD_PRELOAD variable along with darshan. The main wrapper would call the PMPI_Init and then call the real main. You could either call PMPI_Finalize after the real main returns or try using atexit() to register a helper function that calls PMPI_Finalize() to catch cases where applications exit at places other than main. (Or maybe register PMPI_Finalize directly?) I'm also making the assumption you can intercept main which I don't know if that is true. Then in the LD_PRELOAD you list your library, darshan and maybe MPI? although i think the dynamic loader should load MPI when darshan.so is loaded without naming it explicitly.
something to try anyway.
kevin
On Jun 5, 2013, at 1:22 AM, Michael Kluge <michael.kluge at tu-dresden.de> wrote:
> Hi Julian,
> the problem is that I'm looking for a tool that works with all dynamic binaries, even those, where I don't have the source and that are not using MPI. There is no hope with darshan for this type of binaries?
> Regards, Michael
> On 05.06.2013 00:24, Julian Kunkel wrote:
>> Hi
>> With ld's wrap option I think you can provide a main() replacement which
>> calls (p)mpi_init() then the real main and (p)mpi_finalize() afterwards.
>> This way you only have to recompile POSIX apps wrapping against you
>> "darshaning" main method.
>> Regards
>> Julian
>> -- send with android. Sorry for typos.
>> Am 04.06.2013 19:03 schrieb "Michael Kluge" <michael.kluge at tu-dresden.de
>> <mailto:michael.kluge at tu-dresden.de>>:
>> Hi Kevin,
>> if I really want to use darshan for POSIX programs on single hosts,
>> then it should be fairly easy to emulate the semantics of the MPI
>> calls through a couple of pthread calls. It might even be possible
>> to replace the few MPI funktions used in darshan with a generic
>> abstraction layer and create an MPI and POSIX-only implementation of
>> that layer. Just thinking ...
>> Regards, Michael
>> Am 04.06.2013 18 <tel:04.06.2013%2018>:49, schrieb Kevin Harms:
>> Michael,
>> Darshan itself needs MPI. It uses some collective calls and
>> file routines when generating the log. The log is written when
>> MPI_Finalize is called. If you're going to modify your POSIX
>> program, then it seems easier to just instrument your main()
>> with MPI_Init() and MPI_Finalize().
>> Using:
>> void __attribute__ ((constructor)) PMPI_Init()
>> i think would work to initialize darshan, but you still need
>> to call PMPI_Finalize at some point to get the log.
>> kevin
>> On Jun 4, 2013, at 8:37 AM, Michael Kluge
>> <mailto:michael.kluge at tu-dresden.de>> wrote:
>> Dear list,
>> if I understand all the documentation well, darshan collects
>> profiles of MPI programs only because it will initialize
>> itself from a wrapper to MPI_Init(). Is this the only case,
>> why pure POSIX programs (maybe multithreaded) would not work
>> together with darshan?
>> Is there any chance that an approach that uses
>> void __attribute__ ((constructor)) my_lib_init()
>> (see:
>> http://gcc.gnu.org/onlinedocs/__gcc/Function-Attributes.html
>> <http://gcc.gnu.org/onlinedocs/gcc/Function-Attributes.html>)
>> from gcc would work as well for pure POSIX programs?
>> Regards, Michael
>> Dr.-Ing. Michael Kluge
>> Technische Universität Dresden
>> Center for Information Services and
>> High Performance Computing (ZIH)
>> D-01062 Dresden
>> Germany
>> Contact:
>> Willersbau, Room WIL A 208
>> Phone: (+49) 351 463-34217 <tel:%28%2B49%29%20351%20463-34217>
>> Fax: (+49) 351 463-37773 <tel:%28%2B49%29%20351%20463-37773>
>> e-mail: michael.kluge at tu-dresden.de
>> WWW: http://www.tu-dresden.de/zih
>> _________________________________________________
>> Darshan-users mailing list
>> Darshan-users at lists.mcs.anl.__gov
>> <mailto:Darshan-users at lists.mcs.anl.gov>
>> https://lists.mcs.anl.gov/__mailman/listinfo/darshan-users
>> <https://lists.mcs.anl.gov/mailman/listinfo/darshan-users>
> D-01062 Dresden
> Germany
> Contact:
> Willersbau, Room A 208
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20130605/faeff09a/attachment.bin>
More information about the Darshan-users
