[Darshan-commits] [Git][darshan/darshan][dev-no-mpi] 3 commits: port lustre mod to recent darshan changes
Shane Snyder
xgitlab at cels.anl.gov
Tue Dec 10 15:56:35 CST 2019
Shane Snyder pushed to branch dev-no-mpi at darshan / darshan
Commits:
4fd1d6d3 by Shane Snyder at 2019-12-10T20:13:17Z
146a6ccb by Shane Snyder at 2019-12-10T20:29:00Z
port hdf5 mod to recent darshan changes
c0e202d6 by Shane Snyder at 2019-12-10T21:55:25Z
only include ld-opts for modules we build
6 changed files:
- darshan-runtime/Makefile.in
- darshan-runtime/configure
- darshan-runtime/configure.in
- darshan-runtime/lib/darshan-hdf5.c
- darshan-runtime/lib/darshan-lustre.c
- darshan-runtime/share/ld-opts/darshan-base-ld-opts.in
Changes:
@@ -248,16 +248,24 @@ endif
install -m 755 share/mpi-profile/darshan-bg-f.conf $(datarootdir)/mpi-profile/darshan-bg-f.conf
install -d $(datarootdir)/ld-opts
install -m 644 share/ld-opts/darshan-base-ld-opts $(datarootdir)/ld-opts/darshan-base-ld-opts
+ifdef BUILD_POSIX_MODULE
install -m 644 $(srcdir)/share/ld-opts/darshan-posix-ld-opts $(datarootdir)/ld-opts/darshan-posix-ld-opts
+endif
+ifdef BUILD_STDIO_MODULE
+ install -m 644 $(srcdir)/share/ld-opts/darshan-stdio-ld-opts $(datarootdir)/ld-opts/darshan-stdio-ld-opts
+endif
+ifdef BUILD_MPIIO_MODULE
+ install -m 644 $(srcdir)/share/ld-opts/darshan-mpiio-ld-opts $(datarootdir)/ld-opts/darshan-mpiio-ld-opts
+endif
+ifdef BUILD_PNETCDF_MODULE
+ install -m 644 $(srcdir)/share/ld-opts/darshan-pnetcdf-ld-opts $(datarootdir)/ld-opts/darshan-pnetcdf-ld-opts
+endif
ifdef BUILD_HDF5_MODULE
install -m 644 $(srcdir)/share/ld-opts/darshan-hdf5-ld-opts $(datarootdir)/ld-opts/darshan-hdf5-ld-opts
endif
ifdef BUILD_MDHIM_MODULE
install -m 644 $(srcdir)/share/ld-opts/darshan-mdhim-ld-opts $(datarootdir)/ld-opts/darshan-mdhim-ld-opts
endif
- install -m 644 $(srcdir)/share/ld-opts/darshan-pnetcdf-ld-opts $(datarootdir)/ld-opts/darshan-pnetcdf-ld-opts
- install -m 644 $(srcdir)/share/ld-opts/darshan-stdio-ld-opts $(datarootdir)/ld-opts/darshan-stdio-ld-opts
- install -m 644 $(srcdir)/share/ld-opts/darshan-mpiio-ld-opts $(datarootdir)/ld-opts/darshan-mpiio-ld-opts
ifdef ENABLE_MMAP_LOGS
install -m 755 share/darshan-mmap-epilog.sh $(datarootdir)/darshan-mmap-epilog.sh
endif
@@ -679,7 +679,6 @@ infodir
docdir
oldincludedir
includedir
-runstatedir
localstatedir
sharedstatedir
sysconfdir
@@ -775,7 +774,6 @@ datadir='${datarootdir}'
sysconfdir='${prefix}/etc'
sharedstatedir='${prefix}/com'
localstatedir='${prefix}/var'
-runstatedir='${localstatedir}/run'
includedir='${prefix}/include'
oldincludedir='/usr/include'
docdir='${datarootdir}/doc/${PACKAGE_TARNAME}'
@@ -1028,15 +1026,6 @@ do
| -silent | --silent | --silen | --sile | --sil)
silent=yes ;;
- -runstatedir | --runstatedir | --runstatedi | --runstated \
- | --runstate | --runstat | --runsta | --runst | --runs \
- | --run | --ru | --r)
- ac_prev=runstatedir ;;
- -runstatedir=* | --runstatedir=* | --runstatedi=* | --runstated=* \
- | --runstate=* | --runstat=* | --runsta=* | --runst=* | --runs=* \
- | --run=* | --ru=* | --r=*)
- runstatedir=$ac_optarg ;;
-sbindir | --sbindir | --sbindi | --sbind | --sbin | --sbi | --sb)
ac_prev=sbindir ;;
-sbindir=* | --sbindir=* | --sbindi=* | --sbind=* | --sbin=* \
@@ -1174,7 +1163,7 @@ fi
for ac_var in exec_prefix prefix bindir sbindir libexecdir datarootdir \
datadir sysconfdir sharedstatedir localstatedir includedir \
oldincludedir docdir infodir htmldir dvidir pdfdir psdir \
- libdir localedir mandir runstatedir
+ libdir localedir mandir
do
eval ac_val=\$$ac_var
# Remove trailing slashes.
@@ -1327,7 +1316,6 @@ Fine tuning of the installation directories:
--sysconfdir=DIR read-only single-machine data [PREFIX/etc]
--sharedstatedir=DIR modifiable architecture-independent data [PREFIX/com]
--localstatedir=DIR modifiable single-machine data [PREFIX/var]
- --runstatedir=DIR modifiable per-process data [LOCALSTATEDIR/run]
--libdir=DIR object code libraries [EPREFIX/lib]
--includedir=DIR C header files [PREFIX/include]
--oldincludedir=DIR C header files for non-gcc [/usr/include]
@@ -2304,6 +2292,25 @@ test -z "$INSTALL_SCRIPT" && INSTALL_SCRIPT='${INSTALL}'
test -z "$INSTALL_DATA" && INSTALL_DATA='${INSTALL} -m 644'
+# We need to know the value of the $libdir and $bindir variables so that
+# we can reference the correct path in the darshan compiler wrappers.
+# Unfortunately, those two variables are not normally evaluated by autoconf.
+# They are evaluated at build time using Makefile variable substitutions.
+# The following logic was copied from mpich2 1.3.1 to resolve the $libdir
+# variable at configure time.
+# Temporarily replace the default NONE value for exec_prefix
+# and prefix with the actual, default values.
+savePrefix=$prefix
+saveExecprefix=$exec_prefix
+test "x$prefix" = xNONE && prefix=$ac_default_prefix
+test "x$exec_prefix" = xNONE && exec_prefix=$prefix
+eval darshan_lib_path=$libdir
+eval darshan_share_path=$datarootdir
+prefix=$savePrefix
+exec_prefix=$saveExecprefix
# Check whether --with-mpi was given.
if test "${with_mpi+set}" = set; then :
@@ -4102,6 +4109,7 @@ fi
# HDF5 module
BUILD_HDF5_MODULE=
+BUILD_HDF5_POST110=
DARSHAN_HDF5_LD_OPTS=
# see if user explicitly enabled support for an HDF5 API
@@ -4115,6 +4123,7 @@ $as_echo "#define __DARSHAN_ENABLE_HDF5110 1" >>confdefs.h
as_fn_error $? "Cannot set both --enable-HDF5-post-1.10 and --enable-HDF5-pre-1.10" "$LINENO" 5
fi
BUILD_HDF5_MODULE=1
+ BUILD_HDF5_POST110=1
DARSHAN_HDF5_LD_OPTS="@${darshan_share_path}/ld-opts/darshan-hdf5-ld-opts"
fi
@@ -4635,25 +4644,6 @@ fi
done
-# We need to know the value of the $libdir and $bindir variables so that
-# we can reference the correct path in the darshan compiler wrappers.
-# Unfortunately, those two variables are not normally evaluated by autoconf.
-# They are evaluated at build time using Makefile variable substitutions.
-# The following logic was copied from mpich2 1.3.1 to resolve the $libdir
-# variable at configure time.
-# Temporarily replace the default NONE value for exec_prefix
-# and prefix with the actual, default values.
-savePrefix=$prefix
-saveExecprefix=$exec_prefix
-test "x$prefix" = xNONE && prefix=$ac_default_prefix
-test "x$exec_prefix" = xNONE && exec_prefix=$prefix
-eval darshan_lib_path=$libdir
-eval darshan_share_path=$datarootdir
-prefix=$savePrefix
-exec_prefix=$saveExecprefix
# Begin tests for MPI-enabled builds
@@ -6202,7 +6192,7 @@ fi
if test "x$BUILD_HDF5_MODULE" = "x"; then :
{ $as_echo "$as_me:${as_lineno-$LINENO}: HDF5 module support: no" >&5
$as_echo "$as_me: HDF5 module support: no" >&6;}
-elif if test "x$BUILD_HDF5_PRE110" = "x1"; then :
+elif if test "x$BUILD_HDF5_POST110" = "x1"; then :
{ $as_echo "$as_me:${as_lineno-$LINENO}: HDF5 module support: 1.10+" >&5
$as_echo "$as_me: HDF5 module support: 1.10+" >&6;}
else
@@ -13,6 +13,25 @@ AC_CONFIG_HEADER(darshan-runtime-config.h)
AC_PROG_INSTALL
+savePrefix=$prefix
+prefix=$savePrefix
dnl Check for MPI
AC_ARG_WITH(mpi,
[AS_HELP_STRING([--without-mpi], [Build without support for MPI])],
@@ -211,6 +230,7 @@ AS_IF([test "x$enable_pnetcdf_mod" = "xno" || test "x$ENABLE_MPI" = "x"],
# HDF5 module
BUILD_HDF5_MODULE=
@@ -223,6 +243,7 @@ AC_ARG_ENABLE(HDF5-post-1.10,
AC_MSG_ERROR([Cannot set both --enable-HDF5-post-1.10 and --enable-HDF5-pre-1.10])
fi
BUILD_HDF5_MODULE=1
fi]
@@ -365,25 +386,6 @@ CFLAGS="$old_cflags"
AC_CHECK_HEADERS(mntent.h sys/mount.h)
-savePrefix=$prefix
-prefix=$savePrefix
@@ -535,7 +537,7 @@ AS_IF(
[test "x$BUILD_HDF5_MODULE" = "x"],
[AC_MSG_NOTICE(HDF5 module support: no)],
[AS_IF(
- [test "x$BUILD_HDF5_PRE110" = "x1"],
+ [test "x$BUILD_HDF5_POST110" = "x1"],
[AC_MSG_NOTICE(HDF5 module support: 1.10+)],
[AC_MSG_NOTICE(HDF5 module support: pre-1.10)]
@@ -60,14 +60,17 @@ static void hdf5_runtime_initialize(
void);
static struct hdf5_file_record_ref *hdf5_track_new_file_record(
darshan_record_id rec_id, const char *path);
-static void hdf5_record_reduction_op(
- void* infile_v, void* inoutfile_v, int *len, MPI_Datatype *datatype);
static void hdf5_cleanup_runtime(
void);
+#ifdef HAVE_MPI
+static void hdf5_record_reduction_op(
+ void* infile_v, void* inoutfile_v, int *len, MPI_Datatype *datatype);
+static void hdf5_mpi_redux(
+ void *hdf5_buf, MPI_Comm mod_comm,
+ darshan_record_id *shared_recs, int shared_rec_count);
+#endif
static void hdf5_shutdown(
- MPI_Comm mod_comm, darshan_record_id *shared_recs,
- int shared_rec_count, void **hdf5_buf, int *hdf5_buf_sz);
+ void **hdf5_buf, int *hdf5_buf_sz);
static struct hdf5_runtime *hdf5_runtime = NULL;
static pthread_mutex_t hdf5_runtime_mutex = PTHREAD_RECURSIVE_MUTEX_INITIALIZER_NP;
@@ -257,6 +260,12 @@ herr_t DARSHAN_DECL(H5Fclose)(hid_t file_id)
static void hdf5_runtime_initialize()
int hdf5_buf_size;
+ darshan_module_funcs mod_funcs = {
+#ifdef HAVE_MPI
+ .mod_redux_func = &hdf5_mpi_redux,
+#endif
+ .mod_shutdown_func = &hdf5_shutdown
/* try and store the default number of records for this module */
hdf5_buf_size = DARSHAN_DEF_MOD_REC_COUNT * sizeof(struct darshan_hdf5_file);
@@ -264,7 +273,7 @@ static void hdf5_runtime_initialize()
/* register hdf5 module with darshan-core */
darshan_core_register_module(
DARSHAN_HDF5_MOD,
- &hdf5_shutdown,
+ mod_funcs,
&hdf5_buf_size,
&my_rank,
NULL);
@@ -335,6 +344,18 @@ static struct hdf5_file_record_ref *hdf5_track_new_file_record(
return(rec_ref);
+static void hdf5_cleanup_runtime()
+ darshan_clear_record_refs(&(hdf5_runtime->hid_hash), 0);
+ darshan_clear_record_refs(&(hdf5_runtime->rec_id_hash), 1);
+ free(hdf5_runtime);
+ hdf5_runtime = NULL;
+ return;
+#ifdef HAVE_MPI
static void hdf5_record_reduction_op(void* infile_v, void* inoutfile_v,
@@ -384,32 +405,22 @@ static void hdf5_record_reduction_op(void* infile_v, void* inoutfile_v,
return;
-static void hdf5_cleanup_runtime()
- darshan_clear_record_refs(&(hdf5_runtime->hid_hash), 0);
- darshan_clear_record_refs(&(hdf5_runtime->rec_id_hash), 1);
- free(hdf5_runtime);
- hdf5_runtime = NULL;
- return;
+#endif
* Functions exported by HDF5 module for coordinating with darshan-core *
-static void hdf5_shutdown(
+#ifdef HAVE_MPI
+ void *hdf5_buf,
MPI_Comm mod_comm,
- void **hdf5_buf,
- int *hdf5_buf_sz)
+ int shared_rec_count)
+ int hdf5_rec_count;
struct hdf5_file_record_ref *rec_ref;
struct darshan_hdf5_file *hdf5_rec_buf = *(struct darshan_hdf5_file **)hdf5_buf;
- int hdf5_rec_count;
struct darshan_hdf5_file *red_send_buf = NULL;
struct darshan_hdf5_file *red_recv_buf = NULL;
MPI_Datatype red_type;
@@ -419,81 +430,88 @@ static void hdf5_shutdown(
HDF5_LOCK();
assert(hdf5_runtime);
- hdf5_rec_count = hdf5_runtime->file_rec_count;
+ /* necessary initialization of shared records */
+ for(i = 0; i < shared_rec_count; i++)
+ rec_ref = darshan_lookup_record_ref(hdf5_runtime->rec_id_hash,
+ &shared_recs[i], sizeof(darshan_record_id));
+ assert(rec_ref);
+ rec_ref->file_rec->base_rec.rank = -1;
- /* if there are globally shared files, do a shared file reduction */
- /* NOTE: the shared file reduction is also skipped if the
- * DARSHAN_DISABLE_SHARED_REDUCTION environment variable is set.
+ /* sort the array of records so we get all of the shared records
+ * (marked by rank -1) in a contiguous portion at end of the array
- if(shared_rec_count && !getenv("DARSHAN_DISABLE_SHARED_REDUCTION"))
+ darshan_record_sort(hdf5_rec_buf, hdf5_rec_count,
+ sizeof(struct darshan_hdf5_file));
+ /* make *send_buf point to the shared files at the end of sorted array */
+ red_send_buf = &(hdf5_rec_buf[hdf5_rec_count-shared_rec_count]);
+ /* allocate memory for the reduction output on rank 0 */
+ if(my_rank == 0)
- /* necessary initialization of shared records */
- for(i = 0; i < shared_rec_count; i++)
+ red_recv_buf = malloc(shared_rec_count * sizeof(struct darshan_hdf5_file));
+ if(!red_recv_buf)
- rec_ref = darshan_lookup_record_ref(hdf5_runtime->rec_id_hash,
- &shared_recs[i], sizeof(darshan_record_id));
- assert(rec_ref);
- rec_ref->file_rec->base_rec.rank = -1;
+ HDF5_UNLOCK();
+ return;
- /* sort the array of records so we get all of the shared records
- * (marked by rank -1) in a contiguous portion at end of the array
- darshan_record_sort(hdf5_rec_buf, hdf5_rec_count,
- sizeof(struct darshan_hdf5_file));
+ /* construct a datatype for a HDF5 file record. This is serving no purpose
+ * except to make sure we can do a reduction on proper boundaries
+ PMPI_Type_contiguous(sizeof(struct darshan_hdf5_file),
+ MPI_BYTE, &red_type);
+ PMPI_Type_commit(&red_type);
- /* make *send_buf point to the shared files at the end of sorted array */
- red_send_buf = &(hdf5_rec_buf[hdf5_rec_count-shared_rec_count]);
+ /* register a HDF5 file record reduction operator */
+ PMPI_Op_create(hdf5_record_reduction_op, 1, &red_op);
- /* allocate memory for the reduction output on rank 0 */
- if(my_rank == 0)
- red_recv_buf = malloc(shared_rec_count * sizeof(struct darshan_hdf5_file));
- if(!red_recv_buf)
- HDF5_UNLOCK();
- return;
+ /* reduce shared HDF5 file records */
+ PMPI_Reduce(red_send_buf, red_recv_buf,
+ shared_rec_count, red_type, red_op, 0, mod_comm);
- /* construct a datatype for a HDF5 file record. This is serving no purpose
- * except to make sure we can do a reduction on proper boundaries
- PMPI_Type_contiguous(sizeof(struct darshan_hdf5_file),
- MPI_BYTE, &red_type);
- PMPI_Type_commit(&red_type);
+ /* clean up reduction state */
+ if(my_rank == 0)
+ int tmp_ndx = hdf5_rec_count - shared_rec_count;
+ memcpy(&(hdf5_rec_buf[tmp_ndx]), red_recv_buf,
+ shared_rec_count * sizeof(struct darshan_hdf5_file));
+ free(red_recv_buf);
+ else
+ hdf5_rec_count -= shared_rec_count;
- /* register a HDF5 file record reduction operator */
- PMPI_Op_create(hdf5_record_reduction_op, 1, &red_op);
+ PMPI_Type_free(&red_type);
+ PMPI_Op_free(&red_op);
- /* reduce shared HDF5 file records */
- PMPI_Reduce(red_send_buf, red_recv_buf,
- shared_rec_count, red_type, red_op, 0, mod_comm);
+ HDF5_UNLOCK();
+ return;
+#endif
- /* clean up reduction state */
- if(my_rank == 0)
- int tmp_ndx = hdf5_rec_count - shared_rec_count;
- memcpy(&(hdf5_rec_buf[tmp_ndx]), red_recv_buf,
- shared_rec_count * sizeof(struct darshan_hdf5_file));
- free(red_recv_buf);
- else
- hdf5_rec_count -= shared_rec_count;
+static void hdf5_shutdown(
+ void **hdf5_buf,
+ int *hdf5_buf_sz)
- PMPI_Type_free(&red_type);
- PMPI_Op_free(&red_op);
+ HDF5_LOCK();
+ assert(hdf5_runtime);
- /* update output buffer size to account for shared file reduction */
- *hdf5_buf_sz = hdf5_rec_count * sizeof(struct darshan_hdf5_file);
+ hdf5_rec_count = hdf5_runtime->file_rec_count;
/* shutdown internal structures used for instrumenting */
hdf5_cleanup_runtime();
+ /* update output buffer size to account for shared file reduction */
+ *hdf5_buf_sz = hdf5_rec_count * sizeof(struct darshan_hdf5_file);
HDF5_UNLOCK();
return;
@@ -35,9 +35,13 @@ static int lustre_record_compare(
int sort_lustre_records(
void);
+#ifdef HAVE_MPI
+static void lustre_mpi_redux(
+ void *lustre_buf, MPI_Comm mod_comm,
+#endif
static void lustre_shutdown(
- int shared_rec_count, void **lustre_buf, int *lustre_buf_sz);
+ void **lustre_buf, int *lustre_buf_sz);
struct lustre_runtime *lustre_runtime = NULL;
static pthread_mutex_t lustre_runtime_mutex = PTHREAD_RECURSIVE_MUTEX_INITIALIZER_NP;
@@ -49,6 +53,7 @@ static int my_rank = -1;
#ifndef LOV_MAX_STRIPE_COUNT /* for Lustre < 2.4 */
#define LOV_MAX_STRIPE_COUNT 2000
#endif
void darshan_instrument_lustre_file(const char* filepath, int fd)
struct lustre_record_ref *rec_ref;
@@ -177,6 +182,13 @@ void darshan_instrument_lustre_file(const char* filepath, int fd)
static void lustre_runtime_initialize()
int lustre_buf_size;
+#ifdef HAVE_MPI
+ .mod_redux_func = &lustre_mpi_redux,
+#endif
+ .mod_shutdown_func = &lustre_shutdown
/* try and store a default number of records for this module, assuming
* each file uses 64 OSTs
@@ -186,7 +198,7 @@ static void lustre_runtime_initialize()
/* register the lustre module with darshan-core */
DARSHAN_LUSTRE_MOD,
- &lustre_shutdown,
+ mod_funcs,
&lustre_buf_size,
&my_rank,
NULL);
@@ -215,12 +227,12 @@ static void lustre_runtime_initialize()
* Functions exported by Lustre module for coordinating with darshan-core *
-static void lustre_shutdown(
+#ifdef HAVE_MPI
+ void *posix_buf,
MPI_Comm mod_comm,
- void **lustre_buf,
- int *lustre_buf_sz)
int i;
@@ -228,9 +240,6 @@ static void lustre_shutdown(
LUSTRE_LOCK();
assert(lustre_runtime);
- lustre_runtime->record_buffer = *lustre_buf;
- lustre_runtime->record_buffer_size = *lustre_buf_sz;
@@ -253,21 +262,36 @@ static void lustre_shutdown(
else
darshan_core_fprintf(stderr, "WARNING: unexpected condition in Darshan, possibly triggered by memory corruption. Darshan log may be incorrect.\n");
- /* sort the array of files descending by rank so that we get all of the
- * shared files (marked by rank -1) in a contiguous portion at end
- * of the array
- sort_lustre_records();
+ LUSTRE_UNLOCK();
+ return;
+#endif
- /* simply drop all shared records from the end of the record array on
- * non-root ranks simply by recalculating the size of the buffer
- if (my_rank != 0)
- darshan_iter_record_refs(lustre_runtime->record_id_hash,
- &lustre_subtract_shared_rec_size);
+static void lustre_shutdown(
+ int *lustre_buf_sz)
+ LUSTRE_LOCK();
+ assert(lustre_runtime);
+ lustre_runtime->record_buffer = *lustre_buf;
+ lustre_runtime->record_buffer_size = *lustre_buf_sz;
+ /* sort the array of files descending by rank so that we get all of the
+ * shared files (marked by rank -1) in a contiguous portion at end
+ * of the array
+ sort_lustre_records();
+ /* simply drop all shared records from the end of the record array on
+ * non-root ranks simply by recalculating the size of the buffer
+ if (my_rank != 0)
+ darshan_iter_record_refs(lustre_runtime->record_id_hash,
+ &lustre_subtract_shared_rec_size);
/* modify output buffer size to account for any shared records that were removed */
@@ -7,9 +7,9 @@
--wrap=PMPI_Init
--wrap=PMPI_Init_thread
--wrap=PMPI_Finalize
-@@darshan_share_path@/ld-opts/darshan-posix-ld-opts
-@@darshan_share_path@/ld-opts/darshan-pnetcdf-ld-opts
-@@darshan_share_path@/ld-opts/darshan-stdio-ld-opts
-@@darshan_share_path@/ld-opts/darshan-mpiio-ld-opts
+ at DARSHAN_POSIX_LD_OPTS@
+ at DARSHAN_STDIO_LD_OPTS@
+ at DARSHAN_MPIIO_LD_OPTS@
+ at DARSHAN_PNETCDF_LD_OPTS@
@DARSHAN_HDF5_LD_OPTS@
@DARSHAN_MDHIM_LD_OPTS@
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/compare/2d3f980d516bf52a3edf87671f6ddfb9f5962801...c0e202d699e382a9516eac42dca3e0592137cf45
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20191210/252724e4/attachment-0001.html>
More information about the Darshan-commits
