[Darshan-commits] [Git][darshan/darshan][dev-no-mpi] update darshan-runtime doc to reflect non-mpi work
Shane Snyder
xgitlab at cels.anl.gov
Tue Dec 10 12:01:24 CST 2019
Shane Snyder pushed to branch dev-no-mpi at darshan / darshan
Commits:
2d3f980d by Shane Snyder at 2019-12-10T18:00:52Z
1 changed file:
- darshan-runtime/doc/darshan-runtime.txt
Changes:
@@ -13,12 +13,19 @@ application that has been instrumented with Darshan will produce a single
log file each time it is executed. This log summarizes the I/O access patterns
used by the application.
-The darshan-runtime instrumentation only instruments MPI applications (the
-application must at least call `MPI_Init()` and `MPI_Finalize()`). However,
-it captures both MPI-IO and POSIX file access. It also captures limited
-information about HDF5 and PnetCDF access. Darshan also exposes an API that
-can be used to develop and add new instrumentation modules (for other I/O library
-interfaces or to gather system-specific data, for instance), as detailed in
+The darshan-runtime instrumentation has traditionally only supported MPI
+applications (specifically, those that call `MPI_Init()` and `MPI_Finalize()`),
+but, as of version 3.2.0, Darshan also supports instrumentation of non-MPI
+applications. Regardless of whether MPI is used, Darshan provides detailed
+statistics about POSIX level file accesses made by the application.
+In the case of MPI applications, Darshan additionally captures detals on MPI-IO
+level access, as well as limited information about HDF5 and PnetCDF access.
+Note that instrumentation of non-MPI applications is currently only supported
+in Darshan's shared library, which applications must `LD_PRELOAD`.
+Starting in version 3.0.0, Darshan also exposes an API that can be used to develop
+and add new instrumentation modules (for other I/O library interfaces or to gather
+system-specific data, for instance), as detailed in
http://www.mcs.anl.gov/research/projects/darshan/docs/darshan-modularization.html[this document].
Newly contributed modules include a module for gathering system-specific parameters
for jobs running on BG/Q systems, a module for gathering Lustre striping data for
@@ -42,12 +49,12 @@ http://www.mcs.anl.gov/darshan[Darshan web site].
== Requirements
-* MPI C compiler
+* C compiler (preferrably GCC-compatible)
* zlib development headers and library
== Compilation
-.Configure and build example
+.Configure and build example (with MPI support)
tar -xvzf darshan-<version-number>.tar.gz
cd darshan-<version-number>/darshan-runtime
@@ -56,6 +63,15 @@ make
make install
+.Configure and build example (without MPI support)
+tar -xvzf darshan-<version-number>.tar.gz
+cd darshan-<version-number>/darshan-runtime
+./configure --with-mem-align=8 --with-log-path=/darshan-logs --with-jobid-env=PBS_JOBID --without-mpi CC=gcc
+make
+make install
.Explanation of configure arguments:
* `--with-mem-align=` (mandatory): This value is system-dependent and will be
used by Darshan to determine if the buffer for a read or write operation is
@@ -77,7 +93,9 @@ file. See `./configure --help` for details.
active Darshan instrumentation modules can collectively consume.
* `--with-zlib=`: specifies an alternate location for the zlib development
header and library.
-* `CC=`: specifies the MPI C compiler to use for compilation.
+* `CC=`: specifies the C compiler to use for compilation.
+* `--without-mpi`: disables MPI support when building Darshan - MPI support is
+assumed if not specified.
* `--enable-mmap-logs`: enables the use of Darshan's mmap log file mechanism.
* `--disable-cuserid`: disables use of cuserid() at runtime.
* `--disable-ld-preload`: disables building of the Darshan LD_PRELOAD library
@@ -147,22 +165,22 @@ administrators group
=== Instrumentation method
The instrumentation method to use depends on whether the executables
-produced by your MPI compiler are statically or dynamically linked. If you
+produced by your compiler are statically or dynamically linked. If you
are unsure, you can check by running `ldd <executable_name>` on an example
executable. Dynamically-linked executables will produce a list of shared
libraries when this command is executed.
-Most MPI compilers allow you to toggle dynamic or static linking via options
-such as `-dynamic` or `-static`. Please check your MPI compiler man page
+Some compilers allow you to toggle dynamic or static linking via options
+such as `-dynamic` or `-static`. Please check your compiler man page
for details if you intend to force one mode or the other.
-== Instrumenting statically-linked applications
+== Instrumenting statically-linked MPI applications
Statically linked executables must be instrumented at compile time.
The simplest methods to do this are to either generate a customized
MPI compiler script (e.g. `mpicc`) that includes the link options and
libraries needed by Darshan, or to use existing profiling configuration
-hooks for existing MPI compiler scripts. Once this is done, Darshan
+hooks for MPI compiler scripts. Once this is done, Darshan
instrumentation is transparent; you simply compile applications using
the darshan-enabled MPI compiler scripts.
@@ -224,9 +242,9 @@ add the necessary link options and libraries. Please see the
`darshan-gen-*` scripts for examples or contact the Darshan users mailing
list for help.
-== Instrumenting dynamically-linked applications
+== Instrumenting dynamically-linked MPI applications
-For dynamically-linked executables, darshan relies on the `LD_PRELOAD`
+For dynamically-linked executables, Darshan relies on the `LD_PRELOAD`
environment variable to insert instrumentation at run time. The executables
should be compiled using the normal, unmodified MPI compiler.
@@ -245,7 +263,7 @@ mpiexec -n 4 -env LD_PRELOAD /home/carns/darshan-install/lib/libdarshan.so mpi-i
srun -n 4 --export=LD_PRELOAD=/home/carns/darshan-install/lib/libdarshan.so mpi-io-test
-For sequential programs, the following will set LD_PRELOAD for process duration only:
+For sequential invocations of MPI programs, the following will set LD_PRELOAD for process duration only:
env LD_PRELOAD=/home/carns/darshan-install/lib/libdarshan.so mpi-io-test
@@ -288,6 +306,35 @@ exclusively by the executable itself. You can check the rpath of the
darshan library by running `objdump -x
/home/carns/darshan-install/lib/libdarshan.so |grep RPATH`.
+== Instrumenting dynamically-linked non-MPI applications
+Similar to the process described in the previous section, Darshan relies on the
+`LD_PRELOAD` mechanism for instrumenting dynamically-linked non-MPI applications.
+This allows Darshan to instrument dynamically-linked binaries produced by non-MPI
+compilers (e.g., gcc or clang), extending Darshan instrumentation to new contexts
+(like instrumentation of arbitrary Python programs or instrumenting serial
+file transfer utilities like `cp` and `scp`).
+The only additional step required of Darshan non-MPI users is to also set the
+DARSHAN_ENABLE_NONMPI environment variable to signal to Darshan that non-MPI
+instrumentation is requested:
+export DARSHAN_ENABLE_NONMPI=1
+As described in the previous section, it may be desirable to users to limit the
+scope of Darshan's instrumentation by only enabling LD_PRELOAD on the target
+executable:
+env LD_PRELOAD=/home/carns/darshan-install/lib/libdarshan.so io-test
+[NOTE]
+Recall that Darshan instrumentation of non-MPI applications is only possible with
+dynamically-linked applications.
== Darshan installation recipes
The following recipes provide examples for prominent HPC systems.
@@ -557,6 +604,7 @@ behavior at runtime:
* DARSHAN_MMAP_LOGPATH: if Darshan's mmap log file mechanism is enabled, this variable specifies what path the mmap log files should be stored in (if not specified, log files will be stored in `/tmp`).
* DARSHAN_EXCLUDE_DIRS: specifies a list of comma-separated paths that Darshan will not instrument at runtime (in addition to Darshan's default blacklist)
* DXT_ENABLE_IO_TRACE: setting this environment variable enables the DXT (Darshan eXtended Tracing) modules at runtime. Users can specify a numeric value for this variable to set the number of MiB to use for tracing per process; if no value is specified, Darshan will use a default value of 4 MiB.
+* DARSHAN_ENABLE_NONMPI: setting this environment variable is required to generate Darshan logs for non-MPI applications
== Debugging
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/2d3f980d516bf52a3edf87671f6ddfb9f5962801
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20191210/56b13f9b/attachment-0001.html>
More information about the Darshan-commits
