[Darshan-commits] [Git][darshan/darshan][dev-no-mpi] 2 commits: bug fix: don't use mpi_in_place on nonzero ranks
Shane Snyder xgitlab at cels.anl.gov
Tue Dec 10 22:41:02 CST 2019
Shane Snyder pushed to branch dev-no-mpi at darshan / darshan
Commits:
d987494e by Shane Snyder at 2019-12-11T04:40:47Z
aff75f19 by Shane Snyder at 2019-12-11T04:40:47Z
bug fix: set input buffer for mpi reduxes
1 changed file:
- darshan-runtime/lib/darshan-core.c
Changes:
@@ -383,10 +383,18 @@ void darshan_core_initialize(int argc, char **argv)
 #ifdef HAVE_MPI
         if(using_mpi)
-            PMPI_Reduce(MPI_IN_PLACE, &init_time, 1,
-                MPI_DOUBLE, MPI_MAX, 0, darshan_core->mpi_comm);
+            if(my_rank == 0)
+                PMPI_Reduce(MPI_IN_PLACE, &init_time, 1,
+                    MPI_DOUBLE, MPI_MAX, 0, darshan_core->mpi_comm);
+            else
+                PMPI_Reduce(&init_time, &init_time, 1,
+                return; /* return early so every rank doesn't print */
-        if(my_rank > 0) return;
 #endif
         darshan_core_fprintf(stderr, "#darshan:<op>\t<nprocs>\t<time>\n");
@@ -473,10 +481,22 @@ void darshan_core_shutdown()
             MPI_SUM, final_core->mpi_comm);
         /* reduce to report first start and last end time across all ranks at rank 0 */
-        PMPI_Reduce(MPI_IN_PLACE, &final_core->log_job_p->start_time,
-            1, MPI_INT64_T, MPI_MIN, 0, final_core->mpi_comm);
-        PMPI_Reduce(MPI_IN_PLACE, &final_core->log_job_p->end_time,
-            1, MPI_INT64_T, MPI_MAX, 0, final_core->mpi_comm);
+        if(my_rank == 0)
+            PMPI_Reduce(MPI_IN_PLACE, &final_core->log_job_p->start_time,
+                1, MPI_INT64_T, MPI_MIN, 0, final_core->mpi_comm);
+            PMPI_Reduce(MPI_IN_PLACE, &final_core->log_job_p->end_time,
+                1, MPI_INT64_T, MPI_MAX, 0, final_core->mpi_comm);
+        else
+            PMPI_Reduce(&final_core->log_job_p->start_time,
+                &final_core->log_job_p->start_time,
+            PMPI_Reduce(&final_core->log_job_p->end_time,
+                &final_core->log_job_p->end_time,
         /* get a list of records which are shared across all processes */
         darshan_get_shared_records(final_core, &shared_recs, &shared_rec_cnt);
@@ -547,42 +567,40 @@ void darshan_core_shutdown()
         if(internal_timing_flag)
             mod1[i] = darshan_core_wtime();
-#ifdef HAVE_MPI
-        struct darshan_core_name_record_ref *ref = NULL;
-        int mod_shared_rec_cnt = 0;
-        int j;
-        if(using_mpi)
+        /* if module is registered locally, perform module shutdown operations */
+        if(this_mod)
-            /* set the shared record list for this module */
-            for(j = 0; j < shared_rec_cnt; j++)
+            mod_buf = final_core->mod_array[i]->rec_buf_start;
+            mod_buf_sz = final_core->mod_array[i]->rec_buf_p - mod_buf;
+#ifdef HAVE_MPI
+            if(using_mpi)
-                HASH_FIND(hlink, final_core->name_hash, &shared_recs[j],
-                    sizeof(darshan_record_id), ref);
-                assert(ref);
-                if(DARSHAN_MOD_FLAG_ISSET(ref->global_mod_flags, i))
+                struct darshan_core_name_record_ref *ref = NULL;
+                int mod_shared_rec_cnt = 0;
+                int j;
+                /* set the shared record list for this module */
+                for(j = 0; j < shared_rec_cnt; j++)
-                    mod_shared_recs[mod_shared_rec_cnt++] = shared_recs[j];
+                    HASH_FIND(hlink, final_core->name_hash, &shared_recs[j],
+                        sizeof(darshan_record_id), ref);
+                    assert(ref);
+                    if(DARSHAN_MOD_FLAG_ISSET(ref->global_mod_flags, i))
+                        mod_shared_recs[mod_shared_rec_cnt++] = shared_recs[j];
-            /* allow the module an opportunity to reduce shared files */
-            if(this_mod->mod_funcs.mod_redux_func && (mod_shared_recs > 0) &&
-               (!getenv("DARSHAN_DISABLE_SHARED_REDUCTION")))
-                this_mod->mod_funcs.mod_redux_func(mod_buf, final_core->mpi_comm,
-                    mod_shared_recs, mod_shared_rec_cnt);
+                /* allow the module an opportunity to reduce shared files */
+                if(this_mod->mod_funcs.mod_redux_func && (mod_shared_recs > 0) &&
+                   (!getenv("DARSHAN_DISABLE_SHARED_REDUCTION")))
+                    this_mod->mod_funcs.mod_redux_func(mod_buf, final_core->mpi_comm,
+                        mod_shared_recs, mod_shared_rec_cnt);
 #endif
-        /* if module is registered locally, get the corresponding output buffer
-         * NOTE: this function can be used to run collective operations across
-         * modules, if there are records shared globally.
-        if(this_mod)
-            mod_buf = final_core->mod_array[i]->rec_buf_start;
-            mod_buf_sz = final_core->mod_array[i]->rec_buf_p - mod_buf;
+            /* get the final output buffer */
             this_mod->mod_funcs.mod_shutdown_func(&mod_buf, &mod_buf_sz);
@@ -643,22 +661,39 @@ void darshan_core_shutdown()
 #ifdef HAVE_MPI
         if(using_mpi)
-            PMPI_Reduce(MPI_IN_PLACE, &open_tm, 1,
-                MPI_DOUBLE, MPI_MAX, 0, final_core->mpi_comm);
-            PMPI_Reduce(MPI_IN_PLACE, &header_tm, 1,
-            PMPI_Reduce(MPI_IN_PLACE, &job_tm, 1,
-            PMPI_Reduce(MPI_IN_PLACE, &rec_tm, 1,
-            PMPI_Reduce(MPI_IN_PLACE, &all_tm, 1,
-            PMPI_Reduce(MPI_IN_PLACE, mod_tm, DARSHAN_MAX_MODS,
-            /* let rank 0 report the timing info */
-            if(my_rank > 0)
+            if(my_rank == 0)
+                PMPI_Reduce(MPI_IN_PLACE, &open_tm, 1,
+                    MPI_DOUBLE, MPI_MAX, 0, final_core->mpi_comm);
+                PMPI_Reduce(MPI_IN_PLACE, &header_tm, 1,
+                PMPI_Reduce(MPI_IN_PLACE, &job_tm, 1,
+                PMPI_Reduce(MPI_IN_PLACE, &rec_tm, 1,
+                PMPI_Reduce(MPI_IN_PLACE, &all_tm, 1,
+                PMPI_Reduce(MPI_IN_PLACE, mod_tm, DARSHAN_MAX_MODS,
+            else
+                PMPI_Reduce(&open_tm, &open_tm, 1,
+                PMPI_Reduce(&header_tm, &header_tm, 1,
+                PMPI_Reduce(&job_tm, &job_tm, 1,
+                PMPI_Reduce(&rec_tm, &rec_tm, 1,
+                PMPI_Reduce(&all_tm, &all_tm, 1,
+                PMPI_Reduce(mod_tm, mod_tm, DARSHAN_MAX_MODS,
+                /* let rank 0 report the timing info */
                 goto exit;
 #endif
@@ -1678,7 +1713,7 @@ static int darshan_log_write_header(darshan_core_log_fh log_fh,
 #ifdef HAVE_MPI
     MPI_Status status;
-    if (using_mpi)
+    if(using_mpi)
         /* write out log header, after running 2 reductions on header variables:
          *  1) reduce 'partial_flag' variable to determine which modules ran out
@@ -1686,16 +1721,25 @@ static int darshan_log_write_header(darshan_core_log_fh log_fh,
          *  2) reduce 'mod_ver' array to determine which log format version each
          *     module used for this output log
-        PMPI_Reduce(
-            MPI_IN_PLACE, &(core->log_hdr_p->partial_flag),
-            1, MPI_UINT32_T, MPI_BOR, 0, core->mpi_comm);
-        PMPI_Reduce(
-            MPI_IN_PLACE, &(core->log_hdr_p->mod_ver),
-            DARSHAN_MAX_MODS, MPI_UINT32_T, MPI_MAX, 0, core->mpi_comm);
-        /* only rank 0 writes the header */
-        if(my_rank > 0)
-            return(0);
+        if(my_rank == 0)
+            PMPI_Reduce(
+                MPI_IN_PLACE, &(core->log_hdr_p->partial_flag),
+                1, MPI_UINT32_T, MPI_BOR, 0, core->mpi_comm);
+            PMPI_Reduce(
+                MPI_IN_PLACE, &(core->log_hdr_p->mod_ver),
+                DARSHAN_MAX_MODS, MPI_UINT32_T, MPI_MAX, 0, core->mpi_comm);
+        else
+            PMPI_Reduce(
+                &(core->log_hdr_p->partial_flag), &(core->log_hdr_p->partial_flag),
+            PMPI_Reduce(
+                &(core->log_hdr_p->mod_ver), &(core->log_hdr_p->mod_ver),
+            return(0); /* only rank 0 writes the header */
         /* write the header using MPI */
         ret = PMPI_File_write_at(log_fh.mpi_fh, 0, core->log_hdr_p,
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/compare/c0e202d699e382a9516eac42dca3e0592137cf45...aff75f19b5cb8d3d1e3cf01e7eabac8a84583105
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20191210/84ea0337/attachment-0001.html>
More information about the Darshan-commits mailing list
