[Darshan-commits] [Git][darshan/darshan][autoperf-mod] 3 commits: Update darshan-parser to move module specific code for perf,totals,etc. into the…
Kevin Harms xgitlab at cels.anl.gov
Thu Mar 8 16:27:37 CST 2018
Kevin Harms pushed to branch autoperf-mod at darshan / darshan
Commits:
3f4e5438 by Kevin Harms at 2018-03-08T22:03:19+00:00
Update darshan-parser to move module specific code for perf,totals,etc. into the module specific parts of the code. Make parser more generic
edbae6e2 by Kevin Harms at 2018-03-08T22:26:54+00:00
Correct __apxc_logutils definition
457a18fc by Kevin Harms at 2018-03-08T22:27:15+00:00
Remove requirement for papi in darshan-util
14 changed files:
- darshan-log-format.h
- darshan-util/configure.in
- darshan-util/darshan-bgq-logutils.c
- darshan-util/darshan-dxt-logutils.c
- darshan-util/darshan-hdf5-logutils.c
- darshan-util/darshan-logutils.c
- darshan-util/darshan-logutils.h
- darshan-util/darshan-lustre-logutils.c
- darshan-util/darshan-mpiio-logutils.c
- darshan-util/darshan-null-logutils.c
- darshan-util/darshan-parser.c
- darshan-util/darshan-pnetcdf-logutils.c
- darshan-util/darshan-posix-logutils.c
- darshan-util/darshan-stdio-logutils.c
Changes:
--- a/darshan-log-format.h
+++ b/darshan-log-format.h
@@ -139,7 +139,7 @@ struct darshan_base_record
 #ifdef DARSHAN_USE_APXC
 #define __DARSHAN_APXC_VER DARSHAN_APXC_VER
-#define __apxc_logutils = &apx_logutils;
+#define __apxc_logutils &apxc_logutils
 #else
 #define __DARSHAN_APXC_VER 0
 #define __apxc_logutils NULL
--- a/darshan-util/configure.in
+++ b/darshan-util/configure.in
@@ -86,10 +86,6 @@ AC_ARG_ENABLE(
 if test x$enable_autoperf_crayxc = xyes; then
-    AC_CHECK_HEADER([papi.h],
-                    with_papi=-lpapi,
-                    [AC_MSG_ERROR([Cannot find required header for papi])],
     AC_REQUIRE_AUX_FILE([modules/autoperf/crayxc/darshan-apxc-log-format.h])
 dnl    AC_CHECK_FILE([modules/autoperf/crayxc/darshan-apxc-log-format.h],
 dnl                  DARSHAN_USE_APXC=1,
--- a/darshan-util/darshan-bgq-logutils.c
+++ b/darshan-util/darshan-bgq-logutils.c
@@ -50,7 +50,13 @@ struct darshan_mod_logutil_funcs bgq_logutils =
     .log_print_record = &darshan_log_print_bgq_rec,
     .log_print_description = &darshan_log_print_bgq_description,
     .log_print_diff = &darshan_log_print_bgq_rec_diff,
-    .log_agg_records = &darshan_log_agg_bgq_recs
+    .log_agg_records = &darshan_log_agg_bgq_recs,
+    .log_accum_file = NULL,
+    .log_accum_perf = NULL,
+    .log_calc_file = NULL,
+    .log_print_total_file = NULL,
+    .log_file_list = NULL,
+    .log_calc_perf = NULL
 static int darshan_log_get_bgq_rec(darshan_fd fd, void** bgq_buf_p)
--- a/darshan-util/darshan-dxt-logutils.c
+++ b/darshan-util/darshan-dxt-logutils.c
@@ -41,6 +41,12 @@ struct darshan_mod_logutil_funcs dxt_posix_logutils =
     .log_print_description = NULL,
     .log_print_diff = NULL,
     .log_agg_records = NULL,
 struct darshan_mod_logutil_funcs dxt_mpiio_logutils =
--- a/darshan-util/darshan-hdf5-logutils.c
+++ b/darshan-util/darshan-hdf5-logutils.c
@@ -46,7 +46,13 @@ struct darshan_mod_logutil_funcs hdf5_logutils =
     .log_print_record = &darshan_log_print_hdf5_file,
     .log_print_description = &darshan_log_print_hdf5_description,
     .log_print_diff = &darshan_log_print_hdf5_file_diff,
-    .log_agg_records = &darshan_log_agg_hdf5_files
+    .log_agg_records = &darshan_log_agg_hdf5_files,
 static int darshan_log_get_hdf5_file(darshan_fd fd, void** hdf5_buf_p)
--- a/darshan-util/darshan-logutils.c
+++ b/darshan-util/darshan-logutils.c
@@ -1837,8 +1837,50 @@ int darshan_log_get_namerecs_3_00(void *name_rec_buf, int buf_len,
     return(buf_processed);
+void darshan_calc_perf(perf_data_t *pdata, int64_t nprocs)
+    int64_t i;
+    pdata->shared_time_by_cumul =
+        pdata->shared_time_by_cumul / (double)nprocs;
+    pdata->shared_meta_time = pdata->shared_meta_time / (double)nprocs;
+    for (i=0; i<nprocs; i++)
+        if (pdata->rank_cumul_io_time[i] > pdata->slowest_rank_time)
+            pdata->slowest_rank_time = pdata->rank_cumul_io_time[i];
+            pdata->slowest_rank_meta_time = pdata->rank_cumul_md_time[i];
+            pdata->slowest_rank_rank = i;
+    if (pdata->slowest_rank_time + pdata->shared_time_by_cumul)
+    pdata->agg_perf_by_cumul = ((double)pdata->total_bytes / 1048576.0) /
+                                  (pdata->slowest_rank_time +
+                                   pdata->shared_time_by_cumul);
+    if (pdata->slowest_rank_time + pdata->shared_time_by_open)
+    pdata->agg_perf_by_open  = ((double)pdata->total_bytes / 1048576.0) /
+                                    pdata->shared_time_by_open);
+    if (pdata->slowest_rank_time + pdata->shared_time_by_open_lastio)
+    pdata->agg_perf_by_open_lastio = ((double)pdata->total_bytes / 1048576.0) /
+                                      pdata->shared_time_by_open_lastio);
+    if (pdata->slowest_rank_time + pdata->shared_time_by_slowest)
+    pdata->agg_perf_by_slowest = ((double)pdata->total_bytes / 1048576.0) /
+                                      pdata->shared_time_by_slowest);
+    return;
- * Support functions for use with other languages
+ * Support functions for use with other language bindings
@@ -1872,6 +1914,11 @@ void darshan_log_get_modules (darshan_fd fd,
     return;
+ * darshan_log_get_record
+ *   Wrapper to hide the mod_logutils callback functions.
 int  darshan_log_get_record (darshan_fd fd,
                              int mod_idx,
                              void **buf)
@@ -1884,6 +1931,86 @@ int  darshan_log_get_record (darshan_fd fd,
+ * darshan_log_stats
+ *  Loops over the POSIX, MPIIO and STDIO module records to generate
+ *  derived stats. This is the same as the parser '--perf' and '--total'
+ *  options.
+int darshan_log_stats (darshan_fd fd)
+    int mod_list[] = { DARSHAN_POSIX_MOD,
+                       DARSHAN_MPIIO_MOD,
+                       DARSHAN_STDIO_MOD };
+    int i;
+    int idx;
+    int ret;
+    char *buf;
+    struct darshan_base_record *base_rec;
+    hash_entry_t *file_hash = NULL;
+    hash_entry_t total;
+    file_data_t fdata;
+    perf_data_t pdata;
+    memset(&total, 0, sizeof(total));
+    memset(&fdata, 0, sizeof(fdata));
+    memset(&pdata, 0, sizeof(pdata));
+    buf = malloc(DEF_MOD_BUF_SIZE);
+    if (!buf)
+        return(-1);
+    for (i = 0; i < sizeof(mod_list)/sizeof(int); i++)
+        idx = mod_list[i];
+        if (fd->mod_map[idx].len == 0)
+            continue;
+        memset(buf, 0, DEF_MOD_BUF_SIZE);
+        while(1)
+            int r;
+            hash_entry_t *hfile = NULL;
+            r = mod_logutils[i]->log_get_record(fd, (void**)&buf);
+            if (r < 1)
+                break;
+            base_rec = (struct darshan_base_record *) buf;
+            HASH_FIND(hlink, file_hash, &(base_rec->id), sizeof(darshan_record_id), hfile);
+            if (!hfile)
+                hfile = malloc(sizeof(*hfile));
+                if (!hfile)
+                    ret = -1;
+                    //goto cleanup;
+                memset(hfile, 0, sizeof(*hfile));
+                hfile->rec_id = base_rec->id;
+                hfile->type = 0;
+                hfile->procs = 0;
+                hfile->rec_dat = NULL;
+                hfile->cumul_time = 0.0;
+                hfile->slowest_time = 0.0;
+                HASH_ADD(hlink, file_hash, rec_id, sizeof(darshan_record_id), hfile);
+    return;
  * Local variables:
  *  c-indent-level: 4
  *  c-basic-offset: 4
--- a/darshan-util/darshan-logutils.h
+++ b/darshan-util/darshan-logutils.h
@@ -22,6 +22,12 @@
 #define DEF_MOD_BUF_SIZE 81920
+#define FILETYPE_SHARED (1 << 0)
+#define FILETYPE_UNIQUE (1 << 1)
+#define FILETYPE_PARTSHARED (1 << 2)
+#define max(a,b) (((a) > (b)) ? (a) : (b))
 struct darshan_fd_int_state;
 /* darshan file descriptor definition */
@@ -62,6 +68,58 @@ struct lustre_record_ref
 	UT_hash_handle hlink;
+typedef struct hash_entry_s
+    UT_hash_handle hlink;
+    darshan_record_id rec_id;
+    int64_t type;
+    int64_t procs;
+    void *rec_dat;
+    double cumul_time;
+    double slowest_time;
+} hash_entry_t;
+typedef struct file_data_s
+    int64_t total;
+    int64_t total_size;
+    int64_t total_max;
+    int64_t read_only;
+    int64_t read_only_size;
+    int64_t read_only_max;
+    int64_t write_only;
+    int64_t write_only_size;
+    int64_t write_only_max;
+    int64_t read_write;
+    int64_t read_write_size;
+    int64_t read_write_max;
+    int64_t unique;
+    int64_t unique_size;
+    int64_t unique_max;
+    int64_t shared;
+    int64_t shared_size;
+    int64_t shared_max;
+} file_data_t;
+typedef struct perf_data_s
+    int64_t total_bytes;
+    double slowest_rank_time;
+    double slowest_rank_meta_time;
+    int slowest_rank_rank;
+    double shared_time_by_cumul;
+    double shared_time_by_open;
+    double shared_time_by_open_lastio;
+    double shared_time_by_slowest;
+    double shared_meta_time;
+    double agg_perf_by_cumul;
+    double agg_perf_by_open;
+    double agg_perf_by_open_lastio;
+    double agg_perf_by_slowest;
+    double *rank_cumul_io_time;
+    double *rank_cumul_md_time;
+} perf_data_t;
 struct darshan_mnt_info
     char mnt_type[DARSHAN_EXE_LEN];
@@ -131,6 +189,38 @@ struct darshan_mod_logutil_funcs
         void *agg_rec,
         int init_flag
+    /* accumulate file statistics across processes */
+    void (*log_accum_file)(
+        void *rec,
+        hash_entry_t *hfile,
+        int64_t nprocs
+    /* accumulate data for performance estimate */
+    void (*log_accum_perf)(
+        void *rec,
+        perf_data_t *pdata
+    /* accumulate statistics about files and file counts */
+    void (*log_calc_file)(
+        file_data_t *fdata
+    /* print out the aggregate file stats */
+    void (*log_print_total_file)(
+        void *rec,
+        int ver
+    /* print out statistics on a per file basis */
+    void (*log_file_list)(
+        struct darshan_name_record_ref *name_hash,
+        int detail_flag
+    /* calculate performance estimate */
+    void (*log_calc_perf)(
+        perf_data_t *pdata,
+        int64_t nprocs
 extern struct darshan_mod_logutil_funcs *mod_logutils[];
@@ -171,6 +261,7 @@ void darshan_log_close(darshan_fd file);
 void darshan_log_print_version_warnings(const char *version_string);
 void darshan_log_get_modules (darshan_fd fd, struct darshan_mod_info **mods, int* count);
 int darshan_log_get_record (darshan_fd fd, int mod_idx, void **buf);
+void darshan_calc_perf(perf_data_t *pdata, int64_t nprocs);
 /* convenience macros for printing Darshan counters */
 #define DARSHAN_PRINT_HEADER() \
--- a/darshan-util/darshan-lustre-logutils.c
+++ b/darshan-util/darshan-lustre-logutils.c
@@ -40,7 +40,13 @@ struct darshan_mod_logutil_funcs lustre_logutils =
     .log_print_record = &darshan_log_print_lustre_record,
     .log_print_description = &darshan_log_print_lustre_description,
     .log_print_diff = &darshan_log_print_lustre_record_diff,
-    .log_agg_records = &darshan_log_agg_lustre_records
+    .log_agg_records = &darshan_log_agg_lustre_records,
 static int darshan_log_get_lustre_record(darshan_fd fd, void** lustre_buf_p)
--- a/darshan-util/darshan-mpiio-logutils.c
+++ b/darshan-util/darshan-mpiio-logutils.c
@@ -38,6 +38,11 @@ static void darshan_log_print_mpiio_description(int ver);
 static void darshan_log_print_mpiio_file_diff(void *file_rec1, char *file_name1,
     void *file_rec2, char *file_name2);
 static void darshan_log_agg_mpiio_files(void *rec, void *agg_rec, int init_flag);
+static void darshan_log_mpiio_accum_file(void *mfile, hash_entry_t *hfile, int64_t nprocs);
+static void darshan_log_mpiio_accum_perf(void *mfile, perf_data_t *pdata);
+static void darshan_log_mpiio_calc_file(hash_entry_t *file_hash, file_data_t *fdata);
+static void darshan_log_mpiio_print_total_file(void *mfile, int mpiio_ver);
+static void darshan_log_mpiio_file_list(hash_entry_t *file_hash, struct darshan_name_record_ref *name_hash, int detail_flag);
 struct darshan_mod_logutil_funcs mpiio_logutils =
@@ -46,7 +51,13 @@ struct darshan_mod_logutil_funcs mpiio_logutils =
     .log_print_record = &darshan_log_print_mpiio_file,
     .log_print_description = &darshan_log_print_mpiio_description,
     .log_print_diff = &darshan_log_print_mpiio_file_diff,
-    .log_agg_records = &darshan_log_agg_mpiio_files
+    .log_agg_records = &darshan_log_agg_mpiio_files,
+    .log_accum_file = &darshan_log_mpiio_accum_file,
+    .log_accum_perf = &darshan_log_mpiio_accum_perf,
+    .log_calc_file = &darshan_log_mpiio_calc_file,
+    .log_print_total_file = &darshan_log_mpiio_print_total_file,
+    .log_file_list = &darshan_log_mpiio_file_list,
+    .log_calc_perf = &darshan_calc_perf
 static int darshan_log_get_mpiio_file(darshan_fd fd, void** mpiio_buf_p)
@@ -541,6 +552,447 @@ static void darshan_log_agg_mpiio_files(void *rec, void *agg_rec, int init_flag)
     return;
+    void *infile,
+    int64_t nprocs)
+    struct darshan_mpiio_file *mfile = infile;
+    int i, j;
+    int set;
+    int min_ndx;
+    int64_t min;
+    struct darshan_mpiio_file* tmp;
+    hfile->procs += 1;
+    if(mfile->base_rec.rank == -1)
+        hfile->slowest_time = mfile->fcounters[MPIIO_F_SLOWEST_RANK_TIME];
+    else
+        hfile->slowest_time = max(hfile->slowest_time,
+            (mfile->fcounters[MPIIO_F_META_TIME] +
+            mfile->fcounters[MPIIO_F_READ_TIME] +
+            mfile->fcounters[MPIIO_F_WRITE_TIME]));
+        hfile->procs = nprocs;
+        hfile->type |= FILETYPE_SHARED;
+    else if(hfile->procs > 1)
+        hfile->type &= (~FILETYPE_UNIQUE);
+        hfile->type |= FILETYPE_PARTSHARED;
+    else
+        hfile->type |= FILETYPE_UNIQUE;
+    hfile->cumul_time += mfile->fcounters[MPIIO_F_META_TIME] +
+                         mfile->fcounters[MPIIO_F_WRITE_TIME];
+    if(hfile->rec_dat == NULL)
+        hfile->rec_dat = malloc(sizeof(struct darshan_mpiio_file));
+        assert(hfile->rec_dat);
+        memset(hfile->rec_dat, 0, sizeof(struct darshan_mpiio_file));
+    tmp = (struct darshan_mpiio_file*)hfile->rec_dat;
+    for(i = 0; i < MPIIO_NUM_INDICES; i++)
+        switch(i)
+        case MPIIO_MODE:
+            tmp->counters[i] = mfile->counters[i];
+            break;
+        case MPIIO_ACCESS1_ACCESS:
+        case MPIIO_ACCESS2_ACCESS:
+        case MPIIO_ACCESS3_ACCESS:
+        case MPIIO_ACCESS4_ACCESS:
+             * do nothing here because these will be stored
+             * when the _COUNT is accessed.
+            break;
+        case MPIIO_ACCESS1_COUNT:
+        case MPIIO_ACCESS2_COUNT:
+        case MPIIO_ACCESS3_COUNT:
+        case MPIIO_ACCESS4_COUNT:
+            set = 0;
+            min_ndx = MPIIO_ACCESS1_COUNT;
+            min = tmp->counters[min_ndx];
+            for(j = MPIIO_ACCESS1_COUNT; j <= MPIIO_ACCESS4_COUNT; j++)
+                if(tmp->counters[j-4] == mfile->counters[i-4])
+                    tmp->counters[j] += mfile->counters[i];
+                    set = 1;
+                    break;
+                if(tmp->counters[j] < min)
+                    min_ndx = j;
+                    min = tmp->counters[j];
+            if(!set && (mfile->counters[i] > min))
+                tmp->counters[i-4] = mfile->counters[i-4];
+            break;
+        case MPIIO_FASTEST_RANK:
+        case MPIIO_SLOWEST_RANK:
+        case MPIIO_FASTEST_RANK_BYTES:
+        case MPIIO_SLOWEST_RANK_BYTES:
+            tmp->counters[i] = 0;
+            break;
+        case MPIIO_MAX_READ_TIME_SIZE:
+        case MPIIO_MAX_WRITE_TIME_SIZE:
+            break;
+        default:
+            tmp->counters[i] += mfile->counters[i];
+            break;
+    for(i = 0; i < MPIIO_F_NUM_INDICES; i++)
+        switch(i)
+            case MPIIO_F_OPEN_TIMESTAMP:
+            case MPIIO_F_READ_START_TIMESTAMP:
+            case MPIIO_F_WRITE_START_TIMESTAMP:
+                if(tmp->fcounters[i] == 0 ||
+                    tmp->fcounters[i] > mfile->fcounters[i])
+                    tmp->fcounters[i] = mfile->fcounters[i];
+                break;
+            case MPIIO_F_READ_END_TIMESTAMP:
+            case MPIIO_F_WRITE_END_TIMESTAMP:
+            case MPIIO_F_CLOSE_TIMESTAMP:
+                    tmp->fcounters[i] < mfile->fcounters[i])
+                break;
+            case MPIIO_F_FASTEST_RANK_TIME:
+            case MPIIO_F_SLOWEST_RANK_TIME:
+            case MPIIO_F_VARIANCE_RANK_TIME:
+            case MPIIO_F_VARIANCE_RANK_BYTES:
+                tmp->fcounters[i] = 0;
+                break;
+            case MPIIO_F_MAX_READ_TIME:
+                if(tmp->fcounters[i] < mfile->fcounters[i])
+                    tmp->counters[MPIIO_MAX_READ_TIME_SIZE] =
+                        mfile->counters[MPIIO_MAX_READ_TIME_SIZE];
+                break;
+            case MPIIO_F_MAX_WRITE_TIME:
+                    tmp->counters[MPIIO_MAX_WRITE_TIME_SIZE] =
+                        mfile->counters[MPIIO_MAX_WRITE_TIME_SIZE];
+                break;
+            default:
+                tmp->fcounters[i] += mfile->fcounters[i];
+                break;
+    return;
+    void *infile,
+    perf_data_t *pdata)
+    pdata->total_bytes += mfile->counters[MPIIO_BYTES_READ] +
+                          mfile->counters[MPIIO_BYTES_WRITTEN];
+     * Calculation of Shared File Time
+     *   Four Methods!!!!
+     *     by_cumul: sum time counters and divide by nprocs
+     *               (inaccurate if lots of variance between procs)
+     *     by_open: difference between timestamp of open and close
+     *              (inaccurate if file is left open without i/o happening)
+     *     by_open_lastio: difference between timestamp of open and the
+     *                     timestamp of last i/o
+     *                     (similar to above but fixes case where file is left
+     *                      open after io is complete)
+     *     by_slowest: use slowest rank time from log data
+     *                 (most accurate but requires newer log version)
+        /* by_open */
+        if(mfile->fcounters[MPIIO_F_CLOSE_TIMESTAMP] >
+            mfile->fcounters[MPIIO_F_OPEN_TIMESTAMP])
+            pdata->shared_time_by_open +=
+                mfile->fcounters[MPIIO_F_CLOSE_TIMESTAMP] -
+                mfile->fcounters[MPIIO_F_OPEN_TIMESTAMP];
+        /* by_open_lastio */
+        if(mfile->fcounters[MPIIO_F_READ_END_TIMESTAMP] >
+            mfile->fcounters[MPIIO_F_WRITE_END_TIMESTAMP])
+            /* be careful: file may have been opened but not read or written */
+            if(mfile->fcounters[MPIIO_F_READ_END_TIMESTAMP] > mfile->fcounters[MPIIO_F_OPEN_TIMESTAMP])
+                pdata->shared_time_by_open_lastio +=
+                    mfile->fcounters[MPIIO_F_READ_END_TIMESTAMP] -
+        else
+            if(mfile->fcounters[MPIIO_F_WRITE_END_TIMESTAMP] > mfile->fcounters[MPIIO_F_OPEN_TIMESTAMP])
+                    mfile->fcounters[MPIIO_F_WRITE_END_TIMESTAMP] -
+        pdata->shared_time_by_cumul +=
+            mfile->fcounters[MPIIO_F_META_TIME] +
+        pdata->shared_meta_time += mfile->fcounters[MPIIO_F_META_TIME];
+        /* by_slowest */
+        pdata->shared_time_by_slowest +=
+            mfile->fcounters[MPIIO_F_SLOWEST_RANK_TIME];
+     * Calculation of Unique File Time
+     *   record the data for each file and sum it
+    else
+        pdata->rank_cumul_io_time[mfile->base_rec.rank] +=
+            mfile->fcounters[MPIIO_F_WRITE_TIME]);
+        pdata->rank_cumul_md_time[mfile->base_rec.rank] +=
+            mfile->fcounters[MPIIO_F_META_TIME];
+    return;
+    hash_entry_t *file_hash,
+    file_data_t *fdata)
+    hash_entry_t *curr = NULL;
+    hash_entry_t *tmp = NULL;
+    struct darshan_mpiio_file *file_rec;
+    memset(fdata, 0, sizeof(*fdata));
+    HASH_ITER(hlink, file_hash, curr, tmp)
+        int64_t bytes;
+        int64_t r;
+        int64_t w;
+        file_rec = (struct darshan_mpiio_file*)curr->rec_dat;
+        assert(file_rec);
+        bytes = file_rec->counters[MPIIO_BYTES_READ] +
+                file_rec->counters[MPIIO_BYTES_WRITTEN];
+        r = (file_rec->counters[MPIIO_INDEP_READS]+
+             file_rec->counters[MPIIO_COLL_READS] +
+             file_rec->counters[MPIIO_SPLIT_READS] +
+             file_rec->counters[MPIIO_NB_READS]);
+        w = (file_rec->counters[MPIIO_INDEP_WRITES]+
+             file_rec->counters[MPIIO_COLL_WRITES] +
+             file_rec->counters[MPIIO_SPLIT_WRITES] +
+             file_rec->counters[MPIIO_NB_WRITES]);
+        fdata->total += 1;
+        fdata->total_size += bytes;
+        fdata->total_max = max(fdata->total_max, bytes);
+        if (r && !w)
+            fdata->read_only += 1;
+            fdata->read_only_size += bytes;
+            fdata->read_only_max = max(fdata->read_only_max, bytes);
+        if (!r && w)
+            fdata->write_only += 1;
+            fdata->write_only_size += bytes;
+            fdata->write_only_max = max(fdata->write_only_max, bytes);
+        if (r && w)
+            fdata->read_write += 1;
+            fdata->read_write_size += bytes;
+            fdata->read_write_max = max(fdata->read_write_max, bytes);
+        if ((curr->type & (FILETYPE_SHARED|FILETYPE_PARTSHARED)))
+            fdata->shared += 1;
+            fdata->shared_size += bytes;
+            fdata->shared_max = max(fdata->shared_max, bytes);
+        if ((curr->type & (FILETYPE_UNIQUE)))
+            fdata->unique += 1;
+            fdata->unique_size += bytes;
+            fdata->unique_max = max(fdata->unique_max, bytes);
+    return;
+    void *infile,
+    int mpiio_ver)
+    int i;
+    mod_logutils[DARSHAN_MPIIO_MOD]->log_print_description(mpiio_ver);
+    printf("\n");
+        printf("total_%s: %"PRId64"\n",
+            mpiio_counter_names[i], mfile->counters[i]);
+        printf("total_%s: %lf\n",
+            mpiio_f_counter_names[i], mfile->fcounters[i]);
+    return;
+    int detail_flag)
+    struct darshan_mpiio_file *file_rec = NULL;
+    struct darshan_name_record_ref *ref = NULL;
+    int i;
+    /* list of columns:
+     * normal mode
+     * - file id
+     * - file name
+     * - nprocs
+     * - slowest I/O time
+     * - average cumulative I/O time
+     * detailed mode
+     * - first open
+     * - first read
+     * - first write
+     * - last read
+     * - last write
+     * - last close
+     * - MPI indep opens
+     * - MPI coll opens
+     * - r histogram
+     * - w histogram
+    if(detail_flag)
+        printf("\n# Per-file summary of I/O activity (detailed).\n");
+    else
+        printf("\n# Per-file summary of I/O activity.\n");
+    printf("# -----\n");
+    printf("# <record_id>: darshan record id for this file\n");
+    printf("# <file_name>: full file name\n");
+    printf("# <nprocs>: number of processes that opened the file\n");
+    printf("# <slowest>: (estimated) time in seconds consumed in IO by slowest process\n");
+    printf("# <avg>: average time in seconds consumed in IO per process\n");
+    if(detail_flag)
+        printf("# <start_{open/read/write}>: start timestamp of first open, read, or write\n");
+        printf("# <end_{read/write/close}>: end timestamp of last read, write, or close\n");
+        printf("# <mpi_indep_opens>: independent MPI_File_open calls\n");
+        printf("# <mpi_coll_opens>: collective MPI_File_open calls\n");
+        printf("# <MPIIO_SIZE_READ_AGG_*>: MPI-IO aggregate read size histogram\n");
+        printf("# <MPIIO_SIZE_WRITE_AGG_*>: MPI-IO aggregate write size histogram\n");
+    printf("\n# <record_id>\t<file_name>\t<nprocs>\t<slowest>\t<avg>");
+    if(detail_flag)
+        printf("\t<start_open>\t<start_read>\t<start_write>");
+        printf("\t<end_read>\t<end_write>\t<end_close>");
+        printf("\t<mpi_indep_opens>\t<mpi_coll_opens>");
+        for(i=MPIIO_SIZE_READ_AGG_0_100; i<= MPIIO_SIZE_WRITE_AGG_1G_PLUS; i++)
+            printf("\t<%s>", mpiio_counter_names[i]);
+    printf("\n");
+        assert(file_rec);
+        HASH_FIND(hlink, name_hash, &(curr->rec_id), sizeof(darshan_record_id), ref);
+        assert(ref);
+        printf("%" PRIu64 "\t%s\t%" PRId64 "\t%f\t%f",
+            curr->rec_id,
+            ref->name_record->name,
+            curr->procs,
+            curr->slowest_time,
+            curr->cumul_time/(double)curr->procs);
+        if(detail_flag)
+            for(i=MPIIO_F_OPEN_TIMESTAMP; i<=MPIIO_F_CLOSE_TIMESTAMP; i++)
+                printf("\t%f", file_rec->fcounters[i]);
+            printf("\t%" PRId64 "\t%" PRId64, file_rec->counters[MPIIO_INDEP_OPENS],
+                file_rec->counters[MPIIO_COLL_OPENS]);
+                printf("\t%" PRId64, file_rec->counters[i]);
+        printf("\n");
+    return;
  * Local variables:
  *  c-indent-level: 4
--- a/darshan-util/darshan-null-logutils.c
+++ b/darshan-util/darshan-null-logutils.c
@@ -52,7 +52,13 @@ struct darshan_mod_logutil_funcs null_logutils =
     .log_print_record = &darshan_log_print_null_record,
     .log_print_description = &darshan_log_print_null_description,
     .log_print_diff = &darshan_log_print_null_record_diff,
-    .log_agg_records = &darshan_log_agg_null_records
+    .log_agg_records = &darshan_log_agg_null_records,
 /* retrieve a NULL record from log file descriptor 'fd', storing the
--- a/darshan-util/darshan-parser.c
+++ b/darshan-util/darshan-parser.c
@@ -37,88 +37,9 @@
   OPTION_FILE_LIST|\
   OPTION_FILE_LIST_DETAILED)
-#define FILETYPE_SHARED (1 << 0)
-#define FILETYPE_UNIQUE (1 << 1)
-#define FILETYPE_PARTSHARED (1 << 2)
-#define max(a,b) (((a) > (b)) ? (a) : (b))
- * Datatypes
-typedef struct hash_entry_s
-    UT_hash_handle hlink;
-    darshan_record_id rec_id;
-    int64_t type;
-    int64_t procs;
-    void *rec_dat;
-    double cumul_time;
-    double slowest_time;
-} hash_entry_t;
-typedef struct file_data_s
-    int64_t total;
-    int64_t total_size;
-    int64_t total_max;
-    int64_t read_only;
-    int64_t read_only_size;
-    int64_t read_only_max;
-    int64_t write_only;
-    int64_t write_only_size;
-    int64_t write_only_max;
-    int64_t read_write;
-    int64_t read_write_size;
-    int64_t read_write_max;
-    int64_t unique;
-    int64_t unique_size;
-    int64_t unique_max;
-    int64_t shared;
-    int64_t shared_size;
-    int64_t shared_max;
-} file_data_t;
-typedef struct perf_data_s
-    int64_t total_bytes;
-    double slowest_rank_time;
-    double slowest_rank_meta_time;
-    int slowest_rank_rank;
-    double shared_time_by_cumul;
-    double shared_time_by_open;
-    double shared_time_by_open_lastio;
-    double shared_time_by_slowest;
-    double shared_meta_time;
-    double agg_perf_by_cumul;
-    double agg_perf_by_open;
-    double agg_perf_by_open_lastio;
-    double agg_perf_by_slowest;
-    double *rank_cumul_io_time;
-    double *rank_cumul_md_time;
-} perf_data_t;
  * Prototypes
-void posix_accum_file(struct darshan_posix_file *pfile, hash_entry_t *hfile, int64_t nprocs);
-void posix_accum_perf(struct darshan_posix_file *pfile, perf_data_t *pdata);
-void posix_calc_file(hash_entry_t *file_hash, file_data_t *fdata);
-void posix_print_total_file(struct darshan_posix_file *pfile, int posix_ver);
-void posix_file_list(hash_entry_t *file_hash, struct darshan_name_record_ref *name_hash, int detail_flag);
-void mpiio_accum_file(struct darshan_mpiio_file *mfile, hash_entry_t *hfile, int64_t nprocs);
-void mpiio_accum_perf(struct darshan_mpiio_file *mfile, perf_data_t *pdata);
-void mpiio_calc_file(hash_entry_t *file_hash, file_data_t *fdata);
-void mpiio_print_total_file(struct darshan_mpiio_file *mfile, int mpiio_ver);
-void mpiio_file_list(hash_entry_t *file_hash, struct darshan_name_record_ref *name_hash, int detail_flag);
-void stdio_accum_perf(struct darshan_stdio_file *pfile, perf_data_t *pdata);
-void stdio_accum_file(struct darshan_stdio_file *pfile, hash_entry_t *hfile, int64_t nprocs);
-void stdio_calc_file(hash_entry_t *file_hash, file_data_t *fdata);
-void stdio_file_list(hash_entry_t *file_hash, struct darshan_name_record_ref *name_hash, int detail_flag);
-void stdio_print_total_file(struct darshan_stdio_file *pfile, int stdio_ver);
 void calc_perf(perf_data_t *pdata, int64_t nprocs);
 int usage (char *exename)
@@ -333,6 +254,25 @@ int main(int argc, char **argv)
+#if 0
+    printf("\n# defs ---\n");
+    printf("DARSHAN_EXE_LEN = %d\n", DARSHAN_EXE_LEN);
+    printf("DARSHAN_APXC_MAGIC = 0x%" PRIu64 "\n", DARSHAN_APXC_MAGIC);
+    printf("APXC_NUM_INDICES = %d\n", APXC_NUM_INDICES);
+    printf("POSIX_F_NUM_INDICES = %d\n", POSIX_F_NUM_INDICES);
+    printf("POSIX_NUM_INDICES = %d\n", POSIX_NUM_INDICES);
+    printf("STDIO_F_NUM_INDICES = %d\n", STDIO_F_NUM_INDICES);
+    printf("STDIO_NUM_INDICES = %d\n", STDIO_NUM_INDICES);
+    printf("MPIIO_F_NUM_INDICES = %d\n", MPIIO_F_NUM_INDICES);
+    printf("MPIIO_NUM_INDICES = %d\n", MPIIO_NUM_INDICES);
+    printf("PNETCDF_F_NUM_INDICES = %d\n", PNETCDF_F_NUM_INDICES);
+    printf("PNETCDF_NUM_INDICES = %d\n", PNETCDF_NUM_INDICES);
+    printf("HDF5_F_NUM_INDICES = %d\n", HDF5_F_NUM_INDICES);
+    printf("HDF5_NUM_INDICES = %d\n", HDF5_NUM_INDICES);
+    printf("BGQ_F_NUM_INDICES = %d\n", BGQ_F_NUM_INDICES);
+    printf("BGQ_NUM_INDICES = %d\n", BGQ_NUM_INDICES);
+#endif
     /* print table of mounted file systems */
     printf("\n# mounted file systems (mount point and fs type)\n");
     printf("# -------------------------------------------------------\n");
@@ -486,12 +426,10 @@ int main(int argc, char **argv)
                     mnt_pt, fs_type);
-            /* we calculate more detailed stats for POSIX, MPI-IO, and STDIO modules,
-             * if the parser is executed with more than the base option
+             * Compute derived statsitics for those modules that support it
+             * and if the user requested it.
-            if(i != DARSHAN_POSIX_MOD && i != DARSHAN_MPIIO_MOD && i != DARSHAN_STDIO_MOD)
-                continue;
             if(!hfile)
@@ -514,23 +452,15 @@ int main(int argc, char **argv)
                 HASH_ADD(hlink, file_hash,rec_id, sizeof(darshan_record_id), hfile);
-            if(i == DARSHAN_POSIX_MOD)
+            if (mod_logutils[i]->log_accum_file)
-                posix_accum_file((struct darshan_posix_file*)mod_buf, &total, job.nprocs);
-                posix_accum_file((struct darshan_posix_file*)mod_buf, hfile, job.nprocs);
-                posix_accum_perf((struct darshan_posix_file*)mod_buf, &pdata);
+                mod_logutils[i]->log_accum_file(mod_buf, &total, job.nprocs);
+                mod_logutils[i]->log_accum_file(mod_buf, hfile, job.nprocs);
-            else if(i == DARSHAN_MPIIO_MOD)
-                mpiio_accum_file((struct darshan_mpiio_file*)mod_buf, &total, job.nprocs);
-                mpiio_accum_file((struct darshan_mpiio_file*)mod_buf, hfile, job.nprocs);
-                mpiio_accum_perf((struct darshan_mpiio_file*)mod_buf, &pdata);
-            else if(i == DARSHAN_STDIO_MOD)
+            if (mod_logutils[i]->log_accum_perf)
-                stdio_accum_file((struct darshan_stdio_file*)mod_buf, &total, job.nprocs);
-                stdio_accum_file((struct darshan_stdio_file*)mod_buf, hfile, job.nprocs);
-                stdio_accum_perf((struct darshan_stdio_file*)mod_buf, &pdata);
+                mod_logutils[i]->log_accum_perf(mod_buf, &pdata);
             memset(mod_buf, 0, DEF_MOD_BUF_SIZE);
@@ -538,44 +468,21 @@ int main(int argc, char **argv)
         if(ret == -1)
             continue; /* move on to the next module if there was an error with this one */
-        /* we calculate more detailed stats for POSIX and MPI-IO modules,
+        /* Calculate more detailed stats if the module supports it and
+         * the user requested it.
-            continue;
         /* Total Calc */
-        if(mask & OPTION_TOTAL)
+        if ((mask & OPTION_TOTAL) &&
+            (mod_logutils[i]->log_print_total_file))
-                posix_print_total_file((struct darshan_posix_file*)total.rec_dat, fd->mod_ver[i]);
-                mpiio_print_total_file((struct darshan_mpiio_file*)total.rec_dat, fd->mod_ver[i]);
-                stdio_print_total_file((struct darshan_stdio_file*)total.rec_dat, fd->mod_ver[i]);
+                mod_logutils[i]->log_print_total_file(total.rec_dat, fd->mod_ver[i]);
         /* File Calc */
-        if(mask & OPTION_FILE)
+        if ((mask & OPTION_FILE) &&
+            (mod_logutils[i]->log_calc_file))
-                posix_calc_file(file_hash, &fdata);
-                mpiio_calc_file(file_hash, &fdata);
-                stdio_calc_file(file_hash, &fdata);
+            mod_logutils[i]->log_calc_file(file_hash, &fdata);
             printf("\n# Total file counts\n");
@@ -616,9 +523,10 @@ int main(int argc, char **argv)
         /* Perf Calc */
-        if(mask & OPTION_PERF)
+        if ((mask & OPTION_PERF) &&
+            (mod_logutils[i]->log_calc_perf))
-            calc_perf(&pdata, job.nprocs);
+            mod_logutils[i]->log_calc_perf(&pdata, job.nprocs);
             printf("\n# performance\n");
             printf("# -----------\n");
@@ -648,29 +556,12 @@ int main(int argc, char **argv)
             printf("# agg_perf_by_slowest: %lf\n", pdata.agg_perf_by_slowest);
-        if((mask & OPTION_FILE_LIST) || (mask & OPTION_FILE_LIST_DETAILED))
+        if (((mask & OPTION_FILE_LIST) ||
+             (mask & OPTION_FILE_LIST_DETAILED)) &&
+            (mod_logutils[i]->log_file_list))
-                if(mask & OPTION_FILE_LIST_DETAILED)
-                    posix_file_list(file_hash, name_hash, 1);
-                else
-                    posix_file_list(file_hash, name_hash, 0);
-                    mpiio_file_list(file_hash, name_hash, 1);
-                else
-                    mpiio_file_list(file_hash, name_hash, 0);
-                    stdio_file_list(file_hash, name_hash, 1);
-                else
-                    stdio_file_list(file_hash, name_hash, 0);
+            int mode = (mask & OPTION_FILE_LIST_DETAILED) ? 1 : 0;
+            mod_logutils[i]->log_file_list(file_hash, name_hash, mode);
         /* reset data structures for next module */
@@ -719,1313 +610,6 @@ cleanup:
     return(ret);
-                      hash_entry_t *hfile,
-                      int64_t nprocs)
-    int i;
-    struct darshan_stdio_file* tmp;
-    hfile->procs += 1;
-    if(pfile->base_rec.rank == -1)
-        hfile->slowest_time = pfile->fcounters[STDIO_F_SLOWEST_RANK_TIME];
-    else
-        hfile->slowest_time = max(hfile->slowest_time,
-            (pfile->fcounters[STDIO_F_META_TIME] +
-            pfile->fcounters[STDIO_F_READ_TIME] +
-            pfile->fcounters[STDIO_F_WRITE_TIME]));
-        hfile->procs = nprocs;
-        hfile->type |= FILETYPE_SHARED;
-    else if(hfile->procs > 1)
-        hfile->type &= (~FILETYPE_UNIQUE);
-        hfile->type |= FILETYPE_PARTSHARED;
-    else
-        hfile->type |= FILETYPE_UNIQUE;
-    hfile->cumul_time += pfile->fcounters[STDIO_F_META_TIME] +
-                         pfile->fcounters[STDIO_F_WRITE_TIME];
-    if(hfile->rec_dat == NULL)
-        hfile->rec_dat = malloc(sizeof(struct darshan_stdio_file));
-        assert(hfile->rec_dat);
-        memset(hfile->rec_dat, 0, sizeof(struct darshan_stdio_file));
-    tmp = (struct darshan_stdio_file*)hfile->rec_dat;
-    for(i = 0; i < STDIO_NUM_INDICES; i++)
-        switch(i)
-        case STDIO_MAX_BYTE_READ:
-        case STDIO_MAX_BYTE_WRITTEN:
-            if (tmp->counters[i] < pfile->counters[i])
-                tmp->counters[i] = pfile->counters[i];
-            break;
-        case POSIX_FASTEST_RANK:
-        case POSIX_SLOWEST_RANK:
-        case POSIX_FASTEST_RANK_BYTES:
-        case POSIX_SLOWEST_RANK_BYTES:
-            tmp->counters[i] = 0;
-            break;
-        default:
-            tmp->counters[i] += pfile->counters[i];
-            break;
-    for(i = 0; i < STDIO_F_NUM_INDICES; i++)
-        switch(i)
-            case STDIO_F_OPEN_START_TIMESTAMP:
-            case STDIO_F_CLOSE_START_TIMESTAMP:
-            case STDIO_F_READ_START_TIMESTAMP:
-            case STDIO_F_WRITE_START_TIMESTAMP:
-                if(tmp->fcounters[i] == 0 ||
-                    tmp->fcounters[i] > pfile->fcounters[i])
-                    tmp->fcounters[i] = pfile->fcounters[i];
-                break;
-            case STDIO_F_READ_END_TIMESTAMP:
-            case STDIO_F_WRITE_END_TIMESTAMP:
-            case STDIO_F_OPEN_END_TIMESTAMP:
-            case STDIO_F_CLOSE_END_TIMESTAMP:
-                    tmp->fcounters[i] < pfile->fcounters[i])
-                break;
-            case STDIO_F_FASTEST_RANK_TIME:
-            case STDIO_F_SLOWEST_RANK_TIME:
-            case STDIO_F_VARIANCE_RANK_TIME:
-            case STDIO_F_VARIANCE_RANK_BYTES:
-                tmp->fcounters[i] = 0;
-                break;
-            default:
-                tmp->fcounters[i] += pfile->fcounters[i];
-                break;
-    return;
-                      int64_t nprocs)
-    int i, j;
-    int set;
-    int min_ndx;
-    int64_t min;
-    struct darshan_posix_file* tmp;
-        hfile->slowest_time = pfile->fcounters[POSIX_F_SLOWEST_RANK_TIME];
-    else
-            (pfile->fcounters[POSIX_F_META_TIME] +
-            pfile->fcounters[POSIX_F_READ_TIME] +
-            pfile->fcounters[POSIX_F_WRITE_TIME]));
-    else
-    hfile->cumul_time += pfile->fcounters[POSIX_F_META_TIME] +
-                         pfile->fcounters[POSIX_F_WRITE_TIME];
-        hfile->rec_dat = malloc(sizeof(struct darshan_posix_file));
-        memset(hfile->rec_dat, 0, sizeof(struct darshan_posix_file));
-    tmp = (struct darshan_posix_file*)hfile->rec_dat;
-    for(i = 0; i < POSIX_NUM_INDICES; i++)
-        switch(i)
-        case POSIX_MODE:
-        case POSIX_MEM_ALIGNMENT:
-        case POSIX_FILE_ALIGNMENT:
-            break;
-        case POSIX_MAX_BYTE_READ:
-        case POSIX_MAX_BYTE_WRITTEN:
-            break;
-        case POSIX_STRIDE1_STRIDE:
-        case POSIX_STRIDE2_STRIDE:
-        case POSIX_STRIDE3_STRIDE:
-        case POSIX_STRIDE4_STRIDE:
-        case POSIX_ACCESS1_ACCESS:
-        case POSIX_ACCESS2_ACCESS:
-        case POSIX_ACCESS3_ACCESS:
-        case POSIX_ACCESS4_ACCESS:
-            * do nothing here because these will be stored
-            * when the _COUNT is accessed.
-           break;
-        case POSIX_STRIDE1_COUNT:
-        case POSIX_STRIDE2_COUNT:
-        case POSIX_STRIDE3_COUNT:
-        case POSIX_STRIDE4_COUNT:
-            set = 0;
-            min_ndx = POSIX_STRIDE1_COUNT;
-            min = tmp->counters[min_ndx];
-            for(j = POSIX_STRIDE1_COUNT; j <= POSIX_STRIDE4_COUNT; j++)
-                if(tmp->counters[j-4] == pfile->counters[i-4])
-                    tmp->counters[j] += pfile->counters[i];
-                    set = 1;
-                    break;
-                if(tmp->counters[j] < min)
-                    min_ndx = j;
-                    min = tmp->counters[j];
-            if(!set && (pfile->counters[i] > min))
-                tmp->counters[min_ndx] = pfile->counters[i];
-                tmp->counters[min_ndx-4] = pfile->counters[i-4];
-            break;
-        case POSIX_ACCESS1_COUNT:
-        case POSIX_ACCESS2_COUNT:
-        case POSIX_ACCESS3_COUNT:
-        case POSIX_ACCESS4_COUNT:
-            set = 0;
-            min_ndx = POSIX_ACCESS1_COUNT;
-            for(j = POSIX_ACCESS1_COUNT; j <= POSIX_ACCESS4_COUNT; j++)
-                    set = 1;
-                    break;
-                    min_ndx = j;
-                tmp->counters[i-4] = pfile->counters[i-4];
-            break;
-            break;
-        case POSIX_MAX_READ_TIME_SIZE:
-        case POSIX_MAX_WRITE_TIME_SIZE:
-            break;
-        default:
-            break;
-    for(i = 0; i < POSIX_F_NUM_INDICES; i++)
-        switch(i)
-            case POSIX_F_OPEN_START_TIMESTAMP:
-            case POSIX_F_READ_START_TIMESTAMP:
-            case POSIX_F_WRITE_START_TIMESTAMP:
-            case POSIX_F_CLOSE_START_TIMESTAMP:
-                break;
-            case POSIX_F_OPEN_END_TIMESTAMP:
-            case POSIX_F_READ_END_TIMESTAMP:
-            case POSIX_F_WRITE_END_TIMESTAMP:
-            case POSIX_F_CLOSE_END_TIMESTAMP:
-                break;
-            case POSIX_F_FASTEST_RANK_TIME:
-            case POSIX_F_SLOWEST_RANK_TIME:
-            case POSIX_F_VARIANCE_RANK_TIME:
-            case POSIX_F_VARIANCE_RANK_BYTES:
-                break;
-            case POSIX_F_MAX_READ_TIME:
-                if(tmp->fcounters[i] < pfile->fcounters[i])
-                    tmp->counters[POSIX_MAX_READ_TIME_SIZE] =
-                        pfile->counters[POSIX_MAX_READ_TIME_SIZE];
-                break;
-            case POSIX_F_MAX_WRITE_TIME:
-                    tmp->counters[POSIX_MAX_WRITE_TIME_SIZE] =
-                        pfile->counters[POSIX_MAX_WRITE_TIME_SIZE];
-                break;
-            default:
-                break;
-    return;
-                      int64_t nprocs)
-    int i, j;
-    int set;
-    int min_ndx;
-    int64_t min;
-    struct darshan_mpiio_file* tmp;
-    if(mfile->base_rec.rank == -1)
-        hfile->slowest_time = mfile->fcounters[MPIIO_F_SLOWEST_RANK_TIME];
-    else
-            (mfile->fcounters[MPIIO_F_META_TIME] +
-            mfile->fcounters[MPIIO_F_READ_TIME] +
-            mfile->fcounters[MPIIO_F_WRITE_TIME]));
-    else
-    hfile->cumul_time += mfile->fcounters[MPIIO_F_META_TIME] +
-                         mfile->fcounters[MPIIO_F_WRITE_TIME];
-        hfile->rec_dat = malloc(sizeof(struct darshan_mpiio_file));
-        memset(hfile->rec_dat, 0, sizeof(struct darshan_mpiio_file));
-    tmp = (struct darshan_mpiio_file*)hfile->rec_dat;
-    for(i = 0; i < MPIIO_NUM_INDICES; i++)
-        switch(i)
-        case MPIIO_MODE:
-            tmp->counters[i] = mfile->counters[i];
-            break;
-        case MPIIO_ACCESS1_ACCESS:
-        case MPIIO_ACCESS2_ACCESS:
-        case MPIIO_ACCESS3_ACCESS:
-        case MPIIO_ACCESS4_ACCESS:
-            break;
-        case MPIIO_ACCESS1_COUNT:
-        case MPIIO_ACCESS2_COUNT:
-        case MPIIO_ACCESS3_COUNT:
-        case MPIIO_ACCESS4_COUNT:
-            set = 0;
-            min_ndx = MPIIO_ACCESS1_COUNT;
-            for(j = MPIIO_ACCESS1_COUNT; j <= MPIIO_ACCESS4_COUNT; j++)
-                if(tmp->counters[j-4] == mfile->counters[i-4])
-                    tmp->counters[j] += mfile->counters[i];
-                    set = 1;
-                    break;
-                    min_ndx = j;
-            if(!set && (mfile->counters[i] > min))
-                tmp->counters[i-4] = mfile->counters[i-4];
-            break;
-        case MPIIO_FASTEST_RANK:
-        case MPIIO_SLOWEST_RANK:
-        case MPIIO_FASTEST_RANK_BYTES:
-        case MPIIO_SLOWEST_RANK_BYTES:
-            break;
-        case MPIIO_MAX_READ_TIME_SIZE:
-        case MPIIO_MAX_WRITE_TIME_SIZE:
-            break;
-        default:
-            tmp->counters[i] += mfile->counters[i];
-            break;
-    for(i = 0; i < MPIIO_F_NUM_INDICES; i++)
-        switch(i)
-            case MPIIO_F_OPEN_TIMESTAMP:
-            case MPIIO_F_READ_START_TIMESTAMP:
-            case MPIIO_F_WRITE_START_TIMESTAMP:
-                    tmp->fcounters[i] > mfile->fcounters[i])
-                    tmp->fcounters[i] = mfile->fcounters[i];
-                break;
-            case MPIIO_F_READ_END_TIMESTAMP:
-            case MPIIO_F_WRITE_END_TIMESTAMP:
-            case MPIIO_F_CLOSE_TIMESTAMP:
-                    tmp->fcounters[i] < mfile->fcounters[i])
-                break;
-            case MPIIO_F_FASTEST_RANK_TIME:
-            case MPIIO_F_SLOWEST_RANK_TIME:
-            case MPIIO_F_VARIANCE_RANK_TIME:
-            case MPIIO_F_VARIANCE_RANK_BYTES:
-                break;
-            case MPIIO_F_MAX_READ_TIME:
-                if(tmp->fcounters[i] < mfile->fcounters[i])
-                    tmp->counters[MPIIO_MAX_READ_TIME_SIZE] =
-                        mfile->counters[MPIIO_MAX_READ_TIME_SIZE];
-                break;
-            case MPIIO_F_MAX_WRITE_TIME:
-                    tmp->counters[MPIIO_MAX_WRITE_TIME_SIZE] =
-                        mfile->counters[MPIIO_MAX_WRITE_TIME_SIZE];
-                break;
-            default:
-                tmp->fcounters[i] += mfile->fcounters[i];
-                break;
-    return;
-                      perf_data_t *pdata)
-    pdata->total_bytes += pfile->counters[STDIO_BYTES_READ] +
-                          pfile->counters[STDIO_BYTES_WRITTEN];
-     * Calculation of Shared File Time
-     *   Four Methods!!!!
-     *     by_cumul: sum time counters and divide by nprocs
-     *               (inaccurate if lots of variance between procs)
-     *     by_open: difference between timestamp of open and close
-     *              (inaccurate if file is left open without i/o happening)
-     *     by_open_lastio: difference between timestamp of open and the
-     *                     timestamp of last i/o
-     *                     (similar to above but fixes case where file is left
-     *                      open after io is complete)
-     *     by_slowest: use slowest rank time from log data
-     *                 (most accurate but requires newer log version)
-        /* by_open */
-        if(pfile->fcounters[STDIO_F_CLOSE_END_TIMESTAMP] >
-            pfile->fcounters[STDIO_F_OPEN_START_TIMESTAMP])
-            pdata->shared_time_by_open +=
-                pfile->fcounters[STDIO_F_CLOSE_END_TIMESTAMP] -
-                pfile->fcounters[STDIO_F_OPEN_START_TIMESTAMP];
-        /* by_open_lastio */
-        if(pfile->fcounters[STDIO_F_READ_END_TIMESTAMP] >
-            pfile->fcounters[STDIO_F_WRITE_END_TIMESTAMP])
-            /* be careful: file may have been opened but not read or written */
-            if(pfile->fcounters[STDIO_F_READ_END_TIMESTAMP] > pfile->fcounters[STDIO_F_OPEN_START_TIMESTAMP])
-                pdata->shared_time_by_open_lastio +=
-                    pfile->fcounters[STDIO_F_READ_END_TIMESTAMP] -
-        else
-            if(pfile->fcounters[STDIO_F_WRITE_END_TIMESTAMP] > pfile->fcounters[STDIO_F_OPEN_START_TIMESTAMP])
-                    pfile->fcounters[STDIO_F_WRITE_END_TIMESTAMP] -
-        pdata->shared_time_by_cumul +=
-            pfile->fcounters[STDIO_F_META_TIME] +
-        pdata->shared_meta_time += pfile->fcounters[STDIO_F_META_TIME];
-        /* by_slowest */
-        pdata->shared_time_by_slowest +=
-            pfile->fcounters[STDIO_F_SLOWEST_RANK_TIME];
-     * Calculation of Unique File Time
-     *   record the data for each file and sum it
-    else
-        pdata->rank_cumul_io_time[pfile->base_rec.rank] +=
-            pfile->fcounters[STDIO_F_WRITE_TIME]);
-        pdata->rank_cumul_md_time[pfile->base_rec.rank] +=
-            pfile->fcounters[STDIO_F_META_TIME];
-    return;
-    pdata->total_bytes += pfile->counters[POSIX_BYTES_READ] +
-                          pfile->counters[POSIX_BYTES_WRITTEN];
-        /* by_open */
-        if(pfile->fcounters[POSIX_F_CLOSE_END_TIMESTAMP] >
-            pfile->fcounters[POSIX_F_OPEN_START_TIMESTAMP])
-                pfile->fcounters[POSIX_F_CLOSE_END_TIMESTAMP] -
-                pfile->fcounters[POSIX_F_OPEN_START_TIMESTAMP];
-        if(pfile->fcounters[POSIX_F_READ_END_TIMESTAMP] >
-            pfile->fcounters[POSIX_F_WRITE_END_TIMESTAMP])
-            if(pfile->fcounters[POSIX_F_READ_END_TIMESTAMP] > pfile->fcounters[POSIX_F_OPEN_START_TIMESTAMP])
-                    pfile->fcounters[POSIX_F_READ_END_TIMESTAMP] -
-        else
-            if(pfile->fcounters[POSIX_F_WRITE_END_TIMESTAMP] > pfile->fcounters[POSIX_F_OPEN_START_TIMESTAMP])
-                    pfile->fcounters[POSIX_F_WRITE_END_TIMESTAMP] -
-            pfile->fcounters[POSIX_F_META_TIME] +
-        pdata->shared_meta_time += pfile->fcounters[POSIX_F_META_TIME];
-        /* by_slowest */
-            pfile->fcounters[POSIX_F_SLOWEST_RANK_TIME];
-    else
-            pfile->fcounters[POSIX_F_WRITE_TIME]);
-            pfile->fcounters[POSIX_F_META_TIME];
-    return;
-    pdata->total_bytes += mfile->counters[MPIIO_BYTES_READ] +
-                          mfile->counters[MPIIO_BYTES_WRITTEN];
-        /* by_open */
-        if(mfile->fcounters[MPIIO_F_CLOSE_TIMESTAMP] >
-            mfile->fcounters[MPIIO_F_OPEN_TIMESTAMP])
-                mfile->fcounters[MPIIO_F_CLOSE_TIMESTAMP] -
-                mfile->fcounters[MPIIO_F_OPEN_TIMESTAMP];
-        if(mfile->fcounters[MPIIO_F_READ_END_TIMESTAMP] >
-            mfile->fcounters[MPIIO_F_WRITE_END_TIMESTAMP])
-            if(mfile->fcounters[MPIIO_F_READ_END_TIMESTAMP] > mfile->fcounters[MPIIO_F_OPEN_TIMESTAMP])
-                    mfile->fcounters[MPIIO_F_READ_END_TIMESTAMP] -
-        else
-            if(mfile->fcounters[MPIIO_F_WRITE_END_TIMESTAMP] > mfile->fcounters[MPIIO_F_OPEN_TIMESTAMP])
-                    mfile->fcounters[MPIIO_F_WRITE_END_TIMESTAMP] -
-            mfile->fcounters[MPIIO_F_META_TIME] +
-        pdata->shared_meta_time += mfile->fcounters[MPIIO_F_META_TIME];
-        /* by_slowest */
-            mfile->fcounters[MPIIO_F_SLOWEST_RANK_TIME];
-    else
-        pdata->rank_cumul_io_time[mfile->base_rec.rank] +=
-            mfile->fcounters[MPIIO_F_WRITE_TIME]);
-        pdata->rank_cumul_md_time[mfile->base_rec.rank] +=
-            mfile->fcounters[MPIIO_F_META_TIME];
-    return;
-                     file_data_t *fdata)
-    hash_entry_t *curr = NULL;
-    hash_entry_t *tmp = NULL;
-    struct darshan_stdio_file *file_rec;
-    memset(fdata, 0, sizeof(*fdata));
-    HASH_ITER(hlink, file_hash, curr, tmp)
-        int64_t bytes;
-        int64_t r;
-        int64_t w;
-        file_rec = (struct darshan_stdio_file*)curr->rec_dat;
-        assert(file_rec);
-        bytes = file_rec->counters[STDIO_BYTES_READ] +
-                file_rec->counters[STDIO_BYTES_WRITTEN];
-        r = file_rec->counters[STDIO_READS];
-        w = file_rec->counters[STDIO_WRITES];
-        fdata->total += 1;
-        fdata->total_size += bytes;
-        fdata->total_max = max(fdata->total_max, bytes);
-        if (r && !w)
-            fdata->read_only += 1;
-            fdata->read_only_size += bytes;
-            fdata->read_only_max = max(fdata->read_only_max, bytes);
-        if (!r && w)
-            fdata->write_only += 1;
-            fdata->write_only_size += bytes;
-            fdata->write_only_max = max(fdata->write_only_max, bytes);
-        if (r && w)
-            fdata->read_write += 1;
-            fdata->read_write_size += bytes;
-            fdata->read_write_max = max(fdata->read_write_max, bytes);
-        if ((curr->type & (FILETYPE_SHARED|FILETYPE_PARTSHARED)))
-            fdata->shared += 1;
-            fdata->shared_size += bytes;
-            fdata->shared_max = max(fdata->shared_max, bytes);
-        if ((curr->type & (FILETYPE_UNIQUE)))
-            fdata->unique += 1;
-            fdata->unique_size += bytes;
-            fdata->unique_max = max(fdata->unique_max, bytes);
-    return;
-    struct darshan_posix_file *file_rec;
-        int64_t bytes;
-        int64_t r;
-        int64_t w;
-        file_rec = (struct darshan_posix_file*)curr->rec_dat;
-        assert(file_rec);
-        bytes = file_rec->counters[POSIX_BYTES_READ] +
-                file_rec->counters[POSIX_BYTES_WRITTEN];
-        r = file_rec->counters[POSIX_READS];
-        w = file_rec->counters[POSIX_WRITES];
-        if (r && !w)
-        if (!r && w)
-        if (r && w)
-    return;
-    struct darshan_mpiio_file *file_rec;
-        int64_t bytes;
-        int64_t r;
-        int64_t w;
-        file_rec = (struct darshan_mpiio_file*)curr->rec_dat;
-        assert(file_rec);
-        bytes = file_rec->counters[MPIIO_BYTES_READ] +
-                file_rec->counters[MPIIO_BYTES_WRITTEN];
-        r = (file_rec->counters[MPIIO_INDEP_READS]+
-             file_rec->counters[MPIIO_COLL_READS] +
-             file_rec->counters[MPIIO_SPLIT_READS] +
-             file_rec->counters[MPIIO_NB_READS]);
-        w = (file_rec->counters[MPIIO_INDEP_WRITES]+
-             file_rec->counters[MPIIO_COLL_WRITES] +
-             file_rec->counters[MPIIO_SPLIT_WRITES] +
-             file_rec->counters[MPIIO_NB_WRITES]);
-        if (r && !w)
-        if (!r && w)
-        if (r && w)
-    return;
-void calc_perf(perf_data_t *pdata,
-               int64_t nprocs)
-    int64_t i;
-    pdata->shared_time_by_cumul =
-        pdata->shared_time_by_cumul / (double)nprocs;
-    pdata->shared_meta_time = pdata->shared_meta_time / (double)nprocs;
-    for (i=0; i<nprocs; i++)
-        if (pdata->rank_cumul_io_time[i] > pdata->slowest_rank_time)
-            pdata->slowest_rank_time = pdata->rank_cumul_io_time[i];
-            pdata->slowest_rank_meta_time = pdata->rank_cumul_md_time[i];
-            pdata->slowest_rank_rank = i;
-    if (pdata->slowest_rank_time + pdata->shared_time_by_cumul)
-    pdata->agg_perf_by_cumul = ((double)pdata->total_bytes / 1048576.0) /
-                                  (pdata->slowest_rank_time +
-                                   pdata->shared_time_by_cumul);
-    if (pdata->slowest_rank_time + pdata->shared_time_by_open)
-    pdata->agg_perf_by_open  = ((double)pdata->total_bytes / 1048576.0) /
-                                    pdata->shared_time_by_open);
-    if (pdata->slowest_rank_time + pdata->shared_time_by_open_lastio)
-    pdata->agg_perf_by_open_lastio = ((double)pdata->total_bytes / 1048576.0) /
-                                      pdata->shared_time_by_open_lastio);
-    if (pdata->slowest_rank_time + pdata->shared_time_by_slowest)
-    pdata->agg_perf_by_slowest = ((double)pdata->total_bytes / 1048576.0) /
-                                      pdata->shared_time_by_slowest);
-    return;
-    int i;
-    mod_logutils[DARSHAN_STDIO_MOD]->log_print_description(stdio_ver);
-    printf("\n");
-        printf("total_%s: %"PRId64"\n",
-            stdio_counter_names[i], pfile->counters[i]);
-        printf("total_%s: %lf\n",
-            stdio_f_counter_names[i], pfile->fcounters[i]);
-    return;
-    int i;
-    mod_logutils[DARSHAN_POSIX_MOD]->log_print_description(posix_ver);
-    printf("\n");
-            posix_counter_names[i], pfile->counters[i]);
-            posix_f_counter_names[i], pfile->fcounters[i]);
-    return;
-    int i;
-    mod_logutils[DARSHAN_MPIIO_MOD]->log_print_description(mpiio_ver);
-    printf("\n");
-            mpiio_counter_names[i], mfile->counters[i]);
-            mpiio_f_counter_names[i], mfile->fcounters[i]);
-    return;
-                     struct darshan_name_record_ref *name_hash,
-                     int detail_flag)
-    struct darshan_stdio_file *file_rec = NULL;
-    struct darshan_name_record_ref *ref = NULL;
-    int i;
-    /* list of columns:
-     * normal mode
-     * - file id
-     * - file name
-     * - nprocs
-     * - slowest I/O time
-     * - average cumulative I/O time
-     * detailed mode
-     * - first open
-     * - first read
-     * - first write
-     * - last read
-     * - last write
-     * - last close
-     * - STDIO opens
-    if(detail_flag)
-        printf("\n# Per-file summary of I/O activity (detailed).\n");
-    else
-        printf("\n# Per-file summary of I/O activity.\n");
-    printf("# -----\n");
-    printf("# <record_id>: darshan record id for this file\n");
-    printf("# <file_name>: full file name\n");
-    printf("# <nprocs>: number of processes that opened the file\n");
-    printf("# <slowest>: (estimated) time in seconds consumed in IO by slowest process\n");
-    printf("# <avg>: average time in seconds consumed in IO per process\n");
-    if(detail_flag)
-        printf("# <start_{open/close/write/read}>: start timestamp of first open, close, write, or read\n");
-        printf("# <end_{open/close/write/read}>: end timestamp of last open, close, write, or read\n");
-        printf("# <stdio_opens>: STDIO open calls\n");
-    printf("\n# <record_id>\t<file_name>\t<nprocs>\t<slowest>\t<avg>");
-    if(detail_flag)
-        printf("\t<start_open>\t<start_close>\t<start_write>\t<start_read>");
-        printf("\t<end_open>\t<end_close>\t<end_write>\t<end_read>\t<stdio_opens>");
-    printf("\n");
-        assert(file_rec);
-        HASH_FIND(hlink, name_hash, &(curr->rec_id), sizeof(darshan_record_id), ref);
-        assert(ref);
-        printf("%" PRIu64 "\t%s\t%" PRId64 "\t%f\t%f",
-            curr->rec_id,
-            ref->name_record->name,
-            curr->procs,
-            curr->slowest_time,
-            curr->cumul_time/(double)curr->procs);
-        if(detail_flag)
-            for(i=STDIO_F_OPEN_START_TIMESTAMP; i<=STDIO_F_READ_END_TIMESTAMP; i++)
-                printf("\t%f", file_rec->fcounters[i]);
-            printf("\t%" PRId64, file_rec->counters[STDIO_OPENS]);
-        printf("\n");
-    return;
-                     int detail_flag)
-    struct darshan_posix_file *file_rec = NULL;
-    int i;
-     * normal mode
-     * - file id
-     * - file name
-     * - nprocs
-     * detailed mode
-     * - first open
-     * - first read
-     * - first write
-     * - last read
-     * - last write
-     * - last close
-     * - POSIX opens
-     * - r histogram
-     * - w histogram
-    if(detail_flag)
-    else
-    if(detail_flag)
-        printf("# <start_{open/read/write/close}>: start timestamp of first open, read, write, or close\n");
-        printf("# <end_{open/read/write/close}>: end timestamp of last open, read, write, or close\n");
-        printf("# <posix_opens>: POSIX open calls\n");
-        printf("# <POSIX_SIZE_READ_*>: POSIX read size histogram\n");
-        printf("# <POSIX_SIZE_WRITE_*>: POSIX write size histogram\n");
-    if(detail_flag)
-        printf("\t<start_open>\t<start_read>\t<start_write>\t<start_close>");
-        printf("\t<end_open>\t<end_read>\t<end_write>\t<end_close>\t<posix_opens>");
-        for(i=POSIX_SIZE_READ_0_100; i<= POSIX_SIZE_WRITE_1G_PLUS; i++)
-            printf("\t<%s>", posix_counter_names[i]);
-    printf("\n");
-        assert(file_rec);
-        assert(ref);
-            curr->rec_id,
-            curr->procs,
-        if(detail_flag)
-            for(i=POSIX_F_OPEN_START_TIMESTAMP; i<=POSIX_F_CLOSE_END_TIMESTAMP; i++)
-            printf("\t%" PRId64, file_rec->counters[POSIX_OPENS]);
-                printf("\t%" PRId64, file_rec->counters[i]);
-        printf("\n");
-    return;
-                     int detail_flag)
-    struct darshan_mpiio_file *file_rec = NULL;
-    int i;
-     * normal mode
-     * - file id
-     * - file name
-     * - nprocs
-     * detailed mode
-     * - first open
-     * - first read
-     * - first write
-     * - last read
-     * - last write
-     * - last close
-     * - MPI indep opens
-     * - MPI coll opens
-     * - r histogram
-     * - w histogram
-    if(detail_flag)
-    else
-    if(detail_flag)
-        printf("# <start_{open/read/write}>: start timestamp of first open, read, or write\n");
-        printf("# <end_{read/write/close}>: end timestamp of last read, write, or close\n");
-        printf("# <mpi_indep_opens>: independent MPI_File_open calls\n");
-        printf("# <mpi_coll_opens>: collective MPI_File_open calls\n");
-        printf("# <MPIIO_SIZE_READ_AGG_*>: MPI-IO aggregate read size histogram\n");
-        printf("# <MPIIO_SIZE_WRITE_AGG_*>: MPI-IO aggregate write size histogram\n");
-    if(detail_flag)
-        printf("\t<start_open>\t<start_read>\t<start_write>");
-        printf("\t<end_read>\t<end_write>\t<end_close>");
-        printf("\t<mpi_indep_opens>\t<mpi_coll_opens>");
-        for(i=MPIIO_SIZE_READ_AGG_0_100; i<= MPIIO_SIZE_WRITE_AGG_1G_PLUS; i++)
-            printf("\t<%s>", mpiio_counter_names[i]);
-    printf("\n");
-        assert(file_rec);
-        assert(ref);
-            curr->rec_id,
-            curr->procs,
-        if(detail_flag)
-            for(i=MPIIO_F_OPEN_TIMESTAMP; i<=MPIIO_F_CLOSE_TIMESTAMP; i++)
-            printf("\t%" PRId64 "\t%" PRId64, file_rec->counters[MPIIO_INDEP_OPENS],
-                file_rec->counters[MPIIO_COLL_OPENS]);
-        printf("\n");
-    return;
  * Local variables:
  *  c-indent-level: 4
--- a/darshan-util/darshan-pnetcdf-logutils.c
+++ b/darshan-util/darshan-pnetcdf-logutils.c
@@ -46,7 +46,13 @@ struct darshan_mod_logutil_funcs pnetcdf_logutils =
     .log_print_record = &darshan_log_print_pnetcdf_file,
     .log_print_description = &darshan_log_print_pnetcdf_description,
     .log_print_diff = &darshan_log_print_pnetcdf_file_diff,
-    .log_agg_records = &darshan_log_agg_pnetcdf_files
+    .log_agg_records = &darshan_log_agg_pnetcdf_files,
 static int darshan_log_get_pnetcdf_file(darshan_fd fd, void** pnetcdf_buf_p)
--- a/darshan-util/darshan-posix-logutils.c
+++ b/darshan-util/darshan-posix-logutils.c
@@ -41,6 +41,11 @@ static void darshan_log_print_posix_description(int ver);
 static void darshan_log_print_posix_file_diff(void *file_rec1, char *file_name1,
 static void darshan_log_agg_posix_files(void *rec, void *agg_rec, int init_flag);
+static void darshan_log_posix_accum_file(void *pfile, hash_entry_t *hfile, int64_t nprocs);
+static void darshan_log_posix_accum_perf(void *pfile, perf_data_t *pdata);
+static void darshan_log_posix_calc_file(hash_entry_t *file_hash, file_data_t *fdata);
+static void darshan_log_posix_print_total_file(void *pfile, int posix_ver);
+static void darshan_log_posix_file_list(hash_entry_t *file_hash, struct darshan_name_record_ref *name_hash, int detail_flag);
 struct darshan_mod_logutil_funcs posix_logutils =
@@ -50,6 +55,12 @@ struct darshan_mod_logutil_funcs posix_logutils =
     .log_print_description = &darshan_log_print_posix_description,
     .log_print_diff = &darshan_log_print_posix_file_diff,
     .log_agg_records = &darshan_log_agg_posix_files,
+    .log_accum_file = &darshan_log_posix_accum_file,
+    .log_accum_perf = &darshan_log_posix_accum_perf,
+    .log_calc_file = &darshan_log_posix_calc_file,
+    .log_print_total_file = &darshan_log_posix_print_total_file,
+    .log_file_list = &darshan_log_posix_file_list,
 static int darshan_log_get_posix_file(darshan_fd fd, void** posix_buf_p)
@@ -631,6 +642,479 @@ static void darshan_log_agg_posix_files(void *rec, void *agg_rec, int init_flag)
     return;
+    void *infile,
+    int64_t nprocs)
+    struct darshan_posix_file *pfile = infile;
+    int i, j;
+    int set;
+    int min_ndx;
+    int64_t min;
+    struct darshan_posix_file* tmp;
+    if(pfile->base_rec.rank == -1)
+        hfile->slowest_time = pfile->fcounters[POSIX_F_SLOWEST_RANK_TIME];
+    else
+            (pfile->fcounters[POSIX_F_META_TIME] +
+            pfile->fcounters[POSIX_F_READ_TIME] +
+            pfile->fcounters[POSIX_F_WRITE_TIME]));
+    else
+    hfile->cumul_time += pfile->fcounters[POSIX_F_META_TIME] +
+                         pfile->fcounters[POSIX_F_WRITE_TIME];
+        hfile->rec_dat = malloc(sizeof(struct darshan_posix_file));
+        memset(hfile->rec_dat, 0, sizeof(struct darshan_posix_file));
+    tmp = (struct darshan_posix_file*)hfile->rec_dat;
+    for(i = 0; i < POSIX_NUM_INDICES; i++)
+        switch(i)
+        case POSIX_MODE:
+        case POSIX_MEM_ALIGNMENT:
+        case POSIX_FILE_ALIGNMENT:
+            tmp->counters[i] = pfile->counters[i];
+            break;
+        case POSIX_MAX_BYTE_READ:
+        case POSIX_MAX_BYTE_WRITTEN:
+            if (tmp->counters[i] < pfile->counters[i])
+            break;
+        case POSIX_STRIDE1_STRIDE:
+        case POSIX_STRIDE2_STRIDE:
+        case POSIX_STRIDE3_STRIDE:
+        case POSIX_STRIDE4_STRIDE:
+        case POSIX_ACCESS1_ACCESS:
+        case POSIX_ACCESS2_ACCESS:
+        case POSIX_ACCESS3_ACCESS:
+        case POSIX_ACCESS4_ACCESS:
+           break;
+        case POSIX_STRIDE1_COUNT:
+        case POSIX_STRIDE2_COUNT:
+        case POSIX_STRIDE3_COUNT:
+        case POSIX_STRIDE4_COUNT:
+            set = 0;
+            min_ndx = POSIX_STRIDE1_COUNT;
+            for(j = POSIX_STRIDE1_COUNT; j <= POSIX_STRIDE4_COUNT; j++)
+                if(tmp->counters[j-4] == pfile->counters[i-4])
+                    tmp->counters[j] += pfile->counters[i];
+                    set = 1;
+                    break;
+                    min_ndx = j;
+            if(!set && (pfile->counters[i] > min))
+                tmp->counters[min_ndx] = pfile->counters[i];
+                tmp->counters[min_ndx-4] = pfile->counters[i-4];
+            break;
+        case POSIX_ACCESS1_COUNT:
+        case POSIX_ACCESS2_COUNT:
+        case POSIX_ACCESS3_COUNT:
+        case POSIX_ACCESS4_COUNT:
+            set = 0;
+            min_ndx = POSIX_ACCESS1_COUNT;
+            for(j = POSIX_ACCESS1_COUNT; j <= POSIX_ACCESS4_COUNT; j++)
+                    set = 1;
+                    break;
+                    min_ndx = j;
+                tmp->counters[i-4] = pfile->counters[i-4];
+            break;
+        case POSIX_FASTEST_RANK:
+        case POSIX_SLOWEST_RANK:
+        case POSIX_FASTEST_RANK_BYTES:
+        case POSIX_SLOWEST_RANK_BYTES:
+            break;
+        case POSIX_MAX_READ_TIME_SIZE:
+        case POSIX_MAX_WRITE_TIME_SIZE:
+            break;
+        default:
+            tmp->counters[i] += pfile->counters[i];
+            break;
+    for(i = 0; i < POSIX_F_NUM_INDICES; i++)
+        switch(i)
+            case POSIX_F_OPEN_START_TIMESTAMP:
+            case POSIX_F_READ_START_TIMESTAMP:
+            case POSIX_F_WRITE_START_TIMESTAMP:
+            case POSIX_F_CLOSE_START_TIMESTAMP:
+                    tmp->fcounters[i] > pfile->fcounters[i])
+                    tmp->fcounters[i] = pfile->fcounters[i];
+                break;
+            case POSIX_F_OPEN_END_TIMESTAMP:
+            case POSIX_F_READ_END_TIMESTAMP:
+            case POSIX_F_WRITE_END_TIMESTAMP:
+            case POSIX_F_CLOSE_END_TIMESTAMP:
+                    tmp->fcounters[i] < pfile->fcounters[i])
+                break;
+            case POSIX_F_FASTEST_RANK_TIME:
+            case POSIX_F_SLOWEST_RANK_TIME:
+            case POSIX_F_VARIANCE_RANK_TIME:
+            case POSIX_F_VARIANCE_RANK_BYTES:
+                break;
+            case POSIX_F_MAX_READ_TIME:
+                if(tmp->fcounters[i] < pfile->fcounters[i])
+                    tmp->counters[POSIX_MAX_READ_TIME_SIZE] =
+                        pfile->counters[POSIX_MAX_READ_TIME_SIZE];
+                break;
+            case POSIX_F_MAX_WRITE_TIME:
+                    tmp->counters[POSIX_MAX_WRITE_TIME_SIZE] =
+                        pfile->counters[POSIX_MAX_WRITE_TIME_SIZE];
+                break;
+            default:
+                tmp->fcounters[i] += pfile->fcounters[i];
+                break;
+    return;
+    void *infile,
+    pdata->total_bytes += pfile->counters[POSIX_BYTES_READ] +
+                          pfile->counters[POSIX_BYTES_WRITTEN];
+        /* by_open */
+        if(pfile->fcounters[POSIX_F_CLOSE_END_TIMESTAMP] >
+            pfile->fcounters[POSIX_F_OPEN_START_TIMESTAMP])
+                pfile->fcounters[POSIX_F_CLOSE_END_TIMESTAMP] -
+                pfile->fcounters[POSIX_F_OPEN_START_TIMESTAMP];
+        if(pfile->fcounters[POSIX_F_READ_END_TIMESTAMP] >
+            pfile->fcounters[POSIX_F_WRITE_END_TIMESTAMP])
+            if(pfile->fcounters[POSIX_F_READ_END_TIMESTAMP] > pfile->fcounters[POSIX_F_OPEN_START_TIMESTAMP])
+                    pfile->fcounters[POSIX_F_READ_END_TIMESTAMP] -
+        else
+            if(pfile->fcounters[POSIX_F_WRITE_END_TIMESTAMP] > pfile->fcounters[POSIX_F_OPEN_START_TIMESTAMP])
+                    pfile->fcounters[POSIX_F_WRITE_END_TIMESTAMP] -
+            pfile->fcounters[POSIX_F_META_TIME] +
+        pdata->shared_meta_time += pfile->fcounters[POSIX_F_META_TIME];
+        /* by_slowest */
+            pfile->fcounters[POSIX_F_SLOWEST_RANK_TIME];
+    else
+        pdata->rank_cumul_io_time[pfile->base_rec.rank] +=
+            pfile->fcounters[POSIX_F_WRITE_TIME]);
+        pdata->rank_cumul_md_time[pfile->base_rec.rank] +=
+            pfile->fcounters[POSIX_F_META_TIME];
+    return;
+    struct darshan_posix_file *file_rec;
+        int64_t bytes;
+        int64_t r;
+        int64_t w;
+        file_rec = (struct darshan_posix_file*)curr->rec_dat;
+        assert(file_rec);
+        bytes = file_rec->counters[POSIX_BYTES_READ] +
+                file_rec->counters[POSIX_BYTES_WRITTEN];
+        r = file_rec->counters[POSIX_READS];
+        w = file_rec->counters[POSIX_WRITES];
+        if (r && !w)
+        if (!r && w)
+        if (r && w)
+    return;
+    void *infile,
+    int posix_ver)
+    int i;
+    mod_logutils[DARSHAN_POSIX_MOD]->log_print_description(posix_ver);
+    printf("\n");
+            posix_counter_names[i], pfile->counters[i]);
+            posix_f_counter_names[i], pfile->fcounters[i]);
+    return;
+    int detail_flag)
+    struct darshan_posix_file *file_rec = NULL;
+    int i;
+     * normal mode
+     * - file id
+     * - file name
+     * - nprocs
+     * detailed mode
+     * - first open
+     * - first read
+     * - first write
+     * - last read
+     * - last write
+     * - last close
+     * - POSIX opens
+     * - r histogram
+     * - w histogram
+    if(detail_flag)
+    else
+    if(detail_flag)
+        printf("# <start_{open/read/write/close}>: start timestamp of first open, read, write, or close\n");
+        printf("# <end_{open/read/write/close}>: end timestamp of last open, read, write, or close\n");
+        printf("# <posix_opens>: POSIX open calls\n");
+        printf("# <POSIX_SIZE_READ_*>: POSIX read size histogram\n");
+        printf("# <POSIX_SIZE_WRITE_*>: POSIX write size histogram\n");
+    if(detail_flag)
+        printf("\t<start_open>\t<start_read>\t<start_write>\t<start_close>");
+        printf("\t<end_open>\t<end_read>\t<end_write>\t<end_close>\t<posix_opens>");
+        for(i=POSIX_SIZE_READ_0_100; i<= POSIX_SIZE_WRITE_1G_PLUS; i++)
+            printf("\t<%s>", posix_counter_names[i]);
+    printf("\n");
+        assert(file_rec);
+        assert(ref);
+            curr->rec_id,
+            curr->procs,
+        if(detail_flag)
+            for(i=POSIX_F_OPEN_START_TIMESTAMP; i<=POSIX_F_CLOSE_END_TIMESTAMP; i++)
+            printf("\t%" PRId64, file_rec->counters[POSIX_OPENS]);
+        printf("\n");
+    return;
  * Local variables:
  *  c-indent-level: 4
--- a/darshan-util/darshan-stdio-logutils.c
+++ b/darshan-util/darshan-stdio-logutils.c
@@ -40,6 +40,11 @@ static void darshan_log_print_stdio_description(int ver);
 static void darshan_log_print_stdio_record_diff(void *file_rec1, char *file_name1,
 static void darshan_log_agg_stdio_records(void *rec, void *agg_rec, int init_flag);
+static void darshan_log_stdio_accum_perf(void *pfile, perf_data_t *pdata);
+static void darshan_log_stdio_accum_file(void *pfile, hash_entry_t *hfile, int64_t nprocs);
+static void darshan_log_stdio_calc_file(hash_entry_t *file_hash, file_data_t *fdata);
+static void darshan_log_stdio_file_list(hash_entry_t *file_hash, struct darshan_name_record_ref *name_hash, int detail_flag);
+static void darshan_log_stdio_print_total_file(void *pfile, int stdio_ver);
 /* structure storing each function needed for implementing the darshan
  * logutil interface. these functions are used for reading, writing, and
@@ -52,7 +57,13 @@ struct darshan_mod_logutil_funcs stdio_logutils =
     .log_print_record = &darshan_log_print_stdio_record,
     .log_print_description = &darshan_log_print_stdio_description,
     .log_print_diff = &darshan_log_print_stdio_record_diff,
-    .log_agg_records = &darshan_log_agg_stdio_records
+    .log_agg_records = &darshan_log_agg_stdio_records,
+    .log_accum_file = &darshan_log_stdio_accum_file,
+    .log_accum_perf = &darshan_log_stdio_accum_perf,
+    .log_calc_file = &darshan_log_stdio_calc_file,
+    .log_print_total_file = &darshan_log_stdio_print_total_file,
+    .log_file_list = &darshan_log_stdio_file_list,
 /* retrieve a STDIO record from log file descriptor 'fd', storing the
@@ -416,6 +427,375 @@ static void darshan_log_agg_stdio_records(void *rec, void *agg_rec, int init_fla
     return;
+static void darshan_log_stdio_accum_file(void *infile,
+                                         int64_t nprocs)
+    struct darshan_stdio_file *pfile = infile;
+    int i;
+    struct darshan_stdio_file* tmp;
+        hfile->slowest_time = pfile->fcounters[STDIO_F_SLOWEST_RANK_TIME];
+    else
+            (pfile->fcounters[STDIO_F_META_TIME] +
+            pfile->fcounters[STDIO_F_READ_TIME] +
+            pfile->fcounters[STDIO_F_WRITE_TIME]));
+    else
+    hfile->cumul_time += pfile->fcounters[STDIO_F_META_TIME] +
+                         pfile->fcounters[STDIO_F_WRITE_TIME];
+        hfile->rec_dat = malloc(sizeof(struct darshan_stdio_file));
+        memset(hfile->rec_dat, 0, sizeof(struct darshan_stdio_file));
+    tmp = (struct darshan_stdio_file*)hfile->rec_dat;
+    for(i = 0; i < STDIO_NUM_INDICES; i++)
+        switch(i)
+        case STDIO_MAX_BYTE_READ:
+        case STDIO_MAX_BYTE_WRITTEN:
+            break;
+            break;
+        default:
+            break;
+    for(i = 0; i < STDIO_F_NUM_INDICES; i++)
+        switch(i)
+            case STDIO_F_OPEN_START_TIMESTAMP:
+            case STDIO_F_CLOSE_START_TIMESTAMP:
+            case STDIO_F_READ_START_TIMESTAMP:
+            case STDIO_F_WRITE_START_TIMESTAMP:
+                break;
+            case STDIO_F_READ_END_TIMESTAMP:
+            case STDIO_F_WRITE_END_TIMESTAMP:
+            case STDIO_F_OPEN_END_TIMESTAMP:
+            case STDIO_F_CLOSE_END_TIMESTAMP:
+                break;
+            case STDIO_F_FASTEST_RANK_TIME:
+            case STDIO_F_SLOWEST_RANK_TIME:
+            case STDIO_F_VARIANCE_RANK_TIME:
+            case STDIO_F_VARIANCE_RANK_BYTES:
+                break;
+            default:
+                break;
+    return;
+static void darshan_log_stdio_accum_perf(void *infile,
+    pdata->total_bytes += pfile->counters[STDIO_BYTES_READ] +
+                          pfile->counters[STDIO_BYTES_WRITTEN];
+        /* by_open */
+        if(pfile->fcounters[STDIO_F_CLOSE_END_TIMESTAMP] >
+            pfile->fcounters[STDIO_F_OPEN_START_TIMESTAMP])
+                pfile->fcounters[STDIO_F_CLOSE_END_TIMESTAMP] -
+                pfile->fcounters[STDIO_F_OPEN_START_TIMESTAMP];
+        if(pfile->fcounters[STDIO_F_READ_END_TIMESTAMP] >
+            pfile->fcounters[STDIO_F_WRITE_END_TIMESTAMP])
+            if(pfile->fcounters[STDIO_F_READ_END_TIMESTAMP] > pfile->fcounters[STDIO_F_OPEN_START_TIMESTAMP])
+                    pfile->fcounters[STDIO_F_READ_END_TIMESTAMP] -
+        else
+            if(pfile->fcounters[STDIO_F_WRITE_END_TIMESTAMP] > pfile->fcounters[STDIO_F_OPEN_START_TIMESTAMP])
+                    pfile->fcounters[STDIO_F_WRITE_END_TIMESTAMP] -
+            pfile->fcounters[STDIO_F_META_TIME] +
+        pdata->shared_meta_time += pfile->fcounters[STDIO_F_META_TIME];
+        /* by_slowest */
+           pfile->fcounters[STDIO_F_SLOWEST_RANK_TIME];
+    else
+            pfile->fcounters[STDIO_F_WRITE_TIME]);
+            pfile->fcounters[STDIO_F_META_TIME];
+    return;
+    struct darshan_stdio_file *file_rec;
+        int64_t bytes;
+        int64_t r;
+        int64_t w;
+        file_rec = (struct darshan_stdio_file*)curr->rec_dat;
+        assert(file_rec);
+        bytes = file_rec->counters[STDIO_BYTES_READ] +
+                file_rec->counters[STDIO_BYTES_WRITTEN];
+        r = file_rec->counters[STDIO_READS];
+        w = file_rec->counters[STDIO_WRITES];
+        if (r && !w)
+        if (!r && w)
+        if (r && w)
+    return;
+    void *infile,
+    int stdio_ver)
+    int i;
+    mod_logutils[DARSHAN_STDIO_MOD]->log_print_description(stdio_ver);
+    printf("\n");
+            stdio_counter_names[i], pfile->counters[i]);
+            stdio_f_counter_names[i], pfile->fcounters[i]);
+    return;
+    int detail_flag)
+    struct darshan_stdio_file *file_rec = NULL;
+    int i;
+     * normal mode
+     * - file id
+     * - file name
+     * - nprocs
+     * detailed mode
+     * - first open
+     * - first read
+     * - first write
+     * - last read
+     * - last write
+     * - last close
+     * - STDIO opens
+    if(detail_flag)
+    else
+    if(detail_flag)
+        printf("# <start_{open/close/write/read}>: start timestamp of first open, close, write, or read\n");
+        printf("# <end_{open/close/write/read}>: end timestamp of last open, close, write, or read\n");
+        printf("# <stdio_opens>: STDIO open calls\n");
+    if(detail_flag)
+        printf("\t<start_open>\t<start_close>\t<start_write>\t<start_read>");
+        printf("\t<end_open>\t<end_close>\t<end_write>\t<end_read>\t<stdio_opens>");
+    printf("\n");
+        assert(file_rec);
+        assert(ref);
+            curr->rec_id,
+            curr->procs,
+        if(detail_flag)
+            for(i=STDIO_F_OPEN_START_TIMESTAMP; i<=STDIO_F_READ_END_TIMESTAMP; i++)
+            printf("\t%" PRId64, file_rec->counters[STDIO_OPENS]);
+        printf("\n");
+    return;
  * Local variables:
  *  c-indent-level: 4
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/compare/cc0d9252be1f7ec9c095fbefbaa02e3404ea7e36...457a18fc78cf814e8b0e1d86efd7aed9fac82355
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20180308/65662c26/attachment-0001.html>
More information about the Darshan-commits mailing list
