[Darshan-commits] [Git][darshan/darshan][master] one more small doc change
Shane Snyder xgitlab at cels.anl.gov
Mon Mar 5 21:33:44 CST 2018
Shane Snyder pushed to branch master at darshan / darshan
Commits:
c5443990 by Shane Snyder at 2018-03-05T21:31:59-06:00
1 changed file:
- doc/darshan-modularization.txt
Changes:
--- a/doc/darshan-modularization.txt
+++ b/doc/darshan-modularization.txt
@@ -471,7 +471,7 @@ new instrumentation modules:
 * Necessary linker flags for inserting this module's wrapper functions need to be added to a
 module-specific file which is used when linking applications with Darshan. For an example,
 consider `darshan-runtime/share/ld-opts/darshan-posix-ld-opts`, the required linker options for the POSIX
-module. The base linker options file for Darshan (`darshan-runtime/darshan-base-ld-opts.in`)
+module. The base linker options file for Darshan (`darshan-runtime/share/ld-opts/darshan-base-ld-opts.in`)
 must also be updated to point to the new module-specific linker options file.
 * Targets must be added to `Makefile.in` to build static and shared objects for the module's
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/c5443990024d0fa8ae6f51206bdcc1007a623f35
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20180305/d6ec4a27/attachment-0001.html>
More information about the Darshan-commits mailing list
