[Darshan-commits] [Git][darshan/darshan][autoperf-mod] Update configure to validate autoperf module is present when autoperf is requested
Kevin Harms
xgitlab at cels.anl.gov
Tue Mar 13 11:18:16 CDT 2018
Kevin Harms pushed to branch autoperf-mod at darshan / darshan
Commits:
9357d7f9 by Kevin Harms at 2018-03-13T16:17:59+00:00
2 changed files:
- darshan-runtime/configure.in
- darshan-util/configure.in
Changes:
--- a/darshan-runtime/configure.in
+++ b/darshan-runtime/configure.in
@@ -170,15 +170,15 @@ if test x$enable_lustre_mod != xno; then
fi
if test x$enable_autoperf_crayxc = xyes; then
+ abssrcdir=$(readlink -f ${srcdir})
AC_CHECK_HEADER([papi.h],
with_papi=-lpapi,
[AC_MSG_ERROR([Cannot find required header for papi])],
- AC_REQUIRE_AUX_FILE([modules/autoperf/crayxc/darshan-apxc-log-format.h])
-dnl AC_CHECK_FILE([modules/autoperf/crayxc/darshan-apxc-log-format.h],
-dnl DARSHAN_USE_APXC=1,
-dnl [AC_MSG_ERROR([AutoPerf submodule not initialized])])
- DARSHAN_USE_APXC=1
+ AC_CHECK_HEADER([${abssrcdir}/../modules/autoperf/crayxc/darshan-apxc-log-format.h],
+ DARSHAN_USE_APXC=1,
+ [AC_MSG_ERROR([The autoperf module is not present])],
+ [-]) # this last part tells it to only check for presence
fi
if test x$GOT_ALIGNMENT != x1; then
--- a/darshan-util/configure.in
+++ b/darshan-util/configure.in
@@ -86,11 +86,11 @@ AC_ARG_ENABLE(
fi
AC_CHECK_FUNCS([strndup])
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/9357d7f98b263f60a02bdec1dfec0f45bfa2beee
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20180313/3534f202/attachment-0001.html>
More information about the Darshan-commits
