[Darshan-commits] [Git][darshan/darshan][dev-stdio] fseeko64 wrapper
Philip Carns xgitlab at cels.anl.gov
Mon May 23 22:20:22 CDT 2016
Philip Carns pushed to branch dev-stdio at darshan / darshan
Commits:
93a0e7a1 by Phil Carns at 2016-05-23T23:20:13-04:00
fseeko64 wrapper
2 changed files:
- darshan-runtime/lib/darshan-stdio.c
- darshan-runtime/share/ld-opts/darshan-stdio-ld-opts
Changes:
--- a/darshan-runtime/lib/darshan-stdio.c
+++ b/darshan-runtime/lib/darshan-stdio.c
@@ -61,7 +61,7 @@
  * int      fseek(FILE *, long int, int);                   DONE
  * int      fseeko(FILE *, off_t, int);                     DONE
- * int      fseeko64(FILE *, off_t, int);
+ * int      fseeko64(FILE *, off_t, int);                   DONE
  * int      fsetpos(FILE *, const fpos_t *);
  * int      fsetpos64(FILE *, const fpos_t *);
  * void     rewind(FILE *);
@@ -122,6 +122,7 @@ DARSHAN_FORWARD_DECL(vfscanf, int, (FILE *stream, const char *format, va_list ap
 DARSHAN_FORWARD_DECL(fgets, char*, (char *s, int size, FILE *stream));
 DARSHAN_FORWARD_DECL(fseek, int, (FILE *stream, long offset, int whence));
 DARSHAN_FORWARD_DECL(fseeko, int, (FILE *stream, off_t offset, int whence));
+DARSHAN_FORWARD_DECL(fseeko64, int, (FILE *stream, off_t offset, int whence));
 /* The stdio_file_runtime structure maintains necessary runtime metadata
  * for the STDIO file record (darshan_stdio_record structure, defined in
@@ -803,6 +804,37 @@ int DARSHAN_DECL(fseeko)(FILE *stream, off_t offset, int whence)
     return(ret);
+int DARSHAN_DECL(fseeko64)(FILE *stream, off_t offset, int whence)
+    int ret;
+    struct stdio_file_runtime* file;
+    double tm1, tm2;
+    MAP_OR_FAIL(fseeko64);
+    tm1 = darshan_core_wtime();
+    ret = __real_fseeko64(stream, offset, whence);
+    tm2 = darshan_core_wtime();
+    if(ret >= 0)
+        STDIO_LOCK();
+        stdio_runtime_initialize();
+        file = stdio_file_by_stream(stream);
+        if(file)
+            file->offset = ftell(stream);
+            DARSHAN_TIMER_INC_NO_OVERLAP(
+                file->file_record->fcounters[STDIO_F_META_TIME],
+                tm1, tm2, file->last_meta_end);
+            file->file_record->counters[STDIO_SEEKS] += 1;
+        STDIO_UNLOCK();
+    return(ret);
  * Internal functions for manipulating STDIO module state *
--- a/darshan-runtime/share/ld-opts/darshan-stdio-ld-opts
+++ b/darshan-runtime/share/ld-opts/darshan-stdio-ld-opts
@@ -17,6 +17,7 @@
 --wrap=fgets
 --wrap=fseek
 --wrap=fseeko
+--wrap=fseeko64
 --wrap=fprintf
 --wrap=vfprintf
 --wrap=fputc
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/93a0e7a1ae18cf721646aa14fd55fa7f0321eb33
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20160523/db1a9c80/attachment.html>
More information about the Darshan-commits mailing list
