[Darshan-commits] [Git][darshan/darshan][dev-stdio] fsetpos and fsetpos64 wrappers
Philip Carns
xgitlab at cels.anl.gov
Mon May 23 22:24:28 CDT 2016
Philip Carns pushed to branch dev-stdio at darshan / darshan
Commits:
0289d4ab by Phil Carns at 2016-05-23T23:24:12-04:00
2 changed files:
- darshan-runtime/lib/darshan-stdio.c
- darshan-runtime/share/ld-opts/darshan-stdio-ld-opts
Changes:
--- a/darshan-runtime/lib/darshan-stdio.c
+++ b/darshan-runtime/lib/darshan-stdio.c
@@ -62,8 +62,8 @@
* int fseek(FILE *, long int, int); DONE
* int fseeko(FILE *, off_t, int); DONE
* int fseeko64(FILE *, off_t, int); DONE
- * int fsetpos(FILE *, const fpos_t *);
- * int fsetpos64(FILE *, const fpos_t *);
+ * int fsetpos(FILE *, const fpos_t *); DONE
+ * int fsetpos64(FILE *, const fpos_t *); DONE
* void rewind(FILE *);
* int ungetc(int, FILE *);
@@ -123,6 +123,8 @@ DARSHAN_FORWARD_DECL(fgets, char*, (char *s, int size, FILE *stream));
DARSHAN_FORWARD_DECL(fseek, int, (FILE *stream, long offset, int whence));
DARSHAN_FORWARD_DECL(fseeko, int, (FILE *stream, off_t offset, int whence));
DARSHAN_FORWARD_DECL(fseeko64, int, (FILE *stream, off_t offset, int whence));
+DARSHAN_FORWARD_DECL(fsetpos, int, (FILE *stream, const fpos_t *pos));
+DARSHAN_FORWARD_DECL(fsetpos64, int, (FILE *stream, const fpos_t *pos));
/* The stdio_file_runtime structure maintains necessary runtime metadata
* for the STDIO file record (darshan_stdio_record structure, defined in
@@ -835,6 +837,69 @@ int DARSHAN_DECL(fseeko64)(FILE *stream, off_t offset, int whence)
return(ret);
+int DARSHAN_DECL(fsetpos)(FILE *stream, const fpos_t *pos)
+ int ret;
+ struct stdio_file_runtime* file;
+ double tm1, tm2;
+ MAP_OR_FAIL(fsetpos);
+ tm1 = darshan_core_wtime();
+ ret = __real_fsetpos(stream, pos);
+ tm2 = darshan_core_wtime();
+ if(ret >= 0)
+ STDIO_LOCK();
+ stdio_runtime_initialize();
+ file = stdio_file_by_stream(stream);
+ if(file)
+ file->offset = ftell(stream);
+ DARSHAN_TIMER_INC_NO_OVERLAP(
+ file->file_record->fcounters[STDIO_F_META_TIME],
+ tm1, tm2, file->last_meta_end);
+ file->file_record->counters[STDIO_SEEKS] += 1;
+ STDIO_UNLOCK();
+ return(ret);
+int DARSHAN_DECL(fsetpos64)(FILE *stream, const fpos_t *pos)
+ int ret;
+ double tm1, tm2;
+ MAP_OR_FAIL(fsetpos64);
+ ret = __real_fsetpos64(stream, pos);
+ if(ret >= 0)
+ STDIO_LOCK();
+ if(file)
+ STDIO_UNLOCK();
+ return(ret);
* Internal functions for manipulating STDIO module state *
--- a/darshan-runtime/share/ld-opts/darshan-stdio-ld-opts
+++ b/darshan-runtime/share/ld-opts/darshan-stdio-ld-opts
@@ -23,3 +23,5 @@
--wrap=fputc
--wrap=fputs
--wrap=putw
+--wrap=fsetpos
+--wrap=fsetpos64
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/0289d4ab80414e46aa0b467a3121ac111651af57
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20160523/56da48b5/attachment-0001.html>
More information about the Darshan-commits
