[Darshan-commits] [Git][darshan/darshan][dev-stdio] freopen64	wrapper
    Philip Carns
    xgitlab at cels.anl.gov
    Mon May 23 22:19:04 CDT 2016
Philip Carns pushed to branch dev-stdio at darshan / darshan
Commits:
0461e398 by Phil Carns at 2016-05-23T23:18:54-04:00
freopen64 wrapper
2 changed files:
- darshan-runtime/lib/darshan-stdio.c
- darshan-runtime/share/ld-opts/darshan-stdio-ld-opts
Changes:
--- a/darshan-runtime/lib/darshan-stdio.c
+++ b/darshan-runtime/lib/darshan-stdio.c
@@ -27,7 +27,7 @@
  * FILE    *fopen(const char *, const char *);              DONE
  * FILE    *fopen64(const char *, const char *);            DONE
  * FILE    *freopen(const char *, const char *, FILE *);    DONE
- * FILE    *freopen64(const char *, const char *, FILE *);
+ * FILE    *freopen64(const char *, const char *, FILE *);  DONE
  * functions for closing streams
@@ -103,6 +103,7 @@ DARSHAN_FORWARD_DECL(fopen, FILE*, (const char *path, const char *mode));
 DARSHAN_FORWARD_DECL(fopen64, FILE*, (const char *path, const char *mode));
 DARSHAN_FORWARD_DECL(fdopen, FILE*, (int fd, const char *mode));
 DARSHAN_FORWARD_DECL(freopen, FILE*, (const char *path, const char *mode, FILE *stream));
+DARSHAN_FORWARD_DECL(freopen64, FILE*, (const char *path, const char *mode, FILE *stream));
 DARSHAN_FORWARD_DECL(fclose, int, (FILE *fp));
 DARSHAN_FORWARD_DECL(fflush, int, (FILE *fp));
 DARSHAN_FORWARD_DECL(fwrite, size_t, (const void *ptr, size_t size, size_t nmemb, FILE *stream));
@@ -357,6 +358,26 @@ FILE* DARSHAN_DECL(freopen)(const char *path, const char *mode, FILE *stream)
     return(ret);
+FILE* DARSHAN_DECL(freopen64)(const char *path, const char *mode, FILE *stream)
+    FILE* ret;
+    double tm1, tm2;
+    MAP_OR_FAIL(freopen64);
+    tm1 = darshan_core_wtime();
+    ret = __real_freopen64(path, mode, stream);
+    tm2 = darshan_core_wtime();
+    STDIO_LOCK();
+    stdio_runtime_initialize();
+    STDIO_RECORD_OPEN(ret, path, tm1, tm2);
+    STDIO_UNLOCK();
+    return(ret);
 int DARSHAN_DECL(fflush)(FILE *fp)
     double tm1, tm2;
--- a/darshan-runtime/share/ld-opts/darshan-stdio-ld-opts
+++ b/darshan-runtime/share/ld-opts/darshan-stdio-ld-opts
@@ -3,6 +3,7 @@
 --wrap=fopen64
 --wrap=fdopen
 --wrap=freopen
+--wrap=freopen64
 --wrap=fflush
 --wrap=fclose
 --wrap=fwrite
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/0461e398916195e67c137eea76f2aa7385beea34
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20160523/2bdd08c6/attachment.html>
More information about the Darshan-commits
