[Darshan-commits] [Git][darshan/darshan][dev-stdio] putw wrapper
Philip Carns xgitlab at cels.anl.gov
Mon May 23 22:00:29 CDT 2016
Philip Carns pushed to branch dev-stdio at darshan / darshan
Commits:
29641b6a by Phil Carns at 2016-05-23T23:00:21-04:00
putw wrapper
2 changed files:
- darshan-runtime/lib/darshan-stdio.c
- darshan-runtime/share/ld-opts/darshan-stdio-ld-opts
Changes:
--- a/darshan-runtime/lib/darshan-stdio.c
+++ b/darshan-runtime/lib/darshan-stdio.c
@@ -53,7 +53,7 @@
  * int      fputs(const char *, FILE *);                    DONE
  * size_t   fwrite(const void *, size_t, size_t, FILE *);   DONE
  * int      putc(int, FILE *);                              DONE
- * int      putw(int, FILE *);
+ * int      putw(int, FILE *);                              DONE
  * functions for changing file position
@@ -103,6 +103,7 @@ DARSHAN_FORWARD_DECL(fclose, int, (FILE *fp));
 DARSHAN_FORWARD_DECL(fflush, int, (FILE *fp));
 DARSHAN_FORWARD_DECL(fwrite, size_t, (const void *ptr, size_t size, size_t nmemb, FILE *stream));
 DARSHAN_FORWARD_DECL(fputc, int, (int c, FILE *stream));
+DARSHAN_FORWARD_DECL(putw, int, (int w, FILE *stream));
 DARSHAN_FORWARD_DECL(fputs, int, (const char *s, FILE *stream));
 DARSHAN_FORWARD_DECL(fprintf, int, (FILE *stream, const char *format, ...));
 DARSHAN_FORWARD_DECL(vfprintf, int, (FILE *stream, const char *format, va_list));
@@ -443,6 +444,27 @@ int DARSHAN_DECL(fputc)(int c, FILE *stream)
     return(ret);
+int DARSHAN_DECL(putw)(int w, FILE *stream)
+    int ret;
+    double tm1, tm2;
+    MAP_OR_FAIL(putw);
+    tm1 = darshan_core_wtime();
+    ret = __real_putw(w, stream);
+    tm2 = darshan_core_wtime();
+    STDIO_LOCK();
+    stdio_runtime_initialize();
+    if(ret != EOF)
+        STDIO_RECORD_WRITE(stream, sizeof(int), tm1, tm2, 0);
+    STDIO_UNLOCK();
+    return(ret);
 int DARSHAN_DECL(fputs)(const char *s, FILE *stream)
--- a/darshan-runtime/share/ld-opts/darshan-stdio-ld-opts
+++ b/darshan-runtime/share/ld-opts/darshan-stdio-ld-opts
@@ -19,3 +19,4 @@
 --wrap=vfprintf
 --wrap=fputc
 --wrap=fputs
+--wrap=putw
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/29641b6a1442664260033a6601f8c70b6037009e
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20160523/bb2941ee/attachment.html>
More information about the Darshan-commits mailing list
