[Darshan-commits] [Git][darshan/darshan][dev-stdio] fseeko wrapper
Philip Carns xgitlab at cels.anl.gov
Mon May 23 22:03:20 CDT 2016
Philip Carns pushed to branch dev-stdio at darshan / darshan
Commits:
9697f099 by Phil Carns at 2016-05-23T23:03:11-04:00
fseeko wrapper
2 changed files:
- darshan-runtime/lib/darshan-stdio.c
- darshan-runtime/share/ld-opts/darshan-stdio-ld-opts
Changes:
--- a/darshan-runtime/lib/darshan-stdio.c
+++ b/darshan-runtime/lib/darshan-stdio.c
@@ -25,6 +25,7 @@
  * FILE    *fdopen(int, const char *);                      DONE
  * FILE    *fopen(const char *, const char *);              DONE
+ * FILE    *fopen64(const char *, const char *);            DONE
  * FILE    *freopen(const char *, const char *, FILE *);    DONE
  * functions for closing streams
@@ -116,6 +117,7 @@ DARSHAN_FORWARD_DECL(fscanf, int, (FILE *stream, const char *format, ...));
 DARSHAN_FORWARD_DECL(vfscanf, int, (FILE *stream, const char *format, va_list ap));
 DARSHAN_FORWARD_DECL(fgets, char*, (char *s, int size, FILE *stream));
 DARSHAN_FORWARD_DECL(fseek, int, (FILE *stream, long offset, int whence));
+DARSHAN_FORWARD_DECL(fseeko, int, (FILE *stream, off_t offset, int whence));
 /* The stdio_file_runtime structure maintains necessary runtime metadata
  * for the STDIO file record (darshan_stdio_record structure, defined in
@@ -746,6 +748,37 @@ int DARSHAN_DECL(fseek)(FILE *stream, long offset, int whence)
     return(ret);
+int DARSHAN_DECL(fseeko)(FILE *stream, off_t offset, int whence)
+    int ret;
+    struct stdio_file_runtime* file;
+    double tm1, tm2;
+    MAP_OR_FAIL(fseeko);
+    tm1 = darshan_core_wtime();
+    ret = __real_fseeko(stream, offset, whence);
+    tm2 = darshan_core_wtime();
+    if(ret >= 0)
+        STDIO_LOCK();
+        stdio_runtime_initialize();
+        file = stdio_file_by_stream(stream);
+        if(file)
+            file->offset = ftell(stream);
+            DARSHAN_TIMER_INC_NO_OVERLAP(
+                file->file_record->fcounters[STDIO_F_META_TIME],
+                tm1, tm2, file->last_meta_end);
+            file->file_record->counters[STDIO_SEEKS] += 1;
+        STDIO_UNLOCK();
+    return(ret);
  * Internal functions for manipulating STDIO module state *
--- a/darshan-runtime/share/ld-opts/darshan-stdio-ld-opts
+++ b/darshan-runtime/share/ld-opts/darshan-stdio-ld-opts
@@ -15,6 +15,7 @@
 --wrap=getw
 --wrap=fgets
 --wrap=fseek
+--wrap=fseeko
 --wrap=fprintf
 --wrap=vfprintf
 --wrap=fputc
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/9697f0995ecd71ab6de1dcd8e5c8585e9a5396ce
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20160523/5d10aae7/attachment-0001.html>
More information about the Darshan-commits mailing list
