[Darshan-commits] [Git][darshan/darshan][dev-stdio] putc wrapper
Philip Carns xgitlab at cels.anl.gov
Mon May 23 21:58:04 CDT 2016
Philip Carns pushed to branch dev-stdio at darshan / darshan
Commits:
d094097c by Phil Carns at 2016-05-23T22:57:57-04:00
putc wrapper
2 changed files:
- darshan-runtime/lib/darshan-stdio.c
- darshan-runtime/share/ld-opts/darshan-stdio-ld-opts
Changes:
--- a/darshan-runtime/lib/darshan-stdio.c
+++ b/darshan-runtime/lib/darshan-stdio.c
@@ -52,7 +52,7 @@
  * int      fputc(int, FILE *);                             DONE
  * int      fputs(const char *, FILE *);                    DONE
  * size_t   fwrite(const void *, size_t, size_t, FILE *);   DONE
- * int      putc(int, FILE *);
+ * int      putc(int, FILE *);                              DONE
  * int      putw(int, FILE *);
  * functions for changing file position
@@ -110,6 +110,7 @@ DARSHAN_FORWARD_DECL(fread, size_t, (void *ptr, size_t size, size_t nmemb, FILE
 DARSHAN_FORWARD_DECL(fgetc, int, (FILE *stream));
 DARSHAN_FORWARD_DECL(getw, int, (FILE *stream));
 DARSHAN_FORWARD_DECL(_IO_getc, int, (FILE *stream));
+DARSHAN_FORWARD_DECL(_IO_putc, int, (int, FILE *stream));
 DARSHAN_FORWARD_DECL(fscanf, int, (FILE *stream, const char *format, ...));
 DARSHAN_FORWARD_DECL(vfscanf, int, (FILE *stream, const char *format, va_list ap));
 DARSHAN_FORWARD_DECL(fgets, char*, (char *s, int size, FILE *stream));
@@ -577,6 +578,26 @@ size_t DARSHAN_DECL(_IO_getc)(FILE *stream)
     return(ret);
+/* NOTE: stdio.h typically implements putc() as a macro pointing to _IO_putc */
+size_t DARSHAN_DECL(_IO_putc)(int c, FILE *stream)
+    int ret;
+    double tm1, tm2;
+    MAP_OR_FAIL(_IO_putc);
+    tm1 = darshan_core_wtime();
+    ret = __real__IO_putc(c, stream);
+    tm2 = darshan_core_wtime();
+    STDIO_LOCK();
+    stdio_runtime_initialize();
+    if(ret != EOF)
+        STDIO_RECORD_WRITE(stream, 1, tm1, tm2, 0);
+    STDIO_UNLOCK();
+    return(ret);
 size_t DARSHAN_DECL(getw)(FILE *stream)
     int ret;
--- a/darshan-runtime/share/ld-opts/darshan-stdio-ld-opts
+++ b/darshan-runtime/share/ld-opts/darshan-stdio-ld-opts
@@ -11,6 +11,7 @@
 --wrap=fscanf
 --wrap=vfscanf
 --wrap=_IO_getc
+--wrap=_IO_putc
 --wrap=getw
 --wrap=fgets
 --wrap=fseek
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/d094097c466abf23043e0ac7f37223a8fed2c1de
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20160523/3364bb33/attachment.html>
More information about the Darshan-commits mailing list
