[Darshan-commits] [Git][darshan/darshan][dev-stdio] fscanf and vfscanf wrappers
Philip Carns
xgitlab at cels.anl.gov
Mon May 23 20:14:02 CDT 2016
Philip Carns pushed to branch dev-stdio at darshan / darshan
Commits:
9e6663d9 by Phil Carns at 2016-05-23T21:13:46-04:00
- needs testing
2 changed files:
- darshan-runtime/lib/darshan-stdio.c
- darshan-runtime/share/ld-opts/darshan-stdio-ld-opts
Changes:
--- a/darshan-runtime/lib/darshan-stdio.c
+++ b/darshan-runtime/lib/darshan-stdio.c
@@ -16,6 +16,7 @@
* - POSIX_FWRITES
* - POSIX_FSEEKS
* - add regression test cases for all functions captured here
+ * - especially the scanf and printf variants
/* catalog of stdio functions instrumented by this module
@@ -39,7 +40,8 @@
* int fgetc(FILE *); DONE
* char *fgets(char *, int, FILE *); DONE
* size_t fread(void *, size_t, size_t, FILE *); DONE
- * int fscanf(FILE *, const char *, ...);
+ * int fscanf(FILE *, const char *, ...); DONE
+ * int vfscanf(FILE *, const char *, va_list); DONE
* int getc(FILE *);
* int getc_unlocked(FILE *);
* int getw(FILE *);
@@ -100,6 +102,8 @@ DARSHAN_FORWARD_DECL(fflush, int, (FILE *fp));
DARSHAN_FORWARD_DECL(fwrite, size_t, (const void *ptr, size_t size, size_t nmemb, FILE *stream));
DARSHAN_FORWARD_DECL(fread, size_t, (void *ptr, size_t size, size_t nmemb, FILE *stream));
DARSHAN_FORWARD_DECL(fgetc, int, (FILE *stream));
+DARSHAN_FORWARD_DECL(fscanf, int, (FILE *stream, const char *format, ...));
+DARSHAN_FORWARD_DECL(vfscanf, int, (FILE *stream, const char *format, va_list ap));
DARSHAN_FORWARD_DECL(fgets, char*, (char *s, int size, FILE *stream));
DARSHAN_FORWARD_DECL(fseek, int, (FILE *stream, long offset, int whence));
@@ -449,6 +453,59 @@ size_t DARSHAN_DECL(fgetc)(FILE *stream)
return(ret);
+int DARSHAN_DECL(fscanf)(FILE *stream, const char *format, ...)
+ int ret;
+ double tm1, tm2;
+ va_list ap;
+ long start_off, end_off;
+ MAP_OR_FAIL(vfscanf);
+ tm1 = darshan_core_wtime();
+ /* NOTE: we intentionally switch to vfscanf here to handle the variable
+ * length arguments.
+ start_off = ftell(stream);
+ va_start(ap, format);
+ ret = __real_vfscanf(stream, format, ap);
+ va_end(ap);
+ end_off = ftell(stream);
+ tm2 = darshan_core_wtime();
+ STDIO_LOCK();
+ stdio_runtime_initialize();
+ if(ret != 0)
+ STDIO_RECORD_READ(stream, end_off-start_off, tm1, tm2);
+ STDIO_UNLOCK();
+ return(ret);
+int DARSHAN_DECL(vfscanf)(FILE *stream, const char *format, va_list ap)
+ int ret;
+ double tm1, tm2;
+ STDIO_LOCK();
+ if(ret != 0)
+ STDIO_UNLOCK();
+ return(ret);
char* DARSHAN_DECL(fgets)(char *s, int size, FILE *stream)
char *ret;
--- a/darshan-runtime/share/ld-opts/darshan-stdio-ld-opts
+++ b/darshan-runtime/share/ld-opts/darshan-stdio-ld-opts
@@ -8,5 +8,7 @@
--wrap=fwrite
--wrap=fread
--wrap=fgetc
+--wrap=fscanf
+--wrap=vfscanf
--wrap=fgets
--wrap=fseek
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/9e6663d9f1891f63ebf7dda5b7ae5ee3677e9d52
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20160523/3b065259/attachment.html>
More information about the Darshan-commits
