[Darshan-commits] [Git][darshan/darshan][dev-stdio] getc wrapper
Philip Carns
xgitlab at cels.anl.gov
Mon May 23 20:19:01 CDT 2016
Philip Carns pushed to branch dev-stdio at darshan / darshan
Commits:
551c339c by Phil Carns at 2016-05-23T21:18:51-04:00
getc wrapper
2 changed files:
- darshan-runtime/lib/darshan-stdio.c
- darshan-runtime/share/ld-opts/darshan-stdio-ld-opts
Changes:
--- a/darshan-runtime/lib/darshan-stdio.c
+++ b/darshan-runtime/lib/darshan-stdio.c
@@ -42,7 +42,7 @@
* size_t fread(void *, size_t, size_t, FILE *); DONE
* int fscanf(FILE *, const char *, ...); DONE
* int vfscanf(FILE *, const char *, va_list); DONE
- * int getc(FILE *);
+ * int getc(FILE *); DONE
* int getc_unlocked(FILE *);
* int getw(FILE *);
@@ -102,6 +102,7 @@ DARSHAN_FORWARD_DECL(fflush, int, (FILE *fp));
DARSHAN_FORWARD_DECL(fwrite, size_t, (const void *ptr, size_t size, size_t nmemb, FILE *stream));
DARSHAN_FORWARD_DECL(fread, size_t, (void *ptr, size_t size, size_t nmemb, FILE *stream));
DARSHAN_FORWARD_DECL(fgetc, int, (FILE *stream));
+DARSHAN_FORWARD_DECL(_IO_getc, int, (FILE *stream));
DARSHAN_FORWARD_DECL(fscanf, int, (FILE *stream, const char *format, ...));
DARSHAN_FORWARD_DECL(vfscanf, int, (FILE *stream, const char *format, va_list ap));
DARSHAN_FORWARD_DECL(fgets, char*, (char *s, int size, FILE *stream));
@@ -453,6 +454,27 @@ size_t DARSHAN_DECL(fgetc)(FILE *stream)
return(ret);
+/* NOTE: stdio.h typically implements getc() as a macro pointing to _IO_getc */
+size_t DARSHAN_DECL(_IO_getc)(FILE *stream)
+ int ret;
+ double tm1, tm2;
+ MAP_OR_FAIL(_IO_getc);
+ tm1 = darshan_core_wtime();
+ ret = __real__IO_getc(stream);
+ tm2 = darshan_core_wtime();
+ STDIO_LOCK();
+ stdio_runtime_initialize();
+ if(ret != EOF)
+ STDIO_RECORD_READ(stream, 1, tm1, tm2);
+ STDIO_UNLOCK();
+ return(ret);
int DARSHAN_DECL(fscanf)(FILE *stream, const char *format, ...)
int ret;
--- a/darshan-runtime/share/ld-opts/darshan-stdio-ld-opts
+++ b/darshan-runtime/share/ld-opts/darshan-stdio-ld-opts
@@ -10,5 +10,6 @@
--wrap=fgetc
--wrap=fscanf
--wrap=vfscanf
+--wrap=_IO_getc
--wrap=fgets
--wrap=fseek
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/551c339c02254cdd99b2ef5b720c7da1b58fed13
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20160523/1d2d7f77/attachment.html>
More information about the Darshan-commits
