[Darshan-commits] [Git][darshan/darshan][dev-stdio] fgets wrapper
Philip Carns
xgitlab at cels.anl.gov
Mon May 23 19:57:19 CDT 2016
Philip Carns pushed to branch dev-stdio at darshan / darshan
Commits:
da08451f by Phil Carns at 2016-05-23T20:57:07-04:00
fgets wrapper
2 changed files:
- darshan-runtime/lib/darshan-stdio.c
- darshan-runtime/share/ld-opts/darshan-stdio-ld-opts
Changes:
--- a/darshan-runtime/lib/darshan-stdio.c
+++ b/darshan-runtime/lib/darshan-stdio.c
@@ -37,7 +37,7 @@
* functions for reading data
* int fgetc(FILE *); DONE
- * char *fgets(char *, int, FILE *);
+ * char *fgets(char *, int, FILE *); DONE
* size_t fread(void *, size_t, size_t, FILE *); DONE
* int fscanf(FILE *, const char *, ...);
* int getc(FILE *);
@@ -100,6 +100,7 @@ DARSHAN_FORWARD_DECL(fflush, int, (FILE *fp));
DARSHAN_FORWARD_DECL(fwrite, size_t, (const void *ptr, size_t size, size_t nmemb, FILE *stream));
DARSHAN_FORWARD_DECL(fread, size_t, (void *ptr, size_t size, size_t nmemb, FILE *stream));
DARSHAN_FORWARD_DECL(fgetc, int, (FILE *stream));
+DARSHAN_FORWARD_DECL(fgets, char*, (char *s, int size, FILE *stream));
DARSHAN_FORWARD_DECL(fseek, int, (FILE *stream, long offset, int whence));
/* The stdio_file_runtime structure maintains necessary runtime metadata
@@ -448,6 +449,27 @@ size_t DARSHAN_DECL(fgetc)(FILE *stream)
return(ret);
+char* DARSHAN_DECL(fgets)(char *s, int size, FILE *stream)
+ char *ret;
+ double tm1, tm2;
+ MAP_OR_FAIL(fgets);
+ tm1 = darshan_core_wtime();
+ ret = __real_fgets(s, size, stream);
+ tm2 = darshan_core_wtime();
+ STDIO_LOCK();
+ stdio_runtime_initialize();
+ if(ret != NULL)
+ STDIO_RECORD_READ(stream, strlen(ret), tm1, tm2);
+ STDIO_UNLOCK();
+ return(ret);
int DARSHAN_DECL(fseek)(FILE *stream, long offset, int whence)
int ret;
--- a/darshan-runtime/share/ld-opts/darshan-stdio-ld-opts
+++ b/darshan-runtime/share/ld-opts/darshan-stdio-ld-opts
@@ -8,4 +8,5 @@
--wrap=fwrite
--wrap=fread
--wrap=fgetc
+--wrap=fgets
--wrap=fseek
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/da08451f6e8310935194656dd7bad3a43c93a272
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20160523/2ed28711/attachment.html>
More information about the Darshan-commits
