[Darshan-commits] [Git][darshan/darshan][dev-stdio] fgetc wrapper
Philip Carns
xgitlab at cels.anl.gov
Mon May 23 19:53:27 CDT 2016
Philip Carns pushed to branch dev-stdio at darshan / darshan
Commits:
4cdf8a06 by Phil Carns at 2016-05-23T20:53:18-04:00
fgetc wrapper
2 changed files:
- darshan-runtime/lib/darshan-stdio.c
- darshan-runtime/share/ld-opts/darshan-stdio-ld-opts
Changes:
--- a/darshan-runtime/lib/darshan-stdio.c
+++ b/darshan-runtime/lib/darshan-stdio.c
@@ -36,7 +36,7 @@
* functions for reading data
- * int fgetc(FILE *);
+ * int fgetc(FILE *); DONE
* char *fgets(char *, int, FILE *);
* size_t fread(void *, size_t, size_t, FILE *); DONE
* int fscanf(FILE *, const char *, ...);
@@ -99,6 +99,7 @@ DARSHAN_FORWARD_DECL(fclose, int, (FILE *fp));
DARSHAN_FORWARD_DECL(fflush, int, (FILE *fp));
DARSHAN_FORWARD_DECL(fwrite, size_t, (const void *ptr, size_t size, size_t nmemb, FILE *stream));
DARSHAN_FORWARD_DECL(fread, size_t, (void *ptr, size_t size, size_t nmemb, FILE *stream));
+DARSHAN_FORWARD_DECL(fgetc, int, (FILE *stream));
DARSHAN_FORWARD_DECL(fseek, int, (FILE *stream, long offset, int whence));
/* The stdio_file_runtime structure maintains necessary runtime metadata
@@ -427,6 +428,26 @@ size_t DARSHAN_DECL(fread)(void *ptr, size_t size, size_t nmemb, FILE *stream)
return(ret);
+size_t DARSHAN_DECL(fgetc)(FILE *stream)
+ int ret;
+ double tm1, tm2;
+ MAP_OR_FAIL(fgetc);
+ tm1 = darshan_core_wtime();
+ ret = __real_fgetc(stream);
+ tm2 = darshan_core_wtime();
+ STDIO_LOCK();
+ stdio_runtime_initialize();
+ if(ret != EOF)
+ STDIO_RECORD_READ(stream, 1, tm1, tm2);
+ STDIO_UNLOCK();
+ return(ret);
int DARSHAN_DECL(fseek)(FILE *stream, long offset, int whence)
int ret;
--- a/darshan-runtime/share/ld-opts/darshan-stdio-ld-opts
+++ b/darshan-runtime/share/ld-opts/darshan-stdio-ld-opts
@@ -7,4 +7,5 @@
--wrap=fclose
--wrap=fwrite
--wrap=fread
+--wrap=fgetc
--wrap=fseek
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/4cdf8a06da2dc6bbaf4b19045d77f698ed972cff
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20160523/b7dac439/attachment-0001.html>
More information about the Darshan-commits
