[Darshan-commits] [Git][darshan/darshan][dev-stdio] fflush wrapper
Philip Carns
xgitlab at cels.anl.gov
Mon May 23 19:50:12 CDT 2016
Philip Carns pushed to branch dev-stdio at darshan / darshan
Commits:
9781671b by Phil Carns at 2016-05-23T20:50:05-04:00
fflush wrapper
4 changed files:
- darshan-runtime/lib/darshan-stdio.c
- darshan-runtime/share/ld-opts/darshan-stdio-ld-opts
- darshan-stdio-log-format.h
- darshan-util/darshan-stdio-logutils.c
Changes:
--- a/darshan-runtime/lib/darshan-stdio.c
+++ b/darshan-runtime/lib/darshan-stdio.c
@@ -32,7 +32,7 @@
* functions for flushing streams
- * int fflush(FILE *);
+ * int fflush(FILE *); DONE
* functions for reading data
@@ -96,6 +96,7 @@ DARSHAN_FORWARD_DECL(fopen64, FILE*, (const char *path, const char *mode));
DARSHAN_FORWARD_DECL(fdopen, FILE*, (int fd, const char *mode));
DARSHAN_FORWARD_DECL(freopen, FILE*, (const char *path, const char *mode, FILE *stream));
DARSHAN_FORWARD_DECL(fclose, int, (FILE *fp));
+DARSHAN_FORWARD_DECL(fflush, int, (FILE *fp));
DARSHAN_FORWARD_DECL(fwrite, size_t, (const void *ptr, size_t size, size_t nmemb, FILE *stream));
DARSHAN_FORWARD_DECL(fread, size_t, (void *ptr, size_t size, size_t nmemb, FILE *stream));
DARSHAN_FORWARD_DECL(fseek, int, (FILE *stream, long offset, int whence));
@@ -238,7 +239,7 @@ static void stdio_shutdown(void);
DARSHAN_TIMER_INC_NO_OVERLAP(file->file_record->fcounters[STDIO_F_READ_TIME], __tm1, __tm2, file->last_write_end); \
} while(0)
-#define STDIO_RECORD_WRITE(__fp, __bytes, __tm1, __tm2) do{ \
+#define STDIO_RECORD_WRITE(__fp, __bytes, __tm1, __tm2, __fflush_flag) do{ \
int64_t this_offset; \
struct stdio_file_runtime* file; \
file = stdio_file_by_stream(__fp); \
@@ -248,7 +249,10 @@ static void stdio_shutdown(void);
if(file->file_record->counters[STDIO_MAX_BYTE_WRITTEN] < (this_offset + __bytes - 1)) \
file->file_record->counters[STDIO_MAX_BYTE_WRITTEN] = (this_offset + __bytes - 1); \
file->file_record->counters[STDIO_BYTES_WRITTEN] += __bytes; \
- file->file_record->counters[STDIO_WRITES] += 1; \
+ if(__fflush_flag) \
+ file->file_record->counters[STDIO_FLUSHES] += 1; \
+ else \
+ file->file_record->counters[STDIO_WRITES] += 1; \
if(file->file_record->fcounters[STDIO_F_WRITE_START_TIMESTAMP] == 0 || \
file->file_record->fcounters[STDIO_F_WRITE_START_TIMESTAMP] > __tm1) \
file->file_record->fcounters[STDIO_F_WRITE_START_TIMESTAMP] = __tm1; \
@@ -332,6 +336,26 @@ FILE* DARSHAN_DECL(freopen)(const char *path, const char *mode, FILE *stream)
return(ret);
+int DARSHAN_DECL(fflush)(FILE *fp)
+ double tm1, tm2;
+ int ret;
+ MAP_OR_FAIL(fflush);
+ tm1 = darshan_core_wtime();
+ ret = __real_fflush(fp);
+ tm2 = darshan_core_wtime();
+ STDIO_LOCK();
+ stdio_runtime_initialize();
+ if(ret >= 0)
+ STDIO_RECORD_WRITE(fp, 0, tm1, tm2, 1);
+ STDIO_UNLOCK();
+ return(ret);
int DARSHAN_DECL(fclose)(FILE *fp)
@@ -377,7 +401,7 @@ size_t DARSHAN_DECL(fwrite)(const void *ptr, size_t size, size_t nmemb, FILE *st
STDIO_LOCK();
if(ret > 0)
- STDIO_RECORD_WRITE(stream, size*ret, tm1, tm2);
+ STDIO_RECORD_WRITE(stream, size*ret, tm1, tm2, 0);
STDIO_UNLOCK();
return(ret);
--- a/darshan-runtime/share/ld-opts/darshan-stdio-ld-opts
+++ b/darshan-runtime/share/ld-opts/darshan-stdio-ld-opts
@@ -3,6 +3,7 @@
--wrap=fopen64
--wrap=fdopen
--wrap=freopen
+--wrap=fflush
--wrap=fclose
--wrap=fwrite
--wrap=fread
--- a/darshan-stdio-log-format.h
+++ b/darshan-stdio-log-format.h
@@ -27,6 +27,8 @@
X(STDIO_READS) \
/* count of seeks */\
X(STDIO_SEEKS) \
+ /* count of flushes */\
+ X(STDIO_FLUSHES) \
/* end of counters */\
X(STDIO_NUM_INDICES)
--- a/darshan-util/darshan-stdio-logutils.c
+++ b/darshan-util/darshan-stdio-logutils.c
@@ -143,7 +143,7 @@ static void darshan_log_print_stdio_record(void *file_rec, char *file_name,
static void darshan_log_print_stdio_description()
printf("\n# description of STDIO counters:\n");
- printf("# STDIO_{OPENS|WRITES|READS|SEEKS} are types of operations.\n");
+ printf("# STDIO_{OPENS|WRITES|READS|SEEKS|FLUSHES} are types of operations.\n");
printf("# STDIO_BYTES_*: total bytes read and written.\n");
printf("# STDIO_MAX_BYTE_*: highest offset byte read and written.\n");
printf("# STDIO_F_*_START_TIMESTAMP: timestamp of the first call to that type of function.\n");
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/9781671bd804abde8a89f0d3dbedb8950092b8c1
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20160523/6b0b82d9/attachment.html>
More information about the Darshan-commits
