[Darshan-commits] [Git][darshan/darshan][dev-stdio] 2 commits: fdopen wrapper
Philip Carns
xgitlab at cels.anl.gov
Mon May 23 19:42:08 CDT 2016
Philip Carns pushed to branch dev-stdio at darshan / darshan
Commits:
9930d72a by Phil Carns at 2016-05-23T20:38:32-04:00
fdopen wrapper
e025a97f by Phil Carns at 2016-05-23T20:42:01-04:00
freopen wrapper
2 changed files:
- darshan-runtime/lib/darshan-stdio.c
- darshan-runtime/share/ld-opts/darshan-stdio-ld-opts
Changes:
--- a/darshan-runtime/lib/darshan-stdio.c
+++ b/darshan-runtime/lib/darshan-stdio.c
@@ -15,6 +15,7 @@
* - POSIX_FREADS
* - POSIX_FWRITES
* - POSIX_FSEEKS
+ * - add regression test cases for all functions captured here
/* catalog of stdio functions instrumented by this module
@@ -22,8 +23,8 @@
* functions for opening streams
* FILE *fdopen(int, const char *); DONE
- * FILE *fopen(const char *, const char *);
- * FILE *freopen(const char *, const char *, FILE *);
+ * FILE *fopen(const char *, const char *); DONE
+ * FILE *freopen(const char *, const char *, FILE *); DONE
* functions for closing streams
@@ -92,6 +93,8 @@
DARSHAN_FORWARD_DECL(fopen, FILE*, (const char *path, const char *mode));
DARSHAN_FORWARD_DECL(fopen64, FILE*, (const char *path, const char *mode));
+DARSHAN_FORWARD_DECL(fdopen, FILE*, (int fd, const char *mode));
+DARSHAN_FORWARD_DECL(freopen, FILE*, (const char *path, const char *mode, FILE *stream));
DARSHAN_FORWARD_DECL(fclose, int, (FILE *fp));
DARSHAN_FORWARD_DECL(fwrite, size_t, (const void *ptr, size_t size, size_t nmemb, FILE *stream));
DARSHAN_FORWARD_DECL(fread, size_t, (void *ptr, size_t size, size_t nmemb, FILE *stream));
@@ -291,6 +294,44 @@ FILE* DARSHAN_DECL(fopen64)(const char *path, const char *mode)
return(ret);
+FILE* DARSHAN_DECL(fdopen)(int fd, const char *mode)
+ FILE* ret;
+ double tm1, tm2;
+ MAP_OR_FAIL(fdopen);
+ tm1 = darshan_core_wtime();
+ ret = __real_fdopen(fd, mode);
+ tm2 = darshan_core_wtime();
+ STDIO_LOCK();
+ stdio_runtime_initialize();
+ STDIO_RECORD_OPEN(ret, "UNKNOWN-FDOPEN", tm1, tm2);
+ STDIO_UNLOCK();
+ return(ret);
+FILE* DARSHAN_DECL(freopen)(const char *path, const char *mode, FILE *stream)
+ FILE* ret;
+ double tm1, tm2;
+ MAP_OR_FAIL(freopen);
+ ret = __real_freopen(path, mode, stream);
+ STDIO_LOCK();
+ STDIO_RECORD_OPEN(ret, path, tm1, tm2);
+ STDIO_UNLOCK();
+ return(ret);
int DARSHAN_DECL(fclose)(FILE *fp)
struct stdio_file_runtime* file;
--- a/darshan-runtime/share/ld-opts/darshan-stdio-ld-opts
+++ b/darshan-runtime/share/ld-opts/darshan-stdio-ld-opts
@@ -1,6 +1,8 @@
--undefined=__wrap_fopen
--wrap=fopen
--wrap=fopen64
+--wrap=fdopen
+--wrap=freopen
--wrap=fclose
--wrap=fwrite
--wrap=fread
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/compare/11c80b443cafe3486518ae37b944470ef27a238a...e025a97f1a3ecae760b265992356b3977199ec67
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20160523/ef995484/attachment.html>
More information about the Darshan-commits
