[Darshan-commits] [Git][darshan/darshan][mmap-dev] darshan-core code and documentation cleanup
Shane Snyder
xgitlab at cels.anl.gov
Wed Jun 8 17:04:20 CDT 2016
Shane Snyder pushed to branch mmap-dev at darshan / darshan
Commits:
d8f3575a by Shane Snyder at 2016-06-08T16:58:23-05:00
Cleanup the structure and documenation of the code to be in sync
with the new mmap version of Darshan. In particular, I made sure
all extra mmap logic was properly ifdef wrapped so it's more clear
which portions of the code are responsible for implementing that
feature.
3 changed files:
- darshan-runtime/darshan-core.h
- darshan-runtime/darshan.h
- darshan-runtime/lib/darshan-core.c
Changes:
--- a/darshan-runtime/darshan-core.h
+++ b/darshan-runtime/darshan-core.h
@@ -58,6 +58,7 @@ struct darshan_core_module
struct darshan_module_funcs funcs;
+/* strucutre for keeping a reference to registered name records */
struct darshan_core_name_record_ref
struct darshan_name_record *name_record;
@@ -80,6 +81,7 @@ struct darshan_core_runtime
struct darshan_core_module* mod_array[DARSHAN_MAX_MODS];
int mod_mem_used;
struct darshan_core_name_record_ref *name_hash;
+ int name_mem_used;
double wtime_offset;
char *comp_buf;
#ifdef __DARSHAN_ENABLE_MMAP_LOGS
--- a/darshan-runtime/darshan.h
+++ b/darshan-runtime/darshan.h
@@ -92,11 +92,14 @@ struct darshan_module_funcs
* Register module identifier 'mod_id' with the darshan-core runtime
* environment, allowing the module to store I/O characterization data.
* 'funcs' is a pointer to a structure containing each of the function
- * pointers required by darshan-core to shut down the module. The function
- * returns the following integers passed in as pointers: 'rank' is the
- * MPI rank of the calling process, 'mod_mem_limit' is the maximum amount
- * of memory the module may use, and 'sys_mem_alignment' is the configured
- * memory alignment value Darshan was configured with.
+ * pointers required by darshan-core to shut down the module.
+ * 'inout_mod_buf_size' is an input/output argument, with it being
+ * set to the requested amount of module memory on input, and set to
+ * the amount allocated by darshan-core on output. If given, 'rank' is
+ * a pointer to an integer which will contain the calling process's
+ * MPI rank on return. If given, 'sys_mem_alignment' is a pointer to
+ * an integer which will contain the memory alignment value Darshan
+ * was configured with on return.
void darshan_core_register_module(
darshan_module_id mod_id,
@@ -115,7 +118,7 @@ void darshan_core_unregister_module(
/* darshan_core_gen_record_id()
+ * Returns the Darshan record ID correpsonding to input string 'name'.
darshan_record_id darshan_core_gen_record_id(
const char *name);
@@ -124,15 +127,14 @@ darshan_record_id darshan_core_gen_record_id(
* Register a record with the darshan-core runtime, allowing it to be
* properly tracked and (potentially) correlated with records from other
- * modules. 'name' is the the name of the Darshan record (e.g., the full
- * file path) and 'len' is the size of the name pointer (string length
- * for string names). 'mod_id' is the identifier of the calling module,
- * 'printable_flag' indicates whether the name is a string, and
- * 'mod_limit_flag' is set if the calling module is out of memory (to
- * prevent darshan-core from creating new records and to just search
- * through existing records). 'rec_id' is an output pointer storing the
- * correspoing Darshan record identifier and 'file_alignment' is an output
- * pointer storing the file system alignment value for the given record.
+ * modules. 'rec_id' is the Darshan record id as given by the
+ * `darshan_core_gen_record_id` function. 'name' is the the name of the
+ * Darshan record (e.g., the full file path), which for now is just a
+ * string. 'mod_id' is the identifier of the calling module. 'rec_len'
+ * is the size of the record being registered with Darshan. If given,
+ * 'file_alignment' is a pointer to an integer which on return will
+ * contain the corresponding file system alignment of the file system
+ * path 'name' resides on.
void *darshan_core_register_record(
darshan_record_id rec_id,
@@ -150,8 +152,8 @@ double darshan_core_wtime(void);
/* darshan_core_excluded_path()
- * Returns true (1) if the given file path is in Darshan's list of
- * excluded file paths, false (0) otherwise.
+ * Returns true (1) if the given file path 'path' is in Darshan's
+ * list of excluded file paths, false (0) otherwise.
int darshan_core_excluded_path(
const char * path);
--- a/darshan-runtime/lib/darshan-core.c
+++ b/darshan-runtime/lib/darshan-core.c
@@ -41,6 +41,7 @@ static pthread_mutex_t darshan_core_mutex = PTHREAD_RECURSIVE_MUTEX_INITIALIZER_
static int my_rank = -1;
static int nprocs = -1;
static int darshan_mem_alignment = 1;
+static long darshan_mod_mem_quota = DARSHAN_MOD_MEM_MAX;
/* paths prefixed with the following directories are not traced by darshan */
char* darshan_path_exclusions[] = {
@@ -89,11 +90,13 @@ static struct mnt_data mnt_data_array[DARSHAN_MAX_MNTS];
static int mnt_data_count = 0;
/* prototypes for internal helper functions */
+static void *darshan_init_mmap_log(
+ struct darshan_core_runtime* core, int jobid);
static void darshan_log_record_hints_and_ver(
struct darshan_core_runtime* core);
static void darshan_get_exe_and_mounts(
struct darshan_core_runtime *core, int argc, char **argv);
-static void darshan_add_name_record_ref(
+static int darshan_add_name_record_ref(
struct darshan_core_runtime *core, darshan_record_id rec_id,
const char *name, darshan_module_id mod_id);
static int darshan_block_size_from_path(
@@ -132,13 +135,6 @@ void darshan_core_initialize(int argc, char **argv)
int ret;
int tmpval;
int i;
-#ifdef __DARSHAN_ENABLE_MMAP_LOGS
- int mmap_fd;
- int mmap_size;
- int sys_page_size;
- char cuser[L_cuserid] = {0};
- char *mmap_log_dir;
-#endif
DARSHAN_MPI_CALL(PMPI_Comm_size)(MPI_COMM_WORLD, &nprocs);
DARSHAN_MPI_CALL(PMPI_Comm_rank)(MPI_COMM_WORLD, &my_rank);
@@ -203,13 +199,15 @@ void darshan_core_initialize(int argc, char **argv)
memset(init_core, 0, sizeof(*init_core));
init_core->wtime_offset = DARSHAN_MPI_CALL(PMPI_Wtime)();
+ /* TODO: do we alloc new memory as we go or just do everything up front? */
#ifndef __DARSHAN_ENABLE_MMAP_LOGS
/* just allocate memory for each log file region */
init_core->log_hdr_p = malloc(sizeof(struct darshan_header));
init_core->log_job_p = malloc(sizeof(struct darshan_job));
init_core->log_exemnt_p = malloc(DARSHAN_EXE_LEN+1);
init_core->log_name_p = malloc(DARSHAN_NAME_RECORD_BUF_SIZE);
- init_core->log_mod_p = malloc(DARSHAN_MOD_MEM_MAX);
+ init_core->log_mod_p = malloc(darshan_mod_mem_quota);
if(!(init_core->log_hdr_p) || !(init_core->log_job_p) ||
!(init_core->log_exemnt_p) || !(init_core->log_name_p) ||
@@ -223,75 +221,18 @@ void darshan_core_initialize(int argc, char **argv)
memset(init_core->log_job_p, 0, sizeof(struct darshan_job));
memset(init_core->log_exemnt_p, 0, DARSHAN_EXE_LEN+1);
memset(init_core->log_name_p, 0, DARSHAN_NAME_RECORD_BUF_SIZE);
- memset(init_core->log_mod_p, 0, DARSHAN_MOD_MEM_MAX);
+ memset(init_core->log_mod_p, 0, darshan_mod_mem_quota);
#else
/* if mmap logs are enabled, we need to initialize the mmap region
* before setting the corresponding log file region pointers
- sys_page_size = sysconf(_SC_PAGESIZE);
- assert(sys_page_size > 0);
- mmap_size = sizeof(struct darshan_header) + DARSHAN_JOB_RECORD_SIZE +
- + DARSHAN_NAME_RECORD_BUF_SIZE + DARSHAN_MOD_MEM_MAX;
- if(mmap_size % sys_page_size)
- mmap_size = ((mmap_size / sys_page_size) + 1) * sys_page_size;
- envstr = getenv(DARSHAN_MMAP_LOG_PATH_OVERRIDE);
- if(envstr)
- mmap_log_dir = envstr;
- else
- mmap_log_dir = DARSHAN_DEF_MMAP_LOG_PATH;
- darshan_get_user_name(cuser);
- /* construct a unique temporary log file name for this process
- * to write mmap log data to
- snprintf(init_core->mmap_log_name, PATH_MAX,
- "/%s/%s_%s_id%d_mmap-log-%d.darshan",
- mmap_log_dir, cuser, __progname, jobid, my_rank);
- /* create the temporary mmapped darshan log */
- mmap_fd = open(init_core->mmap_log_name, O_CREAT|O_RDWR|O_EXCL , 0644);
- if(mmap_fd < 0)
- fprintf(stderr, "darshan library warning: "
- "unable to create darshan log file %s\n", init_core->mmap_log_name);
- free(init_core);
- return;
- /* TODO: what's more expensive? truncate or write zeros? perf test this call and later accesses */
- /* allocate the necessary space in the log file */
- ret = ftruncate(mmap_fd, mmap_size);
- if(ret < 0)
- "unable to allocate darshan log file %s\n", init_core->mmap_log_name);
- free(init_core);
- close(mmap_fd);
- unlink(init_core->mmap_log_name);
- return;
- /* memory map buffers for getting at least some summary i/o data
- * into a log file if darshan does not shut down properly
- void *mmap_p = mmap(NULL, mmap_size, PROT_WRITE, MAP_SHARED, mmap_fd, 0);
- if(mmap_p == MAP_FAILED)
+ void *mmap_p = darshan_init_mmap_log(init_core, jobid);
+ if(!mmap_p)
- "unable to mmap darshan log file %s\n", init_core->mmap_log_name);
free(init_core);
- close(mmap_fd);
return;
- /* close darshan log file (this does *not* unmap the log file) */
- close(mmap_fd);
/* set the memory pointers for each log file region */
init_core->log_hdr_p = (struct darshan_header *)mmap_p;
init_core->log_job_p = (struct darshan_job *)
@@ -306,7 +247,7 @@ void darshan_core_initialize(int argc, char **argv)
/* set header fields needed for the mmap log mechanism */
init_core->log_hdr_p->comp_type = DARSHAN_NO_COMP;
init_core->log_hdr_p->name_map.off =
- sizeof(struct darshan_header) + DARSHAN_JOB_RECORD_SIZE;
+ ((char *)init_core->log_name_p - (char *)init_core->log_hdr_p);
#endif
/* set known header fields for the log file */
@@ -339,10 +280,6 @@ void darshan_core_initialize(int argc, char **argv)
- /* reduce so all ranks agree on the job start time */
- DARSHAN_MPI_CALL(PMPI_Allreduce)(MPI_IN_PLACE, &init_core->log_job_p->start_time,
- 1, MPI_INT64_T, MPI_MIN, MPI_COMM_WORLD);
if(internal_timing_flag)
init_time = DARSHAN_MPI_CALL(PMPI_Wtime)() - init_start;
@@ -361,11 +298,10 @@ void darshan_core_initialize(int argc, char **argv)
void darshan_core_shutdown()
struct darshan_core_runtime *final_core;
- struct darshan_header out_header;
- struct darshan_job out_job;
int internal_timing_flag = 0;
struct tm *start_tm;
time_t start_time_tmp;
+ int64_t first_start_time;
int64_t last_end_time;
double start_log_time;
double tm_end;
@@ -404,40 +340,27 @@ void darshan_core_shutdown()
darshan_core = NULL;
DARSHAN_CORE_UNLOCK();
- memcpy(&out_job, final_core->log_job_p, sizeof(struct darshan_job));
- /* TODO: can we get rid of out_ header and job?? */
- /* XXX just copy mmap files somewhere else to avoid corruption */
- DARSHAN_MPI_CALL(PMPI_Barrier)(MPI_COMM_WORLD);
- char cp_cmd[500] = {0};
- sprintf(cp_cmd, "cp %s ~/Desktop", final_core->mmap_log_name);
- system(cp_cmd);
- /* indicate in the metadata field of the temporary darshan log file that
- * the darshan shutdown process was invoked on the data in the log. since
- * we have no way of knowing how far the shutdown process got, the data
- * could potentially be in inconsistent or corrupt state. in this case,
- * darshan currently does not generate a log file at all.
+ /* remove the temporary mmap log files */
+ /* NOTE: this unlink is not immediate as it must wait for the mapping
+ * to no longer be referenced, which in our case happens when the
+ * executable exits. If the application terminates mid-shutdown, then
+ * there will be no mmap files and no final log file.
- char *m = final_core->log_job_p->metadata + strlen(final_core->log_job_p->metadata);
- int meta_remain = DARSHAN_JOB_METADATA_LEN - strlen(final_core->log_job_p->metadata) - 1;
- /* TODO: do we ever check for darshan_shutdown? */
- snprintf(m, meta_remain, "darshan_shutdown=yes\n");
+ unlink(final_core->mmap_log_name);
#endif
- /* we also need to set which modules were registered on this process and
- * call into those modules and give them a chance to perform any necessary
- * pre-shutdown steps.
- for(i = 0; i < DARSHAN_MAX_MODS; i++)
+ final_core->log_job_p->end_time = time(NULL);
+ /* reduce to report first start and last end time across all ranks at rank 0 */
+ DARSHAN_MPI_CALL(PMPI_Reduce)(&final_core->log_job_p->start_time, &first_start_time,
+ 1, MPI_INT64_T, MPI_MIN, 0, MPI_COMM_WORLD);
+ DARSHAN_MPI_CALL(PMPI_Reduce)(&final_core->log_job_p->end_time, &last_end_time,
+ 1, MPI_INT64_T, MPI_MAX, 0, MPI_COMM_WORLD);
+ if(my_rank == 0)
- if(final_core->mod_array[i])
- local_mod_use[i] = 1;
- final_core->mod_array[i]->funcs.begin_shutdown();
+ final_core->log_job_p->start_time = first_start_time;
+ final_core->log_job_p->end_time = last_end_time;
final_core->comp_buf = malloc(DARSHAN_COMP_BUF_SIZE);
@@ -476,14 +399,17 @@ void darshan_core_shutdown()
return;
- final_core->log_job_p->end_time = time(NULL);
- /* reduce to report last end time across all ranks at rank 0 */
- DARSHAN_MPI_CALL(PMPI_Reduce)(&final_core->log_job_p->end_time, &last_end_time,
- 1, MPI_INT64_T, MPI_MAX, 0, MPI_COMM_WORLD);
- if(my_rank == 0)
+ /* set which modules were registered locally, and call into
+ * them to disable further instrumentation and to perform any
+ * other pre-shutdown steps
+ for(i = 0; i < DARSHAN_MAX_MODS; i++)
- out_job.end_time = last_end_time;
+ if(final_core->mod_array[i])
+ local_mod_use[i] = 1;
+ final_core->mod_array[i]->funcs.begin_shutdown();
/* reduce the number of times a module was opened globally and bcast to everyone */
@@ -520,7 +446,7 @@ void darshan_core_shutdown()
/* rank 0 is responsible for writing the compressed darshan job information */
if(my_rank == 0)
- void *pointers[2] = {&out_job, final_core->log_exemnt_p};
+ void *pointers[2] = {final_core->log_job_p, final_core->log_exemnt_p};
int lengths[2] = {sizeof(struct darshan_job), strlen(final_core->log_exemnt_p)};
int comp_buf_sz = 0;
@@ -564,11 +490,11 @@ void darshan_core_shutdown()
rec1 = DARSHAN_MPI_CALL(PMPI_Wtime)();
/* write the record name->id hash to the log file */
- out_header.name_map.off = gz_fp;
+ final_core->log_hdr_p->name_map.off = gz_fp;
ret = darshan_log_write_name_record_hash(log_fh, final_core, &gz_fp);
- out_header.name_map.len = gz_fp - out_header.name_map.off;
+ final_core->log_hdr_p->name_map.len = gz_fp - final_core->log_hdr_p->name_map.off;
- /* error out if unable to write record hash */
+ /* error out if unable to write the name record hash */
DARSHAN_MPI_CALL(PMPI_Allreduce)(&ret, &all_ret, 1, MPI_INT,
MPI_LOR, MPI_COMM_WORLD);
if(all_ret != 0)
@@ -591,11 +517,10 @@ void darshan_core_shutdown()
assert(mod_shared_recs);
/* loop over globally used darshan modules and:
- * - perform shared file reductions, if possible
* - get final output buffer
* - compress (zlib) provided output buffer
* - append compressed buffer to log file
- * - add module index info (file offset/length) to log header
+ * - add module map info (file offset/length) to log header
* - shutdown the module
@@ -611,8 +536,8 @@ void darshan_core_shutdown()
if(my_rank == 0)
- out_header.mod_map[i].off = 0;
- out_header.mod_map[i].len = 0;
+ final_core->log_hdr_p->mod_map[i].off = 0;
+ final_core->log_hdr_p->mod_map[i].len = 0;
continue;
@@ -620,8 +545,7 @@ void darshan_core_shutdown()
mod1[i] = DARSHAN_MPI_CALL(PMPI_Wtime)();
- /* set the shared file list for this module */
- memset(mod_shared_recs, 0, shared_rec_cnt * sizeof(darshan_record_id));
+ /* set the shared record list for this module */
for(j = 0; j < shared_rec_cnt; j++)
HASH_FIND(hlink, final_core->name_hash, &shared_recs[j],
@@ -636,7 +560,7 @@ void darshan_core_shutdown()
/* if module is registered locally, get the corresponding output buffer
* NOTE: this function can be used to run collective operations across
- * modules, if there are file records shared globally.
+ * modules, if there are records shared globally.
if(this_mod)
@@ -647,9 +571,10 @@ void darshan_core_shutdown()
/* append this module's data to the darshan log */
- out_header.mod_map[i].off = gz_fp;
+ final_core->log_hdr_p->mod_map[i].off = gz_fp;
ret = darshan_log_append_all(log_fh, final_core, mod_buf, mod_buf_sz, &gz_fp);
- out_header.mod_map[i].len = gz_fp - out_header.mod_map[i].off;
+ gz_fp - final_core->log_hdr_p->mod_map[i].off;
/* error out if the log append failed */
@@ -679,26 +604,25 @@ void darshan_core_shutdown()
header1 = DARSHAN_MPI_CALL(PMPI_Wtime)();
- /* write out log header, after running 2 reduction on header variables:
+ /* write out log header, after running 2 reductions on header variables:
* 1) reduce 'partial_flag' variable to determine which modules ran out
- * of memory for storing I/O data
+ * of memory for storing data
* 2) reduce 'mod_ver' array to determine which log format version each
* module used for this output log
- DARSHAN_MPI_CALL(PMPI_Reduce)(&(final_core->log_hdr_p->partial_flag),
- &(out_header.partial_flag), 1, MPI_UINT32_T, MPI_BOR, 0, MPI_COMM_WORLD);
- DARSHAN_MPI_CALL(PMPI_Reduce)(&(final_core->log_hdr_p->mod_ver),
- &(out_header.mod_ver), DARSHAN_MAX_MODS, MPI_UINT32_T, MPI_MAX,
- 0, MPI_COMM_WORLD);
if(my_rank == 0)
/* rank 0 is responsible for writing the log header */
- /* initialize the remaining header fields */
- strcpy(out_header.version_string, DARSHAN_LOG_VERSION);
- out_header.magic_nr = DARSHAN_MAGIC_NR;
- out_header.comp_type = DARSHAN_ZLIB_COMP;
+ final_core->log_hdr_p->comp_type = DARSHAN_ZLIB_COMP;
+ MPI_IN_PLACE, &(final_core->log_hdr_p->partial_flag),
+ 1, MPI_UINT32_T, MPI_BOR, 0, MPI_COMM_WORLD);
+ MPI_IN_PLACE, &(final_core->log_hdr_p->mod_ver),
+ DARSHAN_MAX_MODS, MPI_UINT32_T, MPI_MAX, 0, MPI_COMM_WORLD);
- all_ret = DARSHAN_MPI_CALL(PMPI_File_write_at)(log_fh, 0, &out_header,
+ all_ret = DARSHAN_MPI_CALL(PMPI_File_write_at)(log_fh, 0, final_core->log_hdr_p,
sizeof(struct darshan_header), MPI_BYTE, &status);
if(all_ret != MPI_SUCCESS)
@@ -707,6 +631,15 @@ void darshan_core_shutdown()
unlink(logfile_name);
+ else
+ &(final_core->log_hdr_p->partial_flag), &(final_core->log_hdr_p->partial_flag),
+ &(final_core->log_hdr_p->mod_ver), &(final_core->log_hdr_p->mod_ver),
/* error out if unable to write log header */
DARSHAN_MPI_CALL(PMPI_Bcast)(&all_ret, 1, MPI_INT, 0, MPI_COMM_WORLD);
@@ -758,11 +691,6 @@ void darshan_core_shutdown()
- /* remove the temporary mmap log files */
- unlink(final_core->mmap_log_name);
-#endif
free(logfile_name);
free(shared_recs);
free(mod_shared_recs);
@@ -824,6 +752,80 @@ void darshan_core_shutdown()
+static void *darshan_init_mmap_log(struct darshan_core_runtime* core, int jobid)
+ int ret;
+ int mmap_fd;
+ int mmap_size;
+ int sys_page_size;
+ char cuser[L_cuserid] = {0};
+ char *envstr;
+ char *mmap_log_path;
+ void *mmap_p;
+ sys_page_size = sysconf(_SC_PAGESIZE);
+ assert(sys_page_size > 0);
+ mmap_size = sizeof(struct darshan_header) + DARSHAN_JOB_RECORD_SIZE +
+ + DARSHAN_NAME_RECORD_BUF_SIZE + darshan_mod_mem_quota;
+ if(mmap_size % sys_page_size)
+ mmap_size = ((mmap_size / sys_page_size) + 1) * sys_page_size;
+ envstr = getenv(DARSHAN_MMAP_LOG_PATH_OVERRIDE);
+ if(envstr)
+ mmap_log_path = envstr;
+ else
+ mmap_log_path = DARSHAN_DEF_MMAP_LOG_PATH;
+ darshan_get_user_name(cuser);
+ /* construct a unique temporary log file name for this process
+ * to write mmap log data to
+ snprintf(core->mmap_log_name, PATH_MAX,
+ "/%s/%s_%s_id%d_mmap-log-%d.darshan",
+ mmap_log_path, cuser, __progname, jobid, my_rank);
+ /* create the temporary mmapped darshan log */
+ mmap_fd = open(core->mmap_log_name, O_CREAT|O_RDWR|O_EXCL , 0644);
+ if(mmap_fd < 0)
+ fprintf(stderr, "darshan library warning: "
+ "unable to create darshan log file %s\n", core->mmap_log_name);
+ return(NULL);
+ /* TODO: ftruncate or just zero fill? */
+ /* allocate the necessary space in the log file */
+ ret = ftruncate(mmap_fd, mmap_size);
+ if(ret < 0)
+ "unable to allocate darshan log file %s\n", core->mmap_log_name);
+ close(mmap_fd);
+ unlink(core->mmap_log_name);
+ return(NULL);
+ /* create the memory map for darshan's data structures so they are
+ * persisted to file as the application executes
+ mmap_p = mmap(NULL, mmap_size, PROT_WRITE, MAP_SHARED, mmap_fd, 0);
+ if(mmap_p == MAP_FAILED)
+ "unable to mmap darshan log file %s\n", core->mmap_log_name);
+ close(mmap_fd);
+ return(NULL);
+ /* close darshan log file (this does *not* unmap the log file) */
+ close(mmap_fd);
+ return(mmap_p);
/* record any hints used to write the darshan log in the job data */
static void darshan_log_record_hints_and_ver(struct darshan_core_runtime* core)
@@ -884,7 +886,7 @@ static int mnt_data_cmp(const void* a, const void* b)
/* adds an entry to table of mounted file systems */
-static void add_entry(char* buf, int* space_left, struct mntent *entry)
+static void add_entry(char* buf, int* space_left, struct mntent* entry)
int ret;
char tmp_mnt[256];
@@ -1221,38 +1223,37 @@ static void darshan_get_logfile_name(char* logfile_name, int jobid, struct tm* s
return;
-static void darshan_add_name_record_ref(struct darshan_core_runtime *core,
+static int darshan_add_name_record_ref(struct darshan_core_runtime *core,
darshan_record_id rec_id, const char *name, darshan_module_id mod_id)
struct darshan_core_name_record_ref *ref;
int record_size = sizeof(darshan_record_id) + strlen(name) + 1;
- if((record_size + core->log_hdr_p->name_map.len) > DARSHAN_NAME_RECORD_BUF_SIZE)
- return;
+ if((record_size + core->name_mem_used) > DARSHAN_NAME_RECORD_BUF_SIZE)
+ return(0);
ref = malloc(sizeof(*ref));
- if(ref)
- memset(ref, 0, sizeof(*ref));
- ref->name_record = (struct darshan_name_record *)
- ((char *)core->log_name_p + core->log_hdr_p->name_map.len);
- memset(ref->name_record, 0, record_size);
- ref->name_record->id = rec_id;
- strcpy(ref->name_record->name, name);
- if(!DARSHAN_MOD_FLAG_ISSET(ref->mod_flags, mod_id))
- DARSHAN_MOD_FLAG_SET(ref->mod_flags, mod_id);
- /* add the record to the hash table */
- HASH_ADD(hlink, core->name_hash, name_record->id,
- sizeof(darshan_record_id), ref);
- core->log_hdr_p->name_map.len += record_size;
+ if(!ref)
+ return(0);
+ memset(ref, 0, sizeof(*ref));
+ /* initialize the name record */
+ ref->name_record = (struct darshan_name_record *)
+ ((char *)core->log_name_p + core->name_mem_used);
+ memset(ref->name_record, 0, record_size);
+ ref->name_record->id = rec_id;
+ strcpy(ref->name_record->name, name);
+ DARSHAN_MOD_FLAG_SET(ref->mod_flags, mod_id);
+ /* add the record to the hash table */
+ HASH_ADD(hlink, core->name_hash, name_record->id,
+ sizeof(darshan_record_id), ref);
+ core->name_mem_used += record_size;
+#ifdef __DARSHAN_ENABLE_MMAP_LOGS
+ core->log_hdr_p->name_map.len += record_size;
+#endif
- return;
+ return(1);
static void darshan_get_shared_records(struct darshan_core_runtime *core,
@@ -1304,7 +1305,7 @@ static void darshan_get_shared_records(struct darshan_core_runtime *core,
- /* now allreduce so everyone agrees which files are shared and
+ /* now allreduce so everyone agrees which records are shared and
* which modules accessed them collectively
DARSHAN_MPI_CALL(PMPI_Allreduce)(mod_flags, global_mod_flags, tmp_cnt,
@@ -1319,7 +1320,7 @@ static void darshan_get_shared_records(struct darshan_core_runtime *core,
/* set global_mod_flags so we know which modules collectively
* accessed this module. we need this info to support shared
- * file reductions
+ * record reductions
HASH_FIND(hlink, core->name_hash, &id_array[i], sizeof(darshan_record_id), ref);
assert(ref);
@@ -1496,7 +1497,8 @@ static int darshan_log_write_name_record_hash(MPI_File log_fh,
int name_rec_buf_len;
int ret;
- name_rec_buf_len = core->log_hdr_p->name_map.len;
+ /* remove globally shared name records from non-zero ranks */
+ name_rec_buf_len = core->name_mem_used;
if(my_rank > 0)
name_rec = core->log_name_p;
@@ -1512,6 +1514,9 @@ static int darshan_log_write_name_record_hash(MPI_File log_fh,
if(ref->global_mod_flags)
+ /* this record is shared globally, move to the temporary
+ * shared record buffer and update hash references
HASH_DELETE(hlink, core->name_hash, ref);
memcpy(shared_buf, name_rec, rec_len);
ref->name_record = (struct darshan_name_record *)shared_buf;
@@ -1523,6 +1528,9 @@ static int darshan_log_write_name_record_hash(MPI_File log_fh,
else
+ /* this record is not shared, but we still may need to
+ * move it forward in our buffer and update hash references
if(my_buf != (char *)name_rec)
@@ -1538,8 +1546,12 @@ static int darshan_log_write_name_record_hash(MPI_File log_fh,
name_rec = (struct darshan_name_record *)tmp_p;
name_rec_buf_len -= rec_len;
- name_rec_buf_len = core->log_hdr_p->name_map.len - shared_buf_len;
+ name_rec_buf_len = core->name_mem_used - shared_buf_len;
+ /* append the shared records back to the end of the name record
+ * buffer and update hash table references so we can still
+ * reference these records as modules shutdown
name_rec = (struct darshan_name_record *)core->comp_buf;
while(shared_buf_len > 0)
@@ -1678,7 +1690,6 @@ static void darshan_core_cleanup(struct darshan_core_runtime* core)
-/* TODO: do we alloc new space as we go or just do everything up front? */
struct darshan_module_funcs *funcs,
@@ -1712,7 +1723,7 @@ void darshan_core_register_module(
memset(mod, 0, sizeof(*mod));
/* set module's record buffer and max memory usage */
- mod_mem_avail = DARSHAN_MOD_MEM_MAX - darshan_core->mod_mem_used;
+ mod_mem_avail = darshan_mod_mem_quota - darshan_core->mod_mem_used;
if(mod_mem_avail >= mod_mem_req)
mod->rec_mem_avail = mod_mem_req;
else
@@ -1724,12 +1735,11 @@ void darshan_core_register_module(
/* register module with darshan */
darshan_core->mod_array[mod_id] = mod;
darshan_core->mod_mem_used += mod->rec_mem_avail;
- /* update darshan header */
- /* TODO: ifdef wrap for mmap ? */
darshan_core->log_hdr_p->mod_ver[mod_id] = darshan_module_versions[mod_id];
darshan_core->log_hdr_p->mod_map[mod_id].off =
((char *)mod->rec_buf_start - (char *)darshan_core->log_hdr_p);
+#endif
*inout_mod_buf_size = mod->rec_mem_avail;
@@ -1743,35 +1753,26 @@ void darshan_core_register_module(
return;
-/* TODO: */
+/* NOTE: we currently don't really have a simple way of returning the
+ * memory allocated to this module back to darshan to hand out to
+ * other modules, so all we do is disable the module so darshan does
+ * not attempt to call into it at shutdown time
- struct darshan_core_name_record_ref *ref, *tmp;
if(!darshan_core)
return;
DARSHAN_CORE_LOCK();
- /* iterate all records and disassociate this module from them */
- HASH_ITER(hlink, darshan_core->name_hash, ref, tmp)
- /* disassociate this module from the given record id */
- DARSHAN_MOD_FLAG_UNSET(ref->mod_flags, mod_id);
- if(!(ref->mod_flags))
- /* if no other modules are associated with this rec, delete it */
- HASH_DELETE(hlink, darshan_core->name_hash, ref);
/* update darshan internal structures and header */
free(darshan_core->mod_array[mod_id]);
darshan_core->mod_array[mod_id] = NULL;
+ darshan_core->log_hdr_p->mod_ver[mod_id] = 0;
darshan_core->log_hdr_p->mod_map[mod_id].len = 0;
+#endif
return;
@@ -1793,6 +1794,7 @@ void *darshan_core_register_record(
void *rec_buf;
+ int ret;
if(!darshan_core)
return(NULL);
@@ -1817,14 +1819,26 @@ void *darshan_core_register_record(
if(!ref)
- darshan_add_name_record_ref(darshan_core, rec_id, name, mod_id);
+ ret = darshan_add_name_record_ref(darshan_core, rec_id, name, mod_id);
+ if(ret == 0)
+ DARSHAN_MOD_FLAG_SET(darshan_core->log_hdr_p->partial_flag, mod_id);
+ DARSHAN_CORE_UNLOCK();
+ return(NULL);
+ else
rec_buf = darshan_core->mod_array[mod_id]->rec_buf_p;
darshan_core->mod_array[mod_id]->rec_buf_p += rec_len;
darshan_core->mod_array[mod_id]->rec_mem_avail -= rec_len;
- darshan_core->log_hdr_p->mod_map[mod_id].len += rec_len; /* XXX */
+ darshan_core->log_hdr_p->mod_map[mod_id].len += rec_len;
+#endif
if(file_alignment)
@@ -1833,13 +1847,6 @@ void *darshan_core_register_record(
return(rec_buf);;
-/* TODO: */
-void darshan_core_unregister_record(
- darshan_record_id rec_id,
- darshan_module_id mod_id)
double darshan_core_wtime()
if(!darshan_core)
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/d8f3575ac292132eea109c725114bc27883d012d
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20160608/8d5facdc/attachment-0001.html>
More information about the Darshan-commits
