[Darshan-commits] [Git][darshan/darshan][mmap-dev] fix comment and shuffle some more code
Shane Snyder
xgitlab at cels.anl.gov
Wed Jun 8 17:34:42 CDT 2016
Shane Snyder pushed to branch mmap-dev at darshan / darshan
Commits:
54baa7dd by Shane Snyder at 2016-06-08T17:34:05-05:00
2 changed files:
- darshan-runtime/darshan.h
- darshan-runtime/lib/darshan-posix.c
Changes:
--- a/darshan-runtime/darshan.h
+++ b/darshan-runtime/darshan.h
@@ -134,7 +134,8 @@ darshan_record_id darshan_core_gen_record_id(
* is the size of the record being registered with Darshan. If given,
* 'file_alignment' is a pointer to an integer which on return will
* contain the corresponding file system alignment of the file system
- * path 'name' resides on.
+ * path 'name' resides on. Returns a pointer to the address the record
+ * should be written to on success, NULL on failure.
void *darshan_core_register_record(
darshan_record_id rec_id,
--- a/darshan-runtime/lib/darshan-posix.c
+++ b/darshan-runtime/lib/darshan-posix.c
@@ -1574,6 +1574,32 @@ static void posix_aio_tracker_add(int fd, void *aiocbp)
return;
+static void posix_finalize_file_records(void *rec_ref_p)
+ struct posix_file_record_ref *rec_ref =
+ (struct posix_file_record_ref *)rec_ref_p;
+#ifndef __DARSHAN_ENABLE_MMAP_LOGS
+ /* walk common counters to get 4 most common -- only if mmap
+ * feature is disabled (mmap updates counters on the go)
+ /* common accesses */
+ darshan_walk_common_vals(rec_ref->access_root,
+ &(rec_ref->file_rec->counters[POSIX_ACCESS1_ACCESS]),
+ &(rec_ref->file_rec->counters[POSIX_ACCESS1_COUNT]));
+ /* common strides */
+ darshan_walk_common_vals(rec_ref->stride_root,
+ &(rec_ref->file_rec->counters[POSIX_STRIDE1_STRIDE]),
+ &(rec_ref->file_rec->counters[POSIX_STRIDE1_COUNT]));
+#endif
+ tdestroy(rec_ref->access_root, free);
+ tdestroy(rec_ref->stride_root, free);
+ return;
static void posix_record_reduction_op(void* infile_v, void* inoutfile_v,
int *len, MPI_Datatype *datatype)
@@ -1901,32 +1927,6 @@ static void posix_begin_shutdown()
return;
-static void posix_finalize_file_records(void *rec_ref_p)
- struct posix_file_record_ref *rec_ref =
- (struct posix_file_record_ref *)rec_ref_p;
-#ifndef __DARSHAN_ENABLE_MMAP_LOGS
- /* walk common counters to get 4 most common -- only if mmap
- * feature is disabled (mmap updates counters on the go)
- /* common accesses */
- darshan_walk_common_vals(rec_ref->access_root,
- &(rec_ref->file_rec->counters[POSIX_ACCESS1_ACCESS]),
- &(rec_ref->file_rec->counters[POSIX_ACCESS1_COUNT]));
- /* common strides */
- darshan_walk_common_vals(rec_ref->stride_root,
- &(rec_ref->file_rec->counters[POSIX_STRIDE1_STRIDE]),
- &(rec_ref->file_rec->counters[POSIX_STRIDE1_COUNT]));
-#endif
- tdestroy(rec_ref->access_root, free);
- tdestroy(rec_ref->stride_root, free);
- return;
static void posix_get_output_data(
MPI_Comm mod_comm,
darshan_record_id *shared_recs,
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/54baa7ddf924fdcea333761b93b4b2fc10168702
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20160608/be597f36/attachment-0001.html>
More information about the Darshan-commits
