[Darshan-commits] [Git][darshan/darshan][lustre-mod] 5 commits: made print_lustre_runtime
Glenn K. Lockwood
xgitlab at cels.anl.gov
Tue Jun 7 13:53:57 CDT 2016
Glenn K. Lockwood pushed to branch lustre-mod at darshan / darshan
Commits:
6538893d by Glenn K. Lockwood at 2016-06-03T11:02:16-07:00
15d6b046 by Glenn K. Lockwood at 2016-06-03T11:03:15-07:00
fixed problem where make was breaking if only some dependencies had been updated
ab49f325 by Glenn K. Lockwood at 2016-06-03T11:03:43-07:00
first record was being rejected because the core stub was handing out rec_id==0
f5f23bc1 by Glenn K. Lockwood at 2016-06-07T09:42:47-07:00
implemented a simple get_output_data that doesn't use MPI; all ranks except rank0 just drop their shared records
fad7e816 by Glenn K. Lockwood at 2016-06-07T11:53:20-07:00
added more stubs to enable testing of lustre-mod's shared-file reduction
5 changed files:
- darshan-runtime/lib/darshan-lustre.c
- + darshan-runtime/lib/darshan-lustre_old.c
- darshan-test/lustre/Makefile
- darshan-test/lustre/darshan-core-stub.c
- darshan-test/lustre/mpi.h
Changes:
--- a/darshan-runtime/lib/darshan-lustre.c
+++ b/darshan-runtime/lib/darshan-lustre.c
@@ -229,7 +229,6 @@ static void lustre_begin_shutdown(void)
return;
-/* XXX - still need to update 5/26/2016 */
static void lustre_get_output_data(
MPI_Comm mod_comm,
darshan_record_id *shared_recs,
@@ -239,10 +238,6 @@ static void lustre_get_output_data(
struct lustre_record_runtime *file;
int i;
- struct darshan_lustre_record *red_send_buf = NULL;
- struct darshan_lustre_record *red_recv_buf = NULL;
- MPI_Datatype red_type;
- MPI_Op red_op;
assert(lustre_runtime);
@@ -250,7 +245,7 @@ static void lustre_get_output_data(
/* NOTE: the shared file reduction is also skipped if the
* DARSHAN_DISABLE_SHARED_REDUCTION environment variable is set.
- if(shared_rec_count && !getenv("DARSHAN_DISABLE_SHARED_REDUCTION"))
+ if (shared_rec_count && !getenv("DARSHAN_DISABLE_SHARED_REDUCTION"))
/* necessary initialization of shared records */
for(i = 0; i < shared_rec_count; i++)
@@ -268,44 +263,9 @@ static void lustre_get_output_data(
sort_lustre_records();
- /* make *send_buf point to the shared files at the end of sorted array
- red_send_buf =
- &(lustre_runtime->record_runtime_array[lustre_runtime->record_count-shared_rec_count]);
- /* allocate memory for the reduction output on rank 0
- if(my_rank == 0)
- red_recv_buf = malloc(shared_rec_count * sizeof(struct darshan_lustre_record));
- if(!red_recv_buf)
- return;
- DARSHAN_MPI_CALL(PMPI_Type_contiguous)(sizeof(struct darshan_lustre_record),
- MPI_BYTE, &red_type);
- DARSHAN_MPI_CALL(PMPI_Type_commit)(&red_type);
- DARSHAN_MPI_CALL(PMPI_Op_create)(lustre_record_reduction_op, 1, &red_op);
- DARSHAN_MPI_CALL(PMPI_Reduce)(red_send_buf, red_recv_buf,
- shared_rec_count, red_type, red_op, 0, mod_comm);
- /* clean up reduction state
- if(my_rank == 0)
- memcpy(&(lustre_runtime->record_array[lustre_runtime->record_count - shared_rec_count]), red_recv_buf,
- shared_rec_count * sizeof(struct darshan_lustre_record));
- free(red_recv_buf);
- else
+ /* allocate memory for the reduction output on rank 0 */
+ if (my_rank != 0)
lustre_runtime->record_count -= shared_rec_count;
- DARSHAN_MPI_CALL(PMPI_Type_free)(&red_type);
- DARSHAN_MPI_CALL(PMPI_Op_free)(&red_op);
*lustre_buf = (void *)(lustre_runtime->record_buffer);
@@ -333,11 +293,18 @@ static int lustre_record_compare(const void* a_p, const void* b_p)
const struct lustre_record_runtime* a = a_p;
const struct lustre_record_runtime* b = b_p;
- if(a->record->rank < b->record->rank)
+ if (a->record->rank < b->record->rank)
return 1;
- if(a->record->rank > b->record->rank)
+ if (a->record->rank > b->record->rank)
return -1;
+ /* if ( a->record->rank == b->record->rank ) we MUST do a secondary
+ * sort so that the order of qsort is fully deterministic and consistent
+ * across all MPI ranks. Without a secondary sort, the sort order can
+ * be affected by rank-specific variations (e.g., the order in which
+ * files are first opened).
return 0;
@@ -458,18 +425,20 @@ void print_lustre_runtime( void )
printf( "File %2d\n", i );
for ( j = 0; j < LUSTRE_NUM_INDICES; j++ )
- printf( " Counter %2d: %10ld, addr %ld\n",
+ printf( " Counter %-2d: %10ld, addr %ld\n",
j,
rec->counters[j],
(char*)(&(rec->counters[j])) - (char*)(lustre_runtime->record_buffer) );
for ( j = 0; j < rec->counters[LUSTRE_STRIPE_WIDTH]; j++ )
- printf( " Stripe %2d: %10ld, addr %ld\n",
+ if ( j > 0 && j % 2 == 0 ) printf("\n");
+ printf( " Stripe %-2d: %10ld, addr %-9d",
j,
rec->ost_ids[j],
(char*)(&(rec->ost_ids[j])) - (char*)(lustre_runtime->record_buffer) );
+ printf( "\n" );
return;
--- /dev/null
+++ b/darshan-runtime/lib/darshan-lustre_old.c
@@ -0,0 +1,543 @@
+ * Copyright (C) 2015 University of Chicago.
+ * See COPYRIGHT notice in top-level directory.
+#define _XOPEN_SOURCE 500
+#define _GNU_SOURCE
+#include "darshan-runtime-config.h"
+#include <stdio.h>
+#include <unistd.h>
+#include <sys/types.h>
+#include <sys/stat.h>
+#include <time.h>
+#include <stdlib.h>
+#include <assert.h>
+#include <pthread.h>
+#include <sys/ioctl.h>
+/* XXX stick this into autoconf .h */
+#include <lustre/lustre_user.h>
+#include "uthash.h"
+#include "darshan.h"
+#include "darshan-dynamic.h"
+#include "darshan-lustre.h"
+struct lustre_runtime *lustre_runtime = NULL;
+static pthread_mutex_t lustre_runtime_mutex = PTHREAD_RECURSIVE_MUTEX_INITIALIZER_NP;
+static int instrumentation_disabled = 0;
+static int my_rank = -1;
+static void lustre_runtime_initialize(void);
+static void lustre_begin_shutdown(void);
+static void lustre_get_output_data(MPI_Comm mod_comm, darshan_record_id *shared_recs,
+ int shared_rec_count, void **lustre_buf, int *lustre_buf_sz);
+static void lustre_shutdown(void);
+static int lustre_record_compare(const void* a_p, const void* b_p);
+static void lustre_record_reduction_op(void* infile_v, void* inoutfile_v,
+ int *len, MPI_Datatype *datatype);
+#define LUSTRE_LOCK() pthread_mutex_lock(&lustre_runtime_mutex)
+#define LUSTRE_UNLOCK() pthread_mutex_unlock(&lustre_runtime_mutex)
+#define LUSTRE_RECORD_SIZE( osts ) ( sizeof(struct darshan_lustre_record) + sizeof(int64_t) * (osts - 1) )
+void darshan_instrument_lustre_file(const char* filepath, int fd)
+ struct lustre_record_runtime *rec_rt;
+ struct darshan_lustre_record *rec;
+ struct darshan_fs_info fs_info;
+ darshan_record_id rec_id;
+ int limit_flag;
+ int i;
+ struct lov_user_md *lum;
+ size_t lumsize = sizeof(struct lov_user_md) +
+ LOV_MAX_STRIPE_COUNT * sizeof(struct lov_user_ost_data);
+ size_t rec_size;
+ LUSTRE_LOCK();
+ /* make sure the lustre module is already initialized */
+ lustre_runtime_initialize();
+ /* if we can't issue ioctl, we have no counter data at all */
+ if ( (lum = calloc(1, lumsize)) == NULL )
+ return;
+ /* find out the OST count of this file so we can allocate memory */
+ lum->lmm_magic = LOV_USER_MAGIC;
+ lum->lmm_stripe_count = LOV_MAX_STRIPE_COUNT;
+ /* -1 means ioctl failed, likely because file isn't on Lustre */
+ if ( ioctl( fd, LL_IOC_LOV_GETSTRIPE, (void *)lum ) == -1 )
+ free(lum);
+ return;
+ rec_size = LUSTRE_RECORD_SIZE( lum->lmm_stripe_count );
+ /* broken out for clarity */
+ void *end_of_new_record = (char*)lustre_runtime->next_free_record + rec_size;
+ void *end_of_rec_buffer = (char*)lustre_runtime->record_buffer + lustre_runtime->record_buffer_max;
+ limit_flag = ( end_of_new_record > end_of_rec_buffer );
+ /* register a Lustre file record with Darshan */
+ fs_info.fs_type = -1;
+ darshan_core_register_record(
+ (void *)filepath,
+ strlen(filepath),
+ DARSHAN_LUSTRE_MOD,
+ 1,
+ limit_flag,
+ &rec_id,
+ &fs_info);
+ /* if record id is 0, darshan has no more memory for instrumenting */
+ if(rec_id == 0)
+ free(lum);
+ LUSTRE_UNLOCK();
+ return;
+ /* search the hash table for this file record, and initialize if not found */
+ HASH_FIND(hlink, lustre_runtime->record_runtime_hash, &rec_id, sizeof(darshan_record_id), rec_rt );
+ if ( !rec_rt ) {
+ /* allocate a new lustre record and append it to the array */
+ rec_rt = &(lustre_runtime->record_runtime_array[lustre_runtime->record_count]);
+ rec_rt->record = lustre_runtime->next_free_record;
+ rec_rt->record_size = rec_size;
+ lustre_runtime->next_free_record = (char*)(lustre_runtime->next_free_record) + rec_size;
+ lustre_runtime->record_buffer_used += rec_size;
+ rec = rec_rt->record;
+ rec->rec_id = rec_id;
+ rec->rank = my_rank;
+ /* implicit assumption here that none of these counters will change
+ * after the first time a file is opened. This may not always be
+ * true in the future */
+ if ( fs_info.fs_type != -1 )
+ rec->counters[LUSTRE_OSTS] = fs_info.ost_count;
+ rec->counters[LUSTRE_MDTS] = fs_info.mdt_count;
+ else
+ rec->counters[LUSTRE_OSTS] = -1;
+ rec->counters[LUSTRE_MDTS] = -1;
+ rec->counters[LUSTRE_STRIPE_SIZE] = lum->lmm_stripe_size;
+ rec->counters[LUSTRE_STRIPE_WIDTH] = lum->lmm_stripe_count;
+ rec->counters[LUSTRE_STRIPE_OFFSET] = lum->lmm_stripe_offset;
+ for ( i = 0; i < lum->lmm_stripe_count; i++ )
+ rec->ost_ids[i] = lum->lmm_objects[i].l_ost_idx;
+ free(lum);
+ HASH_ADD(hlink, lustre_runtime->record_runtime_hash, record->rec_id, sizeof(darshan_record_id), rec_rt);
+ lustre_runtime->record_count++;
+ LUSTRE_UNLOCK();
+ return;
+static void lustre_runtime_initialize()
+ int mem_limit;
+ int max_records;
+ struct darshan_module_funcs lustre_mod_fns =
+ .begin_shutdown = &lustre_begin_shutdown,
+ .get_output_data = &lustre_get_output_data,
+ .shutdown = &lustre_shutdown
+ /* don't do anything if already initialized or instrumenation is disabled */
+ if(lustre_runtime || instrumentation_disabled)
+ return;
+ /* register the lustre module with darshan-core */
+ darshan_core_register_module(
+ &lustre_mod_fns,
+ &my_rank,
+ &mem_limit,
+ NULL);
+ /* return if no memory assigned by darshan core */
+ if(mem_limit == 0)
+ return;
+ lustre_runtime = malloc(sizeof(*lustre_runtime));
+ if(!lustre_runtime)
+ return;
+ memset(lustre_runtime, 0, sizeof(*lustre_runtime));
+ /* allocate the full size of the memory limit we are given */
+ lustre_runtime->record_buffer= malloc(mem_limit);
+ if(!lustre_runtime->record_buffer)
+ lustre_runtime->record_buffer_max = 0;
+ return;
+ lustre_runtime->record_buffer_max = mem_limit;
+ lustre_runtime->next_free_record = lustre_runtime->record_buffer;
+ memset(lustre_runtime->record_buffer, 0, lustre_runtime->record_buffer_max);
+ /* Allocate array of Lustre runtime data. We calculate the maximum possible
+ * number of records that will fit into mem_limit by assuming that each
+ * record has the minimum possible OST count, then allocate that many
+ * runtime records. record_buffer will always run out of memory before
+ * we overflow record_runtime_array.
+ max_records = mem_limit / sizeof(struct darshan_lustre_record);
+ lustre_runtime->record_runtime_array =
+ malloc( max_records * sizeof(struct lustre_record_runtime));
+ if(!lustre_runtime->record_runtime_array)
+ free( lustre_runtime->record_buffer );
+ return;
+ memset(lustre_runtime->record_runtime_array, 0,
+ max_records * sizeof(struct lustre_record_runtime));
+ return;
+ * Functions exported by Lustre module for coordinating with darshan-core *
+ assert(lustre_runtime);
+ LUSTRE_LOCK();
+ /* disable further instrumentation while Darshan shuts down */
+ instrumentation_disabled = 1;
+ LUSTRE_UNLOCK();
+ return;
+ MPI_Comm mod_comm,
+ darshan_record_id *shared_recs,
+ void **lustre_buf,
+ int *lustre_buf_sz)
+ struct lustre_record_runtime *file;
+ int i, ishared;
+ int *rec_lengths;
+ size_t shared_rec_size;
+ struct darshan_lustre_record *red_send_buf = NULL;
+ struct darshan_lustre_record *red_recv_buf = NULL;
+ MPI_Datatype red_type;
+ MPI_Aint *rec_offsets;
+ MPI_Op red_op;
+ /* if there are globally shared files, do a shared file reduction */
+ /* NOTE: the shared file reduction is also skipped if the
+ * DARSHAN_DISABLE_SHARED_REDUCTION environment variable is set.
+ /* necessary initialization of shared records */
+ for(i = 0; i < shared_rec_count; i++)
+ HASH_FIND(hlink, lustre_runtime->record_runtime_hash, &shared_recs[i],
+ sizeof(darshan_record_id), file);
+ assert(file);
+ file->record->rank = -1;
+ /* sort the array of files descending by rank so that we get all of the
+ * shared files (marked by rank -1) in a contiguous portion at end
+ * of the array
+ sort_lustre_records();
+ /* make red_send_buf point to the first shared-file record */
+ ishared = lustre_runtime->record_count - shared_rec_count;
+ red_send_buf =
+ (lustre_runtime->record_runtime_array[ishared]).record;
+ if (my_rank == 0)
+ shared_rec_size = lustre_runtime->record_buffer_used - ((char*)red_send_buf - (char*)lustre_runtime->record_buffer);
+ red_recv_buf = malloc(shared_rec_size);
+ if (!red_recv_buf)
+ return;
+ /* need to build rec_lengths (array of ints) and rec_offsets (array of ints) */
+ rec_lengths = malloc(sizeof(*rec_lengths) * shared_rec_count);
+ rec_offsets = malloc(sizeof(*rec_offsets) * shared_rec_count);
+ for ( i = ishared; i < shared_rec_count; i ++ )
+ rec_lengths[i] = (lustre_runtime->record_runtime_array[i]).record_size;
+ rec_offsets[i] = (char*)((lustre_runtime->record_runtime_array[i]).record) -
+ (char*)((lustre_runtime->record_runtime_array[ishared]).record);
+ DARSHAN_MPI_CALL(PMPI_Type_hindexed)(
+ shared_rec_count,
+ rec_lengths,
+ rec_offsets,
+ MPI_BYTE,
+ &red_type
+ DARSHAN_MPI_CALL(PMPI_Type_commit)(&red_type);
+ DARSHAN_MPI_CALL(PMPI_Op_create)(lustre_record_reduction_op, 1, &red_op);
+ DARSHAN_MPI_CALL(PMPI_Reduce)(red_send_buf, red_recv_buf,
+ shared_rec_count, red_type, red_op, 0, mod_comm);
+ /* clean up reduction state */
+ if (my_rank == 0)
+ memcpy(&(lustre_runtime->record_buffer[ishared]), red_recv_buf,
+ shared_rec_size);
+ free(red_recv_buf);
+ else
+ lustre_runtime->record_count -= shared_rec_count;
+ free(rec_lengths);
+ free(rec_offsets);
+ DARSHAN_MPI_CALL(PMPI_Type_free)(&red_type);
+ DARSHAN_MPI_CALL(PMPI_Op_free)(&red_op);
+ *lustre_buf = (void *)(lustre_runtime->record_buffer);
+ *lustre_buf_sz = lustre_runtime->record_buffer_used;
+ return;
+ HASH_CLEAR(hlink, lustre_runtime->record_runtime_hash);
+ free(lustre_runtime->record_runtime_array);
+ free(lustre_runtime->record_buffer);
+ free(lustre_runtime);
+ lustre_runtime = NULL;
+ return;
+/* compare function for sorting file records by descending rank */
+ const struct lustre_record_runtime* a = a_p;
+ const struct lustre_record_runtime* b = b_p;
+ return 1;
+ return -1;
+ return 0;
+ * Sort the record_runtimes and records by MPI rank to facilitate shared redux.
+ * This requires craftiness and additional heap utilization because the records
+ * (but not record_runtimes) have variable size. Currently has to temporarily
+ * duplicate the entire record_buffer; there is room for more memory-efficient
+ * optimization if this becomes a scalability issue.
+int sort_lustre_records()
+ int i;
+ struct lustre_record_runtime *rec_rt, *tmp_rec_rt;
+ char *new_buf, *p;
+ /* Create a new buffer to store an entire replica of record_buffer. Since
+ * we know the exact size of record_buffer's useful data at this point, we
+ * can allocate the exact amount we need instead of record_buffer_max */
+ new_buf = malloc(lustre_runtime->record_buffer_used);
+ p = new_buf;
+ if ( !new_buf )
+ return 1;
+ /* qsort breaks the hash table, so delete it now to free its memory buffers
+ * and prevent later confusion */
+ HASH_ITER( hlink, lustre_runtime->record_runtime_hash, rec_rt, tmp_rec_rt )
+ HASH_DELETE( hlink, lustre_runtime->record_runtime_hash, rec_rt );
+ /* sort the runtime records, which is has fixed-length elements */
+ qsort(
+ lustre_runtime->record_runtime_array,
+ lustre_runtime->record_count,
+ sizeof(struct lustre_record_runtime),
+ lustre_record_compare
+ /* rebuild the hash and array with the qsorted runtime records */
+ for ( i = 0; i < lustre_runtime->record_count; i++ )
+ rec_rt = &(lustre_runtime->record_runtime_array[i]);
+ HASH_ADD(hlink, lustre_runtime->record_runtime_hash, record->rec_id, sizeof(darshan_record_id), rec_rt );
+ /* create reordered record buffer, then copy it back in place */
+ memcpy( p, rec_rt->record, rec_rt->record_size );
+ /* fix record pointers within each runtime record too - pre-emptively
+ * point them at where they will live in record_buffer after we memcpy
+ * below */
+ rec_rt->record = (struct darshan_lustre_record *)((char*)(lustre_runtime->record_buffer) + (p - new_buf));
+ p += rec_rt->record_size;
+ memcpy(
+ lustre_runtime->record_buffer,
+ new_buf,
+ lustre_runtime->record_buffer_used );
+ free(new_buf);
+ return 0;
+/* this is just boilerplate reduction code that isn't currently used */
+ struct darshan_lustre_record tmp_record;
+ struct darshan_lustre_record *infile = infile_v;
+ struct darshan_lustre_record *inoutfile = inoutfile_v;
+ int i, j;
+ for( i=0; i<*len; i++ )
+ memset(&tmp_record, 0, sizeof(struct darshan_lustre_record));
+ tmp_record.rec_id = infile->rec_id;
+ tmp_record.rank = -1;
+ /* preserve only rank 0's value */
+ for( j = LUSTRE_OSTS; j < LUSTRE_NUM_INDICES; j++)
+ if ( my_rank == 0 )
+ tmp_record.counters[j] = infile->counters[j];
+ else
+ tmp_record.counters[j] = inoutfile->counters[j];
+ /* update pointers */
+ *inoutfile = tmp_record;
+ inoutfile++;
+ infile++;
+ return;
+ * Dump the memory structure of our records and runtime records
+void print_lustre_runtime( void )
+ int i, j;
+ /* print what we just loaded */
+ rec = (lustre_runtime->record_runtime_array[i]).record;
+ printf( "File %2d\n", i );
+ for ( j = 0; j < LUSTRE_NUM_INDICES; j++ )
+ j,
+ rec->counters[j],
+ (char*)(&(rec->counters[j])) - (char*)(lustre_runtime->record_buffer) );
+ for ( j = 0; j < rec->counters[LUSTRE_STRIPE_WIDTH]; j++ )
+ j,
+ rec->ost_ids[j],
+ (char*)(&(rec->ost_ids[j])) - (char*)(lustre_runtime->record_buffer) );
+ printf( "\n" );
+ return;
+ * Dump the order in which records appear in memory
+void print_array( void )
+ int i;
+ printf("*** DUMPING RECORD LIST BY ARRAY SEQUENCE\n");
+ printf( "*** record %d rank %d osts %d\n",
+ rec_rt->record->rec_id,
+ rec_rt->record->rank,
+ rec_rt->record->counters[LUSTRE_STRIPE_WIDTH]);
+void print_hash( void )
+ printf("*** DUMPING RECORD LIST BY HASH SEQUENCE\n");
+ return;
+ * Local variables:
+ * c-indent-level: 4
+ * c-basic-offset: 4
+ * End:
+ * vim: ts=8 sts=4 sw=4 expandtab
--- a/darshan-test/lustre/Makefile
+++ b/darshan-test/lustre/Makefile
@@ -7,10 +7,10 @@ CFLAGS = -O0 -g -I../.. -I../../darshan-runtime
CFLAGS += -I.
darshan-tester: $(OBJS)
- $(CC) $(LDFLAGS) $? $(LOADLIBES) $(LDLIBS) -o $@
+ $(CC) $(LDFLAGS) $^ $(LOADLIBES) $(LDLIBS) -o $@
darshan-tester-mpi: $(OBJS)
darshan-lustre.o: ../../darshan-runtime/lib/darshan-lustre.c
$(CC) $(CPPFLAGS) $(CFLAGS) -c $? -o $@
--- a/darshan-test/lustre/darshan-core-stub.c
+++ b/darshan-test/lustre/darshan-core-stub.c
@@ -15,7 +15,7 @@
* Global variables
-static darshan_record_id next_rec_id = 0;
+static darshan_record_id next_rec_id = 1;
static int my_rank = 0;
static struct darshan_module_funcs mod_funcs;
@@ -87,7 +87,7 @@ int main( int argc, char **argv )
for ( i = 1; i < argc; i++ )
fname = argv[i];
- printf( "\nProcessing %s\n", fname );
+ printf( "File %3d - processing %s\n", i, fname );
fd = open( fname, O_RDONLY );
darshan_instrument_lustre_file( fname, fd );
close(fd);
--- a/darshan-test/lustre/mpi.h
+++ b/darshan-test/lustre/mpi.h
@@ -5,4 +5,6 @@
typedef int MPI_Comm;
typedef int MPI_Datatype;
typedef int MPI_Op;
+typedef long MPI_Aint;
+unsigned char MPI_BYTE;
#define MPI_COMM_WORLD 0
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/compare/dc1a9eb90c044ecb054cc50e7400c2bc3a9080e7...fad7e81662c2b6c1c4a749c9299d6bb65537c022
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20160607/12c9308b/attachment-0001.html>
More information about the Darshan-commits
