[Darshan-commits] [Darshan] branch, dev-modular, updated. darshan-2.3.1-187-gda0aaec
Service Account git at mcs.anl.gov
Wed Sep 23 13:45:19 CDT 2015
This is an automated email from the git hooks/post-receive script. It was
generated because a ref change was pushed to the repository containing
the project "".
The branch, dev-modular has been updated
       via  da0aaec641c2c4fa48d1079ff34679a3aec227ab (commit)
      from  779162dfb241581839e0fdf32d0320c8546b8747 (commit)
Those revisions listed above that are new to this repository have
not appeared on any other notification email; so we list those
revisions in full, below.
- Log -----------------------------------------------------------------
commit da0aaec641c2c4fa48d1079ff34679a3aec227ab
Author: Shane Snyder <ssnyder at mcs.anl.gov>
Date:   Wed Sep 23 13:44:48 2015 -0500
    update darshan-job-summary to be more clear
Summary of changes:
 .../bin/darshan-job-summary.pl.in                  |    7 ++++---
 .../darshan-job-summary/share/file-access-eps.gplt |    6 +++---
 .../share/file-access-table.tex                    |    2 +-
 .../darshan-job-summary/share/pattern-eps.gplt     |    2 +-
 4 files changed, 9 insertions(+), 8 deletions(-)
Diff of changes:
diff --git a/darshan-util/darshan-job-summary/bin/darshan-job-summary.pl.in b/darshan-util/darshan-job-summary/bin/darshan-job-summary.pl.in
index 4826009..03afc76 100755
--- a/darshan-util/darshan-job-summary/bin/darshan-job-summary.pl.in
+++ b/darshan-util/darshan-job-summary/bin/darshan-job-summary.pl.in
@@ -567,7 +567,7 @@ print FILE_CNT_TABLE "
 \\begin{tabular}{r|r|r|r}
 \\multicolumn{4}{c}{ } \\\\
 \\multicolumn{4}{c}{File Count Summary} \\\\
-\\multicolumn{4}{c}{(estimated by I/O access offsets)} \\\\
+\\multicolumn{4}{c}{(estimated by POSIX I/O access offsets)} \\\\
 \\hline
 type \& number of files \& avg. size \& max size \\\\
 \\hline
@@ -750,7 +750,7 @@ open(FS_TABLE, ">$tmp_dir/fs-data-table.tex") || die("error opening output files
 print FS_TABLE "
 \\begin{tabular}{c|r|r|r|r}
 \\multicolumn{5}{c}{ } \\\\
-\\multicolumn{5}{c}{Data Transfer Per Filesystem} \\\\
+\\multicolumn{5}{c}{Data Transfer Per Filesystem (POSIX)} \\\\
 \\hline
 \\multirow{2}{*}{File System} \& \\multicolumn{2}{c}{Write} \\vline \& \\multicolumn{2}{c}{Read} \\\\
 \\cline{2-5}
@@ -799,7 +799,7 @@ open(VAR_TABLE, ">$tmp_dir/variance-table.tex") || die("error opening output fil
 print VAR_TABLE "
 \\begin{tabular}{c|r|r|r|r|r|r|r|r|r}
 \\multicolumn{10}{c}{} \\\\
-\\multicolumn{10}{c}{Variance in Shared Files} \\\\
+\\multicolumn{10}{c}{Variance in Shared Files (POSIX)} \\\\
 \\hline
 File \& Processes \& \\multicolumn{3}{c}{Fastest} \\vline \&
 \\multicolumn{3}{c}{Slowest} \\vline \& \\multicolumn{2}{c}{\$\\sigma\$} \\\\
@@ -858,6 +858,7 @@ print("Slowest shared file time: $shared_file_time\n");
 print("Total bytes read and written by app (may be incorrect): $total_job_bytes\n");
 my $tmp_total_time = $slowest_uniq_time+$shared_file_time;
 print("Total absolute I/O time: $tmp_total_time\n");
+print("**NOTE: above shared and unique file times calculated using MPI-IO timers if MPI-IO interface used on a given file, POSIX timers otherwise.\n");
 # move to tmp_dir
 chdir $tmp_dir;
diff --git a/darshan-util/darshan-job-summary/share/file-access-eps.gplt b/darshan-util/darshan-job-summary/share/file-access-eps.gplt
index 01a47db..f4954fd 100644
--- a/darshan-util/darshan-job-summary/share/file-access-eps.gplt
+++ b/darshan-util/darshan-job-summary/share/file-access-eps.gplt
@@ -8,7 +8,7 @@ set xdata time
 set timefmt "%s"
 set format x "%H:%M:%S"
 set yrange [-1:ymax]
-set title "Timespan from first to last read access on independent files"
+set title "Timespan from first to last read access on independent files (POSIX)"
 set xrange ["0":runtime]
 set ytics 0,yinc,ymaxtic
 set lmargin 6
@@ -25,7 +25,7 @@ set style increment user
 plot "file-access-read.dat" using 1:2:3:4 with vectors nohead filled notitle
 set output "file-access-write.eps"
-set title "Timespan from first to last write access on independent files"
+set title "Timespan from first to last write access on independent files (POSIX)"
 # lw 3 to make lines thicker...
 plot "file-access-write.dat" using 1:2:3:4 with vectors nohead filled lt 2 notitle
@@ -34,7 +34,7 @@ set output "file-access-shared.eps"
 unset ytics
 set ylabel "All processes"
 set yrange [-1:1]
-set title "Timespan from first to last access on files shared by all processes"
+set title "Timespan from first to last access on files shared by all processes (POSIX)"
 plot "file-access-read-sh.dat" using 1:2:3:4 with vectors nohead filled lw 10 title "read", \
 "file-access-write-sh.dat" using 1:(($2)-.2):3:4 with vectors nohead filled lw 10 title "write"
diff --git a/darshan-util/darshan-job-summary/share/file-access-table.tex b/darshan-util/darshan-job-summary/share/file-access-table.tex
index f607aa2..d3d9e40 100644
--- a/darshan-util/darshan-job-summary/share/file-access-table.tex
+++ b/darshan-util/darshan-job-summary/share/file-access-table.tex
@@ -1,5 +1,5 @@
 \begin{tabular}{l|p{1.7in}r}
-\multicolumn{3}{c}{Average I/O per process} \\
+\multicolumn{3}{c}{Average I/O per process (POSIX)} \\
 \hline
  & Cumulative time spent in I/O functions (seconds) & Amount of I/O (MB) \\
 \hline
diff --git a/darshan-util/darshan-job-summary/share/pattern-eps.gplt b/darshan-util/darshan-job-summary/share/pattern-eps.gplt
index db62206..644a36d 100644
--- a/darshan-util/darshan-job-summary/share/pattern-eps.gplt
+++ b/darshan-util/darshan-job-summary/share/pattern-eps.gplt
@@ -22,7 +22,7 @@ set datafile separator ","
 set ylabel "Ops (Total, All Procs)"
 set ylabel offset character 2,0,0 font "" textcolor lt -1 rotate by 90
-set title "I/O Pattern"
+set title "POSIX I/O Pattern"
 plot  "pattern.dat" using 2:xtic(1) title "Total", \
       "" using 3 title "Sequential", \
       "" using 4 title "Consecutive"
hooks/post-receive
More information about the Darshan-commits mailing list
