[Darshan-commits] [Darshan] branch, dev-modular, updated. darshan-2.3.1-189-g550977d
Service Account
git at mcs.anl.gov
Thu Sep 24 09:41:28 CDT 2015
This is an automated email from the git hooks/post-receive script. It was
generated because a ref change was pushed to the repository containing
the project "".
The branch, dev-modular has been updated
via 550977d1a68c464b873b2b6f1a321062c59abf71 (commit)
via 773a085a2c0623c0172e66db4658d4a8539ae311 (commit)
from da0aaec641c2c4fa48d1079ff34679a3aec227ab (commit)
Those revisions listed above that are new to this repository have
not appeared on any other notification email; so we list those
revisions in full, below.
- Log -----------------------------------------------------------------
commit 550977d1a68c464b873b2b6f1a321062c59abf71
Author: Shane Snyder <ssnyder at mcs.anl.gov>
Date: Thu Sep 24 09:41:01 2015 -0500
updated darshan-util documentation for dev-modular
commit 773a085a2c0623c0172e66db4658d4a8539ae311
Date: Thu Sep 24 09:39:32 2015 -0500
clean up utilities output and minor bug fixes
Summary of changes:
darshan-util/configure | 4035 ++++++++------------
.../bin/darshan-job-summary.pl.in | 6 +
darshan-util/darshan-logutils.h | 2 +-
darshan-util/darshan-parser.c | 17 +-
darshan-util/darshan-summary-per-file.sh | 4 +-
darshan-util/darshan-util-config.h.in | 3 +
darshan-util/doc/darshan-util.txt | 329 +-
7 files changed, 1748 insertions(+), 2648 deletions(-)
Diff of changes:
diff --git a/darshan-util/configure b/darshan-util/configure
index 05c9524..b96c730 100755
--- a/darshan-util/configure
+++ b/darshan-util/configure
@@ -1,18 +1,20 @@
#! /bin/sh
# Guess values for system-dependent variables and create Makefiles.
-# Generated by GNU Autoconf 2.63 for darshan-util 3.0.0-pre1.
+# Generated by GNU Autoconf 2.69 for darshan-util 3.0.0-pre1.
+# Copyright (C) 1992-1996, 1998-2012 Free Software Foundation, Inc.
-# Copyright (C) 1992, 1993, 1994, 1995, 1996, 1998, 1999, 2000, 2001,
-# 2002, 2003, 2004, 2005, 2006, 2007, 2008 Free Software Foundation, Inc.
# This configure script is free software; the Free Software Foundation
# gives unlimited permission to copy, distribute and modify it.
-## M4sh Initialization. ##
+## M4sh Initialization. ##
# Be more Bourne compatible
DUALCASE=1; export DUALCASE # for MKS sh
-if test -n "${ZSH_VERSION+set}" && (emulate sh) >/dev/null 2>&1; then
+if test -n "${ZSH_VERSION+set}" && (emulate sh) >/dev/null 2>&1; then :
emulate sh
NULLCMD=:
# Pre-4.2 versions of Zsh do word splitting on ${1+"$@"}, which
@@ -20,23 +22,15 @@ if test -n "${ZSH_VERSION+set}" && (emulate sh) >/dev/null 2>&1; then
alias -g '${1+"$@"}'='"$@"'
setopt NO_GLOB_SUBST
else
- case `(set -o) 2>/dev/null` in
- *posix*) set -o posix ;;
+ case `(set -o) 2>/dev/null` in #(
+ *posix*) :
+ set -o posix ;; #(
esac
fi
-# PATH needs CR
-# Avoid depending upon Character Ranges.
-as_cr_letters='abcdefghijklmnopqrstuvwxyz'
-as_cr_LETTERS='ABCDEFGHIJKLMNOPQRSTUVWXYZ'
-as_cr_Letters=$as_cr_letters$as_cr_LETTERS
-as_cr_digits='0123456789'
-as_cr_alnum=$as_cr_Letters$as_cr_digits
as_nl='
export as_nl
@@ -44,7 +38,13 @@ export as_nl
as_echo='\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\'
as_echo=$as_echo$as_echo$as_echo$as_echo$as_echo
as_echo=$as_echo$as_echo$as_echo$as_echo$as_echo$as_echo
-if (test "X`printf %s $as_echo`" = "X$as_echo") 2>/dev/null; then
+# Prefer a ksh shell builtin over an external printf program on Solaris,
+# but without wasting forks for bash or zsh.
+if test -z "$BASH_VERSION$ZSH_VERSION" \
+ && (test "X`print -r -- $as_echo`" = "X$as_echo") 2>/dev/null; then
+ as_echo='print -r --'
+ as_echo_n='print -rn --'
+elif (test "X`printf %s $as_echo`" = "X$as_echo") 2>/dev/null; then
as_echo='printf %s\n'
as_echo_n='printf %s'
else
@@ -55,7 +55,7 @@ else
as_echo_body='eval expr "X$1" : "X\\(.*\\)"'
as_echo_n_body='eval
arg=$1;
- case $arg in
+ case $arg in #(
*"$as_nl"*)
expr "X$arg" : "X\\(.*\\)$as_nl";
arg=`expr "X$arg" : ".*$as_nl\\(.*\\)"`;;
@@ -78,13 +78,6 @@ if test "${PATH_SEPARATOR+set}" != set; then
fi
-# Support unset when possible.
-if ( (MAIL=60; unset MAIL) || exit) >/dev/null 2>&1; then
- as_unset=unset
-else
- as_unset=false
-fi
# IFS
# We need space, tab and new line, in precisely that order. Quoting is
@@ -94,15 +87,16 @@ fi
IFS=" "" $as_nl"
# Find who we are. Look in the path if we contain no directory separator.
-case $0 in
+as_myself=
+case $0 in #((
*[\\/]* ) as_myself=$0 ;;
*) as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
for as_dir in $PATH
do
IFS=$as_save_IFS
test -z "$as_dir" && as_dir=.
- test -r "$as_dir/$0" && as_myself=$as_dir/$0 && break
-done
+ test -r "$as_dir/$0" && as_myself=$as_dir/$0 && break
+ done
IFS=$as_save_IFS
@@ -114,12 +108,16 @@ if test "x$as_myself" = x; then
fi
if test ! -f "$as_myself"; then
$as_echo "$as_myself: error: cannot find myself; rerun with an absolute file name" >&2
- { (exit 1); exit 1; }
+ exit 1
fi
-# Work around bugs in pre-3.0 UWIN ksh.
-for as_var in ENV MAIL MAILPATH
-do ($as_unset $as_var) >/dev/null 2>&1 && $as_unset $as_var
+# Unset variables that we do not need and which cause bugs (e.g. in
+# pre-3.0 UWIN ksh). But do not cause bugs in bash 2.01; the "|| exit 1"
+# suppresses any "Segmentation fault" message there. '((' could
+# trigger a bug in pdksh 5.2.14.
+for as_var in BASH_ENV ENV MAIL MAILPATH
+do eval test x\${$as_var+set} = xset \
+ && ( (unset $as_var) || exit 1) >/dev/null 2>&1 && unset $as_var || :
done
PS1='$ '
PS2='> '
@@ -131,330 +129,344 @@ export LC_ALL
LANGUAGE=C
export LANGUAGE
-# Required to use basename.
-if expr a : '\(a\)' >/dev/null 2>&1 &&
- test "X`expr 00001 : '.*\(...\)'`" = X001; then
- as_expr=expr
-else
- as_expr=false
-fi
-if (basename -- /) >/dev/null 2>&1 && test "X`basename -- / 2>&1`" = "X/"; then
- as_basename=basename
-else
- as_basename=false
-fi
-# Name of the executable.
-as_me=`$as_basename -- "$0" ||
-$as_expr X/"$0" : '.*/\([^/][^/]*\)/*$' \| \
- X"$0" : 'X\(//\)$' \| \
- X"$0" : 'X\(/\)' \| . 2>/dev/null ||
-$as_echo X/"$0" |
- sed '/^.*\/\([^/][^/]*\)\/*$/{
- s//\1/
- q
- /^X\/\(\/\/\)$/{
- s//\1/
- q
- /^X\/\(\/\).*/{
- s//\1/
- q
- s/.*/./; q'`
# CDPATH.
-$as_unset CDPATH
+(unset CDPATH) >/dev/null 2>&1 && unset CDPATH
+# Use a proper internal environment variable to ensure we don't fall
+ # into an infinite loop, continuously re-executing ourselves.
+ if test x"${_as_can_reexec}" != xno && test "x$CONFIG_SHELL" != x; then
+ _as_can_reexec=no; export _as_can_reexec;
+ # We cannot yet assume a decent shell, so we have to provide a
+# neutralization value for shells without unset; and this also
+# works around shells that cannot unset nonexistent variables.
+# Preserve -v and -x to the replacement shell.
+BASH_ENV=/dev/null
+ENV=/dev/null
+(unset BASH_ENV) >/dev/null 2>&1 && unset BASH_ENV ENV
+case $- in # ((((
+ *v*x* | *x*v* ) as_opts=-vx ;;
+ *v* ) as_opts=-v ;;
+ *x* ) as_opts=-x ;;
+ * ) as_opts= ;;
+esac
+exec $CONFIG_SHELL $as_opts "$as_myself" ${1+"$@"}
+# Admittedly, this is quite paranoid, since all the known shells bail
+# out after a failed `exec'.
+$as_echo "$0: could not re-execute with $CONFIG_SHELL" >&2
+as_fn_exit 255
+ fi
+ # We don't want this to propagate to other subprocesses.
+ { _as_can_reexec=; unset _as_can_reexec;}
if test "x$CONFIG_SHELL" = x; then
- if (eval ":") 2>/dev/null; then
- as_have_required=yes
+ as_bourne_compatible="if test -n \"\${ZSH_VERSION+set}\" && (emulate sh) >/dev/null 2>&1; then :
+ emulate sh
+ NULLCMD=:
+ # Pre-4.2 versions of Zsh do word splitting on \${1+\"\$@\"}, which
+ # is contrary to our usage. Disable this feature.
+ alias -g '\${1+\"\$@\"}'='\"\$@\"'
+ setopt NO_GLOB_SUBST
else
- as_have_required=no
+ case \`(set -o) 2>/dev/null\` in #(
+ *posix*) :
+esac
fi
- if test $as_have_required = yes && (eval ":
-(as_func_return () {
- (exit \$1)
-as_func_success () {
- as_func_return 0
-as_func_failure () {
- as_func_return 1
-as_func_ret_success () {
- return 0
-as_func_ret_failure () {
- return 1
+ as_required="as_fn_return () { (exit \$1); }
+as_fn_success () { as_fn_return 0; }
+as_fn_failure () { as_fn_return 1; }
+as_fn_ret_success () { return 0; }
+as_fn_ret_failure () { return 1; }
exitcode=0
-if as_func_success; then
-else
- exitcode=1
- echo as_func_success failed.
-fi
-if as_func_failure; then
- exitcode=1
- echo as_func_failure succeeded.
-fi
-if as_func_ret_success; then
-else
- exitcode=1
- echo as_func_ret_success failed.
-fi
-if as_func_ret_failure; then
- exitcode=1
- echo as_func_ret_failure succeeded.
-fi
-if ( set x; as_func_ret_success y && test x = \"\$1\" ); then
+as_fn_success || { exitcode=1; echo as_fn_success failed.; }
+as_fn_failure && { exitcode=1; echo as_fn_failure succeeded.; }
+as_fn_ret_success || { exitcode=1; echo as_fn_ret_success failed.; }
+as_fn_ret_failure && { exitcode=1; echo as_fn_ret_failure succeeded.; }
+if ( set x; as_fn_ret_success y && test x = \"\$1\" ); then :
+else
+ exitcode=1; echo positional parameters were not saved.
+fi
+test x\$exitcode = x0 || exit 1
+test -x / || exit 1"
+ as_suggested=" as_lineno_1=";as_suggested=$as_suggested$LINENO;as_suggested=$as_suggested" as_lineno_1a=\$LINENO
+ as_lineno_2=";as_suggested=$as_suggested$LINENO;as_suggested=$as_suggested" as_lineno_2a=\$LINENO
+ eval 'test \"x\$as_lineno_1'\$as_run'\" != \"x\$as_lineno_2'\$as_run'\" &&
+ test \"x\`expr \$as_lineno_1'\$as_run' + 1\`\" = \"x\$as_lineno_2'\$as_run'\"' || exit 1
+test \$(( 1 + 1 )) = 2 || exit 1"
+ if (eval "$as_required") 2>/dev/null; then :
+ as_have_required=yes
else
- exitcode=1
- echo positional parameters were not saved.
+ as_have_required=no
fi
+ if test x$as_have_required = xyes && (eval "$as_suggested") 2>/dev/null; then :
-test \$exitcode = 0) || { (exit 1); exit 1; }
- as_lineno_1=\$LINENO
- as_lineno_2=\$LINENO
- test \"x\$as_lineno_1\" != \"x\$as_lineno_2\" &&
- test \"x\`expr \$as_lineno_1 + 1\`\" = \"x\$as_lineno_2\") || { (exit 1); exit 1; }
-") 2> /dev/null; then
else
- as_candidate_shells=
- as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
+ as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
+as_found=false
for as_dir in /bin$PATH_SEPARATOR/usr/bin$PATH_SEPARATOR$PATH
do
IFS=$as_save_IFS
- case $as_dir in
+ as_found=:
+ case $as_dir in #(
for as_base in sh bash ksh sh5; do
- as_candidate_shells="$as_candidate_shells $as_dir/$as_base"
+ # Try only shells that exist, to save several forks.
+ as_shell=$as_dir/$as_base
+ if { test -f "$as_shell" || test -f "$as_shell.exe"; } &&
+ { $as_echo "$as_bourne_compatible""$as_required" | as_run=a "$as_shell"; } 2>/dev/null; then :
+ CONFIG_SHELL=$as_shell as_have_required=yes
+ if { $as_echo "$as_bourne_compatible""$as_suggested" | as_run=a "$as_shell"; } 2>/dev/null; then :
+ break 2
+fi
+fi
done;;
esac
+ as_found=false
done
+$as_found || { if { test -f "$SHELL" || test -f "$SHELL.exe"; } &&
+ { $as_echo "$as_bourne_compatible""$as_required" | as_run=a "$SHELL"; } 2>/dev/null; then :
+ CONFIG_SHELL=$SHELL as_have_required=yes
+fi; }
IFS=$as_save_IFS
- for as_shell in $as_candidate_shells $SHELL; do
- # Try only shells that exist, to save several forks.
- if { test -f "$as_shell" || test -f "$as_shell.exe"; } &&
- { ("$as_shell") 2> /dev/null <<\_ASEOF
- emulate sh
- NULLCMD=:
- # Pre-4.2 versions of Zsh do word splitting on ${1+"$@"}, which
- # is contrary to our usage. Disable this feature.
- alias -g '${1+"$@"}'='"$@"'
- setopt NO_GLOB_SUBST
-else
-esac
-fi
-_ASEOF
-}; then
- CONFIG_SHELL=$as_shell
- if { "$as_shell" 2> /dev/null <<\_ASEOF
- emulate sh
- NULLCMD=:
-else
+ if test "x$CONFIG_SHELL" != x; then :
+ export CONFIG_SHELL
+BASH_ENV=/dev/null
+ENV=/dev/null
+case $- in # ((((
+ * ) as_opts= ;;
esac
-fi
- (exit $1)
- as_func_return 0
- as_func_return 1
- return 0
- return 1
-exitcode=0
-else
- exitcode=1
-fi
- exitcode=1
-fi
-else
- exitcode=1
-fi
- exitcode=1
-fi
-if ( set x; as_func_ret_success y && test x = "$1" ); then
-else
- exitcode=1
+exit 255
+fi
+ if test x$as_have_required = xno; then :
+ $as_echo "$0: This script requires a shell more modern than all"
+ $as_echo "$0: the shells that I found on your system."
+ if test x${ZSH_VERSION+set} = xset ; then
+ $as_echo "$0: In particular, zsh $ZSH_VERSION has bugs and should"
+ $as_echo "$0: be upgraded to zsh 4.3.4 or later."
+ else
+ $as_echo "$0: Please tell bug-autoconf at gnu.org about your system,
+$0: including any error possibly output before this
+$0: message. Then install a modern shell, or manually run
+$0: the script under such a shell if you do have one."
+ fi
+ exit 1
fi
-test $exitcode = 0) || { (exit 1); exit 1; }
- as_lineno_1=$LINENO
- as_lineno_2=$LINENO
- test "x$as_lineno_1" != "x$as_lineno_2" &&
- test "x`expr $as_lineno_1 + 1`" = "x$as_lineno_2") || { (exit 1); exit 1; }
-_ASEOF
-}; then
- break
fi
fi
+SHELL=${CONFIG_SHELL-/bin/sh}
+export SHELL
+# Unset more variables known to interfere with behavior of common tools.
+CLICOLOR_FORCE= GREP_OPTIONS=
+unset CLICOLOR_FORCE GREP_OPTIONS
- done
- if test "x$CONFIG_SHELL" != x; then
- for as_var in BASH_ENV ENV
- do ($as_unset $as_var) >/dev/null 2>&1 && $as_unset $as_var
- done
- export CONFIG_SHELL
- exec "$CONFIG_SHELL" "$as_myself" ${1+"$@"}
-fi
+## M4sh Shell Functions. ##
+# as_fn_unset VAR
+# Portably unset VAR.
+as_fn_unset ()
+ { eval $1=; unset $1;}
+as_unset=as_fn_unset
+# as_fn_set_status STATUS
+# Set $? to STATUS, without forking.
+as_fn_set_status ()
+ return $1
+} # as_fn_set_status
- if test $as_have_required = no; then
- echo This script requires a shell more modern than all the
- echo shells that I found on your system. Please install a
- echo modern shell, or manually run the script under such a
- echo shell if you do have one.
-fi
+# as_fn_exit STATUS
+# Exit the shell with STATUS, even in a "trap 0" or "set -e" context.
+as_fn_exit ()
+ set +e
+ as_fn_set_status $1
+ exit $1
+} # as_fn_exit
+# as_fn_mkdir_p
+# Create "$as_dir" as a directory, including parents if necessary.
+as_fn_mkdir_p ()
+ -*) as_dir=./$as_dir;;
+ esac
+ test -d "$as_dir" || eval $as_mkdir_p || {
+ as_dirs=
+ while :; do
+ *\'*) as_qdir=`$as_echo "$as_dir" | sed "s/'/'\\\\\\\\''/g"`;; #'(
+ *) as_qdir=$as_dir;;
+ esac
+ as_dirs="'$as_qdir' $as_dirs"
+ as_dir=`$as_dirname -- "$as_dir" ||
+$as_expr X"$as_dir" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
+ X"$as_dir" : 'X\(//\)[^/]' \| \
+ X"$as_dir" : 'X\(//\)$' \| \
+ X"$as_dir" : 'X\(/\)' \| . 2>/dev/null ||
+$as_echo X"$as_dir" |
+ sed '/^X\(.*[^/]\)\/\/*[^/][^/]*\/*$/{
+ s//\1/
+ q
+ /^X\(\/\/\)[^/].*/{
+ s//\1/
+ q
+ /^X\(\/\/\)$/{
+ s//\1/
+ q
+ /^X\(\/\).*/{
+ s//\1/
+ q
+ s/.*/./; q'`
+ test -d "$as_dir" && break
+ done
+ test -z "$as_dirs" || eval "mkdir $as_dirs"
+ } || test -d "$as_dir" || as_fn_error $? "cannot create directory $as_dir"
-fi
-fi
+} # as_fn_mkdir_p
+# as_fn_executable_p FILE
+# Test if FILE is an executable regular file.
+as_fn_executable_p ()
+ test -f "$1" && test -x "$1"
+} # as_fn_executable_p
+# as_fn_append VAR VALUE
+# Append the text in VALUE to the end of the definition contained in VAR. Take
+# advantage of any shell optimizations that allow amortized linear growth over
+# repeated appends, instead of the typical quadratic growth present in naive
+# implementations.
+if (eval "as_var=1; as_var+=2; test x\$as_var = x12") 2>/dev/null; then :
+ eval 'as_fn_append ()
+ eval $1+=\$2
+else
+ as_fn_append ()
+ eval $1=\$$1\$2
+fi # as_fn_append
+# as_fn_arith ARG...
+# Perform arithmetic evaluation on the ARGs, and store the result in the
+# global $as_val. Take advantage of shells that can avoid forks. The arguments
+# must be portable across $(()) and expr.
+if (eval "test \$(( 1 + 1 )) = 2") 2>/dev/null; then :
+ eval 'as_fn_arith ()
+ as_val=$(( $* ))
+else
+ as_fn_arith ()
+ as_val=`expr "$@" || test $? -eq 1`
+fi # as_fn_arith
-(eval "as_func_return () {
- (exit \$1)
- as_func_return 0
- as_func_return 1
- return 0
- return 1
+# as_fn_error STATUS ERROR [LINENO LOG_FD]
+# Output "`basename $0`: error: ERROR" to stderr. If LINENO and LOG_FD are
+# provided, also output the error to LOG_FD, referencing LINENO. Then exit the
+# script with STATUS, using 1 if that was 0.
+as_fn_error ()
+ as_status=$1; test $as_status -eq 0 && as_status=1
+ if test "$4"; then
+ as_lineno=${as_lineno-"$3"} as_lineno_stack=as_lineno_stack=$as_lineno_stack
+ $as_echo "$as_me:${as_lineno-$LINENO}: error: $2" >&$4
+ fi
+ $as_echo "$as_me: error: $2" >&2
+ as_fn_exit $as_status
+} # as_fn_error
-exitcode=0
+if expr a : '\(a\)' >/dev/null 2>&1 &&
+ test "X`expr 00001 : '.*\(...\)'`" = X001; then
+ as_expr=expr
else
- exitcode=1
-fi
- exitcode=1
+ as_expr=false
fi
+if (basename -- /) >/dev/null 2>&1 && test "X`basename -- / 2>&1`" = "X/"; then
+ as_basename=basename
else
- exitcode=1
-fi
- exitcode=1
+ as_basename=false
fi
+if (as_dir=`dirname -- /` && test "X$as_dir" = X/) >/dev/null 2>&1; then
+ as_dirname=dirname
else
- exitcode=1
+ as_dirname=false
fi
-test \$exitcode = 0") || {
- echo No shell found that supports shell functions.
- echo Please tell bug-autoconf at gnu.org about your system,
- echo including any error possibly output before this message.
- echo This can help us improve future autoconf versions.
- echo Configuration will now proceed without shell functions.
+as_me=`$as_basename -- "$0" ||
+$as_expr X/"$0" : '.*/\([^/][^/]*\)/*$' \| \
+ X"$0" : 'X\(//\)$' \| \
+ X"$0" : 'X\(/\)' \| . 2>/dev/null ||
+$as_echo X/"$0" |
+ sed '/^.*\/\([^/][^/]*\)\/*$/{
+ s//\1/
+ q
+ /^X\/\(\/\/\)$/{
+ s//\1/
+ q
+ /^X\/\(\/\).*/{
+ s//\1/
+ q
+ s/.*/./; q'`
+# Avoid depending upon Character Ranges.
+as_cr_letters='abcdefghijklmnopqrstuvwxyz'
+as_cr_LETTERS='ABCDEFGHIJKLMNOPQRSTUVWXYZ'
+as_cr_Letters=$as_cr_letters$as_cr_LETTERS
+as_cr_digits='0123456789'
+as_cr_alnum=$as_cr_Letters$as_cr_digits
- test "x`expr $as_lineno_1 + 1`" = "x$as_lineno_2" || {
- # Create $as_me.lineno as a copy of $as_myself, but with $LINENO
- # uniformly replaced by the line number. The first 'sed' inserts a
- # line-number line after each line using $LINENO; the second 'sed'
- # does the real work. The second script uses 'N' to pair each
- # line-number line with the line containing $LINENO, and appends
- # trailing '-' during substitution so that $LINENO is not a special
- # case at line end.
- # (Raja R Harinath suggested sed '=', and Paul Eggert wrote the
- # scripts with optimization help from Paolo Bonzini. Blame Lee
- # E. McMahon (1931-1989) for sed's syntax. :-)
+ as_lineno_1=$LINENO as_lineno_1a=$LINENO
+ as_lineno_2=$LINENO as_lineno_2a=$LINENO
+ eval 'test "x$as_lineno_1'$as_run'" != "x$as_lineno_2'$as_run'" &&
+ test "x`expr $as_lineno_1'$as_run' + 1`" = "x$as_lineno_2'$as_run'"' || {
+ # Blame Lee E. McMahon (1931-1989) for sed's syntax. :-)
sed -n '
p
/[$]LINENO/=
@@ -471,9 +483,12 @@ test \$exitcode = 0") || {
s/-\n.*//
' >$as_me.lineno &&
chmod +x "$as_me.lineno" ||
- { $as_echo "$as_me: error: cannot create $as_me.lineno; rerun with a POSIX shell" >&2
- { (exit 1); exit 1; }; }
+ { $as_echo "$as_me: error: cannot create $as_me.lineno; rerun with a POSIX shell" >&2; as_fn_exit 1; }
+ # If we had to re-execute with $CONFIG_SHELL, we're ensured to have
+ # already done that, so ensure we don't try to do so again and fall
+ # in an infinite loop. This has already happened in practice.
# Don't try to exec as it changes $[0], causing all sort of problems
# (the dirname of $[0] is not the place where we might find the
# original and so on. Autoconf is especially sensitive to this).
@@ -482,29 +497,18 @@ test \$exitcode = 0") || {
exit
-if (as_dir=`dirname -- /` && test "X$as_dir" = X/) >/dev/null 2>&1; then
- as_dirname=dirname
-else
- as_dirname=false
-fi
ECHO_C= ECHO_N= ECHO_T=
-case `echo -n x` in
+case `echo -n x` in #(((((
-n*)
- case `echo 'x\c'` in
+ case `echo 'xy\c'` in
*c*) ECHO_T=' ';; # ECHO_T is single tab character.
- *) ECHO_C='\c';;
+ xy) ECHO_C='\c';;
+ *) echo `echo ksh88 bug on AIX 6.1` > /dev/null
+ ECHO_T=' ';;
esac;;
ECHO_N='-n';;
esac
- as_expr=expr
-else
- as_expr=false
-fi
rm -f conf$$ conf$$.exe conf$$.file
if test -d conf$$.dir; then
@@ -519,49 +523,29 @@ if (echo >conf$$.file) 2>/dev/null; then
# ... but there are two gotchas:
# 1) On MSYS, both `ln -s file dir' and `ln file dir' fail.
# 2) DJGPP < 2.04 has no symlinks; `ln -s' creates a wrapper executable.
- # In both cases, we have to default to `cp -p'.
+ # In both cases, we have to default to `cp -pR'.
ln -s conf$$.file conf$$.dir 2>/dev/null && test ! -f conf$$.exe ||
- as_ln_s='cp -p'
+ as_ln_s='cp -pR'
elif ln conf$$.file conf$$ 2>/dev/null; then
as_ln_s=ln
else
- as_ln_s='cp -p'
+ as_ln_s='cp -pR'
fi
else
- as_ln_s='cp -p'
+ as_ln_s='cp -pR'
fi
rm -f conf$$ conf$$.exe conf$$.dir/conf$$.file conf$$.file
rmdir conf$$.dir 2>/dev/null
if mkdir -p . 2>/dev/null; then
- as_mkdir_p=:
+ as_mkdir_p='mkdir -p "$as_dir"'
else
test -d ./-p && rmdir ./-p
as_mkdir_p=false
fi
-if test -x / >/dev/null 2>&1; then
- as_test_x='test -x'
-else
- if ls -dL / >/dev/null 2>&1; then
- as_ls_L_option=L
- else
- as_ls_L_option=
- fi
- as_test_x='
- eval sh -c '\''
- if test -d "$1"; then
- test -d "$1/.";
- else
- case $1 in
- -*)set "./$1";;
- esac;
- case `ls -ld'$as_ls_L_option' "$1" 2>/dev/null` in
- ???[sx]*):;;*)false;;esac;fi
- '\'' sh
-fi
-as_executable_p=$as_test_x
+as_test_x='test -x'
+as_executable_p=as_fn_executable_p
# Sed expression to map a string onto a valid CPP name.
as_tr_cpp="eval sed 'y%*$as_cr_letters%P$as_cr_LETTERS%;s%[^_$as_cr_alnum]%_%g'"
@@ -570,11 +554,11 @@ as_tr_cpp="eval sed 'y%*$as_cr_letters%P$as_cr_LETTERS%;s%[^_$as_cr_alnum]%_%g'"
as_tr_sh="eval sed 'y%*+%pp%;s%[^_$as_cr_alnum]%_%g'"
-exec 7<&0 </dev/null 6>&1
+test -n "$DJDIR" || exec 7<&0 </dev/null
+exec 6>&1
# Name of the host.
-# hostname on some systems (SVR3.2, Linux) returns a bogus exit status,
+# hostname on some systems (SVR3.2, old GNU/Linux) returns a bogus exit status,
# so uname gets run too.
ac_hostname=`(hostname || uname -n) 2>/dev/null | sed 1q`
@@ -589,7 +573,6 @@ cross_compiling=no
subdirs=
MFLAGS=
MAKEFLAGS=
-SHELL=${CONFIG_SHELL-/bin/sh}
# Identity of this package.
PACKAGE_NAME='darshan-util'
@@ -597,6 +580,7 @@ PACKAGE_TARNAME='darshan-util'
PACKAGE_VERSION='3.0.0-pre1'
PACKAGE_STRING='darshan-util 3.0.0-pre1'
PACKAGE_BUGREPORT=''
+PACKAGE_URL=''
ac_unique_file="darshan-logutils.h"
# Factoring default headers for most tests.
@@ -688,6 +672,7 @@ bindir
program_transform_name
prefix
exec_prefix
+PACKAGE_URL
PACKAGE_BUGREPORT
PACKAGE_STRING
PACKAGE_VERSION
@@ -773,8 +758,9 @@ do
fi
case $ac_option in
- *=*) ac_optarg=`expr "X$ac_option" : '[^=]*=\(.*\)'` ;;
- *) ac_optarg=yes ;;
+ *=?*) ac_optarg=`expr "X$ac_option" : '[^=]*=\(.*\)'` ;;
+ *=) ac_optarg= ;;
+ *) ac_optarg=yes ;;
esac
# Accept the important Cygnus configure options, so we can diagnose typos.
@@ -819,8 +805,7 @@ do
ac_useropt=`expr "x$ac_option" : 'x-*disable-\(.*\)'`
# Reject names that are not valid shell variable names.
expr "x$ac_useropt" : ".*[^-+._$as_cr_alnum]" >/dev/null &&
- { $as_echo "$as_me: error: invalid feature name: $ac_useropt" >&2
+ as_fn_error $? "invalid feature name: $ac_useropt"
ac_useropt_orig=$ac_useropt
ac_useropt=`$as_echo "$ac_useropt" | sed 's/[-+.]/_/g'`
case $ac_user_opts in
@@ -846,8 +831,7 @@ do
ac_useropt=`expr "x$ac_option" : 'x-*enable-\([^=]*\)'`
@@ -1051,8 +1035,7 @@ do
ac_useropt=`expr "x$ac_option" : 'x-*with-\([^=]*\)'`
- { $as_echo "$as_me: error: invalid package name: $ac_useropt" >&2
+ as_fn_error $? "invalid package name: $ac_useropt"
@@ -1068,8 +1051,7 @@ do
ac_useropt=`expr "x$ac_option" : 'x-*without-\(.*\)'`
@@ -1099,17 +1081,17 @@ do
| --x-librar=* | --x-libra=* | --x-libr=* | --x-lib=* | --x-li=* | --x-l=*)
x_libraries=$ac_optarg ;;
- -*) { $as_echo "$as_me: error: unrecognized option: $ac_option
-Try \`$0 --help' for more information." >&2
+ -*) as_fn_error $? "unrecognized option: \`$ac_option'
+Try \`$0 --help' for more information"
ac_envvar=`expr "x$ac_option" : 'x\([^=]*\)='`
- expr "x$ac_envvar" : ".*[^_$as_cr_alnum]" >/dev/null &&
- { $as_echo "$as_me: error: invalid variable name: $ac_envvar" >&2
+ case $ac_envvar in #(
+ '' | [0-9]* | *[!_$as_cr_alnum]* )
+ as_fn_error $? "invalid variable name: \`$ac_envvar'" ;;
+ esac
eval $ac_envvar=\$ac_optarg
export $ac_envvar ;;
@@ -1118,7 +1100,7 @@ Try \`$0 --help' for more information." >&2
$as_echo "$as_me: WARNING: you should use --build, --host, --target" >&2
expr "x$ac_option" : ".*[^-._$as_cr_alnum]" >/dev/null &&
$as_echo "$as_me: WARNING: invalid host type: $ac_option" >&2
- : ${build_alias=$ac_option} ${host_alias=$ac_option} ${target_alias=$ac_option}
+ : "${build_alias=$ac_option} ${host_alias=$ac_option} ${target_alias=$ac_option}"
esac
@@ -1126,15 +1108,13 @@ done
if test -n "$ac_prev"; then
ac_option=--`echo $ac_prev | sed 's/_/-/g'`
- { $as_echo "$as_me: error: missing argument to $ac_option" >&2
+ as_fn_error $? "missing argument to $ac_option"
fi
if test -n "$ac_unrecognized_opts"; then
case $enable_option_checking in
no) ;;
- fatal) { $as_echo "$as_me: error: unrecognized options: $ac_unrecognized_opts" >&2
- { (exit 1); exit 1; }; } ;;
+ fatal) as_fn_error $? "unrecognized options: $ac_unrecognized_opts" ;;
*) $as_echo "$as_me: WARNING: unrecognized options: $ac_unrecognized_opts" >&2 ;;
esac
fi
@@ -1157,8 +1137,7 @@ do
[\\/$]* | ?:[\\/]* ) continue;;
NONE | '' ) case $ac_var in *prefix ) continue;; esac;;
esac
- { $as_echo "$as_me: error: expected an absolute directory name for --$ac_var: $ac_val" >&2
+ as_fn_error $? "expected an absolute directory name for --$ac_var: $ac_val"
done
# There might be people who depend on the old broken behavior: `$host'
@@ -1172,8 +1151,6 @@ target=$target_alias
if test "x$host_alias" != x; then
if test "x$build_alias" = x; then
cross_compiling=maybe
- $as_echo "$as_me: WARNING: If you wanted to set the --build type, don't use --host.
- If a cross compiler is detected then cross compile mode will be used." >&2
elif test "x$build_alias" != "x$host_alias"; then
cross_compiling=yes
fi
@@ -1188,11 +1165,9 @@ test "$silent" = yes && exec 6>/dev/null
ac_pwd=`pwd` && test -n "$ac_pwd" &&
ac_ls_di=`ls -di .` &&
ac_pwd_ls_di=`cd "$ac_pwd" && ls -di .` ||
- { $as_echo "$as_me: error: working directory cannot be determined" >&2
+ as_fn_error $? "working directory cannot be determined"
test "X$ac_ls_di" = "X$ac_pwd_ls_di" ||
- { $as_echo "$as_me: error: pwd does not report name of working directory" >&2
+ as_fn_error $? "pwd does not report name of working directory"
# Find the source files, if location was not specified.
@@ -1231,13 +1206,11 @@ else
fi
if test ! -r "$srcdir/$ac_unique_file"; then
test "$ac_srcdir_defaulted" = yes && srcdir="$ac_confdir or .."
- { $as_echo "$as_me: error: cannot find sources ($ac_unique_file) in $srcdir" >&2
+ as_fn_error $? "cannot find sources ($ac_unique_file) in $srcdir"
fi
ac_msg="sources are in $srcdir, but \`cd $srcdir' does not work"
ac_abs_confdir=`(
- cd "$srcdir" && test -r "./$ac_unique_file" || { $as_echo "$as_me: error: $ac_msg" >&2
+ cd "$srcdir" && test -r "./$ac_unique_file" || as_fn_error $? "$ac_msg"
pwd)`
# When building in place, set srcdir=.
if test "$ac_abs_confdir" = "$ac_pwd"; then
@@ -1277,7 +1250,7 @@ Configuration:
--help=short display options specific to this package
--help=recursive display the short help of all the included packages
-V, --version display version information and exit
- -q, --quiet, --silent do not print \`checking...' messages
+ -q, --quiet, --silent do not print \`checking ...' messages
--cache-file=FILE cache test results in FILE [disabled]
-C, --config-cache alias for \`--cache-file=config.cache'
-n, --no-create do not create output files
@@ -1350,13 +1323,14 @@ Some influential environment variables:
LDFLAGS linker flags, e.g. -L<lib dir> if you have libraries in a
nonstandard directory <lib dir>
LIBS libraries to pass to the linker, e.g. -l<library>
- CPPFLAGS C/C++/Objective C preprocessor flags, e.g. -I<include dir> if
+ CPPFLAGS (Objective) C/C++ preprocessor flags, e.g. -I<include dir> if
you have headers in a nonstandard directory <include dir>
CPP C preprocessor
Use these variables to override the choices made by `configure' or to help
it to find libraries and programs with nonstandard names/locations.
+Report bugs to the package provider.
_ACEOF
ac_status=$?
fi
@@ -1420,21 +1394,372 @@ test -n "$ac_init_help" && exit $ac_status
if $ac_init_version; then
cat <<\_ACEOF
darshan-util configure 3.0.0-pre1
-generated by GNU Autoconf 2.63
+generated by GNU Autoconf 2.69
-Copyright (C) 1992, 1993, 1994, 1995, 1996, 1998, 1999, 2000, 2001,
-2002, 2003, 2004, 2005, 2006, 2007, 2008 Free Software Foundation, Inc.
+Copyright (C) 2012 Free Software Foundation, Inc.
_ACEOF
exit
fi
+## Autoconf initialization. ##
+# ac_fn_c_try_compile LINENO
+# Try to compile conftest.$ac_ext, and return whether this succeeded.
+ac_fn_c_try_compile ()
+ as_lineno=${as_lineno-"$1"} as_lineno_stack=as_lineno_stack=$as_lineno_stack
+ rm -f conftest.$ac_objext
+ if { { ac_try="$ac_compile"
+case "(($ac_try" in
+ *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;;
+ *) ac_try_echo=$ac_try;;
+esac
+eval ac_try_echo="\"\$as_me:${as_lineno-$LINENO}: $ac_try_echo\""
+$as_echo "$ac_try_echo"; } >&5
+ (eval "$ac_compile") 2>conftest.err
+ ac_status=$?
+ if test -s conftest.err; then
+ grep -v '^ *+' conftest.err >conftest.er1
+ cat conftest.er1 >&5
+ mv -f conftest.er1 conftest.err
+ fi
+ $as_echo "$as_me:${as_lineno-$LINENO}: \$? = $ac_status" >&5
+ test $ac_status = 0; } && {
+ test -z "$ac_c_werror_flag" ||
+ test ! -s conftest.err
+ } && test -s conftest.$ac_objext; then :
+ ac_retval=0
+else
+ $as_echo "$as_me: failed program was:" >&5
+sed 's/^/| /' conftest.$ac_ext >&5
+ ac_retval=1
+fi
+ eval $as_lineno_stack; ${as_lineno_stack:+:} unset as_lineno
+ as_fn_set_status $ac_retval
+} # ac_fn_c_try_compile
+# ac_fn_c_try_cpp LINENO
+# Try to preprocess conftest.$ac_ext, and return whether this succeeded.
+ac_fn_c_try_cpp ()
+ if { { ac_try="$ac_cpp conftest.$ac_ext"
+esac
+ (eval "$ac_cpp conftest.$ac_ext") 2>conftest.err
+ ac_status=$?
+ fi
+ test $ac_status = 0; } > conftest.i && {
+ test -z "$ac_c_preproc_warn_flag$ac_c_werror_flag" ||
+ }; then :
+ ac_retval=0
+else
+ ac_retval=1
+fi
+} # ac_fn_c_try_cpp
+# ac_fn_c_check_header_mongrel LINENO HEADER VAR INCLUDES
+# Tests whether HEADER exists, giving a warning if it cannot be compiled using
+# the include files in INCLUDES and setting the cache variable VAR
+# accordingly.
+ac_fn_c_check_header_mongrel ()
+ if eval \${$3+:} false; then :
+ { $as_echo "$as_me:${as_lineno-$LINENO}: checking for $2" >&5
+$as_echo_n "checking for $2... " >&6; }
+if eval \${$3+:} false; then :
+ $as_echo_n "(cached) " >&6
+fi
+eval ac_res=\$$3
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_res" >&5
+$as_echo "$ac_res" >&6; }
+else
+ # Is the header compilable?
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking $2 usability" >&5
+$as_echo_n "checking $2 usability... " >&6; }
+cat confdefs.h - <<_ACEOF >conftest.$ac_ext
+/* end confdefs.h. */
+$4
+#include <$2>
+_ACEOF
+if ac_fn_c_try_compile "$LINENO"; then :
+ ac_header_compiler=yes
+else
+ ac_header_compiler=no
+fi
+rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_header_compiler" >&5
+$as_echo "$ac_header_compiler" >&6; }
+# Is the header present?
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking $2 presence" >&5
+$as_echo_n "checking $2 presence... " >&6; }
+#include <$2>
+_ACEOF
+if ac_fn_c_try_cpp "$LINENO"; then :
+ ac_header_preproc=yes
+else
+ ac_header_preproc=no
+fi
+rm -f conftest.err conftest.i conftest.$ac_ext
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_header_preproc" >&5
+$as_echo "$ac_header_preproc" >&6; }
+# So? What about this header?
+case $ac_header_compiler:$ac_header_preproc:$ac_c_preproc_warn_flag in #((
+ yes:no: )
+ { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: $2: accepted by the compiler, rejected by the preprocessor!" >&5
+$as_echo "$as_me: WARNING: $2: accepted by the compiler, rejected by the preprocessor!" >&2;}
+ { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: $2: proceeding with the compiler's result" >&5
+$as_echo "$as_me: WARNING: $2: proceeding with the compiler's result" >&2;}
+ no:yes:* )
+ { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: $2: present but cannot be compiled" >&5
+$as_echo "$as_me: WARNING: $2: present but cannot be compiled" >&2;}
+ { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: $2: check for missing prerequisite headers?" >&5
+$as_echo "$as_me: WARNING: $2: check for missing prerequisite headers?" >&2;}
+ { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: $2: see the Autoconf documentation" >&5
+$as_echo "$as_me: WARNING: $2: see the Autoconf documentation" >&2;}
+ { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: $2: section \"Present But Cannot Be Compiled\"" >&5
+$as_echo "$as_me: WARNING: $2: section \"Present But Cannot Be Compiled\"" >&2;}
+esac
+else
+ eval "$3=\$ac_header_compiler"
+fi
+eval ac_res=\$$3
+fi
+} # ac_fn_c_check_header_mongrel
+# ac_fn_c_try_run LINENO
+# Try to link conftest.$ac_ext, and return whether this succeeded. Assumes
+# that executables *can* be run.
+ac_fn_c_try_run ()
+ if { { ac_try="$ac_link"
+esac
+ (eval "$ac_link") 2>&5
+ ac_status=$?
+ test $ac_status = 0; } && { ac_try='./conftest$ac_exeext'
+ { { case "(($ac_try" in
+esac
+ (eval "$ac_try") 2>&5
+ ac_status=$?
+ test $ac_status = 0; }; }; then :
+ ac_retval=0
+else
+ $as_echo "$as_me: program exited with status $ac_status" >&5
+ ac_retval=$ac_status
+fi
+ rm -rf conftest.dSYM conftest_ipa8_conftest.oo
+} # ac_fn_c_try_run
+# ac_fn_c_check_header_compile LINENO HEADER VAR INCLUDES
+# Tests whether HEADER exists and can be compiled using the include files in
+# INCLUDES, setting the cache variable VAR accordingly.
+ac_fn_c_check_header_compile ()
+else
+ cat confdefs.h - <<_ACEOF >conftest.$ac_ext
+$4
+#include <$2>
+_ACEOF
+ eval "$3=yes"
+else
+ eval "$3=no"
+fi
+fi
+eval ac_res=\$$3
+} # ac_fn_c_check_header_compile
+# ac_fn_c_try_link LINENO
+ac_fn_c_try_link ()
+ rm -f conftest.$ac_objext conftest$ac_exeext
+esac
+ (eval "$ac_link") 2>conftest.err
+ ac_status=$?
+ fi
+ } && test -s conftest$ac_exeext && {
+ test "$cross_compiling" = yes ||
+ test -x conftest$ac_exeext
+ }; then :
+ ac_retval=0
+else
+ ac_retval=1
+fi
+ # Delete the IPA/IPO (Inter Procedural Analysis/Optimization) information
+ # created by the PGI compiler (conftest_ipa8_conftest.oo), as it would
+ # interfere with the next link command; also delete a directory that is
+ # left behind by Apple's compiler. We do this before executing the actions.
+} # ac_fn_c_try_link
+# ac_fn_c_check_func LINENO FUNC VAR
+# Tests whether FUNC exists, setting the cache variable VAR accordingly
+ac_fn_c_check_func ()
+else
+/* Define $2 to an innocuous variant, in case <limits.h> declares $2.
+ For example, HP-UX 11i <limits.h> declares gettimeofday. */
+#define $2 innocuous_$2
+/* System header to define __stub macros and hopefully few prototypes,
+ which can conflict with char $2 (); below.
+ Prefer <limits.h> to <assert.h> if __STDC__ is defined, since
+ <limits.h> exists even on freestanding compilers. */
+#ifdef __STDC__
+# include <limits.h>
+#else
+# include <assert.h>
+#endif
+#undef $2
+/* Override any GCC internal prototype to avoid an error.
+ Use char because int might match the return type of a GCC
+ builtin and then its argument prototype would still apply. */
+#ifdef __cplusplus
+extern "C"
+#endif
+char $2 ();
+/* The GNU C library defines this for functions which it implements
+ to always fail with ENOSYS. Some functions are actually named
+ something starting with __ and the normal name is an alias. */
+#if defined __stub_$2 || defined __stub___$2
+choke me
+#endif
+int
+main ()
+return $2 ();
+ return 0;
+_ACEOF
+if ac_fn_c_try_link "$LINENO"; then :
+ eval "$3=yes"
+else
+ eval "$3=no"
+fi
+rm -f core conftest.err conftest.$ac_objext \
+ conftest$ac_exeext conftest.$ac_ext
+fi
+eval ac_res=\$$3
+} # ac_fn_c_check_func
cat >config.log <<_ACEOF
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
It was created by darshan-util $as_me 3.0.0-pre1, which was
-generated by GNU Autoconf 2.63. Invocation command line was
+generated by GNU Autoconf 2.69. Invocation command line was
$ $0 $@
@@ -1470,8 +1795,8 @@ for as_dir in $PATH
do
IFS=$as_save_IFS
- $as_echo "PATH: $as_dir"
-done
+ $as_echo "PATH: $as_dir"
+ done
IFS=$as_save_IFS
} >&5
@@ -1508,9 +1833,9 @@ do
ac_arg=`$as_echo "$ac_arg" | sed "s/'/'\\\\\\\\''/g"` ;;
esac
case $ac_pass in
- 1) ac_configure_args0="$ac_configure_args0 '$ac_arg'" ;;
+ 1) as_fn_append ac_configure_args0 " '$ac_arg'" ;;
2)
- ac_configure_args1="$ac_configure_args1 '$ac_arg'"
+ as_fn_append ac_configure_args1 " '$ac_arg'"
if test $ac_must_keep_next = true; then
ac_must_keep_next=false # Got value, back to normal.
else
@@ -1526,13 +1851,13 @@ do
-* ) ac_must_keep_next=true ;;
esac
fi
- ac_configure_args="$ac_configure_args '$ac_arg'"
+ as_fn_append ac_configure_args " '$ac_arg'"
esac
done
done
-$as_unset ac_configure_args0 || test "${ac_configure_args0+set}" != set || { ac_configure_args0=; export ac_configure_args0; }
-$as_unset ac_configure_args1 || test "${ac_configure_args1+set}" != set || { ac_configure_args1=; export ac_configure_args1; }
+{ ac_configure_args0=; unset ac_configure_args0;}
+{ ac_configure_args1=; unset ac_configure_args1;}
# When interrupted or exit'd, cleanup temporary files, and complete
# config.log. We remove comments because anyway the quotes in there
@@ -1544,11 +1869,9 @@ trap 'exit_status=$?
echo
- cat <<\_ASBOX
+ $as_echo "## ---------------- ##
## Cache variables. ##
-_ASBOX
echo
# The following way of writing the cache mishandles newlines in values,
@@ -1557,13 +1880,13 @@ _ASBOX
case $ac_val in #(
*${as_nl}*)
case $ac_var in #(
- *_cv_*) { $as_echo "$as_me:$LINENO: WARNING: cache variable $ac_var contains a newline" >&5
+ *_cv_*) { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: cache variable $ac_var contains a newline" >&5
$as_echo "$as_me: WARNING: cache variable $ac_var contains a newline" >&2;} ;;
esac
case $ac_var in #(
_ | IFS | as_nl) ;; #(
BASH_ARGV | BASH_SOURCE) eval $ac_var= ;; #(
- *) $as_unset $ac_var ;;
+ *) { eval $ac_var=; unset $ac_var;} ;;
esac ;;
esac
done
@@ -1582,11 +1905,9 @@ $as_echo "$as_me: WARNING: cache variable $ac_var contains a newline" >&2;} ;;
echo
- cat <<\_ASBOX
+ $as_echo "## ----------------- ##
## Output variables. ##
-_ASBOX
echo
for ac_var in $ac_subst_vars
do
@@ -1599,11 +1920,9 @@ _ASBOX
echo
if test -n "$ac_subst_files"; then
- cat <<\_ASBOX
+ $as_echo "## ------------------- ##
## File substitutions. ##
-_ASBOX
echo
for ac_var in $ac_subst_files
do
@@ -1617,11 +1936,9 @@ _ASBOX
fi
if test -s confdefs.h; then
- cat <<\_ASBOX
+ $as_echo "## ----------- ##
## confdefs.h. ##
-_ASBOX
echo
cat confdefs.h
echo
@@ -1635,46 +1952,53 @@ _ASBOX
exit $exit_status
' 0
for ac_signal in 1 2 13 15; do
- trap 'ac_signal='$ac_signal'; { (exit 1); exit 1; }' $ac_signal
+ trap 'ac_signal='$ac_signal'; as_fn_exit 1' $ac_signal
done
ac_signal=0
# confdefs.h avoids OS command line length limits that DEFS can exceed.
rm -f -r conftest* confdefs.h
+$as_echo "/* confdefs.h */" > confdefs.h
# Predefined preprocessor variables.
cat >>confdefs.h <<_ACEOF
#define PACKAGE_NAME "$PACKAGE_NAME"
_ACEOF
#define PACKAGE_TARNAME "$PACKAGE_TARNAME"
_ACEOF
#define PACKAGE_VERSION "$PACKAGE_VERSION"
_ACEOF
#define PACKAGE_STRING "$PACKAGE_STRING"
_ACEOF
#define PACKAGE_BUGREPORT "$PACKAGE_BUGREPORT"
_ACEOF
+cat >>confdefs.h <<_ACEOF
+#define PACKAGE_URL "$PACKAGE_URL"
+_ACEOF
# Let the site file select an alternate cache file if it wants to.
# Prefer an explicitly selected file to automatically selected ones.
ac_site_file1=NONE
ac_site_file2=NONE
if test -n "$CONFIG_SITE"; then
- ac_site_file1=$CONFIG_SITE
+ # We do not want a PATH search for config.site.
+ case $CONFIG_SITE in #((
+ -*) ac_site_file1=./$CONFIG_SITE;;
+ */*) ac_site_file1=$CONFIG_SITE;;
+ *) ac_site_file1=./$CONFIG_SITE;;
+ esac
elif test "x$prefix" != xNONE; then
ac_site_file1=$prefix/share/config.site
ac_site_file2=$prefix/etc/config.site
@@ -1685,19 +2009,23 @@ fi
for ac_site_file in "$ac_site_file1" "$ac_site_file2"
do
test "x$ac_site_file" = xNONE && continue
- if test -r "$ac_site_file"; then
- { $as_echo "$as_me:$LINENO: loading site script $ac_site_file" >&5
+ if test /dev/null != "$ac_site_file" && test -r "$ac_site_file"; then
+ { $as_echo "$as_me:${as_lineno-$LINENO}: loading site script $ac_site_file" >&5
$as_echo "$as_me: loading site script $ac_site_file" >&6;}
sed 's/^/| /' "$ac_site_file" >&5
- . "$ac_site_file"
+ . "$ac_site_file" \
+ || { { $as_echo "$as_me:${as_lineno-$LINENO}: error: in \`$ac_pwd':" >&5
+$as_echo "$as_me: error: in \`$ac_pwd':" >&2;}
+as_fn_error $? "failed to load site script $ac_site_file
+See \`config.log' for more details" "$LINENO" 5; }
fi
done
if test -r "$cache_file"; then
- # Some versions of bash will fail to source /dev/null (special
- # files actually), so we avoid doing that.
- if test -f "$cache_file"; then
- { $as_echo "$as_me:$LINENO: loading cache $cache_file" >&5
+ # Some versions of bash will fail to source /dev/null (special files
+ # actually), so we avoid doing that. DJGPP emulates it as a regular file.
+ if test /dev/null != "$cache_file" && test -f "$cache_file"; then
+ { $as_echo "$as_me:${as_lineno-$LINENO}: loading cache $cache_file" >&5
$as_echo "$as_me: loading cache $cache_file" >&6;}
case $cache_file in
[\\/]* | ?:[\\/]* ) . "$cache_file";;
@@ -1705,7 +2033,7 @@ $as_echo "$as_me: loading cache $cache_file" >&6;}
esac
fi
else
- { $as_echo "$as_me:$LINENO: creating cache $cache_file" >&5
+ { $as_echo "$as_me:${as_lineno-$LINENO}: creating cache $cache_file" >&5
$as_echo "$as_me: creating cache $cache_file" >&6;}
>$cache_file
fi
@@ -1720,11 +2048,11 @@ for ac_var in $ac_precious_vars; do
eval ac_new_val=\$ac_env_${ac_var}_value
case $ac_old_set,$ac_new_set in
set,)
- { $as_echo "$as_me:$LINENO: error: \`$ac_var' was set to \`$ac_old_val' in the previous run" >&5
+ { $as_echo "$as_me:${as_lineno-$LINENO}: error: \`$ac_var' was set to \`$ac_old_val' in the previous run" >&5
$as_echo "$as_me: error: \`$ac_var' was set to \`$ac_old_val' in the previous run" >&2;}
ac_cache_corrupted=: ;;
,set)
- { $as_echo "$as_me:$LINENO: error: \`$ac_var' was not set in the previous run" >&5
+ { $as_echo "$as_me:${as_lineno-$LINENO}: error: \`$ac_var' was not set in the previous run" >&5
$as_echo "$as_me: error: \`$ac_var' was not set in the previous run" >&2;}
@@ -1734,17 +2062,17 @@ $as_echo "$as_me: error: \`$ac_var' was not set in the previous run" >&2;}
ac_old_val_w=`echo x $ac_old_val`
ac_new_val_w=`echo x $ac_new_val`
if test "$ac_old_val_w" != "$ac_new_val_w"; then
- { $as_echo "$as_me:$LINENO: error: \`$ac_var' has changed since the previous run:" >&5
+ { $as_echo "$as_me:${as_lineno-$LINENO}: error: \`$ac_var' has changed since the previous run:" >&5
$as_echo "$as_me: error: \`$ac_var' has changed since the previous run:" >&2;}
else
- { $as_echo "$as_me:$LINENO: warning: ignoring whitespace changes in \`$ac_var' since the previous run:" >&5
+ { $as_echo "$as_me:${as_lineno-$LINENO}: warning: ignoring whitespace changes in \`$ac_var' since the previous run:" >&5
$as_echo "$as_me: warning: ignoring whitespace changes in \`$ac_var' since the previous run:" >&2;}
eval $ac_var=\$ac_old_val
fi
- { $as_echo "$as_me:$LINENO: former value: \`$ac_old_val'" >&5
+ { $as_echo "$as_me:${as_lineno-$LINENO}: former value: \`$ac_old_val'" >&5
$as_echo "$as_me: former value: \`$ac_old_val'" >&2;}
- { $as_echo "$as_me:$LINENO: current value: \`$ac_new_val'" >&5
+ { $as_echo "$as_me:${as_lineno-$LINENO}: current value: \`$ac_new_val'" >&5
$as_echo "$as_me: current value: \`$ac_new_val'" >&2;}
fi;;
esac
@@ -1756,43 +2084,20 @@ $as_echo "$as_me: current value: \`$ac_new_val'" >&2;}
esac
case " $ac_configure_args " in
*" '$ac_arg' "*) ;; # Avoid dups. Use of quotes ensures accuracy.
- *) ac_configure_args="$ac_configure_args '$ac_arg'" ;;
+ *) as_fn_append ac_configure_args " '$ac_arg'" ;;
esac
fi
done
if $ac_cache_corrupted; then
- { $as_echo "$as_me:$LINENO: error: in \`$ac_pwd':" >&5
+ { $as_echo "$as_me:${as_lineno-$LINENO}: error: in \`$ac_pwd':" >&5
- { $as_echo "$as_me:$LINENO: error: changes in the environment can compromise the build" >&5
+ { $as_echo "$as_me:${as_lineno-$LINENO}: error: changes in the environment can compromise the build" >&5
$as_echo "$as_me: error: changes in the environment can compromise the build" >&2;}
- { { $as_echo "$as_me:$LINENO: error: run \`make distclean' and/or \`rm $cache_file' and start over" >&5
-$as_echo "$as_me: error: run \`make distclean' and/or \`rm $cache_file' and start over" >&2;}
+ as_fn_error $? "run \`make distclean' and/or \`rm $cache_file' and start over" "$LINENO" 5
fi
+## Main body of script. ##
ac_ext=c
ac_cpp='$CPP $CPPFLAGS'
@@ -1819,9 +2124,7 @@ for ac_dir in ../maint/config "$srcdir"/../maint/config; do
fi
done
if test -z "$ac_aux_dir"; then
- { { $as_echo "$as_me:$LINENO: error: cannot find install-sh or install.sh in ../maint/config \"$srcdir\"/../maint/config" >&5
-$as_echo "$as_me: error: cannot find install-sh or install.sh in ../maint/config \"$srcdir\"/../maint/config" >&2;}
+ as_fn_error $? "cannot find install-sh, install.sh, or shtool in ../maint/config \"$srcdir\"/../maint/config" "$LINENO" 5
fi
# These three variables are undocumented and unsupported,
@@ -1850,10 +2153,10 @@ ac_config_headers="$ac_config_headers darshan-util-config.h"
# OS/2's system install, which has a completely different semantic
# ./install, which can be erroneously created by make from ./install.sh.
# Reject install programs that cannot install multiple files.
-{ $as_echo "$as_me:$LINENO: checking for a BSD-compatible install" >&5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for a BSD-compatible install" >&5
$as_echo_n "checking for a BSD-compatible install... " >&6; }
if test -z "$INSTALL"; then
-if test "${ac_cv_path_install+set}" = set; then
+if ${ac_cv_path_install+:} false; then :
else
@@ -1861,11 +2164,11 @@ for as_dir in $PATH
do
IFS=$as_save_IFS
- # Account for people who put trailing slashes in PATH elements.
-case $as_dir/ in
- ./ | .// | /cC/* | \
+ # Account for people who put trailing slashes in PATH elements.
+case $as_dir/ in #((
+ ./ | .// | /[cC]/* | \
/etc/* | /usr/sbin/* | /usr/etc/* | /sbin/* | /usr/afsws/bin/* | \
- ?:\\/os2\\/install\\/* | ?:\\/OS2\\/INSTALL\\/* | \
+ ?:[\\/]os2[\\/]install[\\/]* | ?:[\\/]OS2[\\/]INSTALL[\\/]* | \
/usr/ucb/* ) ;;
# OSF1 and SCO ODT 3.0 have their own names for install.
@@ -1873,7 +2176,7 @@ case $as_dir/ in
# by default.
for ac_prog in ginstall scoinst install; do
for ac_exec_ext in '' $ac_executable_extensions; do
- if { test -f "$as_dir/$ac_prog$ac_exec_ext" && $as_test_x "$as_dir/$ac_prog$ac_exec_ext"; }; then
+ if as_fn_executable_p "$as_dir/$ac_prog$ac_exec_ext"; then
if test $ac_prog = install &&
grep dspmsg "$as_dir/$ac_prog$ac_exec_ext" >/dev/null 2>&1; then
# AIX install. It has an incompatible calling convention.
@@ -1902,7 +2205,7 @@ case $as_dir/ in
esac
-done
+ done
IFS=$as_save_IFS
rm -rf conftest.one conftest.two conftest.dir
@@ -1918,7 +2221,7 @@ fi
INSTALL=$ac_install_sh
fi
fi
-{ $as_echo "$as_me:$LINENO: result: $INSTALL" >&5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $INSTALL" >&5
$as_echo "$INSTALL" >&6; }
# Use test -z because SunOS4 sh mishandles braces in ${var-val}.
@@ -1938,9 +2241,9 @@ ac_compiler_gnu=$ac_cv_c_compiler_gnu
if test -n "$ac_tool_prefix"; then
# Extract the first word of "${ac_tool_prefix}gcc", so it can be a program name with args.
set dummy ${ac_tool_prefix}gcc; ac_word=$2
-{ $as_echo "$as_me:$LINENO: checking for $ac_word" >&5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for $ac_word" >&5
$as_echo_n "checking for $ac_word... " >&6; }
-if test "${ac_cv_prog_CC+set}" = set; then
+if ${ac_cv_prog_CC+:} false; then :
else
if test -n "$CC"; then
@@ -1951,24 +2254,24 @@ for as_dir in $PATH
do
IFS=$as_save_IFS
- for ac_exec_ext in '' $ac_executable_extensions; do
- if { test -f "$as_dir/$ac_word$ac_exec_ext" && $as_test_x "$as_dir/$ac_word$ac_exec_ext"; }; then
+ for ac_exec_ext in '' $ac_executable_extensions; do
+ if as_fn_executable_p "$as_dir/$ac_word$ac_exec_ext"; then
ac_cv_prog_CC="${ac_tool_prefix}gcc"
- $as_echo "$as_me:$LINENO: found $as_dir/$ac_word$ac_exec_ext" >&5
+ $as_echo "$as_me:${as_lineno-$LINENO}: found $as_dir/$ac_word$ac_exec_ext" >&5
break 2
fi
done
-done
+ done
IFS=$as_save_IFS
fi
fi
CC=$ac_cv_prog_CC
- { $as_echo "$as_me:$LINENO: result: $CC" >&5
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: $CC" >&5
$as_echo "$CC" >&6; }
else
- { $as_echo "$as_me:$LINENO: result: no" >&5
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: no" >&5
$as_echo "no" >&6; }
fi
@@ -1978,9 +2281,9 @@ if test -z "$ac_cv_prog_CC"; then
ac_ct_CC=$CC
# Extract the first word of "gcc", so it can be a program name with args.
set dummy gcc; ac_word=$2
-if test "${ac_cv_prog_ac_ct_CC+set}" = set; then
+if ${ac_cv_prog_ac_ct_CC+:} false; then :
else
if test -n "$ac_ct_CC"; then
@@ -1991,24 +2294,24 @@ for as_dir in $PATH
do
IFS=$as_save_IFS
ac_cv_prog_ac_ct_CC="gcc"
break 2
fi
done
-done
+ done
IFS=$as_save_IFS
fi
fi
ac_ct_CC=$ac_cv_prog_ac_ct_CC
- { $as_echo "$as_me:$LINENO: result: $ac_ct_CC" >&5
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_ct_CC" >&5
$as_echo "$ac_ct_CC" >&6; }
else
fi
@@ -2017,7 +2320,7 @@ fi
else
case $cross_compiling:$ac_tool_warned in
yes:)
-{ $as_echo "$as_me:$LINENO: WARNING: using cross tools not prefixed with host triplet" >&5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: using cross tools not prefixed with host triplet" >&5
$as_echo "$as_me: WARNING: using cross tools not prefixed with host triplet" >&2;}
ac_tool_warned=yes ;;
esac
@@ -2031,9 +2334,9 @@ if test -z "$CC"; then
# Extract the first word of "${ac_tool_prefix}cc", so it can be a program name with args.
set dummy ${ac_tool_prefix}cc; ac_word=$2
else
@@ -2044,24 +2347,24 @@ for as_dir in $PATH
do
IFS=$as_save_IFS
ac_cv_prog_CC="${ac_tool_prefix}cc"
break 2
fi
done
-done
+ done
IFS=$as_save_IFS
fi
fi
CC=$ac_cv_prog_CC
else
fi
@@ -2071,9 +2374,9 @@ fi
# Extract the first word of "cc", so it can be a program name with args.
set dummy cc; ac_word=$2
else
@@ -2085,18 +2388,18 @@ for as_dir in $PATH
do
IFS=$as_save_IFS
if test "$as_dir/$ac_word$ac_exec_ext" = "/usr/ucb/cc"; then
ac_prog_rejected=yes
continue
fi
ac_cv_prog_CC="cc"
break 2
fi
done
-done
+ done
IFS=$as_save_IFS
if test $ac_prog_rejected = yes; then
@@ -2115,10 +2418,10 @@ fi
fi
CC=$ac_cv_prog_CC
else
fi
@@ -2130,9 +2433,9 @@ if test -z "$CC"; then
do
# Extract the first word of "$ac_tool_prefix$ac_prog", so it can be a program name with args.
set dummy $ac_tool_prefix$ac_prog; ac_word=$2
else
@@ -2143,24 +2446,24 @@ for as_dir in $PATH
do
IFS=$as_save_IFS
ac_cv_prog_CC="$ac_tool_prefix$ac_prog"
break 2
fi
done
-done
+ done
IFS=$as_save_IFS
fi
fi
CC=$ac_cv_prog_CC
else
fi
@@ -2174,9 +2477,9 @@ if test -z "$CC"; then
do
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
else
@@ -2187,24 +2490,24 @@ for as_dir in $PATH
do
IFS=$as_save_IFS
ac_cv_prog_ac_ct_CC="$ac_prog"
break 2
fi
done
-done
+ done
IFS=$as_save_IFS
fi
fi
else
fi
@@ -2217,7 +2520,7 @@ done
else
yes:)
esac
@@ -2228,57 +2531,37 @@ fi
fi
-test -z "$CC" && { { $as_echo "$as_me:$LINENO: error: in \`$ac_pwd':" >&5
+test -z "$CC" && { { $as_echo "$as_me:${as_lineno-$LINENO}: error: in \`$ac_pwd':" >&5
-{ { $as_echo "$as_me:$LINENO: error: no acceptable C compiler found in \$PATH
-See \`config.log' for more details." >&5
-$as_echo "$as_me: error: no acceptable C compiler found in \$PATH
-See \`config.log' for more details." >&2;}
- { (exit 1); exit 1; }; }; }
+as_fn_error $? "no acceptable C compiler found in \$PATH
# Provide some information about the compiler.
-$as_echo "$as_me:$LINENO: checking for C compiler version" >&5
+$as_echo "$as_me:${as_lineno-$LINENO}: checking for C compiler version" >&5
set X $ac_compile
ac_compiler=$2
-{ (ac_try="$ac_compiler --version >&5"
-case "(($ac_try" in
- *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;;
- *) ac_try_echo=$ac_try;;
-esac
-eval ac_try_echo="\"\$as_me:$LINENO: $ac_try_echo\""
-$as_echo "$ac_try_echo") >&5
- (eval "$ac_compiler --version >&5") 2>&5
- ac_status=$?
- $as_echo "$as_me:$LINENO: \$? = $ac_status" >&5
- (exit $ac_status); }
-{ (ac_try="$ac_compiler -v >&5"
-esac
- (eval "$ac_compiler -v >&5") 2>&5
- ac_status=$?
-{ (ac_try="$ac_compiler -V >&5"
+for ac_option in --version -v -V -qversion; do
+ { { ac_try="$ac_compiler $ac_option >&5"
case "(($ac_try" in
esac
- (eval "$ac_compiler -V >&5") 2>&5
+ (eval "$ac_compiler $ac_option >&5") 2>conftest.err
ac_status=$?
+ sed '10a\
+... rest of stderr output deleted ...
+ 10q' conftest.err >conftest.er1
+ fi
+ rm -f conftest.er1 conftest.err
+done
-cat >conftest.$ac_ext <<_ACEOF
-/* confdefs.h. */
-_ACEOF
-cat confdefs.h >>conftest.$ac_ext
-cat >>conftest.$ac_ext <<_ACEOF
int
@@ -2294,8 +2577,8 @@ ac_clean_files="$ac_clean_files a.out a.out.dSYM a.exe b.out"
# Try to create an executable without -o first, disregard a.out.
# It will help us diagnose broken compilers, and finding out an intuition
# of exeext.
-{ $as_echo "$as_me:$LINENO: checking for C compiler default output file name" >&5
-$as_echo_n "checking for C compiler default output file name... " >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether the C compiler works" >&5
+$as_echo_n "checking whether the C compiler works... " >&6; }
ac_link_default=`$as_echo "$ac_link" | sed 's/ -o *conftest[^ ]*//'`
# The possible output files:
@@ -2311,17 +2594,17 @@ do
done
rm -f $ac_rmfiles
-if { (ac_try="$ac_link_default"
+if { { ac_try="$ac_link_default"
case "(($ac_try" in
esac
(eval "$ac_link_default") 2>&5
ac_status=$?
- (exit $ac_status); }; then
+ test $ac_status = 0; }; then :
# Autoconf-2.13 could set the ac_cv_exeext variable to `no'.
# So ignore a value of `no', otherwise this would lead to `EXEEXT = no'
# in a Makefile. We should not override ac_cv_exeext if it was cached,
@@ -2338,7 +2621,7 @@ do
# certainly right.
break;;
- if test "${ac_cv_exeext+set}" = set && test "$ac_cv_exeext" != no;
+ if test "${ac_cv_exeext+set}" = set && test "$ac_cv_exeext" != no;
then :; else
ac_cv_exeext=`expr "$ac_file" : '[^.]*\(\..*\)'`
fi
@@ -2357,84 +2640,41 @@ test "$ac_cv_exeext" = no && ac_cv_exeext=
else
ac_file=''
fi
-{ $as_echo "$as_me:$LINENO: result: $ac_file" >&5
-$as_echo "$ac_file" >&6; }
-if test -z "$ac_file"; then
- $as_echo "$as_me: failed program was:" >&5
+if test -z "$ac_file"; then :
+$as_echo "no" >&6; }
+$as_echo "$as_me: failed program was:" >&5
-{ { $as_echo "$as_me:$LINENO: error: in \`$ac_pwd':" >&5
+{ { $as_echo "$as_me:${as_lineno-$LINENO}: error: in \`$ac_pwd':" >&5
-{ { $as_echo "$as_me:$LINENO: error: C compiler cannot create executables
-$as_echo "$as_me: error: C compiler cannot create executables
- { (exit 77); exit 77; }; }; }
+as_fn_error 77 "C compiler cannot create executables
+else
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: yes" >&5
+$as_echo "yes" >&6; }
fi
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for C compiler default output file name" >&5
+$as_echo_n "checking for C compiler default output file name... " >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_file" >&5
+$as_echo "$ac_file" >&6; }
ac_exeext=$ac_cv_exeext
-# Check that the compiler produces executables we can run. If not, either
-# the compiler is broken, or we cross compile.
-{ $as_echo "$as_me:$LINENO: checking whether the C compiler works" >&5
-$as_echo_n "checking whether the C compiler works... " >&6; }
-# FIXME: These cross compiler hacks should be removed for Autoconf 3.0
-# If not cross compiling, check that we can run a simple program.
-if test "$cross_compiling" != yes; then
- if { ac_try='./$ac_file'
- { (case "(($ac_try" in
-esac
- (eval "$ac_try") 2>&5
- ac_status=$?
- (exit $ac_status); }; }; then
- cross_compiling=no
- else
- if test "$cross_compiling" = maybe; then
- cross_compiling=yes
- else
- { { $as_echo "$as_me:$LINENO: error: in \`$ac_pwd':" >&5
-$as_echo "$as_me: error: in \`$ac_pwd':" >&2;}
-{ { $as_echo "$as_me:$LINENO: error: cannot run C compiled programs.
-If you meant to cross compile, use \`--host'.
-$as_echo "$as_me: error: cannot run C compiled programs.
- fi
- fi
-fi
-{ $as_echo "$as_me:$LINENO: result: yes" >&5
-$as_echo "yes" >&6; }
rm -f -r a.out a.out.dSYM a.exe conftest$ac_cv_exeext b.out
ac_clean_files=$ac_clean_files_save
-{ $as_echo "$as_me:$LINENO: checking whether we are cross compiling" >&5
-$as_echo_n "checking whether we are cross compiling... " >&6; }
-{ $as_echo "$as_me:$LINENO: result: $cross_compiling" >&5
-$as_echo "$cross_compiling" >&6; }
-{ $as_echo "$as_me:$LINENO: checking for suffix of executables" >&5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for suffix of executables" >&5
$as_echo_n "checking for suffix of executables... " >&6; }
-if { (ac_try="$ac_link"
+if { { ac_try="$ac_link"
case "(($ac_try" in
esac
ac_status=$?
# If both `conftest.exe' and `conftest' are `present' (well, observable)
# catch `conftest.exe'. For instance with Cygwin, `ls conftest' will
# work properly (i.e., refer to `conftest.exe'), while it won't with
@@ -2449,32 +2689,83 @@ for ac_file in conftest.exe conftest conftest.*; do
esac
done
else
+ { { $as_echo "$as_me:${as_lineno-$LINENO}: error: in \`$ac_pwd':" >&5
-{ { $as_echo "$as_me:$LINENO: error: cannot compute suffix of executables: cannot compile and link
-$as_echo "$as_me: error: cannot compute suffix of executables: cannot compile and link
+as_fn_error $? "cannot compute suffix of executables: cannot compile and link
fi
-rm -f conftest$ac_cv_exeext
-{ $as_echo "$as_me:$LINENO: result: $ac_cv_exeext" >&5
+rm -f conftest conftest$ac_cv_exeext
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_exeext" >&5
$as_echo "$ac_cv_exeext" >&6; }
rm -f conftest.$ac_ext
EXEEXT=$ac_cv_exeext
ac_exeext=$EXEEXT
-{ $as_echo "$as_me:$LINENO: checking for suffix of object files" >&5
+#include <stdio.h>
+int
+main ()
+FILE *f = fopen ("conftest.out", "w");
+ return ferror (f) || fclose (f) != 0;
+ return 0;
+_ACEOF
+ac_clean_files="$ac_clean_files conftest.out"
+# Check that the compiler produces executables we can run. If not, either
+# the compiler is broken, or we cross compile.
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether we are cross compiling" >&5
+$as_echo_n "checking whether we are cross compiling... " >&6; }
+if test "$cross_compiling" != yes; then
+ { { ac_try="$ac_link"
+esac
+ ac_status=$?
+ if { ac_try='./conftest$ac_cv_exeext'
+esac
+ ac_status=$?
+ cross_compiling=no
+ else
+ if test "$cross_compiling" = maybe; then
+ cross_compiling=yes
+ else
+as_fn_error $? "cannot run C compiled programs.
+If you meant to cross compile, use \`--host'.
+ fi
+ fi
+fi
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $cross_compiling" >&5
+$as_echo "$cross_compiling" >&6; }
+rm -f conftest.$ac_ext conftest$ac_cv_exeext conftest.out
+ac_clean_files=$ac_clean_files_save
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for suffix of object files" >&5
$as_echo_n "checking for suffix of object files... " >&6; }
-if test "${ac_cv_objext+set}" = set; then
+if ${ac_cv_objext+:} false; then :
else
- cat >conftest.$ac_ext <<_ACEOF
-/* confdefs.h. */
-_ACEOF
int
@@ -2486,17 +2777,17 @@ main ()
_ACEOF
rm -f conftest.o conftest.obj
-if { (ac_try="$ac_compile"
+if { { ac_try="$ac_compile"
case "(($ac_try" in
esac
(eval "$ac_compile") 2>&5
ac_status=$?
for ac_file in conftest.o conftest.obj conftest.*; do
test -f "$ac_file" || continue;
case $ac_file in
@@ -2509,31 +2800,23 @@ else
-{ { $as_echo "$as_me:$LINENO: error: cannot compute suffix of object files: cannot compile
-$as_echo "$as_me: error: cannot compute suffix of object files: cannot compile
+as_fn_error $? "cannot compute suffix of object files: cannot compile
fi
rm -f conftest.$ac_cv_objext conftest.$ac_ext
fi
-{ $as_echo "$as_me:$LINENO: result: $ac_cv_objext" >&5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_objext" >&5
$as_echo "$ac_cv_objext" >&6; }
OBJEXT=$ac_cv_objext
ac_objext=$OBJEXT
-{ $as_echo "$as_me:$LINENO: checking whether we are using the GNU C compiler" >&5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether we are using the GNU C compiler" >&5
$as_echo_n "checking whether we are using the GNU C compiler... " >&6; }
-if test "${ac_cv_c_compiler_gnu+set}" = set; then
+if ${ac_cv_c_compiler_gnu+:} false; then :
else
-/* confdefs.h. */
-_ACEOF
int
@@ -2547,37 +2830,16 @@ main ()
return 0;
_ACEOF
-rm -f conftest.$ac_objext
-esac
- (eval "$ac_compile") 2>conftest.er1
- ac_status=$?
- grep -v '^ *+' conftest.er1 >conftest.err
- rm -f conftest.er1
- cat conftest.err >&5
- (exit $ac_status); } && {
- test -z "$ac_c_werror_flag" ||
- test ! -s conftest.err
- } && test -s conftest.$ac_objext; then
ac_compiler_gnu=yes
else
-sed 's/^/| /' conftest.$ac_ext >&5
- ac_compiler_gnu=no
+ ac_compiler_gnu=no
fi
ac_cv_c_compiler_gnu=$ac_compiler_gnu
fi
-{ $as_echo "$as_me:$LINENO: result: $ac_cv_c_compiler_gnu" >&5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_c_compiler_gnu" >&5
$as_echo "$ac_cv_c_compiler_gnu" >&6; }
if test $ac_compiler_gnu = yes; then
GCC=yes
@@ -2586,20 +2848,16 @@ else
fi
ac_test_CFLAGS=${CFLAGS+set}
ac_save_CFLAGS=$CFLAGS
-{ $as_echo "$as_me:$LINENO: checking whether $CC accepts -g" >&5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether $CC accepts -g" >&5
$as_echo_n "checking whether $CC accepts -g... " >&6; }
-if test "${ac_cv_prog_cc_g+set}" = set; then
+if ${ac_cv_prog_cc_g+:} false; then :
else
ac_save_c_werror_flag=$ac_c_werror_flag
ac_c_werror_flag=yes
ac_cv_prog_cc_g=no
CFLAGS="-g"
-/* confdefs.h. */
-_ACEOF
int
@@ -2610,35 +2868,11 @@ main ()
return 0;
_ACEOF
-esac
- ac_status=$?
ac_cv_prog_cc_g=yes
else
- CFLAGS=""
-/* confdefs.h. */
-_ACEOF
+ CFLAGS=""
int
@@ -2649,36 +2883,12 @@ main ()
return 0;
_ACEOF
-esac
- ac_status=$?
-else
- ac_c_werror_flag=$ac_save_c_werror_flag
+else
+ ac_c_werror_flag=$ac_save_c_werror_flag
CFLAGS="-g"
-/* confdefs.h. */
-_ACEOF
int
@@ -2689,42 +2899,17 @@ main ()
return 0;
_ACEOF
-esac
- ac_status=$?
ac_cv_prog_cc_g=yes
-else
fi
fi
fi
fi
-{ $as_echo "$as_me:$LINENO: result: $ac_cv_prog_cc_g" >&5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_prog_cc_g" >&5
$as_echo "$ac_cv_prog_cc_g" >&6; }
if test "$ac_test_CFLAGS" = set; then
CFLAGS=$ac_save_CFLAGS
@@ -2741,23 +2926,18 @@ else
CFLAGS=
fi
fi
-{ $as_echo "$as_me:$LINENO: checking for $CC option to accept ISO C89" >&5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for $CC option to accept ISO C89" >&5
$as_echo_n "checking for $CC option to accept ISO C89... " >&6; }
-if test "${ac_cv_prog_cc_c89+set}" = set; then
+if ${ac_cv_prog_cc_c89+:} false; then :
else
ac_cv_prog_cc_c89=no
ac_save_CC=$CC
-/* confdefs.h. */
-_ACEOF
#include <stdarg.h>
#include <stdio.h>
-#include <sys/types.h>
-#include <sys/stat.h>
+struct stat;
/* Most of the following tests are stolen from RCS 5.7's src/conf.sh. */
struct buf { int x; };
FILE * (*rcsopen) (struct buf *, struct stat *, int);
@@ -2809,32 +2989,9 @@ for ac_arg in '' -qlanglvl=extc89 -qlanglvl=ansi -std \
-Ae "-Aa -D_HPUX_SOURCE" "-Xc -D__EXTENSIONS__"
do
CC="$ac_save_CC $ac_arg"
- rm -f conftest.$ac_objext
-esac
- ac_status=$?
+ if ac_fn_c_try_compile "$LINENO"; then :
ac_cv_prog_cc_c89=$ac_arg
-else
fi
test "x$ac_cv_prog_cc_c89" != "xno" && break
done
@@ -2845,17 +3002,19 @@ fi
# AC_CACHE_VAL
case "x$ac_cv_prog_cc_c89" in
x)
- { $as_echo "$as_me:$LINENO: result: none needed" >&5
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: none needed" >&5
$as_echo "none needed" >&6; } ;;
xno)
- { $as_echo "$as_me:$LINENO: result: unsupported" >&5
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: unsupported" >&5
$as_echo "unsupported" >&6; } ;;
CC="$CC $ac_cv_prog_cc_c89"
- { $as_echo "$as_me:$LINENO: result: $ac_cv_prog_cc_c89" >&5
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_prog_cc_c89" >&5
$as_echo "$ac_cv_prog_cc_c89" >&6; } ;;
esac
+if test "x$ac_cv_prog_cc_c89" != xno; then :
+fi
ac_ext=c
@@ -2869,14 +3028,14 @@ ac_cpp='$CPP $CPPFLAGS'
ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5'
ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
-{ $as_echo "$as_me:$LINENO: checking how to run the C preprocessor" >&5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking how to run the C preprocessor" >&5
$as_echo_n "checking how to run the C preprocessor... " >&6; }
# On Suns, sometimes $CPP names a directory.
if test -n "$CPP" && test -d "$CPP"; then
CPP=
fi
if test -z "$CPP"; then
- if test "${ac_cv_prog_CPP+set}" = set; then
+ if ${ac_cv_prog_CPP+:} false; then :
else
# Double quotes because CPP needs to be expanded
@@ -2891,11 +3050,7 @@ do
# <limits.h> exists even on freestanding compilers.
# On the NeXT, cc -E runs the code through the compiler's parser,
# not just through cpp. "Syntax error" is here to catch this case.
-/* confdefs.h. */
-_ACEOF
#ifdef __STDC__
@@ -2904,78 +3059,34 @@ cat >>conftest.$ac_ext <<_ACEOF
#endif
Syntax error
_ACEOF
-if { (ac_try="$ac_cpp conftest.$ac_ext"
-esac
- (eval "$ac_cpp conftest.$ac_ext") 2>conftest.er1
- ac_status=$?
- (exit $ac_status); } >/dev/null && {
- test -z "$ac_c_preproc_warn_flag$ac_c_werror_flag" ||
- }; then
-else
+else
# Broken: fails on valid input.
continue
fi
-rm -f conftest.err conftest.$ac_ext
# OK, works on sane cases. Now check whether nonexistent headers
# can be detected and how.
-/* confdefs.h. */
-_ACEOF
#include <ac_nonexistent.h>
_ACEOF
-esac
- ac_status=$?
- }; then
# Broken: success on invalid input.
continue
else
# Passes both tests.
ac_preproc_ok=:
break
fi
done
# Because of `break', _AC_PREPROC_IFELSE's cleaning code was skipped.
-if $ac_preproc_ok; then
+rm -f conftest.i conftest.err conftest.$ac_ext
+if $ac_preproc_ok; then :
break
fi
@@ -2987,7 +3098,7 @@ fi
else
ac_cv_prog_CPP=$CPP
fi
-{ $as_echo "$as_me:$LINENO: result: $CPP" >&5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $CPP" >&5
$as_echo "$CPP" >&6; }
ac_preproc_ok=false
for ac_c_preproc_warn_flag in '' yes
@@ -2998,11 +3109,7 @@ do
-/* confdefs.h. */
-_ACEOF
#ifdef __STDC__
@@ -3011,87 +3118,40 @@ cat >>conftest.$ac_ext <<_ACEOF
#endif
Syntax error
_ACEOF
-esac
- ac_status=$?
- }; then
-else
+else
continue
fi
-/* confdefs.h. */
-_ACEOF
_ACEOF
-esac
- ac_status=$?
- }; then
continue
else
ac_preproc_ok=:
break
fi
done
else
-{ { $as_echo "$as_me:$LINENO: error: C preprocessor \"$CPP\" fails sanity check
-$as_echo "$as_me: error: C preprocessor \"$CPP\" fails sanity check
+as_fn_error $? "C preprocessor \"$CPP\" fails sanity check
fi
ac_ext=c
@@ -3101,9 +3161,9 @@ ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $
-{ $as_echo "$as_me:$LINENO: checking for grep that handles long lines and -e" >&5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for grep that handles long lines and -e" >&5
$as_echo_n "checking for grep that handles long lines and -e... " >&6; }
-if test "${ac_cv_path_GREP+set}" = set; then
+if ${ac_cv_path_GREP+:} false; then :
else
if test -z "$GREP"; then
@@ -3114,10 +3174,10 @@ for as_dir in $PATH$PATH_SEPARATOR/usr/xpg4/bin
do
IFS=$as_save_IFS
test -z "$as_dir" && as_dir=.
- for ac_prog in grep ggrep; do
+ for ac_prog in grep ggrep; do
ac_path_GREP="$as_dir/$ac_prog$ac_exec_ext"
- { test -f "$ac_path_GREP" && $as_test_x "$ac_path_GREP"; } || continue
+ as_fn_executable_p "$ac_path_GREP" || continue
# Check for GNU ac_path_GREP and select it if it is found.
# Check for GNU $ac_path_GREP
case `"$ac_path_GREP" --version 2>&1` in
@@ -3134,7 +3194,7 @@ case `"$ac_path_GREP" --version 2>&1` in
$as_echo 'GREP' >> "conftest.nl"
"$ac_path_GREP" -e 'GREP$' -e '-(cannot match)-' < "conftest.nl" >"conftest.out" 2>/dev/null || break
diff "conftest.out" "conftest.nl" >/dev/null 2>&1 || break
- ac_count=`expr $ac_count + 1`
+ as_fn_arith $ac_count + 1 && ac_count=$as_val
if test $ac_count -gt ${ac_path_GREP_max-0}; then
# Best one so far, save it but keep looking for a better one
ac_cv_path_GREP="$ac_path_GREP"
@@ -3149,26 +3209,24 @@ esac
$ac_path_GREP_found && break 3
done
done
-done
+ done
IFS=$as_save_IFS
if test -z "$ac_cv_path_GREP"; then
- { { $as_echo "$as_me:$LINENO: error: no acceptable grep could be found in $PATH$PATH_SEPARATOR/usr/xpg4/bin" >&5
-$as_echo "$as_me: error: no acceptable grep could be found in $PATH$PATH_SEPARATOR/usr/xpg4/bin" >&2;}
+ as_fn_error $? "no acceptable grep could be found in $PATH$PATH_SEPARATOR/usr/xpg4/bin" "$LINENO" 5
fi
else
ac_cv_path_GREP=$GREP
fi
fi
-{ $as_echo "$as_me:$LINENO: result: $ac_cv_path_GREP" >&5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_path_GREP" >&5
$as_echo "$ac_cv_path_GREP" >&6; }
GREP="$ac_cv_path_GREP"
-{ $as_echo "$as_me:$LINENO: checking for egrep" >&5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for egrep" >&5
$as_echo_n "checking for egrep... " >&6; }
-if test "${ac_cv_path_EGREP+set}" = set; then
+if ${ac_cv_path_EGREP+:} false; then :
else
if echo a | $GREP -E '(a|b)' >/dev/null 2>&1
@@ -3182,10 +3240,10 @@ for as_dir in $PATH$PATH_SEPARATOR/usr/xpg4/bin
do
IFS=$as_save_IFS
- for ac_prog in egrep; do
+ for ac_prog in egrep; do
ac_path_EGREP="$as_dir/$ac_prog$ac_exec_ext"
- { test -f "$ac_path_EGREP" && $as_test_x "$ac_path_EGREP"; } || continue
+ as_fn_executable_p "$ac_path_EGREP" || continue
# Check for GNU ac_path_EGREP and select it if it is found.
# Check for GNU $ac_path_EGREP
case `"$ac_path_EGREP" --version 2>&1` in
@@ -3202,7 +3260,7 @@ case `"$ac_path_EGREP" --version 2>&1` in
$as_echo 'EGREP' >> "conftest.nl"
"$ac_path_EGREP" 'EGREP$' < "conftest.nl" >"conftest.out" 2>/dev/null || break
if test $ac_count -gt ${ac_path_EGREP_max-0}; then
ac_cv_path_EGREP="$ac_path_EGREP"
@@ -3217,12 +3275,10 @@ esac
$ac_path_EGREP_found && break 3
done
done
-done
+ done
IFS=$as_save_IFS
if test -z "$ac_cv_path_EGREP"; then
- { { $as_echo "$as_me:$LINENO: error: no acceptable egrep could be found in $PATH$PATH_SEPARATOR/usr/xpg4/bin" >&5
-$as_echo "$as_me: error: no acceptable egrep could be found in $PATH$PATH_SEPARATOR/usr/xpg4/bin" >&2;}
+ as_fn_error $? "no acceptable egrep could be found in $PATH$PATH_SEPARATOR/usr/xpg4/bin" "$LINENO" 5
fi
else
ac_cv_path_EGREP=$EGREP
@@ -3230,21 +3286,17 @@ fi
fi
fi
-{ $as_echo "$as_me:$LINENO: result: $ac_cv_path_EGREP" >&5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_path_EGREP" >&5
$as_echo "$ac_cv_path_EGREP" >&6; }
EGREP="$ac_cv_path_EGREP"
-{ $as_echo "$as_me:$LINENO: checking for ANSI C header files" >&5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for ANSI C header files" >&5
$as_echo_n "checking for ANSI C header files... " >&6; }
-if test "${ac_cv_header_stdc+set}" = set; then
+if ${ac_cv_header_stdc+:} false; then :
else
-/* confdefs.h. */
-_ACEOF
#include <stdlib.h>
#include <stdarg.h>
@@ -3259,48 +3311,23 @@ main ()
return 0;
_ACEOF
-esac
- ac_status=$?
ac_cv_header_stdc=yes
else
- ac_cv_header_stdc=no
+ ac_cv_header_stdc=no
fi
if test $ac_cv_header_stdc = yes; then
# SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-/* confdefs.h. */
-_ACEOF
#include <string.h>
_ACEOF
if (eval "$ac_cpp conftest.$ac_ext") 2>&5 |
- $EGREP "memchr" >/dev/null 2>&1; then
+ $EGREP "memchr" >/dev/null 2>&1; then :
else
fi
@@ -3310,18 +3337,14 @@ fi
# ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-/* confdefs.h. */
-_ACEOF
#include <stdlib.h>
_ACEOF
- $EGREP "free" >/dev/null 2>&1; then
+ $EGREP "free" >/dev/null 2>&1; then :
else
fi
@@ -3331,14 +3354,10 @@ fi
# /bin/cc in Irix-4.0.5 gets non-ANSI ctype macros unless using -ansi.
- if test "$cross_compiling" = yes; then
+ if test "$cross_compiling" = yes; then :
else
-/* confdefs.h. */
-_ACEOF
#include <ctype.h>
#include <stdlib.h>
@@ -3365,118 +3384,33 @@ main ()
return 0;
_ACEOF
-rm -f conftest$ac_exeext
-esac
- (eval "$ac_link") 2>&5
- ac_status=$?
- (exit $ac_status); } && { ac_try='./conftest$ac_exeext'
-esac
- ac_status=$?
-else
- $as_echo "$as_me: program exited with status $ac_status" >&5
-$as_echo "$as_me: failed program was:" >&5
+if ac_fn_c_try_run "$LINENO"; then :
-( exit $ac_status )
-ac_cv_header_stdc=no
+else
fi
-rm -rf conftest.dSYM
-rm -f core *.core core.conftest.* gmon.out bb.out conftest$ac_exeext conftest.$ac_objext conftest.$ac_ext
+rm -f core *.core core.conftest.* gmon.out bb.out conftest$ac_exeext \
+ conftest.$ac_objext conftest.beam conftest.$ac_ext
fi
fi
fi
-{ $as_echo "$as_me:$LINENO: result: $ac_cv_header_stdc" >&5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_header_stdc" >&5
$as_echo "$ac_cv_header_stdc" >&6; }
-cat >>confdefs.h <<\_ACEOF
-#define STDC_HEADERS 1
-_ACEOF
+$as_echo "#define STDC_HEADERS 1" >>confdefs.h
fi
# On IRIX 5.3, sys/types and inttypes.h are conflicting.
for ac_header in sys/types.h sys/stat.h stdlib.h string.h memory.h strings.h \
inttypes.h stdint.h unistd.h
-do
-as_ac_Header=`$as_echo "ac_cv_header_$ac_header" | $as_tr_sh`
-{ $as_echo "$as_me:$LINENO: checking for $ac_header" >&5
-$as_echo_n "checking for $ac_header... " >&6; }
-if { as_var=$as_ac_Header; eval "test \"\${$as_var+set}\" = set"; }; then
- $as_echo_n "(cached) " >&6
-else
-/* confdefs.h. */
-_ACEOF
-/* end confdefs.h. */
-$ac_includes_default
-#include <$ac_header>
-_ACEOF
-esac
- ac_status=$?
- eval "$as_ac_Header=yes"
-else
- eval "$as_ac_Header=no"
-fi
-rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext
-fi
-ac_res=`eval 'as_val=${'$as_ac_Header'}
- $as_echo "$as_val"'`
- { $as_echo "$as_me:$LINENO: result: $ac_res" >&5
-$as_echo "$ac_res" >&6; }
-as_val=`eval 'as_val=${'$as_ac_Header'}
- if test "x$as_val" = x""yes; then
+do :
+ as_ac_Header=`$as_echo "ac_cv_header_$ac_header" | $as_tr_sh`
+ac_fn_c_check_header_compile "$LINENO" "$ac_header" "$as_ac_Header" "$ac_includes_default
+if eval test \"x\$"$as_ac_Header"\" = x"yes"; then :
#define `$as_echo "HAVE_$ac_header" | $as_tr_cpp` 1
_ACEOF
@@ -3490,7 +3424,7 @@ done
# Check whether --with-zlib was given.
-if test "${with_zlib+set}" = set; then
+if test "${with_zlib+set}" = set; then :
withval=$with_zlib; if test "$withval" != no ; then
if test -d "$withval"
then
@@ -3500,166 +3434,31 @@ if test "${with_zlib+set}" = set; then
__DARSHAN_ZLIB_LINK_FLAGS="-L${ZLIB_HOME}/lib"
__DARSHAN_ZLIB_INCLUDE_FLAGS="-I${ZLIB_HOME}/include"
else
- { $as_echo "$as_me:$LINENO: WARNING: Sorry, $withval does not exist, checking usual places" >&5
+ { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: Sorry, $withval does not exist, checking usual places" >&5
$as_echo "$as_me: WARNING: Sorry, $withval does not exist, checking usual places" >&2;}
fi
else
- { { $as_echo "$as_me:$LINENO: error: zlib is required" >&5
-$as_echo "$as_me: error: zlib is required" >&2;}
-fi
-fi
-if test "${ac_cv_header_zlib_h+set}" = set; then
- { $as_echo "$as_me:$LINENO: checking for zlib.h" >&5
-$as_echo_n "checking for zlib.h... " >&6; }
-fi
-{ $as_echo "$as_me:$LINENO: result: $ac_cv_header_zlib_h" >&5
-$as_echo "$ac_cv_header_zlib_h" >&6; }
-else
- # Is the header compilable?
-{ $as_echo "$as_me:$LINENO: checking zlib.h usability" >&5
-$as_echo_n "checking zlib.h usability... " >&6; }
-/* confdefs.h. */
-_ACEOF
-#include <zlib.h>
-_ACEOF
-esac
- ac_status=$?
- ac_header_compiler=yes
-else
- ac_header_compiler=no
+ as_fn_error $? "zlib is required" "$LINENO" 5
fi
-{ $as_echo "$as_me:$LINENO: result: $ac_header_compiler" >&5
-$as_echo "$ac_header_compiler" >&6; }
-# Is the header present?
-{ $as_echo "$as_me:$LINENO: checking zlib.h presence" >&5
-$as_echo_n "checking zlib.h presence... " >&6; }
-/* confdefs.h. */
-_ACEOF
-#include <zlib.h>
-_ACEOF
-esac
- ac_status=$?
- }; then
- ac_header_preproc=yes
-else
- ac_header_preproc=no
fi
-{ $as_echo "$as_me:$LINENO: result: $ac_header_preproc" >&5
-$as_echo "$ac_header_preproc" >&6; }
-# So? What about this header?
-case $ac_header_compiler:$ac_header_preproc:$ac_c_preproc_warn_flag in
- yes:no: )
- { $as_echo "$as_me:$LINENO: WARNING: zlib.h: accepted by the compiler, rejected by the preprocessor!" >&5
-$as_echo "$as_me: WARNING: zlib.h: accepted by the compiler, rejected by the preprocessor!" >&2;}
- { $as_echo "$as_me:$LINENO: WARNING: zlib.h: proceeding with the compiler's result" >&5
-$as_echo "$as_me: WARNING: zlib.h: proceeding with the compiler's result" >&2;}
- no:yes:* )
- { $as_echo "$as_me:$LINENO: WARNING: zlib.h: present but cannot be compiled" >&5
-$as_echo "$as_me: WARNING: zlib.h: present but cannot be compiled" >&2;}
- { $as_echo "$as_me:$LINENO: WARNING: zlib.h: check for missing prerequisite headers?" >&5
-$as_echo "$as_me: WARNING: zlib.h: check for missing prerequisite headers?" >&2;}
- { $as_echo "$as_me:$LINENO: WARNING: zlib.h: see the Autoconf documentation" >&5
-$as_echo "$as_me: WARNING: zlib.h: see the Autoconf documentation" >&2;}
- { $as_echo "$as_me:$LINENO: WARNING: zlib.h: section \"Present But Cannot Be Compiled\"" >&5
-$as_echo "$as_me: WARNING: zlib.h: section \"Present But Cannot Be Compiled\"" >&2;}
- { $as_echo "$as_me:$LINENO: WARNING: zlib.h: proceeding with the preprocessor's result" >&5
-$as_echo "$as_me: WARNING: zlib.h: proceeding with the preprocessor's result" >&2;}
- { $as_echo "$as_me:$LINENO: WARNING: zlib.h: in the future, the compiler will take precedence" >&5
-$as_echo "$as_me: WARNING: zlib.h: in the future, the compiler will take precedence" >&2;}
-esac
-{ $as_echo "$as_me:$LINENO: checking for zlib.h" >&5
-else
- ac_cv_header_zlib_h=$ac_header_preproc
-fi
+ac_fn_c_check_header_mongrel "$LINENO" "zlib.h" "ac_cv_header_zlib_h" "$ac_includes_default"
+if test "x$ac_cv_header_zlib_h" = xyes; then :
-fi
-if test "x$ac_cv_header_zlib_h" = x""yes; then
else
- { { $as_echo "$as_me:$LINENO: error: z.h not found" >&5
-$as_echo "$as_me: error: z.h not found" >&2;}
+ as_fn_error $? "z.h not found" "$LINENO" 5
fi
-{ $as_echo "$as_me:$LINENO: checking for inflateEnd in -lz" >&5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for inflateEnd in -lz" >&5
$as_echo_n "checking for inflateEnd in -lz... " >&6; }
-if test "${ac_cv_lib_z_inflateEnd+set}" = set; then
+if ${ac_cv_lib_z_inflateEnd+:} false; then :
else
ac_check_lib_save_LIBS=$LIBS
LIBS="-lz $LIBS"
-/* confdefs.h. */
-_ACEOF
@@ -3677,43 +3476,18 @@ return inflateEnd ();
return 0;
_ACEOF
-rm -f conftest.$ac_objext conftest$ac_exeext
-esac
- (eval "$ac_link") 2>conftest.er1
- ac_status=$?
- } && test -s conftest$ac_exeext && {
- test "$cross_compiling" = yes ||
- $as_test_x conftest$ac_exeext
- }; then
ac_cv_lib_z_inflateEnd=yes
else
- ac_cv_lib_z_inflateEnd=no
+ ac_cv_lib_z_inflateEnd=no
fi
-rm -f core conftest.err conftest.$ac_objext conftest_ipa8_conftest.oo \
- conftest$ac_exeext conftest.$ac_ext
LIBS=$ac_check_lib_save_LIBS
fi
-{ $as_echo "$as_me:$LINENO: result: $ac_cv_lib_z_inflateEnd" >&5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_lib_z_inflateEnd" >&5
$as_echo "$ac_cv_lib_z_inflateEnd" >&6; }
-if test "x$ac_cv_lib_z_inflateEnd" = x""yes; then
+if test "x$ac_cv_lib_z_inflateEnd" = xyes; then :
#define HAVE_LIBZ 1
_ACEOF
@@ -3721,9 +3495,7 @@ _ACEOF
LIBS="-lz $LIBS"
else
- { { $as_echo "$as_me:$LINENO: error: libz not found" >&5
-$as_echo "$as_me: error: libz not found" >&2;}
+ as_fn_error $? "libz not found" "$LINENO" 5
fi
@@ -3731,22 +3503,22 @@ fi
# Handle user hints
-{ $as_echo "$as_me:$LINENO: checking if bzlib is wanted" >&5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking if bzlib is wanted" >&5
$as_echo_n "checking if bzlib is wanted... " >&6; }
# Check whether --with-bzlib was given.
-if test "${with_bzlib+set}" = set; then
+if test "${with_bzlib+set}" = set; then :
withval=$with_bzlib; if test "$withval" != no ; then
then
BZLIB_HOME="$withval"
else
fi
else
DISABLE_BZLIB=1
fi
fi
@@ -3763,7 +3535,7 @@ fi
if test -z "${DISABLE_BZLIB}"
then
- { $as_echo "$as_me:$LINENO: result: yes" >&5
BZLIB_OLD_LDFLAGS=$LDFLAGS
BZLIB_OLD_CPPFLAGS=$LDFLAGS
@@ -3776,18 +3548,14 @@ ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5'
- { $as_echo "$as_me:$LINENO: checking for BZ2_bzCompressInit in -lbz2" >&5
+ { $as_echo "$as_me:${as_lineno-$LINENO}: checking for BZ2_bzCompressInit in -lbz2" >&5
$as_echo_n "checking for BZ2_bzCompressInit in -lbz2... " >&6; }
-if test "${ac_cv_lib_bz2_BZ2_bzCompressInit+set}" = set; then
+if ${ac_cv_lib_bz2_BZ2_bzCompressInit+:} false; then :
else
LIBS="-lbz2 $LIBS"
-/* confdefs.h. */
-_ACEOF
@@ -3805,176 +3573,25 @@ return BZ2_bzCompressInit ();
return 0;
_ACEOF
-esac
- ac_status=$?
- }; then
ac_cv_lib_bz2_BZ2_bzCompressInit=yes
else
- ac_cv_lib_bz2_BZ2_bzCompressInit=no
+ ac_cv_lib_bz2_BZ2_bzCompressInit=no
fi
fi
-{ $as_echo "$as_me:$LINENO: result: $ac_cv_lib_bz2_BZ2_bzCompressInit" >&5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_lib_bz2_BZ2_bzCompressInit" >&5
$as_echo "$ac_cv_lib_bz2_BZ2_bzCompressInit" >&6; }
-if test "x$ac_cv_lib_bz2_BZ2_bzCompressInit" = x""yes; then
+if test "x$ac_cv_lib_bz2_BZ2_bzCompressInit" = xyes; then :
bzlib_cv_libbz2=yes
else
bzlib_cv_libbz2=no
fi
- if test "${ac_cv_header_bzlib_h+set}" = set; then
- { $as_echo "$as_me:$LINENO: checking for bzlib.h" >&5
-$as_echo_n "checking for bzlib.h... " >&6; }
-if test "${ac_cv_header_bzlib_h+set}" = set; then
-fi
-{ $as_echo "$as_me:$LINENO: result: $ac_cv_header_bzlib_h" >&5
-$as_echo "$ac_cv_header_bzlib_h" >&6; }
-else
-{ $as_echo "$as_me:$LINENO: checking bzlib.h usability" >&5
-$as_echo_n "checking bzlib.h usability... " >&6; }
-/* confdefs.h. */
-_ACEOF
-#include <bzlib.h>
-_ACEOF
-esac
- ac_status=$?
-else
-fi
-{ $as_echo "$as_me:$LINENO: checking bzlib.h presence" >&5
-$as_echo_n "checking bzlib.h presence... " >&6; }
-/* confdefs.h. */
-_ACEOF
-#include <bzlib.h>
-_ACEOF
-esac
- ac_status=$?
- }; then
-else
-fi
- yes:no: )
- { $as_echo "$as_me:$LINENO: WARNING: bzlib.h: accepted by the compiler, rejected by the preprocessor!" >&5
-$as_echo "$as_me: WARNING: bzlib.h: accepted by the compiler, rejected by the preprocessor!" >&2;}
- { $as_echo "$as_me:$LINENO: WARNING: bzlib.h: proceeding with the compiler's result" >&5
-$as_echo "$as_me: WARNING: bzlib.h: proceeding with the compiler's result" >&2;}
- no:yes:* )
- { $as_echo "$as_me:$LINENO: WARNING: bzlib.h: present but cannot be compiled" >&5
-$as_echo "$as_me: WARNING: bzlib.h: present but cannot be compiled" >&2;}
- { $as_echo "$as_me:$LINENO: WARNING: bzlib.h: check for missing prerequisite headers?" >&5
-$as_echo "$as_me: WARNING: bzlib.h: check for missing prerequisite headers?" >&2;}
- { $as_echo "$as_me:$LINENO: WARNING: bzlib.h: see the Autoconf documentation" >&5
-$as_echo "$as_me: WARNING: bzlib.h: see the Autoconf documentation" >&2;}
- { $as_echo "$as_me:$LINENO: WARNING: bzlib.h: section \"Present But Cannot Be Compiled\"" >&5
-$as_echo "$as_me: WARNING: bzlib.h: section \"Present But Cannot Be Compiled\"" >&2;}
- { $as_echo "$as_me:$LINENO: WARNING: bzlib.h: proceeding with the preprocessor's result" >&5
-$as_echo "$as_me: WARNING: bzlib.h: proceeding with the preprocessor's result" >&2;}
- { $as_echo "$as_me:$LINENO: WARNING: bzlib.h: in the future, the compiler will take precedence" >&5
-$as_echo "$as_me: WARNING: bzlib.h: in the future, the compiler will take precedence" >&2;}
-esac
-{ $as_echo "$as_me:$LINENO: checking for bzlib.h" >&5
-else
- ac_cv_header_bzlib_h=$ac_header_preproc
-fi
-fi
-if test "x$ac_cv_header_bzlib_h" = x""yes; then
+ ac_fn_c_check_header_mongrel "$LINENO" "bzlib.h" "ac_cv_header_bzlib_h" "$ac_includes_default"
+if test "x$ac_cv_header_bzlib_h" = xyes; then :
bzlib_cv_bzlib_h=yes
else
bzlib_cv_bzlib_h=no
@@ -3992,19 +3609,14 @@ ac_compiler_gnu=$ac_cv_c_compiler_gnu
# If both library and header were found, use them
-{ $as_echo "$as_me:$LINENO: checking for BZ2_bzCompressInit in -lbz2" >&5
else
LIBS="-lbz2 $LIBS"
-/* confdefs.h. */
-_ACEOF
@@ -4022,43 +3634,18 @@ return BZ2_bzCompressInit ();
return 0;
_ACEOF
-esac
- ac_status=$?
- }; then
else
fi
fi
#define HAVE_LIBBZ2 1
_ACEOF
@@ -4067,9 +3654,9 @@ _ACEOF
fi
- { $as_echo "$as_me:$LINENO: checking bzlib in ${BZLIB_HOME}" >&5
+ { $as_echo "$as_me:${as_lineno-$LINENO}: checking bzlib in ${BZLIB_HOME}" >&5
$as_echo_n "checking bzlib in ${BZLIB_HOME}... " >&6; }
- { $as_echo "$as_me:$LINENO: result: ok" >&5
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: ok" >&5
$as_echo "ok" >&6; }
LIBBZ2=-lbz2
@@ -4077,17 +3664,17 @@ $as_echo "ok" >&6; }
# If either header or library was not found, revert and bomb
LDFLAGS="$BZLIB_OLD_LDFLAGS"
CPPFLAGS="$BZLIB_OLD_CPPFLAGS"
- { $as_echo "$as_me:$LINENO: result: failed" >&5
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: failed" >&5
$as_echo "failed" >&6; }
# Don't fail; this is optional in Darshan
# AC_MSG_ERROR(either specify a valid bzlib installation with --with-bzlib=DIR or disable bzlib usage with --without-bzlib)
# TODO: it would be nice if this showed up at the _end_ of
# configure...
- { $as_echo "$as_me:$LINENO: WARNING: libbz2 not found; Darshan utilities will use gzip only." >&5
+ { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: libbz2 not found; Darshan utilities will use gzip only." >&5
$as_echo "$as_me: WARNING: libbz2 not found; Darshan utilities will use gzip only." >&2;}
fi
fi
@@ -4096,146 +3683,12 @@ fi
# checks to see how we can print 64 bit values on this architecture
-for ac_header in inttypes.h
-do
- { $as_echo "$as_me:$LINENO: checking for $ac_header" >&5
-fi
-else
-{ $as_echo "$as_me:$LINENO: checking $ac_header usability" >&5
-$as_echo_n "checking $ac_header usability... " >&6; }
-/* confdefs.h. */
-_ACEOF
-_ACEOF
-esac
- ac_status=$?
-else
-fi
-{ $as_echo "$as_me:$LINENO: checking $ac_header presence" >&5
-$as_echo_n "checking $ac_header presence... " >&6; }
-/* confdefs.h. */
-_ACEOF
-_ACEOF
-esac
- ac_status=$?
- }; then
-else
-fi
- yes:no: )
- { $as_echo "$as_me:$LINENO: WARNING: $ac_header: accepted by the compiler, rejected by the preprocessor!" >&5
-$as_echo "$as_me: WARNING: $ac_header: accepted by the compiler, rejected by the preprocessor!" >&2;}
- { $as_echo "$as_me:$LINENO: WARNING: $ac_header: proceeding with the compiler's result" >&5
-$as_echo "$as_me: WARNING: $ac_header: proceeding with the compiler's result" >&2;}
- no:yes:* )
- { $as_echo "$as_me:$LINENO: WARNING: $ac_header: present but cannot be compiled" >&5
-$as_echo "$as_me: WARNING: $ac_header: present but cannot be compiled" >&2;}
- { $as_echo "$as_me:$LINENO: WARNING: $ac_header: check for missing prerequisite headers?" >&5
-$as_echo "$as_me: WARNING: $ac_header: check for missing prerequisite headers?" >&2;}
- { $as_echo "$as_me:$LINENO: WARNING: $ac_header: see the Autoconf documentation" >&5
-$as_echo "$as_me: WARNING: $ac_header: see the Autoconf documentation" >&2;}
- { $as_echo "$as_me:$LINENO: WARNING: $ac_header: section \"Present But Cannot Be Compiled\"" >&5
-$as_echo "$as_me: WARNING: $ac_header: section \"Present But Cannot Be Compiled\"" >&2;}
- { $as_echo "$as_me:$LINENO: WARNING: $ac_header: proceeding with the preprocessor's result" >&5
-$as_echo "$as_me: WARNING: $ac_header: proceeding with the preprocessor's result" >&2;}
- { $as_echo "$as_me:$LINENO: WARNING: $ac_header: in the future, the compiler will take precedence" >&5
-$as_echo "$as_me: WARNING: $ac_header: in the future, the compiler will take precedence" >&2;}
-esac
-else
- eval "$as_ac_Header=\$ac_header_preproc"
-fi
-fi
+ for ac_header in inttypes.h
+do :
+ ac_fn_c_check_header_mongrel "$LINENO" "inttypes.h" "ac_cv_header_inttypes_h" "$ac_includes_default"
+if test "x$ac_cv_header_inttypes_h" = xyes; then :
-#define `$as_echo "HAVE_$ac_header" | $as_tr_cpp` 1
+#define HAVE_INTTYPES_H 1
_ACEOF
fi
@@ -4243,17 +3696,13 @@ fi
done
if test $ac_cv_header_inttypes_h = yes; then
- { $as_echo "$as_me:$LINENO: checking whether the inttypes.h PRIxNN macros are broken" >&5
+ { $as_echo "$as_me:${as_lineno-$LINENO}: checking whether the inttypes.h PRIxNN macros are broken" >&5
$as_echo_n "checking whether the inttypes.h PRIxNN macros are broken... " >&6; }
-if test "${gt_cv_inttypes_pri_broken+set}" = set; then
+if ${gt_cv_inttypes_pri_broken+:} false; then :
else
-/* confdefs.h. */
-_ACEOF
#include <inttypes.h>
#ifdef PRId32
@@ -4268,36 +3717,15 @@ main ()
return 0;
_ACEOF
-esac
- ac_status=$?
gt_cv_inttypes_pri_broken=no
else
- gt_cv_inttypes_pri_broken=yes
+ gt_cv_inttypes_pri_broken=yes
fi
fi
-{ $as_echo "$as_me:$LINENO: result: $gt_cv_inttypes_pri_broken" >&5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $gt_cv_inttypes_pri_broken" >&5
$as_echo "$gt_cv_inttypes_pri_broken" >&6; }
fi
if test "$gt_cv_inttypes_pri_broken" = yes; then
@@ -4313,156 +3741,18 @@ _ACEOF
if test x$PRI_MACROS_BROKEN == xyes; then
- { { $as_echo "$as_me:$LINENO: error: PRI_xx macros are broken" >&5
-$as_echo "$as_me: error: PRI_xx macros are broken" >&2;}
+ as_fn_error $? "PRI_xx macros are broken" "$LINENO" 5
else
-do
-fi
-else
-/* confdefs.h. */
-_ACEOF
-_ACEOF
-esac
- ac_status=$?
-else
-fi
-/* confdefs.h. */
-_ACEOF
-_ACEOF
-esac
- ac_status=$?
- }; then
-else
-fi
- yes:no: )
- no:yes:* )
-esac
-else
-fi
-fi
+do :
_ACEOF
else
- { { $as_echo "$as_me:$LINENO: error: Couldn't find inttypes.h" >&5
-$as_echo "$as_me: error: Couldn't find inttypes.h" >&2;}
+ as_fn_error $? "Couldn't find inttypes.h" "$LINENO" 5
fi
done
@@ -4471,9 +3761,9 @@ fi
# Extract the first word of "pdflatex", so it can be a program name with args.
set dummy pdflatex; ac_word=$2
-if test "${ac_cv_prog_HAVE_PDFLATEX+set}" = set; then
+if ${ac_cv_prog_HAVE_PDFLATEX+:} false; then :
else
if test -n "$HAVE_PDFLATEX"; then
@@ -4484,14 +3774,14 @@ for as_dir in $PATH
do
IFS=$as_save_IFS
ac_cv_prog_HAVE_PDFLATEX="yes"
break 2
fi
done
-done
+ done
IFS=$as_save_IFS
test -z "$ac_cv_prog_HAVE_PDFLATEX" && ac_cv_prog_HAVE_PDFLATEX="no"
@@ -4499,43 +3789,38 @@ fi
fi
HAVE_PDFLATEX=$ac_cv_prog_HAVE_PDFLATEX
- { $as_echo "$as_me:$LINENO: result: $HAVE_PDFLATEX" >&5
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: $HAVE_PDFLATEX" >&5
$as_echo "$HAVE_PDFLATEX" >&6; }
else
fi
if test x$HAVE_PDFLATEX == xyes; then
- { $as_echo "$as_me:$LINENO: checking for -halt-on-error argument to pdflatex" >&5
+ { $as_echo "$as_me:${as_lineno-$LINENO}: checking for -halt-on-error argument to pdflatex" >&5
$as_echo_n "checking for -halt-on-error argument to pdflatex... " >&6; }
PDFLATEX_GREP=`pdflatex --help |grep halt-on-error`
if test "x$PDFLATEX_GREP" != "x"; then
__DARSHAN_PDFLATEX_HALT_ON_ERROR="-halt-on-error"
else
__DARSHAN_PDFLATEX_HALT_ON_ERROR=""
fi
fi
- { $as_echo "$as_me:$LINENO: checking whether byte ordering is bigendian" >&5
+ { $as_echo "$as_me:${as_lineno-$LINENO}: checking whether byte ordering is bigendian" >&5
$as_echo_n "checking whether byte ordering is bigendian... " >&6; }
-if test "${ac_cv_c_bigendian+set}" = set; then
+if ${ac_cv_c_bigendian+:} false; then :
else
ac_cv_c_bigendian=unknown
# See if we're dealing with a universal compiler.
-/* confdefs.h. */
-_ACEOF
#ifndef __APPLE_CC__
not a universal capable compiler
@@ -4543,46 +3828,34 @@ cat >>conftest.$ac_ext <<_ACEOF
typedef int dummy;
_ACEOF
-esac
- ac_status=$?
+if ac_fn_c_try_compile "$LINENO"; then :
# Check for potential -arch flags. It is not universal unless
- # there are some -arch flags. Note that *ppc* also matches
- # ppc64. This check is also rather less than ideal.
- case "${CC} ${CFLAGS} ${CPPFLAGS} ${LDFLAGS}" in #(
- *-arch*ppc*|*-arch*i386*|*-arch*x86_64*) ac_cv_c_bigendian=universal;;
- esac
-else
+ # there are at least two -arch flags with different values.
+ ac_arch=
+ ac_prev=
+ for ac_word in $CC $CFLAGS $CPPFLAGS $LDFLAGS; do
+ if test -n "$ac_prev"; then
+ case $ac_word in
+ i?86 | x86_64 | ppc | ppc64)
+ if test -z "$ac_arch" || test "$ac_arch" = "$ac_word"; then
+ ac_arch=$ac_word
+ else
+ ac_cv_c_bigendian=universal
+ break
+ fi
+ esac
+ ac_prev=
+ elif test "x$ac_word" = "x-arch"; then
+ ac_prev=arch
+ fi
+ done
fi
if test $ac_cv_c_bigendian = unknown; then
# See if sys/param.h defines the BYTE_ORDER macro.
-/* confdefs.h. */
-_ACEOF
#include <sys/param.h>
@@ -4600,30 +3873,9 @@ main ()
return 0;
_ACEOF
-esac
- ac_status=$?
# It does; now see whether it defined to BIG_ENDIAN or not.
-/* confdefs.h. */
-_ACEOF
@@ -4639,49 +3891,18 @@ main ()
return 0;
_ACEOF
-esac
- ac_status=$?
ac_cv_c_bigendian=yes
else
- ac_cv_c_bigendian=no
+ ac_cv_c_bigendian=no
fi
-else
fi
fi
# See if <limits.h> defines _LITTLE_ENDIAN or _BIG_ENDIAN (e.g., Solaris).
-/* confdefs.h. */
-_ACEOF
#include <limits.h>
@@ -4696,30 +3917,9 @@ main ()
return 0;
_ACEOF
-esac
- ac_status=$?
# It does; now see whether it defined to _BIG_ENDIAN or not.
-/* confdefs.h. */
-_ACEOF
#include <limits.h>
@@ -4734,51 +3934,20 @@ main ()
return 0;
_ACEOF
-esac
- ac_status=$?
else
fi
-else
fi
fi
# Compile a test program.
# Try to guess by grepping values from an object file.
-/* confdefs.h. */
-_ACEOF
short int ascii_mm[] =
{ 0x4249, 0x4765, 0x6E44, 0x6961, 0x6E53, 0x7953, 0 };
@@ -4804,24 +3973,7 @@ return use_ascii (foo) == use_ebcdic (foo);
return 0;
_ACEOF
-esac
- ac_status=$?
if grep BIGenDianSyS conftest.$ac_objext >/dev/null; then
fi
@@ -4833,20 +3985,10 @@ $as_echo "$ac_try_echo") >&5
fi
fi
-else
fi
else
-/* confdefs.h. */
-_ACEOF
int
@@ -4866,79 +4008,41 @@ main ()
return 0;
_ACEOF
-esac
- ac_status=$?
-esac
- ac_status=$?
else
-ac_cv_c_bigendian=yes
+ ac_cv_c_bigendian=yes
fi
fi
fi
fi
-{ $as_echo "$as_me:$LINENO: result: $ac_cv_c_bigendian" >&5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_c_bigendian" >&5
$as_echo "$ac_cv_c_bigendian" >&6; }
case $ac_cv_c_bigendian in #(
yes)
- cat >>confdefs.h <<\_ACEOF
-#define WORDS_BIGENDIAN 1
-_ACEOF
+ $as_echo "#define WORDS_BIGENDIAN 1" >>confdefs.h
no)
universal)
-#define AC_APPLE_UNIVERSAL_BUILD 1
-_ACEOF
+$as_echo "#define AC_APPLE_UNIVERSAL_BUILD 1" >>confdefs.h
- { { $as_echo "$as_me:$LINENO: error: unknown endianness
- presetting ac_cv_c_bigendian=no (or yes) will help" >&5
-$as_echo "$as_me: error: unknown endianness
- presetting ac_cv_c_bigendian=no (or yes) will help" >&2;}
- { (exit 1); exit 1; }; } ;;
+ as_fn_error $? "unknown endianness
+ presetting ac_cv_c_bigendian=no (or yes) will help" "$LINENO" 5 ;;
esac
old_cflags="$CFLAGS"
CFLAGS="$CFLAGS -D_FILE_OFFSET_BITS=64 -D_LARGEFILE64_SOURCE"
-{ $as_echo "$as_me:$LINENO: checking for off64_t" >&5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for off64_t" >&5
$as_echo_n "checking for off64_t... " >&6; }
-/* confdefs.h. */
-_ACEOF
+cat confdefs.h - <<_ACEOF >conftest.$ac_ext
#include <stdio.h>
@@ -4965,46 +4069,23 @@ main ()
return 0;
_ACEOF
-esac
- ac_status=$?
-#define HAVE_OFF64_T 1
-_ACEOF
+$as_echo "#define HAVE_OFF64_T 1" >>confdefs.h
else
fi
CFLAGS="$old_cflags"
DARSHAN_ENABLE_SHARED=0
# Check whether --enable-shared was given.
-if test "${enable_shared+set}" = set; then
+if test "${enable_shared+set}" = set; then :
enableval=$enable_shared; if test "x$enableval" = "xyes" ; then
DARSHAN_ENABLE_SHARED=1
fi
@@ -5012,102 +4093,12 @@ fi
fi
for ac_func in strndup
-do
-as_ac_var=`$as_echo "ac_cv_func_$ac_func" | $as_tr_sh`
-{ $as_echo "$as_me:$LINENO: checking for $ac_func" >&5
-$as_echo_n "checking for $ac_func... " >&6; }
-if { as_var=$as_ac_var; eval "test \"\${$as_var+set}\" = set"; }; then
-else
-/* confdefs.h. */
-_ACEOF
-/* Define $ac_func to an innocuous variant, in case <limits.h> declares $ac_func.
- For example, HP-UX 11i <limits.h> declares gettimeofday. */
-#define $ac_func innocuous_$ac_func
-/* System header to define __stub macros and hopefully few prototypes,
- which can conflict with char $ac_func (); below.
- Prefer <limits.h> to <assert.h> if __STDC__ is defined, since
- <limits.h> exists even on freestanding compilers. */
-#ifdef __STDC__
-# include <limits.h>
-#else
-# include <assert.h>
-#endif
-#undef $ac_func
-/* Override any GCC internal prototype to avoid an error.
- Use char because int might match the return type of a GCC
- builtin and then its argument prototype would still apply. */
-#ifdef __cplusplus
-extern "C"
-#endif
-char $ac_func ();
-/* The GNU C library defines this for functions which it implements
- to always fail with ENOSYS. Some functions are actually named
- something starting with __ and the normal name is an alias. */
-#if defined __stub_$ac_func || defined __stub___$ac_func
-choke me
-#endif
-int
-main ()
-return $ac_func ();
- return 0;
-_ACEOF
-esac
- ac_status=$?
- }; then
- eval "$as_ac_var=yes"
-else
- eval "$as_ac_var=no"
-fi
-fi
-ac_res=`eval 'as_val=${'$as_ac_var'}
-as_val=`eval 'as_val=${'$as_ac_var'}
+do :
+ ac_fn_c_check_func "$LINENO" "strndup" "ac_cv_func_strndup"
+if test "x$ac_cv_func_strndup" = xyes; then :
-#define `$as_echo "HAVE_$ac_func" | $as_tr_cpp` 1
+#define HAVE_STRNDUP 1
_ACEOF
fi
@@ -5150,13 +4141,13 @@ _ACEOF
case $ac_val in #(
*${as_nl}*)
case $ac_var in #(
esac
case $ac_var in #(
esac ;;
esac
done
@@ -5164,8 +4155,8 @@ $as_echo "$as_me: WARNING: cache variable $ac_var contains a newline" >&2;} ;;
(set) 2>&1 |
case $as_nl`(ac_space=' '; set) 2>&1` in #(
*${as_nl}ac_space=\ *)
- # `set' does not quote correctly, so add quotes (double-quote
- # substitution turns \\\\ into \\, and sed turns \\ into \).
+ # `set' does not quote correctly, so add quotes: double-quote
+ # substitution turns \\\\ into \\, and sed turns \\ into \.
sed -n \
"s/'/'\\\\''/g;
s/^\\([_$as_cr_alnum]*_cv_[_$as_cr_alnum]*\\)=\\(.*\\)/\\1='\\2'/p"
@@ -5187,12 +4178,23 @@ $as_echo "$as_me: WARNING: cache variable $ac_var contains a newline" >&2;} ;;
:end' >>confcache
if diff "$cache_file" confcache >/dev/null 2>&1; then :; else
if test -w "$cache_file"; then
- test "x$cache_file" != "x/dev/null" &&
- { $as_echo "$as_me:$LINENO: updating cache $cache_file" >&5
+ if test "x$cache_file" != "x/dev/null"; then
+ { $as_echo "$as_me:${as_lineno-$LINENO}: updating cache $cache_file" >&5
$as_echo "$as_me: updating cache $cache_file" >&6;}
- cat confcache >$cache_file
+ if test ! -f "$cache_file" || test -h "$cache_file"; then
+ cat confcache >"$cache_file"
+ else
+ case $cache_file in #(
+ mv -f confcache "$cache_file"$$ &&
+ mv -f "$cache_file"$$ "$cache_file" ;; #(
+ mv -f confcache "$cache_file" ;;
+ esac
+ fi
+ fi
else
- { $as_echo "$as_me:$LINENO: not updating unwritable cache $cache_file" >&5
+ { $as_echo "$as_me:${as_lineno-$LINENO}: not updating unwritable cache $cache_file" >&5
$as_echo "$as_me: not updating unwritable cache $cache_file" >&6;}
fi
fi
@@ -5206,14 +4208,15 @@ DEFS=-DHAVE_CONFIG_H
ac_libobjs=
ac_ltlibobjs=
+U=
for ac_i in : $LIBOBJS; do test "x$ac_i" = x: && continue
# 1. Remove the extension, and $U if already installed.
ac_script='s/\$U\././;s/\.o$//;s/\.obj$//'
ac_i=`$as_echo "$ac_i" | sed "$ac_script"`
# 2. Prepend LIBOBJDIR. When used with automake>=1.10 LIBOBJDIR
# will be set to the directory where LIBOBJS objects are built.
- ac_libobjs="$ac_libobjs \${LIBOBJDIR}$ac_i\$U.$ac_objext"
- ac_ltlibobjs="$ac_ltlibobjs \${LIBOBJDIR}$ac_i"'$U.lo'
+ as_fn_append ac_libobjs " \${LIBOBJDIR}$ac_i\$U.$ac_objext"
+ as_fn_append ac_ltlibobjs " \${LIBOBJDIR}$ac_i"'$U.lo'
done
LIBOBJS=$ac_libobjs
@@ -5222,13 +4225,14 @@ LTLIBOBJS=$ac_ltlibobjs
-: ${CONFIG_STATUS=./config.status}
+: "${CONFIG_STATUS=./config.status}"
ac_write_fail=0
ac_clean_files_save=$ac_clean_files
ac_clean_files="$ac_clean_files $CONFIG_STATUS"
-{ $as_echo "$as_me:$LINENO: creating $CONFIG_STATUS" >&5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: creating $CONFIG_STATUS" >&5
$as_echo "$as_me: creating $CONFIG_STATUS" >&6;}
-cat >$CONFIG_STATUS <<_ACEOF || ac_write_fail=1
+as_write_fail=0
+cat >$CONFIG_STATUS <<_ASEOF || as_write_fail=1
#! $SHELL
# Generated by $as_me.
# Run this file to recreate the current configuration.
@@ -5238,17 +4242,18 @@ cat >$CONFIG_STATUS <<_ACEOF || ac_write_fail=1
debug=false
ac_cs_recheck=false
ac_cs_silent=false
-SHELL=\${CONFIG_SHELL-$SHELL}
-_ACEOF
-cat >>$CONFIG_STATUS <<\_ACEOF || ac_write_fail=1
-## M4sh Initialization. ##
+SHELL=\${CONFIG_SHELL-$SHELL}
+export SHELL
+_ASEOF
+cat >>$CONFIG_STATUS <<\_ASEOF || as_write_fail=1
+## M4sh Initialization. ##
# Be more Bourne compatible
DUALCASE=1; export DUALCASE # for MKS sh
-if test -n "${ZSH_VERSION+set}" && (emulate sh) >/dev/null 2>&1; then
+if test -n "${ZSH_VERSION+set}" && (emulate sh) >/dev/null 2>&1; then :
emulate sh
NULLCMD=:
# Pre-4.2 versions of Zsh do word splitting on ${1+"$@"}, which
@@ -5256,23 +4261,15 @@ if test -n "${ZSH_VERSION+set}" && (emulate sh) >/dev/null 2>&1; then
alias -g '${1+"$@"}'='"$@"'
setopt NO_GLOB_SUBST
else
- case `(set -o) 2>/dev/null` in
- *posix*) set -o posix ;;
+ case `(set -o) 2>/dev/null` in #(
+ *posix*) :
+ set -o posix ;; #(
esac
fi
-# PATH needs CR
-# Avoid depending upon Character Ranges.
-as_cr_letters='abcdefghijklmnopqrstuvwxyz'
-as_cr_LETTERS='ABCDEFGHIJKLMNOPQRSTUVWXYZ'
-as_cr_Letters=$as_cr_letters$as_cr_LETTERS
-as_cr_digits='0123456789'
-as_cr_alnum=$as_cr_Letters$as_cr_digits
as_nl='
export as_nl
@@ -5280,7 +4277,13 @@ export as_nl
as_echo='\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\'
as_echo=$as_echo$as_echo$as_echo$as_echo$as_echo
as_echo=$as_echo$as_echo$as_echo$as_echo$as_echo$as_echo
-if (test "X`printf %s $as_echo`" = "X$as_echo") 2>/dev/null; then
+# Prefer a ksh shell builtin over an external printf program on Solaris,
+# but without wasting forks for bash or zsh.
+if test -z "$BASH_VERSION$ZSH_VERSION" \
+ && (test "X`print -r -- $as_echo`" = "X$as_echo") 2>/dev/null; then
+ as_echo='print -r --'
+ as_echo_n='print -rn --'
+elif (test "X`printf %s $as_echo`" = "X$as_echo") 2>/dev/null; then
as_echo='printf %s\n'
as_echo_n='printf %s'
else
@@ -5291,7 +4294,7 @@ else
as_echo_body='eval expr "X$1" : "X\\(.*\\)"'
as_echo_n_body='eval
arg=$1;
- case $arg in
+ case $arg in #(
*"$as_nl"*)
expr "X$arg" : "X\\(.*\\)$as_nl";
arg=`expr "X$arg" : ".*$as_nl\\(.*\\)"`;;
@@ -5314,13 +4317,6 @@ if test "${PATH_SEPARATOR+set}" != set; then
fi
-# Support unset when possible.
-if ( (MAIL=60; unset MAIL) || exit) >/dev/null 2>&1; then
- as_unset=unset
-else
- as_unset=false
-fi
# IFS
# We need space, tab and new line, in precisely that order. Quoting is
@@ -5330,15 +4326,16 @@ fi
IFS=" "" $as_nl"
# Find who we are. Look in the path if we contain no directory separator.
-case $0 in
+as_myself=
+case $0 in #((
*[\\/]* ) as_myself=$0 ;;
*) as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
for as_dir in $PATH
do
IFS=$as_save_IFS
- test -r "$as_dir/$0" && as_myself=$as_dir/$0 && break
-done
+ test -r "$as_dir/$0" && as_myself=$as_dir/$0 && break
+ done
IFS=$as_save_IFS
@@ -5350,12 +4347,16 @@ if test "x$as_myself" = x; then
fi
if test ! -f "$as_myself"; then
$as_echo "$as_myself: error: cannot find myself; rerun with an absolute file name" >&2
+ exit 1
fi
-# Work around bugs in pre-3.0 UWIN ksh.
-for as_var in ENV MAIL MAILPATH
-do ($as_unset $as_var) >/dev/null 2>&1 && $as_unset $as_var
+# Unset variables that we do not need and which cause bugs (e.g. in
+# pre-3.0 UWIN ksh). But do not cause bugs in bash 2.01; the "|| exit 1"
+# suppresses any "Segmentation fault" message there. '((' could
+# trigger a bug in pdksh 5.2.14.
+for as_var in BASH_ENV ENV MAIL MAILPATH
+do eval test x\${$as_var+set} = xset \
+ && ( (unset $as_var) || exit 1) >/dev/null 2>&1 && unset $as_var || :
done
PS1='$ '
PS2='> '
@@ -5367,7 +4368,89 @@ export LC_ALL
LANGUAGE=C
export LANGUAGE
-# Required to use basename.
+# CDPATH.
+(unset CDPATH) >/dev/null 2>&1 && unset CDPATH
+# as_fn_error STATUS ERROR [LINENO LOG_FD]
+# Output "`basename $0`: error: ERROR" to stderr. If LINENO and LOG_FD are
+# provided, also output the error to LOG_FD, referencing LINENO. Then exit the
+# script with STATUS, using 1 if that was 0.
+as_fn_error ()
+ as_status=$1; test $as_status -eq 0 && as_status=1
+ if test "$4"; then
+ as_lineno=${as_lineno-"$3"} as_lineno_stack=as_lineno_stack=$as_lineno_stack
+ $as_echo "$as_me:${as_lineno-$LINENO}: error: $2" >&$4
+ fi
+ $as_echo "$as_me: error: $2" >&2
+ as_fn_exit $as_status
+} # as_fn_error
+# as_fn_set_status STATUS
+# Set $? to STATUS, without forking.
+as_fn_set_status ()
+ return $1
+} # as_fn_set_status
+# as_fn_exit STATUS
+# Exit the shell with STATUS, even in a "trap 0" or "set -e" context.
+as_fn_exit ()
+ set +e
+ as_fn_set_status $1
+ exit $1
+} # as_fn_exit
+# as_fn_unset VAR
+# Portably unset VAR.
+as_fn_unset ()
+ { eval $1=; unset $1;}
+as_unset=as_fn_unset
+# as_fn_append VAR VALUE
+# Append the text in VALUE to the end of the definition contained in VAR. Take
+# advantage of any shell optimizations that allow amortized linear growth over
+# repeated appends, instead of the typical quadratic growth present in naive
+# implementations.
+if (eval "as_var=1; as_var+=2; test x\$as_var = x12") 2>/dev/null; then :
+ eval 'as_fn_append ()
+ eval $1+=\$2
+else
+ as_fn_append ()
+ eval $1=\$$1\$2
+fi # as_fn_append
+# as_fn_arith ARG...
+# Perform arithmetic evaluation on the ARGs, and store the result in the
+# global $as_val. Take advantage of shells that can avoid forks. The arguments
+# must be portable across $(()) and expr.
+if (eval "test \$(( 1 + 1 )) = 2") 2>/dev/null; then :
+ eval 'as_fn_arith ()
+ as_val=$(( $* ))
+else
+ as_fn_arith ()
+ as_val=`expr "$@" || test $? -eq 1`
+fi # as_fn_arith
if expr a : '\(a\)' >/dev/null 2>&1 &&
test "X`expr 00001 : '.*\(...\)'`" = X001; then
as_expr=expr
@@ -5381,8 +4464,12 @@ else
as_basename=false
fi
+if (as_dir=`dirname -- /` && test "X$as_dir" = X/) >/dev/null 2>&1; then
+ as_dirname=dirname
+else
+ as_dirname=false
+fi
-# Name of the executable.
as_me=`$as_basename -- "$0" ||
$as_expr X/"$0" : '.*/\([^/][^/]*\)/*$' \| \
X"$0" : 'X\(//\)$' \| \
@@ -5402,76 +4489,25 @@ $as_echo X/"$0" |
s/.*/./; q'`
-# CDPATH.
-$as_unset CDPATH
- as_lineno_1=$LINENO
- as_lineno_2=$LINENO
- test "x$as_lineno_1" != "x$as_lineno_2" &&
- test "x`expr $as_lineno_1 + 1`" = "x$as_lineno_2" || {
- # Create $as_me.lineno as a copy of $as_myself, but with $LINENO
- # uniformly replaced by the line number. The first 'sed' inserts a
- # line-number line after each line using $LINENO; the second 'sed'
- # does the real work. The second script uses 'N' to pair each
- # line-number line with the line containing $LINENO, and appends
- # trailing '-' during substitution so that $LINENO is not a special
- # case at line end.
- # (Raja R Harinath suggested sed '=', and Paul Eggert wrote the
- # scripts with optimization help from Paolo Bonzini. Blame Lee
- # E. McMahon (1931-1989) for sed's syntax. :-)
- sed -n '
- p
- /[$]LINENO/=
- ' <$as_myself |
- sed '
- s/[$]LINENO.*/&-/
- t lineno
- b
- :lineno
- N
- :loop
- s/[$]LINENO\([^'$as_cr_alnum'_].*\n\)\(.*\)/\2\1\2/
- t loop
- s/-\n.*//
- ' >$as_me.lineno &&
- chmod +x "$as_me.lineno" ||
- { $as_echo "$as_me: error: cannot create $as_me.lineno; rerun with a POSIX shell" >&2
- # Don't try to exec as it changes $[0], causing all sort of problems
- # (the dirname of $[0] is not the place where we might find the
- # original and so on. Autoconf is especially sensitive to this).
- . "./$as_me.lineno"
- # Exit status is that of the last command.
- exit
-if (as_dir=`dirname -- /` && test "X$as_dir" = X/) >/dev/null 2>&1; then
- as_dirname=dirname
-else
- as_dirname=false
-fi
+# Avoid depending upon Character Ranges.
+as_cr_letters='abcdefghijklmnopqrstuvwxyz'
+as_cr_LETTERS='ABCDEFGHIJKLMNOPQRSTUVWXYZ'
+as_cr_Letters=$as_cr_letters$as_cr_LETTERS
+as_cr_digits='0123456789'
+as_cr_alnum=$as_cr_Letters$as_cr_digits
ECHO_C= ECHO_N= ECHO_T=
-case `echo -n x` in
+case `echo -n x` in #(((((
-n*)
- case `echo 'x\c'` in
+ case `echo 'xy\c'` in
*c*) ECHO_T=' ';; # ECHO_T is single tab character.
- *) ECHO_C='\c';;
+ xy) ECHO_C='\c';;
+ *) echo `echo ksh88 bug on AIX 6.1` > /dev/null
+ ECHO_T=' ';;
esac;;
ECHO_N='-n';;
esac
-if expr a : '\(a\)' >/dev/null 2>&1 &&
- test "X`expr 00001 : '.*\(...\)'`" = X001; then
- as_expr=expr
-else
- as_expr=false
-fi
rm -f conf$$ conf$$.exe conf$$.file
if test -d conf$$.dir; then
@@ -5486,49 +4522,85 @@ if (echo >conf$$.file) 2>/dev/null; then
# ... but there are two gotchas:
# 1) On MSYS, both `ln -s file dir' and `ln file dir' fail.
# 2) DJGPP < 2.04 has no symlinks; `ln -s' creates a wrapper executable.
- # In both cases, we have to default to `cp -p'.
+ # In both cases, we have to default to `cp -pR'.
ln -s conf$$.file conf$$.dir 2>/dev/null && test ! -f conf$$.exe ||
- as_ln_s='cp -p'
+ as_ln_s='cp -pR'
elif ln conf$$.file conf$$ 2>/dev/null; then
as_ln_s=ln
else
- as_ln_s='cp -p'
+ as_ln_s='cp -pR'
fi
else
- as_ln_s='cp -p'
+ as_ln_s='cp -pR'
fi
rm -f conf$$ conf$$.exe conf$$.dir/conf$$.file conf$$.file
rmdir conf$$.dir 2>/dev/null
+# as_fn_mkdir_p
+# Create "$as_dir" as a directory, including parents if necessary.
+as_fn_mkdir_p ()
+ case $as_dir in #(
+ -*) as_dir=./$as_dir;;
+ esac
+ test -d "$as_dir" || eval $as_mkdir_p || {
+ as_dirs=
+ while :; do
+ *\'*) as_qdir=`$as_echo "$as_dir" | sed "s/'/'\\\\\\\\''/g"`;; #'(
+ *) as_qdir=$as_dir;;
+ esac
+ as_dirs="'$as_qdir' $as_dirs"
+ as_dir=`$as_dirname -- "$as_dir" ||
+$as_expr X"$as_dir" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
+ X"$as_dir" : 'X\(//\)[^/]' \| \
+ X"$as_dir" : 'X\(//\)$' \| \
+ X"$as_dir" : 'X\(/\)' \| . 2>/dev/null ||
+$as_echo X"$as_dir" |
+ sed '/^X\(.*[^/]\)\/\/*[^/][^/]*\/*$/{
+ s//\1/
+ q
+ /^X\(\/\/\)[^/].*/{
+ s//\1/
+ q
+ /^X\(\/\/\)$/{
+ s//\1/
+ q
+ /^X\(\/\).*/{
+ s//\1/
+ q
+ s/.*/./; q'`
+ test -d "$as_dir" && break
+ done
+ test -z "$as_dirs" || eval "mkdir $as_dirs"
+ } || test -d "$as_dir" || as_fn_error $? "cannot create directory $as_dir"
+} # as_fn_mkdir_p
if mkdir -p . 2>/dev/null; then
- as_mkdir_p=:
+ as_mkdir_p='mkdir -p "$as_dir"'
else
test -d ./-p && rmdir ./-p
as_mkdir_p=false
fi
-if test -x / >/dev/null 2>&1; then
- as_test_x='test -x'
-else
- if ls -dL / >/dev/null 2>&1; then
- as_ls_L_option=L
- else
- as_ls_L_option=
- fi
- as_test_x='
- eval sh -c '\''
- if test -d "$1"; then
- test -d "$1/.";
- else
- case $1 in
- -*)set "./$1";;
- esac;
- case `ls -ld'$as_ls_L_option' "$1" 2>/dev/null` in
- ???[sx]*):;;*)false;;esac;fi
- '\'' sh
-fi
-as_executable_p=$as_test_x
+# as_fn_executable_p FILE
+# Test if FILE is an executable regular file.
+as_fn_executable_p ()
+ test -f "$1" && test -x "$1"
+} # as_fn_executable_p
+as_test_x='test -x'
+as_executable_p=as_fn_executable_p
# Sed expression to map a string onto a valid CPP name.
as_tr_cpp="eval sed 'y%*$as_cr_letters%P$as_cr_LETTERS%;s%[^_$as_cr_alnum]%_%g'"
@@ -5538,13 +4610,19 @@ as_tr_sh="eval sed 'y%*+%pp%;s%[^_$as_cr_alnum]%_%g'"
exec 6>&1
+## Main body of $CONFIG_STATUS script. ##
+_ASEOF
+test $as_write_fail = 0 && chmod +x $CONFIG_STATUS || ac_write_fail=1
-# Save the log message, to keep $[0] and so on meaningful, and to
+cat >>$CONFIG_STATUS <<\_ACEOF || ac_write_fail=1
+# Save the log message, to keep $0 and so on meaningful, and to
# report actual input values of CONFIG_FILES etc. instead of their
# values after options handling.
ac_log="
This file was extended by darshan-util $as_me 3.0.0-pre1, which was
-generated by GNU Autoconf 2.63. Invocation command line was
+generated by GNU Autoconf 2.69. Invocation command line was
CONFIG_FILES = $CONFIG_FILES
CONFIG_HEADERS = $CONFIG_HEADERS
@@ -5575,13 +4653,15 @@ _ACEOF
ac_cs_usage="\
-\`$as_me' instantiates files from templates according to the
-current configuration.
+\`$as_me' instantiates files and other configuration actions
+from templates according to the current configuration. Unless the files
+and actions are specified as TAGs, all are instantiated by default.
-Usage: $0 [OPTION]... [FILE]...
+Usage: $0 [OPTION]... [TAG]...
-h, --help print this help, then exit
-V, --version print version number and configuration settings, then exit
+ --config print configuration, then exit
-q, --quiet, --silent
do not print progress messages
-d, --debug don't remove temporary files
@@ -5597,16 +4677,17 @@ $config_files
Configuration headers:
$config_headers
-Report bugs to <bug-autoconf at gnu.org>."
+Report bugs to the package provider."
_ACEOF
cat >>$CONFIG_STATUS <<_ACEOF || ac_write_fail=1
+ac_cs_config="`$as_echo "$ac_configure_args" | sed 's/^ //; s/[\\""\`\$]/\\\\&/g'`"
ac_cs_version="\\
darshan-util config.status 3.0.0-pre1
-configured by $0, generated by GNU Autoconf 2.63,
- with options \\"`$as_echo "$ac_configure_args" | sed 's/^ //; s/[\\""\`\$]/\\\\&/g'`\\"
+configured by $0, generated by GNU Autoconf 2.69,
+ with options \\"\$ac_cs_config\\"
-Copyright (C) 2008 Free Software Foundation, Inc.
+Copyright (C) 2012 Free Software Foundation, Inc.
This config.status script is free software; the Free Software Foundation
gives unlimited permission to copy, distribute and modify it."
@@ -5622,11 +4703,16 @@ ac_need_defaults=:
while test $# != 0
do
case $1 in
ac_option=`expr "X$1" : 'X\([^=]*\)='`
ac_optarg=`expr "X$1" : 'X[^=]*=\(.*\)'`
ac_shift=:
+ ac_option=`expr "X$1" : 'X\([^=]*\)='`
+ ac_optarg=
+ ac_shift=:
ac_option=$1
ac_optarg=$2
@@ -5640,27 +4726,29 @@ do
ac_cs_recheck=: ;;
--version | --versio | --versi | --vers | --ver | --ve | --v | -V )
$as_echo "$ac_cs_version"; exit ;;
+ --config | --confi | --conf | --con | --co | --c )
+ $as_echo "$ac_cs_config"; exit ;;
--debug | --debu | --deb | --de | --d | -d )
debug=: ;;
--file | --fil | --fi | --f )
$ac_shift
case $ac_optarg in
*\'*) ac_optarg=`$as_echo "$ac_optarg" | sed "s/'/'\\\\\\\\''/g"` ;;
+ '') as_fn_error $? "missing file argument" ;;
esac
- CONFIG_FILES="$CONFIG_FILES '$ac_optarg'"
+ as_fn_append CONFIG_FILES " '$ac_optarg'"
ac_need_defaults=false;;
--header | --heade | --head | --hea )
$ac_shift
case $ac_optarg in
esac
- CONFIG_HEADERS="$CONFIG_HEADERS '$ac_optarg'"
+ as_fn_append CONFIG_HEADERS " '$ac_optarg'"
--he | --h)
# Conflict between --help and --header
- { $as_echo "$as_me: error: ambiguous option: $1
-Try \`$0 --help' for more information." >&2
- { (exit 1); exit 1; }; };;
+ as_fn_error $? "ambiguous option: \`$1'
+Try \`$0 --help' for more information.";;
--help | --hel | -h )
$as_echo "$ac_cs_usage"; exit ;;
-q | -quiet | --quiet | --quie | --qui | --qu | --q \
@@ -5668,11 +4756,10 @@ Try \`$0 --help' for more information." >&2
ac_cs_silent=: ;;
# This is an error.
- -*) { $as_echo "$as_me: error: unrecognized option: $1
+ -*) as_fn_error $? "unrecognized option: \`$1'
+Try \`$0 --help' for more information." ;;
- *) ac_config_targets="$ac_config_targets $1"
+ *) as_fn_append ac_config_targets " $1"
ac_need_defaults=false ;;
esac
@@ -5689,7 +4776,7 @@ fi
_ACEOF
if \$ac_cs_recheck; then
- set X '$SHELL' '$0' $ac_configure_args \$ac_configure_extra_args --no-create --no-recursion
+ set X $SHELL '$0' $ac_configure_args \$ac_configure_extra_args --no-create --no-recursion
shift
\$as_echo "running CONFIG_SHELL=$SHELL \$*" >&6
CONFIG_SHELL='$SHELL'
@@ -5723,9 +4810,7 @@ do
"darshan-job-summary/bin/darshan-job-summary.pl") CONFIG_FILES="$CONFIG_FILES darshan-job-summary/bin/darshan-job-summary.pl" ;;
"maint/darshan-util.pc") CONFIG_FILES="$CONFIG_FILES maint/darshan-util.pc" ;;
- *) { { $as_echo "$as_me:$LINENO: error: invalid argument: $ac_config_target" >&5
-$as_echo "$as_me: error: invalid argument: $ac_config_target" >&2;}
+ *) as_fn_error $? "invalid argument: \`$ac_config_target'" "$LINENO" 5;;
esac
done
@@ -5747,26 +4832,24 @@ fi
# after its creation but before its name has been assigned to `$tmp'.
$debug ||
- tmp=
+ tmp= ac_tmp=
trap 'exit_status=$?
- { test -z "$tmp" || test ! -d "$tmp" || rm -fr "$tmp"; } && exit $exit_status
+ : "${ac_tmp:=$tmp}"
+ { test ! -d "$ac_tmp" || rm -fr "$ac_tmp"; } && exit $exit_status
' 0
- trap '{ (exit 1); exit 1; }' 1 2 13 15
+ trap 'as_fn_exit 1' 1 2 13 15
# Create a (secure) tmp directory for tmp files.
tmp=`(umask 077 && mktemp -d "./confXXXXXX") 2>/dev/null` &&
- test -n "$tmp" && test -d "$tmp"
+ test -d "$tmp"
tmp=./conf$$-$RANDOM
(umask 077 && mkdir "$tmp")
- $as_echo "$as_me: cannot create a temporary directory in ." >&2
+} || as_fn_error $? "cannot create a temporary directory in ." "$LINENO" 5
+ac_tmp=$tmp
# Set up the scripts for CONFIG_FILES section.
# No need to generate them if there are no CONFIG_FILES.
@@ -5774,7 +4857,13 @@ $debug ||
if test -n "$CONFIG_FILES"; then
-ac_cr='
+ac_cr=`echo X | tr X '\015'`
+# On cygwin, bash can eat \r inside `` if the user requested igncr.
+# But we know of no other shell where ac_cr would be empty at this
+# point, so we can use a bashism as a fallback.
+if test "x$ac_cr" = x; then
+ eval ac_cr=\$\'\\r\'
+fi
ac_cs_awk_cr=`$AWK 'BEGIN { print "a\rb" }' </dev/null 2>/dev/null`
if test "$ac_cs_awk_cr" = "a${ac_cr}b"; then
ac_cs_awk_cr='\\r'
@@ -5782,7 +4871,7 @@ else
ac_cs_awk_cr=$ac_cr
fi
-echo 'BEGIN {' >"$tmp/subs1.awk" &&
+echo 'BEGIN {' >"$ac_tmp/subs1.awk" &&
_ACEOF
@@ -5791,24 +4880,18 @@ _ACEOF
echo "$ac_subst_vars" | sed 's/.*/&!$&$ac_delim/' &&
echo "_ACEOF"
} >conf$$subs.sh ||
- { { $as_echo "$as_me:$LINENO: error: could not make $CONFIG_STATUS" >&5
-$as_echo "$as_me: error: could not make $CONFIG_STATUS" >&2;}
-ac_delim_num=`echo "$ac_subst_vars" | grep -c '$'`
+ as_fn_error $? "could not make $CONFIG_STATUS" "$LINENO" 5
+ac_delim_num=`echo "$ac_subst_vars" | grep -c '^'`
ac_delim='%!_!# '
for ac_last_try in false false false false false :; do
. ./conf$$subs.sh ||
ac_delim_n=`sed -n "s/.*$ac_delim\$/X/p" conf$$subs.awk | grep -c X`
if test $ac_delim_n = $ac_delim_num; then
break
elif $ac_last_try; then
else
ac_delim="$ac_delim!$ac_delim _$ac_delim!! "
fi
@@ -5816,7 +4899,7 @@ done
rm -f conf$$subs.sh
-cat >>"\$tmp/subs1.awk" <<\\_ACAWK &&
+cat >>"\$ac_tmp/subs1.awk" <<\\_ACAWK &&
_ACEOF
sed -n '
h
@@ -5830,7 +4913,7 @@ s/'"$ac_delim"'$//
t delim
:nl
h
-s/\(.\{148\}\).*/\1/
+s/\(.\{148\}\)..*/\1/
t more1
s/["\\]/\\&/g; s/^/"/; s/$/\\n"\\/
p
@@ -5844,7 +4927,7 @@ s/.\{148\}//
t nl
:delim
h
t more2
s/["\\]/\\&/g; s/^/"/; s/$/"/
p
@@ -5864,7 +4947,7 @@ t delim
rm -f conf$$subs.awk
_ACAWK
-cat >>"\$tmp/subs1.awk" <<_ACAWK &&
+cat >>"\$ac_tmp/subs1.awk" <<_ACAWK &&
for (key in S) S_is_set[key] = 1
FS = ""
@@ -5896,23 +4979,29 @@ if sed "s/$ac_cr//" < /dev/null > /dev/null 2>&1; then
sed "s/$ac_cr\$//; s/$ac_cr/$ac_cs_awk_cr/g"
else
cat
-fi < "$tmp/subs1.awk" > "$tmp/subs.awk" \
- || { { $as_echo "$as_me:$LINENO: error: could not setup config files machinery" >&5
-$as_echo "$as_me: error: could not setup config files machinery" >&2;}
+fi < "$ac_tmp/subs1.awk" > "$ac_tmp/subs.awk" \
+ || as_fn_error $? "could not setup config files machinery" "$LINENO" 5
_ACEOF
-# VPATH may cause trouble with some makes, so we remove $(srcdir),
-# ${srcdir} and @srcdir@ from VPATH if srcdir is ".", strip leading and
+# VPATH may cause trouble with some makes, so we remove sole $(srcdir),
+# ${srcdir} and @srcdir@ entries from VPATH if srcdir is ".", strip leading and
# trailing colons and then remove the whole line if VPATH becomes empty
# (actually we leave an empty line to preserve line numbers).
if test "x$srcdir" = x.; then
- ac_vpsub='/^[ ]*VPATH[ ]*=/{
-s/:*\$(srcdir):*/:/
-s/:*\${srcdir}:*/:/
-s/:*@srcdir@:*/:/
-s/^\([^=]*=[ ]*\):*/\1/
+ ac_vpsub='/^[ ]*VPATH[ ]*=[ ]*/{
+h
+s///
+s/^/:/
+s/[ ]*$/:/
+s/:\$(srcdir):/:/g
+s/:\${srcdir}:/:/g
+s/:@srcdir@:/:/g
+s/^:*//
s/:*$//
+x
+s/\(=[ ]*\).*/\1/
+G
+s/\n//
s/^[^=]*=[ ]*$//
fi
@@ -5924,7 +5013,7 @@ fi # test -n "$CONFIG_FILES"
# No need to generate them if there are no CONFIG_HEADERS.
# This happens for instance with `./config.status Makefile'.
if test -n "$CONFIG_HEADERS"; then
-cat >"$tmp/defines.awk" <<\_ACAWK ||
+cat >"$ac_tmp/defines.awk" <<\_ACAWK ||
BEGIN {
_ACEOF
@@ -5936,13 +5025,11 @@ _ACEOF
# handling of long lines.
ac_delim='%!_!# '
for ac_last_try in false false :; do
- ac_t=`sed -n "/$ac_delim/p" confdefs.h`
- if test -z "$ac_t"; then
+ ac_tt=`sed -n "/$ac_delim/p" confdefs.h`
+ if test -z "$ac_tt"; then
break
- { { $as_echo "$as_me:$LINENO: error: could not make $CONFIG_HEADERS" >&5
-$as_echo "$as_me: error: could not make $CONFIG_HEADERS" >&2;}
+ as_fn_error $? "could not make $CONFIG_HEADERS" "$LINENO" 5
else
fi
@@ -6027,9 +5114,7 @@ cat >>$CONFIG_STATUS <<_ACEOF || ac_write_fail=1
_ACAWK
_ACEOF
- { { $as_echo "$as_me:$LINENO: error: could not setup config headers machinery" >&5
-$as_echo "$as_me: error: could not setup config headers machinery" >&2;}
+ as_fn_error $? "could not setup config headers machinery" "$LINENO" 5
fi # test -n "$CONFIG_HEADERS"
@@ -6042,9 +5127,7 @@ do
esac
case $ac_mode$ac_tag in
:[FHL]*:*);;
- :L* | :C*:*) { { $as_echo "$as_me:$LINENO: error: invalid tag $ac_tag" >&5
-$as_echo "$as_me: error: invalid tag $ac_tag" >&2;}
+ :L* | :C*:*) as_fn_error $? "invalid tag \`$ac_tag'" "$LINENO" 5;;
:[FH]-) ac_tag=-:-;;
:[FH]*) ac_tag=$ac_tag:$ac_tag.in;;
esac
@@ -6063,7 +5146,7 @@ $as_echo "$as_me: error: invalid tag $ac_tag" >&2;}
for ac_f
do
case $ac_f in
- -) ac_f="$tmp/stdin";;
+ -) ac_f="$ac_tmp/stdin";;
*) # Look for the file first in the build tree, then in the source tree
# (if the path is not absolute). The absolute path cannot be DOS-style,
# because $ac_f cannot contain `:'.
@@ -6072,12 +5155,10 @@ $as_echo "$as_me: error: invalid tag $ac_tag" >&2;}
[\\/$]*) false;;
*) test -f "$srcdir/$ac_f" && ac_f="$srcdir/$ac_f";;
esac ||
- { { $as_echo "$as_me:$LINENO: error: cannot find input file: $ac_f" >&5
-$as_echo "$as_me: error: cannot find input file: $ac_f" >&2;}
+ as_fn_error 1 "cannot find input file: \`$ac_f'" "$LINENO" 5;;
esac
case $ac_f in *\'*) ac_f=`$as_echo "$ac_f" | sed "s/'/'\\\\\\\\''/g"`;; esac
- ac_file_inputs="$ac_file_inputs '$ac_f'"
+ as_fn_append ac_file_inputs " '$ac_f'"
done
# Let's still pretend it is `configure' which instantiates (i.e., don't
@@ -6088,7 +5169,7 @@ $as_echo "$as_me: error: cannot find input file: $ac_f" >&2;}
`' by configure.'
if test x"$ac_file" != x-; then
configure_input="$ac_file. $configure_input"
- { $as_echo "$as_me:$LINENO: creating $ac_file" >&5
+ { $as_echo "$as_me:${as_lineno-$LINENO}: creating $ac_file" >&5
$as_echo "$as_me: creating $ac_file" >&6;}
fi
# Neutralize special characters interpreted by sed in replacement strings.
@@ -6100,10 +5181,8 @@ $as_echo "$as_me: creating $ac_file" >&6;}
esac
case $ac_tag in
- *:-:* | *:-) cat >"$tmp/stdin" \
- || { { $as_echo "$as_me:$LINENO: error: could not create $ac_file" >&5
-$as_echo "$as_me: error: could not create $ac_file" >&2;}
+ *:-:* | *:-) cat >"$ac_tmp/stdin" \
+ || as_fn_error $? "could not create $ac_file" "$LINENO" 5 ;;
esac
esac
@@ -6131,47 +5210,7 @@ $as_echo X"$ac_file" |
q
s/.*/./; q'`
- { as_dir="$ac_dir"
- case $as_dir in #(
- -*) as_dir=./$as_dir;;
- esac
- test -d "$as_dir" || { $as_mkdir_p && mkdir -p "$as_dir"; } || {
- as_dirs=
- while :; do
- *\'*) as_qdir=`$as_echo "$as_dir" | sed "s/'/'\\\\\\\\''/g"`;; #'(
- *) as_qdir=$as_dir;;
- esac
- as_dirs="'$as_qdir' $as_dirs"
- as_dir=`$as_dirname -- "$as_dir" ||
-$as_expr X"$as_dir" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
- X"$as_dir" : 'X\(//\)[^/]' \| \
- X"$as_dir" : 'X\(//\)$' \| \
- X"$as_dir" : 'X\(/\)' \| . 2>/dev/null ||
-$as_echo X"$as_dir" |
- sed '/^X\(.*[^/]\)\/\/*[^/][^/]*\/*$/{
- s//\1/
- q
- /^X\(\/\/\)[^/].*/{
- s//\1/
- q
- /^X\(\/\/\)$/{
- s//\1/
- q
- /^X\(\/\).*/{
- s//\1/
- q
- s/.*/./; q'`
- test -d "$as_dir" && break
- done
- test -z "$as_dirs" || eval "mkdir $as_dirs"
- } || test -d "$as_dir" || { { $as_echo "$as_me:$LINENO: error: cannot create directory $as_dir" >&5
-$as_echo "$as_me: error: cannot create directory $as_dir" >&2;}
- { (exit 1); exit 1; }; }; }
+ as_dir="$ac_dir"; as_fn_mkdir_p
ac_builddir=.
case "$ac_dir" in
@@ -6223,7 +5262,6 @@ cat >>$CONFIG_STATUS <<\_ACEOF || ac_write_fail=1
# If the template does not know about datarootdir, expand it.
# FIXME: This hack should be removed a few years after 2.60.
ac_datarootdir_hack=; ac_datarootdir_seen=
ac_sed_dataroot='
/datarootdir/ {
p
@@ -6233,12 +5271,11 @@ ac_sed_dataroot='
/@docdir@/p
/@infodir@/p
/@localedir@/p
-/@mandir@/p
+/@mandir@/p'
case `eval "sed -n \"\$ac_sed_dataroot\" $ac_file_inputs"` in
*datarootdir*) ac_datarootdir_seen=yes;;
*@datadir@*|*@docdir@*|*@infodir@*|*@localedir@*|*@mandir@*)
- { $as_echo "$as_me:$LINENO: WARNING: $ac_file_inputs seems to ignore the --datarootdir setting" >&5
+ { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: $ac_file_inputs seems to ignore the --datarootdir setting" >&5
$as_echo "$as_me: WARNING: $ac_file_inputs seems to ignore the --datarootdir setting" >&2;}
_ACEOF
@@ -6248,7 +5285,7 @@ cat >>$CONFIG_STATUS <<_ACEOF || ac_write_fail=1
s&@infodir@&$infodir&g
s&@localedir@&$localedir&g
s&@mandir@&$mandir&g
- s&\\\${datarootdir}&$datarootdir&g' ;;
+ s&\\\${datarootdir}&$datarootdir&g' ;;
esac
_ACEOF
@@ -6275,27 +5312,24 @@ s&@abs_top_builddir@&$ac_abs_top_builddir&;t t
s&@INSTALL@&$ac_INSTALL&;t t
$ac_datarootdir_hack
-eval sed \"\$ac_sed_extra\" "$ac_file_inputs" | $AWK -f "$tmp/subs.awk" >$tmp/out \
+eval sed \"\$ac_sed_extra\" "$ac_file_inputs" | $AWK -f "$ac_tmp/subs.awk" \
+ >$ac_tmp/out || as_fn_error $? "could not create $ac_file" "$LINENO" 5
test -z "$ac_datarootdir_hack$ac_datarootdir_seen" &&
- { ac_out=`sed -n '/\${datarootdir}/p' "$tmp/out"`; test -n "$ac_out"; } &&
- { ac_out=`sed -n '/^[ ]*datarootdir[ ]*:*=/p' "$tmp/out"`; test -z "$ac_out"; } &&
- { $as_echo "$as_me:$LINENO: WARNING: $ac_file contains a reference to the variable \`datarootdir'
-which seems to be undefined. Please make sure it is defined." >&5
+ { ac_out=`sed -n '/\${datarootdir}/p' "$ac_tmp/out"`; test -n "$ac_out"; } &&
+ { ac_out=`sed -n '/^[ ]*datarootdir[ ]*:*=/p' \
+ "$ac_tmp/out"`; test -z "$ac_out"; } &&
+ { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: $ac_file contains a reference to the variable \`datarootdir'
+which seems to be undefined. Please make sure it is defined" >&5
$as_echo "$as_me: WARNING: $ac_file contains a reference to the variable \`datarootdir'
-which seems to be undefined. Please make sure it is defined." >&2;}
+which seems to be undefined. Please make sure it is defined" >&2;}
- rm -f "$tmp/stdin"
+ rm -f "$ac_tmp/stdin"
case $ac_file in
- -) cat "$tmp/out" && rm -f "$tmp/out";;
- *) rm -f "$ac_file" && mv "$tmp/out" "$ac_file";;
+ -) cat "$ac_tmp/out" && rm -f "$ac_tmp/out";;
+ *) rm -f "$ac_file" && mv "$ac_tmp/out" "$ac_file";;
esac \
:H)
@@ -6304,27 +5338,21 @@ $as_echo "$as_me: error: could not create $ac_file" >&2;}
$as_echo "/* $configure_input */" \
- && eval '$AWK -f "$tmp/defines.awk"' "$ac_file_inputs"
- } >"$tmp/config.h" \
- if diff "$ac_file" "$tmp/config.h" >/dev/null 2>&1; then
- { $as_echo "$as_me:$LINENO: $ac_file is unchanged" >&5
+ && eval '$AWK -f "$ac_tmp/defines.awk"' "$ac_file_inputs"
+ } >"$ac_tmp/config.h" \
+ if diff "$ac_file" "$ac_tmp/config.h" >/dev/null 2>&1; then
+ { $as_echo "$as_me:${as_lineno-$LINENO}: $ac_file is unchanged" >&5
$as_echo "$as_me: $ac_file is unchanged" >&6;}
else
rm -f "$ac_file"
- mv "$tmp/config.h" "$ac_file" \
+ mv "$ac_tmp/config.h" "$ac_file" \
fi
else
- && eval '$AWK -f "$tmp/defines.awk"' "$ac_file_inputs" \
- || { { $as_echo "$as_me:$LINENO: error: could not create -" >&5
-$as_echo "$as_me: error: could not create -" >&2;}
+ && eval '$AWK -f "$ac_tmp/defines.awk"' "$ac_file_inputs" \
+ || as_fn_error $? "could not create -" "$LINENO" 5
fi
@@ -6334,15 +5362,12 @@ $as_echo "$as_me: error: could not create -" >&2;}
done # for ac_tag
-{ (exit 0); exit 0; }
+as_fn_exit 0
_ACEOF
-chmod +x $CONFIG_STATUS
ac_clean_files=$ac_clean_files_save
test $ac_write_fail = 0 ||
- { { $as_echo "$as_me:$LINENO: error: write failure creating $CONFIG_STATUS" >&5
-$as_echo "$as_me: error: write failure creating $CONFIG_STATUS" >&2;}
+ as_fn_error $? "write failure creating $CONFIG_STATUS" "$LINENO" 5
# configure is writing to config.log, and then calls config.status.
@@ -6363,15 +5388,15 @@ if test "$no_create" != yes; then
exec 5>>config.log
# Use ||, not &&, to avoid exiting from the if with $? = 1, which
# would make configure fail if this is the last instruction.
- $ac_cs_success || { (exit 1); exit 1; }
+ $ac_cs_success || as_fn_exit 1
fi
if test -n "$ac_unrecognized_opts" && test "$enable_option_checking" != no; then
- { $as_echo "$as_me:$LINENO: WARNING: unrecognized options: $ac_unrecognized_opts" >&5
+ { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: unrecognized options: $ac_unrecognized_opts" >&5
$as_echo "$as_me: WARNING: unrecognized options: $ac_unrecognized_opts" >&2;}
fi
if test x$HAVE_PDFLATEX != xyes; then
- { $as_echo "$as_me:$LINENO: WARNING: Please install pdflatex if you wish to use the darshan-job-summary.pl utility" >&5
+ { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: Please install pdflatex if you wish to use the darshan-job-summary.pl utility" >&5
$as_echo "$as_me: WARNING: Please install pdflatex if you wish to use the darshan-job-summary.pl utility" >&2;}
fi
diff --git a/darshan-util/darshan-job-summary/bin/darshan-job-summary.pl.in b/darshan-util/darshan-job-summary/bin/darshan-job-summary.pl.in
index 03afc76..79ef9de 100755
--- a/darshan-util/darshan-job-summary/bin/darshan-job-summary.pl.in
+++ b/darshan-util/darshan-job-summary/bin/darshan-job-summary.pl.in
@@ -986,6 +986,12 @@ sub process_file_record
my(%file_record) = %{$_[1]};
my $rank = $file_record{'RANK'};
+ if(!defined $file_record{'POSIX_OPENS'})
+ # ignore data records that don't have POSIX & MPI data
+ return;
if($file_record{'POSIX_OPENS'} == 0 &&
$file_record{'POSIX_FOPENS'} == 0 &&
(!defined $file_record{'MPIIO_INDEP_OPENS'} ||
diff --git a/darshan-util/darshan-logutils.h b/darshan-util/darshan-logutils.h
index d6c120a..c5d2a5d 100644
--- a/darshan-util/darshan-logutils.h
+++ b/darshan-util/darshan-logutils.h
@@ -96,7 +96,7 @@ void darshan_log_close(darshan_fd file);
/* convenience macros for printing Darshan counters */
#define DARSHAN_PRINT_HEADER() \
- printf("\n#<module>\t<rank>\t<file>\t<counter>\t<value>" \
+ printf("\n#<module>\t<rank>\t<record id>\t<counter>\t<value>" \
"\t<file name>\t<mount pt>\t<fs type>\n")
#define DARSHAN_COUNTER_PRINT(__mod_name, __rank, __file_id, \
diff --git a/darshan-util/darshan-parser.c b/darshan-util/darshan-parser.c
index bbbc91b..dba30b4 100644
--- a/darshan-util/darshan-parser.c
+++ b/darshan-util/darshan-parser.c
@@ -298,8 +298,8 @@ int main(int argc, char **argv)
printf("# metadata: %s = %s\n", key, value);
- /* print breakdown of each log file component's contribution to file size */
- printf("\n# log file component sizes (compressed)\n");
+ /* print breakdown of each log file region's contribution to file size */
+ printf("\n# log file region sizes (compressed)\n");
printf("# -------------------------------------------------------\n");
printf("# header: %zu bytes (uncompressed)\n", sizeof(struct darshan_header));
printf("# job data: %zu bytes\n", fd->job_map.len);
@@ -345,12 +345,17 @@ int main(int argc, char **argv)
empty_mods++;
continue;
+ /* skip modules with no logutil definitions */
else if(!mod_logutils[i])
fprintf(stderr, "Warning: no log utility handlers defined "
"for module %s, SKIPPING.\n", darshan_module_names[i]);
continue;
+ /* currently we only do base parsing for non MPI & POSIX modules */
+ else if((i != DARSHAN_POSIX_MOD) && (i != DARSHAN_MPIIO_MOD) &&
+ !(mask & OPTION_BASE))
+ continue;
/* this module has data to be parsed and printed */
memset(mod_buf, 0, DEF_MOD_BUF_SIZE);
@@ -1404,7 +1409,7 @@ void posix_file_list(hash_entry_t *file_hash,
printf("\n# Per-file summary of I/O activity.\n");
printf("# <record_id>: darshan record id for this file\n");
- printf("# <file_name>: file name\n");
+ printf("# <file_name>: full file name\n");
printf("# <nprocs>: number of processes that opened the file\n");
printf("# <slowest>: (estimated) time in seconds consumed in IO by slowest process\n");
printf("# <avg>: average time in seconds consumed in IO per process\n");
@@ -1417,7 +1422,7 @@ void posix_file_list(hash_entry_t *file_hash,
printf("# <POSIX_SIZE_WRITE_*>: POSIX write size histogram\n");
- printf("\n# <file_id>\t<file_name>\t<nprocs>\t<slowest>\t<avg>");
+ printf("\n# <record_id>\t<file_name>\t<nprocs>\t<slowest>\t<avg>");
if(detail_flag)
printf("\t<start_open>\t<start_read>\t<start_write>");
@@ -1496,7 +1501,7 @@ void mpiio_file_list(hash_entry_t *file_hash,
@@ -1510,7 +1515,7 @@ void mpiio_file_list(hash_entry_t *file_hash,
printf("# <MPIIO_SIZE_WRITE_AGG_*>: MPI-IO aggregate write size histogram\n");
if(detail_flag)
diff --git a/darshan-util/darshan-summary-per-file.sh b/darshan-util/darshan-summary-per-file.sh
index 50c342b..f55052a 100644
--- a/darshan-util/darshan-summary-per-file.sh
+++ b/darshan-util/darshan-summary-per-file.sh
@@ -14,7 +14,7 @@ if [ $# -ne 2 ]; then
fi
# count number of files present in log
-filecount=`darshan-parser --file-list $1| egrep -v '^(#|$)' | wc -l`
+filecount=`darshan-parser --file-list $1| egrep -v '^(#|$)' | cut -f 1-2 | uniq | wc -l`
rc=$?
if [ $rc -ne 0 ]; then
exit $rc
@@ -29,7 +29,7 @@ fi
# loop through all files in log
counter=0
-darshan-parser --file-list $1| egrep -v '^(#|$)' |
+darshan-parser --file-list $1| egrep -v '^(#|$)' | cut -f 1-2 | uniq |
while read -r hash suffix stuff ; do
counter=$((counter+1))
file=$(basename $suffix)
diff --git a/darshan-util/darshan-util-config.h.in b/darshan-util/darshan-util-config.h.in
index 8541fac..f48e068 100644
--- a/darshan-util/darshan-util-config.h.in
+++ b/darshan-util/darshan-util-config.h.in
@@ -54,6 +54,9 @@
/* Define to the one symbol short name of this package. */
#undef PACKAGE_TARNAME
+/* Define to the home page for this package. */
+#undef PACKAGE_URL
/* Define to the version of this package. */
#undef PACKAGE_VERSION
diff --git a/darshan-util/doc/darshan-util.txt b/darshan-util/doc/darshan-util.txt
index b9eced7..dbde068 100644
--- a/darshan-util/doc/darshan-util.txt
+++ b/darshan-util/doc/darshan-util.txt
@@ -39,7 +39,6 @@ make
make install
-CC variable
[NOTE]
The darshan-util package is intended to be used on a login node or
workstation. For most use cases this means that you should
@@ -91,9 +90,8 @@ produce a `carns_my-app_id114525_7-27-58921_19.pdf` output file).
You can also manually specify the name of the output file using the
`--output` argument.
-An example of the output produced by darshan-job-summary.pl can be found at
-http://www.mcs.anl.gov/research/projects/darshan/files/2012/06/pcarns_mpi-io-test_id3406_6-7-47644-13333843235489639491_1.pdf
+An example of the output produced by darshan-job-summary.pl can be found
+link:http://www.mcs.anl.gov/research/projects/darshan/docs/ssnyder_ior-hdf5_id3655016_9-23-29011-12333993518351519212_1.darshan.pdf[HERE].
=== darshan-summary-per-file.sh
@@ -155,8 +153,6 @@ of each line:
|output line | description
| "# darshan log version" | internal version number of the Darshan log file
-| "# size of file statistics" | uncompressed size of each file record in the binary log file
-| "# size of job statistics" | uncompressed size of the overall job statistics in the binary log file
| "# exe" | name of the executable that generated the log file
| "# uid" | user id that the job ran as
| "# jobid" | job id from the scheduler
@@ -168,6 +164,19 @@ of each line:
| "# run time" | run time of the job in seconds
+==== Log file region sizes
+The next portion of the parser output displays the size of each region
+contained within the given log file. Each log file will contain the
+following regions:
+* header - constant-sized uncompressed header providing data on how to properly access the log
+* job data - job-level metadata (e.g., start/end time and exe name) for the log
+* record table - a table mapping Darshan record identifiers to full file name paths
+* module data - each module (e.g., POSIX, MPI-IO, etc.) stores their I/O characterization data in distinct regions of the log
+All regions of the log file are compressed (in libz or bzip2 format), except the header.
==== Table of mounted file systems
The next portion of the output shows a table of all general purpose file
@@ -175,139 +184,193 @@ systems that were mounted while the job was running. Each line uses the
following format:
-<device> <mount point> <fs type>
+<mount point> <fs type>
-The device field is the device ID as reported by the stat() system call.
-Note that this device ID may change if the node is rebooted or the file
-system is remounted.
==== Format of I/O characterization fields
The remainder of the output will show characteristics for each file that was
opened by the application. Each line uses the following format:
-<rank> <file name hash> <counter name> <counter value> <file name suffix> <mount point> <fs type>
+<module> <rank> <record id> <counter name> <counter value> <file name> <mount point> <fs type>
-The `<rank>` column indicates the rank of the process that opened the file. A
-rank value of -1 indicates that all processes opened the same file. In that
-case, the value of the counter represents an aggregate across all processes. The
-`<file name hash>` is a 64 bit hash of the file path/name that was opened. It
-is used as a way to uniquely differentiate each file. The `<counter name>` is
-the name of the statistic that the line is reporting, while the `<counter
-value>` is the value of that statistic. A value of -1 indicates that Darshan
-was unable to collect statistics for that particular counter, and the value
-should be ignored. The `<file name suffix>` shows the last
-11 characters of the file name. The `<mount point>` is the mount point of the
-file system that this file belongs to. The `<fs type>` is the type of file
-system.
+The `<module>` column specifies the module responsible for recording this piece
+of I/O characterization data. The `<rank>` column indicates the rank of the process
+that opened the file. A rank value of -1 indicates that all processes opened the
+same file. In that case, the value of the counter represents an aggregate across all
+processes. The `<record id>` is a 64 bit hash of the file path/name that was opened.
+It is used as a way to uniquely differentiate each file. The `<counter name>` is
+the name of the statistic that the line is reporting, while the `<counter value>` is
+the value of that statistic. A value of -1 indicates that Darshan was unable to
+collect statistics for that particular counter, and the value should be ignored.
+The `<file name>` field shows the complete file name the record corresponds to. The
+`<mount point>` is the mount point of the file system that this file belongs to and
+`<fs type>` is the type of that file system.
==== I/O characterization fields
-The following table shows a list of integer statistics that are available
-for each file, along with a description of each.
-Unless otherwise noted, counters include all variants of the call in
-question, such a `read()`, `pread()`, and `readv()` for CP_POSIX_READS.
+The following tables show a list of integer statistics that are available for each of
+Darshan's current instrumentation modules, along with a description of each. Unless
+otherwise noted, counters include all variants of the call in question, such as
+`read()`, `pread()`, and `readv()` for POSIX_READS.
+.POSIX module
[cols="40%,60%",options="header"]
-| output line | description
-| CP_POSIX_READS | Count of POSIX read operations
-| CP_POSIX_WRITES | Count of POSIX write operations
-| CP_POSIX_OPENS | Count of how many times the file was opened
-| CP_POSIX_SEEKS | Count of POSIX seek operations
-| CP_POSIX_STATS | Count of POSIX stat operations
-| CP_POSIX_MMAPS | Count of POSIX mmap operations
-| CP_POSIX_FREADS | Count of stream read operations
-| CP_POSIX_FWRITES | Count of stream write operations
-| CP_POSIX_FOPENS | Count of stream open operations
-| CP_POSIX_FSEEKS | Count of stream seek operations
-| CP_POSIX_FSYNCS | Count of fsync operations
-| CP_POSIX_FDSYNCS | Count of fdatasync operations
-| CP_INDEP_OPENS | Count of non-collective MPI opens
-| CP_COLL_OPENS | Count of collective MPI opens
-| CP_INDEP_READS | Count of non-collective MPI reads
-| CP_INDEP_WRITES | Count of non-collective MPI writes
-| CP_COLL_READS | Count of collective MPI reads
-| CP_COLL_WRITES | Count of collective MPI writes
-| CP_SPLIT_READS | Count of MPI split collective reads
-| CP_SPLIT_WRITES | Count of MPI split collective writes
-| CP_NB_READS | Count of MPI non-blocking reads
-| CP_NB_WRITES | Count of MPI non-blocking writes
-| CP_SYNCS | Count of MPI file syncs
-| CP_INDEP_NC_OPENS | Count of independent Parallel NetCDF opens
-| CP_COLL_NC_OPENS | Count of collective Parallel NetCDF opens
-| CP_HDF5_OPENS | Count of HDF5 opens
-| CP_COMBINER_* | Count of each type of MPI datatype (both in memory and in file)
-| CP_HINTS | Count of MPI file hints used
-| CP_VIEWS | Count of MPI file views used
-| CP_MODE | Mode that the file was last opened in
-| CP_BYTES_READ | Total number of bytes that were read from the file
-| CP_BYTES_WRITTEN | Total number of bytes written to the file
-| CP_MAX_BYTE_READ | Highest offset in the file that was read
-| CP_MAX_BYTE_WRITTEN | Highest offset in the file that was written
-| CP_CONSEC_READS | Number of consecutive reads (that were immediately adjacent to the previous access)
-| CP_CONSEC_WRITES | Number of consecutive writes (that were immediately adjacent to the previous access)
-| CP_SEQ_READS | Number of sequential reads (at a higher offset than where the previous access left off)
-| CP_SEQ_WRITES | Number of sequential writes (at a higher offset than where the previous access left off)
-| CP_RW_SWITCHES | Number of times that access toggled between read and write in consecutive operations
-| CP_MEM_NOT_ALIGNED | Number of times that a read or write was not aligned in memory
-| CP_MEM_ALIGNMENT | Memory alignment value (chosen at compile time)
-| CP_FILE_NOT_ALIGNED | Number of times that a read or write was not aligned in file
-| CP_FILE_ALIGNMENT | File alignment value. This value is detected at
+| counter name | description
+| POSIX_OPENS | Count of how many times the file was opened
+| POSIX_READS | Count of POSIX read operations
+| POSIX_WRITES | Count of POSIX write operations
+| POSIX_SEEKS | Count of POSIX seek operations
+| POSIX_STATS | Count of POSIX stat operations
+| POSIX_MMAPS | Count of POSIX mmap operations
+| POSIX_FOPENS | Count of POSIX stream open operations
+| POSIX_FREADS | Count of POSIX stream read operations
+| POSIX_FWRITES | Count of POSIX stream write operations
+| POSIX_FSEEKS | Count of POSIX stream seek operations
+| POSIX_FSYNCS | Count of POSIX fsync operations
+| POSIX_FDSYNCS | Count of POSIX fdatasync operations
+| POSIX_MODE | Mode that the file was last opened in
+| POSIX_BYTES_READ | Total number of bytes that were read from the file
+| POSIX_BYTES_WRITTEN | Total number of bytes written to the file
+| POSIX_MAX_BYTE_READ | Highest offset in the file that was read
+| POSIX_MAX_BYTE_WRITTEN | Highest offset in the file that was written
+| POSIX_CONSEC_READS | Number of consecutive reads (that were immediately adjacent to the previous access)
+| POSIX_CONSEC_WRITES | Number of consecutive writes (that were immediately adjacent to the previous access)
+| POSIX_SEQ_READS | Number of sequential reads (at a higher offset than where the previous access left off)
+| POSIX_SEQ_WRITES | Number of sequential writes (at a higher offset than where the previous access left off)
+| POSIX_RW_SWITCHES | Number of times that access toggled between read and write in consecutive operations
+| POSIX_MEM_NOT_ALIGNED | Number of times that a read or write was not aligned in memory
+| POSIX_MEM_ALIGNMENT | Memory alignment value (chosen at compile time)
+| POSIX_FILE_NOT_ALIGNED | Number of times that a read or write was not aligned in file
+| POSIX_FILE_ALIGNMENT | File alignment value. This value is detected at
runtime on most file systems. On Lustre, however, Darshan assumes a default
value of 1 MiB for optimal file alignment.
-| CP_MAX_READ_TIME_SIZE | Size of the slowest POSIX read operation
-| CP_MAX_WRITE_TIME_SIZE | Size of the slowest POSIX write operation
-| CP_SIZE_READ_* | Histogram of read access sizes at POSIX level
-| CP_SIZE_READ_AGG_* | Histogram of total size of read accesses at MPI level, even if access is noncontiguous
-| CP_EXTENT_READ_* | Histogram of read extents
-| CP_SIZE_WRITE_* | Histogram of write access sizes at POSIX level
-| CP_SIZE_WRITE_AGG_* | Histogram of total size of write accesses at MPI level, even if access is noncontiguous
-| CP_EXTENT_WRITE_* | Histogram of write extents
-| CP_STRIDE[1-4]_STRIDE | Size of 4 most common stride patterns
-| CP_STRIDE[1-4]_COUNT | Count of 4 most common stride patterns
-| CP_ACCESS[1-4]_ACCESS | 4 most common access sizes
-| CP_ACCESS[1-4]_COUNT | Count of 4 most common access sizes
-| CP_DEVICE | File system identifier; correlates with mount table shown earlier. In Darshan 2.2.5 and earlier, this is the device ID reported by stat(), in Darshan 2.2.6 and later, this is an opaque identifier generated by Darshan.
-| CP_SIZE_AT_OPEN | Size of file at first open time
-| CP_FASTEST_RANK | The MPI rank of the rank with smallest time spent in I/O
-| CP_FASTEST_RANK_BYTES | The number of bytes transferred by the rank with smallest time spent in I/O
-| CP_SLOWEST_RANK | The MPI rank of the rank with largest time spent in I/O
-| CP_SLOWEST_RANK_BYTES | The number of bytes transferred by the rank with the largest time spent in I/O
+| POSIX_MAX_READ_TIME_SIZE | Size of the slowest POSIX read operation
+| POSIX_MAX_WRITE_TIME_SIZE | Size of the slowest POSIX write operation
+| POSIX_SIZE_READ_* | Histogram of read access sizes at POSIX level
+| POSIX_SIZE_WRITE_* | Histogram of write access sizes at POSIX level
+| POSIX_STRIDE[1-4]_STRIDE | Size of 4 most common stride patterns
+| POSIX_STRIDE[1-4]_COUNT | Count of 4 most common stride patterns
+| POSIX_ACCESS[1-4]_ACCESS | 4 most common POSIX access sizes
+| POSIX_ACCESS[1-4]_COUNT | Count of 4 most common POSIX access sizes
+| POSIX_FASTEST_RANK | The MPI rank of the rank with smallest time spent in POSIX I/O
+| POSIX_FASTEST_RANK_BYTES | The number of bytes transferred by the rank with smallest time spent in POSIX I/O
+| POSIX_SLOWEST_RANK | The MPI rank of the rank with largest time spent in POSIX I/O
+| POSIX_SLOWEST_RANK_BYTES | The number of bytes transferred by the rank with the largest time spent in POSIX I/O
+| POSIX_F_OPEN_TIMESTAMP | Timestamp of first time that the file was opened
+| POSIX_F_READ_START_TIMESTAMP | Timestamp that the first POSIX read operation began
+| POSIX_F_WRITE_START_TIMESTAMP | Timestamp that the first POSIX write operation began
+| POSIX_F_READ_END_TIMESTAMP | Timestamp that the last POSIX read operation ended
+| POSIX_F_WRITE_END_TIMESTAMP | Timestamp that the last POSIX write operation ended
+| POSIX_F_CLOSE_TIMESTAMP | Timestamp of the last time that the file was closed
+| POSIX_F_READ_TIME | Cumulative time spent reading at the POSIX level
+| POSIX_F_WRITE_TIME | Cumulative time spent in write, fsync, and fdatasync at the POSIX level
+| POSIX_F_META_TIME | Cumulative time spent in open, close, stat, and seek at the POSIX level
+| POSIX_F_MAX_READ_TIME | Duration of the slowest individual POSIX read operation
+| POSIX_F_MAX_WRITE_TIME | Duration of the slowest individual POSIX write operation
+| POSIX_F_FASTEST_RANK_TIME | The time of the rank which had the smallest amount of time spent in POSIX I/O (cumulative read, write, and meta times)
+| POSIX_F_SLOWEST_RANK_TIME | The time of the rank which had the largest amount of time spent in POSIX I/O
+| POSIX_F_VARIANCE_RANK_TIME | The population variance for POSIX I/O time of all the ranks
+| POSIX_F_VARIANCE_RANK_BYTES | The population variance for bytes transferred of all the ranks
+.MPI-IO module
+[cols="40%,60%",options="header"]
+| MPIIO_INDEP_OPENS | Count of non-collective MPI opens
+| MPIIO_COLL_OPENS | Count of collective MPI opens
+| MPIIO_INDEP_READS | Count of non-collective MPI reads
+| MPIIO_INDEP_WRITES | Count of non-collective MPI writes
+| MPIIO_COLL_READS | Count of collective MPI reads
+| MPIIO_COLL_WRITES | Count of collective MPI writes
+| MPIIO_SPLIT_READS | Count of MPI split collective reads
+| MPIIO_SPLIT_WRITES | Count of MPI split collective writes
+| MPIIO_NB_READS | Count of MPI non-blocking reads
+| MPIIO_NB_WRITES | Count of MPI non-blocking writes
+| MPIIO_SYNCS | Count of MPI file syncs
+| MPIIO_HINTS | Count of MPI file hints used
+| MPIIO_VIEWS | Count of MPI file views used
+| MPIIO_MODE | MPI mode that the file was last opened in
+| MPIIO_BYTES_READ | Total number of bytes that were read from the file at MPI level
+| MPIIO_BYTES_WRITTEN | Total number of bytes written to the file at MPI level
+| MPIIO_RW_SWITCHES | Number of times that access toggled between read and write in consecutive MPI operations
+| MPIIO_MAX_READ_TIME_SIZE | Size of the slowest MPI read operation
+| MPIIO_MAX_WRITE_TIME_SIZE | Size of the slowest MPI write operation
+| MPIIO_SIZE_READ_AGG_* | Histogram of total size of read accesses at MPI level, even if access is noncontiguous
+| MPIIO_SIZE_WRITE_AGG_* | Histogram of total size of write accesses at MPI level, even if access is noncontiguous
+| MPIIO_ACCESS[1-4]_ACCESS | 4 most common MPI aggregate access sizes
+| MPIIO_ACCESS[1-4]_COUNT | Count of 4 most common MPI aggregate access sizes
+| MPIIO_FASTEST_RANK | The MPI rank of the rank with smallest time spent in MPI I/O
+| MPIIO_FASTEST_RANK_BYTES | The number of bytes transferred by the rank with smallest time spent in MPI I/O
+| MPIIO_SLOWEST_RANK | The MPI rank of the rank with largest time spent in MPI I/O
+| MPIIO_SLOWEST_RANK_BYTES | The number of bytes transferred by the rank with the largest time spent in MPI I/O
+| MPIIO_F_OPEN_TIMESTAMP | Timestamp of first time that the file was opened at MPI level
+| MPIIO_F_READ_START_TIMESTAMP | Timestamp that the first MPI read operation began
+| MPIIO_F_WRITE_START_TIMESTAMP | Timestamp that the first MPI write operation begin
+| MPIIO_F_READ_END_TIMESTAMP | Timestamp that the last MPI read operation ended
+| MPIIO_F_WRITE_END_TIMESTAMP | Timestamp that the last MPI write operation ended
+| MPIIO_F_CLOSE_TIMESTAMP | Timestamp of the last time that the file was closed at MPI level
+| MPIIO_READ_TIME | Cumulative time spent reading at MPI level
+| MPIIO_WRITE_TIME | Cumulative time spent write and sync at MPI level
+| MPIIO_META_TIME | Cumulative time spent in open and close at MPI level
+| MPIIO_F_MAX_READ_TIME | Duration of the slowest individual MPI read operation
+| MPIIO_F_MAX_WRITE_TIME | Duration of the slowest individual MPI write operation
+| CP_F_FASTEST_RANK_TIME | The time of the rank which had the smallest amount of time spent in MPI I/O (cumulative read, write, and meta times)
+| CP_F_SLOWEST_RANK_TIME | The time of the rank which had the largest amount of time spent in MPI I/O
+| CP_F_VARIANCE_RANK_TIME | The population variance for MPI I/O time of all the ranks
+| CP_F_VARIANCE_RANK_BYTES | The population variance for bytes transferred of all the ranks at MPI level
-The following is a list of floating point statistics that are available for
-each file:
+.HDF5 module
+| HDF5_OPENS | Count of HDF5 opens
+| HDF5_F_OPEN_TIMESTAMP | Timestamp of first time that the file was opened at HDF5 level
+| HDF5_F_CLOSE_TIMESTAMP | Timestamp of the last time that the file was closed at HDF5 level
+.PnetCDF module
+| PNETCDF_INDEP_OPENS | Count of PnetCDF independent opens
+| PNETCDF_COLL_OPENS | Count of PnetCDF collective opens
+| PNETCDF_F_OPEN_TIMESTAMP | Timestamp of first time that the file was opened at PnetCDF level
+| PNETCDF_F_CLOSE_TIMESTAMP | Timestamp of the last time that the file was closed at PnetCDF level
+===== Additional modules
+.BG/Q module (if enabled on BG/Q systems)
-| CP_F_OPEN_TIMESTAMP | Timestamp of first time that the file was opened
-| CP_F_CLOSE_TIMESTAMP | Timestamp of the last time that the file was closed
-| CP_F_READ_START_TIMESTAMP | Timestamp that the first read operation began
-| CP_F_READ_END_TIMESTAMP | Timestamp that the last read operation ended
-| CP_F_WRITE_START_TIMESTAMP | Timestamp that the first write operation begin
-| CP_F_WRITE_END_TIMESTAMP | Timestamp that the last write operation ended
-| CP_F_POSIX_READ_TIME | Cumulative time spent reading at the POSIX level
-| CP_F_POSIX_WRITE_TIME | Cumulative time spent in write, fsync, and fdatasync at the POSIX level
-| CP_F_POSIX_META_TIME | Cumulative time spent in open, close, stat, and seek at the POSIX level
-| CP_F_MPI_META_TIME | Cumulative time spent in open and close at the MPI-IO level
-| CP_F_MPI_READ_TIME | Cumulative time spent reading at the MPI-IO level
-| CP_F_MPI_WRITE_TIME | Cumulative time spent write and sync at the MPI-IO level
-| CP_F_MAX_READ_TIME | Duration of the slowest individual POSIX read operation
-| CP_F_MAX_WRITE_TIME | Duration of the slowest individual POSIX write operation
-| CP_F_FASTEST_RANK_TIME | The time of the rank which had the smallest amount of time spent in I/O. If the file was accessed usign MPI-IO it combines the MPI meta, read, and write time. If the file was not accessed with MPI-IO then it combines the posix meta, read, and write time.
-| CP_F_SLOWEST_RANK_TIME | The time of the rank which had the largest amount of time spent in I/O
-| CP_F_VARIANCE_RANK_TIME | The population variance for I/O time of all the ranks
-| CP_F_VARIANCE_RANK_BYTES | The population variance for bytes transferred of all the ranks
+| BGQ_CSJOBID | Control system job ID
+| BGQ_NNODES | Total number of BG/Q compute nodes
+| BGQ_RANKSPERNODE | Number of MPI ranks per compute node
+| BGQ_DDRPERNODE | Size of compute node DDR in MiB
+| BGQ_INODES | Total number of BG/Q I/O nodes
+| BGQ_ANODES | Dimension of A torus
+| BGQ_BNODES | Dimension of B torus
+| BGQ_CNODES | Dimension of C torus
+| BGQ_DNODES | Dimension of D torus
+| BGQ_ENODES | Dimension of E torus
+| BGQ_TORUSENABLED | Bitfield indicating enabled torus dimensions
+| BGQ_F_TIMESTAMP | Timestamp of when BG/Q data was collected
==== Additional summary output
+The following sections describe addtitional parser options that provide
+summary I/O characterization data for the given log.
+*NOTE*: These options are currently only supported by the POSIX and MPI-IO modules.
===== Performance
Use the '--perf' option to get performance approximations using four
@@ -377,20 +440,19 @@ it doesn't make sense to aggregate the data.
.Example output
-total_CP_INDEP_OPENS: 0
-total_CP_COLL_OPENS: 196608
-total_CP_INDEP_READS: 0
-total_CP_INDEP_WRITES: 0
-total_CP_COLL_READS: 0
-total_CP_COLL_WRITES: 0
-total_CP_SPLIT_READS: 0
-total_CP_SPLIT_WRITES: 1179648
-total_CP_NB_READS: 0
-total_CP_NB_WRITES: 0
-total_CP_SYNCS: 0
-total_CP_POSIX_READS: 983045
-total_CP_POSIX_WRITES: 33795
-total_CP_POSIX_OPENS: 230918
+total_POSIX_OPENS: 1024
+total_POSIX_READS: 0
+total_POSIX_WRITES: 16384
+total_POSIX_SEEKS: 16384
+total_POSIX_STATS: 1024
+total_POSIX_MMAPS: 0
+total_POSIX_FOPENS: 0
+total_POSIX_FREADS: 0
+total_POSIX_FWRITES: 0
+total_POSIX_BYTES_READ: 0
+total_POSIX_BYTES_WRITTEN: 68719476736
+total_POSIX_MAX_BYTE_READ: 0
+total_POSIX_MAX_BYTE_WRITTEN: 67108863
@@ -403,15 +465,14 @@ file.
.Example output
-# <hash>: hash of file name
-# <suffix>: last 15 characters of file name
-# <type>: MPI or POSIX
+# <record_id>: darshan record id for this file
+# <file_name>: full file name
-# <hash> <suffix> <type> <nprocs> <slowest> <avg>
-17028232952633024488 amples/boom.dat MPI 2 0.000363 0.012262
+# <record_id> <file_name> <nprocs> <slowest> <avg>
+5041708885572677970 /projects/SSSPPg/snyder/ior/ior.dat 1024 16.342061 1.705930
===== Detailed file list
@@ -420,14 +481,14 @@ The `--file-list-detailed` is the same as --file-list except that it
produces many columns of output containing statistics broken down by file.
This option is mainly useful for automated analysis.
-=== Other command line utilities
+=== Other darshan-util utilities
The darshan-util package includes a number of other utilies that can be
summarized briefly as follows:
* darshan-convert: converts an existing log file to the newest log format.
-If the output file has a .bz2 extension, then it will be re-compressed in
-bz2 format rather than gz format. It also has command line options for
+If the `--bzip2` flag is given, then the output file will be re-compressed in
+bzip2 format rather than libz format. It also has command line options for
anonymizing personal data, adding metadata annotation to the log header, and
restricting the output to a specific instrumented file.
* darshan-diff: compares two darshan log files and shows counters that
hooks/post-receive
More information about the Darshan-commits
