[Darshan-commits] [Darshan] branch, dev-modular, updated. darshan-2.3.1-186-g779162d
Service Account
git at mcs.anl.gov
Wed Sep 23 10:40:09 CDT 2015
This is an automated email from the git hooks/post-receive script. It was
generated because a ref change was pushed to the repository containing
the project "".
The branch, dev-modular has been updated
via 779162dfb241581839e0fdf32d0320c8546b8747 (commit)
via 20ff15470f5264c9b8b3e02d86ac39030d2bea64 (commit)
from 67b02ca5120f74d7a7134f2761bc4db0e6b2bead (commit)
Those revisions listed above that are new to this repository have
not appeared on any other notification email; so we list those
revisions in full, below.
- Log -----------------------------------------------------------------
commit 779162dfb241581839e0fdf32d0320c8546b8747
Author: Shane Snyder <ssnyder at mcs.anl.gov>
Date: Tue Sep 22 20:40:42 2015 -0700
update runtime pkgconfig file
commit 20ff15470f5264c9b8b3e02d86ac39030d2bea64
Date: Tue Sep 22 11:53:48 2015 -0700
git configure working on cray
Summary of changes:
darshan-runtime/configure | 4254 +++++++++++++-------
darshan-runtime/configure.in | 7 +-
darshan-runtime/darshan-runtime-config.h.in | 3 -
.../lib/pkgconfig/darshan-runtime.pc.in | 5 +-
darshan-util/configure | 4035 ++++++++++++-------
darshan-util/darshan-util-config.h.in | 3 -
6 files changed, 5217 insertions(+), 3090 deletions(-)
Diff of changes:
diff --git a/darshan-runtime/configure b/darshan-runtime/configure
index 176ccc2..4820969 100755
--- a/darshan-runtime/configure
+++ b/darshan-runtime/configure
@@ -1,20 +1,18 @@
#! /bin/sh
# Guess values for system-dependent variables and create Makefiles.
-# Generated by GNU Autoconf 2.69 for darshan-runtime 3.0.0-pre1.
-# Copyright (C) 1992-1996, 1998-2012 Free Software Foundation, Inc.
+# Generated by GNU Autoconf 2.63 for darshan-runtime 3.0.0-pre1.
+# Copyright (C) 1992, 1993, 1994, 1995, 1996, 1998, 1999, 2000, 2001,
+# 2002, 2003, 2004, 2005, 2006, 2007, 2008 Free Software Foundation, Inc.
# This configure script is free software; the Free Software Foundation
# gives unlimited permission to copy, distribute and modify it.
-## M4sh Initialization. ##
+## M4sh Initialization. ##
# Be more Bourne compatible
DUALCASE=1; export DUALCASE # for MKS sh
-if test -n "${ZSH_VERSION+set}" && (emulate sh) >/dev/null 2>&1; then :
+if test -n "${ZSH_VERSION+set}" && (emulate sh) >/dev/null 2>&1; then
emulate sh
NULLCMD=:
# Pre-4.2 versions of Zsh do word splitting on ${1+"$@"}, which
@@ -22,15 +20,23 @@ if test -n "${ZSH_VERSION+set}" && (emulate sh) >/dev/null 2>&1; then :
alias -g '${1+"$@"}'='"$@"'
setopt NO_GLOB_SUBST
else
- case `(set -o) 2>/dev/null` in #(
- *posix*) :
- set -o posix ;; #(
+ case `(set -o) 2>/dev/null` in
+ *posix*) set -o posix ;;
esac
fi
+# PATH needs CR
+# Avoid depending upon Character Ranges.
+as_cr_letters='abcdefghijklmnopqrstuvwxyz'
+as_cr_LETTERS='ABCDEFGHIJKLMNOPQRSTUVWXYZ'
+as_cr_Letters=$as_cr_letters$as_cr_LETTERS
+as_cr_digits='0123456789'
+as_cr_alnum=$as_cr_Letters$as_cr_digits
as_nl='
export as_nl
@@ -38,13 +44,7 @@ export as_nl
as_echo='\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\'
as_echo=$as_echo$as_echo$as_echo$as_echo$as_echo
as_echo=$as_echo$as_echo$as_echo$as_echo$as_echo$as_echo
-# Prefer a ksh shell builtin over an external printf program on Solaris,
-# but without wasting forks for bash or zsh.
-if test -z "$BASH_VERSION$ZSH_VERSION" \
- && (test "X`print -r -- $as_echo`" = "X$as_echo") 2>/dev/null; then
- as_echo='print -r --'
- as_echo_n='print -rn --'
-elif (test "X`printf %s $as_echo`" = "X$as_echo") 2>/dev/null; then
+if (test "X`printf %s $as_echo`" = "X$as_echo") 2>/dev/null; then
as_echo='printf %s\n'
as_echo_n='printf %s'
else
@@ -55,7 +55,7 @@ else
as_echo_body='eval expr "X$1" : "X\\(.*\\)"'
as_echo_n_body='eval
arg=$1;
- case $arg in #(
+ case $arg in
*"$as_nl"*)
expr "X$arg" : "X\\(.*\\)$as_nl";
arg=`expr "X$arg" : ".*$as_nl\\(.*\\)"`;;
@@ -78,6 +78,13 @@ if test "${PATH_SEPARATOR+set}" != set; then
fi
+# Support unset when possible.
+if ( (MAIL=60; unset MAIL) || exit) >/dev/null 2>&1; then
+ as_unset=unset
+else
+ as_unset=false
+fi
# IFS
# We need space, tab and new line, in precisely that order. Quoting is
@@ -87,16 +94,15 @@ fi
IFS=" "" $as_nl"
# Find who we are. Look in the path if we contain no directory separator.
-as_myself=
-case $0 in #((
+case $0 in
*[\\/]* ) as_myself=$0 ;;
*) as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
for as_dir in $PATH
do
IFS=$as_save_IFS
test -z "$as_dir" && as_dir=.
- test -r "$as_dir/$0" && as_myself=$as_dir/$0 && break
- done
+ test -r "$as_dir/$0" && as_myself=$as_dir/$0 && break
+done
IFS=$as_save_IFS
@@ -108,16 +114,12 @@ if test "x$as_myself" = x; then
fi
if test ! -f "$as_myself"; then
$as_echo "$as_myself: error: cannot find myself; rerun with an absolute file name" >&2
- exit 1
+ { (exit 1); exit 1; }
fi
-# Unset variables that we do not need and which cause bugs (e.g. in
-# pre-3.0 UWIN ksh). But do not cause bugs in bash 2.01; the "|| exit 1"
-# suppresses any "Segmentation fault" message there. '((' could
-# trigger a bug in pdksh 5.2.14.
-for as_var in BASH_ENV ENV MAIL MAILPATH
-do eval test x\${$as_var+set} = xset \
- && ( (unset $as_var) || exit 1) >/dev/null 2>&1 && unset $as_var || :
+# Work around bugs in pre-3.0 UWIN ksh.
+for as_var in ENV MAIL MAILPATH
+do ($as_unset $as_var) >/dev/null 2>&1 && $as_unset $as_var
done
PS1='$ '
PS2='> '
@@ -129,344 +131,330 @@ export LC_ALL
LANGUAGE=C
export LANGUAGE
+# Required to use basename.
+if expr a : '\(a\)' >/dev/null 2>&1 &&
+ test "X`expr 00001 : '.*\(...\)'`" = X001; then
+ as_expr=expr
+else
+ as_expr=false
+fi
+if (basename -- /) >/dev/null 2>&1 && test "X`basename -- / 2>&1`" = "X/"; then
+ as_basename=basename
+else
+ as_basename=false
+fi
+# Name of the executable.
+as_me=`$as_basename -- "$0" ||
+$as_expr X/"$0" : '.*/\([^/][^/]*\)/*$' \| \
+ X"$0" : 'X\(//\)$' \| \
+ X"$0" : 'X\(/\)' \| . 2>/dev/null ||
+$as_echo X/"$0" |
+ sed '/^.*\/\([^/][^/]*\)\/*$/{
+ s//\1/
+ q
+ /^X\/\(\/\/\)$/{
+ s//\1/
+ q
+ /^X\/\(\/\).*/{
+ s//\1/
+ q
+ s/.*/./; q'`
# CDPATH.
-(unset CDPATH) >/dev/null 2>&1 && unset CDPATH
-# Use a proper internal environment variable to ensure we don't fall
- # into an infinite loop, continuously re-executing ourselves.
- if test x"${_as_can_reexec}" != xno && test "x$CONFIG_SHELL" != x; then
- _as_can_reexec=no; export _as_can_reexec;
- # We cannot yet assume a decent shell, so we have to provide a
-# neutralization value for shells without unset; and this also
-# works around shells that cannot unset nonexistent variables.
-# Preserve -v and -x to the replacement shell.
-BASH_ENV=/dev/null
-ENV=/dev/null
-(unset BASH_ENV) >/dev/null 2>&1 && unset BASH_ENV ENV
-case $- in # ((((
- *v*x* | *x*v* ) as_opts=-vx ;;
- *v* ) as_opts=-v ;;
- *x* ) as_opts=-x ;;
- * ) as_opts= ;;
-esac
-exec $CONFIG_SHELL $as_opts "$as_myself" ${1+"$@"}
-# Admittedly, this is quite paranoid, since all the known shells bail
-# out after a failed `exec'.
-$as_echo "$0: could not re-execute with $CONFIG_SHELL" >&2
-as_fn_exit 255
- fi
- # We don't want this to propagate to other subprocesses.
- { _as_can_reexec=; unset _as_can_reexec;}
+$as_unset CDPATH
if test "x$CONFIG_SHELL" = x; then
- as_bourne_compatible="if test -n \"\${ZSH_VERSION+set}\" && (emulate sh) >/dev/null 2>&1; then :
- emulate sh
- NULLCMD=:
- # Pre-4.2 versions of Zsh do word splitting on \${1+\"\$@\"}, which
- # is contrary to our usage. Disable this feature.
- alias -g '\${1+\"\$@\"}'='\"\$@\"'
- setopt NO_GLOB_SUBST
+ if (eval ":") 2>/dev/null; then
+ as_have_required=yes
else
- case \`(set -o) 2>/dev/null\` in #(
- *posix*) :
-esac
+ as_have_required=no
fi
- as_required="as_fn_return () { (exit \$1); }
-as_fn_success () { as_fn_return 0; }
-as_fn_failure () { as_fn_return 1; }
-as_fn_ret_success () { return 0; }
-as_fn_ret_failure () { return 1; }
+ if test $as_have_required = yes && (eval ":
+(as_func_return () {
+ (exit \$1)
+as_func_success () {
+ as_func_return 0
+as_func_failure () {
+ as_func_return 1
+as_func_ret_success () {
+ return 0
+as_func_ret_failure () {
+ return 1
exitcode=0
-as_fn_success || { exitcode=1; echo as_fn_success failed.; }
-as_fn_failure && { exitcode=1; echo as_fn_failure succeeded.; }
-as_fn_ret_success || { exitcode=1; echo as_fn_ret_success failed.; }
-as_fn_ret_failure && { exitcode=1; echo as_fn_ret_failure succeeded.; }
-if ( set x; as_fn_ret_success y && test x = \"\$1\" ); then :
-else
- exitcode=1; echo positional parameters were not saved.
-fi
-test x\$exitcode = x0 || exit 1
-test -x / || exit 1"
- as_suggested=" as_lineno_1=";as_suggested=$as_suggested$LINENO;as_suggested=$as_suggested" as_lineno_1a=\$LINENO
- as_lineno_2=";as_suggested=$as_suggested$LINENO;as_suggested=$as_suggested" as_lineno_2a=\$LINENO
- eval 'test \"x\$as_lineno_1'\$as_run'\" != \"x\$as_lineno_2'\$as_run'\" &&
- test \"x\`expr \$as_lineno_1'\$as_run' + 1\`\" = \"x\$as_lineno_2'\$as_run'\"' || exit 1
-test \$(( 1 + 1 )) = 2 || exit 1"
- if (eval "$as_required") 2>/dev/null; then :
- as_have_required=yes
+if as_func_success; then
else
- as_have_required=no
+ exitcode=1
+ echo as_func_success failed.
+fi
+if as_func_failure; then
+ exitcode=1
+ echo as_func_failure succeeded.
fi
- if test x$as_have_required = xyes && (eval "$as_suggested") 2>/dev/null; then :
+if as_func_ret_success; then
else
- as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
-as_found=false
+ exitcode=1
+ echo as_func_ret_success failed.
+fi
+if as_func_ret_failure; then
+ exitcode=1
+ echo as_func_ret_failure succeeded.
+fi
+if ( set x; as_func_ret_success y && test x = \"\$1\" ); then
+else
+ exitcode=1
+ echo positional parameters were not saved.
+fi
+test \$exitcode = 0) || { (exit 1); exit 1; }
+ as_lineno_1=\$LINENO
+ as_lineno_2=\$LINENO
+ test \"x\$as_lineno_1\" != \"x\$as_lineno_2\" &&
+ test \"x\`expr \$as_lineno_1 + 1\`\" = \"x\$as_lineno_2\") || { (exit 1); exit 1; }
+") 2> /dev/null; then
+else
+ as_candidate_shells=
+ as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
for as_dir in /bin$PATH_SEPARATOR/usr/bin$PATH_SEPARATOR$PATH
do
IFS=$as_save_IFS
- as_found=:
- case $as_dir in #(
+ case $as_dir in
for as_base in sh bash ksh sh5; do
- # Try only shells that exist, to save several forks.
- as_shell=$as_dir/$as_base
- if { test -f "$as_shell" || test -f "$as_shell.exe"; } &&
- { $as_echo "$as_bourne_compatible""$as_required" | as_run=a "$as_shell"; } 2>/dev/null; then :
- CONFIG_SHELL=$as_shell as_have_required=yes
- if { $as_echo "$as_bourne_compatible""$as_suggested" | as_run=a "$as_shell"; } 2>/dev/null; then :
- break 2
-fi
-fi
+ as_candidate_shells="$as_candidate_shells $as_dir/$as_base"
done;;
esac
- as_found=false
done
-$as_found || { if { test -f "$SHELL" || test -f "$SHELL.exe"; } &&
- { $as_echo "$as_bourne_compatible""$as_required" | as_run=a "$SHELL"; } 2>/dev/null; then :
- CONFIG_SHELL=$SHELL as_have_required=yes
-fi; }
IFS=$as_save_IFS
- if test "x$CONFIG_SHELL" != x; then :
- export CONFIG_SHELL
-BASH_ENV=/dev/null
-ENV=/dev/null
-case $- in # ((((
- * ) as_opts= ;;
+ for as_shell in $as_candidate_shells $SHELL; do
+ # Try only shells that exist, to save several forks.
+ if { test -f "$as_shell" || test -f "$as_shell.exe"; } &&
+ { ("$as_shell") 2> /dev/null <<\_ASEOF
+ emulate sh
+ NULLCMD=:
+ # Pre-4.2 versions of Zsh do word splitting on ${1+"$@"}, which
+ # is contrary to our usage. Disable this feature.
+ alias -g '${1+"$@"}'='"$@"'
+ setopt NO_GLOB_SUBST
+else
esac
-exit 255
-fi
- if test x$as_have_required = xno; then :
- $as_echo "$0: This script requires a shell more modern than all"
- $as_echo "$0: the shells that I found on your system."
- if test x${ZSH_VERSION+set} = xset ; then
- $as_echo "$0: In particular, zsh $ZSH_VERSION has bugs and should"
- $as_echo "$0: be upgraded to zsh 4.3.4 or later."
- else
- $as_echo "$0: Please tell bug-autoconf at gnu.org about your system,
-$0: including any error possibly output before this
-$0: message. Then install a modern shell, or manually run
-$0: the script under such a shell if you do have one."
- fi
- exit 1
-fi
-fi
fi
-SHELL=${CONFIG_SHELL-/bin/sh}
-export SHELL
-# Unset more variables known to interfere with behavior of common tools.
-CLICOLOR_FORCE= GREP_OPTIONS=
-unset CLICOLOR_FORCE GREP_OPTIONS
-## M4sh Shell Functions. ##
-# as_fn_unset VAR
-# Portably unset VAR.
-as_fn_unset ()
- { eval $1=; unset $1;}
-as_unset=as_fn_unset
-# as_fn_set_status STATUS
-# Set $? to STATUS, without forking.
-as_fn_set_status ()
- return $1
-} # as_fn_set_status
+_ASEOF
+}; then
+ CONFIG_SHELL=$as_shell
+ if { "$as_shell" 2> /dev/null <<\_ASEOF
+ emulate sh
+ NULLCMD=:
+else
+esac
-# as_fn_exit STATUS
-# Exit the shell with STATUS, even in a "trap 0" or "set -e" context.
-as_fn_exit ()
- set +e
- as_fn_set_status $1
- exit $1
-} # as_fn_exit
-# as_fn_mkdir_p
-# Create "$as_dir" as a directory, including parents if necessary.
-as_fn_mkdir_p ()
+fi
- -*) as_dir=./$as_dir;;
- esac
- test -d "$as_dir" || eval $as_mkdir_p || {
- as_dirs=
- while :; do
- *\'*) as_qdir=`$as_echo "$as_dir" | sed "s/'/'\\\\\\\\''/g"`;; #'(
- *) as_qdir=$as_dir;;
- esac
- as_dirs="'$as_qdir' $as_dirs"
- as_dir=`$as_dirname -- "$as_dir" ||
-$as_expr X"$as_dir" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
- X"$as_dir" : 'X\(//\)[^/]' \| \
- X"$as_dir" : 'X\(//\)$' \| \
- X"$as_dir" : 'X\(/\)' \| . 2>/dev/null ||
-$as_echo X"$as_dir" |
- sed '/^X\(.*[^/]\)\/\/*[^/][^/]*\/*$/{
- s//\1/
- q
- /^X\(\/\/\)[^/].*/{
- s//\1/
- q
- /^X\(\/\/\)$/{
- s//\1/
- q
- /^X\(\/\).*/{
- s//\1/
- q
- s/.*/./; q'`
- test -d "$as_dir" && break
- done
- test -z "$as_dirs" || eval "mkdir $as_dirs"
- } || test -d "$as_dir" || as_fn_error $? "cannot create directory $as_dir"
+ (exit $1)
+ as_func_return 0
+ as_func_return 1
+ return 0
+ return 1
-} # as_fn_mkdir_p
+exitcode=0
+else
+ exitcode=1
+fi
-# as_fn_executable_p FILE
-# Test if FILE is an executable regular file.
-as_fn_executable_p ()
- test -f "$1" && test -x "$1"
-} # as_fn_executable_p
-# as_fn_append VAR VALUE
-# Append the text in VALUE to the end of the definition contained in VAR. Take
-# advantage of any shell optimizations that allow amortized linear growth over
-# repeated appends, instead of the typical quadratic growth present in naive
-# implementations.
-if (eval "as_var=1; as_var+=2; test x\$as_var = x12") 2>/dev/null; then :
- eval 'as_fn_append ()
- eval $1+=\$2
+ exitcode=1
+fi
else
- as_fn_append ()
- eval $1=\$$1\$2
-fi # as_fn_append
-# as_fn_arith ARG...
-# Perform arithmetic evaluation on the ARGs, and store the result in the
-# global $as_val. Take advantage of shells that can avoid forks. The arguments
-# must be portable across $(()) and expr.
-if (eval "test \$(( 1 + 1 )) = 2") 2>/dev/null; then :
- eval 'as_fn_arith ()
- as_val=$(( $* ))
+ exitcode=1
+fi
+ exitcode=1
+fi
+if ( set x; as_func_ret_success y && test x = "$1" ); then
else
- as_fn_arith ()
- as_val=`expr "$@" || test $? -eq 1`
-fi # as_fn_arith
+ exitcode=1
+fi
+test $exitcode = 0) || { (exit 1); exit 1; }
-# as_fn_error STATUS ERROR [LINENO LOG_FD]
-# Output "`basename $0`: error: ERROR" to stderr. If LINENO and LOG_FD are
-# provided, also output the error to LOG_FD, referencing LINENO. Then exit the
-# script with STATUS, using 1 if that was 0.
-as_fn_error ()
- as_status=$1; test $as_status -eq 0 && as_status=1
- if test "$4"; then
- as_lineno=${as_lineno-"$3"} as_lineno_stack=as_lineno_stack=$as_lineno_stack
- $as_echo "$as_me:${as_lineno-$LINENO}: error: $2" >&$4
- fi
- $as_echo "$as_me: error: $2" >&2
- as_fn_exit $as_status
-} # as_fn_error
+ as_lineno_1=$LINENO
+ as_lineno_2=$LINENO
+ test "x$as_lineno_1" != "x$as_lineno_2" &&
+ test "x`expr $as_lineno_1 + 1`" = "x$as_lineno_2") || { (exit 1); exit 1; }
-if expr a : '\(a\)' >/dev/null 2>&1 &&
- test "X`expr 00001 : '.*\(...\)'`" = X001; then
- as_expr=expr
+_ASEOF
+}; then
+ break
+fi
+fi
+ done
+ if test "x$CONFIG_SHELL" != x; then
+ for as_var in BASH_ENV ENV
+ do ($as_unset $as_var) >/dev/null 2>&1 && $as_unset $as_var
+ done
+ export CONFIG_SHELL
+ exec "$CONFIG_SHELL" "$as_myself" ${1+"$@"}
+fi
+ if test $as_have_required = no; then
+ echo This script requires a shell more modern than all the
+ echo shells that I found on your system. Please install a
+ echo modern shell, or manually run the script under such a
+ echo shell if you do have one.
+fi
+fi
+fi
+(eval "as_func_return () {
+ (exit \$1)
+ as_func_return 0
+ as_func_return 1
+ return 0
+ return 1
+exitcode=0
else
- as_expr=false
+ exitcode=1
fi
-if (basename -- /) >/dev/null 2>&1 && test "X`basename -- / 2>&1`" = "X/"; then
- as_basename=basename
+ exitcode=1
+fi
else
- as_basename=false
+ exitcode=1
fi
-if (as_dir=`dirname -- /` && test "X$as_dir" = X/) >/dev/null 2>&1; then
- as_dirname=dirname
+ exitcode=1
+fi
else
- as_dirname=false
+ exitcode=1
fi
-as_me=`$as_basename -- "$0" ||
-$as_expr X/"$0" : '.*/\([^/][^/]*\)/*$' \| \
- X"$0" : 'X\(//\)$' \| \
- X"$0" : 'X\(/\)' \| . 2>/dev/null ||
-$as_echo X/"$0" |
- sed '/^.*\/\([^/][^/]*\)\/*$/{
- s//\1/
- q
- /^X\/\(\/\/\)$/{
- s//\1/
- q
- /^X\/\(\/\).*/{
- s//\1/
- q
- s/.*/./; q'`
+test \$exitcode = 0") || {
+ echo No shell found that supports shell functions.
+ echo Please tell bug-autoconf at gnu.org about your system,
+ echo including any error possibly output before this message.
+ echo This can help us improve future autoconf versions.
+ echo Configuration will now proceed without shell functions.
-# Avoid depending upon Character Ranges.
-as_cr_letters='abcdefghijklmnopqrstuvwxyz'
-as_cr_LETTERS='ABCDEFGHIJKLMNOPQRSTUVWXYZ'
-as_cr_Letters=$as_cr_letters$as_cr_LETTERS
-as_cr_digits='0123456789'
-as_cr_alnum=$as_cr_Letters$as_cr_digits
+ test "x`expr $as_lineno_1 + 1`" = "x$as_lineno_2" || {
- as_lineno_1=$LINENO as_lineno_1a=$LINENO
- as_lineno_2=$LINENO as_lineno_2a=$LINENO
- eval 'test "x$as_lineno_1'$as_run'" != "x$as_lineno_2'$as_run'" &&
- test "x`expr $as_lineno_1'$as_run' + 1`" = "x$as_lineno_2'$as_run'"' || {
- # Blame Lee E. McMahon (1931-1989) for sed's syntax. :-)
+ # Create $as_me.lineno as a copy of $as_myself, but with $LINENO
+ # uniformly replaced by the line number. The first 'sed' inserts a
+ # line-number line after each line using $LINENO; the second 'sed'
+ # does the real work. The second script uses 'N' to pair each
+ # line-number line with the line containing $LINENO, and appends
+ # trailing '-' during substitution so that $LINENO is not a special
+ # case at line end.
+ # (Raja R Harinath suggested sed '=', and Paul Eggert wrote the
+ # scripts with optimization help from Paolo Bonzini. Blame Lee
+ # E. McMahon (1931-1989) for sed's syntax. :-)
sed -n '
p
/[$]LINENO/=
@@ -483,12 +471,9 @@ as_cr_alnum=$as_cr_Letters$as_cr_digits
s/-\n.*//
' >$as_me.lineno &&
chmod +x "$as_me.lineno" ||
- { $as_echo "$as_me: error: cannot create $as_me.lineno; rerun with a POSIX shell" >&2; as_fn_exit 1; }
+ { $as_echo "$as_me: error: cannot create $as_me.lineno; rerun with a POSIX shell" >&2
+ { (exit 1); exit 1; }; }
- # If we had to re-execute with $CONFIG_SHELL, we're ensured to have
- # already done that, so ensure we don't try to do so again and fall
- # in an infinite loop. This has already happened in practice.
# Don't try to exec as it changes $[0], causing all sort of problems
# (the dirname of $[0] is not the place where we might find the
# original and so on. Autoconf is especially sensitive to this).
@@ -497,18 +482,29 @@ as_cr_alnum=$as_cr_Letters$as_cr_digits
exit
+if (as_dir=`dirname -- /` && test "X$as_dir" = X/) >/dev/null 2>&1; then
+ as_dirname=dirname
+else
+ as_dirname=false
+fi
ECHO_C= ECHO_N= ECHO_T=
-case `echo -n x` in #(((((
+case `echo -n x` in
-n*)
- case `echo 'xy\c'` in
+ case `echo 'x\c'` in
*c*) ECHO_T=' ';; # ECHO_T is single tab character.
- xy) ECHO_C='\c';;
- *) echo `echo ksh88 bug on AIX 6.1` > /dev/null
- ECHO_T=' ';;
+ *) ECHO_C='\c';;
esac;;
ECHO_N='-n';;
esac
+ as_expr=expr
+else
+ as_expr=false
+fi
rm -f conf$$ conf$$.exe conf$$.file
if test -d conf$$.dir; then
@@ -523,29 +519,49 @@ if (echo >conf$$.file) 2>/dev/null; then
# ... but there are two gotchas:
# 1) On MSYS, both `ln -s file dir' and `ln file dir' fail.
# 2) DJGPP < 2.04 has no symlinks; `ln -s' creates a wrapper executable.
- # In both cases, we have to default to `cp -pR'.
+ # In both cases, we have to default to `cp -p'.
ln -s conf$$.file conf$$.dir 2>/dev/null && test ! -f conf$$.exe ||
- as_ln_s='cp -pR'
+ as_ln_s='cp -p'
elif ln conf$$.file conf$$ 2>/dev/null; then
as_ln_s=ln
else
- as_ln_s='cp -pR'
+ as_ln_s='cp -p'
fi
else
- as_ln_s='cp -pR'
+ as_ln_s='cp -p'
fi
rm -f conf$$ conf$$.exe conf$$.dir/conf$$.file conf$$.file
rmdir conf$$.dir 2>/dev/null
if mkdir -p . 2>/dev/null; then
- as_mkdir_p='mkdir -p "$as_dir"'
+ as_mkdir_p=:
else
test -d ./-p && rmdir ./-p
as_mkdir_p=false
fi
-as_test_x='test -x'
-as_executable_p=as_fn_executable_p
+if test -x / >/dev/null 2>&1; then
+ as_test_x='test -x'
+else
+ if ls -dL / >/dev/null 2>&1; then
+ as_ls_L_option=L
+ else
+ as_ls_L_option=
+ fi
+ as_test_x='
+ eval sh -c '\''
+ if test -d "$1"; then
+ test -d "$1/.";
+ else
+ case $1 in
+ -*)set "./$1";;
+ esac;
+ case `ls -ld'$as_ls_L_option' "$1" 2>/dev/null` in
+ ???[sx]*):;;*)false;;esac;fi
+ '\'' sh
+fi
+as_executable_p=$as_test_x
# Sed expression to map a string onto a valid CPP name.
as_tr_cpp="eval sed 'y%*$as_cr_letters%P$as_cr_LETTERS%;s%[^_$as_cr_alnum]%_%g'"
@@ -554,11 +570,11 @@ as_tr_cpp="eval sed 'y%*$as_cr_letters%P$as_cr_LETTERS%;s%[^_$as_cr_alnum]%_%g'"
as_tr_sh="eval sed 'y%*+%pp%;s%[^_$as_cr_alnum]%_%g'"
-test -n "$DJDIR" || exec 7<&0 </dev/null
-exec 6>&1
+exec 7<&0 </dev/null 6>&1
# Name of the host.
-# hostname on some systems (SVR3.2, old GNU/Linux) returns a bogus exit status,
+# hostname on some systems (SVR3.2, Linux) returns a bogus exit status,
# so uname gets run too.
ac_hostname=`(hostname || uname -n) 2>/dev/null | sed 1q`
@@ -573,6 +589,7 @@ cross_compiling=no
subdirs=
MFLAGS=
MAKEFLAGS=
+SHELL=${CONFIG_SHELL-/bin/sh}
# Identity of this package.
PACKAGE_NAME='darshan-runtime'
@@ -580,7 +597,6 @@ PACKAGE_TARNAME='darshan-runtime'
PACKAGE_VERSION='3.0.0-pre1'
PACKAGE_STRING='darshan-runtime 3.0.0-pre1'
PACKAGE_BUGREPORT=''
-PACKAGE_URL=''
ac_unique_file="darshan.h"
# Factoring default headers for most tests.
@@ -672,7 +688,6 @@ bindir
program_transform_name
prefix
exec_prefix
-PACKAGE_URL
PACKAGE_BUGREPORT
PACKAGE_STRING
PACKAGE_VERSION
@@ -765,9 +780,8 @@ do
fi
case $ac_option in
- *=?*) ac_optarg=`expr "X$ac_option" : '[^=]*=\(.*\)'` ;;
- *=) ac_optarg= ;;
- *) ac_optarg=yes ;;
+ *=*) ac_optarg=`expr "X$ac_option" : '[^=]*=\(.*\)'` ;;
+ *) ac_optarg=yes ;;
esac
# Accept the important Cygnus configure options, so we can diagnose typos.
@@ -812,7 +826,8 @@ do
ac_useropt=`expr "x$ac_option" : 'x-*disable-\(.*\)'`
# Reject names that are not valid shell variable names.
expr "x$ac_useropt" : ".*[^-+._$as_cr_alnum]" >/dev/null &&
- as_fn_error $? "invalid feature name: $ac_useropt"
+ { $as_echo "$as_me: error: invalid feature name: $ac_useropt" >&2
ac_useropt_orig=$ac_useropt
ac_useropt=`$as_echo "$ac_useropt" | sed 's/[-+.]/_/g'`
case $ac_user_opts in
@@ -838,7 +853,8 @@ do
ac_useropt=`expr "x$ac_option" : 'x-*enable-\([^=]*\)'`
@@ -1042,7 +1058,8 @@ do
ac_useropt=`expr "x$ac_option" : 'x-*with-\([^=]*\)'`
- as_fn_error $? "invalid package name: $ac_useropt"
+ { $as_echo "$as_me: error: invalid package name: $ac_useropt" >&2
@@ -1058,7 +1075,8 @@ do
ac_useropt=`expr "x$ac_option" : 'x-*without-\(.*\)'`
@@ -1088,17 +1106,17 @@ do
| --x-librar=* | --x-libra=* | --x-libr=* | --x-lib=* | --x-li=* | --x-l=*)
x_libraries=$ac_optarg ;;
- -*) as_fn_error $? "unrecognized option: \`$ac_option'
-Try \`$0 --help' for more information"
+ -*) { $as_echo "$as_me: error: unrecognized option: $ac_option
+Try \`$0 --help' for more information." >&2
ac_envvar=`expr "x$ac_option" : 'x\([^=]*\)='`
- case $ac_envvar in #(
- '' | [0-9]* | *[!_$as_cr_alnum]* )
- as_fn_error $? "invalid variable name: \`$ac_envvar'" ;;
- esac
+ expr "x$ac_envvar" : ".*[^_$as_cr_alnum]" >/dev/null &&
+ { $as_echo "$as_me: error: invalid variable name: $ac_envvar" >&2
eval $ac_envvar=\$ac_optarg
export $ac_envvar ;;
@@ -1107,7 +1125,7 @@ Try \`$0 --help' for more information"
$as_echo "$as_me: WARNING: you should use --build, --host, --target" >&2
expr "x$ac_option" : ".*[^-._$as_cr_alnum]" >/dev/null &&
$as_echo "$as_me: WARNING: invalid host type: $ac_option" >&2
- : "${build_alias=$ac_option} ${host_alias=$ac_option} ${target_alias=$ac_option}"
+ : ${build_alias=$ac_option} ${host_alias=$ac_option} ${target_alias=$ac_option}
esac
@@ -1115,13 +1133,15 @@ done
if test -n "$ac_prev"; then
ac_option=--`echo $ac_prev | sed 's/_/-/g'`
- as_fn_error $? "missing argument to $ac_option"
+ { $as_echo "$as_me: error: missing argument to $ac_option" >&2
fi
if test -n "$ac_unrecognized_opts"; then
case $enable_option_checking in
no) ;;
- fatal) as_fn_error $? "unrecognized options: $ac_unrecognized_opts" ;;
+ fatal) { $as_echo "$as_me: error: unrecognized options: $ac_unrecognized_opts" >&2
+ { (exit 1); exit 1; }; } ;;
*) $as_echo "$as_me: WARNING: unrecognized options: $ac_unrecognized_opts" >&2 ;;
esac
fi
@@ -1144,7 +1164,8 @@ do
[\\/$]* | ?:[\\/]* ) continue;;
NONE | '' ) case $ac_var in *prefix ) continue;; esac;;
esac
- as_fn_error $? "expected an absolute directory name for --$ac_var: $ac_val"
+ { $as_echo "$as_me: error: expected an absolute directory name for --$ac_var: $ac_val" >&2
done
# There might be people who depend on the old broken behavior: `$host'
@@ -1158,6 +1179,8 @@ target=$target_alias
if test "x$host_alias" != x; then
if test "x$build_alias" = x; then
cross_compiling=maybe
+ $as_echo "$as_me: WARNING: If you wanted to set the --build type, don't use --host.
+ If a cross compiler is detected then cross compile mode will be used." >&2
elif test "x$build_alias" != "x$host_alias"; then
cross_compiling=yes
fi
@@ -1172,9 +1195,11 @@ test "$silent" = yes && exec 6>/dev/null
ac_pwd=`pwd` && test -n "$ac_pwd" &&
ac_ls_di=`ls -di .` &&
ac_pwd_ls_di=`cd "$ac_pwd" && ls -di .` ||
- as_fn_error $? "working directory cannot be determined"
+ { $as_echo "$as_me: error: working directory cannot be determined" >&2
test "X$ac_ls_di" = "X$ac_pwd_ls_di" ||
- as_fn_error $? "pwd does not report name of working directory"
+ { $as_echo "$as_me: error: pwd does not report name of working directory" >&2
# Find the source files, if location was not specified.
@@ -1213,11 +1238,13 @@ else
fi
if test ! -r "$srcdir/$ac_unique_file"; then
test "$ac_srcdir_defaulted" = yes && srcdir="$ac_confdir or .."
- as_fn_error $? "cannot find sources ($ac_unique_file) in $srcdir"
+ { $as_echo "$as_me: error: cannot find sources ($ac_unique_file) in $srcdir" >&2
fi
ac_msg="sources are in $srcdir, but \`cd $srcdir' does not work"
ac_abs_confdir=`(
- cd "$srcdir" && test -r "./$ac_unique_file" || as_fn_error $? "$ac_msg"
+ cd "$srcdir" && test -r "./$ac_unique_file" || { $as_echo "$as_me: error: $ac_msg" >&2
pwd)`
# When building in place, set srcdir=.
if test "$ac_abs_confdir" = "$ac_pwd"; then
@@ -1257,7 +1284,7 @@ Configuration:
--help=short display options specific to this package
--help=recursive display the short help of all the included packages
-V, --version display version information and exit
- -q, --quiet, --silent do not print \`checking ...' messages
+ -q, --quiet, --silent do not print \`checking...' messages
--cache-file=FILE cache test results in FILE [disabled]
-C, --config-cache alias for \`--cache-file=config.cache'
-n, --no-create do not create output files
@@ -1337,14 +1364,13 @@ Some influential environment variables:
LDFLAGS linker flags, e.g. -L<lib dir> if you have libraries in a
nonstandard directory <lib dir>
LIBS libraries to pass to the linker, e.g. -l<library>
- CPPFLAGS (Objective) C/C++ preprocessor flags, e.g. -I<include dir> if
+ CPPFLAGS C/C++/Objective C preprocessor flags, e.g. -I<include dir> if
you have headers in a nonstandard directory <include dir>
CPP C preprocessor
Use these variables to override the choices made by `configure' or to help
it to find libraries and programs with nonstandard names/locations.
-Report bugs to the package provider.
_ACEOF
ac_status=$?
fi
@@ -1408,359 +1434,21 @@ test -n "$ac_init_help" && exit $ac_status
if $ac_init_version; then
cat <<\_ACEOF
darshan-runtime configure 3.0.0-pre1
-generated by GNU Autoconf 2.69
+generated by GNU Autoconf 2.63
-Copyright (C) 2012 Free Software Foundation, Inc.
+Copyright (C) 1992, 1993, 1994, 1995, 1996, 1998, 1999, 2000, 2001,
+2002, 2003, 2004, 2005, 2006, 2007, 2008 Free Software Foundation, Inc.
_ACEOF
exit
fi
-## Autoconf initialization. ##
-# ac_fn_c_try_compile LINENO
-# Try to compile conftest.$ac_ext, and return whether this succeeded.
-ac_fn_c_try_compile ()
- as_lineno=${as_lineno-"$1"} as_lineno_stack=as_lineno_stack=$as_lineno_stack
- rm -f conftest.$ac_objext
- if { { ac_try="$ac_compile"
-case "(($ac_try" in
- *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;;
- *) ac_try_echo=$ac_try;;
-esac
-eval ac_try_echo="\"\$as_me:${as_lineno-$LINENO}: $ac_try_echo\""
-$as_echo "$ac_try_echo"; } >&5
- (eval "$ac_compile") 2>conftest.err
- ac_status=$?
- if test -s conftest.err; then
- grep -v '^ *+' conftest.err >conftest.er1
- cat conftest.er1 >&5
- mv -f conftest.er1 conftest.err
- fi
- $as_echo "$as_me:${as_lineno-$LINENO}: \$? = $ac_status" >&5
- test $ac_status = 0; } && {
- test -z "$ac_c_werror_flag" ||
- test ! -s conftest.err
- } && test -s conftest.$ac_objext; then :
- ac_retval=0
-else
- $as_echo "$as_me: failed program was:" >&5
-sed 's/^/| /' conftest.$ac_ext >&5
- ac_retval=1
-fi
- eval $as_lineno_stack; ${as_lineno_stack:+:} unset as_lineno
- as_fn_set_status $ac_retval
-} # ac_fn_c_try_compile
-# ac_fn_c_try_cpp LINENO
-# Try to preprocess conftest.$ac_ext, and return whether this succeeded.
-ac_fn_c_try_cpp ()
- if { { ac_try="$ac_cpp conftest.$ac_ext"
-esac
- (eval "$ac_cpp conftest.$ac_ext") 2>conftest.err
- ac_status=$?
- fi
- test $ac_status = 0; } > conftest.i && {
- test -z "$ac_c_preproc_warn_flag$ac_c_werror_flag" ||
- }; then :
- ac_retval=0
-else
- ac_retval=1
-fi
-} # ac_fn_c_try_cpp
-# ac_fn_c_check_header_mongrel LINENO HEADER VAR INCLUDES
-# Tests whether HEADER exists, giving a warning if it cannot be compiled using
-# the include files in INCLUDES and setting the cache variable VAR
-# accordingly.
-ac_fn_c_check_header_mongrel ()
- if eval \${$3+:} false; then :
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking for $2" >&5
-$as_echo_n "checking for $2... " >&6; }
-if eval \${$3+:} false; then :
- $as_echo_n "(cached) " >&6
-fi
-eval ac_res=\$$3
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_res" >&5
-$as_echo "$ac_res" >&6; }
-else
- # Is the header compilable?
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking $2 usability" >&5
-$as_echo_n "checking $2 usability... " >&6; }
-cat confdefs.h - <<_ACEOF >conftest.$ac_ext
-/* end confdefs.h. */
-$4
-#include <$2>
-_ACEOF
-if ac_fn_c_try_compile "$LINENO"; then :
- ac_header_compiler=yes
-else
- ac_header_compiler=no
-fi
-rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_header_compiler" >&5
-$as_echo "$ac_header_compiler" >&6; }
-# Is the header present?
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking $2 presence" >&5
-$as_echo_n "checking $2 presence... " >&6; }
-#include <$2>
-_ACEOF
-if ac_fn_c_try_cpp "$LINENO"; then :
- ac_header_preproc=yes
-else
- ac_header_preproc=no
-fi
-rm -f conftest.err conftest.i conftest.$ac_ext
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_header_preproc" >&5
-$as_echo "$ac_header_preproc" >&6; }
-# So? What about this header?
-case $ac_header_compiler:$ac_header_preproc:$ac_c_preproc_warn_flag in #((
- yes:no: )
- { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: $2: accepted by the compiler, rejected by the preprocessor!" >&5
-$as_echo "$as_me: WARNING: $2: accepted by the compiler, rejected by the preprocessor!" >&2;}
- { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: $2: proceeding with the compiler's result" >&5
-$as_echo "$as_me: WARNING: $2: proceeding with the compiler's result" >&2;}
- no:yes:* )
- { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: $2: present but cannot be compiled" >&5
-$as_echo "$as_me: WARNING: $2: present but cannot be compiled" >&2;}
- { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: $2: check for missing prerequisite headers?" >&5
-$as_echo "$as_me: WARNING: $2: check for missing prerequisite headers?" >&2;}
- { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: $2: see the Autoconf documentation" >&5
-$as_echo "$as_me: WARNING: $2: see the Autoconf documentation" >&2;}
- { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: $2: section \"Present But Cannot Be Compiled\"" >&5
-$as_echo "$as_me: WARNING: $2: section \"Present But Cannot Be Compiled\"" >&2;}
-esac
-else
- eval "$3=\$ac_header_compiler"
-fi
-eval ac_res=\$$3
-fi
-} # ac_fn_c_check_header_mongrel
-# ac_fn_c_try_run LINENO
-# Try to link conftest.$ac_ext, and return whether this succeeded. Assumes
-# that executables *can* be run.
-ac_fn_c_try_run ()
- if { { ac_try="$ac_link"
-esac
- (eval "$ac_link") 2>&5
- ac_status=$?
- test $ac_status = 0; } && { ac_try='./conftest$ac_exeext'
- { { case "(($ac_try" in
-esac
- (eval "$ac_try") 2>&5
- ac_status=$?
- test $ac_status = 0; }; }; then :
- ac_retval=0
-else
- $as_echo "$as_me: program exited with status $ac_status" >&5
- ac_retval=$ac_status
-fi
- rm -rf conftest.dSYM conftest_ipa8_conftest.oo
-} # ac_fn_c_try_run
-# ac_fn_c_check_header_compile LINENO HEADER VAR INCLUDES
-# Tests whether HEADER exists and can be compiled using the include files in
-# INCLUDES, setting the cache variable VAR accordingly.
-ac_fn_c_check_header_compile ()
-else
- cat confdefs.h - <<_ACEOF >conftest.$ac_ext
-$4
-#include <$2>
-_ACEOF
- eval "$3=yes"
-else
- eval "$3=no"
-fi
-fi
-eval ac_res=\$$3
-} # ac_fn_c_check_header_compile
-# ac_fn_c_try_link LINENO
-ac_fn_c_try_link ()
- rm -f conftest.$ac_objext conftest$ac_exeext
-esac
- (eval "$ac_link") 2>conftest.err
- ac_status=$?
- fi
- } && test -s conftest$ac_exeext && {
- test "$cross_compiling" = yes ||
- test -x conftest$ac_exeext
- }; then :
- ac_retval=0
-else
- ac_retval=1
-fi
- # Delete the IPA/IPO (Inter Procedural Analysis/Optimization) information
- # created by the PGI compiler (conftest_ipa8_conftest.oo), as it would
- # interfere with the next link command; also delete a directory that is
- # left behind by Apple's compiler. We do this before executing the actions.
-} # ac_fn_c_try_link
-# ac_fn_c_check_type LINENO TYPE VAR INCLUDES
-# Tests whether TYPE exists after having included INCLUDES, setting cache
-# variable VAR accordingly.
-ac_fn_c_check_type ()
-else
- eval "$3=no"
-$4
-int
-main ()
-if (sizeof ($2))
- return 0;
- return 0;
-_ACEOF
-$4
-int
-main ()
-if (sizeof (($2)))
- return 0;
- return 0;
-_ACEOF
-else
- eval "$3=yes"
-fi
-fi
-fi
-eval ac_res=\$$3
-} # ac_fn_c_check_type
cat >config.log <<_ACEOF
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
It was created by darshan-runtime $as_me 3.0.0-pre1, which was
-generated by GNU Autoconf 2.69. Invocation command line was
+generated by GNU Autoconf 2.63. Invocation command line was
$ $0 $@
@@ -1796,8 +1484,8 @@ for as_dir in $PATH
do
IFS=$as_save_IFS
- $as_echo "PATH: $as_dir"
- done
+ $as_echo "PATH: $as_dir"
+done
IFS=$as_save_IFS
} >&5
@@ -1834,9 +1522,9 @@ do
ac_arg=`$as_echo "$ac_arg" | sed "s/'/'\\\\\\\\''/g"` ;;
esac
case $ac_pass in
- 1) as_fn_append ac_configure_args0 " '$ac_arg'" ;;
+ 1) ac_configure_args0="$ac_configure_args0 '$ac_arg'" ;;
2)
- as_fn_append ac_configure_args1 " '$ac_arg'"
+ ac_configure_args1="$ac_configure_args1 '$ac_arg'"
if test $ac_must_keep_next = true; then
ac_must_keep_next=false # Got value, back to normal.
else
@@ -1852,13 +1540,13 @@ do
-* ) ac_must_keep_next=true ;;
esac
fi
- as_fn_append ac_configure_args " '$ac_arg'"
+ ac_configure_args="$ac_configure_args '$ac_arg'"
esac
done
done
-{ ac_configure_args0=; unset ac_configure_args0;}
-{ ac_configure_args1=; unset ac_configure_args1;}
+$as_unset ac_configure_args0 || test "${ac_configure_args0+set}" != set || { ac_configure_args0=; export ac_configure_args0; }
+$as_unset ac_configure_args1 || test "${ac_configure_args1+set}" != set || { ac_configure_args1=; export ac_configure_args1; }
# When interrupted or exit'd, cleanup temporary files, and complete
# config.log. We remove comments because anyway the quotes in there
@@ -1870,9 +1558,11 @@ trap 'exit_status=$?
echo
- $as_echo "## ---------------- ##
+ cat <<\_ASBOX
## Cache variables. ##
+_ASBOX
echo
# The following way of writing the cache mishandles newlines in values,
@@ -1881,13 +1571,13 @@ trap 'exit_status=$?
case $ac_val in #(
*${as_nl}*)
case $ac_var in #(
- *_cv_*) { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: cache variable $ac_var contains a newline" >&5
+ *_cv_*) { $as_echo "$as_me:$LINENO: WARNING: cache variable $ac_var contains a newline" >&5
$as_echo "$as_me: WARNING: cache variable $ac_var contains a newline" >&2;} ;;
esac
case $ac_var in #(
_ | IFS | as_nl) ;; #(
BASH_ARGV | BASH_SOURCE) eval $ac_var= ;; #(
- *) { eval $ac_var=; unset $ac_var;} ;;
+ *) $as_unset $ac_var ;;
esac ;;
esac
done
@@ -1906,9 +1596,11 @@ $as_echo "$as_me: WARNING: cache variable $ac_var contains a newline" >&2;} ;;
echo
- $as_echo "## ----------------- ##
+ cat <<\_ASBOX
## Output variables. ##
+_ASBOX
echo
for ac_var in $ac_subst_vars
do
@@ -1921,9 +1613,11 @@ $as_echo "$as_me: WARNING: cache variable $ac_var contains a newline" >&2;} ;;
echo
if test -n "$ac_subst_files"; then
- $as_echo "## ------------------- ##
+ cat <<\_ASBOX
## File substitutions. ##
+_ASBOX
echo
for ac_var in $ac_subst_files
do
@@ -1937,9 +1631,11 @@ $as_echo "$as_me: WARNING: cache variable $ac_var contains a newline" >&2;} ;;
fi
if test -s confdefs.h; then
- $as_echo "## ----------- ##
+ cat <<\_ASBOX
## confdefs.h. ##
+_ASBOX
echo
cat confdefs.h
echo
@@ -1953,39 +1649,37 @@ $as_echo "$as_me: WARNING: cache variable $ac_var contains a newline" >&2;} ;;
exit $exit_status
' 0
for ac_signal in 1 2 13 15; do
- trap 'ac_signal='$ac_signal'; as_fn_exit 1' $ac_signal
+ trap 'ac_signal='$ac_signal'; { (exit 1); exit 1; }' $ac_signal
done
ac_signal=0
# confdefs.h avoids OS command line length limits that DEFS can exceed.
rm -f -r conftest* confdefs.h
-$as_echo "/* confdefs.h */" > confdefs.h
# Predefined preprocessor variables.
cat >>confdefs.h <<_ACEOF
#define PACKAGE_NAME "$PACKAGE_NAME"
_ACEOF
#define PACKAGE_TARNAME "$PACKAGE_TARNAME"
_ACEOF
#define PACKAGE_VERSION "$PACKAGE_VERSION"
_ACEOF
#define PACKAGE_STRING "$PACKAGE_STRING"
_ACEOF
-cat >>confdefs.h <<_ACEOF
-#define PACKAGE_BUGREPORT "$PACKAGE_BUGREPORT"
-_ACEOF
-#define PACKAGE_URL "$PACKAGE_URL"
+#define PACKAGE_BUGREPORT "$PACKAGE_BUGREPORT"
_ACEOF
@@ -1994,12 +1688,7 @@ _ACEOF
ac_site_file1=NONE
ac_site_file2=NONE
if test -n "$CONFIG_SITE"; then
- # We do not want a PATH search for config.site.
- case $CONFIG_SITE in #((
- -*) ac_site_file1=./$CONFIG_SITE;;
- */*) ac_site_file1=$CONFIG_SITE;;
- *) ac_site_file1=./$CONFIG_SITE;;
- esac
+ ac_site_file1=$CONFIG_SITE
elif test "x$prefix" != xNONE; then
ac_site_file1=$prefix/share/config.site
ac_site_file2=$prefix/etc/config.site
@@ -2010,23 +1699,19 @@ fi
for ac_site_file in "$ac_site_file1" "$ac_site_file2"
do
test "x$ac_site_file" = xNONE && continue
- if test /dev/null != "$ac_site_file" && test -r "$ac_site_file"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: loading site script $ac_site_file" >&5
+ if test -r "$ac_site_file"; then
+ { $as_echo "$as_me:$LINENO: loading site script $ac_site_file" >&5
$as_echo "$as_me: loading site script $ac_site_file" >&6;}
sed 's/^/| /' "$ac_site_file" >&5
- . "$ac_site_file" \
- || { { $as_echo "$as_me:${as_lineno-$LINENO}: error: in \`$ac_pwd':" >&5
-$as_echo "$as_me: error: in \`$ac_pwd':" >&2;}
-as_fn_error $? "failed to load site script $ac_site_file
-See \`config.log' for more details" "$LINENO" 5; }
+ . "$ac_site_file"
fi
done
if test -r "$cache_file"; then
- # Some versions of bash will fail to source /dev/null (special files
- # actually), so we avoid doing that. DJGPP emulates it as a regular file.
- if test /dev/null != "$cache_file" && test -f "$cache_file"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: loading cache $cache_file" >&5
+ # Some versions of bash will fail to source /dev/null (special
+ # files actually), so we avoid doing that.
+ if test -f "$cache_file"; then
+ { $as_echo "$as_me:$LINENO: loading cache $cache_file" >&5
$as_echo "$as_me: loading cache $cache_file" >&6;}
case $cache_file in
[\\/]* | ?:[\\/]* ) . "$cache_file";;
@@ -2034,7 +1719,7 @@ $as_echo "$as_me: loading cache $cache_file" >&6;}
esac
fi
else
- { $as_echo "$as_me:${as_lineno-$LINENO}: creating cache $cache_file" >&5
+ { $as_echo "$as_me:$LINENO: creating cache $cache_file" >&5
$as_echo "$as_me: creating cache $cache_file" >&6;}
>$cache_file
fi
@@ -2049,11 +1734,11 @@ for ac_var in $ac_precious_vars; do
eval ac_new_val=\$ac_env_${ac_var}_value
case $ac_old_set,$ac_new_set in
set,)
- { $as_echo "$as_me:${as_lineno-$LINENO}: error: \`$ac_var' was set to \`$ac_old_val' in the previous run" >&5
+ { $as_echo "$as_me:$LINENO: error: \`$ac_var' was set to \`$ac_old_val' in the previous run" >&5
$as_echo "$as_me: error: \`$ac_var' was set to \`$ac_old_val' in the previous run" >&2;}
ac_cache_corrupted=: ;;
,set)
- { $as_echo "$as_me:${as_lineno-$LINENO}: error: \`$ac_var' was not set in the previous run" >&5
+ { $as_echo "$as_me:$LINENO: error: \`$ac_var' was not set in the previous run" >&5
$as_echo "$as_me: error: \`$ac_var' was not set in the previous run" >&2;}
@@ -2063,17 +1748,17 @@ $as_echo "$as_me: error: \`$ac_var' was not set in the previous run" >&2;}
ac_old_val_w=`echo x $ac_old_val`
ac_new_val_w=`echo x $ac_new_val`
if test "$ac_old_val_w" != "$ac_new_val_w"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: error: \`$ac_var' has changed since the previous run:" >&5
+ { $as_echo "$as_me:$LINENO: error: \`$ac_var' has changed since the previous run:" >&5
$as_echo "$as_me: error: \`$ac_var' has changed since the previous run:" >&2;}
else
- { $as_echo "$as_me:${as_lineno-$LINENO}: warning: ignoring whitespace changes in \`$ac_var' since the previous run:" >&5
+ { $as_echo "$as_me:$LINENO: warning: ignoring whitespace changes in \`$ac_var' since the previous run:" >&5
$as_echo "$as_me: warning: ignoring whitespace changes in \`$ac_var' since the previous run:" >&2;}
eval $ac_var=\$ac_old_val
fi
- { $as_echo "$as_me:${as_lineno-$LINENO}: former value: \`$ac_old_val'" >&5
+ { $as_echo "$as_me:$LINENO: former value: \`$ac_old_val'" >&5
$as_echo "$as_me: former value: \`$ac_old_val'" >&2;}
- { $as_echo "$as_me:${as_lineno-$LINENO}: current value: \`$ac_new_val'" >&5
+ { $as_echo "$as_me:$LINENO: current value: \`$ac_new_val'" >&5
$as_echo "$as_me: current value: \`$ac_new_val'" >&2;}
fi;;
esac
@@ -2085,20 +1770,43 @@ $as_echo "$as_me: current value: \`$ac_new_val'" >&2;}
esac
case " $ac_configure_args " in
*" '$ac_arg' "*) ;; # Avoid dups. Use of quotes ensures accuracy.
- *) as_fn_append ac_configure_args " '$ac_arg'" ;;
+ *) ac_configure_args="$ac_configure_args '$ac_arg'" ;;
esac
fi
done
if $ac_cache_corrupted; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: error: in \`$ac_pwd':" >&5
+ { $as_echo "$as_me:$LINENO: error: in \`$ac_pwd':" >&5
- { $as_echo "$as_me:${as_lineno-$LINENO}: error: changes in the environment can compromise the build" >&5
+ { $as_echo "$as_me:$LINENO: error: changes in the environment can compromise the build" >&5
$as_echo "$as_me: error: changes in the environment can compromise the build" >&2;}
- as_fn_error $? "run \`make distclean' and/or \`rm $cache_file' and start over" "$LINENO" 5
+ { { $as_echo "$as_me:$LINENO: error: run \`make distclean' and/or \`rm $cache_file' and start over" >&5
+$as_echo "$as_me: error: run \`make distclean' and/or \`rm $cache_file' and start over" >&2;}
fi
-## Main body of script. ##
ac_ext=c
ac_cpp='$CPP $CPPFLAGS'
@@ -2125,7 +1833,9 @@ for ac_dir in ../maint/config "$srcdir"/../maint/config; do
fi
done
if test -z "$ac_aux_dir"; then
- as_fn_error $? "cannot find install-sh, install.sh, or shtool in ../maint/config \"$srcdir\"/../maint/config" "$LINENO" 5
+ { { $as_echo "$as_me:$LINENO: error: cannot find install-sh or install.sh in ../maint/config \"$srcdir\"/../maint/config" >&5
+$as_echo "$as_me: error: cannot find install-sh or install.sh in ../maint/config \"$srcdir\"/../maint/config" >&2;}
fi
# These three variables are undocumented and unsupported,
@@ -2154,10 +1864,10 @@ ac_config_headers="$ac_config_headers darshan-runtime-config.h"
# OS/2's system install, which has a completely different semantic
# ./install, which can be erroneously created by make from ./install.sh.
# Reject install programs that cannot install multiple files.
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for a BSD-compatible install" >&5
+{ $as_echo "$as_me:$LINENO: checking for a BSD-compatible install" >&5
$as_echo_n "checking for a BSD-compatible install... " >&6; }
if test -z "$INSTALL"; then
-if ${ac_cv_path_install+:} false; then :
+if test "${ac_cv_path_install+set}" = set; then
else
@@ -2165,11 +1875,11 @@ for as_dir in $PATH
do
IFS=$as_save_IFS
- # Account for people who put trailing slashes in PATH elements.
-case $as_dir/ in #((
- ./ | .// | /[cC]/* | \
+ # Account for people who put trailing slashes in PATH elements.
+case $as_dir/ in
+ ./ | .// | /cC/* | \
/etc/* | /usr/sbin/* | /usr/etc/* | /sbin/* | /usr/afsws/bin/* | \
- ?:[\\/]os2[\\/]install[\\/]* | ?:[\\/]OS2[\\/]INSTALL[\\/]* | \
+ ?:\\/os2\\/install\\/* | ?:\\/OS2\\/INSTALL\\/* | \
/usr/ucb/* ) ;;
# OSF1 and SCO ODT 3.0 have their own names for install.
@@ -2177,7 +1887,7 @@ case $as_dir/ in #((
# by default.
for ac_prog in ginstall scoinst install; do
for ac_exec_ext in '' $ac_executable_extensions; do
- if as_fn_executable_p "$as_dir/$ac_prog$ac_exec_ext"; then
+ if { test -f "$as_dir/$ac_prog$ac_exec_ext" && $as_test_x "$as_dir/$ac_prog$ac_exec_ext"; }; then
if test $ac_prog = install &&
grep dspmsg "$as_dir/$ac_prog$ac_exec_ext" >/dev/null 2>&1; then
# AIX install. It has an incompatible calling convention.
@@ -2206,7 +1916,7 @@ case $as_dir/ in #((
esac
- done
+done
IFS=$as_save_IFS
rm -rf conftest.one conftest.two conftest.dir
@@ -2222,7 +1932,7 @@ fi
INSTALL=$ac_install_sh
fi
fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $INSTALL" >&5
+{ $as_echo "$as_me:$LINENO: result: $INSTALL" >&5
$as_echo "$INSTALL" >&6; }
# Use test -z because SunOS4 sh mishandles braces in ${var-val}.
@@ -2234,7 +1944,7 @@ test -z "$INSTALL_SCRIPT" && INSTALL_SCRIPT='${INSTALL}'
test -z "$INSTALL_DATA" && INSTALL_DATA='${INSTALL} -m 644'
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether the mpicc compiler works" >&5
+{ $as_echo "$as_me:$LINENO: checking whether the mpicc compiler works" >&5
$as_echo_n "checking whether the mpicc compiler works... " >&6; }
ac_ext=c
@@ -2244,9 +1954,9 @@ ac_compiler_gnu=$ac_cv_c_compiler_gnu
if test -n "$ac_tool_prefix"; then
# Extract the first word of "${ac_tool_prefix}gcc", so it can be a program name with args.
set dummy ${ac_tool_prefix}gcc; ac_word=$2
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for $ac_word" >&5
+{ $as_echo "$as_me:$LINENO: checking for $ac_word" >&5
$as_echo_n "checking for $ac_word... " >&6; }
-if ${ac_cv_prog_CC+:} false; then :
+if test "${ac_cv_prog_CC+set}" = set; then
else
if test -n "$CC"; then
@@ -2257,24 +1967,24 @@ for as_dir in $PATH
do
IFS=$as_save_IFS
- for ac_exec_ext in '' $ac_executable_extensions; do
- if as_fn_executable_p "$as_dir/$ac_word$ac_exec_ext"; then
+ for ac_exec_ext in '' $ac_executable_extensions; do
+ if { test -f "$as_dir/$ac_word$ac_exec_ext" && $as_test_x "$as_dir/$ac_word$ac_exec_ext"; }; then
ac_cv_prog_CC="${ac_tool_prefix}gcc"
- $as_echo "$as_me:${as_lineno-$LINENO}: found $as_dir/$ac_word$ac_exec_ext" >&5
+ $as_echo "$as_me:$LINENO: found $as_dir/$ac_word$ac_exec_ext" >&5
break 2
fi
done
- done
+done
IFS=$as_save_IFS
fi
fi
CC=$ac_cv_prog_CC
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $CC" >&5
+ { $as_echo "$as_me:$LINENO: result: $CC" >&5
$as_echo "$CC" >&6; }
else
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: no" >&5
+ { $as_echo "$as_me:$LINENO: result: no" >&5
$as_echo "no" >&6; }
fi
@@ -2284,9 +1994,9 @@ if test -z "$ac_cv_prog_CC"; then
ac_ct_CC=$CC
# Extract the first word of "gcc", so it can be a program name with args.
set dummy gcc; ac_word=$2
-if ${ac_cv_prog_ac_ct_CC+:} false; then :
+if test "${ac_cv_prog_ac_ct_CC+set}" = set; then
else
if test -n "$ac_ct_CC"; then
@@ -2297,24 +2007,24 @@ for as_dir in $PATH
do
IFS=$as_save_IFS
ac_cv_prog_ac_ct_CC="gcc"
break 2
fi
done
- done
+done
IFS=$as_save_IFS
fi
fi
ac_ct_CC=$ac_cv_prog_ac_ct_CC
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_ct_CC" >&5
+ { $as_echo "$as_me:$LINENO: result: $ac_ct_CC" >&5
$as_echo "$ac_ct_CC" >&6; }
else
fi
@@ -2323,7 +2033,7 @@ fi
else
case $cross_compiling:$ac_tool_warned in
yes:)
-{ $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: using cross tools not prefixed with host triplet" >&5
+{ $as_echo "$as_me:$LINENO: WARNING: using cross tools not prefixed with host triplet" >&5
$as_echo "$as_me: WARNING: using cross tools not prefixed with host triplet" >&2;}
ac_tool_warned=yes ;;
esac
@@ -2337,9 +2047,9 @@ if test -z "$CC"; then
# Extract the first word of "${ac_tool_prefix}cc", so it can be a program name with args.
set dummy ${ac_tool_prefix}cc; ac_word=$2
else
@@ -2350,24 +2060,24 @@ for as_dir in $PATH
do
IFS=$as_save_IFS
ac_cv_prog_CC="${ac_tool_prefix}cc"
break 2
fi
done
- done
+done
IFS=$as_save_IFS
fi
fi
CC=$ac_cv_prog_CC
else
fi
@@ -2377,9 +2087,9 @@ fi
# Extract the first word of "cc", so it can be a program name with args.
set dummy cc; ac_word=$2
else
@@ -2391,18 +2101,18 @@ for as_dir in $PATH
do
IFS=$as_save_IFS
if test "$as_dir/$ac_word$ac_exec_ext" = "/usr/ucb/cc"; then
ac_prog_rejected=yes
continue
fi
ac_cv_prog_CC="cc"
break 2
fi
done
- done
+done
IFS=$as_save_IFS
if test $ac_prog_rejected = yes; then
@@ -2421,10 +2131,10 @@ fi
fi
CC=$ac_cv_prog_CC
else
fi
@@ -2436,9 +2146,9 @@ if test -z "$CC"; then
do
# Extract the first word of "$ac_tool_prefix$ac_prog", so it can be a program name with args.
set dummy $ac_tool_prefix$ac_prog; ac_word=$2
else
@@ -2449,24 +2159,24 @@ for as_dir in $PATH
do
IFS=$as_save_IFS
ac_cv_prog_CC="$ac_tool_prefix$ac_prog"
break 2
fi
done
- done
+done
IFS=$as_save_IFS
fi
fi
CC=$ac_cv_prog_CC
else
fi
@@ -2480,9 +2190,9 @@ if test -z "$CC"; then
do
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
else
@@ -2493,24 +2203,24 @@ for as_dir in $PATH
do
IFS=$as_save_IFS
ac_cv_prog_ac_ct_CC="$ac_prog"
break 2
fi
done
- done
+done
IFS=$as_save_IFS
fi
fi
else
fi
@@ -2523,7 +2233,7 @@ done
else
yes:)
esac
@@ -2534,37 +2244,57 @@ fi
fi
-test -z "$CC" && { { $as_echo "$as_me:${as_lineno-$LINENO}: error: in \`$ac_pwd':" >&5
+test -z "$CC" && { { $as_echo "$as_me:$LINENO: error: in \`$ac_pwd':" >&5
-as_fn_error $? "no acceptable C compiler found in \$PATH
+{ { $as_echo "$as_me:$LINENO: error: no acceptable C compiler found in \$PATH
+See \`config.log' for more details." >&5
+$as_echo "$as_me: error: no acceptable C compiler found in \$PATH
+See \`config.log' for more details." >&2;}
+ { (exit 1); exit 1; }; }; }
# Provide some information about the compiler.
-$as_echo "$as_me:${as_lineno-$LINENO}: checking for C compiler version" >&5
+$as_echo "$as_me:$LINENO: checking for C compiler version" >&5
set X $ac_compile
ac_compiler=$2
-for ac_option in --version -v -V -qversion; do
- { { ac_try="$ac_compiler $ac_option >&5"
+{ (ac_try="$ac_compiler --version >&5"
case "(($ac_try" in
esac
- (eval "$ac_compiler $ac_option >&5") 2>conftest.err
+eval ac_try_echo="\"\$as_me:$LINENO: $ac_try_echo\""
+$as_echo "$ac_try_echo") >&5
+ (eval "$ac_compiler --version >&5") 2>&5
ac_status=$?
- sed '10a\
-... rest of stderr output deleted ...
- 10q' conftest.err >conftest.er1
- fi
- rm -f conftest.er1 conftest.err
-done
+ $as_echo "$as_me:$LINENO: \$? = $ac_status" >&5
+ (exit $ac_status); }
+{ (ac_try="$ac_compiler -v >&5"
+case "(($ac_try" in
+ *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;;
+ *) ac_try_echo=$ac_try;;
+esac
+ (eval "$ac_compiler -v >&5") 2>&5
+ ac_status=$?
+{ (ac_try="$ac_compiler -V >&5"
+esac
+ (eval "$ac_compiler -V >&5") 2>&5
+ ac_status=$?
+cat >conftest.$ac_ext <<_ACEOF
+/* confdefs.h. */
+_ACEOF
+cat confdefs.h >>conftest.$ac_ext
+cat >>conftest.$ac_ext <<_ACEOF
int
@@ -2580,8 +2310,8 @@ ac_clean_files="$ac_clean_files a.out a.out.dSYM a.exe b.out"
# Try to create an executable without -o first, disregard a.out.
# It will help us diagnose broken compilers, and finding out an intuition
# of exeext.
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether the C compiler works" >&5
-$as_echo_n "checking whether the C compiler works... " >&6; }
+{ $as_echo "$as_me:$LINENO: checking for C compiler default output file name" >&5
+$as_echo_n "checking for C compiler default output file name... " >&6; }
ac_link_default=`$as_echo "$ac_link" | sed 's/ -o *conftest[^ ]*//'`
# The possible output files:
@@ -2597,17 +2327,17 @@ do
done
rm -f $ac_rmfiles
-if { { ac_try="$ac_link_default"
+if { (ac_try="$ac_link_default"
case "(($ac_try" in
esac
(eval "$ac_link_default") 2>&5
ac_status=$?
- test $ac_status = 0; }; then :
+ (exit $ac_status); }; then
# Autoconf-2.13 could set the ac_cv_exeext variable to `no'.
# So ignore a value of `no', otherwise this would lead to `EXEEXT = no'
# in a Makefile. We should not override ac_cv_exeext if it was cached,
@@ -2624,7 +2354,7 @@ do
# certainly right.
break;;
- if test "${ac_cv_exeext+set}" = set && test "$ac_cv_exeext" != no;
+ if test "${ac_cv_exeext+set}" = set && test "$ac_cv_exeext" != no;
then :; else
ac_cv_exeext=`expr "$ac_file" : '[^.]*\(\..*\)'`
fi
@@ -2643,41 +2373,84 @@ test "$ac_cv_exeext" = no && ac_cv_exeext=
else
ac_file=''
fi
-if test -z "$ac_file"; then :
-$as_echo "no" >&6; }
-$as_echo "$as_me: failed program was:" >&5
+{ $as_echo "$as_me:$LINENO: result: $ac_file" >&5
+$as_echo "$ac_file" >&6; }
+if test -z "$ac_file"; then
+ $as_echo "$as_me: failed program was:" >&5
-{ { $as_echo "$as_me:${as_lineno-$LINENO}: error: in \`$ac_pwd':" >&5
+{ { $as_echo "$as_me:$LINENO: error: in \`$ac_pwd':" >&5
-as_fn_error 77 "C compiler cannot create executables
-else
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: yes" >&5
-$as_echo "yes" >&6; }
+{ { $as_echo "$as_me:$LINENO: error: C compiler cannot create executables
+$as_echo "$as_me: error: C compiler cannot create executables
+ { (exit 77); exit 77; }; }; }
fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for C compiler default output file name" >&5
-$as_echo_n "checking for C compiler default output file name... " >&6; }
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_file" >&5
-$as_echo "$ac_file" >&6; }
ac_exeext=$ac_cv_exeext
+# Check that the compiler produces executables we can run. If not, either
+# the compiler is broken, or we cross compile.
+{ $as_echo "$as_me:$LINENO: checking whether the C compiler works" >&5
+$as_echo_n "checking whether the C compiler works... " >&6; }
+# FIXME: These cross compiler hacks should be removed for Autoconf 3.0
+# If not cross compiling, check that we can run a simple program.
+if test "$cross_compiling" != yes; then
+ if { ac_try='./$ac_file'
+ { (case "(($ac_try" in
+esac
+ (eval "$ac_try") 2>&5
+ ac_status=$?
+ (exit $ac_status); }; }; then
+ cross_compiling=no
+ else
+ if test "$cross_compiling" = maybe; then
+ cross_compiling=yes
+ else
+ { { $as_echo "$as_me:$LINENO: error: in \`$ac_pwd':" >&5
+$as_echo "$as_me: error: in \`$ac_pwd':" >&2;}
+{ { $as_echo "$as_me:$LINENO: error: cannot run C compiled programs.
+If you meant to cross compile, use \`--host'.
+$as_echo "$as_me: error: cannot run C compiled programs.
+ fi
+ fi
+fi
+{ $as_echo "$as_me:$LINENO: result: yes" >&5
+$as_echo "yes" >&6; }
rm -f -r a.out a.out.dSYM a.exe conftest$ac_cv_exeext b.out
ac_clean_files=$ac_clean_files_save
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for suffix of executables" >&5
+{ $as_echo "$as_me:$LINENO: checking whether we are cross compiling" >&5
+$as_echo_n "checking whether we are cross compiling... " >&6; }
+{ $as_echo "$as_me:$LINENO: result: $cross_compiling" >&5
+$as_echo "$cross_compiling" >&6; }
+{ $as_echo "$as_me:$LINENO: checking for suffix of executables" >&5
$as_echo_n "checking for suffix of executables... " >&6; }
-if { { ac_try="$ac_link"
+if { (ac_try="$ac_link"
case "(($ac_try" in
esac
ac_status=$?
# If both `conftest.exe' and `conftest' are `present' (well, observable)
# catch `conftest.exe'. For instance with Cygwin, `ls conftest' will
# work properly (i.e., refer to `conftest.exe'), while it won't with
@@ -2692,83 +2465,32 @@ for ac_file in conftest.exe conftest conftest.*; do
esac
done
else
- { { $as_echo "$as_me:${as_lineno-$LINENO}: error: in \`$ac_pwd':" >&5
-as_fn_error $? "cannot compute suffix of executables: cannot compile and link
+{ { $as_echo "$as_me:$LINENO: error: cannot compute suffix of executables: cannot compile and link
+$as_echo "$as_me: error: cannot compute suffix of executables: cannot compile and link
fi
-rm -f conftest conftest$ac_cv_exeext
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_exeext" >&5
+rm -f conftest$ac_cv_exeext
+{ $as_echo "$as_me:$LINENO: result: $ac_cv_exeext" >&5
$as_echo "$ac_cv_exeext" >&6; }
rm -f conftest.$ac_ext
EXEEXT=$ac_cv_exeext
ac_exeext=$EXEEXT
-#include <stdio.h>
-int
-main ()
-FILE *f = fopen ("conftest.out", "w");
- return ferror (f) || fclose (f) != 0;
- return 0;
-_ACEOF
-ac_clean_files="$ac_clean_files conftest.out"
-# Check that the compiler produces executables we can run. If not, either
-# the compiler is broken, or we cross compile.
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether we are cross compiling" >&5
-$as_echo_n "checking whether we are cross compiling... " >&6; }
-if test "$cross_compiling" != yes; then
- { { ac_try="$ac_link"
-esac
- ac_status=$?
- if { ac_try='./conftest$ac_cv_exeext'
-esac
- ac_status=$?
- cross_compiling=no
- else
- if test "$cross_compiling" = maybe; then
- cross_compiling=yes
- else
-as_fn_error $? "cannot run C compiled programs.
-If you meant to cross compile, use \`--host'.
- fi
- fi
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $cross_compiling" >&5
-$as_echo "$cross_compiling" >&6; }
-rm -f conftest.$ac_ext conftest$ac_cv_exeext conftest.out
-ac_clean_files=$ac_clean_files_save
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for suffix of object files" >&5
+{ $as_echo "$as_me:$LINENO: checking for suffix of object files" >&5
$as_echo_n "checking for suffix of object files... " >&6; }
-if ${ac_cv_objext+:} false; then :
+if test "${ac_cv_objext+set}" = set; then
else
+ cat >conftest.$ac_ext <<_ACEOF
+/* confdefs.h. */
+_ACEOF
int
@@ -2780,17 +2502,17 @@ main ()
_ACEOF
rm -f conftest.o conftest.obj
-if { { ac_try="$ac_compile"
+if { (ac_try="$ac_compile"
case "(($ac_try" in
esac
(eval "$ac_compile") 2>&5
ac_status=$?
for ac_file in conftest.o conftest.obj conftest.*; do
test -f "$ac_file" || continue;
case $ac_file in
@@ -2803,23 +2525,31 @@ else
-as_fn_error $? "cannot compute suffix of object files: cannot compile
+{ { $as_echo "$as_me:$LINENO: error: cannot compute suffix of object files: cannot compile
+$as_echo "$as_me: error: cannot compute suffix of object files: cannot compile
fi
rm -f conftest.$ac_cv_objext conftest.$ac_ext
fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_objext" >&5
+{ $as_echo "$as_me:$LINENO: result: $ac_cv_objext" >&5
$as_echo "$ac_cv_objext" >&6; }
OBJEXT=$ac_cv_objext
ac_objext=$OBJEXT
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether we are using the GNU C compiler" >&5
+{ $as_echo "$as_me:$LINENO: checking whether we are using the GNU C compiler" >&5
$as_echo_n "checking whether we are using the GNU C compiler... " >&6; }
-if ${ac_cv_c_compiler_gnu+:} false; then :
+if test "${ac_cv_c_compiler_gnu+set}" = set; then
else
+/* confdefs.h. */
+_ACEOF
int
@@ -2833,16 +2563,37 @@ main ()
return 0;
_ACEOF
+rm -f conftest.$ac_objext
+esac
+ (eval "$ac_compile") 2>conftest.er1
+ ac_status=$?
+ grep -v '^ *+' conftest.er1 >conftest.err
+ rm -f conftest.er1
+ cat conftest.err >&5
+ (exit $ac_status); } && {
+ test -z "$ac_c_werror_flag" ||
+ test ! -s conftest.err
+ } && test -s conftest.$ac_objext; then
ac_compiler_gnu=yes
else
- ac_compiler_gnu=no
+sed 's/^/| /' conftest.$ac_ext >&5
+ ac_compiler_gnu=no
fi
ac_cv_c_compiler_gnu=$ac_compiler_gnu
fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_c_compiler_gnu" >&5
+{ $as_echo "$as_me:$LINENO: result: $ac_cv_c_compiler_gnu" >&5
$as_echo "$ac_cv_c_compiler_gnu" >&6; }
if test $ac_compiler_gnu = yes; then
GCC=yes
@@ -2851,16 +2602,20 @@ else
fi
ac_test_CFLAGS=${CFLAGS+set}
ac_save_CFLAGS=$CFLAGS
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether $CC accepts -g" >&5
+{ $as_echo "$as_me:$LINENO: checking whether $CC accepts -g" >&5
$as_echo_n "checking whether $CC accepts -g... " >&6; }
-if ${ac_cv_prog_cc_g+:} false; then :
+if test "${ac_cv_prog_cc_g+set}" = set; then
else
ac_save_c_werror_flag=$ac_c_werror_flag
ac_c_werror_flag=yes
ac_cv_prog_cc_g=no
CFLAGS="-g"
+/* confdefs.h. */
+_ACEOF
int
@@ -2871,11 +2626,35 @@ main ()
return 0;
_ACEOF
+esac
+ ac_status=$?
ac_cv_prog_cc_g=yes
else
- CFLAGS=""
+ CFLAGS=""
+/* confdefs.h. */
+_ACEOF
int
@@ -2886,12 +2665,36 @@ main ()
return 0;
_ACEOF
+esac
+ ac_status=$?
else
- ac_c_werror_flag=$ac_save_c_werror_flag
+ ac_c_werror_flag=$ac_save_c_werror_flag
CFLAGS="-g"
+/* confdefs.h. */
+_ACEOF
int
@@ -2902,17 +2705,42 @@ main ()
return 0;
_ACEOF
+esac
+ ac_status=$?
ac_cv_prog_cc_g=yes
+else
fi
fi
fi
fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_prog_cc_g" >&5
+{ $as_echo "$as_me:$LINENO: result: $ac_cv_prog_cc_g" >&5
$as_echo "$ac_cv_prog_cc_g" >&6; }
if test "$ac_test_CFLAGS" = set; then
CFLAGS=$ac_save_CFLAGS
@@ -2929,18 +2757,23 @@ else
CFLAGS=
fi
fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for $CC option to accept ISO C89" >&5
+{ $as_echo "$as_me:$LINENO: checking for $CC option to accept ISO C89" >&5
$as_echo_n "checking for $CC option to accept ISO C89... " >&6; }
-if ${ac_cv_prog_cc_c89+:} false; then :
+if test "${ac_cv_prog_cc_c89+set}" = set; then
else
ac_cv_prog_cc_c89=no
ac_save_CC=$CC
+/* confdefs.h. */
+_ACEOF
#include <stdarg.h>
#include <stdio.h>
-struct stat;
+#include <sys/types.h>
+#include <sys/stat.h>
/* Most of the following tests are stolen from RCS 5.7's src/conf.sh. */
struct buf { int x; };
FILE * (*rcsopen) (struct buf *, struct stat *, int);
@@ -2992,9 +2825,32 @@ for ac_arg in '' -qlanglvl=extc89 -qlanglvl=ansi -std \
-Ae "-Aa -D_HPUX_SOURCE" "-Xc -D__EXTENSIONS__"
do
CC="$ac_save_CC $ac_arg"
- if ac_fn_c_try_compile "$LINENO"; then :
+ rm -f conftest.$ac_objext
+esac
+ ac_status=$?
ac_cv_prog_cc_c89=$ac_arg
+else
fi
test "x$ac_cv_prog_cc_c89" != "xno" && break
done
@@ -3005,19 +2861,17 @@ fi
# AC_CACHE_VAL
case "x$ac_cv_prog_cc_c89" in
x)
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: none needed" >&5
+ { $as_echo "$as_me:$LINENO: result: none needed" >&5
$as_echo "none needed" >&6; } ;;
xno)
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: unsupported" >&5
+ { $as_echo "$as_me:$LINENO: result: unsupported" >&5
$as_echo "unsupported" >&6; } ;;
CC="$CC $ac_cv_prog_cc_c89"
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_prog_cc_c89" >&5
+ { $as_echo "$as_me:$LINENO: result: $ac_cv_prog_cc_c89" >&5
$as_echo "$ac_cv_prog_cc_c89" >&6; } ;;
esac
-if test "x$ac_cv_prog_cc_c89" != xno; then :
-fi
ac_ext=c
@@ -3026,7 +2880,11 @@ ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $
+/* confdefs.h. */
+_ACEOF
#include <mpi.h>
int
@@ -3037,15 +2895,38 @@ int ret = MPI_Init(0, (void*)0)
return 0;
_ACEOF
+esac
+ ac_status=$?
+ { $as_echo "$as_me:$LINENO: result: yes" >&5
else
- as_fn_error $? "CC doesn't appear to be a valid MPI compiler. See INSTALL document or try adding CC=mpicc to your configure command line." "$LINENO" 5
+ { { $as_echo "$as_me:$LINENO: error: CC doesn't appear to be a valid MPI compiler. See INSTALL document or try adding CC=mpicc to your configure command line." >&5
+$as_echo "$as_me: error: CC doesn't appear to be a valid MPI compiler. See INSTALL document or try adding CC=mpicc to your configure command line." >&2;}
fi
ac_ext=c
@@ -3053,14 +2934,14 @@ ac_cpp='$CPP $CPPFLAGS'
ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5'
ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking how to run the C preprocessor" >&5
+{ $as_echo "$as_me:$LINENO: checking how to run the C preprocessor" >&5
$as_echo_n "checking how to run the C preprocessor... " >&6; }
# On Suns, sometimes $CPP names a directory.
if test -n "$CPP" && test -d "$CPP"; then
CPP=
fi
if test -z "$CPP"; then
- if ${ac_cv_prog_CPP+:} false; then :
+ if test "${ac_cv_prog_CPP+set}" = set; then
else
# Double quotes because CPP needs to be expanded
@@ -3075,7 +2956,11 @@ do
# <limits.h> exists even on freestanding compilers.
# On the NeXT, cc -E runs the code through the compiler's parser,
# not just through cpp. "Syntax error" is here to catch this case.
+/* confdefs.h. */
+_ACEOF
#ifdef __STDC__
# include <limits.h>
@@ -3084,34 +2969,78 @@ do
#endif
Syntax error
_ACEOF
+if { (ac_try="$ac_cpp conftest.$ac_ext"
+esac
+ (eval "$ac_cpp conftest.$ac_ext") 2>conftest.er1
+ ac_status=$?
+ (exit $ac_status); } >/dev/null && {
+ test -z "$ac_c_preproc_warn_flag$ac_c_werror_flag" ||
+ }; then
else
# Broken: fails on valid input.
continue
fi
+rm -f conftest.err conftest.$ac_ext
# OK, works on sane cases. Now check whether nonexistent headers
# can be detected and how.
+/* confdefs.h. */
+_ACEOF
#include <ac_nonexistent.h>
_ACEOF
+esac
+ ac_status=$?
+ }; then
# Broken: success on invalid input.
continue
else
# Passes both tests.
ac_preproc_ok=:
break
fi
done
# Because of `break', _AC_PREPROC_IFELSE's cleaning code was skipped.
-rm -f conftest.i conftest.err conftest.$ac_ext
-if $ac_preproc_ok; then :
+if $ac_preproc_ok; then
break
fi
@@ -3123,7 +3052,7 @@ fi
else
ac_cv_prog_CPP=$CPP
fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $CPP" >&5
+{ $as_echo "$as_me:$LINENO: result: $CPP" >&5
$as_echo "$CPP" >&6; }
ac_preproc_ok=false
for ac_c_preproc_warn_flag in '' yes
@@ -3134,7 +3063,11 @@ do
+/* confdefs.h. */
+_ACEOF
#ifdef __STDC__
@@ -3143,40 +3076,87 @@ do
#endif
Syntax error
_ACEOF
+esac
+ ac_status=$?
+ }; then
else
continue
fi
+/* confdefs.h. */
+_ACEOF
_ACEOF
+esac
+ ac_status=$?
+ }; then
continue
else
ac_preproc_ok=:
break
fi
done
else
-as_fn_error $? "C preprocessor \"$CPP\" fails sanity check
+{ { $as_echo "$as_me:$LINENO: error: C preprocessor \"$CPP\" fails sanity check
+$as_echo "$as_me: error: C preprocessor \"$CPP\" fails sanity check
fi
ac_ext=c
@@ -3186,9 +3166,9 @@ ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for grep that handles long lines and -e" >&5
+{ $as_echo "$as_me:$LINENO: checking for grep that handles long lines and -e" >&5
$as_echo_n "checking for grep that handles long lines and -e... " >&6; }
-if ${ac_cv_path_GREP+:} false; then :
+if test "${ac_cv_path_GREP+set}" = set; then
else
if test -z "$GREP"; then
@@ -3199,10 +3179,10 @@ for as_dir in $PATH$PATH_SEPARATOR/usr/xpg4/bin
do
IFS=$as_save_IFS
test -z "$as_dir" && as_dir=.
- for ac_prog in grep ggrep; do
+ for ac_prog in grep ggrep; do
ac_path_GREP="$as_dir/$ac_prog$ac_exec_ext"
- as_fn_executable_p "$ac_path_GREP" || continue
+ { test -f "$ac_path_GREP" && $as_test_x "$ac_path_GREP"; } || continue
# Check for GNU ac_path_GREP and select it if it is found.
# Check for GNU $ac_path_GREP
case `"$ac_path_GREP" --version 2>&1` in
@@ -3219,7 +3199,7 @@ case `"$ac_path_GREP" --version 2>&1` in
$as_echo 'GREP' >> "conftest.nl"
"$ac_path_GREP" -e 'GREP$' -e '-(cannot match)-' < "conftest.nl" >"conftest.out" 2>/dev/null || break
diff "conftest.out" "conftest.nl" >/dev/null 2>&1 || break
- as_fn_arith $ac_count + 1 && ac_count=$as_val
+ ac_count=`expr $ac_count + 1`
if test $ac_count -gt ${ac_path_GREP_max-0}; then
# Best one so far, save it but keep looking for a better one
ac_cv_path_GREP="$ac_path_GREP"
@@ -3234,24 +3214,26 @@ esac
$ac_path_GREP_found && break 3
done
done
- done
+done
IFS=$as_save_IFS
if test -z "$ac_cv_path_GREP"; then
- as_fn_error $? "no acceptable grep could be found in $PATH$PATH_SEPARATOR/usr/xpg4/bin" "$LINENO" 5
+ { { $as_echo "$as_me:$LINENO: error: no acceptable grep could be found in $PATH$PATH_SEPARATOR/usr/xpg4/bin" >&5
+$as_echo "$as_me: error: no acceptable grep could be found in $PATH$PATH_SEPARATOR/usr/xpg4/bin" >&2;}
fi
else
ac_cv_path_GREP=$GREP
fi
fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_path_GREP" >&5
+{ $as_echo "$as_me:$LINENO: result: $ac_cv_path_GREP" >&5
$as_echo "$ac_cv_path_GREP" >&6; }
GREP="$ac_cv_path_GREP"
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for egrep" >&5
+{ $as_echo "$as_me:$LINENO: checking for egrep" >&5
$as_echo_n "checking for egrep... " >&6; }
-if ${ac_cv_path_EGREP+:} false; then :
+if test "${ac_cv_path_EGREP+set}" = set; then
else
if echo a | $GREP -E '(a|b)' >/dev/null 2>&1
@@ -3265,10 +3247,10 @@ for as_dir in $PATH$PATH_SEPARATOR/usr/xpg4/bin
do
IFS=$as_save_IFS
- for ac_prog in egrep; do
+ for ac_prog in egrep; do
ac_path_EGREP="$as_dir/$ac_prog$ac_exec_ext"
- as_fn_executable_p "$ac_path_EGREP" || continue
+ { test -f "$ac_path_EGREP" && $as_test_x "$ac_path_EGREP"; } || continue
# Check for GNU ac_path_EGREP and select it if it is found.
# Check for GNU $ac_path_EGREP
case `"$ac_path_EGREP" --version 2>&1` in
@@ -3285,7 +3267,7 @@ case `"$ac_path_EGREP" --version 2>&1` in
$as_echo 'EGREP' >> "conftest.nl"
"$ac_path_EGREP" 'EGREP$' < "conftest.nl" >"conftest.out" 2>/dev/null || break
if test $ac_count -gt ${ac_path_EGREP_max-0}; then
ac_cv_path_EGREP="$ac_path_EGREP"
@@ -3300,10 +3282,12 @@ esac
$ac_path_EGREP_found && break 3
done
done
- done
+done
IFS=$as_save_IFS
if test -z "$ac_cv_path_EGREP"; then
- as_fn_error $? "no acceptable egrep could be found in $PATH$PATH_SEPARATOR/usr/xpg4/bin" "$LINENO" 5
+ { { $as_echo "$as_me:$LINENO: error: no acceptable egrep could be found in $PATH$PATH_SEPARATOR/usr/xpg4/bin" >&5
+$as_echo "$as_me: error: no acceptable egrep could be found in $PATH$PATH_SEPARATOR/usr/xpg4/bin" >&2;}
fi
else
ac_cv_path_EGREP=$EGREP
@@ -3311,17 +3295,21 @@ fi
fi
fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_path_EGREP" >&5
+{ $as_echo "$as_me:$LINENO: result: $ac_cv_path_EGREP" >&5
$as_echo "$ac_cv_path_EGREP" >&6; }
EGREP="$ac_cv_path_EGREP"
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for ANSI C header files" >&5
+{ $as_echo "$as_me:$LINENO: checking for ANSI C header files" >&5
$as_echo_n "checking for ANSI C header files... " >&6; }
-if ${ac_cv_header_stdc+:} false; then :
+if test "${ac_cv_header_stdc+set}" = set; then
else
+/* confdefs.h. */
+_ACEOF
#include <stdlib.h>
#include <stdarg.h>
@@ -3336,23 +3324,48 @@ main ()
return 0;
_ACEOF
+esac
+ ac_status=$?
ac_cv_header_stdc=yes
else
- ac_cv_header_stdc=no
+ ac_cv_header_stdc=no
fi
if test $ac_cv_header_stdc = yes; then
# SunOS 4.x string.h does not declare mem*, contrary to ANSI.
+/* confdefs.h. */
+_ACEOF
#include <string.h>
_ACEOF
if (eval "$ac_cpp conftest.$ac_ext") 2>&5 |
- $EGREP "memchr" >/dev/null 2>&1; then :
+ $EGREP "memchr" >/dev/null 2>&1; then
else
fi
@@ -3362,14 +3375,18 @@ fi
# ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
+/* confdefs.h. */
+_ACEOF
#include <stdlib.h>
_ACEOF
- $EGREP "free" >/dev/null 2>&1; then :
+ $EGREP "free" >/dev/null 2>&1; then
else
fi
@@ -3379,10 +3396,14 @@ fi
# /bin/cc in Irix-4.0.5 gets non-ANSI ctype macros unless using -ansi.
- if test "$cross_compiling" = yes; then :
+ if test "$cross_compiling" = yes; then
else
+/* confdefs.h. */
+_ACEOF
#include <ctype.h>
#include <stdlib.h>
@@ -3409,33 +3430,118 @@ main ()
return 0;
_ACEOF
-if ac_fn_c_try_run "$LINENO"; then :
+rm -f conftest$ac_exeext
+esac
+ (eval "$ac_link") 2>&5
+ ac_status=$?
+ (exit $ac_status); } && { ac_try='./conftest$ac_exeext'
+esac
+ ac_status=$?
else
+ $as_echo "$as_me: program exited with status $ac_status" >&5
+$as_echo "$as_me: failed program was:" >&5
+( exit $ac_status )
+ac_cv_header_stdc=no
fi
-rm -f core *.core core.conftest.* gmon.out bb.out conftest$ac_exeext \
- conftest.$ac_objext conftest.beam conftest.$ac_ext
+rm -rf conftest.dSYM
+rm -f core *.core core.conftest.* gmon.out bb.out conftest$ac_exeext conftest.$ac_objext conftest.$ac_ext
fi
fi
fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_header_stdc" >&5
+{ $as_echo "$as_me:$LINENO: result: $ac_cv_header_stdc" >&5
$as_echo "$ac_cv_header_stdc" >&6; }
-$as_echo "#define STDC_HEADERS 1" >>confdefs.h
+cat >>confdefs.h <<\_ACEOF
+#define STDC_HEADERS 1
+_ACEOF
fi
# On IRIX 5.3, sys/types and inttypes.h are conflicting.
for ac_header in sys/types.h sys/stat.h stdlib.h string.h memory.h strings.h \
inttypes.h stdint.h unistd.h
-do :
- as_ac_Header=`$as_echo "ac_cv_header_$ac_header" | $as_tr_sh`
-ac_fn_c_check_header_compile "$LINENO" "$ac_header" "$as_ac_Header" "$ac_includes_default
-if eval test \"x\$"$as_ac_Header"\" = x"yes"; then :
+do
+as_ac_Header=`$as_echo "ac_cv_header_$ac_header" | $as_tr_sh`
+{ $as_echo "$as_me:$LINENO: checking for $ac_header" >&5
+$as_echo_n "checking for $ac_header... " >&6; }
+if { as_var=$as_ac_Header; eval "test \"\${$as_var+set}\" = set"; }; then
+ $as_echo_n "(cached) " >&6
+else
+/* confdefs.h. */
+_ACEOF
+/* end confdefs.h. */
+$ac_includes_default
+#include <$ac_header>
+_ACEOF
+esac
+ ac_status=$?
+ eval "$as_ac_Header=yes"
+else
+ eval "$as_ac_Header=no"
+fi
+rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext
+fi
+ac_res=`eval 'as_val=${'$as_ac_Header'}
+ $as_echo "$as_val"'`
+ { $as_echo "$as_me:$LINENO: result: $ac_res" >&5
+$as_echo "$ac_res" >&6; }
+as_val=`eval 'as_val=${'$as_ac_Header'}
+ if test "x$as_val" = x""yes; then
#define `$as_echo "HAVE_$ac_header" | $as_tr_cpp` 1
_ACEOF
@@ -3449,7 +3555,7 @@ done
# Check whether --with-zlib was given.
-if test "${with_zlib+set}" = set; then :
+if test "${with_zlib+set}" = set; then
withval=$with_zlib; if test "$withval" != no ; then
if test -d "$withval"
then
@@ -3459,31 +3565,166 @@ if test "${with_zlib+set}" = set; then :
__DARSHAN_ZLIB_LINK_FLAGS="-L${ZLIB_HOME}/lib"
__DARSHAN_ZLIB_INCLUDE_FLAGS="-I${ZLIB_HOME}/include"
else
- { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: Sorry, $withval does not exist, checking usual places" >&5
+ { $as_echo "$as_me:$LINENO: WARNING: Sorry, $withval does not exist, checking usual places" >&5
$as_echo "$as_me: WARNING: Sorry, $withval does not exist, checking usual places" >&2;}
fi
else
- as_fn_error $? "zlib is required" "$LINENO" 5
+ { { $as_echo "$as_me:$LINENO: error: zlib is required" >&5
+$as_echo "$as_me: error: zlib is required" >&2;}
+fi
+fi
+if test "${ac_cv_header_zlib_h+set}" = set; then
+ { $as_echo "$as_me:$LINENO: checking for zlib.h" >&5
+$as_echo_n "checking for zlib.h... " >&6; }
+fi
+{ $as_echo "$as_me:$LINENO: result: $ac_cv_header_zlib_h" >&5
+$as_echo "$ac_cv_header_zlib_h" >&6; }
+else
+ # Is the header compilable?
+{ $as_echo "$as_me:$LINENO: checking zlib.h usability" >&5
+$as_echo_n "checking zlib.h usability... " >&6; }
+/* confdefs.h. */
+_ACEOF
+#include <zlib.h>
+_ACEOF
+esac
+ ac_status=$?
+ ac_header_compiler=yes
+else
+ ac_header_compiler=no
fi
+{ $as_echo "$as_me:$LINENO: result: $ac_header_compiler" >&5
+$as_echo "$ac_header_compiler" >&6; }
+# Is the header present?
+{ $as_echo "$as_me:$LINENO: checking zlib.h presence" >&5
+$as_echo_n "checking zlib.h presence... " >&6; }
+/* confdefs.h. */
+_ACEOF
+#include <zlib.h>
+_ACEOF
+esac
+ ac_status=$?
+ }; then
+ ac_header_preproc=yes
+else
+ ac_header_preproc=no
fi
+{ $as_echo "$as_me:$LINENO: result: $ac_header_preproc" >&5
+$as_echo "$ac_header_preproc" >&6; }
+# So? What about this header?
+case $ac_header_compiler:$ac_header_preproc:$ac_c_preproc_warn_flag in
+ yes:no: )
+ { $as_echo "$as_me:$LINENO: WARNING: zlib.h: accepted by the compiler, rejected by the preprocessor!" >&5
+$as_echo "$as_me: WARNING: zlib.h: accepted by the compiler, rejected by the preprocessor!" >&2;}
+ { $as_echo "$as_me:$LINENO: WARNING: zlib.h: proceeding with the compiler's result" >&5
+$as_echo "$as_me: WARNING: zlib.h: proceeding with the compiler's result" >&2;}
+ no:yes:* )
+ { $as_echo "$as_me:$LINENO: WARNING: zlib.h: present but cannot be compiled" >&5
+$as_echo "$as_me: WARNING: zlib.h: present but cannot be compiled" >&2;}
+ { $as_echo "$as_me:$LINENO: WARNING: zlib.h: check for missing prerequisite headers?" >&5
+$as_echo "$as_me: WARNING: zlib.h: check for missing prerequisite headers?" >&2;}
+ { $as_echo "$as_me:$LINENO: WARNING: zlib.h: see the Autoconf documentation" >&5
+$as_echo "$as_me: WARNING: zlib.h: see the Autoconf documentation" >&2;}
+ { $as_echo "$as_me:$LINENO: WARNING: zlib.h: section \"Present But Cannot Be Compiled\"" >&5
+$as_echo "$as_me: WARNING: zlib.h: section \"Present But Cannot Be Compiled\"" >&2;}
+ { $as_echo "$as_me:$LINENO: WARNING: zlib.h: proceeding with the preprocessor's result" >&5
+$as_echo "$as_me: WARNING: zlib.h: proceeding with the preprocessor's result" >&2;}
+ { $as_echo "$as_me:$LINENO: WARNING: zlib.h: in the future, the compiler will take precedence" >&5
+$as_echo "$as_me: WARNING: zlib.h: in the future, the compiler will take precedence" >&2;}
-ac_fn_c_check_header_mongrel "$LINENO" "zlib.h" "ac_cv_header_zlib_h" "$ac_includes_default"
-if test "x$ac_cv_header_zlib_h" = xyes; then :
+esac
+{ $as_echo "$as_me:$LINENO: checking for zlib.h" >&5
+else
+ ac_cv_header_zlib_h=$ac_header_preproc
+fi
+fi
+if test "x$ac_cv_header_zlib_h" = x""yes; then
else
- as_fn_error $? "z.h not found" "$LINENO" 5
+ { { $as_echo "$as_me:$LINENO: error: z.h not found" >&5
+$as_echo "$as_me: error: z.h not found" >&2;}
fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for inflateEnd in -lz" >&5
+{ $as_echo "$as_me:$LINENO: checking for inflateEnd in -lz" >&5
$as_echo_n "checking for inflateEnd in -lz... " >&6; }
-if ${ac_cv_lib_z_inflateEnd+:} false; then :
+if test "${ac_cv_lib_z_inflateEnd+set}" = set; then
else
ac_check_lib_save_LIBS=$LIBS
LIBS="-lz $LIBS"
+/* confdefs.h. */
+_ACEOF
/* Override any GCC internal prototype to avoid an error.
@@ -3501,18 +3742,43 @@ return inflateEnd ();
return 0;
_ACEOF
-if ac_fn_c_try_link "$LINENO"; then :
+rm -f conftest.$ac_objext conftest$ac_exeext
+esac
+ (eval "$ac_link") 2>conftest.er1
+ ac_status=$?
+ } && test -s conftest$ac_exeext && {
+ test "$cross_compiling" = yes ||
+ $as_test_x conftest$ac_exeext
+ }; then
ac_cv_lib_z_inflateEnd=yes
else
- ac_cv_lib_z_inflateEnd=no
+ ac_cv_lib_z_inflateEnd=no
fi
-rm -f core conftest.err conftest.$ac_objext \
- conftest$ac_exeext conftest.$ac_ext
+rm -f core conftest.err conftest.$ac_objext conftest_ipa8_conftest.oo \
+ conftest$ac_exeext conftest.$ac_ext
LIBS=$ac_check_lib_save_LIBS
fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_lib_z_inflateEnd" >&5
+{ $as_echo "$as_me:$LINENO: result: $ac_cv_lib_z_inflateEnd" >&5
$as_echo "$ac_cv_lib_z_inflateEnd" >&6; }
-if test "x$ac_cv_lib_z_inflateEnd" = xyes; then :
+if test "x$ac_cv_lib_z_inflateEnd" = x""yes; then
#define HAVE_LIBZ 1
_ACEOF
@@ -3520,17 +3786,21 @@ _ACEOF
LIBS="-lz $LIBS"
else
- as_fn_error $? "libz not found" "$LINENO" 5
+ { { $as_echo "$as_me:$LINENO: error: libz not found" >&5
+$as_echo "$as_me: error: libz not found" >&2;}
fi
# Check whether --enable-cuserid was given.
-if test "${enable_cuserid+set}" = set; then :
+if test "${enable_cuserid+set}" = set; then
enableval=$enable_cuserid; if test "x$enableval" = "xno" ; then
-$as_echo "#define DARSHAN_DISABLE_CUSERID 1" >>confdefs.h
+#define DARSHAN_DISABLE_CUSERID 1
+_ACEOF
fi
@@ -3538,7 +3808,7 @@ fi
# Check whether --enable-ld-preload was given.
-if test "${enable_ld_preload+set}" = set; then :
+if test "${enable_ld_preload+set}" = set; then
enableval=$enable_ld_preload; if test "x$enableval" = "xno" ; then
DISABLE_LDPRELOAD="1"
fi
@@ -3547,10 +3817,12 @@ fi
# Check whether --enable-group-readable-logs was given.
-if test "${enable_group_readable_logs+set}" = set; then :
+if test "${enable_group_readable_logs+set}" = set; then
enableval=$enable_group_readable_logs; if test "x$enableval" = "xyes" ; then
-$as_echo "#define __DARSHAN_GROUP_READABLE_LOGS 1" >>confdefs.h
+#define __DARSHAN_GROUP_READABLE_LOGS 1
+_ACEOF
fi
@@ -3559,9 +3831,11 @@ fi
# Check whether --with-mem-align was given.
-if test "${with_mem_align+set}" = set; then :
+if test "${with_mem_align+set}" = set; then
withval=$with_mem_align; if test x$withval = xyes; then
- as_fn_error $? "--with-mem-align must be given a number in bytes" "$LINENO" 5
+ { { $as_echo "$as_me:$LINENO: error: --with-mem-align must be given a number in bytes" >&5
+$as_echo "$as_me: error: --with-mem-align must be given a number in bytes" >&2;}
else
@@ -3576,9 +3850,11 @@ fi
# Check whether --with-log-path-by-env was given.
-if test "${with_log_path_by_env+set}" = set; then :
+if test "${with_log_path_by_env+set}" = set; then
withval=$with_log_path_by_env; if test x$withval = xyes; then
- as_fn_error $? "--with-log-path-by-env must be given at least one variable name" "$LINENO" 5
+ { { $as_echo "$as_me:$LINENO: error: --with-log-path-by-env must be given at least one variable name" >&5
+$as_echo "$as_me: error: --with-log-path-by-env must be given at least one variable name" >&2;}
else
@@ -3594,9 +3870,11 @@ fi
# Check whether --with-log-hints was given.
-if test "${with_log_hints+set}" = set; then :
+if test "${with_log_hints+set}" = set; then
withval=$with_log_hints; if test x$withval = xyes; then
- as_fn_error $? "--with-log-hints must be given an argument" "$LINENO" 5
+ { { $as_echo "$as_me:$LINENO: error: --with-log-hints must be given an argument" >&5
+$as_echo "$as_me: error: --with-log-hints must be given an argument" >&2;}
else
@@ -3612,9 +3890,11 @@ fi
# Check whether --with-log-path was given.
-if test "${with_log_path+set}" = set; then :
+if test "${with_log_path+set}" = set; then
withval=$with_log_path; if test x$withval = xyes; then
- as_fn_error $? "--with-log-path must be given a pathname" "$LINENO" 5
+ { { $as_echo "$as_me:$LINENO: error: --with-log-path must be given a pathname" >&5
+$as_echo "$as_me: error: --with-log-path must be given a pathname" >&2;}
else
@@ -3630,9 +3910,11 @@ fi
# Check whether --with-jobid-env was given.
-if test "${with_jobid_env+set}" = set; then :
+if test "${with_jobid_env+set}" = set; then
withval=$with_jobid_env; if test x$withval = xyes; then
- as_fn_error $? "--with-jobid-env must be given a name" "$LINENO" 5
+ { { $as_echo "$as_me:$LINENO: error: --with-jobid-env must be given a name" >&5
+$as_echo "$as_me: error: --with-jobid-env must be given a name" >&2;}
else
@@ -3647,13 +3929,19 @@ fi
if test x$GOT_ALIGNMENT != x1; then
- as_fn_error $? "must provide --with-mem-align=<num> argument to configure." "$LINENO" 5
+ { { $as_echo "$as_me:$LINENO: error: must provide --with-mem-align=<num> argument to configure." >&5
+$as_echo "$as_me: error: must provide --with-mem-align=<num> argument to configure." >&2;}
fi
if test x$GOT_LOG_PATH != x1; then
- as_fn_error $? "must provide --with-log-path=<path> _or_ --with-log-path-by-env=<variable list> argument to configure." "$LINENO" 5
+ { { $as_echo "$as_me:$LINENO: error: must provide --with-log-path=<path> _or_ --with-log-path-by-env=<variable list> argument to configure." >&5
+$as_echo "$as_me: error: must provide --with-log-path=<path> _or_ --with-log-path-by-env=<variable list> argument to configure." >&2;}
fi
if test x$GOT_JOBID != x1; then
- as_fn_error $? "must provide --with-jobid-env=<name> argument to configure." "$LINENO" 5
+ { { $as_echo "$as_me:$LINENO: error: must provide --with-jobid-env=<name> argument to configure." >&5
+$as_echo "$as_me: error: must provide --with-jobid-env=<name> argument to configure." >&2;}
fi
__DARSHAN_LOG_HINTS_DEFAULT="romio_no_indep_rw=true;cb_nodes=4"
if test x$GOT_LOG_HINTS != x1; then
@@ -3666,12 +3954,146 @@ fi
# checks to see how we can print 64 bit values on this architecture
- for ac_header in inttypes.h
-do :
- ac_fn_c_check_header_mongrel "$LINENO" "inttypes.h" "ac_cv_header_inttypes_h" "$ac_includes_default"
-if test "x$ac_cv_header_inttypes_h" = xyes; then :
+for ac_header in inttypes.h
+do
+ { $as_echo "$as_me:$LINENO: checking for $ac_header" >&5
+fi
+else
+{ $as_echo "$as_me:$LINENO: checking $ac_header usability" >&5
+$as_echo_n "checking $ac_header usability... " >&6; }
+/* confdefs.h. */
+_ACEOF
+_ACEOF
+esac
+ ac_status=$?
+else
+fi
+{ $as_echo "$as_me:$LINENO: checking $ac_header presence" >&5
+$as_echo_n "checking $ac_header presence... " >&6; }
+/* confdefs.h. */
+_ACEOF
+_ACEOF
+esac
+ ac_status=$?
+ }; then
+else
+fi
+ yes:no: )
+ { $as_echo "$as_me:$LINENO: WARNING: $ac_header: accepted by the compiler, rejected by the preprocessor!" >&5
+$as_echo "$as_me: WARNING: $ac_header: accepted by the compiler, rejected by the preprocessor!" >&2;}
+ { $as_echo "$as_me:$LINENO: WARNING: $ac_header: proceeding with the compiler's result" >&5
+$as_echo "$as_me: WARNING: $ac_header: proceeding with the compiler's result" >&2;}
+ no:yes:* )
+ { $as_echo "$as_me:$LINENO: WARNING: $ac_header: present but cannot be compiled" >&5
+$as_echo "$as_me: WARNING: $ac_header: present but cannot be compiled" >&2;}
+ { $as_echo "$as_me:$LINENO: WARNING: $ac_header: check for missing prerequisite headers?" >&5
+$as_echo "$as_me: WARNING: $ac_header: check for missing prerequisite headers?" >&2;}
+ { $as_echo "$as_me:$LINENO: WARNING: $ac_header: see the Autoconf documentation" >&5
+$as_echo "$as_me: WARNING: $ac_header: see the Autoconf documentation" >&2;}
+ { $as_echo "$as_me:$LINENO: WARNING: $ac_header: section \"Present But Cannot Be Compiled\"" >&5
+$as_echo "$as_me: WARNING: $ac_header: section \"Present But Cannot Be Compiled\"" >&2;}
+ { $as_echo "$as_me:$LINENO: WARNING: $ac_header: proceeding with the preprocessor's result" >&5
+$as_echo "$as_me: WARNING: $ac_header: proceeding with the preprocessor's result" >&2;}
+ { $as_echo "$as_me:$LINENO: WARNING: $ac_header: in the future, the compiler will take precedence" >&5
+$as_echo "$as_me: WARNING: $ac_header: in the future, the compiler will take precedence" >&2;}
+esac
+else
+ eval "$as_ac_Header=\$ac_header_preproc"
+fi
+fi
-#define HAVE_INTTYPES_H 1
+#define `$as_echo "HAVE_$ac_header" | $as_tr_cpp` 1
_ACEOF
fi
@@ -3679,13 +4101,17 @@ fi
done
if test $ac_cv_header_inttypes_h = yes; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking whether the inttypes.h PRIxNN macros are broken" >&5
+ { $as_echo "$as_me:$LINENO: checking whether the inttypes.h PRIxNN macros are broken" >&5
$as_echo_n "checking whether the inttypes.h PRIxNN macros are broken... " >&6; }
-if ${gt_cv_inttypes_pri_broken+:} false; then :
+if test "${gt_cv_inttypes_pri_broken+set}" = set; then
else
+/* confdefs.h. */
+_ACEOF
#include <inttypes.h>
#ifdef PRId32
@@ -3700,15 +4126,36 @@ main ()
return 0;
_ACEOF
+esac
+ ac_status=$?
gt_cv_inttypes_pri_broken=no
else
- gt_cv_inttypes_pri_broken=yes
+ gt_cv_inttypes_pri_broken=yes
fi
fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $gt_cv_inttypes_pri_broken" >&5
+{ $as_echo "$as_me:$LINENO: result: $gt_cv_inttypes_pri_broken" >&5
$as_echo "$gt_cv_inttypes_pri_broken" >&6; }
fi
if test "$gt_cv_inttypes_pri_broken" = yes; then
@@ -3724,32 +4171,175 @@ _ACEOF
if test x$PRI_MACROS_BROKEN == xyes; then
- as_fn_error $? "PRI_xx macros are broken" "$LINENO" 5
+ { { $as_echo "$as_me:$LINENO: error: PRI_xx macros are broken" >&5
+$as_echo "$as_me: error: PRI_xx macros are broken" >&2;}
+else
+do
+fi
+else
+/* confdefs.h. */
+_ACEOF
+_ACEOF
+esac
+ ac_status=$?
+else
+fi
+/* confdefs.h. */
+_ACEOF
+_ACEOF
+esac
+ ac_status=$?
+ }; then
+else
+fi
+ yes:no: )
+ no:yes:* )
+esac
else
-do :
+fi
+fi
_ACEOF
else
- as_fn_error $? "Couldn't find inttypes.h" "$LINENO" 5
+ { { $as_echo "$as_me:$LINENO: error: Couldn't find inttypes.h" >&5
+$as_echo "$as_me: error: Couldn't find inttypes.h" >&2;}
fi
done
fi
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking whether byte ordering is bigendian" >&5
+ { $as_echo "$as_me:$LINENO: checking whether byte ordering is bigendian" >&5
$as_echo_n "checking whether byte ordering is bigendian... " >&6; }
-if ${ac_cv_c_bigendian+:} false; then :
+if test "${ac_cv_c_bigendian+set}" = set; then
else
ac_cv_c_bigendian=unknown
# See if we're dealing with a universal compiler.
+/* confdefs.h. */
+_ACEOF
#ifndef __APPLE_CC__
not a universal capable compiler
@@ -3757,34 +4347,46 @@ else
typedef int dummy;
_ACEOF
+esac
+ ac_status=$?
# Check for potential -arch flags. It is not universal unless
- # there are at least two -arch flags with different values.
- ac_arch=
- ac_prev=
- for ac_word in $CC $CFLAGS $CPPFLAGS $LDFLAGS; do
- if test -n "$ac_prev"; then
- case $ac_word in
- i?86 | x86_64 | ppc | ppc64)
- if test -z "$ac_arch" || test "$ac_arch" = "$ac_word"; then
- ac_arch=$ac_word
- else
- ac_cv_c_bigendian=universal
- break
- fi
- esac
- ac_prev=
- elif test "x$ac_word" = "x-arch"; then
- ac_prev=arch
- fi
- done
+ # there are some -arch flags. Note that *ppc* also matches
+ # ppc64. This check is also rather less than ideal.
+ case "${CC} ${CFLAGS} ${CPPFLAGS} ${LDFLAGS}" in #(
+ *-arch*ppc*|*-arch*i386*|*-arch*x86_64*) ac_cv_c_bigendian=universal;;
+ esac
+else
fi
if test $ac_cv_c_bigendian = unknown; then
# See if sys/param.h defines the BYTE_ORDER macro.
+/* confdefs.h. */
+_ACEOF
#include <sys/param.h>
@@ -3802,9 +4404,30 @@ main ()
return 0;
_ACEOF
+esac
+ ac_status=$?
# It does; now see whether it defined to BIG_ENDIAN or not.
+/* confdefs.h. */
+_ACEOF
@@ -3820,18 +4443,49 @@ main ()
return 0;
_ACEOF
+esac
+ ac_status=$?
ac_cv_c_bigendian=yes
else
- ac_cv_c_bigendian=no
+ ac_cv_c_bigendian=no
fi
+else
fi
fi
# See if <limits.h> defines _LITTLE_ENDIAN or _BIG_ENDIAN (e.g., Solaris).
+/* confdefs.h. */
+_ACEOF
#include <limits.h>
@@ -3846,9 +4500,30 @@ main ()
return 0;
_ACEOF
+esac
+ ac_status=$?
# It does; now see whether it defined to _BIG_ENDIAN or not.
+/* confdefs.h. */
+_ACEOF
#include <limits.h>
@@ -3863,20 +4538,51 @@ main ()
return 0;
_ACEOF
+esac
+ ac_status=$?
else
fi
+else
fi
fi
# Compile a test program.
# Try to guess by grepping values from an object file.
+/* confdefs.h. */
+_ACEOF
short int ascii_mm[] =
{ 0x4249, 0x4765, 0x6E44, 0x6961, 0x6E53, 0x7953, 0 };
@@ -3902,7 +4608,24 @@ return use_ascii (foo) == use_ebcdic (foo);
return 0;
_ACEOF
-if ac_fn_c_try_compile "$LINENO"; then :
+esac
+ ac_status=$?
if grep BIGenDianSyS conftest.$ac_objext >/dev/null; then
fi
@@ -3914,10 +4637,20 @@ if ac_fn_c_try_compile "$LINENO"; then :
fi
fi
+else
fi
else
+/* confdefs.h. */
+_ACEOF
int
@@ -3937,41 +4670,79 @@ main ()
return 0;
_ACEOF
+esac
+ ac_status=$?
+esac
+ ac_status=$?
else
- ac_cv_c_bigendian=yes
+ac_cv_c_bigendian=yes
fi
fi
fi
fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_c_bigendian" >&5
+{ $as_echo "$as_me:$LINENO: result: $ac_cv_c_bigendian" >&5
$as_echo "$ac_cv_c_bigendian" >&6; }
case $ac_cv_c_bigendian in #(
yes)
- $as_echo "#define WORDS_BIGENDIAN 1" >>confdefs.h
+ cat >>confdefs.h <<\_ACEOF
+#define WORDS_BIGENDIAN 1
+_ACEOF
no)
universal)
-$as_echo "#define AC_APPLE_UNIVERSAL_BUILD 1" >>confdefs.h
+#define AC_APPLE_UNIVERSAL_BUILD 1
+_ACEOF
- as_fn_error $? "unknown endianness
- presetting ac_cv_c_bigendian=no (or yes) will help" "$LINENO" 5 ;;
+ { { $as_echo "$as_me:$LINENO: error: unknown endianness
+ presetting ac_cv_c_bigendian=no (or yes) will help" >&5
+$as_echo "$as_me: error: unknown endianness
+ presetting ac_cv_c_bigendian=no (or yes) will help" >&2;}
+ { (exit 1); exit 1; }; } ;;
esac
old_cflags="$CFLAGS"
CFLAGS="$CFLAGS -D_FILE_OFFSET_BITS=64 -D_LARGEFILE64_SOURCE"
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for struct aiocb64" >&5
+{ $as_echo "$as_me:$LINENO: checking for struct aiocb64" >&5
$as_echo_n "checking for struct aiocb64... " >&6; }
-cat confdefs.h - <<_ACEOF >conftest.$ac_ext
+/* confdefs.h. */
+_ACEOF
#include <aio.h>
@@ -3984,25 +4755,52 @@ main ()
return 0;
_ACEOF
+esac
+ ac_status=$?
-$as_echo "#define HAVE_AIOCB64 1" >>confdefs.h
+#define HAVE_AIOCB64 1
+_ACEOF
else
fi
CFLAGS="$old_cflags"
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for off64_t" >&5
+{ $as_echo "$as_me:$LINENO: checking for off64_t" >&5
$as_echo_n "checking for off64_t... " >&6; }
+/* confdefs.h. */
+_ACEOF
#include <stdio.h>
@@ -4029,25 +4827,182 @@ main ()
return 0;
_ACEOF
+esac
+ ac_status=$?
-$as_echo "#define HAVE_OFF64_T 1" >>confdefs.h
+#define HAVE_OFF64_T 1
+_ACEOF
else
fi
for ac_header in mntent.h sys/mount.h
-do :
-ac_fn_c_check_header_mongrel "$LINENO" "$ac_header" "$as_ac_Header" "$ac_includes_default"
+do
+fi
+else
+/* confdefs.h. */
+_ACEOF
+_ACEOF
+esac
+ ac_status=$?
+else
+fi
+/* confdefs.h. */
+_ACEOF
+_ACEOF
+esac
+ ac_status=$?
+ }; then
+else
+fi
+ yes:no: )
+ no:yes:* )
+esac
+else
+fi
+fi
_ACEOF
@@ -4077,9 +5032,13 @@ prefix=$savePrefix
exec_prefix=$saveExecprefix
# determine if the MPI library includes MPI-IO functions or not
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for MPI-IO support in MPI" >&5
+{ $as_echo "$as_me:$LINENO: checking for MPI-IO support in MPI" >&5
$as_echo_n "checking for MPI-IO support in MPI... " >&6; }
+/* confdefs.h. */
+_ACEOF
#include <mpi.h>
int
@@ -4097,22 +5056,53 @@ main ()
return 0;
_ACEOF
+esac
+ ac_status=$?
+ }; then
else
- as_fn_error $? "Darshan requires a version of MPI with MPI-IO support" "$LINENO" 5
+ { { $as_echo "$as_me:$LINENO: error: Darshan requires a version of MPI with MPI-IO support" >&5
+$as_echo "$as_me: error: Darshan requires a version of MPI with MPI-IO support" >&2;}
fi
# At some point MPI-IO converted most API functions to be const correct. We
# need to test for this to determine how to define MPI-IO wrappers in
# Darshan. First we try compiling without cost qualifiers.
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for MPI-IO prototypes without const qualifier" >&5
+{ $as_echo "$as_me:$LINENO: checking for MPI-IO prototypes without const qualifier" >&5
$as_echo_n "checking for MPI-IO prototypes without const qualifier... " >&6; }
+/* confdefs.h. */
+_ACEOF
#include <mpi.h>
@@ -4128,18 +5118,42 @@ main ()
return 0;
_ACEOF
+esac
+ ac_status=$?
else
# unable to compile without const qualifiers. Let's try again with
# const qualifiers.
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking for MPI-IO prototypes with const qualifier" >&5
+ { $as_echo "$as_me:$LINENO: checking for MPI-IO prototypes with const qualifier" >&5
$as_echo_n "checking for MPI-IO prototypes with const qualifier... " >&6; }
- cat confdefs.h - <<_ACEOF >conftest.$ac_ext
+/* confdefs.h. */
+_ACEOF
#include <mpi.h>
@@ -4155,16 +5169,42 @@ main ()
return 0;
_ACEOF
+esac
+ ac_status=$?
-$as_echo "#define HAVE_MPIIO_CONST 1" >>confdefs.h
+#define HAVE_MPIIO_CONST 1
+_ACEOF
+else
fi
fi
# determine if mpicc can create shared libraries that use MPI functions
@@ -4172,9 +5212,13 @@ old_cflags="$CFLAGS"
CFLAGS="$CFLAGS -shared -fpic -DPIC"
old_libs="$LIBS"
LIBS="$LIBS -ldl"
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for shared libraries in MPI" >&5
+{ $as_echo "$as_me:$LINENO: checking for shared libraries in MPI" >&5
$as_echo_n "checking for shared libraries in MPI... " >&6; }
+/* confdefs.h. */
+_ACEOF
#include <mpi.h>
int
@@ -4188,19 +5232,44 @@ main ()
return 0;
_ACEOF
+esac
+ ac_status=$?
+ }; then
else
- { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: mpicc doesn't support shared objects; disabling LD_PRELOAD library" >&5
+ { $as_echo "$as_me:$LINENO: WARNING: mpicc doesn't support shared objects; disabling LD_PRELOAD library" >&5
$as_echo "$as_me: WARNING: mpicc doesn't support shared objects; disabling LD_PRELOAD library" >&2;}
fi
LIBS="$old_libs"
@@ -4209,37 +5278,136 @@ LIBS="$old_libs"
# for MPI 1.x implementations that did not use generalized requests yet in
# MPI-IO. Later MPI implementations might typedef MPIO_Request to MPI_Request
# so there is no harm in using the former if it is available there.
-ac_fn_c_check_type "$LINENO" "MPIO_Request" "ac_cv_type_MPIO_Request" "#include <mpi.h>
-if test "x$ac_cv_type_MPIO_Request" = xyes; then :
+{ $as_echo "$as_me:$LINENO: checking for MPIO_Request" >&5
+$as_echo_n "checking for MPIO_Request... " >&6; }
+if test "${ac_cv_type_MPIO_Request+set}" = set; then
+else
+ ac_cv_type_MPIO_Request=no
+/* confdefs.h. */
+_ACEOF
+#include <mpi.h>
-$as_echo "#define __D_MPI_REQUEST MPIO_Request" >>confdefs.h
+int
+main ()
+if (sizeof (MPIO_Request))
+ return 0;
+ return 0;
+_ACEOF
+esac
+ ac_status=$?
+/* confdefs.h. */
+_ACEOF
+#include <mpi.h>
+int
+main ()
+if (sizeof ((MPIO_Request)))
+ return 0;
+ return 0;
+_ACEOF
+esac
+ ac_status=$?
+else
+ ac_cv_type_MPIO_Request=yes
+fi
else
-$as_echo "#define __D_MPI_REQUEST MPI_Request" >>confdefs.h
+fi
+fi
+{ $as_echo "$as_me:$LINENO: result: $ac_cv_type_MPIO_Request" >&5
+$as_echo "$ac_cv_type_MPIO_Request" >&6; }
+if test "x$ac_cv_type_MPIO_Request" = x""yes; then
+#define __D_MPI_REQUEST MPIO_Request
+_ACEOF
+else
+#define __D_MPI_REQUEST MPI_Request
+_ACEOF
fi
# attempt to detect librarly naming convention in mpi compiler script
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for old (pre-3.1.1) style MPICH library naming convention" >&5
+{ $as_echo "$as_me:$LINENO: checking for old (pre-3.1.1) style MPICH library naming convention" >&5
$as_echo_n "checking for old (pre-3.1.1) style MPICH library naming convention... " >&6; }
-if $CC -show foo.c -o foo |grep lmpich >& /dev/null; then :
+if $CC -show foo.c -o foo |grep lmpich >& /dev/null; then
MPICH_LIB_OLD=1
else
MPICH_LIB_OLD=0
fi
# check to see whether the bgq instrumentation module should be built
# Check whether --enable-bgq_mod was given.
-if test "${enable_bgq_mod+set}" = set; then :
+if test "${enable_bgq_mod+set}" = set; then
enableval=$enable_bgq_mod;
else
enable_bgq_mod=check
@@ -4247,9 +5415,13 @@ else
fi
if test x$enable_bgq_mod != xno; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking for BG/Q environment" >&5
+ { $as_echo "$as_me:$LINENO: checking for BG/Q environment" >&5
$as_echo_n "checking for BG/Q environment... " >&6; }
+/* confdefs.h. */
+_ACEOF
#ifndef __bgq__
@@ -4264,19 +5436,41 @@ main ()
return 0;
_ACEOF
+esac
+ ac_status=$?
DARSHAN_USE_BGQ=1
else
- if
- test "x$enable_bgq_mod" = xyes; then :
- as_fn_error $? "BG/Q module enabled in non-BG/Q environment" "$LINENO" 5
+ if test "x$enable_bgq_mod" = xyes; then
+ { { $as_echo "$as_me:$LINENO: error: BG/Q module enabled in non-BG/Q environment" >&5
+$as_echo "$as_me: error: BG/Q module enabled in non-BG/Q environment" >&2;}
fi
fi
fi
@@ -4319,13 +5513,13 @@ _ACEOF
case $ac_val in #(
*${as_nl}*)
case $ac_var in #(
- *_cv_*) { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: cache variable $ac_var contains a newline" >&5
+ *_cv_*) { $as_echo "$as_me:$LINENO: WARNING: cache variable $ac_var contains a newline" >&5
$as_echo "$as_me: WARNING: cache variable $ac_var contains a newline" >&2;} ;;
esac
case $ac_var in #(
_ | IFS | as_nl) ;; #(
BASH_ARGV | BASH_SOURCE) eval $ac_var= ;; #(
- *) { eval $ac_var=; unset $ac_var;} ;;
+ *) $as_unset $ac_var ;;
esac ;;
esac
done
@@ -4333,8 +5527,8 @@ $as_echo "$as_me: WARNING: cache variable $ac_var contains a newline" >&2;} ;;
(set) 2>&1 |
case $as_nl`(ac_space=' '; set) 2>&1` in #(
*${as_nl}ac_space=\ *)
- # `set' does not quote correctly, so add quotes: double-quote
- # substitution turns \\\\ into \\, and sed turns \\ into \.
+ # `set' does not quote correctly, so add quotes (double-quote
+ # substitution turns \\\\ into \\, and sed turns \\ into \).
sed -n \
"s/'/'\\\\''/g;
s/^\\([_$as_cr_alnum]*_cv_[_$as_cr_alnum]*\\)=\\(.*\\)/\\1='\\2'/p"
@@ -4356,23 +5550,12 @@ $as_echo "$as_me: WARNING: cache variable $ac_var contains a newline" >&2;} ;;
:end' >>confcache
if diff "$cache_file" confcache >/dev/null 2>&1; then :; else
if test -w "$cache_file"; then
- if test "x$cache_file" != "x/dev/null"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: updating cache $cache_file" >&5
+ test "x$cache_file" != "x/dev/null" &&
+ { $as_echo "$as_me:$LINENO: updating cache $cache_file" >&5
$as_echo "$as_me: updating cache $cache_file" >&6;}
- if test ! -f "$cache_file" || test -h "$cache_file"; then
- cat confcache >"$cache_file"
- else
- case $cache_file in #(
- mv -f confcache "$cache_file"$$ &&
- mv -f "$cache_file"$$ "$cache_file" ;; #(
- mv -f confcache "$cache_file" ;;
- esac
- fi
- fi
+ cat confcache >$cache_file
else
- { $as_echo "$as_me:${as_lineno-$LINENO}: not updating unwritable cache $cache_file" >&5
+ { $as_echo "$as_me:$LINENO: not updating unwritable cache $cache_file" >&5
$as_echo "$as_me: not updating unwritable cache $cache_file" >&6;}
fi
fi
@@ -4386,15 +5569,14 @@ DEFS=-DHAVE_CONFIG_H
ac_libobjs=
ac_ltlibobjs=
-U=
for ac_i in : $LIBOBJS; do test "x$ac_i" = x: && continue
# 1. Remove the extension, and $U if already installed.
ac_script='s/\$U\././;s/\.o$//;s/\.obj$//'
ac_i=`$as_echo "$ac_i" | sed "$ac_script"`
# 2. Prepend LIBOBJDIR. When used with automake>=1.10 LIBOBJDIR
# will be set to the directory where LIBOBJS objects are built.
- as_fn_append ac_libobjs " \${LIBOBJDIR}$ac_i\$U.$ac_objext"
- as_fn_append ac_ltlibobjs " \${LIBOBJDIR}$ac_i"'$U.lo'
+ ac_libobjs="$ac_libobjs \${LIBOBJDIR}$ac_i\$U.$ac_objext"
+ ac_ltlibobjs="$ac_ltlibobjs \${LIBOBJDIR}$ac_i"'$U.lo'
done
LIBOBJS=$ac_libobjs
@@ -4403,14 +5585,13 @@ LTLIBOBJS=$ac_ltlibobjs
-: "${CONFIG_STATUS=./config.status}"
+: ${CONFIG_STATUS=./config.status}
ac_write_fail=0
ac_clean_files_save=$ac_clean_files
ac_clean_files="$ac_clean_files $CONFIG_STATUS"
-{ $as_echo "$as_me:${as_lineno-$LINENO}: creating $CONFIG_STATUS" >&5
+{ $as_echo "$as_me:$LINENO: creating $CONFIG_STATUS" >&5
$as_echo "$as_me: creating $CONFIG_STATUS" >&6;}
-as_write_fail=0
-cat >$CONFIG_STATUS <<_ASEOF || as_write_fail=1
+cat >$CONFIG_STATUS <<_ACEOF || ac_write_fail=1
#! $SHELL
# Generated by $as_me.
# Run this file to recreate the current configuration.
@@ -4420,18 +5601,17 @@ cat >$CONFIG_STATUS <<_ASEOF || as_write_fail=1
debug=false
ac_cs_recheck=false
ac_cs_silent=false
SHELL=\${CONFIG_SHELL-$SHELL}
-export SHELL
-_ASEOF
-cat >>$CONFIG_STATUS <<\_ASEOF || as_write_fail=1
-## M4sh Initialization. ##
+_ACEOF
+cat >>$CONFIG_STATUS <<\_ACEOF || ac_write_fail=1
+## M4sh Initialization. ##
# Be more Bourne compatible
DUALCASE=1; export DUALCASE # for MKS sh
-if test -n "${ZSH_VERSION+set}" && (emulate sh) >/dev/null 2>&1; then :
+if test -n "${ZSH_VERSION+set}" && (emulate sh) >/dev/null 2>&1; then
emulate sh
NULLCMD=:
# Pre-4.2 versions of Zsh do word splitting on ${1+"$@"}, which
@@ -4439,15 +5619,23 @@ if test -n "${ZSH_VERSION+set}" && (emulate sh) >/dev/null 2>&1; then :
alias -g '${1+"$@"}'='"$@"'
setopt NO_GLOB_SUBST
else
- case `(set -o) 2>/dev/null` in #(
- *posix*) :
- set -o posix ;; #(
+ case `(set -o) 2>/dev/null` in
+ *posix*) set -o posix ;;
esac
fi
+# PATH needs CR
+# Avoid depending upon Character Ranges.
+as_cr_letters='abcdefghijklmnopqrstuvwxyz'
+as_cr_LETTERS='ABCDEFGHIJKLMNOPQRSTUVWXYZ'
+as_cr_Letters=$as_cr_letters$as_cr_LETTERS
+as_cr_digits='0123456789'
+as_cr_alnum=$as_cr_Letters$as_cr_digits
as_nl='
export as_nl
@@ -4455,13 +5643,7 @@ export as_nl
as_echo='\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\'
as_echo=$as_echo$as_echo$as_echo$as_echo$as_echo
as_echo=$as_echo$as_echo$as_echo$as_echo$as_echo$as_echo
-# Prefer a ksh shell builtin over an external printf program on Solaris,
-# but without wasting forks for bash or zsh.
-if test -z "$BASH_VERSION$ZSH_VERSION" \
- && (test "X`print -r -- $as_echo`" = "X$as_echo") 2>/dev/null; then
- as_echo='print -r --'
- as_echo_n='print -rn --'
-elif (test "X`printf %s $as_echo`" = "X$as_echo") 2>/dev/null; then
+if (test "X`printf %s $as_echo`" = "X$as_echo") 2>/dev/null; then
as_echo='printf %s\n'
as_echo_n='printf %s'
else
@@ -4472,7 +5654,7 @@ else
as_echo_body='eval expr "X$1" : "X\\(.*\\)"'
as_echo_n_body='eval
arg=$1;
- case $arg in #(
+ case $arg in
*"$as_nl"*)
expr "X$arg" : "X\\(.*\\)$as_nl";
arg=`expr "X$arg" : ".*$as_nl\\(.*\\)"`;;
@@ -4495,6 +5677,13 @@ if test "${PATH_SEPARATOR+set}" != set; then
fi
+# Support unset when possible.
+if ( (MAIL=60; unset MAIL) || exit) >/dev/null 2>&1; then
+ as_unset=unset
+else
+ as_unset=false
+fi
# IFS
# We need space, tab and new line, in precisely that order. Quoting is
@@ -4504,16 +5693,15 @@ fi
IFS=" "" $as_nl"
# Find who we are. Look in the path if we contain no directory separator.
-as_myself=
-case $0 in #((
+case $0 in
*[\\/]* ) as_myself=$0 ;;
*) as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
for as_dir in $PATH
do
IFS=$as_save_IFS
- test -r "$as_dir/$0" && as_myself=$as_dir/$0 && break
- done
+ test -r "$as_dir/$0" && as_myself=$as_dir/$0 && break
+done
IFS=$as_save_IFS
@@ -4525,16 +5713,12 @@ if test "x$as_myself" = x; then
fi
if test ! -f "$as_myself"; then
$as_echo "$as_myself: error: cannot find myself; rerun with an absolute file name" >&2
- exit 1
fi
-# Unset variables that we do not need and which cause bugs (e.g. in
-# pre-3.0 UWIN ksh). But do not cause bugs in bash 2.01; the "|| exit 1"
-# suppresses any "Segmentation fault" message there. '((' could
-# trigger a bug in pdksh 5.2.14.
-for as_var in BASH_ENV ENV MAIL MAILPATH
-do eval test x\${$as_var+set} = xset \
- && ( (unset $as_var) || exit 1) >/dev/null 2>&1 && unset $as_var || :
+# Work around bugs in pre-3.0 UWIN ksh.
+for as_var in ENV MAIL MAILPATH
+do ($as_unset $as_var) >/dev/null 2>&1 && $as_unset $as_var
done
PS1='$ '
PS2='> '
@@ -4546,89 +5730,7 @@ export LC_ALL
LANGUAGE=C
export LANGUAGE
-# CDPATH.
-(unset CDPATH) >/dev/null 2>&1 && unset CDPATH
-# as_fn_error STATUS ERROR [LINENO LOG_FD]
-# Output "`basename $0`: error: ERROR" to stderr. If LINENO and LOG_FD are
-# provided, also output the error to LOG_FD, referencing LINENO. Then exit the
-# script with STATUS, using 1 if that was 0.
-as_fn_error ()
- as_status=$1; test $as_status -eq 0 && as_status=1
- if test "$4"; then
- as_lineno=${as_lineno-"$3"} as_lineno_stack=as_lineno_stack=$as_lineno_stack
- $as_echo "$as_me:${as_lineno-$LINENO}: error: $2" >&$4
- fi
- $as_echo "$as_me: error: $2" >&2
- as_fn_exit $as_status
-} # as_fn_error
-# as_fn_set_status STATUS
-# Set $? to STATUS, without forking.
-as_fn_set_status ()
- return $1
-} # as_fn_set_status
-# as_fn_exit STATUS
-# Exit the shell with STATUS, even in a "trap 0" or "set -e" context.
-as_fn_exit ()
- set +e
- as_fn_set_status $1
- exit $1
-} # as_fn_exit
-# as_fn_unset VAR
-# Portably unset VAR.
-as_fn_unset ()
- { eval $1=; unset $1;}
-as_unset=as_fn_unset
-# as_fn_append VAR VALUE
-# Append the text in VALUE to the end of the definition contained in VAR. Take
-# advantage of any shell optimizations that allow amortized linear growth over
-# repeated appends, instead of the typical quadratic growth present in naive
-# implementations.
-if (eval "as_var=1; as_var+=2; test x\$as_var = x12") 2>/dev/null; then :
- eval 'as_fn_append ()
- eval $1+=\$2
-else
- as_fn_append ()
- eval $1=\$$1\$2
-fi # as_fn_append
-# as_fn_arith ARG...
-# Perform arithmetic evaluation on the ARGs, and store the result in the
-# global $as_val. Take advantage of shells that can avoid forks. The arguments
-# must be portable across $(()) and expr.
-if (eval "test \$(( 1 + 1 )) = 2") 2>/dev/null; then :
- eval 'as_fn_arith ()
- as_val=$(( $* ))
-else
- as_fn_arith ()
- as_val=`expr "$@" || test $? -eq 1`
-fi # as_fn_arith
+# Required to use basename.
if expr a : '\(a\)' >/dev/null 2>&1 &&
test "X`expr 00001 : '.*\(...\)'`" = X001; then
as_expr=expr
@@ -4642,12 +5744,8 @@ else
as_basename=false
fi
-if (as_dir=`dirname -- /` && test "X$as_dir" = X/) >/dev/null 2>&1; then
- as_dirname=dirname
-else
- as_dirname=false
-fi
+# Name of the executable.
as_me=`$as_basename -- "$0" ||
$as_expr X/"$0" : '.*/\([^/][^/]*\)/*$' \| \
X"$0" : 'X\(//\)$' \| \
@@ -4667,25 +5765,76 @@ $as_echo X/"$0" |
s/.*/./; q'`
-# Avoid depending upon Character Ranges.
-as_cr_letters='abcdefghijklmnopqrstuvwxyz'
-as_cr_LETTERS='ABCDEFGHIJKLMNOPQRSTUVWXYZ'
-as_cr_Letters=$as_cr_letters$as_cr_LETTERS
-as_cr_digits='0123456789'
-as_cr_alnum=$as_cr_Letters$as_cr_digits
+# CDPATH.
+$as_unset CDPATH
+ as_lineno_1=$LINENO
+ as_lineno_2=$LINENO
+ test "x$as_lineno_1" != "x$as_lineno_2" &&
+ test "x`expr $as_lineno_1 + 1`" = "x$as_lineno_2" || {
+ # Create $as_me.lineno as a copy of $as_myself, but with $LINENO
+ # uniformly replaced by the line number. The first 'sed' inserts a
+ # line-number line after each line using $LINENO; the second 'sed'
+ # does the real work. The second script uses 'N' to pair each
+ # line-number line with the line containing $LINENO, and appends
+ # trailing '-' during substitution so that $LINENO is not a special
+ # case at line end.
+ # (Raja R Harinath suggested sed '=', and Paul Eggert wrote the
+ # scripts with optimization help from Paolo Bonzini. Blame Lee
+ # E. McMahon (1931-1989) for sed's syntax. :-)
+ sed -n '
+ p
+ /[$]LINENO/=
+ ' <$as_myself |
+ sed '
+ s/[$]LINENO.*/&-/
+ t lineno
+ b
+ :lineno
+ N
+ :loop
+ s/[$]LINENO\([^'$as_cr_alnum'_].*\n\)\(.*\)/\2\1\2/
+ t loop
+ s/-\n.*//
+ ' >$as_me.lineno &&
+ chmod +x "$as_me.lineno" ||
+ { $as_echo "$as_me: error: cannot create $as_me.lineno; rerun with a POSIX shell" >&2
+ # Don't try to exec as it changes $[0], causing all sort of problems
+ # (the dirname of $[0] is not the place where we might find the
+ # original and so on. Autoconf is especially sensitive to this).
+ . "./$as_me.lineno"
+ # Exit status is that of the last command.
+ exit
+if (as_dir=`dirname -- /` && test "X$as_dir" = X/) >/dev/null 2>&1; then
+ as_dirname=dirname
+else
+ as_dirname=false
+fi
ECHO_C= ECHO_N= ECHO_T=
-case `echo -n x` in #(((((
+case `echo -n x` in
-n*)
- case `echo 'xy\c'` in
+ case `echo 'x\c'` in
*c*) ECHO_T=' ';; # ECHO_T is single tab character.
- xy) ECHO_C='\c';;
- *) echo `echo ksh88 bug on AIX 6.1` > /dev/null
- ECHO_T=' ';;
+ *) ECHO_C='\c';;
esac;;
ECHO_N='-n';;
esac
+if expr a : '\(a\)' >/dev/null 2>&1 &&
+ test "X`expr 00001 : '.*\(...\)'`" = X001; then
+ as_expr=expr
+else
+ as_expr=false
+fi
rm -f conf$$ conf$$.exe conf$$.file
if test -d conf$$.dir; then
@@ -4700,85 +5849,49 @@ if (echo >conf$$.file) 2>/dev/null; then
# ... but there are two gotchas:
# 1) On MSYS, both `ln -s file dir' and `ln file dir' fail.
# 2) DJGPP < 2.04 has no symlinks; `ln -s' creates a wrapper executable.
- # In both cases, we have to default to `cp -pR'.
+ # In both cases, we have to default to `cp -p'.
ln -s conf$$.file conf$$.dir 2>/dev/null && test ! -f conf$$.exe ||
- as_ln_s='cp -pR'
+ as_ln_s='cp -p'
elif ln conf$$.file conf$$ 2>/dev/null; then
as_ln_s=ln
else
- as_ln_s='cp -pR'
+ as_ln_s='cp -p'
fi
else
- as_ln_s='cp -pR'
+ as_ln_s='cp -p'
fi
rm -f conf$$ conf$$.exe conf$$.dir/conf$$.file conf$$.file
rmdir conf$$.dir 2>/dev/null
-# as_fn_mkdir_p
-# Create "$as_dir" as a directory, including parents if necessary.
-as_fn_mkdir_p ()
- case $as_dir in #(
- -*) as_dir=./$as_dir;;
- esac
- test -d "$as_dir" || eval $as_mkdir_p || {
- as_dirs=
- while :; do
- *\'*) as_qdir=`$as_echo "$as_dir" | sed "s/'/'\\\\\\\\''/g"`;; #'(
- *) as_qdir=$as_dir;;
- esac
- as_dirs="'$as_qdir' $as_dirs"
- as_dir=`$as_dirname -- "$as_dir" ||
-$as_expr X"$as_dir" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
- X"$as_dir" : 'X\(//\)[^/]' \| \
- X"$as_dir" : 'X\(//\)$' \| \
- X"$as_dir" : 'X\(/\)' \| . 2>/dev/null ||
-$as_echo X"$as_dir" |
- sed '/^X\(.*[^/]\)\/\/*[^/][^/]*\/*$/{
- s//\1/
- q
- /^X\(\/\/\)[^/].*/{
- s//\1/
- q
- /^X\(\/\/\)$/{
- s//\1/
- q
- /^X\(\/\).*/{
- s//\1/
- q
- s/.*/./; q'`
- test -d "$as_dir" && break
- done
- test -z "$as_dirs" || eval "mkdir $as_dirs"
- } || test -d "$as_dir" || as_fn_error $? "cannot create directory $as_dir"
-} # as_fn_mkdir_p
if mkdir -p . 2>/dev/null; then
- as_mkdir_p='mkdir -p "$as_dir"'
+ as_mkdir_p=:
else
test -d ./-p && rmdir ./-p
as_mkdir_p=false
fi
-# as_fn_executable_p FILE
-# Test if FILE is an executable regular file.
-as_fn_executable_p ()
- test -f "$1" && test -x "$1"
-} # as_fn_executable_p
-as_test_x='test -x'
-as_executable_p=as_fn_executable_p
+if test -x / >/dev/null 2>&1; then
+ as_test_x='test -x'
+else
+ if ls -dL / >/dev/null 2>&1; then
+ as_ls_L_option=L
+ else
+ as_ls_L_option=
+ fi
+ as_test_x='
+ eval sh -c '\''
+ if test -d "$1"; then
+ test -d "$1/.";
+ else
+ case $1 in
+ -*)set "./$1";;
+ esac;
+ case `ls -ld'$as_ls_L_option' "$1" 2>/dev/null` in
+ ???[sx]*):;;*)false;;esac;fi
+ '\'' sh
+fi
+as_executable_p=$as_test_x
# Sed expression to map a string onto a valid CPP name.
as_tr_cpp="eval sed 'y%*$as_cr_letters%P$as_cr_LETTERS%;s%[^_$as_cr_alnum]%_%g'"
@@ -4788,19 +5901,13 @@ as_tr_sh="eval sed 'y%*+%pp%;s%[^_$as_cr_alnum]%_%g'"
exec 6>&1
-## Main body of $CONFIG_STATUS script. ##
-_ASEOF
-test $as_write_fail = 0 && chmod +x $CONFIG_STATUS || ac_write_fail=1
-cat >>$CONFIG_STATUS <<\_ACEOF || ac_write_fail=1
-# Save the log message, to keep $0 and so on meaningful, and to
+# Save the log message, to keep $[0] and so on meaningful, and to
# report actual input values of CONFIG_FILES etc. instead of their
# values after options handling.
ac_log="
This file was extended by darshan-runtime $as_me 3.0.0-pre1, which was
-generated by GNU Autoconf 2.69. Invocation command line was
+generated by GNU Autoconf 2.63. Invocation command line was
CONFIG_FILES = $CONFIG_FILES
CONFIG_HEADERS = $CONFIG_HEADERS
@@ -4831,15 +5938,13 @@ _ACEOF
ac_cs_usage="\
-\`$as_me' instantiates files and other configuration actions
-from templates according to the current configuration. Unless the files
-and actions are specified as TAGs, all are instantiated by default.
+\`$as_me' instantiates files from templates according to the
+current configuration.
-Usage: $0 [OPTION]... [TAG]...
+Usage: $0 [OPTION]... [FILE]...
-h, --help print this help, then exit
-V, --version print version number and configuration settings, then exit
- --config print configuration, then exit
-q, --quiet, --silent
do not print progress messages
-d, --debug don't remove temporary files
@@ -4855,17 +5960,16 @@ $config_files
Configuration headers:
$config_headers
-Report bugs to the package provider."
+Report bugs to <bug-autoconf at gnu.org>."
_ACEOF
cat >>$CONFIG_STATUS <<_ACEOF || ac_write_fail=1
-ac_cs_config="`$as_echo "$ac_configure_args" | sed 's/^ //; s/[\\""\`\$]/\\\\&/g'`"
ac_cs_version="\\
darshan-runtime config.status 3.0.0-pre1
-configured by $0, generated by GNU Autoconf 2.69,
- with options \\"\$ac_cs_config\\"
+configured by $0, generated by GNU Autoconf 2.63,
+ with options \\"`$as_echo "$ac_configure_args" | sed 's/^ //; s/[\\""\`\$]/\\\\&/g'`\\"
-Copyright (C) 2012 Free Software Foundation, Inc.
+Copyright (C) 2008 Free Software Foundation, Inc.
This config.status script is free software; the Free Software Foundation
gives unlimited permission to copy, distribute and modify it."
@@ -4881,16 +5985,11 @@ ac_need_defaults=:
while test $# != 0
do
case $1 in
ac_option=`expr "X$1" : 'X\([^=]*\)='`
ac_optarg=`expr "X$1" : 'X[^=]*=\(.*\)'`
ac_shift=:
- ac_option=`expr "X$1" : 'X\([^=]*\)='`
- ac_optarg=
- ac_shift=:
ac_option=$1
ac_optarg=$2
@@ -4904,29 +6003,27 @@ do
ac_cs_recheck=: ;;
--version | --versio | --versi | --vers | --ver | --ve | --v | -V )
$as_echo "$ac_cs_version"; exit ;;
- --config | --confi | --conf | --con | --co | --c )
- $as_echo "$ac_cs_config"; exit ;;
--debug | --debu | --deb | --de | --d | -d )
debug=: ;;
--file | --fil | --fi | --f )
$ac_shift
case $ac_optarg in
*\'*) ac_optarg=`$as_echo "$ac_optarg" | sed "s/'/'\\\\\\\\''/g"` ;;
- '') as_fn_error $? "missing file argument" ;;
esac
- as_fn_append CONFIG_FILES " '$ac_optarg'"
+ CONFIG_FILES="$CONFIG_FILES '$ac_optarg'"
ac_need_defaults=false;;
--header | --heade | --head | --hea )
$ac_shift
case $ac_optarg in
esac
- as_fn_append CONFIG_HEADERS " '$ac_optarg'"
+ CONFIG_HEADERS="$CONFIG_HEADERS '$ac_optarg'"
--he | --h)
# Conflict between --help and --header
- as_fn_error $? "ambiguous option: \`$1'
-Try \`$0 --help' for more information.";;
+ { $as_echo "$as_me: error: ambiguous option: $1
+Try \`$0 --help' for more information." >&2
+ { (exit 1); exit 1; }; };;
--help | --hel | -h )
$as_echo "$ac_cs_usage"; exit ;;
-q | -quiet | --quiet | --quie | --qui | --qu | --q \
@@ -4934,10 +6031,11 @@ Try \`$0 --help' for more information.";;
ac_cs_silent=: ;;
# This is an error.
- -*) as_fn_error $? "unrecognized option: \`$1'
-Try \`$0 --help' for more information." ;;
+ -*) { $as_echo "$as_me: error: unrecognized option: $1
- *) as_fn_append ac_config_targets " $1"
+ *) ac_config_targets="$ac_config_targets $1"
ac_need_defaults=false ;;
esac
@@ -4954,7 +6052,7 @@ fi
_ACEOF
if \$ac_cs_recheck; then
- set X $SHELL '$0' $ac_configure_args \$ac_configure_extra_args --no-create --no-recursion
+ set X '$SHELL' '$0' $ac_configure_args \$ac_configure_extra_args --no-create --no-recursion
shift
\$as_echo "running CONFIG_SHELL=$SHELL \$*" >&6
CONFIG_SHELL='$SHELL'
@@ -5001,7 +6099,9 @@ do
"share/mpi-profile/darshan-bg-cxx.conf") CONFIG_FILES="$CONFIG_FILES share/mpi-profile/darshan-bg-cxx.conf" ;;
"share/mpi-profile/darshan-bg-f.conf") CONFIG_FILES="$CONFIG_FILES share/mpi-profile/darshan-bg-f.conf" ;;
- *) as_fn_error $? "invalid argument: \`$ac_config_target'" "$LINENO" 5;;
+ *) { { $as_echo "$as_me:$LINENO: error: invalid argument: $ac_config_target" >&5
+$as_echo "$as_me: error: invalid argument: $ac_config_target" >&2;}
esac
done
@@ -5023,24 +6123,26 @@ fi
# after its creation but before its name has been assigned to `$tmp'.
$debug ||
- tmp= ac_tmp=
+ tmp=
trap 'exit_status=$?
- : "${ac_tmp:=$tmp}"
- { test ! -d "$ac_tmp" || rm -fr "$ac_tmp"; } && exit $exit_status
+ { test -z "$tmp" || test ! -d "$tmp" || rm -fr "$tmp"; } && exit $exit_status
' 0
- trap 'as_fn_exit 1' 1 2 13 15
+ trap '{ (exit 1); exit 1; }' 1 2 13 15
# Create a (secure) tmp directory for tmp files.
tmp=`(umask 077 && mktemp -d "./confXXXXXX") 2>/dev/null` &&
- test -d "$tmp"
+ test -n "$tmp" && test -d "$tmp"
tmp=./conf$$-$RANDOM
(umask 077 && mkdir "$tmp")
-} || as_fn_error $? "cannot create a temporary directory in ." "$LINENO" 5
-ac_tmp=$tmp
+ $as_echo "$as_me: cannot create a temporary directory in ." >&2
# Set up the scripts for CONFIG_FILES section.
# No need to generate them if there are no CONFIG_FILES.
@@ -5048,13 +6150,7 @@ ac_tmp=$tmp
if test -n "$CONFIG_FILES"; then
-ac_cr=`echo X | tr X '\015'`
-# On cygwin, bash can eat \r inside `` if the user requested igncr.
-# But we know of no other shell where ac_cr would be empty at this
-# point, so we can use a bashism as a fallback.
-if test "x$ac_cr" = x; then
- eval ac_cr=\$\'\\r\'
-fi
+ac_cr='
ac_cs_awk_cr=`$AWK 'BEGIN { print "a\rb" }' </dev/null 2>/dev/null`
if test "$ac_cs_awk_cr" = "a${ac_cr}b"; then
ac_cs_awk_cr='\\r'
@@ -5062,7 +6158,7 @@ else
ac_cs_awk_cr=$ac_cr
fi
-echo 'BEGIN {' >"$ac_tmp/subs1.awk" &&
+echo 'BEGIN {' >"$tmp/subs1.awk" &&
_ACEOF
@@ -5071,18 +6167,24 @@ _ACEOF
echo "$ac_subst_vars" | sed 's/.*/&!$&$ac_delim/' &&
echo "_ACEOF"
} >conf$$subs.sh ||
- as_fn_error $? "could not make $CONFIG_STATUS" "$LINENO" 5
-ac_delim_num=`echo "$ac_subst_vars" | grep -c '^'`
+ { { $as_echo "$as_me:$LINENO: error: could not make $CONFIG_STATUS" >&5
+$as_echo "$as_me: error: could not make $CONFIG_STATUS" >&2;}
+ac_delim_num=`echo "$ac_subst_vars" | grep -c '$'`
ac_delim='%!_!# '
for ac_last_try in false false false false false :; do
. ./conf$$subs.sh ||
ac_delim_n=`sed -n "s/.*$ac_delim\$/X/p" conf$$subs.awk | grep -c X`
if test $ac_delim_n = $ac_delim_num; then
break
elif $ac_last_try; then
else
ac_delim="$ac_delim!$ac_delim _$ac_delim!! "
fi
@@ -5090,7 +6192,7 @@ done
rm -f conf$$subs.sh
-cat >>"\$ac_tmp/subs1.awk" <<\\_ACAWK &&
+cat >>"\$tmp/subs1.awk" <<\\_ACAWK &&
_ACEOF
sed -n '
h
@@ -5104,7 +6206,7 @@ s/'"$ac_delim"'$//
t delim
:nl
h
-s/\(.\{148\}\)..*/\1/
+s/\(.\{148\}\).*/\1/
t more1
s/["\\]/\\&/g; s/^/"/; s/$/\\n"\\/
p
@@ -5118,7 +6220,7 @@ s/.\{148\}//
t nl
:delim
h
t more2
s/["\\]/\\&/g; s/^/"/; s/$/"/
p
@@ -5138,7 +6240,7 @@ t delim
rm -f conf$$subs.awk
_ACAWK
-cat >>"\$ac_tmp/subs1.awk" <<_ACAWK &&
+cat >>"\$tmp/subs1.awk" <<_ACAWK &&
for (key in S) S_is_set[key] = 1
FS = ""
@@ -5170,29 +6272,23 @@ if sed "s/$ac_cr//" < /dev/null > /dev/null 2>&1; then
sed "s/$ac_cr\$//; s/$ac_cr/$ac_cs_awk_cr/g"
else
cat
-fi < "$ac_tmp/subs1.awk" > "$ac_tmp/subs.awk" \
- || as_fn_error $? "could not setup config files machinery" "$LINENO" 5
+fi < "$tmp/subs1.awk" > "$tmp/subs.awk" \
+ || { { $as_echo "$as_me:$LINENO: error: could not setup config files machinery" >&5
+$as_echo "$as_me: error: could not setup config files machinery" >&2;}
_ACEOF
-# VPATH may cause trouble with some makes, so we remove sole $(srcdir),
-# ${srcdir} and @srcdir@ entries from VPATH if srcdir is ".", strip leading and
+# VPATH may cause trouble with some makes, so we remove $(srcdir),
+# ${srcdir} and @srcdir@ from VPATH if srcdir is ".", strip leading and
# trailing colons and then remove the whole line if VPATH becomes empty
# (actually we leave an empty line to preserve line numbers).
if test "x$srcdir" = x.; then
- ac_vpsub='/^[ ]*VPATH[ ]*=[ ]*/{
-h
-s///
-s/^/:/
-s/[ ]*$/:/
-s/:\$(srcdir):/:/g
-s/:\${srcdir}:/:/g
-s/:@srcdir@:/:/g
-s/^:*//
+ ac_vpsub='/^[ ]*VPATH[ ]*=/{
+s/:*\$(srcdir):*/:/
+s/:*\${srcdir}:*/:/
+s/:*@srcdir@:*/:/
+s/^\([^=]*=[ ]*\):*/\1/
s/:*$//
-x
-s/\(=[ ]*\).*/\1/
-G
-s/\n//
s/^[^=]*=[ ]*$//
fi
@@ -5204,7 +6300,7 @@ fi # test -n "$CONFIG_FILES"
# No need to generate them if there are no CONFIG_HEADERS.
# This happens for instance with `./config.status Makefile'.
if test -n "$CONFIG_HEADERS"; then
-cat >"$ac_tmp/defines.awk" <<\_ACAWK ||
+cat >"$tmp/defines.awk" <<\_ACAWK ||
BEGIN {
_ACEOF
@@ -5216,11 +6312,13 @@ _ACEOF
# handling of long lines.
ac_delim='%!_!# '
for ac_last_try in false false :; do
- ac_tt=`sed -n "/$ac_delim/p" confdefs.h`
- if test -z "$ac_tt"; then
+ ac_t=`sed -n "/$ac_delim/p" confdefs.h`
+ if test -z "$ac_t"; then
break
- as_fn_error $? "could not make $CONFIG_HEADERS" "$LINENO" 5
+ { { $as_echo "$as_me:$LINENO: error: could not make $CONFIG_HEADERS" >&5
+$as_echo "$as_me: error: could not make $CONFIG_HEADERS" >&2;}
else
fi
@@ -5305,7 +6403,9 @@ cat >>$CONFIG_STATUS <<_ACEOF || ac_write_fail=1
_ACAWK
_ACEOF
- as_fn_error $? "could not setup config headers machinery" "$LINENO" 5
+ { { $as_echo "$as_me:$LINENO: error: could not setup config headers machinery" >&5
+$as_echo "$as_me: error: could not setup config headers machinery" >&2;}
fi # test -n "$CONFIG_HEADERS"
@@ -5318,7 +6418,9 @@ do
esac
case $ac_mode$ac_tag in
:[FHL]*:*);;
- :L* | :C*:*) as_fn_error $? "invalid tag \`$ac_tag'" "$LINENO" 5;;
+ :L* | :C*:*) { { $as_echo "$as_me:$LINENO: error: invalid tag $ac_tag" >&5
+$as_echo "$as_me: error: invalid tag $ac_tag" >&2;}
:[FH]-) ac_tag=-:-;;
:[FH]*) ac_tag=$ac_tag:$ac_tag.in;;
esac
@@ -5337,7 +6439,7 @@ do
for ac_f
do
case $ac_f in
- -) ac_f="$ac_tmp/stdin";;
+ -) ac_f="$tmp/stdin";;
*) # Look for the file first in the build tree, then in the source tree
# (if the path is not absolute). The absolute path cannot be DOS-style,
# because $ac_f cannot contain `:'.
@@ -5346,10 +6448,12 @@ do
[\\/$]*) false;;
*) test -f "$srcdir/$ac_f" && ac_f="$srcdir/$ac_f";;
esac ||
- as_fn_error 1 "cannot find input file: \`$ac_f'" "$LINENO" 5;;
+ { { $as_echo "$as_me:$LINENO: error: cannot find input file: $ac_f" >&5
+$as_echo "$as_me: error: cannot find input file: $ac_f" >&2;}
esac
case $ac_f in *\'*) ac_f=`$as_echo "$ac_f" | sed "s/'/'\\\\\\\\''/g"`;; esac
- as_fn_append ac_file_inputs " '$ac_f'"
+ ac_file_inputs="$ac_file_inputs '$ac_f'"
done
# Let's still pretend it is `configure' which instantiates (i.e., don't
@@ -5360,7 +6464,7 @@ do
`' by configure.'
if test x"$ac_file" != x-; then
configure_input="$ac_file. $configure_input"
- { $as_echo "$as_me:${as_lineno-$LINENO}: creating $ac_file" >&5
+ { $as_echo "$as_me:$LINENO: creating $ac_file" >&5
$as_echo "$as_me: creating $ac_file" >&6;}
fi
# Neutralize special characters interpreted by sed in replacement strings.
@@ -5372,8 +6476,10 @@ $as_echo "$as_me: creating $ac_file" >&6;}
esac
case $ac_tag in
- *:-:* | *:-) cat >"$ac_tmp/stdin" \
- || as_fn_error $? "could not create $ac_file" "$LINENO" 5 ;;
+ *:-:* | *:-) cat >"$tmp/stdin" \
+ || { { $as_echo "$as_me:$LINENO: error: could not create $ac_file" >&5
+$as_echo "$as_me: error: could not create $ac_file" >&2;}
esac
esac
@@ -5401,7 +6507,47 @@ $as_echo X"$ac_file" |
q
s/.*/./; q'`
- as_dir="$ac_dir"; as_fn_mkdir_p
+ { as_dir="$ac_dir"
+ case $as_dir in #(
+ -*) as_dir=./$as_dir;;
+ esac
+ test -d "$as_dir" || { $as_mkdir_p && mkdir -p "$as_dir"; } || {
+ as_dirs=
+ while :; do
+ *\'*) as_qdir=`$as_echo "$as_dir" | sed "s/'/'\\\\\\\\''/g"`;; #'(
+ *) as_qdir=$as_dir;;
+ esac
+ as_dirs="'$as_qdir' $as_dirs"
+ as_dir=`$as_dirname -- "$as_dir" ||
+$as_expr X"$as_dir" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
+ X"$as_dir" : 'X\(//\)[^/]' \| \
+ X"$as_dir" : 'X\(//\)$' \| \
+ X"$as_dir" : 'X\(/\)' \| . 2>/dev/null ||
+$as_echo X"$as_dir" |
+ sed '/^X\(.*[^/]\)\/\/*[^/][^/]*\/*$/{
+ s//\1/
+ q
+ /^X\(\/\/\)[^/].*/{
+ s//\1/
+ q
+ /^X\(\/\/\)$/{
+ s//\1/
+ q
+ /^X\(\/\).*/{
+ s//\1/
+ q
+ s/.*/./; q'`
+ test -d "$as_dir" && break
+ done
+ test -z "$as_dirs" || eval "mkdir $as_dirs"
+ } || test -d "$as_dir" || { { $as_echo "$as_me:$LINENO: error: cannot create directory $as_dir" >&5
+$as_echo "$as_me: error: cannot create directory $as_dir" >&2;}
+ { (exit 1); exit 1; }; }; }
ac_builddir=.
case "$ac_dir" in
@@ -5453,6 +6599,7 @@ cat >>$CONFIG_STATUS <<\_ACEOF || ac_write_fail=1
# If the template does not know about datarootdir, expand it.
# FIXME: This hack should be removed a few years after 2.60.
ac_datarootdir_hack=; ac_datarootdir_seen=
ac_sed_dataroot='
/datarootdir/ {
p
@@ -5462,11 +6609,12 @@ ac_sed_dataroot='
/@docdir@/p
/@infodir@/p
/@localedir@/p
-/@mandir@/p'
+/@mandir@/p
case `eval "sed -n \"\$ac_sed_dataroot\" $ac_file_inputs"` in
*datarootdir*) ac_datarootdir_seen=yes;;
*@datadir@*|*@docdir@*|*@infodir@*|*@localedir@*|*@mandir@*)
- { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: $ac_file_inputs seems to ignore the --datarootdir setting" >&5
+ { $as_echo "$as_me:$LINENO: WARNING: $ac_file_inputs seems to ignore the --datarootdir setting" >&5
$as_echo "$as_me: WARNING: $ac_file_inputs seems to ignore the --datarootdir setting" >&2;}
_ACEOF
@@ -5476,7 +6624,7 @@ cat >>$CONFIG_STATUS <<_ACEOF || ac_write_fail=1
s&@infodir@&$infodir&g
s&@localedir@&$localedir&g
s&@mandir@&$mandir&g
- s&\\\${datarootdir}&$datarootdir&g' ;;
+ s&\\\${datarootdir}&$datarootdir&g' ;;
esac
_ACEOF
@@ -5503,24 +6651,27 @@ s&@abs_top_builddir@&$ac_abs_top_builddir&;t t
s&@INSTALL@&$ac_INSTALL&;t t
$ac_datarootdir_hack
-eval sed \"\$ac_sed_extra\" "$ac_file_inputs" | $AWK -f "$ac_tmp/subs.awk" \
- >$ac_tmp/out || as_fn_error $? "could not create $ac_file" "$LINENO" 5
+eval sed \"\$ac_sed_extra\" "$ac_file_inputs" | $AWK -f "$tmp/subs.awk" >$tmp/out \
test -z "$ac_datarootdir_hack$ac_datarootdir_seen" &&
- { ac_out=`sed -n '/\${datarootdir}/p' "$ac_tmp/out"`; test -n "$ac_out"; } &&
- { ac_out=`sed -n '/^[ ]*datarootdir[ ]*:*=/p' \
- "$ac_tmp/out"`; test -z "$ac_out"; } &&
- { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: $ac_file contains a reference to the variable \`datarootdir'
-which seems to be undefined. Please make sure it is defined" >&5
+ { ac_out=`sed -n '/\${datarootdir}/p' "$tmp/out"`; test -n "$ac_out"; } &&
+ { ac_out=`sed -n '/^[ ]*datarootdir[ ]*:*=/p' "$tmp/out"`; test -z "$ac_out"; } &&
+ { $as_echo "$as_me:$LINENO: WARNING: $ac_file contains a reference to the variable \`datarootdir'
+which seems to be undefined. Please make sure it is defined." >&5
$as_echo "$as_me: WARNING: $ac_file contains a reference to the variable \`datarootdir'
-which seems to be undefined. Please make sure it is defined" >&2;}
+which seems to be undefined. Please make sure it is defined." >&2;}
- rm -f "$ac_tmp/stdin"
+ rm -f "$tmp/stdin"
case $ac_file in
- -) cat "$ac_tmp/out" && rm -f "$ac_tmp/out";;
- *) rm -f "$ac_file" && mv "$ac_tmp/out" "$ac_file";;
+ -) cat "$tmp/out" && rm -f "$tmp/out";;
+ *) rm -f "$ac_file" && mv "$tmp/out" "$ac_file";;
esac \
:H)
@@ -5529,21 +6680,27 @@ which seems to be undefined. Please make sure it is defined" >&2;}
$as_echo "/* $configure_input */" \
- && eval '$AWK -f "$ac_tmp/defines.awk"' "$ac_file_inputs"
- } >"$ac_tmp/config.h" \
- if diff "$ac_file" "$ac_tmp/config.h" >/dev/null 2>&1; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: $ac_file is unchanged" >&5
+ && eval '$AWK -f "$tmp/defines.awk"' "$ac_file_inputs"
+ } >"$tmp/config.h" \
+ if diff "$ac_file" "$tmp/config.h" >/dev/null 2>&1; then
+ { $as_echo "$as_me:$LINENO: $ac_file is unchanged" >&5
$as_echo "$as_me: $ac_file is unchanged" >&6;}
else
rm -f "$ac_file"
- mv "$ac_tmp/config.h" "$ac_file" \
+ mv "$tmp/config.h" "$ac_file" \
fi
else
- && eval '$AWK -f "$ac_tmp/defines.awk"' "$ac_file_inputs" \
- || as_fn_error $? "could not create -" "$LINENO" 5
+ && eval '$AWK -f "$tmp/defines.awk"' "$ac_file_inputs" \
+ || { { $as_echo "$as_me:$LINENO: error: could not create -" >&5
+$as_echo "$as_me: error: could not create -" >&2;}
fi
@@ -5553,12 +6710,15 @@ $as_echo "$as_me: $ac_file is unchanged" >&6;}
done # for ac_tag
-as_fn_exit 0
+{ (exit 0); exit 0; }
_ACEOF
+chmod +x $CONFIG_STATUS
ac_clean_files=$ac_clean_files_save
test $ac_write_fail = 0 ||
- as_fn_error $? "write failure creating $CONFIG_STATUS" "$LINENO" 5
+ { { $as_echo "$as_me:$LINENO: error: write failure creating $CONFIG_STATUS" >&5
+$as_echo "$as_me: error: write failure creating $CONFIG_STATUS" >&2;}
# configure is writing to config.log, and then calls config.status.
@@ -5579,10 +6739,10 @@ if test "$no_create" != yes; then
exec 5>>config.log
# Use ||, not &&, to avoid exiting from the if with $? = 1, which
# would make configure fail if this is the last instruction.
- $ac_cs_success || as_fn_exit 1
+ $ac_cs_success || { (exit 1); exit 1; }
fi
if test -n "$ac_unrecognized_opts" && test "$enable_option_checking" != no; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: unrecognized options: $ac_unrecognized_opts" >&5
+ { $as_echo "$as_me:$LINENO: WARNING: unrecognized options: $ac_unrecognized_opts" >&5
$as_echo "$as_me: WARNING: unrecognized options: $ac_unrecognized_opts" >&2;}
fi
diff --git a/darshan-runtime/configure.in b/darshan-runtime/configure.in
index a995658..52eab26 100644
--- a/darshan-runtime/configure.in
+++ b/darshan-runtime/configure.in
@@ -295,12 +295,9 @@ if test x$enable_bgq_mod != xno; then
AC_MSG_RESULT(yes)
DARSHAN_USE_BGQ=1,
AC_MSG_RESULT(no)
- AS_IF([
- test "x$enable_bgq_mod" = xyes],
+ AS_IF([test "x$enable_bgq_mod" = xyes],
AC_MSG_ERROR(BG/Q module enabled in non-BG/Q environment),
fi
DARSHAN_VERSION="AC_PACKAGE_VERSION"
diff --git a/darshan-runtime/darshan-runtime-config.h.in b/darshan-runtime/darshan-runtime-config.h.in
index ad3e9cc..fda5303 100644
--- a/darshan-runtime/darshan-runtime-config.h.in
+++ b/darshan-runtime/darshan-runtime-config.h.in
@@ -63,9 +63,6 @@
/* Define to the one symbol short name of this package. */
#undef PACKAGE_TARNAME
-/* Define to the home page for this package. */
-#undef PACKAGE_URL
/* Define to the version of this package. */
#undef PACKAGE_VERSION
diff --git a/darshan-runtime/lib/pkgconfig/darshan-runtime.pc.in b/darshan-runtime/lib/pkgconfig/darshan-runtime.pc.in
index 55c2e92..95d193c 100644
--- a/darshan-runtime/lib/pkgconfig/darshan-runtime.pc.in
+++ b/darshan-runtime/lib/pkgconfig/darshan-runtime.pc.in
@@ -9,10 +9,11 @@ Requires: zlib mpich
Requires.private:
darshan_prefix=@prefix@
+darshan_share=@darshan_share_path@
darshan_includedir=
darshan_libdir= -L${darshan_prefix}/lib
-darshan_linkopts="-Wl,-u,MPI_Init,-u,MPI_Wtime,-u,__wrap_H5Fcreate,-u,__wrap_ncmpi_create,-wrap,write,-wrap,open,-wrap,creat,-wrap,creat64,-wrap,open64,-wrap,close,-wrap,read,-wrap,lseek,-wrap,lseek64,-wrap,pread,-wrap,pwrite,-wrap,readv,-wrap,writev,-wrap,__xstat,-wrap,__lxstat,-wrap,__fxstat,-wrap,__xstat64,-wrap,__lxstat64,-wrap,__fxstat64,-wrap,mmap,-wrap,mmap64,-wrap,fopen,-wrap,fclose,-wrap,fread,-wrap,fwrite,-wrap,fseek,-wrap,fopen64,-wrap,pread64,-wrap,pwrite64,-wrap,fsync,-wrap,fdatasync,-wrap,ncmpi_create,-wrap,ncmpi_open,-wrap,ncmpi_close,-wrap,H5Fcreate,-wrap,H5Fopen,-wrap,H5Fclose,-wrap,aio_write,-wrap,aio_write64,-wrap,aio_read,-wrap,aio_read64,-wrap,lio_listio,-wrap,lio_listio64,-wrap,aio_return,-wrap,aio_return64,-wrap,mkstemp,-wrap,mkostemp,-wrap,mkstemps,-wrap,mkostemps"
+darshan_linkopts="-Wl,@${darshan_share}/darshan-base-ld-opts"
Cflags:
Libs:
-Libs.private: ${darshan_linkopts} ${darshan_libdir} -lfmpich -lmpichcxx -Wl,--start-group -ldarshan-mpi-io -ldarshan-posix -ldarshan-stubs -Wl,--end-group
+Libs.private: ${darshan_linkopts} ${darshan_libdir} -lfmpich -lmpichcxx -Wl,--start-group -ldarshan -ldarshan-stubs -Wl,--end-group
diff --git a/darshan-util/configure b/darshan-util/configure
index b96c730..05c9524 100755
--- a/darshan-util/configure
+++ b/darshan-util/configure
@@ -1,20 +1,18 @@
#! /bin/sh
# Guess values for system-dependent variables and create Makefiles.
-# Generated by GNU Autoconf 2.69 for darshan-util 3.0.0-pre1.
-# Copyright (C) 1992-1996, 1998-2012 Free Software Foundation, Inc.
+# Generated by GNU Autoconf 2.63 for darshan-util 3.0.0-pre1.
+# Copyright (C) 1992, 1993, 1994, 1995, 1996, 1998, 1999, 2000, 2001,
+# 2002, 2003, 2004, 2005, 2006, 2007, 2008 Free Software Foundation, Inc.
# This configure script is free software; the Free Software Foundation
# gives unlimited permission to copy, distribute and modify it.
emulate sh
NULLCMD=:
@@ -22,15 +20,23 @@ if test -n "${ZSH_VERSION+set}" && (emulate sh) >/dev/null 2>&1; then :
else
- *posix*) :
esac
fi
+# PATH needs CR
as_nl='
export as_nl
@@ -38,13 +44,7 @@ export as_nl
else
@@ -55,7 +55,7 @@ else
arg=$1;
- case $arg in #(
+ case $arg in
*"$as_nl"*)
@@ -78,6 +78,13 @@ if test "${PATH_SEPARATOR+set}" != set; then
fi
+ as_unset=unset
+else
+ as_unset=false
+fi
# IFS
@@ -87,16 +94,15 @@ fi
IFS=" "" $as_nl"
-as_myself=
-case $0 in #((
+case $0 in
for as_dir in $PATH
do
IFS=$as_save_IFS
test -z "$as_dir" && as_dir=.
- done
+done
IFS=$as_save_IFS
@@ -108,16 +114,12 @@ if test "x$as_myself" = x; then
fi
- exit 1
fi
done
PS1='$ '
PS2='> '
@@ -129,344 +131,330 @@ export LC_ALL
LANGUAGE=C
export LANGUAGE
+ as_expr=expr
+else
+ as_expr=false
+fi
+if (basename -- /) >/dev/null 2>&1 && test "X`basename -- / 2>&1`" = "X/"; then
+ as_basename=basename
+else
+ as_basename=false
+fi
+as_me=`$as_basename -- "$0" ||
+$as_expr X/"$0" : '.*/\([^/][^/]*\)/*$' \| \
+ X"$0" : 'X\(//\)$' \| \
+ X"$0" : 'X\(/\)' \| . 2>/dev/null ||
+$as_echo X/"$0" |
+ sed '/^.*\/\([^/][^/]*\)\/*$/{
+ s//\1/
+ q
+ /^X\/\(\/\/\)$/{
+ s//\1/
+ q
+ /^X\/\(\/\).*/{
+ s//\1/
+ q
+ s/.*/./; q'`
# CDPATH.
-# Use a proper internal environment variable to ensure we don't fall
- # into an infinite loop, continuously re-executing ourselves.
- if test x"${_as_can_reexec}" != xno && test "x$CONFIG_SHELL" != x; then
- _as_can_reexec=no; export _as_can_reexec;
- # We cannot yet assume a decent shell, so we have to provide a
-# neutralization value for shells without unset; and this also
-# works around shells that cannot unset nonexistent variables.
-# Preserve -v and -x to the replacement shell.
-BASH_ENV=/dev/null
-ENV=/dev/null
-(unset BASH_ENV) >/dev/null 2>&1 && unset BASH_ENV ENV
-case $- in # ((((
- *v*x* | *x*v* ) as_opts=-vx ;;
- *v* ) as_opts=-v ;;
- *x* ) as_opts=-x ;;
- * ) as_opts= ;;
-esac
-exec $CONFIG_SHELL $as_opts "$as_myself" ${1+"$@"}
-# Admittedly, this is quite paranoid, since all the known shells bail
-# out after a failed `exec'.
-$as_echo "$0: could not re-execute with $CONFIG_SHELL" >&2
-as_fn_exit 255
- fi
- # We don't want this to propagate to other subprocesses.
- { _as_can_reexec=; unset _as_can_reexec;}
+$as_unset CDPATH
if test "x$CONFIG_SHELL" = x; then
- as_bourne_compatible="if test -n \"\${ZSH_VERSION+set}\" && (emulate sh) >/dev/null 2>&1; then :
- emulate sh
- NULLCMD=:
- # Pre-4.2 versions of Zsh do word splitting on \${1+\"\$@\"}, which
- # is contrary to our usage. Disable this feature.
- alias -g '\${1+\"\$@\"}'='\"\$@\"'
- setopt NO_GLOB_SUBST
+ if (eval ":") 2>/dev/null; then
+ as_have_required=yes
else
- case \`(set -o) 2>/dev/null\` in #(
- *posix*) :
-esac
+ as_have_required=no
fi
- as_required="as_fn_return () { (exit \$1); }
-as_fn_success () { as_fn_return 0; }
-as_fn_failure () { as_fn_return 1; }
-as_fn_ret_success () { return 0; }
-as_fn_ret_failure () { return 1; }
+ if test $as_have_required = yes && (eval ":
+(as_func_return () {
+ (exit \$1)
+as_func_success () {
+ as_func_return 0
+as_func_failure () {
+ as_func_return 1
+as_func_ret_success () {
+ return 0
+as_func_ret_failure () {
+ return 1
exitcode=0
-as_fn_success || { exitcode=1; echo as_fn_success failed.; }
-as_fn_failure && { exitcode=1; echo as_fn_failure succeeded.; }
-as_fn_ret_success || { exitcode=1; echo as_fn_ret_success failed.; }
-as_fn_ret_failure && { exitcode=1; echo as_fn_ret_failure succeeded.; }
-if ( set x; as_fn_ret_success y && test x = \"\$1\" ); then :
-else
- exitcode=1; echo positional parameters were not saved.
-fi
-test x\$exitcode = x0 || exit 1
-test -x / || exit 1"
- as_suggested=" as_lineno_1=";as_suggested=$as_suggested$LINENO;as_suggested=$as_suggested" as_lineno_1a=\$LINENO
- as_lineno_2=";as_suggested=$as_suggested$LINENO;as_suggested=$as_suggested" as_lineno_2a=\$LINENO
- eval 'test \"x\$as_lineno_1'\$as_run'\" != \"x\$as_lineno_2'\$as_run'\" &&
- test \"x\`expr \$as_lineno_1'\$as_run' + 1\`\" = \"x\$as_lineno_2'\$as_run'\"' || exit 1
-test \$(( 1 + 1 )) = 2 || exit 1"
- if (eval "$as_required") 2>/dev/null; then :
- as_have_required=yes
+if as_func_success; then
else
- as_have_required=no
+ exitcode=1
+ echo as_func_success failed.
+fi
+if as_func_failure; then
+ exitcode=1
+ echo as_func_failure succeeded.
fi
- if test x$as_have_required = xyes && (eval "$as_suggested") 2>/dev/null; then :
+if as_func_ret_success; then
else
- as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
-as_found=false
+ exitcode=1
+ echo as_func_ret_success failed.
+fi
+if as_func_ret_failure; then
+ exitcode=1
+ echo as_func_ret_failure succeeded.
+fi
+if ( set x; as_func_ret_success y && test x = \"\$1\" ); then
+else
+ exitcode=1
+ echo positional parameters were not saved.
+fi
+test \$exitcode = 0) || { (exit 1); exit 1; }
+ as_lineno_1=\$LINENO
+ as_lineno_2=\$LINENO
+ test \"x\$as_lineno_1\" != \"x\$as_lineno_2\" &&
+ test \"x\`expr \$as_lineno_1 + 1\`\" = \"x\$as_lineno_2\") || { (exit 1); exit 1; }
+") 2> /dev/null; then
+else
+ as_candidate_shells=
+ as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
for as_dir in /bin$PATH_SEPARATOR/usr/bin$PATH_SEPARATOR$PATH
do
IFS=$as_save_IFS
- as_found=:
+ case $as_dir in
for as_base in sh bash ksh sh5; do
- # Try only shells that exist, to save several forks.
- as_shell=$as_dir/$as_base
- if { test -f "$as_shell" || test -f "$as_shell.exe"; } &&
- { $as_echo "$as_bourne_compatible""$as_required" | as_run=a "$as_shell"; } 2>/dev/null; then :
- CONFIG_SHELL=$as_shell as_have_required=yes
- if { $as_echo "$as_bourne_compatible""$as_suggested" | as_run=a "$as_shell"; } 2>/dev/null; then :
- break 2
-fi
-fi
+ as_candidate_shells="$as_candidate_shells $as_dir/$as_base"
done;;
esac
- as_found=false
done
-$as_found || { if { test -f "$SHELL" || test -f "$SHELL.exe"; } &&
- { $as_echo "$as_bourne_compatible""$as_required" | as_run=a "$SHELL"; } 2>/dev/null; then :
- CONFIG_SHELL=$SHELL as_have_required=yes
-fi; }
IFS=$as_save_IFS
- if test "x$CONFIG_SHELL" != x; then :
- export CONFIG_SHELL
-BASH_ENV=/dev/null
-ENV=/dev/null
-case $- in # ((((
- * ) as_opts= ;;
+ for as_shell in $as_candidate_shells $SHELL; do
+ # Try only shells that exist, to save several forks.
+ if { test -f "$as_shell" || test -f "$as_shell.exe"; } &&
+ { ("$as_shell") 2> /dev/null <<\_ASEOF
+ emulate sh
+ NULLCMD=:
+ # Pre-4.2 versions of Zsh do word splitting on ${1+"$@"}, which
+ # is contrary to our usage. Disable this feature.
+ alias -g '${1+"$@"}'='"$@"'
+ setopt NO_GLOB_SUBST
+else
esac
-exit 255
-fi
- if test x$as_have_required = xno; then :
- $as_echo "$0: This script requires a shell more modern than all"
- $as_echo "$0: the shells that I found on your system."
- if test x${ZSH_VERSION+set} = xset ; then
- $as_echo "$0: In particular, zsh $ZSH_VERSION has bugs and should"
- $as_echo "$0: be upgraded to zsh 4.3.4 or later."
- else
- $as_echo "$0: Please tell bug-autoconf at gnu.org about your system,
-$0: including any error possibly output before this
-$0: message. Then install a modern shell, or manually run
-$0: the script under such a shell if you do have one."
- fi
- exit 1
-fi
-fi
fi
-SHELL=${CONFIG_SHELL-/bin/sh}
-export SHELL
-# Unset more variables known to interfere with behavior of common tools.
-CLICOLOR_FORCE= GREP_OPTIONS=
-unset CLICOLOR_FORCE GREP_OPTIONS
-## M4sh Shell Functions. ##
-# as_fn_unset VAR
-as_fn_unset ()
- return $1
+_ASEOF
+}; then
+ CONFIG_SHELL=$as_shell
+ if { "$as_shell" 2> /dev/null <<\_ASEOF
+ emulate sh
+ NULLCMD=:
+else
+esac
-as_fn_exit ()
- set +e
- exit $1
-} # as_fn_exit
-# as_fn_mkdir_p
-as_fn_mkdir_p ()
+fi
- esac
- as_dirs=
- while :; do
- esac
- s//\1/
- q
- s//\1/
- q
- /^X\(\/\/\)$/{
- s//\1/
- q
- /^X\(\/\).*/{
- s//\1/
- q
- s/.*/./; q'`
- done
+ (exit $1)
+ as_func_return 0
+ as_func_return 1
+ return 0
+ return 1
-} # as_fn_mkdir_p
+exitcode=0
+else
+ exitcode=1
+fi
-# implementations.
- eval $1+=\$2
+ exitcode=1
+fi
else
- as_fn_append ()
- eval $1=\$$1\$2
-fi # as_fn_append
- as_val=$(( $* ))
+ exitcode=1
+fi
+ exitcode=1
+fi
+if ( set x; as_func_ret_success y && test x = "$1" ); then
else
- as_fn_arith ()
-fi # as_fn_arith
+ exitcode=1
+fi
+test $exitcode = 0) || { (exit 1); exit 1; }
-as_fn_error ()
- fi
-} # as_fn_error
+ test "x`expr $as_lineno_1 + 1`" = "x$as_lineno_2") || { (exit 1); exit 1; }
-if expr a : '\(a\)' >/dev/null 2>&1 &&
- test "X`expr 00001 : '.*\(...\)'`" = X001; then
- as_expr=expr
+_ASEOF
+}; then
+ break
+fi
+fi
+ done
+ if test "x$CONFIG_SHELL" != x; then
+ for as_var in BASH_ENV ENV
+ do ($as_unset $as_var) >/dev/null 2>&1 && $as_unset $as_var
+ done
+ export CONFIG_SHELL
+ exec "$CONFIG_SHELL" "$as_myself" ${1+"$@"}
+fi
+ if test $as_have_required = no; then
+ echo This script requires a shell more modern than all the
+ echo shells that I found on your system. Please install a
+ echo modern shell, or manually run the script under such a
+ echo shell if you do have one.
+fi
+fi
+fi
+(eval "as_func_return () {
+ (exit \$1)
+ as_func_return 0
+ as_func_return 1
+ return 0
+ return 1
+exitcode=0
else
- as_expr=false
+ exitcode=1
fi
-if (basename -- /) >/dev/null 2>&1 && test "X`basename -- / 2>&1`" = "X/"; then
- as_basename=basename
+ exitcode=1
+fi
else
- as_basename=false
+ exitcode=1
fi
+ exitcode=1
+fi
else
- as_dirname=false
+ exitcode=1
fi
-as_me=`$as_basename -- "$0" ||
-$as_expr X/"$0" : '.*/\([^/][^/]*\)/*$' \| \
- X"$0" : 'X\(//\)$' \| \
- X"$0" : 'X\(/\)' \| . 2>/dev/null ||
-$as_echo X/"$0" |
- sed '/^.*\/\([^/][^/]*\)\/*$/{
- s//\1/
- q
- /^X\/\(\/\/\)$/{
- s//\1/
- q
- /^X\/\(\/\).*/{
- s//\1/
- q
- s/.*/./; q'`
+test \$exitcode = 0") || {
+ echo No shell found that supports shell functions.
+ echo Please tell bug-autoconf at gnu.org about your system,
+ echo including any error possibly output before this message.
+ echo This can help us improve future autoconf versions.
+ echo Configuration will now proceed without shell functions.
- as_lineno_1=$LINENO as_lineno_1a=$LINENO
- as_lineno_2=$LINENO as_lineno_2a=$LINENO
- eval 'test "x$as_lineno_1'$as_run'" != "x$as_lineno_2'$as_run'" &&
- test "x`expr $as_lineno_1'$as_run' + 1`" = "x$as_lineno_2'$as_run'"' || {
- # Blame Lee E. McMahon (1931-1989) for sed's syntax. :-)
sed -n '
p
/[$]LINENO/=
@@ -483,12 +471,9 @@ as_cr_alnum=$as_cr_Letters$as_cr_digits
s/-\n.*//
' >$as_me.lineno &&
- { $as_echo "$as_me: error: cannot create $as_me.lineno; rerun with a POSIX shell" >&2; as_fn_exit 1; }
- # If we had to re-execute with $CONFIG_SHELL, we're ensured to have
- # already done that, so ensure we don't try to do so again and fall
- # in an infinite loop. This has already happened in practice.
@@ -497,18 +482,29 @@ as_cr_alnum=$as_cr_Letters$as_cr_digits
exit
+else
+ as_dirname=false
+fi
-n*)
- xy) ECHO_C='\c';;
- ECHO_T=' ';;
+ *) ECHO_C='\c';;
esac;;
ECHO_N='-n';;
esac
+ as_expr=expr
+else
+ as_expr=false
+fi
@@ -523,29 +519,49 @@ if (echo >conf$$.file) 2>/dev/null; then
- as_ln_s='cp -pR'
+ as_ln_s='cp -p'
as_ln_s=ln
else
- as_ln_s='cp -pR'
+ as_ln_s='cp -p'
fi
else
- as_ln_s='cp -pR'
+ as_ln_s='cp -p'
fi
+ as_mkdir_p=:
else
as_mkdir_p=false
fi
+else
+ as_ls_L_option=L
+ else
+ as_ls_L_option=
+ fi
+ as_test_x='
+ eval sh -c '\''
+ test -d "$1/.";
+ else
+ case $1 in
+ -*)set "./$1";;
+ esac;
+ '\'' sh
+fi
@@ -554,11 +570,11 @@ as_tr_cpp="eval sed 'y%*$as_cr_letters%P$as_cr_LETTERS%;s%[^_$as_cr_alnum]%_%g'"
-test -n "$DJDIR" || exec 7<&0 </dev/null
-exec 6>&1
+exec 7<&0 </dev/null 6>&1
# Name of the host.
-# hostname on some systems (SVR3.2, old GNU/Linux) returns a bogus exit status,
+# hostname on some systems (SVR3.2, Linux) returns a bogus exit status,
# so uname gets run too.
ac_hostname=`(hostname || uname -n) 2>/dev/null | sed 1q`
@@ -573,6 +589,7 @@ cross_compiling=no
subdirs=
MFLAGS=
MAKEFLAGS=
+SHELL=${CONFIG_SHELL-/bin/sh}
# Identity of this package.
PACKAGE_NAME='darshan-util'
@@ -580,7 +597,6 @@ PACKAGE_TARNAME='darshan-util'
PACKAGE_VERSION='3.0.0-pre1'
PACKAGE_STRING='darshan-util 3.0.0-pre1'
PACKAGE_BUGREPORT=''
-PACKAGE_URL=''
ac_unique_file="darshan-logutils.h"
# Factoring default headers for most tests.
@@ -672,7 +688,6 @@ bindir
program_transform_name
prefix
exec_prefix
-PACKAGE_URL
PACKAGE_BUGREPORT
PACKAGE_STRING
PACKAGE_VERSION
@@ -758,9 +773,8 @@ do
fi
case $ac_option in
- *=?*) ac_optarg=`expr "X$ac_option" : '[^=]*=\(.*\)'` ;;
- *=) ac_optarg= ;;
- *) ac_optarg=yes ;;
+ *=*) ac_optarg=`expr "X$ac_option" : '[^=]*=\(.*\)'` ;;
+ *) ac_optarg=yes ;;
esac
# Accept the important Cygnus configure options, so we can diagnose typos.
@@ -805,7 +819,8 @@ do
ac_useropt=`expr "x$ac_option" : 'x-*disable-\(.*\)'`
# Reject names that are not valid shell variable names.
expr "x$ac_useropt" : ".*[^-+._$as_cr_alnum]" >/dev/null &&
- as_fn_error $? "invalid feature name: $ac_useropt"
+ { $as_echo "$as_me: error: invalid feature name: $ac_useropt" >&2
ac_useropt_orig=$ac_useropt
ac_useropt=`$as_echo "$ac_useropt" | sed 's/[-+.]/_/g'`
case $ac_user_opts in
@@ -831,7 +846,8 @@ do
ac_useropt=`expr "x$ac_option" : 'x-*enable-\([^=]*\)'`
@@ -1035,7 +1051,8 @@ do
ac_useropt=`expr "x$ac_option" : 'x-*with-\([^=]*\)'`
- as_fn_error $? "invalid package name: $ac_useropt"
+ { $as_echo "$as_me: error: invalid package name: $ac_useropt" >&2
@@ -1051,7 +1068,8 @@ do
ac_useropt=`expr "x$ac_option" : 'x-*without-\(.*\)'`
@@ -1081,17 +1099,17 @@ do
| --x-librar=* | --x-libra=* | --x-libr=* | --x-lib=* | --x-li=* | --x-l=*)
x_libraries=$ac_optarg ;;
- -*) as_fn_error $? "unrecognized option: \`$ac_option'
-Try \`$0 --help' for more information"
+ -*) { $as_echo "$as_me: error: unrecognized option: $ac_option
ac_envvar=`expr "x$ac_option" : 'x\([^=]*\)='`
- case $ac_envvar in #(
- '' | [0-9]* | *[!_$as_cr_alnum]* )
- as_fn_error $? "invalid variable name: \`$ac_envvar'" ;;
- esac
+ expr "x$ac_envvar" : ".*[^_$as_cr_alnum]" >/dev/null &&
+ { $as_echo "$as_me: error: invalid variable name: $ac_envvar" >&2
eval $ac_envvar=\$ac_optarg
export $ac_envvar ;;
@@ -1100,7 +1118,7 @@ Try \`$0 --help' for more information"
$as_echo "$as_me: WARNING: you should use --build, --host, --target" >&2
expr "x$ac_option" : ".*[^-._$as_cr_alnum]" >/dev/null &&
$as_echo "$as_me: WARNING: invalid host type: $ac_option" >&2
- : "${build_alias=$ac_option} ${host_alias=$ac_option} ${target_alias=$ac_option}"
+ : ${build_alias=$ac_option} ${host_alias=$ac_option} ${target_alias=$ac_option}
esac
@@ -1108,13 +1126,15 @@ done
ac_option=--`echo $ac_prev | sed 's/_/-/g'`
- as_fn_error $? "missing argument to $ac_option"
+ { $as_echo "$as_me: error: missing argument to $ac_option" >&2
fi
if test -n "$ac_unrecognized_opts"; then
case $enable_option_checking in
no) ;;
- fatal) as_fn_error $? "unrecognized options: $ac_unrecognized_opts" ;;
+ fatal) { $as_echo "$as_me: error: unrecognized options: $ac_unrecognized_opts" >&2
*) $as_echo "$as_me: WARNING: unrecognized options: $ac_unrecognized_opts" >&2 ;;
esac
fi
@@ -1137,7 +1157,8 @@ do
[\\/$]* | ?:[\\/]* ) continue;;
NONE | '' ) case $ac_var in *prefix ) continue;; esac;;
esac
- as_fn_error $? "expected an absolute directory name for --$ac_var: $ac_val"
+ { $as_echo "$as_me: error: expected an absolute directory name for --$ac_var: $ac_val" >&2
done
# There might be people who depend on the old broken behavior: `$host'
@@ -1151,6 +1172,8 @@ target=$target_alias
if test "x$host_alias" != x; then
if test "x$build_alias" = x; then
cross_compiling=maybe
+ $as_echo "$as_me: WARNING: If you wanted to set the --build type, don't use --host.
+ If a cross compiler is detected then cross compile mode will be used." >&2
elif test "x$build_alias" != "x$host_alias"; then
cross_compiling=yes
fi
@@ -1165,9 +1188,11 @@ test "$silent" = yes && exec 6>/dev/null
ac_pwd=`pwd` && test -n "$ac_pwd" &&
ac_ls_di=`ls -di .` &&
ac_pwd_ls_di=`cd "$ac_pwd" && ls -di .` ||
- as_fn_error $? "working directory cannot be determined"
+ { $as_echo "$as_me: error: working directory cannot be determined" >&2
test "X$ac_ls_di" = "X$ac_pwd_ls_di" ||
- as_fn_error $? "pwd does not report name of working directory"
+ { $as_echo "$as_me: error: pwd does not report name of working directory" >&2
# Find the source files, if location was not specified.
@@ -1206,11 +1231,13 @@ else
fi
if test ! -r "$srcdir/$ac_unique_file"; then
test "$ac_srcdir_defaulted" = yes && srcdir="$ac_confdir or .."
- as_fn_error $? "cannot find sources ($ac_unique_file) in $srcdir"
+ { $as_echo "$as_me: error: cannot find sources ($ac_unique_file) in $srcdir" >&2
fi
ac_msg="sources are in $srcdir, but \`cd $srcdir' does not work"
ac_abs_confdir=`(
- cd "$srcdir" && test -r "./$ac_unique_file" || as_fn_error $? "$ac_msg"
+ cd "$srcdir" && test -r "./$ac_unique_file" || { $as_echo "$as_me: error: $ac_msg" >&2
pwd)`
# When building in place, set srcdir=.
if test "$ac_abs_confdir" = "$ac_pwd"; then
@@ -1250,7 +1277,7 @@ Configuration:
--help=short display options specific to this package
--help=recursive display the short help of all the included packages
-V, --version display version information and exit
- -q, --quiet, --silent do not print \`checking ...' messages
+ -q, --quiet, --silent do not print \`checking...' messages
--cache-file=FILE cache test results in FILE [disabled]
-C, --config-cache alias for \`--cache-file=config.cache'
-n, --no-create do not create output files
@@ -1323,14 +1350,13 @@ Some influential environment variables:
LDFLAGS linker flags, e.g. -L<lib dir> if you have libraries in a
nonstandard directory <lib dir>
LIBS libraries to pass to the linker, e.g. -l<library>
- CPPFLAGS (Objective) C/C++ preprocessor flags, e.g. -I<include dir> if
+ CPPFLAGS C/C++/Objective C preprocessor flags, e.g. -I<include dir> if
you have headers in a nonstandard directory <include dir>
CPP C preprocessor
Use these variables to override the choices made by `configure' or to help
it to find libraries and programs with nonstandard names/locations.
_ACEOF
ac_status=$?
fi
@@ -1394,372 +1420,21 @@ test -n "$ac_init_help" && exit $ac_status
if $ac_init_version; then
cat <<\_ACEOF
darshan-util configure 3.0.0-pre1
+Copyright (C) 1992, 1993, 1994, 1995, 1996, 1998, 1999, 2000, 2001,
+2002, 2003, 2004, 2005, 2006, 2007, 2008 Free Software Foundation, Inc.
_ACEOF
exit
fi
-## Autoconf initialization. ##
-# ac_fn_c_try_compile LINENO
-# Try to compile conftest.$ac_ext, and return whether this succeeded.
-ac_fn_c_try_compile ()
- as_lineno=${as_lineno-"$1"} as_lineno_stack=as_lineno_stack=$as_lineno_stack
- rm -f conftest.$ac_objext
- if { { ac_try="$ac_compile"
-case "(($ac_try" in
- *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;;
- *) ac_try_echo=$ac_try;;
-esac
-eval ac_try_echo="\"\$as_me:${as_lineno-$LINENO}: $ac_try_echo\""
-$as_echo "$ac_try_echo"; } >&5
- (eval "$ac_compile") 2>conftest.err
- ac_status=$?
- if test -s conftest.err; then
- grep -v '^ *+' conftest.err >conftest.er1
- cat conftest.er1 >&5
- mv -f conftest.er1 conftest.err
- fi
- $as_echo "$as_me:${as_lineno-$LINENO}: \$? = $ac_status" >&5
- test $ac_status = 0; } && {
- test -z "$ac_c_werror_flag" ||
- test ! -s conftest.err
- } && test -s conftest.$ac_objext; then :
- ac_retval=0
-else
- $as_echo "$as_me: failed program was:" >&5
-sed 's/^/| /' conftest.$ac_ext >&5
- ac_retval=1
-fi
- eval $as_lineno_stack; ${as_lineno_stack:+:} unset as_lineno
- as_fn_set_status $ac_retval
-} # ac_fn_c_try_compile
-# ac_fn_c_try_cpp LINENO
-# Try to preprocess conftest.$ac_ext, and return whether this succeeded.
-ac_fn_c_try_cpp ()
- if { { ac_try="$ac_cpp conftest.$ac_ext"
-esac
- (eval "$ac_cpp conftest.$ac_ext") 2>conftest.err
- ac_status=$?
- fi
- test $ac_status = 0; } > conftest.i && {
- test -z "$ac_c_preproc_warn_flag$ac_c_werror_flag" ||
- }; then :
- ac_retval=0
-else
- ac_retval=1
-fi
-} # ac_fn_c_try_cpp
-# ac_fn_c_check_header_mongrel LINENO HEADER VAR INCLUDES
-# Tests whether HEADER exists, giving a warning if it cannot be compiled using
-# the include files in INCLUDES and setting the cache variable VAR
-# accordingly.
-ac_fn_c_check_header_mongrel ()
- if eval \${$3+:} false; then :
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking for $2" >&5
-$as_echo_n "checking for $2... " >&6; }
-if eval \${$3+:} false; then :
- $as_echo_n "(cached) " >&6
-fi
-eval ac_res=\$$3
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_res" >&5
-$as_echo "$ac_res" >&6; }
-else
- # Is the header compilable?
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking $2 usability" >&5
-$as_echo_n "checking $2 usability... " >&6; }
-cat confdefs.h - <<_ACEOF >conftest.$ac_ext
-/* end confdefs.h. */
-$4
-#include <$2>
-_ACEOF
-if ac_fn_c_try_compile "$LINENO"; then :
- ac_header_compiler=yes
-else
- ac_header_compiler=no
-fi
-rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_header_compiler" >&5
-$as_echo "$ac_header_compiler" >&6; }
-# Is the header present?
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking $2 presence" >&5
-$as_echo_n "checking $2 presence... " >&6; }
-#include <$2>
-_ACEOF
-if ac_fn_c_try_cpp "$LINENO"; then :
- ac_header_preproc=yes
-else
- ac_header_preproc=no
-fi
-rm -f conftest.err conftest.i conftest.$ac_ext
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_header_preproc" >&5
-$as_echo "$ac_header_preproc" >&6; }
-# So? What about this header?
-case $ac_header_compiler:$ac_header_preproc:$ac_c_preproc_warn_flag in #((
- yes:no: )
- { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: $2: accepted by the compiler, rejected by the preprocessor!" >&5
-$as_echo "$as_me: WARNING: $2: accepted by the compiler, rejected by the preprocessor!" >&2;}
- { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: $2: proceeding with the compiler's result" >&5
-$as_echo "$as_me: WARNING: $2: proceeding with the compiler's result" >&2;}
- no:yes:* )
- { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: $2: present but cannot be compiled" >&5
-$as_echo "$as_me: WARNING: $2: present but cannot be compiled" >&2;}
- { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: $2: check for missing prerequisite headers?" >&5
-$as_echo "$as_me: WARNING: $2: check for missing prerequisite headers?" >&2;}
- { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: $2: see the Autoconf documentation" >&5
-$as_echo "$as_me: WARNING: $2: see the Autoconf documentation" >&2;}
- { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: $2: section \"Present But Cannot Be Compiled\"" >&5
-$as_echo "$as_me: WARNING: $2: section \"Present But Cannot Be Compiled\"" >&2;}
-esac
-else
- eval "$3=\$ac_header_compiler"
-fi
-eval ac_res=\$$3
-fi
-} # ac_fn_c_check_header_mongrel
-# ac_fn_c_try_run LINENO
-# Try to link conftest.$ac_ext, and return whether this succeeded. Assumes
-# that executables *can* be run.
-ac_fn_c_try_run ()
- if { { ac_try="$ac_link"
-esac
- (eval "$ac_link") 2>&5
- ac_status=$?
- test $ac_status = 0; } && { ac_try='./conftest$ac_exeext'
- { { case "(($ac_try" in
-esac
- (eval "$ac_try") 2>&5
- ac_status=$?
- test $ac_status = 0; }; }; then :
- ac_retval=0
-else
- $as_echo "$as_me: program exited with status $ac_status" >&5
- ac_retval=$ac_status
-fi
- rm -rf conftest.dSYM conftest_ipa8_conftest.oo
-} # ac_fn_c_try_run
-# ac_fn_c_check_header_compile LINENO HEADER VAR INCLUDES
-# Tests whether HEADER exists and can be compiled using the include files in
-# INCLUDES, setting the cache variable VAR accordingly.
-ac_fn_c_check_header_compile ()
-else
- cat confdefs.h - <<_ACEOF >conftest.$ac_ext
-$4
-#include <$2>
-_ACEOF
- eval "$3=yes"
-else
- eval "$3=no"
-fi
-fi
-eval ac_res=\$$3
-} # ac_fn_c_check_header_compile
-# ac_fn_c_try_link LINENO
-ac_fn_c_try_link ()
- rm -f conftest.$ac_objext conftest$ac_exeext
-esac
- (eval "$ac_link") 2>conftest.err
- ac_status=$?
- fi
- } && test -s conftest$ac_exeext && {
- test "$cross_compiling" = yes ||
- test -x conftest$ac_exeext
- }; then :
- ac_retval=0
-else
- ac_retval=1
-fi
- # Delete the IPA/IPO (Inter Procedural Analysis/Optimization) information
- # created by the PGI compiler (conftest_ipa8_conftest.oo), as it would
- # interfere with the next link command; also delete a directory that is
- # left behind by Apple's compiler. We do this before executing the actions.
-} # ac_fn_c_try_link
-# ac_fn_c_check_func LINENO FUNC VAR
-# Tests whether FUNC exists, setting the cache variable VAR accordingly
-ac_fn_c_check_func ()
-else
-/* Define $2 to an innocuous variant, in case <limits.h> declares $2.
- For example, HP-UX 11i <limits.h> declares gettimeofday. */
-#define $2 innocuous_$2
-/* System header to define __stub macros and hopefully few prototypes,
- which can conflict with char $2 (); below.
- Prefer <limits.h> to <assert.h> if __STDC__ is defined, since
- <limits.h> exists even on freestanding compilers. */
-#ifdef __STDC__
-# include <limits.h>
-#else
-# include <assert.h>
-#endif
-#undef $2
-/* Override any GCC internal prototype to avoid an error.
- Use char because int might match the return type of a GCC
- builtin and then its argument prototype would still apply. */
-#ifdef __cplusplus
-extern "C"
-#endif
-char $2 ();
-/* The GNU C library defines this for functions which it implements
- to always fail with ENOSYS. Some functions are actually named
- something starting with __ and the normal name is an alias. */
-#if defined __stub_$2 || defined __stub___$2
-choke me
-#endif
-int
-main ()
-return $2 ();
- return 0;
-_ACEOF
-if ac_fn_c_try_link "$LINENO"; then :
- eval "$3=yes"
-else
- eval "$3=no"
-fi
-rm -f core conftest.err conftest.$ac_objext \
- conftest$ac_exeext conftest.$ac_ext
-fi
-eval ac_res=\$$3
-} # ac_fn_c_check_func
cat >config.log <<_ACEOF
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
It was created by darshan-util $as_me 3.0.0-pre1, which was
$ $0 $@
@@ -1795,8 +1470,8 @@ for as_dir in $PATH
do
IFS=$as_save_IFS
- $as_echo "PATH: $as_dir"
- done
+ $as_echo "PATH: $as_dir"
+done
IFS=$as_save_IFS
} >&5
@@ -1833,9 +1508,9 @@ do
ac_arg=`$as_echo "$ac_arg" | sed "s/'/'\\\\\\\\''/g"` ;;
esac
case $ac_pass in
- 1) as_fn_append ac_configure_args0 " '$ac_arg'" ;;
+ 1) ac_configure_args0="$ac_configure_args0 '$ac_arg'" ;;
2)
- as_fn_append ac_configure_args1 " '$ac_arg'"
+ ac_configure_args1="$ac_configure_args1 '$ac_arg'"
if test $ac_must_keep_next = true; then
ac_must_keep_next=false # Got value, back to normal.
else
@@ -1851,13 +1526,13 @@ do
-* ) ac_must_keep_next=true ;;
esac
fi
- as_fn_append ac_configure_args " '$ac_arg'"
+ ac_configure_args="$ac_configure_args '$ac_arg'"
esac
done
done
-{ ac_configure_args0=; unset ac_configure_args0;}
-{ ac_configure_args1=; unset ac_configure_args1;}
+$as_unset ac_configure_args0 || test "${ac_configure_args0+set}" != set || { ac_configure_args0=; export ac_configure_args0; }
+$as_unset ac_configure_args1 || test "${ac_configure_args1+set}" != set || { ac_configure_args1=; export ac_configure_args1; }
# When interrupted or exit'd, cleanup temporary files, and complete
# config.log. We remove comments because anyway the quotes in there
@@ -1869,9 +1544,11 @@ trap 'exit_status=$?
echo
- $as_echo "## ---------------- ##
+ cat <<\_ASBOX
## Cache variables. ##
+_ASBOX
echo
# The following way of writing the cache mishandles newlines in values,
@@ -1880,13 +1557,13 @@ trap 'exit_status=$?
case $ac_val in #(
*${as_nl}*)
case $ac_var in #(
- *_cv_*) { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: cache variable $ac_var contains a newline" >&5
+ *_cv_*) { $as_echo "$as_me:$LINENO: WARNING: cache variable $ac_var contains a newline" >&5
$as_echo "$as_me: WARNING: cache variable $ac_var contains a newline" >&2;} ;;
esac
case $ac_var in #(
_ | IFS | as_nl) ;; #(
BASH_ARGV | BASH_SOURCE) eval $ac_var= ;; #(
- *) { eval $ac_var=; unset $ac_var;} ;;
+ *) $as_unset $ac_var ;;
esac ;;
esac
done
@@ -1905,9 +1582,11 @@ $as_echo "$as_me: WARNING: cache variable $ac_var contains a newline" >&2;} ;;
echo
- $as_echo "## ----------------- ##
+ cat <<\_ASBOX
## Output variables. ##
+_ASBOX
echo
for ac_var in $ac_subst_vars
do
@@ -1920,9 +1599,11 @@ $as_echo "$as_me: WARNING: cache variable $ac_var contains a newline" >&2;} ;;
echo
if test -n "$ac_subst_files"; then
- $as_echo "## ------------------- ##
+ cat <<\_ASBOX
## File substitutions. ##
+_ASBOX
echo
for ac_var in $ac_subst_files
do
@@ -1936,9 +1617,11 @@ $as_echo "$as_me: WARNING: cache variable $ac_var contains a newline" >&2;} ;;
fi
if test -s confdefs.h; then
- $as_echo "## ----------- ##
+ cat <<\_ASBOX
## confdefs.h. ##
+_ASBOX
echo
cat confdefs.h
echo
@@ -1952,39 +1635,37 @@ $as_echo "$as_me: WARNING: cache variable $ac_var contains a newline" >&2;} ;;
exit $exit_status
' 0
for ac_signal in 1 2 13 15; do
- trap 'ac_signal='$ac_signal'; as_fn_exit 1' $ac_signal
+ trap 'ac_signal='$ac_signal'; { (exit 1); exit 1; }' $ac_signal
done
ac_signal=0
# confdefs.h avoids OS command line length limits that DEFS can exceed.
rm -f -r conftest* confdefs.h
-$as_echo "/* confdefs.h */" > confdefs.h
# Predefined preprocessor variables.
cat >>confdefs.h <<_ACEOF
#define PACKAGE_NAME "$PACKAGE_NAME"
_ACEOF
#define PACKAGE_TARNAME "$PACKAGE_TARNAME"
_ACEOF
#define PACKAGE_VERSION "$PACKAGE_VERSION"
_ACEOF
#define PACKAGE_STRING "$PACKAGE_STRING"
_ACEOF
-cat >>confdefs.h <<_ACEOF
-#define PACKAGE_BUGREPORT "$PACKAGE_BUGREPORT"
-_ACEOF
-#define PACKAGE_URL "$PACKAGE_URL"
+#define PACKAGE_BUGREPORT "$PACKAGE_BUGREPORT"
_ACEOF
@@ -1993,12 +1674,7 @@ _ACEOF
ac_site_file1=NONE
ac_site_file2=NONE
if test -n "$CONFIG_SITE"; then
- # We do not want a PATH search for config.site.
- case $CONFIG_SITE in #((
- -*) ac_site_file1=./$CONFIG_SITE;;
- */*) ac_site_file1=$CONFIG_SITE;;
- *) ac_site_file1=./$CONFIG_SITE;;
- esac
+ ac_site_file1=$CONFIG_SITE
elif test "x$prefix" != xNONE; then
ac_site_file1=$prefix/share/config.site
ac_site_file2=$prefix/etc/config.site
@@ -2009,23 +1685,19 @@ fi
for ac_site_file in "$ac_site_file1" "$ac_site_file2"
do
test "x$ac_site_file" = xNONE && continue
- if test /dev/null != "$ac_site_file" && test -r "$ac_site_file"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: loading site script $ac_site_file" >&5
+ if test -r "$ac_site_file"; then
+ { $as_echo "$as_me:$LINENO: loading site script $ac_site_file" >&5
$as_echo "$as_me: loading site script $ac_site_file" >&6;}
sed 's/^/| /' "$ac_site_file" >&5
- . "$ac_site_file" \
- || { { $as_echo "$as_me:${as_lineno-$LINENO}: error: in \`$ac_pwd':" >&5
-$as_echo "$as_me: error: in \`$ac_pwd':" >&2;}
-as_fn_error $? "failed to load site script $ac_site_file
-See \`config.log' for more details" "$LINENO" 5; }
+ . "$ac_site_file"
fi
done
if test -r "$cache_file"; then
- # Some versions of bash will fail to source /dev/null (special files
- # actually), so we avoid doing that. DJGPP emulates it as a regular file.
- if test /dev/null != "$cache_file" && test -f "$cache_file"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: loading cache $cache_file" >&5
+ # Some versions of bash will fail to source /dev/null (special
+ # files actually), so we avoid doing that.
+ if test -f "$cache_file"; then
+ { $as_echo "$as_me:$LINENO: loading cache $cache_file" >&5
$as_echo "$as_me: loading cache $cache_file" >&6;}
case $cache_file in
[\\/]* | ?:[\\/]* ) . "$cache_file";;
@@ -2033,7 +1705,7 @@ $as_echo "$as_me: loading cache $cache_file" >&6;}
esac
fi
else
- { $as_echo "$as_me:${as_lineno-$LINENO}: creating cache $cache_file" >&5
+ { $as_echo "$as_me:$LINENO: creating cache $cache_file" >&5
$as_echo "$as_me: creating cache $cache_file" >&6;}
>$cache_file
fi
@@ -2048,11 +1720,11 @@ for ac_var in $ac_precious_vars; do
eval ac_new_val=\$ac_env_${ac_var}_value
case $ac_old_set,$ac_new_set in
set,)
- { $as_echo "$as_me:${as_lineno-$LINENO}: error: \`$ac_var' was set to \`$ac_old_val' in the previous run" >&5
+ { $as_echo "$as_me:$LINENO: error: \`$ac_var' was set to \`$ac_old_val' in the previous run" >&5
$as_echo "$as_me: error: \`$ac_var' was set to \`$ac_old_val' in the previous run" >&2;}
ac_cache_corrupted=: ;;
,set)
- { $as_echo "$as_me:${as_lineno-$LINENO}: error: \`$ac_var' was not set in the previous run" >&5
+ { $as_echo "$as_me:$LINENO: error: \`$ac_var' was not set in the previous run" >&5
$as_echo "$as_me: error: \`$ac_var' was not set in the previous run" >&2;}
@@ -2062,17 +1734,17 @@ $as_echo "$as_me: error: \`$ac_var' was not set in the previous run" >&2;}
ac_old_val_w=`echo x $ac_old_val`
ac_new_val_w=`echo x $ac_new_val`
if test "$ac_old_val_w" != "$ac_new_val_w"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: error: \`$ac_var' has changed since the previous run:" >&5
+ { $as_echo "$as_me:$LINENO: error: \`$ac_var' has changed since the previous run:" >&5
$as_echo "$as_me: error: \`$ac_var' has changed since the previous run:" >&2;}
else
- { $as_echo "$as_me:${as_lineno-$LINENO}: warning: ignoring whitespace changes in \`$ac_var' since the previous run:" >&5
+ { $as_echo "$as_me:$LINENO: warning: ignoring whitespace changes in \`$ac_var' since the previous run:" >&5
$as_echo "$as_me: warning: ignoring whitespace changes in \`$ac_var' since the previous run:" >&2;}
eval $ac_var=\$ac_old_val
fi
- { $as_echo "$as_me:${as_lineno-$LINENO}: former value: \`$ac_old_val'" >&5
+ { $as_echo "$as_me:$LINENO: former value: \`$ac_old_val'" >&5
$as_echo "$as_me: former value: \`$ac_old_val'" >&2;}
- { $as_echo "$as_me:${as_lineno-$LINENO}: current value: \`$ac_new_val'" >&5
+ { $as_echo "$as_me:$LINENO: current value: \`$ac_new_val'" >&5
$as_echo "$as_me: current value: \`$ac_new_val'" >&2;}
fi;;
esac
@@ -2084,20 +1756,43 @@ $as_echo "$as_me: current value: \`$ac_new_val'" >&2;}
esac
case " $ac_configure_args " in
*" '$ac_arg' "*) ;; # Avoid dups. Use of quotes ensures accuracy.
- *) as_fn_append ac_configure_args " '$ac_arg'" ;;
+ *) ac_configure_args="$ac_configure_args '$ac_arg'" ;;
esac
fi
done
if $ac_cache_corrupted; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: error: in \`$ac_pwd':" >&5
+ { $as_echo "$as_me:$LINENO: error: in \`$ac_pwd':" >&5
- { $as_echo "$as_me:${as_lineno-$LINENO}: error: changes in the environment can compromise the build" >&5
+ { $as_echo "$as_me:$LINENO: error: changes in the environment can compromise the build" >&5
$as_echo "$as_me: error: changes in the environment can compromise the build" >&2;}
- as_fn_error $? "run \`make distclean' and/or \`rm $cache_file' and start over" "$LINENO" 5
+ { { $as_echo "$as_me:$LINENO: error: run \`make distclean' and/or \`rm $cache_file' and start over" >&5
+$as_echo "$as_me: error: run \`make distclean' and/or \`rm $cache_file' and start over" >&2;}
fi
-## Main body of script. ##
ac_ext=c
ac_cpp='$CPP $CPPFLAGS'
@@ -2124,7 +1819,9 @@ for ac_dir in ../maint/config "$srcdir"/../maint/config; do
fi
done
if test -z "$ac_aux_dir"; then
- as_fn_error $? "cannot find install-sh, install.sh, or shtool in ../maint/config \"$srcdir\"/../maint/config" "$LINENO" 5
+ { { $as_echo "$as_me:$LINENO: error: cannot find install-sh or install.sh in ../maint/config \"$srcdir\"/../maint/config" >&5
+$as_echo "$as_me: error: cannot find install-sh or install.sh in ../maint/config \"$srcdir\"/../maint/config" >&2;}
fi
# These three variables are undocumented and unsupported,
@@ -2153,10 +1850,10 @@ ac_config_headers="$ac_config_headers darshan-util-config.h"
# OS/2's system install, which has a completely different semantic
# ./install, which can be erroneously created by make from ./install.sh.
# Reject install programs that cannot install multiple files.
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for a BSD-compatible install" >&5
+{ $as_echo "$as_me:$LINENO: checking for a BSD-compatible install" >&5
$as_echo_n "checking for a BSD-compatible install... " >&6; }
if test -z "$INSTALL"; then
-if ${ac_cv_path_install+:} false; then :
+if test "${ac_cv_path_install+set}" = set; then
else
@@ -2164,11 +1861,11 @@ for as_dir in $PATH
do
IFS=$as_save_IFS
- # Account for people who put trailing slashes in PATH elements.
-case $as_dir/ in #((
- ./ | .// | /[cC]/* | \
+ # Account for people who put trailing slashes in PATH elements.
+case $as_dir/ in
+ ./ | .// | /cC/* | \
/etc/* | /usr/sbin/* | /usr/etc/* | /sbin/* | /usr/afsws/bin/* | \
- ?:[\\/]os2[\\/]install[\\/]* | ?:[\\/]OS2[\\/]INSTALL[\\/]* | \
+ ?:\\/os2\\/install\\/* | ?:\\/OS2\\/INSTALL\\/* | \
/usr/ucb/* ) ;;
# OSF1 and SCO ODT 3.0 have their own names for install.
@@ -2176,7 +1873,7 @@ case $as_dir/ in #((
# by default.
for ac_prog in ginstall scoinst install; do
for ac_exec_ext in '' $ac_executable_extensions; do
- if as_fn_executable_p "$as_dir/$ac_prog$ac_exec_ext"; then
+ if { test -f "$as_dir/$ac_prog$ac_exec_ext" && $as_test_x "$as_dir/$ac_prog$ac_exec_ext"; }; then
if test $ac_prog = install &&
grep dspmsg "$as_dir/$ac_prog$ac_exec_ext" >/dev/null 2>&1; then
# AIX install. It has an incompatible calling convention.
@@ -2205,7 +1902,7 @@ case $as_dir/ in #((
esac
- done
+done
IFS=$as_save_IFS
rm -rf conftest.one conftest.two conftest.dir
@@ -2221,7 +1918,7 @@ fi
INSTALL=$ac_install_sh
fi
fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $INSTALL" >&5
+{ $as_echo "$as_me:$LINENO: result: $INSTALL" >&5
$as_echo "$INSTALL" >&6; }
# Use test -z because SunOS4 sh mishandles braces in ${var-val}.
@@ -2241,9 +1938,9 @@ ac_compiler_gnu=$ac_cv_c_compiler_gnu
if test -n "$ac_tool_prefix"; then
# Extract the first word of "${ac_tool_prefix}gcc", so it can be a program name with args.
set dummy ${ac_tool_prefix}gcc; ac_word=$2
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for $ac_word" >&5
+{ $as_echo "$as_me:$LINENO: checking for $ac_word" >&5
$as_echo_n "checking for $ac_word... " >&6; }
-if ${ac_cv_prog_CC+:} false; then :
+if test "${ac_cv_prog_CC+set}" = set; then
else
if test -n "$CC"; then
@@ -2254,24 +1951,24 @@ for as_dir in $PATH
do
IFS=$as_save_IFS
- for ac_exec_ext in '' $ac_executable_extensions; do
- if as_fn_executable_p "$as_dir/$ac_word$ac_exec_ext"; then
+ for ac_exec_ext in '' $ac_executable_extensions; do
+ if { test -f "$as_dir/$ac_word$ac_exec_ext" && $as_test_x "$as_dir/$ac_word$ac_exec_ext"; }; then
ac_cv_prog_CC="${ac_tool_prefix}gcc"
- $as_echo "$as_me:${as_lineno-$LINENO}: found $as_dir/$ac_word$ac_exec_ext" >&5
+ $as_echo "$as_me:$LINENO: found $as_dir/$ac_word$ac_exec_ext" >&5
break 2
fi
done
- done
+done
IFS=$as_save_IFS
fi
fi
CC=$ac_cv_prog_CC
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $CC" >&5
+ { $as_echo "$as_me:$LINENO: result: $CC" >&5
$as_echo "$CC" >&6; }
else
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: no" >&5
+ { $as_echo "$as_me:$LINENO: result: no" >&5
$as_echo "no" >&6; }
fi
@@ -2281,9 +1978,9 @@ if test -z "$ac_cv_prog_CC"; then
ac_ct_CC=$CC
# Extract the first word of "gcc", so it can be a program name with args.
set dummy gcc; ac_word=$2
-if ${ac_cv_prog_ac_ct_CC+:} false; then :
+if test "${ac_cv_prog_ac_ct_CC+set}" = set; then
else
if test -n "$ac_ct_CC"; then
@@ -2294,24 +1991,24 @@ for as_dir in $PATH
do
IFS=$as_save_IFS
ac_cv_prog_ac_ct_CC="gcc"
break 2
fi
done
- done
+done
IFS=$as_save_IFS
fi
fi
ac_ct_CC=$ac_cv_prog_ac_ct_CC
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_ct_CC" >&5
+ { $as_echo "$as_me:$LINENO: result: $ac_ct_CC" >&5
$as_echo "$ac_ct_CC" >&6; }
else
fi
@@ -2320,7 +2017,7 @@ fi
else
case $cross_compiling:$ac_tool_warned in
yes:)
-{ $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: using cross tools not prefixed with host triplet" >&5
+{ $as_echo "$as_me:$LINENO: WARNING: using cross tools not prefixed with host triplet" >&5
$as_echo "$as_me: WARNING: using cross tools not prefixed with host triplet" >&2;}
ac_tool_warned=yes ;;
esac
@@ -2334,9 +2031,9 @@ if test -z "$CC"; then
# Extract the first word of "${ac_tool_prefix}cc", so it can be a program name with args.
set dummy ${ac_tool_prefix}cc; ac_word=$2
else
@@ -2347,24 +2044,24 @@ for as_dir in $PATH
do
IFS=$as_save_IFS
ac_cv_prog_CC="${ac_tool_prefix}cc"
break 2
fi
done
- done
+done
IFS=$as_save_IFS
fi
fi
CC=$ac_cv_prog_CC
else
fi
@@ -2374,9 +2071,9 @@ fi
# Extract the first word of "cc", so it can be a program name with args.
set dummy cc; ac_word=$2
else
@@ -2388,18 +2085,18 @@ for as_dir in $PATH
do
IFS=$as_save_IFS
if test "$as_dir/$ac_word$ac_exec_ext" = "/usr/ucb/cc"; then
ac_prog_rejected=yes
continue
fi
ac_cv_prog_CC="cc"
break 2
fi
done
- done
+done
IFS=$as_save_IFS
if test $ac_prog_rejected = yes; then
@@ -2418,10 +2115,10 @@ fi
fi
CC=$ac_cv_prog_CC
else
fi
@@ -2433,9 +2130,9 @@ if test -z "$CC"; then
do
# Extract the first word of "$ac_tool_prefix$ac_prog", so it can be a program name with args.
set dummy $ac_tool_prefix$ac_prog; ac_word=$2
else
@@ -2446,24 +2143,24 @@ for as_dir in $PATH
do
IFS=$as_save_IFS
ac_cv_prog_CC="$ac_tool_prefix$ac_prog"
break 2
fi
done
- done
+done
IFS=$as_save_IFS
fi
fi
CC=$ac_cv_prog_CC
else
fi
@@ -2477,9 +2174,9 @@ if test -z "$CC"; then
do
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
else
@@ -2490,24 +2187,24 @@ for as_dir in $PATH
do
IFS=$as_save_IFS
ac_cv_prog_ac_ct_CC="$ac_prog"
break 2
fi
done
- done
+done
IFS=$as_save_IFS
fi
fi
else
fi
@@ -2520,7 +2217,7 @@ done
else
yes:)
esac
@@ -2531,37 +2228,57 @@ fi
fi
-test -z "$CC" && { { $as_echo "$as_me:${as_lineno-$LINENO}: error: in \`$ac_pwd':" >&5
+test -z "$CC" && { { $as_echo "$as_me:$LINENO: error: in \`$ac_pwd':" >&5
-as_fn_error $? "no acceptable C compiler found in \$PATH
+{ { $as_echo "$as_me:$LINENO: error: no acceptable C compiler found in \$PATH
+See \`config.log' for more details." >&5
+$as_echo "$as_me: error: no acceptable C compiler found in \$PATH
+See \`config.log' for more details." >&2;}
# Provide some information about the compiler.
-$as_echo "$as_me:${as_lineno-$LINENO}: checking for C compiler version" >&5
+$as_echo "$as_me:$LINENO: checking for C compiler version" >&5
set X $ac_compile
ac_compiler=$2
-for ac_option in --version -v -V -qversion; do
- { { ac_try="$ac_compiler $ac_option >&5"
+{ (ac_try="$ac_compiler --version >&5"
case "(($ac_try" in
esac
- (eval "$ac_compiler $ac_option >&5") 2>conftest.err
+eval ac_try_echo="\"\$as_me:$LINENO: $ac_try_echo\""
+$as_echo "$ac_try_echo") >&5
+ (eval "$ac_compiler --version >&5") 2>&5
ac_status=$?
- sed '10a\
-... rest of stderr output deleted ...
- 10q' conftest.err >conftest.er1
- fi
- rm -f conftest.er1 conftest.err
-done
+ $as_echo "$as_me:$LINENO: \$? = $ac_status" >&5
+ (exit $ac_status); }
+{ (ac_try="$ac_compiler -v >&5"
+case "(($ac_try" in
+ *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;;
+ *) ac_try_echo=$ac_try;;
+esac
+ (eval "$ac_compiler -v >&5") 2>&5
+ ac_status=$?
+{ (ac_try="$ac_compiler -V >&5"
+esac
+ (eval "$ac_compiler -V >&5") 2>&5
+ ac_status=$?
+cat >conftest.$ac_ext <<_ACEOF
+/* confdefs.h. */
+_ACEOF
+cat confdefs.h >>conftest.$ac_ext
+cat >>conftest.$ac_ext <<_ACEOF
int
@@ -2577,8 +2294,8 @@ ac_clean_files="$ac_clean_files a.out a.out.dSYM a.exe b.out"
# Try to create an executable without -o first, disregard a.out.
# It will help us diagnose broken compilers, and finding out an intuition
# of exeext.
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether the C compiler works" >&5
-$as_echo_n "checking whether the C compiler works... " >&6; }
+{ $as_echo "$as_me:$LINENO: checking for C compiler default output file name" >&5
+$as_echo_n "checking for C compiler default output file name... " >&6; }
ac_link_default=`$as_echo "$ac_link" | sed 's/ -o *conftest[^ ]*//'`
# The possible output files:
@@ -2594,17 +2311,17 @@ do
done
rm -f $ac_rmfiles
-if { { ac_try="$ac_link_default"
+if { (ac_try="$ac_link_default"
case "(($ac_try" in
esac
(eval "$ac_link_default") 2>&5
ac_status=$?
- test $ac_status = 0; }; then :
+ (exit $ac_status); }; then
# Autoconf-2.13 could set the ac_cv_exeext variable to `no'.
# So ignore a value of `no', otherwise this would lead to `EXEEXT = no'
# in a Makefile. We should not override ac_cv_exeext if it was cached,
@@ -2621,7 +2338,7 @@ do
# certainly right.
break;;
- if test "${ac_cv_exeext+set}" = set && test "$ac_cv_exeext" != no;
+ if test "${ac_cv_exeext+set}" = set && test "$ac_cv_exeext" != no;
then :; else
ac_cv_exeext=`expr "$ac_file" : '[^.]*\(\..*\)'`
fi
@@ -2640,41 +2357,84 @@ test "$ac_cv_exeext" = no && ac_cv_exeext=
else
ac_file=''
fi
-if test -z "$ac_file"; then :
-$as_echo "no" >&6; }
-$as_echo "$as_me: failed program was:" >&5
+{ $as_echo "$as_me:$LINENO: result: $ac_file" >&5
+$as_echo "$ac_file" >&6; }
+if test -z "$ac_file"; then
+ $as_echo "$as_me: failed program was:" >&5
-{ { $as_echo "$as_me:${as_lineno-$LINENO}: error: in \`$ac_pwd':" >&5
+{ { $as_echo "$as_me:$LINENO: error: in \`$ac_pwd':" >&5
-as_fn_error 77 "C compiler cannot create executables
-else
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: yes" >&5
-$as_echo "yes" >&6; }
+{ { $as_echo "$as_me:$LINENO: error: C compiler cannot create executables
+$as_echo "$as_me: error: C compiler cannot create executables
+ { (exit 77); exit 77; }; }; }
fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for C compiler default output file name" >&5
-$as_echo_n "checking for C compiler default output file name... " >&6; }
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_file" >&5
-$as_echo "$ac_file" >&6; }
ac_exeext=$ac_cv_exeext
+# Check that the compiler produces executables we can run. If not, either
+# the compiler is broken, or we cross compile.
+{ $as_echo "$as_me:$LINENO: checking whether the C compiler works" >&5
+$as_echo_n "checking whether the C compiler works... " >&6; }
+# FIXME: These cross compiler hacks should be removed for Autoconf 3.0
+# If not cross compiling, check that we can run a simple program.
+if test "$cross_compiling" != yes; then
+ if { ac_try='./$ac_file'
+ { (case "(($ac_try" in
+esac
+ (eval "$ac_try") 2>&5
+ ac_status=$?
+ (exit $ac_status); }; }; then
+ cross_compiling=no
+ else
+ if test "$cross_compiling" = maybe; then
+ cross_compiling=yes
+ else
+ { { $as_echo "$as_me:$LINENO: error: in \`$ac_pwd':" >&5
+$as_echo "$as_me: error: in \`$ac_pwd':" >&2;}
+{ { $as_echo "$as_me:$LINENO: error: cannot run C compiled programs.
+If you meant to cross compile, use \`--host'.
+$as_echo "$as_me: error: cannot run C compiled programs.
+ fi
+ fi
+fi
+{ $as_echo "$as_me:$LINENO: result: yes" >&5
+$as_echo "yes" >&6; }
rm -f -r a.out a.out.dSYM a.exe conftest$ac_cv_exeext b.out
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for suffix of executables" >&5
+{ $as_echo "$as_me:$LINENO: checking whether we are cross compiling" >&5
+$as_echo_n "checking whether we are cross compiling... " >&6; }
+{ $as_echo "$as_me:$LINENO: result: $cross_compiling" >&5
+$as_echo "$cross_compiling" >&6; }
+{ $as_echo "$as_me:$LINENO: checking for suffix of executables" >&5
$as_echo_n "checking for suffix of executables... " >&6; }
-if { { ac_try="$ac_link"
+if { (ac_try="$ac_link"
case "(($ac_try" in
esac
ac_status=$?
# If both `conftest.exe' and `conftest' are `present' (well, observable)
# catch `conftest.exe'. For instance with Cygwin, `ls conftest' will
# work properly (i.e., refer to `conftest.exe'), while it won't with
@@ -2689,83 +2449,32 @@ for ac_file in conftest.exe conftest conftest.*; do
esac
done
else
- { { $as_echo "$as_me:${as_lineno-$LINENO}: error: in \`$ac_pwd':" >&5
-as_fn_error $? "cannot compute suffix of executables: cannot compile and link
+{ { $as_echo "$as_me:$LINENO: error: cannot compute suffix of executables: cannot compile and link
+$as_echo "$as_me: error: cannot compute suffix of executables: cannot compile and link
fi
-rm -f conftest conftest$ac_cv_exeext
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_exeext" >&5
+rm -f conftest$ac_cv_exeext
+{ $as_echo "$as_me:$LINENO: result: $ac_cv_exeext" >&5
$as_echo "$ac_cv_exeext" >&6; }
rm -f conftest.$ac_ext
EXEEXT=$ac_cv_exeext
ac_exeext=$EXEEXT
-#include <stdio.h>
-int
-main ()
-FILE *f = fopen ("conftest.out", "w");
- return ferror (f) || fclose (f) != 0;
- return 0;
-_ACEOF
-ac_clean_files="$ac_clean_files conftest.out"
-# Check that the compiler produces executables we can run. If not, either
-# the compiler is broken, or we cross compile.
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether we are cross compiling" >&5
-$as_echo_n "checking whether we are cross compiling... " >&6; }
-if test "$cross_compiling" != yes; then
- { { ac_try="$ac_link"
-esac
- ac_status=$?
- if { ac_try='./conftest$ac_cv_exeext'
-esac
- ac_status=$?
- cross_compiling=no
- else
- if test "$cross_compiling" = maybe; then
- cross_compiling=yes
- else
-as_fn_error $? "cannot run C compiled programs.
-If you meant to cross compile, use \`--host'.
- fi
- fi
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $cross_compiling" >&5
-$as_echo "$cross_compiling" >&6; }
-rm -f conftest.$ac_ext conftest$ac_cv_exeext conftest.out
-ac_clean_files=$ac_clean_files_save
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for suffix of object files" >&5
+{ $as_echo "$as_me:$LINENO: checking for suffix of object files" >&5
$as_echo_n "checking for suffix of object files... " >&6; }
-if ${ac_cv_objext+:} false; then :
+if test "${ac_cv_objext+set}" = set; then
else
+ cat >conftest.$ac_ext <<_ACEOF
+/* confdefs.h. */
+_ACEOF
int
@@ -2777,17 +2486,17 @@ main ()
_ACEOF
rm -f conftest.o conftest.obj
-if { { ac_try="$ac_compile"
+if { (ac_try="$ac_compile"
case "(($ac_try" in
esac
(eval "$ac_compile") 2>&5
ac_status=$?
for ac_file in conftest.o conftest.obj conftest.*; do
test -f "$ac_file" || continue;
case $ac_file in
@@ -2800,23 +2509,31 @@ else
-as_fn_error $? "cannot compute suffix of object files: cannot compile
+{ { $as_echo "$as_me:$LINENO: error: cannot compute suffix of object files: cannot compile
+$as_echo "$as_me: error: cannot compute suffix of object files: cannot compile
fi
rm -f conftest.$ac_cv_objext conftest.$ac_ext
fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_objext" >&5
+{ $as_echo "$as_me:$LINENO: result: $ac_cv_objext" >&5
$as_echo "$ac_cv_objext" >&6; }
OBJEXT=$ac_cv_objext
ac_objext=$OBJEXT
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether we are using the GNU C compiler" >&5
+{ $as_echo "$as_me:$LINENO: checking whether we are using the GNU C compiler" >&5
$as_echo_n "checking whether we are using the GNU C compiler... " >&6; }
-if ${ac_cv_c_compiler_gnu+:} false; then :
+if test "${ac_cv_c_compiler_gnu+set}" = set; then
else
+/* confdefs.h. */
+_ACEOF
int
@@ -2830,16 +2547,37 @@ main ()
return 0;
_ACEOF
+rm -f conftest.$ac_objext
+esac
+ (eval "$ac_compile") 2>conftest.er1
+ ac_status=$?
+ grep -v '^ *+' conftest.er1 >conftest.err
+ rm -f conftest.er1
+ cat conftest.err >&5
+ (exit $ac_status); } && {
+ test -z "$ac_c_werror_flag" ||
+ test ! -s conftest.err
+ } && test -s conftest.$ac_objext; then
ac_compiler_gnu=yes
else
- ac_compiler_gnu=no
+sed 's/^/| /' conftest.$ac_ext >&5
+ ac_compiler_gnu=no
fi
ac_cv_c_compiler_gnu=$ac_compiler_gnu
fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_c_compiler_gnu" >&5
+{ $as_echo "$as_me:$LINENO: result: $ac_cv_c_compiler_gnu" >&5
$as_echo "$ac_cv_c_compiler_gnu" >&6; }
if test $ac_compiler_gnu = yes; then
GCC=yes
@@ -2848,16 +2586,20 @@ else
fi
ac_test_CFLAGS=${CFLAGS+set}
ac_save_CFLAGS=$CFLAGS
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether $CC accepts -g" >&5
+{ $as_echo "$as_me:$LINENO: checking whether $CC accepts -g" >&5
$as_echo_n "checking whether $CC accepts -g... " >&6; }
-if ${ac_cv_prog_cc_g+:} false; then :
+if test "${ac_cv_prog_cc_g+set}" = set; then
else
ac_save_c_werror_flag=$ac_c_werror_flag
ac_c_werror_flag=yes
ac_cv_prog_cc_g=no
CFLAGS="-g"
+/* confdefs.h. */
+_ACEOF
int
@@ -2868,11 +2610,35 @@ main ()
return 0;
_ACEOF
+esac
+ ac_status=$?
ac_cv_prog_cc_g=yes
else
- CFLAGS=""
+ CFLAGS=""
+/* confdefs.h. */
+_ACEOF
int
@@ -2883,12 +2649,36 @@ main ()
return 0;
_ACEOF
+esac
+ ac_status=$?
else
- ac_c_werror_flag=$ac_save_c_werror_flag
+ ac_c_werror_flag=$ac_save_c_werror_flag
CFLAGS="-g"
+/* confdefs.h. */
+_ACEOF
int
@@ -2899,17 +2689,42 @@ main ()
return 0;
_ACEOF
+esac
+ ac_status=$?
ac_cv_prog_cc_g=yes
+else
fi
fi
fi
fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_prog_cc_g" >&5
+{ $as_echo "$as_me:$LINENO: result: $ac_cv_prog_cc_g" >&5
$as_echo "$ac_cv_prog_cc_g" >&6; }
if test "$ac_test_CFLAGS" = set; then
CFLAGS=$ac_save_CFLAGS
@@ -2926,18 +2741,23 @@ else
CFLAGS=
fi
fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for $CC option to accept ISO C89" >&5
+{ $as_echo "$as_me:$LINENO: checking for $CC option to accept ISO C89" >&5
$as_echo_n "checking for $CC option to accept ISO C89... " >&6; }
-if ${ac_cv_prog_cc_c89+:} false; then :
+if test "${ac_cv_prog_cc_c89+set}" = set; then
else
ac_cv_prog_cc_c89=no
ac_save_CC=$CC
+/* confdefs.h. */
+_ACEOF
#include <stdarg.h>
#include <stdio.h>
-struct stat;
+#include <sys/types.h>
+#include <sys/stat.h>
/* Most of the following tests are stolen from RCS 5.7's src/conf.sh. */
struct buf { int x; };
FILE * (*rcsopen) (struct buf *, struct stat *, int);
@@ -2989,9 +2809,32 @@ for ac_arg in '' -qlanglvl=extc89 -qlanglvl=ansi -std \
-Ae "-Aa -D_HPUX_SOURCE" "-Xc -D__EXTENSIONS__"
do
CC="$ac_save_CC $ac_arg"
- if ac_fn_c_try_compile "$LINENO"; then :
+ rm -f conftest.$ac_objext
+esac
+ ac_status=$?
ac_cv_prog_cc_c89=$ac_arg
+else
fi
test "x$ac_cv_prog_cc_c89" != "xno" && break
done
@@ -3002,19 +2845,17 @@ fi
# AC_CACHE_VAL
case "x$ac_cv_prog_cc_c89" in
x)
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: none needed" >&5
+ { $as_echo "$as_me:$LINENO: result: none needed" >&5
$as_echo "none needed" >&6; } ;;
xno)
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: unsupported" >&5
+ { $as_echo "$as_me:$LINENO: result: unsupported" >&5
$as_echo "unsupported" >&6; } ;;
CC="$CC $ac_cv_prog_cc_c89"
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_prog_cc_c89" >&5
+ { $as_echo "$as_me:$LINENO: result: $ac_cv_prog_cc_c89" >&5
$as_echo "$ac_cv_prog_cc_c89" >&6; } ;;
esac
-if test "x$ac_cv_prog_cc_c89" != xno; then :
-fi
ac_ext=c
@@ -3028,14 +2869,14 @@ ac_cpp='$CPP $CPPFLAGS'
ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5'
ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking how to run the C preprocessor" >&5
+{ $as_echo "$as_me:$LINENO: checking how to run the C preprocessor" >&5
$as_echo_n "checking how to run the C preprocessor... " >&6; }
# On Suns, sometimes $CPP names a directory.
if test -n "$CPP" && test -d "$CPP"; then
CPP=
fi
if test -z "$CPP"; then
- if ${ac_cv_prog_CPP+:} false; then :
+ if test "${ac_cv_prog_CPP+set}" = set; then
else
# Double quotes because CPP needs to be expanded
@@ -3050,7 +2891,11 @@ do
# <limits.h> exists even on freestanding compilers.
# On the NeXT, cc -E runs the code through the compiler's parser,
# not just through cpp. "Syntax error" is here to catch this case.
+/* confdefs.h. */
+_ACEOF
#ifdef __STDC__
@@ -3059,34 +2904,78 @@ do
#endif
Syntax error
_ACEOF
+if { (ac_try="$ac_cpp conftest.$ac_ext"
+esac
+ (eval "$ac_cpp conftest.$ac_ext") 2>conftest.er1
+ ac_status=$?
+ (exit $ac_status); } >/dev/null && {
+ test -z "$ac_c_preproc_warn_flag$ac_c_werror_flag" ||
+ }; then
else
# Broken: fails on valid input.
continue
fi
+rm -f conftest.err conftest.$ac_ext
# OK, works on sane cases. Now check whether nonexistent headers
# can be detected and how.
+/* confdefs.h. */
+_ACEOF
#include <ac_nonexistent.h>
_ACEOF
+esac
+ ac_status=$?
+ }; then
# Broken: success on invalid input.
continue
else
# Passes both tests.
ac_preproc_ok=:
break
fi
done
# Because of `break', _AC_PREPROC_IFELSE's cleaning code was skipped.
-rm -f conftest.i conftest.err conftest.$ac_ext
-if $ac_preproc_ok; then :
+if $ac_preproc_ok; then
break
fi
@@ -3098,7 +2987,7 @@ fi
else
ac_cv_prog_CPP=$CPP
fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $CPP" >&5
+{ $as_echo "$as_me:$LINENO: result: $CPP" >&5
$as_echo "$CPP" >&6; }
ac_preproc_ok=false
for ac_c_preproc_warn_flag in '' yes
@@ -3109,7 +2998,11 @@ do
+/* confdefs.h. */
+_ACEOF
#ifdef __STDC__
@@ -3118,40 +3011,87 @@ do
#endif
Syntax error
_ACEOF
+esac
+ ac_status=$?
+ }; then
else
continue
fi
+/* confdefs.h. */
+_ACEOF
_ACEOF
+esac
+ ac_status=$?
+ }; then
continue
else
ac_preproc_ok=:
break
fi
done
else
-as_fn_error $? "C preprocessor \"$CPP\" fails sanity check
+{ { $as_echo "$as_me:$LINENO: error: C preprocessor \"$CPP\" fails sanity check
+$as_echo "$as_me: error: C preprocessor \"$CPP\" fails sanity check
+ { (exit 1); exit 1; }; }; }
fi
ac_ext=c
@@ -3161,9 +3101,9 @@ ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for grep that handles long lines and -e" >&5
+{ $as_echo "$as_me:$LINENO: checking for grep that handles long lines and -e" >&5
$as_echo_n "checking for grep that handles long lines and -e... " >&6; }
-if ${ac_cv_path_GREP+:} false; then :
+if test "${ac_cv_path_GREP+set}" = set; then
else
if test -z "$GREP"; then
@@ -3174,10 +3114,10 @@ for as_dir in $PATH$PATH_SEPARATOR/usr/xpg4/bin
do
IFS=$as_save_IFS
- for ac_prog in grep ggrep; do
+ for ac_prog in grep ggrep; do
ac_path_GREP="$as_dir/$ac_prog$ac_exec_ext"
- as_fn_executable_p "$ac_path_GREP" || continue
+ { test -f "$ac_path_GREP" && $as_test_x "$ac_path_GREP"; } || continue
# Check for GNU ac_path_GREP and select it if it is found.
# Check for GNU $ac_path_GREP
case `"$ac_path_GREP" --version 2>&1` in
@@ -3194,7 +3134,7 @@ case `"$ac_path_GREP" --version 2>&1` in
$as_echo 'GREP' >> "conftest.nl"
"$ac_path_GREP" -e 'GREP$' -e '-(cannot match)-' < "conftest.nl" >"conftest.out" 2>/dev/null || break
diff "conftest.out" "conftest.nl" >/dev/null 2>&1 || break
- as_fn_arith $ac_count + 1 && ac_count=$as_val
+ ac_count=`expr $ac_count + 1`
if test $ac_count -gt ${ac_path_GREP_max-0}; then
# Best one so far, save it but keep looking for a better one
ac_cv_path_GREP="$ac_path_GREP"
@@ -3209,24 +3149,26 @@ esac
$ac_path_GREP_found && break 3
done
done
- done
+done
IFS=$as_save_IFS
if test -z "$ac_cv_path_GREP"; then
- as_fn_error $? "no acceptable grep could be found in $PATH$PATH_SEPARATOR/usr/xpg4/bin" "$LINENO" 5
+ { { $as_echo "$as_me:$LINENO: error: no acceptable grep could be found in $PATH$PATH_SEPARATOR/usr/xpg4/bin" >&5
+$as_echo "$as_me: error: no acceptable grep could be found in $PATH$PATH_SEPARATOR/usr/xpg4/bin" >&2;}
fi
else
ac_cv_path_GREP=$GREP
fi
fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_path_GREP" >&5
+{ $as_echo "$as_me:$LINENO: result: $ac_cv_path_GREP" >&5
$as_echo "$ac_cv_path_GREP" >&6; }
GREP="$ac_cv_path_GREP"
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for egrep" >&5
+{ $as_echo "$as_me:$LINENO: checking for egrep" >&5
$as_echo_n "checking for egrep... " >&6; }
-if ${ac_cv_path_EGREP+:} false; then :
+if test "${ac_cv_path_EGREP+set}" = set; then
else
if echo a | $GREP -E '(a|b)' >/dev/null 2>&1
@@ -3240,10 +3182,10 @@ for as_dir in $PATH$PATH_SEPARATOR/usr/xpg4/bin
do
IFS=$as_save_IFS
- for ac_prog in egrep; do
+ for ac_prog in egrep; do
ac_path_EGREP="$as_dir/$ac_prog$ac_exec_ext"
- as_fn_executable_p "$ac_path_EGREP" || continue
+ { test -f "$ac_path_EGREP" && $as_test_x "$ac_path_EGREP"; } || continue
# Check for GNU ac_path_EGREP and select it if it is found.
# Check for GNU $ac_path_EGREP
case `"$ac_path_EGREP" --version 2>&1` in
@@ -3260,7 +3202,7 @@ case `"$ac_path_EGREP" --version 2>&1` in
$as_echo 'EGREP' >> "conftest.nl"
"$ac_path_EGREP" 'EGREP$' < "conftest.nl" >"conftest.out" 2>/dev/null || break
if test $ac_count -gt ${ac_path_EGREP_max-0}; then
ac_cv_path_EGREP="$ac_path_EGREP"
@@ -3275,10 +3217,12 @@ esac
$ac_path_EGREP_found && break 3
done
done
- done
+done
IFS=$as_save_IFS
if test -z "$ac_cv_path_EGREP"; then
- as_fn_error $? "no acceptable egrep could be found in $PATH$PATH_SEPARATOR/usr/xpg4/bin" "$LINENO" 5
+ { { $as_echo "$as_me:$LINENO: error: no acceptable egrep could be found in $PATH$PATH_SEPARATOR/usr/xpg4/bin" >&5
+$as_echo "$as_me: error: no acceptable egrep could be found in $PATH$PATH_SEPARATOR/usr/xpg4/bin" >&2;}
fi
else
ac_cv_path_EGREP=$EGREP
@@ -3286,17 +3230,21 @@ fi
fi
fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_path_EGREP" >&5
+{ $as_echo "$as_me:$LINENO: result: $ac_cv_path_EGREP" >&5
$as_echo "$ac_cv_path_EGREP" >&6; }
EGREP="$ac_cv_path_EGREP"
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for ANSI C header files" >&5
+{ $as_echo "$as_me:$LINENO: checking for ANSI C header files" >&5
$as_echo_n "checking for ANSI C header files... " >&6; }
-if ${ac_cv_header_stdc+:} false; then :
+if test "${ac_cv_header_stdc+set}" = set; then
else
+/* confdefs.h. */
+_ACEOF
#include <stdlib.h>
#include <stdarg.h>
@@ -3311,23 +3259,48 @@ main ()
return 0;
_ACEOF
+esac
+ ac_status=$?
ac_cv_header_stdc=yes
else
- ac_cv_header_stdc=no
+ ac_cv_header_stdc=no
fi
if test $ac_cv_header_stdc = yes; then
# SunOS 4.x string.h does not declare mem*, contrary to ANSI.
+/* confdefs.h. */
+_ACEOF
#include <string.h>
_ACEOF
if (eval "$ac_cpp conftest.$ac_ext") 2>&5 |
- $EGREP "memchr" >/dev/null 2>&1; then :
+ $EGREP "memchr" >/dev/null 2>&1; then
else
fi
@@ -3337,14 +3310,18 @@ fi
# ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
+/* confdefs.h. */
+_ACEOF
#include <stdlib.h>
_ACEOF
- $EGREP "free" >/dev/null 2>&1; then :
+ $EGREP "free" >/dev/null 2>&1; then
else
fi
@@ -3354,10 +3331,14 @@ fi
# /bin/cc in Irix-4.0.5 gets non-ANSI ctype macros unless using -ansi.
- if test "$cross_compiling" = yes; then :
+ if test "$cross_compiling" = yes; then
else
+/* confdefs.h. */
+_ACEOF
#include <ctype.h>
#include <stdlib.h>
@@ -3384,33 +3365,118 @@ main ()
return 0;
_ACEOF
-if ac_fn_c_try_run "$LINENO"; then :
+rm -f conftest$ac_exeext
+esac
+ (eval "$ac_link") 2>&5
+ ac_status=$?
+ (exit $ac_status); } && { ac_try='./conftest$ac_exeext'
+esac
+ ac_status=$?
else
+ $as_echo "$as_me: program exited with status $ac_status" >&5
+$as_echo "$as_me: failed program was:" >&5
+( exit $ac_status )
+ac_cv_header_stdc=no
fi
-rm -f core *.core core.conftest.* gmon.out bb.out conftest$ac_exeext \
- conftest.$ac_objext conftest.beam conftest.$ac_ext
+rm -rf conftest.dSYM
+rm -f core *.core core.conftest.* gmon.out bb.out conftest$ac_exeext conftest.$ac_objext conftest.$ac_ext
fi
fi
fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_header_stdc" >&5
+{ $as_echo "$as_me:$LINENO: result: $ac_cv_header_stdc" >&5
$as_echo "$ac_cv_header_stdc" >&6; }
-$as_echo "#define STDC_HEADERS 1" >>confdefs.h
+cat >>confdefs.h <<\_ACEOF
+#define STDC_HEADERS 1
+_ACEOF
fi
# On IRIX 5.3, sys/types and inttypes.h are conflicting.
for ac_header in sys/types.h sys/stat.h stdlib.h string.h memory.h strings.h \
inttypes.h stdint.h unistd.h
-do :
- as_ac_Header=`$as_echo "ac_cv_header_$ac_header" | $as_tr_sh`
-ac_fn_c_check_header_compile "$LINENO" "$ac_header" "$as_ac_Header" "$ac_includes_default
-if eval test \"x\$"$as_ac_Header"\" = x"yes"; then :
+do
+as_ac_Header=`$as_echo "ac_cv_header_$ac_header" | $as_tr_sh`
+{ $as_echo "$as_me:$LINENO: checking for $ac_header" >&5
+$as_echo_n "checking for $ac_header... " >&6; }
+if { as_var=$as_ac_Header; eval "test \"\${$as_var+set}\" = set"; }; then
+ $as_echo_n "(cached) " >&6
+else
+/* confdefs.h. */
+_ACEOF
+/* end confdefs.h. */
+$ac_includes_default
+#include <$ac_header>
+_ACEOF
+esac
+ ac_status=$?
+ eval "$as_ac_Header=yes"
+else
+ eval "$as_ac_Header=no"
+fi
+rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext
+fi
+ac_res=`eval 'as_val=${'$as_ac_Header'}
+ $as_echo "$as_val"'`
+ { $as_echo "$as_me:$LINENO: result: $ac_res" >&5
+$as_echo "$ac_res" >&6; }
+as_val=`eval 'as_val=${'$as_ac_Header'}
+ if test "x$as_val" = x""yes; then
#define `$as_echo "HAVE_$ac_header" | $as_tr_cpp` 1
_ACEOF
@@ -3424,7 +3490,7 @@ done
# Check whether --with-zlib was given.
-if test "${with_zlib+set}" = set; then :
+if test "${with_zlib+set}" = set; then
withval=$with_zlib; if test "$withval" != no ; then
if test -d "$withval"
then
@@ -3434,31 +3500,166 @@ if test "${with_zlib+set}" = set; then :
__DARSHAN_ZLIB_LINK_FLAGS="-L${ZLIB_HOME}/lib"
__DARSHAN_ZLIB_INCLUDE_FLAGS="-I${ZLIB_HOME}/include"
else
- { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: Sorry, $withval does not exist, checking usual places" >&5
+ { $as_echo "$as_me:$LINENO: WARNING: Sorry, $withval does not exist, checking usual places" >&5
$as_echo "$as_me: WARNING: Sorry, $withval does not exist, checking usual places" >&2;}
fi
else
- as_fn_error $? "zlib is required" "$LINENO" 5
+ { { $as_echo "$as_me:$LINENO: error: zlib is required" >&5
+$as_echo "$as_me: error: zlib is required" >&2;}
+fi
+fi
+if test "${ac_cv_header_zlib_h+set}" = set; then
+ { $as_echo "$as_me:$LINENO: checking for zlib.h" >&5
+$as_echo_n "checking for zlib.h... " >&6; }
+fi
+{ $as_echo "$as_me:$LINENO: result: $ac_cv_header_zlib_h" >&5
+$as_echo "$ac_cv_header_zlib_h" >&6; }
+else
+ # Is the header compilable?
+{ $as_echo "$as_me:$LINENO: checking zlib.h usability" >&5
+$as_echo_n "checking zlib.h usability... " >&6; }
+/* confdefs.h. */
+_ACEOF
+#include <zlib.h>
+_ACEOF
+esac
+ ac_status=$?
+ ac_header_compiler=yes
+else
+ ac_header_compiler=no
fi
+{ $as_echo "$as_me:$LINENO: result: $ac_header_compiler" >&5
+$as_echo "$ac_header_compiler" >&6; }
+# Is the header present?
+{ $as_echo "$as_me:$LINENO: checking zlib.h presence" >&5
+$as_echo_n "checking zlib.h presence... " >&6; }
+/* confdefs.h. */
+_ACEOF
+#include <zlib.h>
+_ACEOF
+esac
+ ac_status=$?
+ }; then
+ ac_header_preproc=yes
+else
+ ac_header_preproc=no
fi
+{ $as_echo "$as_me:$LINENO: result: $ac_header_preproc" >&5
+$as_echo "$ac_header_preproc" >&6; }
+# So? What about this header?
+case $ac_header_compiler:$ac_header_preproc:$ac_c_preproc_warn_flag in
+ yes:no: )
+ { $as_echo "$as_me:$LINENO: WARNING: zlib.h: accepted by the compiler, rejected by the preprocessor!" >&5
+$as_echo "$as_me: WARNING: zlib.h: accepted by the compiler, rejected by the preprocessor!" >&2;}
+ { $as_echo "$as_me:$LINENO: WARNING: zlib.h: proceeding with the compiler's result" >&5
+$as_echo "$as_me: WARNING: zlib.h: proceeding with the compiler's result" >&2;}
+ no:yes:* )
+ { $as_echo "$as_me:$LINENO: WARNING: zlib.h: present but cannot be compiled" >&5
+$as_echo "$as_me: WARNING: zlib.h: present but cannot be compiled" >&2;}
+ { $as_echo "$as_me:$LINENO: WARNING: zlib.h: check for missing prerequisite headers?" >&5
+$as_echo "$as_me: WARNING: zlib.h: check for missing prerequisite headers?" >&2;}
+ { $as_echo "$as_me:$LINENO: WARNING: zlib.h: see the Autoconf documentation" >&5
+$as_echo "$as_me: WARNING: zlib.h: see the Autoconf documentation" >&2;}
+ { $as_echo "$as_me:$LINENO: WARNING: zlib.h: section \"Present But Cannot Be Compiled\"" >&5
+$as_echo "$as_me: WARNING: zlib.h: section \"Present But Cannot Be Compiled\"" >&2;}
+ { $as_echo "$as_me:$LINENO: WARNING: zlib.h: proceeding with the preprocessor's result" >&5
+$as_echo "$as_me: WARNING: zlib.h: proceeding with the preprocessor's result" >&2;}
+ { $as_echo "$as_me:$LINENO: WARNING: zlib.h: in the future, the compiler will take precedence" >&5
+$as_echo "$as_me: WARNING: zlib.h: in the future, the compiler will take precedence" >&2;}
-ac_fn_c_check_header_mongrel "$LINENO" "zlib.h" "ac_cv_header_zlib_h" "$ac_includes_default"
-if test "x$ac_cv_header_zlib_h" = xyes; then :
+esac
+{ $as_echo "$as_me:$LINENO: checking for zlib.h" >&5
+else
+ ac_cv_header_zlib_h=$ac_header_preproc
+fi
+fi
+if test "x$ac_cv_header_zlib_h" = x""yes; then
else
- as_fn_error $? "z.h not found" "$LINENO" 5
+ { { $as_echo "$as_me:$LINENO: error: z.h not found" >&5
+$as_echo "$as_me: error: z.h not found" >&2;}
fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for inflateEnd in -lz" >&5
+{ $as_echo "$as_me:$LINENO: checking for inflateEnd in -lz" >&5
$as_echo_n "checking for inflateEnd in -lz... " >&6; }
-if ${ac_cv_lib_z_inflateEnd+:} false; then :
+if test "${ac_cv_lib_z_inflateEnd+set}" = set; then
else
ac_check_lib_save_LIBS=$LIBS
LIBS="-lz $LIBS"
+/* confdefs.h. */
+_ACEOF
@@ -3476,18 +3677,43 @@ return inflateEnd ();
return 0;
_ACEOF
+rm -f conftest.$ac_objext conftest$ac_exeext
+esac
+ (eval "$ac_link") 2>conftest.er1
+ ac_status=$?
+ } && test -s conftest$ac_exeext && {
+ test "$cross_compiling" = yes ||
+ $as_test_x conftest$ac_exeext
+ }; then
ac_cv_lib_z_inflateEnd=yes
else
- ac_cv_lib_z_inflateEnd=no
+ ac_cv_lib_z_inflateEnd=no
fi
+rm -f core conftest.err conftest.$ac_objext conftest_ipa8_conftest.oo \
+ conftest$ac_exeext conftest.$ac_ext
LIBS=$ac_check_lib_save_LIBS
fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_lib_z_inflateEnd" >&5
+{ $as_echo "$as_me:$LINENO: result: $ac_cv_lib_z_inflateEnd" >&5
$as_echo "$ac_cv_lib_z_inflateEnd" >&6; }
-if test "x$ac_cv_lib_z_inflateEnd" = xyes; then :
+if test "x$ac_cv_lib_z_inflateEnd" = x""yes; then
#define HAVE_LIBZ 1
_ACEOF
@@ -3495,7 +3721,9 @@ _ACEOF
LIBS="-lz $LIBS"
else
- as_fn_error $? "libz not found" "$LINENO" 5
+ { { $as_echo "$as_me:$LINENO: error: libz not found" >&5
+$as_echo "$as_me: error: libz not found" >&2;}
fi
@@ -3503,22 +3731,22 @@ fi
# Handle user hints
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking if bzlib is wanted" >&5
+{ $as_echo "$as_me:$LINENO: checking if bzlib is wanted" >&5
$as_echo_n "checking if bzlib is wanted... " >&6; }
# Check whether --with-bzlib was given.
-if test "${with_bzlib+set}" = set; then :
+if test "${with_bzlib+set}" = set; then
withval=$with_bzlib; if test "$withval" != no ; then
then
BZLIB_HOME="$withval"
else
fi
else
DISABLE_BZLIB=1
fi
fi
@@ -3535,7 +3763,7 @@ fi
if test -z "${DISABLE_BZLIB}"
then
+ { $as_echo "$as_me:$LINENO: result: yes" >&5
BZLIB_OLD_LDFLAGS=$LDFLAGS
BZLIB_OLD_CPPFLAGS=$LDFLAGS
@@ -3548,14 +3776,18 @@ ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5'
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking for BZ2_bzCompressInit in -lbz2" >&5
+ { $as_echo "$as_me:$LINENO: checking for BZ2_bzCompressInit in -lbz2" >&5
$as_echo_n "checking for BZ2_bzCompressInit in -lbz2... " >&6; }
-if ${ac_cv_lib_bz2_BZ2_bzCompressInit+:} false; then :
+if test "${ac_cv_lib_bz2_BZ2_bzCompressInit+set}" = set; then
else
LIBS="-lbz2 $LIBS"
+/* confdefs.h. */
+_ACEOF
@@ -3573,25 +3805,176 @@ return BZ2_bzCompressInit ();
return 0;
_ACEOF
+esac
+ ac_status=$?
+ }; then
ac_cv_lib_bz2_BZ2_bzCompressInit=yes
else
- ac_cv_lib_bz2_BZ2_bzCompressInit=no
+ ac_cv_lib_bz2_BZ2_bzCompressInit=no
fi
fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_lib_bz2_BZ2_bzCompressInit" >&5
+{ $as_echo "$as_me:$LINENO: result: $ac_cv_lib_bz2_BZ2_bzCompressInit" >&5
$as_echo "$ac_cv_lib_bz2_BZ2_bzCompressInit" >&6; }
-if test "x$ac_cv_lib_bz2_BZ2_bzCompressInit" = xyes; then :
+if test "x$ac_cv_lib_bz2_BZ2_bzCompressInit" = x""yes; then
bzlib_cv_libbz2=yes
else
bzlib_cv_libbz2=no
fi
- ac_fn_c_check_header_mongrel "$LINENO" "bzlib.h" "ac_cv_header_bzlib_h" "$ac_includes_default"
-if test "x$ac_cv_header_bzlib_h" = xyes; then :
+ if test "${ac_cv_header_bzlib_h+set}" = set; then
+ { $as_echo "$as_me:$LINENO: checking for bzlib.h" >&5
+$as_echo_n "checking for bzlib.h... " >&6; }
+if test "${ac_cv_header_bzlib_h+set}" = set; then
+fi
+{ $as_echo "$as_me:$LINENO: result: $ac_cv_header_bzlib_h" >&5
+$as_echo "$ac_cv_header_bzlib_h" >&6; }
+else
+{ $as_echo "$as_me:$LINENO: checking bzlib.h usability" >&5
+$as_echo_n "checking bzlib.h usability... " >&6; }
+/* confdefs.h. */
+_ACEOF
+#include <bzlib.h>
+_ACEOF
+esac
+ ac_status=$?
+else
+fi
+{ $as_echo "$as_me:$LINENO: checking bzlib.h presence" >&5
+$as_echo_n "checking bzlib.h presence... " >&6; }
+/* confdefs.h. */
+_ACEOF
+#include <bzlib.h>
+_ACEOF
+esac
+ ac_status=$?
+ }; then
+else
+fi
+ yes:no: )
+ { $as_echo "$as_me:$LINENO: WARNING: bzlib.h: accepted by the compiler, rejected by the preprocessor!" >&5
+$as_echo "$as_me: WARNING: bzlib.h: accepted by the compiler, rejected by the preprocessor!" >&2;}
+ { $as_echo "$as_me:$LINENO: WARNING: bzlib.h: proceeding with the compiler's result" >&5
+$as_echo "$as_me: WARNING: bzlib.h: proceeding with the compiler's result" >&2;}
+ no:yes:* )
+ { $as_echo "$as_me:$LINENO: WARNING: bzlib.h: present but cannot be compiled" >&5
+$as_echo "$as_me: WARNING: bzlib.h: present but cannot be compiled" >&2;}
+ { $as_echo "$as_me:$LINENO: WARNING: bzlib.h: check for missing prerequisite headers?" >&5
+$as_echo "$as_me: WARNING: bzlib.h: check for missing prerequisite headers?" >&2;}
+ { $as_echo "$as_me:$LINENO: WARNING: bzlib.h: see the Autoconf documentation" >&5
+$as_echo "$as_me: WARNING: bzlib.h: see the Autoconf documentation" >&2;}
+ { $as_echo "$as_me:$LINENO: WARNING: bzlib.h: section \"Present But Cannot Be Compiled\"" >&5
+$as_echo "$as_me: WARNING: bzlib.h: section \"Present But Cannot Be Compiled\"" >&2;}
+ { $as_echo "$as_me:$LINENO: WARNING: bzlib.h: proceeding with the preprocessor's result" >&5
+$as_echo "$as_me: WARNING: bzlib.h: proceeding with the preprocessor's result" >&2;}
+ { $as_echo "$as_me:$LINENO: WARNING: bzlib.h: in the future, the compiler will take precedence" >&5
+$as_echo "$as_me: WARNING: bzlib.h: in the future, the compiler will take precedence" >&2;}
+esac
+{ $as_echo "$as_me:$LINENO: checking for bzlib.h" >&5
+else
+ ac_cv_header_bzlib_h=$ac_header_preproc
+fi
+fi
+if test "x$ac_cv_header_bzlib_h" = x""yes; then
bzlib_cv_bzlib_h=yes
else
bzlib_cv_bzlib_h=no
@@ -3609,14 +3992,19 @@ ac_compiler_gnu=$ac_cv_c_compiler_gnu
# If both library and header were found, use them
+{ $as_echo "$as_me:$LINENO: checking for BZ2_bzCompressInit in -lbz2" >&5
else
LIBS="-lbz2 $LIBS"
+/* confdefs.h. */
+_ACEOF
@@ -3634,18 +4022,43 @@ return BZ2_bzCompressInit ();
return 0;
_ACEOF
+esac
+ ac_status=$?
+ }; then
else
fi
fi
#define HAVE_LIBBZ2 1
_ACEOF
@@ -3654,9 +4067,9 @@ _ACEOF
fi
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking bzlib in ${BZLIB_HOME}" >&5
+ { $as_echo "$as_me:$LINENO: checking bzlib in ${BZLIB_HOME}" >&5
$as_echo_n "checking bzlib in ${BZLIB_HOME}... " >&6; }
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: ok" >&5
+ { $as_echo "$as_me:$LINENO: result: ok" >&5
$as_echo "ok" >&6; }
LIBBZ2=-lbz2
@@ -3664,17 +4077,17 @@ $as_echo "ok" >&6; }
# If either header or library was not found, revert and bomb
LDFLAGS="$BZLIB_OLD_LDFLAGS"
CPPFLAGS="$BZLIB_OLD_CPPFLAGS"
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: failed" >&5
+ { $as_echo "$as_me:$LINENO: result: failed" >&5
$as_echo "failed" >&6; }
# Don't fail; this is optional in Darshan
# AC_MSG_ERROR(either specify a valid bzlib installation with --with-bzlib=DIR or disable bzlib usage with --without-bzlib)
# TODO: it would be nice if this showed up at the _end_ of
# configure...
- { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: libbz2 not found; Darshan utilities will use gzip only." >&5
+ { $as_echo "$as_me:$LINENO: WARNING: libbz2 not found; Darshan utilities will use gzip only." >&5
$as_echo "$as_me: WARNING: libbz2 not found; Darshan utilities will use gzip only." >&2;}
fi
fi
@@ -3683,12 +4096,146 @@ fi
# checks to see how we can print 64 bit values on this architecture
- for ac_header in inttypes.h
-do :
- ac_fn_c_check_header_mongrel "$LINENO" "inttypes.h" "ac_cv_header_inttypes_h" "$ac_includes_default"
-if test "x$ac_cv_header_inttypes_h" = xyes; then :
+for ac_header in inttypes.h
+do
+ { $as_echo "$as_me:$LINENO: checking for $ac_header" >&5
+fi
+else
+{ $as_echo "$as_me:$LINENO: checking $ac_header usability" >&5
+$as_echo_n "checking $ac_header usability... " >&6; }
+/* confdefs.h. */
+_ACEOF
+_ACEOF
+esac
+ ac_status=$?
+else
+fi
+{ $as_echo "$as_me:$LINENO: checking $ac_header presence" >&5
+$as_echo_n "checking $ac_header presence... " >&6; }
+/* confdefs.h. */
+_ACEOF
+_ACEOF
+esac
+ ac_status=$?
+ }; then
+else
+fi
+ yes:no: )
+ { $as_echo "$as_me:$LINENO: WARNING: $ac_header: accepted by the compiler, rejected by the preprocessor!" >&5
+$as_echo "$as_me: WARNING: $ac_header: accepted by the compiler, rejected by the preprocessor!" >&2;}
+ { $as_echo "$as_me:$LINENO: WARNING: $ac_header: proceeding with the compiler's result" >&5
+$as_echo "$as_me: WARNING: $ac_header: proceeding with the compiler's result" >&2;}
+ no:yes:* )
+ { $as_echo "$as_me:$LINENO: WARNING: $ac_header: present but cannot be compiled" >&5
+$as_echo "$as_me: WARNING: $ac_header: present but cannot be compiled" >&2;}
+ { $as_echo "$as_me:$LINENO: WARNING: $ac_header: check for missing prerequisite headers?" >&5
+$as_echo "$as_me: WARNING: $ac_header: check for missing prerequisite headers?" >&2;}
+ { $as_echo "$as_me:$LINENO: WARNING: $ac_header: see the Autoconf documentation" >&5
+$as_echo "$as_me: WARNING: $ac_header: see the Autoconf documentation" >&2;}
+ { $as_echo "$as_me:$LINENO: WARNING: $ac_header: section \"Present But Cannot Be Compiled\"" >&5
+$as_echo "$as_me: WARNING: $ac_header: section \"Present But Cannot Be Compiled\"" >&2;}
+ { $as_echo "$as_me:$LINENO: WARNING: $ac_header: proceeding with the preprocessor's result" >&5
+$as_echo "$as_me: WARNING: $ac_header: proceeding with the preprocessor's result" >&2;}
+ { $as_echo "$as_me:$LINENO: WARNING: $ac_header: in the future, the compiler will take precedence" >&5
+$as_echo "$as_me: WARNING: $ac_header: in the future, the compiler will take precedence" >&2;}
+esac
+else
+ eval "$as_ac_Header=\$ac_header_preproc"
+fi
+fi
-#define HAVE_INTTYPES_H 1
+#define `$as_echo "HAVE_$ac_header" | $as_tr_cpp` 1
_ACEOF
fi
@@ -3696,13 +4243,17 @@ fi
done
if test $ac_cv_header_inttypes_h = yes; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking whether the inttypes.h PRIxNN macros are broken" >&5
+ { $as_echo "$as_me:$LINENO: checking whether the inttypes.h PRIxNN macros are broken" >&5
$as_echo_n "checking whether the inttypes.h PRIxNN macros are broken... " >&6; }
-if ${gt_cv_inttypes_pri_broken+:} false; then :
+if test "${gt_cv_inttypes_pri_broken+set}" = set; then
else
+/* confdefs.h. */
+_ACEOF
#include <inttypes.h>
#ifdef PRId32
@@ -3717,15 +4268,36 @@ main ()
return 0;
_ACEOF
+esac
+ ac_status=$?
gt_cv_inttypes_pri_broken=no
else
- gt_cv_inttypes_pri_broken=yes
+ gt_cv_inttypes_pri_broken=yes
fi
fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $gt_cv_inttypes_pri_broken" >&5
+{ $as_echo "$as_me:$LINENO: result: $gt_cv_inttypes_pri_broken" >&5
$as_echo "$gt_cv_inttypes_pri_broken" >&6; }
fi
if test "$gt_cv_inttypes_pri_broken" = yes; then
@@ -3741,18 +4313,156 @@ _ACEOF
if test x$PRI_MACROS_BROKEN == xyes; then
- as_fn_error $? "PRI_xx macros are broken" "$LINENO" 5
+ { { $as_echo "$as_me:$LINENO: error: PRI_xx macros are broken" >&5
+$as_echo "$as_me: error: PRI_xx macros are broken" >&2;}
else
-do :
+do
+fi
+else
+/* confdefs.h. */
+_ACEOF
+_ACEOF
+esac
+ ac_status=$?
+else
+fi
+/* confdefs.h. */
+_ACEOF
+_ACEOF
+esac
+ ac_status=$?
+ }; then
+else
+fi
+ yes:no: )
+ no:yes:* )
+esac
+else
+fi
+fi
_ACEOF
else
- as_fn_error $? "Couldn't find inttypes.h" "$LINENO" 5
+ { { $as_echo "$as_me:$LINENO: error: Couldn't find inttypes.h" >&5
+$as_echo "$as_me: error: Couldn't find inttypes.h" >&2;}
fi
done
@@ -3761,9 +4471,9 @@ fi
# Extract the first word of "pdflatex", so it can be a program name with args.
set dummy pdflatex; ac_word=$2
-if ${ac_cv_prog_HAVE_PDFLATEX+:} false; then :
+if test "${ac_cv_prog_HAVE_PDFLATEX+set}" = set; then
else
if test -n "$HAVE_PDFLATEX"; then
@@ -3774,14 +4484,14 @@ for as_dir in $PATH
do
IFS=$as_save_IFS
test -z "$as_dir" && as_dir=.
ac_cv_prog_HAVE_PDFLATEX="yes"
break 2
fi
done
- done
+done
IFS=$as_save_IFS
test -z "$ac_cv_prog_HAVE_PDFLATEX" && ac_cv_prog_HAVE_PDFLATEX="no"
@@ -3789,38 +4499,43 @@ fi
fi
HAVE_PDFLATEX=$ac_cv_prog_HAVE_PDFLATEX
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $HAVE_PDFLATEX" >&5
+ { $as_echo "$as_me:$LINENO: result: $HAVE_PDFLATEX" >&5
$as_echo "$HAVE_PDFLATEX" >&6; }
else
fi
if test x$HAVE_PDFLATEX == xyes; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking for -halt-on-error argument to pdflatex" >&5
+ { $as_echo "$as_me:$LINENO: checking for -halt-on-error argument to pdflatex" >&5
$as_echo_n "checking for -halt-on-error argument to pdflatex... " >&6; }
PDFLATEX_GREP=`pdflatex --help |grep halt-on-error`
if test "x$PDFLATEX_GREP" != "x"; then
__DARSHAN_PDFLATEX_HALT_ON_ERROR="-halt-on-error"
else
__DARSHAN_PDFLATEX_HALT_ON_ERROR=""
fi
fi
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking whether byte ordering is bigendian" >&5
+ { $as_echo "$as_me:$LINENO: checking whether byte ordering is bigendian" >&5
$as_echo_n "checking whether byte ordering is bigendian... " >&6; }
-if ${ac_cv_c_bigendian+:} false; then :
+if test "${ac_cv_c_bigendian+set}" = set; then
else
ac_cv_c_bigendian=unknown
# See if we're dealing with a universal compiler.
+/* confdefs.h. */
+_ACEOF
#ifndef __APPLE_CC__
not a universal capable compiler
@@ -3828,34 +4543,46 @@ else
typedef int dummy;
_ACEOF
-if ac_fn_c_try_compile "$LINENO"; then :
+esac
+ ac_status=$?
# Check for potential -arch flags. It is not universal unless
- # there are at least two -arch flags with different values.
- ac_arch=
- ac_prev=
- for ac_word in $CC $CFLAGS $CPPFLAGS $LDFLAGS; do
- if test -n "$ac_prev"; then
- case $ac_word in
- i?86 | x86_64 | ppc | ppc64)
- if test -z "$ac_arch" || test "$ac_arch" = "$ac_word"; then
- ac_arch=$ac_word
- else
- ac_cv_c_bigendian=universal
- break
- fi
- esac
- ac_prev=
- elif test "x$ac_word" = "x-arch"; then
- ac_prev=arch
- fi
- done
+ # there are some -arch flags. Note that *ppc* also matches
+ # ppc64. This check is also rather less than ideal.
+ case "${CC} ${CFLAGS} ${CPPFLAGS} ${LDFLAGS}" in #(
+ *-arch*ppc*|*-arch*i386*|*-arch*x86_64*) ac_cv_c_bigendian=universal;;
+ esac
+else
fi
if test $ac_cv_c_bigendian = unknown; then
# See if sys/param.h defines the BYTE_ORDER macro.
+/* confdefs.h. */
+_ACEOF
#include <sys/param.h>
@@ -3873,9 +4600,30 @@ main ()
return 0;
_ACEOF
+esac
+ ac_status=$?
# It does; now see whether it defined to BIG_ENDIAN or not.
+/* confdefs.h. */
+_ACEOF
@@ -3891,18 +4639,49 @@ main ()
return 0;
_ACEOF
+esac
+ ac_status=$?
ac_cv_c_bigendian=yes
else
- ac_cv_c_bigendian=no
+ ac_cv_c_bigendian=no
fi
+else
fi
fi
# See if <limits.h> defines _LITTLE_ENDIAN or _BIG_ENDIAN (e.g., Solaris).
+/* confdefs.h. */
+_ACEOF
#include <limits.h>
@@ -3917,9 +4696,30 @@ main ()
return 0;
_ACEOF
+esac
+ ac_status=$?
# It does; now see whether it defined to _BIG_ENDIAN or not.
+/* confdefs.h. */
+_ACEOF
#include <limits.h>
@@ -3934,20 +4734,51 @@ main ()
return 0;
_ACEOF
+esac
+ ac_status=$?
else
fi
+else
fi
fi
# Compile a test program.
# Try to guess by grepping values from an object file.
+/* confdefs.h. */
+_ACEOF
short int ascii_mm[] =
{ 0x4249, 0x4765, 0x6E44, 0x6961, 0x6E53, 0x7953, 0 };
@@ -3973,7 +4804,24 @@ return use_ascii (foo) == use_ebcdic (foo);
return 0;
_ACEOF
+esac
+ ac_status=$?
if grep BIGenDianSyS conftest.$ac_objext >/dev/null; then
fi
@@ -3985,10 +4833,20 @@ if ac_fn_c_try_compile "$LINENO"; then :
fi
fi
+else
fi
else
+/* confdefs.h. */
+_ACEOF
int
@@ -4008,41 +4866,79 @@ main ()
return 0;
_ACEOF
+esac
+ ac_status=$?
+esac
+ ac_status=$?
else
- ac_cv_c_bigendian=yes
+ac_cv_c_bigendian=yes
fi
fi
fi
fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_c_bigendian" >&5
+{ $as_echo "$as_me:$LINENO: result: $ac_cv_c_bigendian" >&5
$as_echo "$ac_cv_c_bigendian" >&6; }
case $ac_cv_c_bigendian in #(
yes)
- $as_echo "#define WORDS_BIGENDIAN 1" >>confdefs.h
+ cat >>confdefs.h <<\_ACEOF
+#define WORDS_BIGENDIAN 1
+_ACEOF
no)
universal)
-$as_echo "#define AC_APPLE_UNIVERSAL_BUILD 1" >>confdefs.h
+#define AC_APPLE_UNIVERSAL_BUILD 1
+_ACEOF
- as_fn_error $? "unknown endianness
- presetting ac_cv_c_bigendian=no (or yes) will help" "$LINENO" 5 ;;
+ { { $as_echo "$as_me:$LINENO: error: unknown endianness
+ presetting ac_cv_c_bigendian=no (or yes) will help" >&5
+$as_echo "$as_me: error: unknown endianness
+ presetting ac_cv_c_bigendian=no (or yes) will help" >&2;}
+ { (exit 1); exit 1; }; } ;;
esac
old_cflags="$CFLAGS"
CFLAGS="$CFLAGS -D_FILE_OFFSET_BITS=64 -D_LARGEFILE64_SOURCE"
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for off64_t" >&5
+{ $as_echo "$as_me:$LINENO: checking for off64_t" >&5
$as_echo_n "checking for off64_t... " >&6; }
-cat confdefs.h - <<_ACEOF >conftest.$ac_ext
+/* confdefs.h. */
+_ACEOF
#include <stdio.h>
@@ -4069,23 +4965,46 @@ main ()
return 0;
_ACEOF
+esac
+ ac_status=$?
-$as_echo "#define HAVE_OFF64_T 1" >>confdefs.h
+#define HAVE_OFF64_T 1
+_ACEOF
else
fi
CFLAGS="$old_cflags"
DARSHAN_ENABLE_SHARED=0
# Check whether --enable-shared was given.
-if test "${enable_shared+set}" = set; then :
+if test "${enable_shared+set}" = set; then
enableval=$enable_shared; if test "x$enableval" = "xyes" ; then
DARSHAN_ENABLE_SHARED=1
fi
@@ -4093,12 +5012,102 @@ fi
fi
for ac_func in strndup
-do :
- ac_fn_c_check_func "$LINENO" "strndup" "ac_cv_func_strndup"
-if test "x$ac_cv_func_strndup" = xyes; then :
+do
+as_ac_var=`$as_echo "ac_cv_func_$ac_func" | $as_tr_sh`
+{ $as_echo "$as_me:$LINENO: checking for $ac_func" >&5
+$as_echo_n "checking for $ac_func... " >&6; }
+if { as_var=$as_ac_var; eval "test \"\${$as_var+set}\" = set"; }; then
+else
+/* confdefs.h. */
+_ACEOF
+/* Define $ac_func to an innocuous variant, in case <limits.h> declares $ac_func.
+ For example, HP-UX 11i <limits.h> declares gettimeofday. */
+#define $ac_func innocuous_$ac_func
+/* System header to define __stub macros and hopefully few prototypes,
+ which can conflict with char $ac_func (); below.
+ Prefer <limits.h> to <assert.h> if __STDC__ is defined, since
+ <limits.h> exists even on freestanding compilers. */
+#ifdef __STDC__
+# include <limits.h>
+#else
+# include <assert.h>
+#endif
+#undef $ac_func
+/* Override any GCC internal prototype to avoid an error.
+ Use char because int might match the return type of a GCC
+ builtin and then its argument prototype would still apply. */
+#ifdef __cplusplus
+extern "C"
+#endif
+char $ac_func ();
+/* The GNU C library defines this for functions which it implements
+ to always fail with ENOSYS. Some functions are actually named
+ something starting with __ and the normal name is an alias. */
+#if defined __stub_$ac_func || defined __stub___$ac_func
+choke me
+#endif
+int
+main ()
+return $ac_func ();
+ return 0;
+_ACEOF
+esac
+ ac_status=$?
+ }; then
+ eval "$as_ac_var=yes"
+else
+ eval "$as_ac_var=no"
+fi
+fi
+ac_res=`eval 'as_val=${'$as_ac_var'}
+as_val=`eval 'as_val=${'$as_ac_var'}
-#define HAVE_STRNDUP 1
+#define `$as_echo "HAVE_$ac_func" | $as_tr_cpp` 1
_ACEOF
fi
@@ -4141,13 +5150,13 @@ _ACEOF
case $ac_val in #(
*${as_nl}*)
case $ac_var in #(
esac
case $ac_var in #(
esac ;;
esac
done
@@ -4155,8 +5164,8 @@ $as_echo "$as_me: WARNING: cache variable $ac_var contains a newline" >&2;} ;;
(set) 2>&1 |
case $as_nl`(ac_space=' '; set) 2>&1` in #(
*${as_nl}ac_space=\ *)
- # `set' does not quote correctly, so add quotes: double-quote
- # substitution turns \\\\ into \\, and sed turns \\ into \.
+ # `set' does not quote correctly, so add quotes (double-quote
+ # substitution turns \\\\ into \\, and sed turns \\ into \).
sed -n \
"s/'/'\\\\''/g;
s/^\\([_$as_cr_alnum]*_cv_[_$as_cr_alnum]*\\)=\\(.*\\)/\\1='\\2'/p"
@@ -4178,23 +5187,12 @@ $as_echo "$as_me: WARNING: cache variable $ac_var contains a newline" >&2;} ;;
:end' >>confcache
if diff "$cache_file" confcache >/dev/null 2>&1; then :; else
if test -w "$cache_file"; then
- if test "x$cache_file" != "x/dev/null"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: updating cache $cache_file" >&5
+ test "x$cache_file" != "x/dev/null" &&
+ { $as_echo "$as_me:$LINENO: updating cache $cache_file" >&5
$as_echo "$as_me: updating cache $cache_file" >&6;}
- if test ! -f "$cache_file" || test -h "$cache_file"; then
- cat confcache >"$cache_file"
- else
- case $cache_file in #(
- mv -f confcache "$cache_file"$$ &&
- mv -f "$cache_file"$$ "$cache_file" ;; #(
- mv -f confcache "$cache_file" ;;
- esac
- fi
- fi
+ cat confcache >$cache_file
else
- { $as_echo "$as_me:${as_lineno-$LINENO}: not updating unwritable cache $cache_file" >&5
+ { $as_echo "$as_me:$LINENO: not updating unwritable cache $cache_file" >&5
$as_echo "$as_me: not updating unwritable cache $cache_file" >&6;}
fi
fi
@@ -4208,15 +5206,14 @@ DEFS=-DHAVE_CONFIG_H
ac_libobjs=
ac_ltlibobjs=
-U=
for ac_i in : $LIBOBJS; do test "x$ac_i" = x: && continue
# 1. Remove the extension, and $U if already installed.
ac_script='s/\$U\././;s/\.o$//;s/\.obj$//'
ac_i=`$as_echo "$ac_i" | sed "$ac_script"`
# 2. Prepend LIBOBJDIR. When used with automake>=1.10 LIBOBJDIR
# will be set to the directory where LIBOBJS objects are built.
- as_fn_append ac_libobjs " \${LIBOBJDIR}$ac_i\$U.$ac_objext"
- as_fn_append ac_ltlibobjs " \${LIBOBJDIR}$ac_i"'$U.lo'
+ ac_libobjs="$ac_libobjs \${LIBOBJDIR}$ac_i\$U.$ac_objext"
+ ac_ltlibobjs="$ac_ltlibobjs \${LIBOBJDIR}$ac_i"'$U.lo'
done
LIBOBJS=$ac_libobjs
@@ -4225,14 +5222,13 @@ LTLIBOBJS=$ac_ltlibobjs
-: "${CONFIG_STATUS=./config.status}"
+: ${CONFIG_STATUS=./config.status}
ac_write_fail=0
ac_clean_files_save=$ac_clean_files
ac_clean_files="$ac_clean_files $CONFIG_STATUS"
-{ $as_echo "$as_me:${as_lineno-$LINENO}: creating $CONFIG_STATUS" >&5
+{ $as_echo "$as_me:$LINENO: creating $CONFIG_STATUS" >&5
$as_echo "$as_me: creating $CONFIG_STATUS" >&6;}
-as_write_fail=0
-cat >$CONFIG_STATUS <<_ASEOF || as_write_fail=1
+cat >$CONFIG_STATUS <<_ACEOF || ac_write_fail=1
#! $SHELL
# Generated by $as_me.
# Run this file to recreate the current configuration.
@@ -4242,18 +5238,17 @@ cat >$CONFIG_STATUS <<_ASEOF || as_write_fail=1
debug=false
ac_cs_recheck=false
ac_cs_silent=false
SHELL=\${CONFIG_SHELL-$SHELL}
-export SHELL
-_ASEOF
-cat >>$CONFIG_STATUS <<\_ASEOF || as_write_fail=1
-## M4sh Initialization. ##
+_ACEOF
+cat >>$CONFIG_STATUS <<\_ACEOF || ac_write_fail=1
+## M4sh Initialization. ##
# Be more Bourne compatible
DUALCASE=1; export DUALCASE # for MKS sh
-if test -n "${ZSH_VERSION+set}" && (emulate sh) >/dev/null 2>&1; then :
+if test -n "${ZSH_VERSION+set}" && (emulate sh) >/dev/null 2>&1; then
emulate sh
NULLCMD=:
# Pre-4.2 versions of Zsh do word splitting on ${1+"$@"}, which
@@ -4261,15 +5256,23 @@ if test -n "${ZSH_VERSION+set}" && (emulate sh) >/dev/null 2>&1; then :
alias -g '${1+"$@"}'='"$@"'
setopt NO_GLOB_SUBST
else
- case `(set -o) 2>/dev/null` in #(
- *posix*) :
- set -o posix ;; #(
+ case `(set -o) 2>/dev/null` in
+ *posix*) set -o posix ;;
esac
fi
+# PATH needs CR
+# Avoid depending upon Character Ranges.
+as_cr_letters='abcdefghijklmnopqrstuvwxyz'
+as_cr_LETTERS='ABCDEFGHIJKLMNOPQRSTUVWXYZ'
+as_cr_Letters=$as_cr_letters$as_cr_LETTERS
+as_cr_digits='0123456789'
+as_cr_alnum=$as_cr_Letters$as_cr_digits
as_nl='
export as_nl
@@ -4277,13 +5280,7 @@ export as_nl
as_echo='\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\'
as_echo=$as_echo$as_echo$as_echo$as_echo$as_echo
as_echo=$as_echo$as_echo$as_echo$as_echo$as_echo$as_echo
-# Prefer a ksh shell builtin over an external printf program on Solaris,
-# but without wasting forks for bash or zsh.
-if test -z "$BASH_VERSION$ZSH_VERSION" \
- && (test "X`print -r -- $as_echo`" = "X$as_echo") 2>/dev/null; then
- as_echo='print -r --'
- as_echo_n='print -rn --'
-elif (test "X`printf %s $as_echo`" = "X$as_echo") 2>/dev/null; then
+if (test "X`printf %s $as_echo`" = "X$as_echo") 2>/dev/null; then
as_echo='printf %s\n'
as_echo_n='printf %s'
else
@@ -4294,7 +5291,7 @@ else
as_echo_body='eval expr "X$1" : "X\\(.*\\)"'
as_echo_n_body='eval
arg=$1;
- case $arg in #(
+ case $arg in
*"$as_nl"*)
expr "X$arg" : "X\\(.*\\)$as_nl";
arg=`expr "X$arg" : ".*$as_nl\\(.*\\)"`;;
@@ -4317,6 +5314,13 @@ if test "${PATH_SEPARATOR+set}" != set; then
fi
+# Support unset when possible.
+if ( (MAIL=60; unset MAIL) || exit) >/dev/null 2>&1; then
+ as_unset=unset
+else
+ as_unset=false
+fi
# IFS
# We need space, tab and new line, in precisely that order. Quoting is
@@ -4326,16 +5330,15 @@ fi
IFS=" "" $as_nl"
# Find who we are. Look in the path if we contain no directory separator.
-as_myself=
-case $0 in #((
+case $0 in
*[\\/]* ) as_myself=$0 ;;
*) as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
for as_dir in $PATH
do
IFS=$as_save_IFS
- test -r "$as_dir/$0" && as_myself=$as_dir/$0 && break
- done
+ test -r "$as_dir/$0" && as_myself=$as_dir/$0 && break
+done
IFS=$as_save_IFS
@@ -4347,16 +5350,12 @@ if test "x$as_myself" = x; then
fi
if test ! -f "$as_myself"; then
$as_echo "$as_myself: error: cannot find myself; rerun with an absolute file name" >&2
- exit 1
fi
-# Unset variables that we do not need and which cause bugs (e.g. in
-# pre-3.0 UWIN ksh). But do not cause bugs in bash 2.01; the "|| exit 1"
-# suppresses any "Segmentation fault" message there. '((' could
-# trigger a bug in pdksh 5.2.14.
-for as_var in BASH_ENV ENV MAIL MAILPATH
-do eval test x\${$as_var+set} = xset \
- && ( (unset $as_var) || exit 1) >/dev/null 2>&1 && unset $as_var || :
+# Work around bugs in pre-3.0 UWIN ksh.
+for as_var in ENV MAIL MAILPATH
+do ($as_unset $as_var) >/dev/null 2>&1 && $as_unset $as_var
done
PS1='$ '
PS2='> '
@@ -4368,89 +5367,7 @@ export LC_ALL
LANGUAGE=C
export LANGUAGE
-# CDPATH.
-(unset CDPATH) >/dev/null 2>&1 && unset CDPATH
-# as_fn_error STATUS ERROR [LINENO LOG_FD]
-# Output "`basename $0`: error: ERROR" to stderr. If LINENO and LOG_FD are
-# provided, also output the error to LOG_FD, referencing LINENO. Then exit the
-# script with STATUS, using 1 if that was 0.
-as_fn_error ()
- as_status=$1; test $as_status -eq 0 && as_status=1
- if test "$4"; then
- as_lineno=${as_lineno-"$3"} as_lineno_stack=as_lineno_stack=$as_lineno_stack
- $as_echo "$as_me:${as_lineno-$LINENO}: error: $2" >&$4
- fi
- $as_echo "$as_me: error: $2" >&2
- as_fn_exit $as_status
-} # as_fn_error
-# as_fn_set_status STATUS
-# Set $? to STATUS, without forking.
-as_fn_set_status ()
- return $1
-} # as_fn_set_status
-# as_fn_exit STATUS
-# Exit the shell with STATUS, even in a "trap 0" or "set -e" context.
-as_fn_exit ()
- set +e
- as_fn_set_status $1
- exit $1
-} # as_fn_exit
-# as_fn_unset VAR
-# Portably unset VAR.
-as_fn_unset ()
- { eval $1=; unset $1;}
-as_unset=as_fn_unset
-# as_fn_append VAR VALUE
-# Append the text in VALUE to the end of the definition contained in VAR. Take
-# advantage of any shell optimizations that allow amortized linear growth over
-# repeated appends, instead of the typical quadratic growth present in naive
-# implementations.
-if (eval "as_var=1; as_var+=2; test x\$as_var = x12") 2>/dev/null; then :
- eval 'as_fn_append ()
- eval $1+=\$2
-else
- as_fn_append ()
- eval $1=\$$1\$2
-fi # as_fn_append
-# as_fn_arith ARG...
-# Perform arithmetic evaluation on the ARGs, and store the result in the
-# global $as_val. Take advantage of shells that can avoid forks. The arguments
-# must be portable across $(()) and expr.
-if (eval "test \$(( 1 + 1 )) = 2") 2>/dev/null; then :
- eval 'as_fn_arith ()
- as_val=$(( $* ))
-else
- as_fn_arith ()
- as_val=`expr "$@" || test $? -eq 1`
-fi # as_fn_arith
+# Required to use basename.
if expr a : '\(a\)' >/dev/null 2>&1 &&
test "X`expr 00001 : '.*\(...\)'`" = X001; then
as_expr=expr
@@ -4464,12 +5381,8 @@ else
as_basename=false
fi
-if (as_dir=`dirname -- /` && test "X$as_dir" = X/) >/dev/null 2>&1; then
- as_dirname=dirname
-else
- as_dirname=false
-fi
+# Name of the executable.
as_me=`$as_basename -- "$0" ||
$as_expr X/"$0" : '.*/\([^/][^/]*\)/*$' \| \
X"$0" : 'X\(//\)$' \| \
@@ -4489,25 +5402,76 @@ $as_echo X/"$0" |
s/.*/./; q'`
-# Avoid depending upon Character Ranges.
-as_cr_letters='abcdefghijklmnopqrstuvwxyz'
-as_cr_LETTERS='ABCDEFGHIJKLMNOPQRSTUVWXYZ'
-as_cr_Letters=$as_cr_letters$as_cr_LETTERS
-as_cr_digits='0123456789'
-as_cr_alnum=$as_cr_Letters$as_cr_digits
+# CDPATH.
+$as_unset CDPATH
+ as_lineno_1=$LINENO
+ as_lineno_2=$LINENO
+ test "x$as_lineno_1" != "x$as_lineno_2" &&
+ test "x`expr $as_lineno_1 + 1`" = "x$as_lineno_2" || {
+ # Create $as_me.lineno as a copy of $as_myself, but with $LINENO
+ # uniformly replaced by the line number. The first 'sed' inserts a
+ # line-number line after each line using $LINENO; the second 'sed'
+ # does the real work. The second script uses 'N' to pair each
+ # line-number line with the line containing $LINENO, and appends
+ # trailing '-' during substitution so that $LINENO is not a special
+ # case at line end.
+ # (Raja R Harinath suggested sed '=', and Paul Eggert wrote the
+ # scripts with optimization help from Paolo Bonzini. Blame Lee
+ # E. McMahon (1931-1989) for sed's syntax. :-)
+ sed -n '
+ p
+ /[$]LINENO/=
+ ' <$as_myself |
+ sed '
+ s/[$]LINENO.*/&-/
+ t lineno
+ b
+ :lineno
+ N
+ :loop
+ s/[$]LINENO\([^'$as_cr_alnum'_].*\n\)\(.*\)/\2\1\2/
+ t loop
+ s/-\n.*//
+ ' >$as_me.lineno &&
+ chmod +x "$as_me.lineno" ||
+ { $as_echo "$as_me: error: cannot create $as_me.lineno; rerun with a POSIX shell" >&2
+ # Don't try to exec as it changes $[0], causing all sort of problems
+ # (the dirname of $[0] is not the place where we might find the
+ # original and so on. Autoconf is especially sensitive to this).
+ . "./$as_me.lineno"
+ # Exit status is that of the last command.
+ exit
+if (as_dir=`dirname -- /` && test "X$as_dir" = X/) >/dev/null 2>&1; then
+ as_dirname=dirname
+else
+ as_dirname=false
+fi
ECHO_C= ECHO_N= ECHO_T=
-case `echo -n x` in #(((((
+case `echo -n x` in
-n*)
- case `echo 'xy\c'` in
+ case `echo 'x\c'` in
*c*) ECHO_T=' ';; # ECHO_T is single tab character.
- xy) ECHO_C='\c';;
- *) echo `echo ksh88 bug on AIX 6.1` > /dev/null
- ECHO_T=' ';;
+ *) ECHO_C='\c';;
esac;;
ECHO_N='-n';;
esac
+if expr a : '\(a\)' >/dev/null 2>&1 &&
+ test "X`expr 00001 : '.*\(...\)'`" = X001; then
+ as_expr=expr
+else
+ as_expr=false
+fi
rm -f conf$$ conf$$.exe conf$$.file
if test -d conf$$.dir; then
@@ -4522,85 +5486,49 @@ if (echo >conf$$.file) 2>/dev/null; then
# ... but there are two gotchas:
# 1) On MSYS, both `ln -s file dir' and `ln file dir' fail.
# 2) DJGPP < 2.04 has no symlinks; `ln -s' creates a wrapper executable.
- # In both cases, we have to default to `cp -pR'.
+ # In both cases, we have to default to `cp -p'.
ln -s conf$$.file conf$$.dir 2>/dev/null && test ! -f conf$$.exe ||
- as_ln_s='cp -pR'
+ as_ln_s='cp -p'
elif ln conf$$.file conf$$ 2>/dev/null; then
as_ln_s=ln
else
- as_ln_s='cp -pR'
+ as_ln_s='cp -p'
fi
else
- as_ln_s='cp -pR'
+ as_ln_s='cp -p'
fi
rm -f conf$$ conf$$.exe conf$$.dir/conf$$.file conf$$.file
rmdir conf$$.dir 2>/dev/null
-# as_fn_mkdir_p
-# Create "$as_dir" as a directory, including parents if necessary.
-as_fn_mkdir_p ()
- case $as_dir in #(
- -*) as_dir=./$as_dir;;
- esac
- test -d "$as_dir" || eval $as_mkdir_p || {
- as_dirs=
- while :; do
- *\'*) as_qdir=`$as_echo "$as_dir" | sed "s/'/'\\\\\\\\''/g"`;; #'(
- *) as_qdir=$as_dir;;
- esac
- as_dirs="'$as_qdir' $as_dirs"
- as_dir=`$as_dirname -- "$as_dir" ||
-$as_expr X"$as_dir" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
- X"$as_dir" : 'X\(//\)[^/]' \| \
- X"$as_dir" : 'X\(//\)$' \| \
- X"$as_dir" : 'X\(/\)' \| . 2>/dev/null ||
-$as_echo X"$as_dir" |
- sed '/^X\(.*[^/]\)\/\/*[^/][^/]*\/*$/{
- s//\1/
- q
- /^X\(\/\/\)[^/].*/{
- s//\1/
- q
- /^X\(\/\/\)$/{
- s//\1/
- q
- /^X\(\/\).*/{
- s//\1/
- q
- s/.*/./; q'`
- test -d "$as_dir" && break
- done
- test -z "$as_dirs" || eval "mkdir $as_dirs"
- } || test -d "$as_dir" || as_fn_error $? "cannot create directory $as_dir"
-} # as_fn_mkdir_p
if mkdir -p . 2>/dev/null; then
- as_mkdir_p='mkdir -p "$as_dir"'
+ as_mkdir_p=:
else
test -d ./-p && rmdir ./-p
as_mkdir_p=false
fi
-# as_fn_executable_p FILE
-# Test if FILE is an executable regular file.
-as_fn_executable_p ()
- test -f "$1" && test -x "$1"
-} # as_fn_executable_p
-as_test_x='test -x'
-as_executable_p=as_fn_executable_p
+if test -x / >/dev/null 2>&1; then
+ as_test_x='test -x'
+else
+ if ls -dL / >/dev/null 2>&1; then
+ as_ls_L_option=L
+ else
+ as_ls_L_option=
+ fi
+ as_test_x='
+ eval sh -c '\''
+ if test -d "$1"; then
+ test -d "$1/.";
+ else
+ case $1 in
+ -*)set "./$1";;
+ esac;
+ case `ls -ld'$as_ls_L_option' "$1" 2>/dev/null` in
+ ???[sx]*):;;*)false;;esac;fi
+ '\'' sh
+fi
+as_executable_p=$as_test_x
# Sed expression to map a string onto a valid CPP name.
as_tr_cpp="eval sed 'y%*$as_cr_letters%P$as_cr_LETTERS%;s%[^_$as_cr_alnum]%_%g'"
@@ -4610,19 +5538,13 @@ as_tr_sh="eval sed 'y%*+%pp%;s%[^_$as_cr_alnum]%_%g'"
exec 6>&1
-## Main body of $CONFIG_STATUS script. ##
-_ASEOF
-test $as_write_fail = 0 && chmod +x $CONFIG_STATUS || ac_write_fail=1
-cat >>$CONFIG_STATUS <<\_ACEOF || ac_write_fail=1
-# Save the log message, to keep $0 and so on meaningful, and to
+# Save the log message, to keep $[0] and so on meaningful, and to
# report actual input values of CONFIG_FILES etc. instead of their
# values after options handling.
ac_log="
This file was extended by darshan-util $as_me 3.0.0-pre1, which was
-generated by GNU Autoconf 2.69. Invocation command line was
+generated by GNU Autoconf 2.63. Invocation command line was
CONFIG_FILES = $CONFIG_FILES
CONFIG_HEADERS = $CONFIG_HEADERS
@@ -4653,15 +5575,13 @@ _ACEOF
ac_cs_usage="\
-\`$as_me' instantiates files and other configuration actions
-from templates according to the current configuration. Unless the files
-and actions are specified as TAGs, all are instantiated by default.
+\`$as_me' instantiates files from templates according to the
+current configuration.
-Usage: $0 [OPTION]... [TAG]...
+Usage: $0 [OPTION]... [FILE]...
-h, --help print this help, then exit
-V, --version print version number and configuration settings, then exit
- --config print configuration, then exit
-q, --quiet, --silent
do not print progress messages
-d, --debug don't remove temporary files
@@ -4677,17 +5597,16 @@ $config_files
Configuration headers:
$config_headers
-Report bugs to the package provider."
+Report bugs to <bug-autoconf at gnu.org>."
_ACEOF
cat >>$CONFIG_STATUS <<_ACEOF || ac_write_fail=1
-ac_cs_config="`$as_echo "$ac_configure_args" | sed 's/^ //; s/[\\""\`\$]/\\\\&/g'`"
ac_cs_version="\\
darshan-util config.status 3.0.0-pre1
-configured by $0, generated by GNU Autoconf 2.69,
- with options \\"\$ac_cs_config\\"
+configured by $0, generated by GNU Autoconf 2.63,
+ with options \\"`$as_echo "$ac_configure_args" | sed 's/^ //; s/[\\""\`\$]/\\\\&/g'`\\"
-Copyright (C) 2012 Free Software Foundation, Inc.
+Copyright (C) 2008 Free Software Foundation, Inc.
This config.status script is free software; the Free Software Foundation
gives unlimited permission to copy, distribute and modify it."
@@ -4703,16 +5622,11 @@ ac_need_defaults=:
while test $# != 0
do
case $1 in
ac_option=`expr "X$1" : 'X\([^=]*\)='`
ac_optarg=`expr "X$1" : 'X[^=]*=\(.*\)'`
ac_shift=:
- ac_option=`expr "X$1" : 'X\([^=]*\)='`
- ac_optarg=
- ac_shift=:
ac_option=$1
ac_optarg=$2
@@ -4726,29 +5640,27 @@ do
ac_cs_recheck=: ;;
--version | --versio | --versi | --vers | --ver | --ve | --v | -V )
$as_echo "$ac_cs_version"; exit ;;
- --config | --confi | --conf | --con | --co | --c )
- $as_echo "$ac_cs_config"; exit ;;
--debug | --debu | --deb | --de | --d | -d )
debug=: ;;
--file | --fil | --fi | --f )
$ac_shift
case $ac_optarg in
*\'*) ac_optarg=`$as_echo "$ac_optarg" | sed "s/'/'\\\\\\\\''/g"` ;;
- '') as_fn_error $? "missing file argument" ;;
esac
- as_fn_append CONFIG_FILES " '$ac_optarg'"
+ CONFIG_FILES="$CONFIG_FILES '$ac_optarg'"
ac_need_defaults=false;;
--header | --heade | --head | --hea )
$ac_shift
case $ac_optarg in
esac
- as_fn_append CONFIG_HEADERS " '$ac_optarg'"
+ CONFIG_HEADERS="$CONFIG_HEADERS '$ac_optarg'"
--he | --h)
# Conflict between --help and --header
- as_fn_error $? "ambiguous option: \`$1'
-Try \`$0 --help' for more information.";;
+ { $as_echo "$as_me: error: ambiguous option: $1
+Try \`$0 --help' for more information." >&2
+ { (exit 1); exit 1; }; };;
--help | --hel | -h )
$as_echo "$ac_cs_usage"; exit ;;
-q | -quiet | --quiet | --quie | --qui | --qu | --q \
@@ -4756,10 +5668,11 @@ Try \`$0 --help' for more information.";;
ac_cs_silent=: ;;
# This is an error.
- -*) as_fn_error $? "unrecognized option: \`$1'
-Try \`$0 --help' for more information." ;;
+ -*) { $as_echo "$as_me: error: unrecognized option: $1
- *) as_fn_append ac_config_targets " $1"
+ *) ac_config_targets="$ac_config_targets $1"
ac_need_defaults=false ;;
esac
@@ -4776,7 +5689,7 @@ fi
_ACEOF
if \$ac_cs_recheck; then
- set X $SHELL '$0' $ac_configure_args \$ac_configure_extra_args --no-create --no-recursion
+ set X '$SHELL' '$0' $ac_configure_args \$ac_configure_extra_args --no-create --no-recursion
shift
\$as_echo "running CONFIG_SHELL=$SHELL \$*" >&6
CONFIG_SHELL='$SHELL'
@@ -4810,7 +5723,9 @@ do
"darshan-job-summary/bin/darshan-job-summary.pl") CONFIG_FILES="$CONFIG_FILES darshan-job-summary/bin/darshan-job-summary.pl" ;;
"maint/darshan-util.pc") CONFIG_FILES="$CONFIG_FILES maint/darshan-util.pc" ;;
- *) as_fn_error $? "invalid argument: \`$ac_config_target'" "$LINENO" 5;;
+ *) { { $as_echo "$as_me:$LINENO: error: invalid argument: $ac_config_target" >&5
+$as_echo "$as_me: error: invalid argument: $ac_config_target" >&2;}
esac
done
@@ -4832,24 +5747,26 @@ fi
# after its creation but before its name has been assigned to `$tmp'.
$debug ||
- tmp= ac_tmp=
+ tmp=
trap 'exit_status=$?
- : "${ac_tmp:=$tmp}"
- { test ! -d "$ac_tmp" || rm -fr "$ac_tmp"; } && exit $exit_status
+ { test -z "$tmp" || test ! -d "$tmp" || rm -fr "$tmp"; } && exit $exit_status
' 0
- trap 'as_fn_exit 1' 1 2 13 15
+ trap '{ (exit 1); exit 1; }' 1 2 13 15
# Create a (secure) tmp directory for tmp files.
tmp=`(umask 077 && mktemp -d "./confXXXXXX") 2>/dev/null` &&
- test -d "$tmp"
+ test -n "$tmp" && test -d "$tmp"
tmp=./conf$$-$RANDOM
(umask 077 && mkdir "$tmp")
-} || as_fn_error $? "cannot create a temporary directory in ." "$LINENO" 5
-ac_tmp=$tmp
+ $as_echo "$as_me: cannot create a temporary directory in ." >&2
# Set up the scripts for CONFIG_FILES section.
# No need to generate them if there are no CONFIG_FILES.
@@ -4857,13 +5774,7 @@ ac_tmp=$tmp
if test -n "$CONFIG_FILES"; then
-ac_cr=`echo X | tr X '\015'`
-# On cygwin, bash can eat \r inside `` if the user requested igncr.
-# But we know of no other shell where ac_cr would be empty at this
-# point, so we can use a bashism as a fallback.
-if test "x$ac_cr" = x; then
- eval ac_cr=\$\'\\r\'
-fi
+ac_cr='
ac_cs_awk_cr=`$AWK 'BEGIN { print "a\rb" }' </dev/null 2>/dev/null`
if test "$ac_cs_awk_cr" = "a${ac_cr}b"; then
ac_cs_awk_cr='\\r'
@@ -4871,7 +5782,7 @@ else
ac_cs_awk_cr=$ac_cr
fi
-echo 'BEGIN {' >"$ac_tmp/subs1.awk" &&
+echo 'BEGIN {' >"$tmp/subs1.awk" &&
_ACEOF
@@ -4880,18 +5791,24 @@ _ACEOF
echo "$ac_subst_vars" | sed 's/.*/&!$&$ac_delim/' &&
echo "_ACEOF"
} >conf$$subs.sh ||
- as_fn_error $? "could not make $CONFIG_STATUS" "$LINENO" 5
-ac_delim_num=`echo "$ac_subst_vars" | grep -c '^'`
+ { { $as_echo "$as_me:$LINENO: error: could not make $CONFIG_STATUS" >&5
+$as_echo "$as_me: error: could not make $CONFIG_STATUS" >&2;}
+ac_delim_num=`echo "$ac_subst_vars" | grep -c '$'`
ac_delim='%!_!# '
for ac_last_try in false false false false false :; do
. ./conf$$subs.sh ||
ac_delim_n=`sed -n "s/.*$ac_delim\$/X/p" conf$$subs.awk | grep -c X`
if test $ac_delim_n = $ac_delim_num; then
break
elif $ac_last_try; then
else
ac_delim="$ac_delim!$ac_delim _$ac_delim!! "
fi
@@ -4899,7 +5816,7 @@ done
rm -f conf$$subs.sh
-cat >>"\$ac_tmp/subs1.awk" <<\\_ACAWK &&
+cat >>"\$tmp/subs1.awk" <<\\_ACAWK &&
_ACEOF
sed -n '
h
@@ -4913,7 +5830,7 @@ s/'"$ac_delim"'$//
t delim
:nl
h
-s/\(.\{148\}\)..*/\1/
+s/\(.\{148\}\).*/\1/
t more1
s/["\\]/\\&/g; s/^/"/; s/$/\\n"\\/
p
@@ -4927,7 +5844,7 @@ s/.\{148\}//
t nl
:delim
h
t more2
s/["\\]/\\&/g; s/^/"/; s/$/"/
p
@@ -4947,7 +5864,7 @@ t delim
rm -f conf$$subs.awk
_ACAWK
-cat >>"\$ac_tmp/subs1.awk" <<_ACAWK &&
+cat >>"\$tmp/subs1.awk" <<_ACAWK &&
for (key in S) S_is_set[key] = 1
FS = ""
@@ -4979,29 +5896,23 @@ if sed "s/$ac_cr//" < /dev/null > /dev/null 2>&1; then
sed "s/$ac_cr\$//; s/$ac_cr/$ac_cs_awk_cr/g"
else
cat
-fi < "$ac_tmp/subs1.awk" > "$ac_tmp/subs.awk" \
- || as_fn_error $? "could not setup config files machinery" "$LINENO" 5
+fi < "$tmp/subs1.awk" > "$tmp/subs.awk" \
+ || { { $as_echo "$as_me:$LINENO: error: could not setup config files machinery" >&5
+$as_echo "$as_me: error: could not setup config files machinery" >&2;}
_ACEOF
-# VPATH may cause trouble with some makes, so we remove sole $(srcdir),
-# ${srcdir} and @srcdir@ entries from VPATH if srcdir is ".", strip leading and
+# VPATH may cause trouble with some makes, so we remove $(srcdir),
+# ${srcdir} and @srcdir@ from VPATH if srcdir is ".", strip leading and
# trailing colons and then remove the whole line if VPATH becomes empty
# (actually we leave an empty line to preserve line numbers).
if test "x$srcdir" = x.; then
- ac_vpsub='/^[ ]*VPATH[ ]*=[ ]*/{
-h
-s///
-s/^/:/
-s/[ ]*$/:/
-s/:\$(srcdir):/:/g
-s/:\${srcdir}:/:/g
-s/:@srcdir@:/:/g
-s/^:*//
+ ac_vpsub='/^[ ]*VPATH[ ]*=/{
+s/:*\$(srcdir):*/:/
+s/:*\${srcdir}:*/:/
+s/:*@srcdir@:*/:/
+s/^\([^=]*=[ ]*\):*/\1/
s/:*$//
-x
-s/\(=[ ]*\).*/\1/
-G
-s/\n//
s/^[^=]*=[ ]*$//
fi
@@ -5013,7 +5924,7 @@ fi # test -n "$CONFIG_FILES"
# No need to generate them if there are no CONFIG_HEADERS.
# This happens for instance with `./config.status Makefile'.
if test -n "$CONFIG_HEADERS"; then
-cat >"$ac_tmp/defines.awk" <<\_ACAWK ||
+cat >"$tmp/defines.awk" <<\_ACAWK ||
BEGIN {
_ACEOF
@@ -5025,11 +5936,13 @@ _ACEOF
# handling of long lines.
ac_delim='%!_!# '
for ac_last_try in false false :; do
- ac_tt=`sed -n "/$ac_delim/p" confdefs.h`
- if test -z "$ac_tt"; then
+ ac_t=`sed -n "/$ac_delim/p" confdefs.h`
+ if test -z "$ac_t"; then
break
- as_fn_error $? "could not make $CONFIG_HEADERS" "$LINENO" 5
+ { { $as_echo "$as_me:$LINENO: error: could not make $CONFIG_HEADERS" >&5
+$as_echo "$as_me: error: could not make $CONFIG_HEADERS" >&2;}
else
fi
@@ -5114,7 +6027,9 @@ cat >>$CONFIG_STATUS <<_ACEOF || ac_write_fail=1
_ACAWK
_ACEOF
- as_fn_error $? "could not setup config headers machinery" "$LINENO" 5
+ { { $as_echo "$as_me:$LINENO: error: could not setup config headers machinery" >&5
+$as_echo "$as_me: error: could not setup config headers machinery" >&2;}
fi # test -n "$CONFIG_HEADERS"
@@ -5127,7 +6042,9 @@ do
esac
case $ac_mode$ac_tag in
:[FHL]*:*);;
- :L* | :C*:*) as_fn_error $? "invalid tag \`$ac_tag'" "$LINENO" 5;;
+ :L* | :C*:*) { { $as_echo "$as_me:$LINENO: error: invalid tag $ac_tag" >&5
+$as_echo "$as_me: error: invalid tag $ac_tag" >&2;}
:[FH]-) ac_tag=-:-;;
:[FH]*) ac_tag=$ac_tag:$ac_tag.in;;
esac
@@ -5146,7 +6063,7 @@ do
for ac_f
do
case $ac_f in
- -) ac_f="$ac_tmp/stdin";;
+ -) ac_f="$tmp/stdin";;
*) # Look for the file first in the build tree, then in the source tree
# (if the path is not absolute). The absolute path cannot be DOS-style,
# because $ac_f cannot contain `:'.
@@ -5155,10 +6072,12 @@ do
[\\/$]*) false;;
*) test -f "$srcdir/$ac_f" && ac_f="$srcdir/$ac_f";;
esac ||
- as_fn_error 1 "cannot find input file: \`$ac_f'" "$LINENO" 5;;
+ { { $as_echo "$as_me:$LINENO: error: cannot find input file: $ac_f" >&5
+$as_echo "$as_me: error: cannot find input file: $ac_f" >&2;}
esac
case $ac_f in *\'*) ac_f=`$as_echo "$ac_f" | sed "s/'/'\\\\\\\\''/g"`;; esac
- as_fn_append ac_file_inputs " '$ac_f'"
+ ac_file_inputs="$ac_file_inputs '$ac_f'"
done
# Let's still pretend it is `configure' which instantiates (i.e., don't
@@ -5169,7 +6088,7 @@ do
`' by configure.'
if test x"$ac_file" != x-; then
configure_input="$ac_file. $configure_input"
- { $as_echo "$as_me:${as_lineno-$LINENO}: creating $ac_file" >&5
+ { $as_echo "$as_me:$LINENO: creating $ac_file" >&5
$as_echo "$as_me: creating $ac_file" >&6;}
fi
# Neutralize special characters interpreted by sed in replacement strings.
@@ -5181,8 +6100,10 @@ $as_echo "$as_me: creating $ac_file" >&6;}
esac
case $ac_tag in
- *:-:* | *:-) cat >"$ac_tmp/stdin" \
- || as_fn_error $? "could not create $ac_file" "$LINENO" 5 ;;
+ *:-:* | *:-) cat >"$tmp/stdin" \
+ || { { $as_echo "$as_me:$LINENO: error: could not create $ac_file" >&5
+$as_echo "$as_me: error: could not create $ac_file" >&2;}
esac
esac
@@ -5210,7 +6131,47 @@ $as_echo X"$ac_file" |
q
s/.*/./; q'`
- as_dir="$ac_dir"; as_fn_mkdir_p
+ { as_dir="$ac_dir"
+ case $as_dir in #(
+ -*) as_dir=./$as_dir;;
+ esac
+ test -d "$as_dir" || { $as_mkdir_p && mkdir -p "$as_dir"; } || {
+ as_dirs=
+ while :; do
+ *\'*) as_qdir=`$as_echo "$as_dir" | sed "s/'/'\\\\\\\\''/g"`;; #'(
+ *) as_qdir=$as_dir;;
+ esac
+ as_dirs="'$as_qdir' $as_dirs"
+ as_dir=`$as_dirname -- "$as_dir" ||
+$as_expr X"$as_dir" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
+ X"$as_dir" : 'X\(//\)[^/]' \| \
+ X"$as_dir" : 'X\(//\)$' \| \
+ X"$as_dir" : 'X\(/\)' \| . 2>/dev/null ||
+$as_echo X"$as_dir" |
+ sed '/^X\(.*[^/]\)\/\/*[^/][^/]*\/*$/{
+ s//\1/
+ q
+ /^X\(\/\/\)[^/].*/{
+ s//\1/
+ q
+ /^X\(\/\/\)$/{
+ s//\1/
+ q
+ /^X\(\/\).*/{
+ s//\1/
+ q
+ s/.*/./; q'`
+ test -d "$as_dir" && break
+ done
+ test -z "$as_dirs" || eval "mkdir $as_dirs"
+ } || test -d "$as_dir" || { { $as_echo "$as_me:$LINENO: error: cannot create directory $as_dir" >&5
+$as_echo "$as_me: error: cannot create directory $as_dir" >&2;}
ac_builddir=.
case "$ac_dir" in
@@ -5262,6 +6223,7 @@ cat >>$CONFIG_STATUS <<\_ACEOF || ac_write_fail=1
# If the template does not know about datarootdir, expand it.
# FIXME: This hack should be removed a few years after 2.60.
ac_datarootdir_hack=; ac_datarootdir_seen=
ac_sed_dataroot='
/datarootdir/ {
p
@@ -5271,11 +6233,12 @@ ac_sed_dataroot='
/@docdir@/p
/@infodir@/p
/@localedir@/p
-/@mandir@/p'
+/@mandir@/p
case `eval "sed -n \"\$ac_sed_dataroot\" $ac_file_inputs"` in
*datarootdir*) ac_datarootdir_seen=yes;;
*@datadir@*|*@docdir@*|*@infodir@*|*@localedir@*|*@mandir@*)
- { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: $ac_file_inputs seems to ignore the --datarootdir setting" >&5
+ { $as_echo "$as_me:$LINENO: WARNING: $ac_file_inputs seems to ignore the --datarootdir setting" >&5
$as_echo "$as_me: WARNING: $ac_file_inputs seems to ignore the --datarootdir setting" >&2;}
_ACEOF
@@ -5285,7 +6248,7 @@ cat >>$CONFIG_STATUS <<_ACEOF || ac_write_fail=1
s&@infodir@&$infodir&g
s&@localedir@&$localedir&g
s&@mandir@&$mandir&g
- s&\\\${datarootdir}&$datarootdir&g' ;;
+ s&\\\${datarootdir}&$datarootdir&g' ;;
esac
_ACEOF
@@ -5312,24 +6275,27 @@ s&@abs_top_builddir@&$ac_abs_top_builddir&;t t
s&@INSTALL@&$ac_INSTALL&;t t
$ac_datarootdir_hack
-eval sed \"\$ac_sed_extra\" "$ac_file_inputs" | $AWK -f "$ac_tmp/subs.awk" \
- >$ac_tmp/out || as_fn_error $? "could not create $ac_file" "$LINENO" 5
+eval sed \"\$ac_sed_extra\" "$ac_file_inputs" | $AWK -f "$tmp/subs.awk" >$tmp/out \
test -z "$ac_datarootdir_hack$ac_datarootdir_seen" &&
- { ac_out=`sed -n '/\${datarootdir}/p' "$ac_tmp/out"`; test -n "$ac_out"; } &&
- { ac_out=`sed -n '/^[ ]*datarootdir[ ]*:*=/p' \
- "$ac_tmp/out"`; test -z "$ac_out"; } &&
- { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: $ac_file contains a reference to the variable \`datarootdir'
-which seems to be undefined. Please make sure it is defined" >&5
+ { ac_out=`sed -n '/\${datarootdir}/p' "$tmp/out"`; test -n "$ac_out"; } &&
+ { ac_out=`sed -n '/^[ ]*datarootdir[ ]*:*=/p' "$tmp/out"`; test -z "$ac_out"; } &&
+ { $as_echo "$as_me:$LINENO: WARNING: $ac_file contains a reference to the variable \`datarootdir'
+which seems to be undefined. Please make sure it is defined." >&5
$as_echo "$as_me: WARNING: $ac_file contains a reference to the variable \`datarootdir'
-which seems to be undefined. Please make sure it is defined" >&2;}
+which seems to be undefined. Please make sure it is defined." >&2;}
- rm -f "$ac_tmp/stdin"
+ rm -f "$tmp/stdin"
case $ac_file in
- -) cat "$ac_tmp/out" && rm -f "$ac_tmp/out";;
- *) rm -f "$ac_file" && mv "$ac_tmp/out" "$ac_file";;
+ -) cat "$tmp/out" && rm -f "$tmp/out";;
+ *) rm -f "$ac_file" && mv "$tmp/out" "$ac_file";;
esac \
:H)
@@ -5338,21 +6304,27 @@ which seems to be undefined. Please make sure it is defined" >&2;}
$as_echo "/* $configure_input */" \
- && eval '$AWK -f "$ac_tmp/defines.awk"' "$ac_file_inputs"
- } >"$ac_tmp/config.h" \
- if diff "$ac_file" "$ac_tmp/config.h" >/dev/null 2>&1; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: $ac_file is unchanged" >&5
+ && eval '$AWK -f "$tmp/defines.awk"' "$ac_file_inputs"
+ } >"$tmp/config.h" \
+ if diff "$ac_file" "$tmp/config.h" >/dev/null 2>&1; then
+ { $as_echo "$as_me:$LINENO: $ac_file is unchanged" >&5
$as_echo "$as_me: $ac_file is unchanged" >&6;}
else
rm -f "$ac_file"
- mv "$ac_tmp/config.h" "$ac_file" \
+ mv "$tmp/config.h" "$ac_file" \
fi
else
- && eval '$AWK -f "$ac_tmp/defines.awk"' "$ac_file_inputs" \
- || as_fn_error $? "could not create -" "$LINENO" 5
+ && eval '$AWK -f "$tmp/defines.awk"' "$ac_file_inputs" \
+ || { { $as_echo "$as_me:$LINENO: error: could not create -" >&5
+$as_echo "$as_me: error: could not create -" >&2;}
fi
@@ -5362,12 +6334,15 @@ $as_echo "$as_me: $ac_file is unchanged" >&6;}
done # for ac_tag
-as_fn_exit 0
+{ (exit 0); exit 0; }
_ACEOF
+chmod +x $CONFIG_STATUS
ac_clean_files=$ac_clean_files_save
test $ac_write_fail = 0 ||
- as_fn_error $? "write failure creating $CONFIG_STATUS" "$LINENO" 5
+ { { $as_echo "$as_me:$LINENO: error: write failure creating $CONFIG_STATUS" >&5
+$as_echo "$as_me: error: write failure creating $CONFIG_STATUS" >&2;}
# configure is writing to config.log, and then calls config.status.
@@ -5388,15 +6363,15 @@ if test "$no_create" != yes; then
exec 5>>config.log
# Use ||, not &&, to avoid exiting from the if with $? = 1, which
# would make configure fail if this is the last instruction.
- $ac_cs_success || as_fn_exit 1
+ $ac_cs_success || { (exit 1); exit 1; }
fi
if test -n "$ac_unrecognized_opts" && test "$enable_option_checking" != no; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: unrecognized options: $ac_unrecognized_opts" >&5
+ { $as_echo "$as_me:$LINENO: WARNING: unrecognized options: $ac_unrecognized_opts" >&5
$as_echo "$as_me: WARNING: unrecognized options: $ac_unrecognized_opts" >&2;}
fi
if test x$HAVE_PDFLATEX != xyes; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: Please install pdflatex if you wish to use the darshan-job-summary.pl utility" >&5
+ { $as_echo "$as_me:$LINENO: WARNING: Please install pdflatex if you wish to use the darshan-job-summary.pl utility" >&5
$as_echo "$as_me: WARNING: Please install pdflatex if you wish to use the darshan-job-summary.pl utility" >&2;}
fi
diff --git a/darshan-util/darshan-util-config.h.in b/darshan-util/darshan-util-config.h.in
index f48e068..8541fac 100644
--- a/darshan-util/darshan-util-config.h.in
+++ b/darshan-util/darshan-util-config.h.in
@@ -54,9 +54,6 @@
/* Define to the one symbol short name of this package. */
#undef PACKAGE_TARNAME
-/* Define to the home page for this package. */
-#undef PACKAGE_URL
/* Define to the version of this package. */
#undef PACKAGE_VERSION
hooks/post-receive
More information about the Darshan-commits
