[Darshan-commits] [Darshan] branch, dev-modular, updated. darshan-2.3.1-184-g67b02ca
Service Account
git at mcs.anl.gov
Tue Sep 22 17:32:19 CDT 2015
This is an automated email from the git hooks/post-receive script. It was
generated because a ref change was pushed to the repository containing
the project "".
The branch, dev-modular has been updated
via 67b02ca5120f74d7a7134f2761bc4db0e6b2bead (commit)
from 991aaa2fbf770a5e4c03848ce6a4e8aa7896f582 (commit)
Those revisions listed above that are new to this repository have
not appeared on any other notification email; so we list those
revisions in full, below.
- Log -----------------------------------------------------------------
commit 67b02ca5120f74d7a7134f2761bc4db0e6b2bead
Author: Shane Snyder <ssnyder at mcs.anl.gov>
Date: Tue Sep 22 17:31:54 2015 -0500
x-macro the logutil defs
Summary of changes:
darshan-log-format.h | 17 ++++++++---------
darshan-util/darshan-logutils.c | 22 ++++------------------
darshan-util/darshan-logutils.h | 2 +-
3 files changed, 13 insertions(+), 28 deletions(-)
Diff of changes:
diff --git a/darshan-log-format.h b/darshan-log-format.h
index a7cc4e3..07fe9b5 100644
--- a/darshan-log-format.h
+++ b/darshan-log-format.h
@@ -33,23 +33,22 @@
#define DARSHAN_MAX_MODS 16
-/* TODO: do we want the logutil defs here ? */
/* X-macro for keeping module ordering consistent */
/* NOTE: first val used to define module enum values,
* second val used to define module name strings, and
* third val is used to provide the name of a
* corresponding logutils structure for parsing module
- * data out of the log file (only used in darshan-util,
- * just pass NULL (no quotes) if no log parsing
- * functions are required).
+ * data out of the log file (only used in darshan-util
+ * component -- NULL can be passed if there are no
+ * logutil definitions)
#define DARSHAN_MODULE_IDS \
X(DARSHAN_NULL_MOD, "NULL", NULL) \
- X(DARSHAN_POSIX_MOD, "POSIX", posix_logutils) \
- X(DARSHAN_MPIIO_MOD, "MPI-IO", mpiio_logutils) \
- X(DARSHAN_HDF5_MOD, "HDF5", hdf5_logutils) \
- X(DARSHAN_PNETCDF_MOD, "PNETCDF", pnetcdf_logutils) \
- X(DARSHAN_BGQ_MOD, "BG/Q", bgq_logutils)
+ X(DARSHAN_POSIX_MOD, "POSIX", &posix_logutils) \
+ X(DARSHAN_MPIIO_MOD, "MPI-IO", &mpiio_logutils) \
+ X(DARSHAN_HDF5_MOD, "HDF5", &hdf5_logutils) \
+ X(DARSHAN_PNETCDF_MOD, "PNETCDF", &pnetcdf_logutils) \
+ X(DARSHAN_BGQ_MOD, "BG/Q", &bgq_logutils)
/* unique identifiers to distinguish between available darshan modules */
/* NOTES: - valid ids range from [0...DARSHAN_MAX_MODS-1]
diff --git a/darshan-util/darshan-logutils.c b/darshan-util/darshan-logutils.c
index aa4afde..732fac7 100644
--- a/darshan-util/darshan-logutils.c
+++ b/darshan-util/darshan-logutils.c
@@ -88,27 +88,13 @@ static int darshan_log_dzunload(darshan_fd fd, struct darshan_log_map *map_p);
/* TODO: check comments on functions to make sure they are right /cleanup */
-/* TODO: can we make this s.t. we don't care about ordering (i.e., X macro it ) */
-/* see gzip interface for ideas */
+/* each module's implementation of the darshan logutil functions */
+#define X(a, b, c) c,
struct darshan_mod_logutil_funcs *mod_logutils[DARSHAN_MAX_MODS] =
- NULL, /* NULL */
- &posix_logutils, /* POSIX */
- &mpiio_logutils, /* MPI-IO */
- &hdf5_logutils, /* HDF5 */
- &pnetcdf_logutils, /* PNETCDF */
- &bgq_logutils, /* BG/Q */
- NULL,
- NULL,
- NULL,
- NULL,
- NULL,
- NULL,
- NULL,
- NULL,
- NULL,
- NULL
+ DARSHAN_MODULE_IDS
+#undef X
/* darshan_log_open()
diff --git a/darshan-util/darshan-logutils.h b/darshan-util/darshan-logutils.h
index 7274341..d6c120a 100644
--- a/darshan-util/darshan-logutils.h
+++ b/darshan-util/darshan-logutils.h
@@ -68,7 +68,7 @@ struct darshan_mod_logutil_funcs
-extern struct darshan_mod_logutil_funcs *mod_logutils[DARSHAN_MAX_MODS];
+extern struct darshan_mod_logutil_funcs *mod_logutils[];
#include "darshan-posix-logutils.h"
#include "darshan-mpiio-logutils.h"
hooks/post-receive
More information about the Darshan-commits
