[Darshan-commits] [Darshan] branch, dev-modular, updated. darshan-2.3.1-175-gae15d89
Service Account git at mcs.anl.gov
Thu Sep 10 15:17:20 CDT 2015
This is an automated email from the git hooks/post-receive script. It was
generated because a ref change was pushed to the repository containing
the project "".
The branch, dev-modular has been updated
       via  ae15d896720a92d229119944890da28a9f4a2038 (commit)
      from  22bc23f2782273ebe8c65eb559f67d9b4b8004e4 (commit)
Those revisions listed above that are new to this repository have
not appeared on any other notification email; so we list those
revisions in full, below.
- Log -----------------------------------------------------------------
commit ae15d896720a92d229119944890da28a9f4a2038
Author: Shane Snyder <ssnyder at mcs.anl.gov>
Date:   Thu Sep 10 13:06:14 2015 -0500
    cleanup runtime component code & docs
Summary of changes:
 darshan-runtime/configure                 |   13 +--------
 darshan-runtime/configure.in              |    7 +----
 darshan-runtime/darshan-gen-cc.pl.in      |    3 +-
 darshan-runtime/darshan-gen-cxx.pl.in     |    2 +-
 darshan-runtime/darshan-gen-fortran.pl.in |    2 +-
 darshan-runtime/doc/darshan-runtime.txt   |   41 ++++++++++------------------
 darshan-runtime/lib/darshan-core.c        |   34 ++++++++++++------------
 darshan-runtime/lib/darshan-hdf5.c        |    5 +++-
 darshan-runtime/lib/darshan-mpiio.c       |    7 +++-
 darshan-runtime/lib/darshan-pnetcdf.c     |    5 +++-
 darshan-runtime/lib/darshan-posix.c       |    5 +++-
 11 files changed, 54 insertions(+), 70 deletions(-)
Diff of changes:
diff --git a/darshan-runtime/configure b/darshan-runtime/configure
index be3e002..176ccc2 100755
--- a/darshan-runtime/configure
+++ b/darshan-runtime/configure
@@ -683,7 +683,6 @@ SHELL'
 ac_subst_files=''
 ac_user_opts='
 enable_option_checking
-with_zlib_for_mpi
 with_zlib
 enable_cuserid
 enable_ld_preload
@@ -1321,13 +1320,12 @@ Optional Features:
 Optional Packages:
   --with-PACKAGE[=ARG]    use PACKAGE [ARG=yes]
   --without-PACKAGE       do not use PACKAGE (same as --with-PACKAGE=no)
   --with-zlib=DIR root directory path of zlib installation defaults to
                     /usr/local or /usr if not found in /usr/local
   --without-zlib to disable zlib usage completely
   --with-mem-align=<num>  Memory alignment in bytes
   --with-log-path-by-env=<env var list> Comma separated list of environment variables to check for log path location before --with-log-path path
-  --with-log-hints=<hint1=x,hint2=y>  Semicolon-separated list of MPI-IO hints for log file write
+  --with-log-hints=<hint1=x;hint2=y>  Semicolon-separated list of MPI-IO hints for log file write
   --with-log-path=<path>  Location to store log files at run time
   --with-jobid-env=<name> Name of environment variable that stores the jobid
     (specify "NONE" if no appropriate environment variable is available:
@@ -3050,15 +3048,6 @@ $as_echo "no" >&6; }
 fi
 rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext
-# Check whether --with-zlib-for-mpi was given.
-if test "${with_zlib_for_mpi+set}" = set; then :
-  withval=$with_zlib_for_mpi; as_fn_error $? "with-zlib-for-mpi argument is deprecated.  Please see Darshan documentation." "$LINENO" 5
-fi
 ac_ext=c
 ac_cpp='$CPP $CPPFLAGS'
 ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5'
diff --git a/darshan-runtime/configure.in b/darshan-runtime/configure.in
index d88b8f7..a995658 100644
--- a/darshan-runtime/configure.in
+++ b/darshan-runtime/configure.in
@@ -21,11 +21,6 @@ AC_TRY_COMPILE([#include <mpi.h>], [int ret = MPI_Init(0, (void*)0)],
     AC_MSG_ERROR(CC doesn't appear to be a valid MPI compiler.  See INSTALL document or try adding CC=mpicc to your configure command line.)
-AC_ARG_WITH(zlib-for-mpi,,
-    AC_MSG_ERROR(with-zlib-for-mpi argument is deprecated.  Please see Darshan documentation.)
 dnl runtime libraries require zlib
 CHECK_ZLIB
@@ -72,7 +67,7 @@ AC_ARG_WITH(log-path-by-env,
 AC_ARG_WITH(log-hints,
-[  --with-log-hints=<hint1=x,hint2=y>  Semicolon-separated list of MPI-IO hints for log file write],
+[  --with-log-hints=<hint1=x;hint2=y>  Semicolon-separated list of MPI-IO hints for log file write],
     if test x$withval = xyes; then
         AC_MSG_ERROR(--with-log-hints must be given an argument)
     else
diff --git a/darshan-runtime/darshan-gen-cc.pl.in b/darshan-runtime/darshan-gen-cc.pl.in
index 7d034b6..b06910b 100644
--- a/darshan-runtime/darshan-gen-cc.pl.in
+++ b/darshan-runtime/darshan-gen-cc.pl.in
@@ -207,8 +207,7 @@ print OUTPUT<<"EOF";
     # if the user is using another PMPI based tool
     # if allargs includes any libraries, then we need to get
-    # -ldarshan-mpi-io in there first
-    # TODO: changing -ldarshan-mpi-io to -ldarshan OK ?
+    # -ldarshan in there first
     argno=0;
     once=0;
     compiler_check=0;
diff --git a/darshan-runtime/darshan-gen-cxx.pl.in b/darshan-runtime/darshan-gen-cxx.pl.in
index d04e347..59ddd84 100644
--- a/darshan-runtime/darshan-gen-cxx.pl.in
+++ b/darshan-runtime/darshan-gen-cxx.pl.in
@@ -207,7 +207,7 @@ print OUTPUT<<"EOF";
     argno=0;
     once=0;
     compiler_check=0;
diff --git a/darshan-runtime/darshan-gen-fortran.pl.in b/darshan-runtime/darshan-gen-fortran.pl.in
index b976f12..078b815 100644
--- a/darshan-runtime/darshan-gen-fortran.pl.in
+++ b/darshan-runtime/darshan-gen-fortran.pl.in
@@ -215,7 +215,7 @@ print OUTPUT<<"EOF";
     argno=0;
     once=0;
     compiler_check=0;
diff --git a/darshan-runtime/doc/darshan-runtime.txt b/darshan-runtime/doc/darshan-runtime.txt
index 34849ad..deb780f 100644
--- a/darshan-runtime/doc/darshan-runtime.txt
+++ b/darshan-runtime/doc/darshan-runtime.txt
@@ -40,40 +40,32 @@ make
 make install
-.Detecting file size and alignment
-[NOTE]
-You can also add --enable-stat-at-open option to cause the Darshan library
-to issue an additional stat() system call on each file the first time that
-it is opened on each process.  This allows Darshan to detect the file
-alignment (and subsequent unaligned accesses).  It also allows Darshan to
-detect the size of files at open time before any I/O is performed.
-Unfortunately, this option can cause significant overhead at scale on file
-systems such as PVFS or Lustre that must contact every server for a given
-file in order to satisfy a stat request.  We therefore disable this
-feature by default.
 .Explanation of configure arguments:
-* `--with-mem-align` (mandatory): This value is system-dependent and will be
+* `--with-mem-align=` (mandatory): This value is system-dependent and will be
 used by Darshan to determine if the buffer for a read or write operation is
 aligned in memory.
-* `--with-log-path` (this, or `--with-log-path-by-env`, is mandatory): This
-specifies the parent directory for the directory tree where darshan logs
-will be placed
-* `--with-jobid-env` (mandatory): this specifies the environment variable that
+* `--with-jobid-env=` (mandatory): this specifies the environment variable that
 Darshan should check to determine the jobid of a job.  Common values are
 `PBS_JOBID` or `COBALT_JOBID`.  If you are not using a scheduler (or your
 scheduler does not advertise the job ID) then you can specify `NONE` here.
 Darshan will fall back to using the pid of the rank 0 process if the
 specified environment variable is not set.
-* `CC=`: specifies the MPI C compiler to use for compilation
-* `--with-log-path-by-env`: specifies an environment variable to use to
+* `--with-log-path=` (this, or `--with-log-path-by-env`, is mandatory): This
+specifies the parent directory for the directory tree where darshan logs
+will be placed.
+* `--with-log-path-by-env=`: specifies an environment variable to use to
 determine the log path at run time.
 * `--with-log-hints=`: specifies hints to use when writing the Darshan log
 file.  See `./configure --help` for details.
 * `--with-zlib=`: specifies an alternate location for the zlib development
 header and library.
+* `CC=`: specifies the MPI C compiler to use for compilation.
+* `--disable-cuserid`: disables use of cuserid() at runtime.
+* `--disable-ld-preload`: disables building of the Darshan LD_PRELOAD library
+* `--disable-bgq-mod`: disables building of the BG/Q module (default checks
+and only builds if BG/Q environment detected).
+* `--enable-group-readable-logs`: sets darshan log file permissions to allow
+group read access.
 === Cross compilation
@@ -479,9 +471,6 @@ behavior at runtime:
 * DARSHAN_LOGHINTS: specifies the MPI-IO hints to use when storing the Darshan output file.  The format is a semicolon-delimited list of key=value pairs, for example: hint1=value1;hint2=value2
 * DARSHAN_MEMALIGN: specifies a value for system memory alignment
 * DARSHAN_JOBID: specifies the name of the environment variable to use for the job identifier, such as PBS_JOBID
-* DARSHAN_DISABLE_SHARED_REDUCTION: disables the step in Darshan aggregation
-in which files that were accessed by all ranks are collapsed into a single
-cumulative file record at rank 0.  This option retains more per-process
-information at the expense of creating larger log files.
+* DARSHAN_DISABLE_SHARED_REDUCTION: disables the step in Darshan aggregation in which files that were accessed by all ranks are collapsed into a single cumulative file record at rank 0.  This option retains more per-process information at the expense of creating larger log files. Note that it is up to individual instrumentation module implementations whether this environment variable is actually honored.
 * DARSHAN_LOGPATH: specifies the path to write Darshan log files to. Note that this directory needs to be formatted using the darshan-mk-log-dirs script.
-* DARSHAN_LOGFILE: specifies the path (directory + Darshan log file name) to write the output Darshan log to. This overrides the default Darshan behavior of automatically generating a log file name and adding to a log file directory formatted using darshan-mk-log-dirs script.
+* DARSHAN_LOGFILE: specifies the path (directory + Darshan log file name) to write the output Darshan log to. This overrides the default Darshan behavior of automatically generating a log file name and adding it to a log file directory formatted using darshan-mk-log-dirs script.
diff --git a/darshan-runtime/lib/darshan-core.c b/darshan-runtime/lib/darshan-core.c
index 17e6b77..96d2684 100644
--- a/darshan-runtime/lib/darshan-core.c
+++ b/darshan-runtime/lib/darshan-core.c
@@ -209,14 +209,14 @@ void darshan_core_initialize(int argc, char **argv)
             /* collect information about command line and mounted file systems */
             darshan_core->trailing_data = darshan_get_exe_and_mounts(darshan_core);
-    /* maybe bootstrap modules with static initializers */
-    i = 0;
-    while(mod_static_init_fns[i])
-        (*mod_static_init_fns[i])();
-        i++;
+        /* maybe bootstrap modules with static initializers */
+        i = 0;
+        while(mod_static_init_fns[i])
+            (*mod_static_init_fns[i])();
+            i++;
     if(internal_timing_flag)
@@ -226,8 +226,8 @@ void darshan_core_initialize(int argc, char **argv)
             MPI_DOUBLE, MPI_MAX, 0, MPI_COMM_WORLD);
         if(my_rank == 0)
-            printf("#darshan:<op>\t<nprocs>\t<time>\n");
-            printf("darshan:init\t%d\t%f\n", nprocs, init_max);
+            fprintf(stderr, "#darshan:<op>\t<nprocs>\t<time>\n");
+            fprintf(stderr, "darshan:init\t%d\t%f\n", nprocs, init_max);
@@ -303,7 +303,7 @@ void darshan_core_shutdown()
     /* set darshan job id/metadata and constuct log file name on rank 0 */
     if(my_rank == 0)
-        /* Use DARSHAN_JOBID_OVERRIDE for the env var or __DARSHAN_JOBID */
+        /* Use DARSHAN_JOBID_OVERRIDE for the env var for __DARSHAN_JOBID */
         envjobid = getenv(DARSHAN_JOBID_OVERRIDE);
         if(!envjobid)
@@ -661,18 +661,18 @@ void darshan_core_shutdown()
         if(my_rank == 0)
-            printf("darshan:log_open\t%d\t%f\n", nprocs, open_slowest);
-            printf("darshan:job_write\t%d\t%f\n", nprocs, job_slowest);
-            printf("darshan:hash_write\t%d\t%f\n", nprocs, rec_slowest);
-            printf("darshan:header_write\t%d\t%f\n", nprocs, header_slowest);
+            fprintf(stderr, "darshan:log_open\t%d\t%f\n", nprocs, open_slowest);
+            fprintf(stderr, "darshan:job_write\t%d\t%f\n", nprocs, job_slowest);
+            fprintf(stderr, "darshan:hash_write\t%d\t%f\n", nprocs, rec_slowest);
+            fprintf(stderr, "darshan:header_write\t%d\t%f\n", nprocs, header_slowest);
             for(i = 0; i < DARSHAN_MAX_MODS; i++)
                 if(global_mod_use_count[i])
-                    printf("darshan:%s_shutdown\t%d\t%f\n", darshan_module_names[i],
+                    fprintf(stderr, "darshan:%s_shutdown\t%d\t%f\n", darshan_module_names[i],
                         nprocs, mod_slowest[i]);
-            printf("darshan:core_shutdown\t%d\t%f\n", nprocs, all_slowest);
+            fprintf(stderr, "darshan:core_shutdown\t%d\t%f\n", nprocs, all_slowest);
diff --git a/darshan-runtime/lib/darshan-hdf5.c b/darshan-runtime/lib/darshan-hdf5.c
index b94010a..455ac06 100644
--- a/darshan-runtime/lib/darshan-hdf5.c
+++ b/darshan-runtime/lib/darshan-hdf5.c
@@ -476,7 +476,10 @@ static void hdf5_get_output_data(
     assert(hdf5_runtime);
     /* if there are globally shared files, do a shared file reduction */
-    if(shared_rec_count)
+    /* NOTE: the shared file reduction is also skipped if the
+     * DARSHAN_DISABLE_SHARED_REDUCTION environment variable is set.
+    if(shared_rec_count && !getenv("DARSHAN_DISABLE_SHARED_REDUCTION"))
         /* necessary initialization of shared records */
         for(i = 0; i < shared_rec_count; i++)
diff --git a/darshan-runtime/lib/darshan-mpiio.c b/darshan-runtime/lib/darshan-mpiio.c
index 672ff99..44c3253 100644
--- a/darshan-runtime/lib/darshan-mpiio.c
+++ b/darshan-runtime/lib/darshan-mpiio.c
@@ -1322,8 +1322,11 @@ static void mpiio_get_output_data(
             &(tmp->file_record->counters[MPIIO_ACCESS1_COUNT]));
-    /* if there are globally shared files, do a shared file reduction */
+    /* if there are globally shared files, do a shared file reduction */
diff --git a/darshan-runtime/lib/darshan-pnetcdf.c b/darshan-runtime/lib/darshan-pnetcdf.c
index 5f4c0d7..5a8ef4e 100644
--- a/darshan-runtime/lib/darshan-pnetcdf.c
+++ b/darshan-runtime/lib/darshan-pnetcdf.c
@@ -488,7 +488,10 @@ static void pnetcdf_get_output_data(
     assert(pnetcdf_runtime);
diff --git a/darshan-runtime/lib/darshan-posix.c b/darshan-runtime/lib/darshan-posix.c
index 0ef1a08..a77a7a4 100644
--- a/darshan-runtime/lib/darshan-posix.c
+++ b/darshan-runtime/lib/darshan-posix.c
@@ -2071,7 +2071,10 @@ static void posix_get_output_data(
hooks/post-receive
More information about the Darshan-commits mailing list
